04-22-2024, 20:01 | #76096 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | Infinix-X6515 Frp Code: Product Brand: Infinix Product Device: Infinix-X6515 Product Model: Infinix X6515 Product Name: X6515-OP SW: Infinix/X6515-OP/Infinix-X6515:12/SP1A.210812.016/231116V1059:user/release-keys Patch Level: SP1A.210812.016 Display ID: X6515-H6127HIJAiAjAk-S-OP-231116V1059 SW Version: 231116V1059 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-11-05 Build Time: 16/11/2023 1:00:11 pm Product Info: x6515_h6127 SW: vnd_x6515_h6127-user 12 SP1A.210812.016 481387 release-keys Product Manfct: INFINIX Product Board: Infinix-X6515 Board Platform: mt6761 Strategy: [none|generic] Firmware ID: MT6761_INFINIX_Infinix_X6515_OSv12_X6515-H6127HIJAiAjAk-S-OP-231116V1059_SP1A.210812.016_x6515_h6127 Verify firmware [MT6761_INFINIX_Infinix_X6515_OSv12_X6515-H6127HIJAiAjAk-S-OP-231116V1059_SP1A.210812.016_x6515_h6127]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0xA2 Size: 0x08C3C7 State: Ok WiFi MAC: AA006E742F76 BlTh MAC: 408EF6677772 IMEI[1]: IMEI[2]: Verify config values... Ok Loaders Ok STORAGE Life Status: eMMC : OK STORAGE OTP Status: UNLOCKED STORAGE RPMB Status: eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Reset port... Done: 00:00:33 Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [-] Userdata [+] FRP [-] Smart WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM12) MODE [0]: PRELOADER PORT; PORT: 12 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: CA9D053C004156079C239463E8909FF024EF405911815869012045243E0A421A IRG: 0x00000080 AGENT: AUTO: Infinix: 2023-11 [d0ad8d98] C:\InfinityBox\CM2MT2\boot\Infinix\2023-11\MTK_AllInOne_DA_BR.bin [f835e4ca] C:\InfinityBox\CM2MT2\boot\Infinix\2023-11\auth_sv5.auth Looking for suitable BootChain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A600 [ 233.50 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: D6010341334135363112437277D1193D crc Ok Ven: Foresee OEM: 259 ID: 413341353631 [A3A561] PRV: 0x12 SNN: 1131575249 [0x437277D1] MM/YY: 1/2022 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE67800000 [ 57.62 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: CF9C44D8C88FCE8BFE64E7A49A034C93 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 50 Strategy: [none|generic] Verify config values... Ok Loaders Ok Stage: Android OS Off Stage: FRP... [1] PROTECTION... Done Reset port... Trying to reboot... Done: 00:00:22 Reconnect Power/Cable now |
04-23-2024, 09:49 | #76097 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Infinity Team
Member: 2072265 Status: Offline Thanks Meter: 47 | redmi 9 frp remove done Operation: Reset Settings/Format FS [ v2.57 ] [+] Smart Analyzer [-] Wipe [-] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make [Userdata] On and repeat operation Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port (COM3) MODE [0]: BOOTROM; PORT: 3 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 407B940D25D1DE0895987EB9C6F2BD1E BROM: Sec Level: 0x000000E7 Mode: SBC+SLA+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 64187B59F1D252DB9AB369C79F30E4C10EA1224CAF928DF07F 6DD2E7BA47EC51 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok EMI known SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 407B940D25D1DE0895987EB9C6F2BD1E AGENT: AUTO: 0_base: base_v2316 [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for suitable bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 450100444134303634011A301115671F crc Ok Vendor: Sandisk OEM: 256 ID: 444134303634 [DA4064] PRV: 0x01 Serial: 439357717 0x1A301115 MM/YY: 6/2020 EMI: FireFly preloader_k65v1_64_bsp.bin with 10 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb 3. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb 7. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 6.00 Gb 8. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 6.00 Gb 9. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 10. