12-27-2010, 07:33 | #7576 (permalink) |
Freak Poster Join Date: Feb 2008 Location: royal mobiles kotla
Member: 714116 Status: Offline Thanks Meter: 48 | huawei g7002 unlocked module v3.71 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G7002 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:9503:0002 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: G5.2EG01V02.11 Version: P2 67 byte(s) read imei: 35645603182951 connection Ok 178 byte(s) read reading data... building new data... writing data... 166 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 10 sec Remove/Install battery now cable L10C+L08A |
The Following User Says Thank You to sajid11 For This Useful Post: |
12-27-2010, 09:28 | #7577 (permalink) |
No Life Poster Join Date: Aug 2007 Location: GREAT INDIA
Member: 559113 Status: Offline Sonork: 100.1596477 Thanks Meter: 760 | MAXX 322 repair done . COM4 [VCP0] selected module v3.25 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:95AB:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: MT226_AI_MAXX.B.ST7669V.V1.5 Version: MALATA23C_07B_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35471902871189 connection Ok building list... done items to clear: 107 items cleared: 107 of 107 building list... done items remains: 0 Finished, time used: 23 sec Remove/Install battery now ! |
The Following User Says Thank You to sonu arya For This Useful Post: |
12-27-2010, 09:44 | #7578 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | Nony Fm Code: COM3 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:0703:000D status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: R202AD_F10A_PCB01_GPRS_MT6225_S00.R202AD_GH_N202I_F10A_V01_100412.BIN project-id: R202AD_GH_N202I_F10A_V01_100412, 00000000 code offset: 00000000 ffs offset/size [01]: 00E40000/001C0000 rom info structure: [standard] type (05) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E40000 standard ffs/eeprom offset confirmed: 00E40000 detecting ffs/eeprom size... ffs/eeprom size: 001C0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E40000-00FFFFFF firmware area: 00000000-00E3FFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: R202AD_F10A_PCB01_GPRS_MT6225_S00.R202AD_GH_N202I_F10A_V01_100412__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\R202AD_F10A_PCB01_GPRS_MT6225_S00.R202AD_GH_N202I_F10A_V01_100412__ffs_20101227-141641.B0E.bin flash: 98000300000001:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2AEA0000000000 Finalization Done Finished, time used: 1 min 57 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to mbiborna For This Useful Post: |
12-27-2010, 09:47 | #7579 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Karachi pakistan Age: 41
Member: 388647 Status: Offline Sonork: sheerazi Thanks Meter: 161 | VODAFONE 541 sim unlock Successfull COM14 [VCP0] selected module v3.63 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:1703:A00E status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.A7485 31E.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_AB686FA6].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: A748531E rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, A66F68AB code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 17G provider: 708X-2GVDES1 customization: CN17FE92 customization: XN17FE92 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17FE92 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17FE92 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35908103094395 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_A748531E_AB686FA6_20101227-134130.B0X.bin Finished, time used: 5 min 56 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to asif ali For This Useful Post: |
12-27-2010, 10:11 | #7580 (permalink) |
Member: 388647 Status: Offline Sonork: sheerazi Thanks Meter: 161 | E71 imei repair ok Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-2: " imei write method: mode-1 imei write channel: imei #2 for dual sim/mono CPU new imei-2: 353955544154782 verification Ok Finished, time used: 9 sec Remove/Install battery now ! |
12-27-2010, 10:56 | #7581 (permalink) |
No Life Poster Join Date: Oct 2010 Location: INDIA (WEST BENGAL)
