Old 08-10-2009, 15:28   #736 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
COM7 [VCP1] selected
module v2.87
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:A660:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98000300000001:2BEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
921600
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.14EFB911.[HEXING23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.PRJ_C0 20B_2_1_MP_V3.BIN_64CDAB07].rpl
identification#1 detection finished
device-id: 14EFB911
identification#1 protocol ver: 04
ver. sw 1: HEXING23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.PRJ_C0 20B_2_1_MP_V3.BIN
ver. sw 2: PRJ_C020B_2_1_MP_V3, F854329B
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detect device identification#2...
detect device identification#2 finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\H EXING23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.PRJ_C02 0B_2_1_MP_V3__system_log_14EFB911_64CDAB07_2009081 0-202159.B0X.bin
Finished, time used: 45 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to cel_phon For This Useful Post:
Old 08-10-2009, 15:54   #737 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
A -ONE REPAIR OK
==== log: [8/10/2009 6:45:59 PM] ====
COM3 [VCP1] selected
module v2.87
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:CE03:0007
status: FF
Boot Done
Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
Initialize Done
Set baud ...
115200
Set baud Done
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
identification#1 structure: 2nd [standard] generation
ver. sw 1: A25_B_268D_F_8_PCB01_GPRS_MT6225_S00.GEMINI_1_0.BI N
ver. sw 2: A25_B_268D_F_8.GEMINI.1.0, 00000000
ffs/eeprom chip: 00
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 40 sec
The Following User Says Thank You to ehsas_ghum For This Useful Post:
Old 08-10-2009, 15:57   #738 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
My220x unlock done
COM3 [VCP0] selected
module v1.67
Device: Sagem-my220x
Action: unlock
unlock method-1
Boot ...
e-gold: 820010
loading...
middle part...
next part...
boot answer: 01
Boot Done
Set Baud ...
230400
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-static_20090805-135333.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-security_20090805-135333.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-complete_20090805-135336.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_lock-area_20090805-135351.B1E.bin
backup critical area Done
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 52 sec
Old 08-11-2009, 07:29   #739 (permalink)
taoujdate's Avatar
Member: 510826
Thanks Meter: 183
Unlock FLY Hi - SLDR Ok
module v2.79
Action: unlock
unlock method: smart fast
Model: Fly-Hi-SLDR
19200 autodetect
Initializing [6219:8B02:8B01]...
CPU: MT6219
chip: 0031:FD5F:BD7F
status: FF
detected CPU: MT6226MA
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6226M,E02
Date: 2005.04.12
Version: 1.0
Version: SL900A.05C.W06.08.MP.V72.F2
Version: ESL6227_05C_HW
60 byte(s) read
imei: 35274502019952
connection Ok
208 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
done
Finished, time used: 15 sec
The Following User Says Thank You to taoujdate For This Useful Post:
Old 08-11-2009, 10:07   #740 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
k200 restart with sim repair ok with infinty
COM1 [VSerial0] selected
module v1.32
Device: Sony-Ericsson-K200i
"advanced chip detection" active
Action: reset settings
Boot ...
Press Power button now !
loading...
Boot done
Check connection ...
Check connection done
Set baud ...
115200
Set baud done
Check hardware ...
flash: 01227E22212200:92EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
software version: R1AD001
software version: CXC1250831
version flex: CDA102773/6
imei: 35617701259072
Check hardware done
Read data ...
reading Sony-Ericsson-K200i_35617701259072_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K200i_35617701259072_eeprom_calibration-1_20090811-131208.80E.bin
reading Sony-Ericsson-K200i_35617701259072_eeprom_calibration-2...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K200i_35617701259072_eeprom_calibration-2_20090811-131216.80E.bin
Read data done
Check data ...
Check data done
Write ...
flash: 01227E22212200:46237300000000
Erase: ffs
Write done
Finished, time used: 62 sec
Old 08-11-2009, 11:35   #741 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
COM7 [VCP0] selected
module v2.87
Model: Autodetect 6205-6227 NOR
19200 autodetect
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:5B41:4D7C
status: FF
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: L364514.6.20.1.0T02M0926_M411C
Version: LCBJ26_05C_HW
detecting structure #2...
done
60 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
building list...
done
items to clear: 195
warning: wrong packet cs
items cleared: 195 of 195
building list...
done
items remains: 0
Finished, time used: 34 sec
Old 08-11-2009, 13:32   #742 (permalink)
.::adnangsm::.'s Avatar
Member: 802214
Sonork: 100.1573572
Thanks Meter: 95
Orange-Vegas(ZTE X760) unlock 100%okkkkkkkk
module v2.75
Device: Orange-Vegas
Action: "sp-unlock"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:4703:000A
status: FF
Boot Done
Initialize ...
flash: 01227E22312200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb
Initialize Done
Set baud ...