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 450100444134303634011A301115671F crc Ok Vendor: Sandisk OEM: 256 ID: 444134303634 [DA4064] PRV: 0x01 Serial: 439357717 0x1A301115 MM/YY: 6/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 50A23340FF8B2974B26AAF88D6AAF130 MEID: 407B940D25D1DE0895987EB9C6F2BD1E USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 43 Select info source... [recovery] Ok SW: Redmi/angelica_global/angelica:10/QP1A.190711.020/V12.0.21.0.QCRMIXM:user/release-keys Product Brand: Redmi Product Device: angelica Product Model: M2006C3MG Product Name: angelica_global Market Name: Redmi 9C Patch Level: QP1A.190711.020 Display ID: QP1A.190711.020 SW Version: V12.0.21.0.QCRMIXM Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-03-01 Build Time: 3/6/2022 2:11:36 PM CPU: armeabi-v7a,armeabi Product Info: angelica SW: angelica-user 10 QP1A.190711.020 V12.0.21.0.QCRMIXM release-keys Product Manfct: Xiaomi Product Board: angelica Board Platform: mt6765 Device ID: xiaomi-m2006c3mg-angelica-angelica-global-redmi-9c Strategy: [xiaomi] Firmware ID: MT6765_Xiaomi_M2006C3MG_OSv10_V12.0.21.0.QCRMIXM_Q P1A.190711.020_angelica_Redmi Android ver: 10 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] EMMC CID: 450100444134303634011A301115671F crc Ok Vendor: Sandisk OEM: 256 ID: 444134303634 [DA4064] PRV: 0x01 Serial: 439357717 0x1A301115 MM/YY: 6/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Verify config values... Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6765__407B940D25D1D E0895987EB9C6F2BD1E\ Items to check: 22 Read [31] NVRAM NVRAM: Items: 0xB4 Size: 0x0ADDD0 [SecLv: Vendor Signed] State: Ok WiFi MAC: 64A2001BFBCA BT MAC: 64A2001C70FA IMEI[1]: 865936050010072 IMEI[2]: 865936050236578 Read [13] NVDATA Read [21] PROINFO Read [32] LK Read [12] NVCFG Read [16] PROTECT1 Read [1] PGPT Read [19] PERSIST Read [0] PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__407B940D25D1D E0895987EB9C6F2BD1E\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__407B940D25D1D E0895987EB9C6F2BD1E.7z Verified Stage: Android OS Off Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 47 sec Reconnect Power/Cable now |
04-24-2024, 06:20 | #76098 (permalink) |
Member: 2072265 Status: Offline Thanks Meter: 47 | i251 format done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 117 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 068BD2453018B9489A6469CB8549BE04 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x00399000-0x003FDFFF , LEN : 0x00065000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
04-25-2024, 12:49 | #76099 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | Xcell View Format & Frp Code: Operation: Reset Settings/Format FS [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM12) MODE [0]: PRELOADER PORT; PORT: 12 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 25D315CC4845440BD3DE976684CE90F60DFCBEC0347FC96B63DD9901FE3C2359 AGENT: AUTO: 0_base: base_v2316 [1d5fdec4] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for suitable BootChain in DA... Found: MT6739; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 150100523331424142063CA7568C62A1 crc Ok Ven: Samsung OEM: 256 ID: 523331424142 [R31BAB] PRV: 0x06 SNN: 1017599628 [0x3CA7568C] MM/YY: 6/2015 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x3A3E00000 [ 14.56 Gb ] CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] RNID: A673A9E3014818DB4293C1FEC83D7E95 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 34 Select info source... recovery [1800000] Ok Patch Level: O11019 Display ID: View_20180831 SW Version: 20180824 Ver. CodeName: REL Ver. Release: 8.1.0 Sec. Patch: 2018-08-05 Build Time: 31/08/2018 6:28:52 am Product Model: View Product Brand: Xcell Product Name: View Product Device: View CPU: armeabi-v7a,armeabi Product Manfct: Vanzo Product Info: fd610b SW: full_fd610b-user 8.1.0 O11019 20180824 release-keys Product Board: fd610b Board Platform: mt6739 Strategy: [none|generic] SmartInfo: Android Ver: 8 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Verify config values... Ok Loaders Ok Stage: Android OS [1] ... Create image... Ok Ok [2] ... Create image... Ok Ok [4] USERDATA... Ok Stage: FRP... [1] PROTECTION... Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Done: 00:00:26 Reconnect Power/Cable now |