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | rm-145-6233 successfull by best no them-graphaic after flash with best this is the problem with best Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 6233 Software ver : V 05.60 14-09-07 RM-145 (c) Nokia IMEI : 354827024403659 Ape Ver : APE Var : APE ADSP: DSP Ver : pb05wk46v50 APE Test: PPM : V 05.60 14-09-07 RM123_145_- (c) Nokia W CNT : Content: india V 05.60 14-09-07 RM123_145_- (c) Nokia Product SN : CAL808309 Product code : 0500000 Base Prd.code: 0528588 Module code : Long Prod.SN : Hardware info======= HWID : 2013 Retu : 32 Tahvo : 53 Batery: 4827 mV Camera: CMT BT: APE BT: APE HW: LCDVer: SEIKO RF ic : 17211721 Lock info =========== IMEI : 354827024403659 IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm123_145_30005.600.mcusw PPM : rm123_145_3005.60.ppm_w CNT : rm123_145_30005.60.image_india Check FlashFiles, Please, wait... Backup enabled, Will read Certificates now... Backup CRT308 CRT308 Backup Created... CRT308 Backup Created... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 2A40011413D74F5013795A5E46D75044E5A4E42E CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 220800EC , CMT , NOR CMT Flash ID : 220800EC < SAMSUNG [SEC] => K8F5615ETM\K5G5629ATD FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent CMT PAPUB : 36DDC4990FD844712A61A80C033211BD9602E3C700 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 354827024403659 CMT : Read CCC certificate... Cert size : 0 byte(s) CMT : Read HWC certificate... Cert size : 0 byte(s) CMT : Read VARIANT certificate... Cert size : 20480 byte(s) Cert Read done! NPC Certificate saved... RPL saved : C:\Program Files\Best_v1.11\BEST_v1.11\Backup\Cert\3548270244 03659_2nd.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 2A40011413D74F5013795A5E46D75044E5A4E42E CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 220800EC , CMT , NOR CMT Flash ID : 220800EC < SAMSUNG [SEC] => K8F5615ETM\K5G5629ATD FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent CMT PAPUB : 36DDC4990FD844712A61A80C033211BD9602E3C700 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm123_145_30005.600.mcusw Found 7 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0000FFFF CMT , NOR , Area : 0x00010000 - 0x0007FFFF CMT , NOR , Area : 0x000A0000 - 0x0021FFFF CMT , NOR , Area : 0x00220000 - 0x011DDFFF CMT , NOR , Area : 0x011DE000 - 0x011DEFFF CMT , NOR , Area : 0x011DF000 - 0x011DFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:50 Transmission mode : Dual (Ddr, TX2) Write : Processing rm123_145_30005.600.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [PMM_CONF] CMT: Writing Hash CERT [SBIF_CONF] Total writen 1061 blocks TIME : Write time : 00:02:07 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm123_145_3005.60.ppm_w Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x011E0000 - 0x016DFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:14 Transmission mode : Dual (Ddr, TX2) Write : Processing rm123_145_3005.60.ppm_w Total writen 297 blocks TIME : Write time : 00:00:36 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm123_145_30005.60.image_india Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x016E0000 - 0x01E7FFFF CMT , NOR , Area : 0x01E80000 - 0x01FDFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:26 Transmission mode : Dual (Ddr, TX2) Write : Processing rm123_145_30005.60.image_india Total writen 148 blocks TIME : Write time : 00:00:18 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 6233 Software Info: V 05.60 14-09-07 RM-145 (c) Nokia IMEI: 354827024403659 Product code: 0500000 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Last edited by niloy2007; 12-27-2010 at 11:03. |
The Following 2 Users Say Thank You to niloy2007 For This Useful Post: |
12-27-2010, 20:20 | #7582 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 633231 Status: Offline Thanks Meter: 666 | COM1 [Serial0] selected module v3.64 Device: Alcatel-708X, 708A Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:F803:A00F status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22302200:09EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... slowest Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.90 123C0A.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_A0891A20].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 90123C0A rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, 201A89A0 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 16Z provider: 708A-2CRGDO3 customization: CN16NQ30 customization: XN16NQ30 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 01224100315609 flash: 01227E22302200:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22302200:09EA0000000000 Finalization Done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_90123C0A_A0891A20_20 101227-031924.B0X.bin Finished, time used: 3 min 29 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to thewolverine For This Useful Post: |