460800
Set baud Done
security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.D95AA F7A.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z15UK_FS_B0 7A105.BIN_C36BC17A].rpl
device-id: D95AAF7A
ver. sw 1: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z15UK_FS_B0 7A105.BIN
ver. sw 2: X760_Z15UK_FS_B07A105, 853E943C
sim-lock status: unknown
reading: Orange-Vegas_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z15UK _FS_B07A105__ffs...
file saved: C:\Program Files\InfinityBox\MModule\Orange-Vegas_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z15UK _FS_B07A105__ffs_20090811-172059.B0E.bin
detection procedure, wait...
detection procedure completed
detecting additional parameters...
error: additional parameters detection failed
Write: area 1/1
additional parameters detected Ok
Write: area 3/1
Write ...
Write: eeprom
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Orange-Vegas_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z15UK _FS_B07A105__system_log_D95AAF7A_C36BC17A_20090811-172349.B0X.bin
Finished, time used: 296 sec
The Following User Says Thank You to .::adnangsm::. For This Useful Post:
Old 08-11-2009, 14:03   #743 (permalink)
Member: 802214
Sonork: 100.1573572
Thanks Meter: 95
module v2.75
Action: "sp-unlock"
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
device-id: D95AAF7A
Write: area 1/1
Write: area 3/1
Write ...
Write: eeprom
Write Done
Finalization ...
Finalization Done
Old 08-11-2009, 16:14   #744 (permalink)
gsmpointhrp's Avatar
Member: 416286
Sonork: 100.1622339
Thanks Meter: 759
COM8 [VCP0] selected
module v1.66
Device: Huawei-T156
Action: unlock
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-static_20090811-180828.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-security_20090811-180829.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-complete_20090811-180831.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_lock-area_20090811-180835.B1E.bin
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 26 sec
The Following User Says Thank You to gsmpointhrp For This Useful Post:
Old 08-11-2009, 17:12   #745 (permalink)
GsmGalant's Avatar
Member: 87568
Thanks Meter: 101
Ot-s100 % unlocked
module v1.32
Device: Alcatel-S120
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Set baud ...
812500
Set baud done
Check hardware ...
flash: 012A7E2A242A00:54000000000000
flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb
Check hardware done
Read data ...
reading Alcatel-S120_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S120_eeprom_calibration-1_20090811-090034.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 64 sec
I canot find in this forum any thread about this phone so try with infinity and succesfull unlock.
Cable of V3, Pinout: RX-4, TX-3.
The Following 2 Users Say Thank You to GsmGalant For This Useful Post:
Old 08-11-2009, 21:50   #746 (permalink)
Member: 130995
Thanks Meter: 35,229
module v1.32
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Set baud ...
812500
Set baud done
Check hardware ...
Check hardware done
Read data ...
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Hello,
Please, read full flash from this phone and send full flash backup to [email protected]
Thank you !
Old 08-12-2009, 08:41   #747 (permalink)
GsmGalant's Avatar
Member: 87568
Thanks Meter: 101
Was sent, We hope in future good support from your briliant team!
The Following User Says Thank You to GsmGalant For This Useful Post:
Old 08-12-2009, 11:18   #748 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
Action: imei
Phone should be Switched ON !
Connecting, wait...
Hardware version: MT6226, E02
Hardware version: HEXING26_08B_GEMINI_HW
Software version: MAUI.08B.W09.08.MP.V
Software date: 2005.04.12
Barcode: MT012345678901234567
imei: 351695019898826
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono CPU
new imei: 350000000000006
verification Ok
Finished, time used: 9 sec
Power off phone now !
Old 08-12-2009, 11:52   #749 (permalink)
..::proudcracker::..'s Avatar
Member: 373786
Sonork: 100.1601935
Thanks Meter: 130
module v1.68
Device: Huawei-T161L
Action: unlock
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
sw version: 0 R_T161L_01 A_T161L_09 25 5 H5 5
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090811-173609.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090811-173610.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090811-173616.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090811-173636.B1E.bin
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 76 sec
The Following User Says Thank You to ..::proudcracker::.. For This Useful Post:
Old 08-12-2009, 13:20   #750 (permalink)
Member: 416286
Sonork: 100.1622339
Thanks Meter: 759
Originally Posted by InfinitySupport View Post
Hello,
Thank you !
i send you working flash file LG LG-KG195 ARIMA26
LG-KG195_ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001-R1C__fullflash_part_1_of_1_20090811-064225.B0X
@ [email protected]
as its missing from support area.
hope it help others and will help to infinity team more useful for us.
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.59969 seconds with 10 queries