04-25-2024, 14:22 | #76100 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | OALE XS1 Format & Frp Code: Product Manfct: magcomm Patch Level: O11019 Display ID: DIS_OALE_XS1_V1.0_20190907 SW Version: 1558493853 Ver. CodeName: REL Ver. Release: 8.1.0 Sec. Patch: 2019-04-05 Build Time: 07/09/2019 4:09:16 am Product Model: XS1 Product Brand: OALE Product Name: XS1 Product Device: XS1 CPU: armeabi-v7a,armeabi Product Info: XS1 SW: full_k80hd_bsp_fwv_512m-user 8.1.0 O11019 1567829358 release-keys Product Board: k80hd_bsp_fwv_512m Board Platform: mt6580 Strategy: [none|generic] Firmware ID: MT6580_magcomm_XS1_OSv8.1.0_DIS_OALE_XS1_V1.0_20190907_O11019_XS1 Verify firmware [MT6580_magcomm_XS1_OSv8.1.0_DIS_OALE_XS1_V1.0_20190907_O11019_XS1]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem : [f2fs] with FDE [encryptable] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0x78 Size: 0x02999A State: Ok WiFi MAC: 00120D390962 BlTh MAC: 804010038082 IMEI[1]: IMEI[2]: Verify config values... Ok Loaders Ok Reset port... Done: 00:00:26 Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [-] Userdata [+] FRP [-] Smart WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM12) MODE [0]: PRELOADER PORT; PORT: 12 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x01 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v2316 [1d5fdec4] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for suitable BootChain in DA... Found: MT6580; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started NAND: DEVICE NOT FOUND EMMC: OK CID: 410001153444544AE2DB0052FB558603 DA v4.2.156 DA: DRAM ready Boot to 2nd DA... Ok Load HW info... EMMC CID: 150100414A5444345200DBE2038655FB crc Ok Ven: Samsung OEM: 256 ID: 414A54443452 [AJTD4R] PRV: 0x00 SNN: 3689022342 [0xDBE20386] MM/YY: 5/2018 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x3AB400000 [ 14.68 Gb ] RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0x40000000 [ 1024.00 Mb ] CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] RNID: C6C19F7D220F28E5BCD81A71CA6A7489 DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: HIGH-SPEED Boot done LEGACY [MTK] Analyze PMT... Ok PMT: LGPT [0x06] Records: 30 Strategy: [none|generic] Verify config values... Ok Loaders Ok Stage: Android OS Off Stage: FRP... [1] PROTECTION... Done Reset port... Trying to reboot... Done: 00:00:19 Reconnect Power/Cable now |
04-25-2024, 15:03 | #76101 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,778 | QMOBILE I6I RESET FRP DONE BY CM2 Card found : 73CA70CC , v0160 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : QMobile : i6i-2020 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:17 |
04-25-2024, 18:41 | #76103 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Chile
Member: 1797183 Status: Offline Thanks Meter: 153 | Reset Mi account Mi 11t amber sucess Code: Operation: Reset Settings/Format FS [ v2.58a7 (beta) ] [+] Smart Analyzer [-] Wipe [-] Userdata [-] FRP [+] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Analyze PMT... Ok PMT: PGPT [0x64] Records: 77 Product Brand: Xiaomi Product Device: agate Product Model: agate Product Name: vnd_agate SW: Xiaomi/vnd_agate/agate:12/SP1A.210812.016/V13.0.2.0.SKWMIXM:user/release-keys Patch Level: SP1A.210812.016 Display ID: SP1A.210812.016 SW Version: V13.0.2.0.SKWMIXM Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2022-01-01 Build Time: 18-02-2022 12:15:19 Product Info: agate SW: vnd_agate-user 12 SP1A.210812.016 V13.0.2.0.SKWMIXM release-keys Product Manfct: Xiaomi Product Name: amber Product Board: agate Board Platform: mt6893 Device ID: xiaomi-agate-vnd-agate-amber Strategy: [xiaomi] Firmware ID: MT6893_Xiaomi_agate_OSv12_V13.0.2.0.SKWMIXM_SP1A.210812.016_agate Android ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] UFS CID: CE014B4C55454738554844432D423045 Ven: 0x01CE VID: KLUEG8UHDC-B0E IFW: 0200 LU0: 0x00400000 [ 4.00 Mb ] LU1: 0x00400000 [ 4.00 Mb ] LU2: 0x3B96000000 [ 238.34 Gb ] FSN: 5a497a3dbd29 REG: 0x303010000 Verify config values... Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6893__27CF6005146526FE10DD8624BAC53A6F Stage: Android OS Off Stage: Smart... Nothing to-do Stage: Accounts... Mi Account Probe Mi Account... Reset Account... Done Finished 10 sec Keep connection Bootloader must be UNLOCKED Unlock Bootloader first! Continue? Yes Operation: Mi Account [Permanent] [ v2.58a7 (beta) ] Wait... Analyze PMT... Ok PMT: PGPT [0x64] Records: 77 Product Brand: Xiaomi Product Device: agate Product Model: agate Product Name: vnd_agate SW: Xiaomi/vnd_agate/agate:12/SP1A.210812.016/V13.0.2.0.SKWMIXM:user/release-keys Patch Level: SP1A.210812.016 Display ID: SP1A.210812.016 SW Version: V13.0.2.0.SKWMIXM Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2022-01-01 Build Time: 18-02-2022 12:15:19 Product Info: agate SW: vnd_agate-user 12 SP1A.210812.016 V13.0.2.0.SKWMIXM release-keys Product Manfct: Xiaomi Product Name: amber Product Board: agate Board Platform: mt6893 Device ID: xiaomi-agate-vnd-agate-amber Strategy: [xiaomi] Firmware ID: MT6893_Xiaomi_agate_OSv12_V13.0.2.0.SKWMIXM_SP1A.210812.016_agate Backup exist: C:\InfinityBox\CM2MT2\backup\MT6893__27CF6005146526FE10DD8624BAC53A6F Probe Mi Account... Reset Account... Done Finalize... load local files: 2 load local buffer: 3452 56 => 3452 Processed 1 items In some cases you may need to RESET device Configure [4] Ok [5] Ok [6] Ok [7] Ok [8] Ok [9] Ok UFS CID: CE014B4C55454738554844432D423045 Ven: 0x01CE VID: KLUEG8UHDC-B0E IFW: 0200 LU0: 0x00400000 [ 4.00 Mb ] LU1: 0x00400000 [ 4.00 Mb ] LU2: 0x3B96000000 [ 238.34 Gb ] FSN: 5a497a3dbd29 REG: 0x303010000 Verify config values... Ok Finished 8 sec Keep connection Probe Mi Account... Account is Off or not detected Finished 54 sec Keep connection |
The Following User Says Thank You to Clinphone For This Useful Post: |
04-26-2024, 06:02 | #76104 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,433 | Oppo A1k Format Done Operation: Reset Settings/Format FS [ v2.58a4 (beta) ] [+] Smart Analyzer [-] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1632 (COM24) MODE [0]: BOOTROM; PORT: 24 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: FF191ABE191D5A80CEFF63CF49C867DC BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 0FBB26CB9F7B591E19792C30940EB977E81AEF86F10DE15169 73975078DEA7BF SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: FF191ABE191D5A80CEFF63CF49C867DC AGENT: AUTO: Oppo: A1K-A12-A31-A32 [c9a7041e] C:\InfinityBox\CM2MT2\boot\0_BASE\BASE_v2044\MTK_A llInOne_DA.27da5d71.bin Looking for suitable bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100514436334D420333EDAAC11683 crc Ok Vendor: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 Serial: 871213761 0x33EDAAC1 MM/YY: 1/2019 EMI: FireFly preloader_oppo6762_18540.bin with 9 memory type(s) 1. eMMC DDR3 ID: 150100515836334142 Samsung QX63AB RAM: 2.00 Gb 2. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC DDR3 ID: 90014A484147346132 Hynix HAG4a2 RAM: 2.00 Gb 4. eMMC DDR3 ID: 13014E53304A394237 Micron S0J9B7 RAM: 3.00 Gb 5. eMMC DDR3 ID: 150100514536334D42 Samsung QE63MB RAM: 2.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 7. eMMC DDR3 ID: 150100524436344D42 Samsung RD64MB RAM: 4.00 Gb 8. eMMC DDR3 ID: 150100514436334D42 Samsung QD63MB RAM: 2.00 Gb 9. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 150100514436334D420333EDAAC11683 crc Ok Vendor: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 Serial: 871213761 0x33EDAAC1 MM/YY: 1/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: C380340485F429352E8F60E60237139E MEID: FF191ABE191D5A80CEFF63CF49C867DC USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 42 Probe boot... Patch Level: PPR1.180610.011 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2021-01-05 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: OPPO SW: full_oppo6762_18540-user 9 PPR1.180610.011 eng.root.20201221.133342 release-keys Build Time: 21-Dec-20 5:37:55 AM SW Version: 1608529075 Product Brand: OPPO Product Model: CPH1923 Product Info: CPH1923 Product Name: CPH1923 Product Device: OP486C SW OTA Version: CPH1923EX_11.A.38_0380_202012211313 Display ID: CPH1923EX_11_A.38 Kernel Info: 4.9.117 Device ID: oppo-cph1923-op486c-MT6765_CPH1923EX_11_A.15_190418_3ebe20b4 Strategy: [oppo] Firmware ID: MT6765_OPPO_CPH1923_OSv9_CPH1923EX_11_A.38_PPR1.18 0610.011_CPH1923.MT6765_CPH1923EX_11_A.15_190418_3 ebe20b4 Android ver: 9 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 150100514436334D420333EDAAC11683 crc Ok Vendor: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 Serial: 871213761 0x33EDAAC1 MM/YY: 1/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] Verify config values... Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6765__FF191ABE191D5 A80CEFF63CF49C867DC\ Items to check: 22 Read [29] NVRAM NVRAM: Items: 0xBB Size: 0x0ACAB4 State: Ok WiFi MAC: 4883B4BFF409 BT MAC: 4883B4BFF408 Read [13] NVDATA Read [20] PROINFO Read [30] LK Read [12] NVCFG Read [15] PROTECT1 Read [1] PGPT Read [18] PERSIST Read [0] PRELOADER Read [5] OPPORESERVE1 Read [7] OPPORESERVE3 ZERO CONTENT file [64.00 Mb] deleted: C:\InfinityBox\CM2MT2\backup\MT6765__FF191ABE191D5 A80CEFF63CF49C867DC\opporeserve3.bin Read [8] OPPO_CUSTOM Done 11 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__FF191ABE191D5 A80CEFF63CF49C867DC\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__FF191ABE191D5 A80CEFF63CF49C867DC.7z Verified Stage: Android OS [1] ... Create partition image... Ok Ok [2] ... Create partition image... Ok Ok [4] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 1 min 27 sec Reconnect Power/Cable now |