12-28-2010, 04:32 | #7583 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 560185 Status: Offline Thanks Meter: 101 | unit problem: stucked on welcome only Read firmware: Code: ==== [12/28/2010 10:56:37 AM] ==== COM4 [VCP0] selected module v3.24 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read firmware ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:63CE:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 208848FFFFFFFF:20884800000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #01 in region #00... flash: 208848FFFFFFFF:20884800000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #02 in region #00... flash: 000001000E000F:00000100000000 flash: 000001000E000F:00000100000000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 208848FFFFFFFF:20884800000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #01 in region #00... flash: 208848FFFFFFFF:20884800000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 it's time to stop: 2F0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: DAYO23C_08B_PMWY_PCB01_GPRS_MT6223_S00.MAUI_08B_W08_48_MP_V6_F8.BIN project-id: MAUI.08B.W08.48.MP.V6.F8, 00000000 code offset: 00000000 ffs offset/size [01]: 00760000/000A0000 rom info structure: [standard] type (05) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00760000 standard ffs/eeprom offset confirmed: 00760000 detecting ffs/eeprom size... ffs/eeprom size: 000A0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00760000-007FFFFF firmware area: 00000000-0075FFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: DAYO23C_08B_PMWY_PCB01_GPRS_MT6223_S00.MAUI_08B_W08_48_MP_V6_F8__firmware_part_1_of_1... file saved: F:\Program Files\InfinityBox\ChineseMiracle\DAYO23C_08B_PMWY_PCB01_GPRS_MT6223_S00.MAUI_08B_W08_48_MP_V6_F8__firmware_part_1_of_1_20101228-110220.B0M.bin Finished, time used: 5 min 37 sec Remove/Install battery now ! FFS Format - Complete mode: Code: WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [12/28/2010 11:04:09 AM] ==== COM4 [VCP0] selected module v3.24 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:63CE:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 208848FFFFFFFF:20884800000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #01 in region #00... flash: 208848FFFFFFFF:20884800000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #02 in region #00... flash: 000001000E000F:00000100000000 flash: 000001000E000F:00000100000000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 208848FFFFFFFF:20884800000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #01 in region #00... flash: 208848FFFFFFFF:20884800000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 it's time to stop: 2F0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: DAYO23C_08B_PMWY_PCB01_GPRS_MT6223_S00.MAUI_08B_W08_48_MP_V6_F8.BIN project-id: MAUI.08B.W08.48.MP.V6.F8, 00000000 code offset: 00000000 ffs offset/size [01]: 00760000/000A0000 rom info structure: [standard] type (05) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00760000 standard ffs/eeprom offset confirmed: 00760000 detecting ffs/eeprom size... ffs/eeprom size: 000A0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00760000-007FFFFF firmware area: 00000000-0075FFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: DAYO23C_08B_PMWY_PCB01_GPRS_MT6223_S00.MAUI_08B_W08_48_MP_V6_F8__ffs... file saved: F:\Program Files\InfinityBox\ChineseMiracle\DAYO23C_08B_PMWY_PCB01_GPRS_MT6223_S00.MAUI_08B_W08_48_MP_V6_F8__ffs_20101228-110517.B0E.bin flash: 208848FFFFFFFF:20884800000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 208848FFFFFFFF:20884800000000 Finalization Done Finished, time used: 1 min 35 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! IMEI #1 and #2 Repair: Code: Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 012345678910234 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 359877740026529 verification Ok Finished, time used: 24 sec Remove/Install battery now ! Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-2: 012345678910234 imei write method: mode-1 imei write channel: imei #2 for dual sim/mono CPU new imei-2: 359877740026537 verification Ok Finished, time used: 3 sec Remove/Install battery now ! |
The Following User Says Thank You to amats211 For This Useful Post: |
12-28-2010, 05:38 | #7584 (permalink) |
Banned Join Date: Nov 2009