04-26-2024, 08:18 | #76105 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | ITEL P40 4G RESET FRP DONE BY CM2 Card found : 73CA70CC , v0160 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : iTel : itel-s663l.460f890f.04b4b7c0 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:17 |
04-26-2024, 12:26 | #76106 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | NOKIA 105 4G TA 1389 READ FLASH FILE DONE BY CM2 Card found : S/N : 73CA70CC , v0160 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : FAD715169F15B75C43590CDF9D62E95E BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : J115_5_BOE_R1_7003_PCB01_gsm_MT6260_S00.J115_5_GCZ L7003_BOE_RED1_V1.bin FileVersion : J115_5_GCZL7003_BOE_Red1_V1 Done! Elapsed: 00:00:10 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : FAD715169F15B75C43590CDF9D62E95E BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Reading Flash Content now ... Read Flash now Read Ok , 3145728 bytes read Check and collect compile info File_Info : J115_5_BOE_R1_7003_PCB01_gsm_MT6260_S00.J115_5_GCZ L7003_BOE_RED1_V1.bin FileVersion : J115_5_GCZL7003_BOE_Red1_V1 Saved to : C:\InfinityBox\CM2MTK\Read_out\J115_5_BOE_R1_7003_ PCB01_gsm_MT6260_S00.J115_5_GCZL7003_BOE_RED1_V1.b in Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
04-26-2024, 14:29 | #76107 (permalink) |
No Life Poster Join Date: Nov 2012 Age: 52
Member: 1835756 Status: Offline Thanks Meter: 922 | Itel a49(a58 pro 4g)frp done ITEL A49(A58 PRO 4G) MODEL-A661L AV-11 Wait... S/N: 00904B323D v0160 Chinese Miracle II - SP3 Service Tool v2.27a3 (beta) Init log engine... Ok Build directories tree... Backup files: C:\Users\mobitech\Desktop\INFINITY SETUPS\CM2SP3_2.27a3\backup\ Backup files: 0 dirs: 0 Build device list... SP3 boot-pack v1.07 2024-03-23 Ok Check for updates [boot-pack]... Socket Error # 11001 Host not found. Check for updates [CM2SP3]... Socket Error # 11001 Host not found. Ready Selected: iTel A04 [Boot [FF] FireFly] mmc [FF] protocol may be SLOW, for flash Read/Write use [FDL] Selected: iTel A58-pro-4g [Boot [FF] FireFly] mmc [FF] protocol may be SLOW, for flash Read/Write use [FDL] Operation: Connect [sc9832e Boot [FF] FireFly] [v2.27a3 (beta)] Wait... - Power device Off - Connect cable [remember Vol+ | Vol-] [remember Test-Point] Waiting for device... Device found PTFN: SPRD U2S Diag (COM9) vid 0x1782 pid 0x4D00 boot: SPRD3 boot iLoader... Ok start iLoader... Ok Handshake... Ok boot xLoader... Ok start FireFly... Ok Loader exec Ok Dev UID: 2f2173ffcadd03763f920c89965443108fb245d3b6c9f63fdf 90acbcaa164d4e get storage info... EMMC CID: 150100515836334142031920CC3FA817 crc Ok Vendor: Samsung OEM: 256 ID: 515836334142 [QX63AB] PRV: 0x03 Serial: 421579839 0x1920CC3F MM/YY: 10/2021 CSD: D02701320F5903FFF6DBFFEF8E404001 temp_write_protect: False perm_write_protect: False wp_group: 0x10 en 0x01 EXTCSD rev1.8 EMMC 5.1 FW: 03 ERASE_GROUP_DEF: 0x0400 BOOT_BUS_WIDTH: 0x00 PARTITION_CONFIG: 0x08 RST_N_FUNCTION: 0x01 PART_S_COMPLETED: False BOOT0/BOOT1 size: 0x400000 4.00 Mb RPMB size: 0x400000 4.00 Mb WP_GRP_SIZE: 0x800000 8.00 Mb Size: Market 32 Gb Actual 0x747C00000 29.12 Gb EOL: Status: Normal: Less than 80% reserved blocks used EOL_A: SLC status: 10% - 20% used EOL_B: MLC status: 10% - 20% used read extcsd... Ok extcsd stored: C:\Users\mobitech\Desktop\INFINITY SETUPS\CM2SP3_2.27a3\backup\ext_csd\sc9832_2f2173f fcadd0376_extcsd_0015-Samsung_QX63AB_5.1_2024-04-26.bin Verify config values... Socket Error # 11001 Host not found. get partitions... Partitions: 73 Connected get sw info... SW: Itel/A661L/itel-A661L:11/RP1A.201005.001/OP-V008-20220221:user/release-keys Product Brand: Itel Product Device: A661L Product Model: itel A661L Product Name: A661L Patch Level: RP1A.201005.001 Display ID: A661L-V490AE-11.0-OP-V008-20220221 SW Version: OP-V008-20220221 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2022-02-05 Build Time: 2/21/2022 4:21:40 AM Product Device: itel-A661L Market Name: itel A49(A58 Pro 4G) CPU: armeabi-v7a,armeabi Product Info: A661L SW: A661L-user 11 RP1A.201005.001 361 release-keys Product Board: A661L Board Platform: sp9832e Product Manfct: itel Android ver: 11 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Device ID: itel-a661l-itel-a49-a58-pro-4g- Strategy: [itel] Firmware ID: SP9832E_itel_itel_A661L_OSv11_A661L-V490AE-11.0-OP-V008-20220221_RP1A.201005.001_A661L_Itel Backup 8 items to: C:\Users\mobitech\Desktop\INFINITY SETUPS\CM2SP3_2.27a3\backup\sc9832_2f2173ffcadd037 6\ Read to C:\Users\mobitech\Desktop\INFINITY SETUPS\CM2SP3_2.27a3\backup\sc9832_2f2173ffcadd037 6\ Reading... Read [1/73] prodnv 10.00 Mb Ok Read [2/73] miscdata 1024.00 Kb Ok Read [8/73] uboot_a 1024.00 Kb Ok Read [9/73] uboot_b 1024.00 Kb Ok Read [13/73] l_fixnv1_a 2.00 Mb Ok Read [14/73] l_fixnv2_a 2.00 Mb Ok Read [15/73] l_fixnv1_b 2.00 Mb Ok Read [16/73] l_fixnv2_b 2.00 Mb Ok Saved 8 of 8 images, 21.00 Mb of 21.00 Mb Done 8 files Compress: C:\Users\mobitech\Desktop\INFINITY SETUPS\CM2SP3_2.27a3\backup\sc9832_2f2173ffcadd037 6\ Cleanup... Ok Verify C:\Users\mobitech\Desktop\INFINITY SETUPS\CM2SP3_2.27a3\backup\sc9832_2f2173ffcadd037 6.7z Finished get slots... slot: a MemTool load 73 items Finished 36 sec Operation: Reset Settings / Format FS [sc9832e Boot [FF] FireFly] [v2.27a3 (beta)] WARNING: Reset may delete ALL USER DATA! Continue? Yes [-] Wipe [-] Userdata [+] FRP [-] Smart Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... Backup exist: C:\Users\mobitech\Desktop\INFINITY SETUPS\CM2SP3_2.27a3\backup\sc9832_2f2173ffcadd037 6\ Stage: FRP... Looking for items... 1 items found [1] Writing... Ok Completed Finished 5 sec Reboot... Disconnect cable if it freez fault 0x05 0x8E | BSL_PHONE_WAIT_INPUT_TIMEOUT Bye |
The Following User Says Thank You to lalit bisht For This Useful Post: |
04-26-2024, 16:14 | #76108 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 51
Member: 1473716 Status: Offline Thanks Meter: 1,282 | Acer Iconia One 10 B3-A40 FRP Done Code: Wait... S/N: 0007ED6721 v0158 Chinese Miracle II - MT2 Service Tool v2.53a3 (beta) Init log engine... Ok Build directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 2 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 88 DA profiles... Ok libusb: v1.2.6.0 Init environment... Ok Load IDBase v915508 Ok Check for updates [boot-pack]... You have latest version [2.45] installed Operation: Identify Device [ v2.53a3 (beta) ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: BROM Only [+] High-Speed [+] Auto-EMI [+] FireFly-Over-DA extended protocol [+] Local SLA [-] Force BROM Wait... - Power device Off - Connect test-point if need - Connect cable [Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port (COM26) MODE [0]: BOOTROM; PORT: 26 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT8167 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x8167 TYPE: MODERN [RAPHAEL] MEID: 1C7497E509792A2969E731C5153DB3E9 BROM: Sec Level: 0x000000E1 Mode: SBC+EXT VER: 0x05 BL: 0xFE [BOOTROM] BROM: EMI: Search EMI: Continue EMI: Found AGENT: AUTO: Acer: MT8167_SEC [b416d5d3] C:\InfinityBox\CM2MT2\boot\Acer\MT8167_SEC\DA_SWSEC_A10L2.668411d6.bin Looking for suitable bootchain in DA... Found: MT8167; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMI: FireFly preloader_neostra8167_tb_n.bin with 1 memory type(s) 1. DRAM LP_DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00040000 [ 256.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 45010044463430313601A36FE63C3561 crc Ok Ven: Sandisk OEM: 256 ID: 444634303136 [DF4016] PRV: 0x01 SNN: 2742019644 [0xA36FE63C] MM/YY: 3/2018 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x3AB400000 [ 14.68 Gb ] CHIP: MT8167 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x8167 TYPE: MODERN [RAPHAEL] RNID: ECD24CA8DECAA106EDCDC673732BFE83 MEID: 1C7497E509792A2969E731C5153DB3E9 USB: FULL-SPEED Set port Speed... PTFN: MediaTek DA USB VCOM (Android) (COM41) MODE: PRELOADER PORT; PORT: 41 Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 23 Select info source... [recovery] Ok Patch Level: NRD90M SW Version: 1536906366 Ver. CodeName: REL Ver. Release: 7.0 Sec. Patch: 2018-08-05 Build Time: 14.09.2018. 06:26:05 Product Model: B3-A40 Product Brand: acer Product Board: B3-A40 Product Name: B3-A40_ww_gen1 Product Device: acer_asgard CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: Acer Board Platform: mt8167 Product Info: acer_asgard SW: full_neostra8167_tb_n-user 7.0 NRD90M 1536906366 release-keys Display ID: Acer_AV0N0_B3-A40_A.001.00_WW_GEN1 Strategy: [none|generic] Firmware ID: MT8167_Acer_B3-A40_OSv7.0_Acer_AV0N0_B3-A40_A.001.00_WW_GEN1_NRD90M_acer_asgard Verify firmware [MT8167_Acer_B3-A40_OSv7.0_Acer_AV0N0_B3-A40_A.001.00_WW_GEN1_NRD90M_acer_asgard]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem [ext4] with FDE [forced encrypt] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0x07 Size: 0x02188A State: Ok WiFi MAC: 68B35E563AAA BlTh MAC: 68B35E563276 Verify config values... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT8167__1C7497E509792A2969E731C5153DB3E9\ Items to check: 22 Read [3] NVRAM Read [2] PROINFO Read [8] LK Read [4] PROTECT1 ZERO CONTENT file [10.00 Mb] deleted: C:\InfinityBox\CM2MT2\backup\MT8167__1C7497E509792A2969E731C5153DB3E9\protect1.bin Read [1] PGPT Read [6] PERSIST ZERO CONTENT file [48.00 Mb] deleted: C:\InfinityBox\CM2MT2\backup\MT8167__1C7497E509792A2969E731C5153DB3E9\persist.bin Read [0] PRELOADER Read [18] KB ZERO CONTENT file [2.00 Mb] deleted: C:\InfinityBox\CM2MT2\backup\MT8167__1C7497E509792A2969E731C5153DB3E9\kb.bin Done 5 files Compress: C:\InfinityBox\CM2MT2\backup\MT8167__1C7497E509792A2969E731C5153DB3E9\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT8167__1C7497E509792A2969E731C5153DB3E9.7z Verified STORAGE Life Status: eMMC : NOT implemented in selected DA STORAGE OTP Status: NOT Enabled STORAGE RPMB Status: eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Analyze preloader... EMI: MT8167 preloader_neostra8167_tb_n.bin with 1 memory type(s) 1. DRAM LP_DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_neostra8167_tb_n.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_neostra8167_tb_n.bin [f09b4574]... Exist Probe FRP... On Probe MDM... Request... Ok Nothing found Probe network config... State: Default Reset port... Trying to reboot... Done: 00:00:56 Reconnect Power/Cable now ------------------------------------------------ ------------------------------------- Operation: Reset Settings/Format FS [ v2.53a3 (beta) ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [+] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... - Power device Off - Connect test-point if need - Connect cable [Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port (COM26) MODE [0]: BOOTROM; PORT: 26 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT8167 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x8167 TYPE: MODERN [RAPHAEL] MEID: 1C7497E509792A2969E731C5153DB3E9 BROM: Sec Level: 0x000000E1 Mode: SBC+EXT VER: 0x05 BL: 0xFE [BOOTROM] EMI loaded by MEID: 1C7497E509792A2969E731C5153DB3E9 AGENT: AUTO: Acer: MT8167_SEC [b416d5d3] C:\InfinityBox\CM2MT2\boot\Acer\MT8167_SEC\DA_SWSEC_A10L2.668411d6.bin Looking for suitable bootchain in DA... Found: MT8167; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMI: FireFly preloader_neostra8167_tb_n.bin with 1 memory type(s) 1. DRAM LP_DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00040000 [ 256.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 45010044463430313601A36FE63C3561 crc Ok Ven: Sandisk OEM: 256 ID: 444634303136 [DF4016] PRV: 0x01 SNN: 2742019644 [0xA36FE63C] MM/YY: 3/2018 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x3AB400000 [ 14.68 Gb ] CHIP: MT8167 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x8167 TYPE: MODERN [RAPHAEL] RNID: ECD24CA8DECAA106EDCDC673732BFE83 MEID: 1C7497E509792A2969E731C5153DB3E9 USB: FULL-SPEED Set port Speed... PTFN: MediaTek DA USB VCOM (Android) (COM41) MODE: PRELOADER PORT; PORT: 41 Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 23 Select info source... [recovery] Ok Patch Level: NRD90M SW Version: 1536906366 Ver. CodeName: REL Ver. Release: 7.0 Sec. Patch: 2018-08-05 Build Time: 14.09.2018. 