Member: 1162712 Status: Offline Sonork: 100.1594855 Thanks Meter: 230 | Micromax-C111 new version unlock done c111 new version unlock done ==== [28/12/2010 10:02:13 AM] ==== COM3 [QCUSB_COM3_1] selected module v1.41 Device: Micromax-C111 operation: Read information Phone should be Switched ON ! connecting... --------------------------------------------------------- HARDWARE : CJF 10 I COMPILE : Oct 09 2010 (20:37:49) REALEASE : Oct 27 2009 (23:00:00) SW Version : CIK 4 01 13 IN s --------------------------------------------------------- Phonce code : 0000 Finished, time used: 3 sec ==== [28/12/2010 10:02:22 AM] ==== COM3 [QCUSB_COM3_1] selected module v1.41 Device: Micromax-C111 operation: SP-unlock Phone should be Switched ON ! connecting... CJF.10.IOct 09 2010 MICROMAX C111 09 Oct 2010 selected.. Offline.. Downloading mode.. prepare for patching... try conecting..1 Sending Boot.. patching in progress... patching in progress 50%... patching in progress 100%... done... Finished, time used: 42 sec ==== [28/12/2010 10:03:37 AM] ==== COM3 [QCUSB_COM3_1] selected module v1.41 Device: Micromax-C111 operation: Read information Phone should be Switched ON ! connecting... --------------------------------------------------------- HARDWARE : CJF 10 I COMPILE : Oct 09 2010 (20:37:49) REALEASE : Oct 27 2009 (23:00:00) SW Version : CIK 4 01 13 IN s --------------------------------------------------------- Phonce code : 0000 Finished, time used: 3 sec |
The Following 3 Users Say Thank You to anil_prajapati For This Useful Post: |
12-28-2010, 05:59 | #7585 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | China flashed (write flash NAND) Code: COM6 [Serial2] selected module v3.25 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: write flash NAND write: Firmware E709C_JSZ4CWIF11_PCB01_GPRS_MT6235B_S01.E709C_XBD_4C_WIFI_F11_01_1_2010-07-31_EVEN35_08B_HW_COMMON_200W30W10W__iPhone-X6128m_En_Ru_Gr_Fr_Es_It_Pl_De_Ml_Id_Vn_Tr_Pt_Bg_Cn_Ar.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: E709C_BOOTLOADER_V005_MT6235B_01_1.bin nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[001E]: 0020:007600200076 [ST] ST512W3A chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done nfi area detection... external bootloader is not present bootloader version: E709C_BOOTLOADER_V005_MT6235B_01_1.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . . . . . . write core... Disconnect... done Finished, time used: 63 min 4 sec Remove/Install battery now ! |
The Following User Says Thank You to akashub For This Useful Post: |
12-28-2010, 07:02 | #7586 (permalink) |
Freak Poster Join Date: Oct 2008
Member: 877161 Status: Offline Thanks Meter: 48 | Successfully unlocked/repaired phones by Infinity-Box ZTE g-N281 Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: TMO_UK_P107A3V1.0.2B11 Version: 09AZTENJ35_09A 83 byte(s) read imei: 3576920xxxxxxx connection Ok 189 byte(s) read reading data... reading data #2... building new data... writing data... 177 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 34 sec Remove/Install battery now ! |
The Following User Says Thank You to faruk_gsm For This Useful Post: |
12-28-2010, 08:46 | #7587 (permalink) |
Freak Poster Join Date: Jun 2010 Location: Denmark
Member: 1329373 Status: Offline Thanks Meter: 87 | n97 ok COM4 [VCP0] selected module v3.24 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E403:0002 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: WQVGA_PCB01_GPRS_MT6225_S00.TYCWQVGA1_01.BIN project-id: TYCWQVGA1.01, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:18E59F00000000 Finalization Done Finished, time used: 56 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to AL-KARAM MOBILE For This Useful Post: |
12-28-2010, 09:26 | #7588 (permalink) |
Member: 1329373 Status: Offline Thanks Meter: 87 | china ok with infinity support COM4 [VCP0] selected module v3.25 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:6903:0005 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: ELT25.X05_128.HW11.V14.MUL1 Version: ELT25.X05_128.HW11.M1 detecting structure #2... 5 11 done 67 byte(s) read imei: 35668548102267 connection Ok building list... done items to clear: 174 warning: wrong packet cs warning: wrong packet cs items cleared: 174 of 174 building list... done items remains: 0 Finished, time used: 32 sec Remove/Install battery now ! |
12-28-2010, 09:55 | #7590 (permalink) |
Member: 1329373 Status: Offline Thanks Meter: 87 | n97 china touchscreen calibration COM4 [VCP0] selected module v3.24 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... WQVGA_PCB01_GPRS_MT6225_S00.TYCWQVGA1_01__fullflas h_20101228-133358.B0M.bin loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E403:0002 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: TYCWQVGA1.01 Version: TYCWQVGA 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok 512 byte(s) read 210 byte(s) read reading data #2... 512 byte(s) read calibration value: 0 writing data... verification... verification Ok Finished, time used: 15 sec Remove/Install battery now ! |