06:26:05 Product Model: B3-A40 Product Brand: acer Product Board: B3-A40 Product Name: B3-A40_ww_gen1 Product Device: acer_asgard CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: Acer Board Platform: mt8167 Product Info: acer_asgard SW: full_neostra8167_tb_n-user 7.0 NRD90M 1536906366 release-keys Display ID: Acer_AV0N0_B3-A40_A.001.00_WW_GEN1 Strategy: [none|generic] SmartInfo: Android Ver: 7 UserDataFS: 0x01 [ext4|4+] CacheFS: 0x01 [ext4|4+] Verify config values... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT8167__1C7497E509792A2969E731C5153DB3E9 Stage: Android OS [2] WIPE... Ok [3] WIPE... Create partition image... Ok size 0x32FE370 addr 0x32FE370; code 0xC0040005 UNKNOWN SPARSE CHUNK TYPE Ok [4] WIPE... Create partition image... Ok size 0xA30124 addr 0xA30124; code 0xC0040005 UNKNOWN SPARSE CHUNK TYPE Ok [6] USERDATA... Ok Stage: FRP... [1] PROTECTION... Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Done: 00:01:14 Reconnect Power/Cable now ----------------------------------------------- ------------------------------------------------ Operation: Read Flash [ v2.53a3 (beta) ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Destination: C:\Users\korisnik\Desktop\ACER B3-A40\ Disk free space: 50.18 Gb Wait... [+] Pack firmware files [Sparse] [-] Forced Read - Power device Off - Connect test-point if need - Connect cable [Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port (COM26) MODE [0]: BOOTROM; PORT: 26 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT8167 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x8167 TYPE: MODERN [RAPHAEL] MEID: 1C7497E509792A2969E731C5153DB3E9 BROM: Sec Level: 0x000000E1 Mode: SBC+EXT VER: 0x05 BL: 0xFE [BOOTROM] EMI loaded by MEID: 1C7497E509792A2969E731C5153DB3E9 AGENT: AUTO: Acer: MT8167_SEC [b416d5d3] C:\InfinityBox\CM2MT2\boot\Acer\MT8167_SEC\DA_SWSEC_A10L2.668411d6.bin Looking for suitable bootchain in DA... Found: MT8167; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMI: FireFly preloader_neostra8167_tb_n.bin with 1 memory type(s) 1. DRAM LP_DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00040000 [ 256.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 45010044463430313601A36FE63C3561 crc Ok Ven: Sandisk OEM: 256 ID: 444634303136 [DF4016] PRV: 0x01 SNN: 2742019644 [0xA36FE63C] MM/YY: 3/2018 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x3AB400000 [ 14.68 Gb ] CHIP: MT8167 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x8167 TYPE: MODERN [RAPHAEL] RNID: ECD24CA8DECAA106EDCDC673732BFE83 MEID: 1C7497E509792A2969E731C5153DB3E9 USB: FULL-SPEED Set port Speed... PTFN: MediaTek DA USB VCOM (Android) (COM41) MODE: PRELOADER PORT; PORT: 41 Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 23 Select info source... [recovery] Ok Patch Level: NRD90M SW Version: 1536906366 Ver. CodeName: REL Ver. Release: 7.0 Sec. Patch: 2018-08-05 Build Time: 14.09.2018. 06:26:05 Product Model: B3-A40 Product Brand: acer Product Board: B3-A40 Product Name: B3-A40_ww_gen1 Product Device: acer_asgard CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: Acer Board Platform: mt8167 Product Info: acer_asgard SW: full_neostra8167_tb_n-user 7.0 NRD90M 1536906366 release-keys Display ID: Acer_AV0N0_B3-A40_A.001.00_WW_GEN1 Strategy: [none|generic] Firmware ID: MT8167_Acer_B3-A40_OSv7.0_Acer_AV0N0_B3-A40_A.001.00_WW_GEN1_NRD90M_acer_asgard Read [1/26]: preloader.bin 4.00 Mb Process file... Ok Ok [ 163.84 Kb ] Read [3/26]: proinfo.img 3.00 Mb Process file... Ok Ok [ 336 B ] Read [4/26]: nvram.bin 5.00 Mb Process file... Ok Ok [ 4.88 Mb ] Read [7/26]: persist.img 48.00 Mb Process file... Read [9/26]: lk.bin 384.00 Kb Process file... Ok Ok [ 244.25 Kb ] Read [10/26]: lk.bin 384.00 Kb Read [11/26]: boot.img 16.00 Mb Process file... Ok Ok [ 9.09 Mb ] Read [12/26]: recovery.img 16.00 Mb Process file... Ok Ok [ 10.52 Mb ] Read [14/26]: logo.bin 8.00 Mb Process file... Ok Ok [ 965.56 Kb ] Read [17/26]: tz.img 5.00 Mb Process file... Ok Ok [ 2.43 Mb ] Read [18/26]: tz.img 5.00 Mb Read [19/26]: kb.img 2.00 Mb Process file... Read [20/26]: dkb.img 2.00 Mb Process file... Read [22/26]: system.img 3.70 Gb Process file... Sparse... Compression ratio: 8% Ok Ok [ 3.41 Gb ] Read [23/26]: cache.img 512.00 Mb Create partition image... Ok Ok [ 0 B ] Read [24/26]: userdata.img 10.28 Gb Create partition image... Ok Ok [ 0 B ] Gathering image info... Build scat... Ok FW Size: 3.44 Gb Android Info saved: _Android_info.txt Scatter: MT8167_Android_scatter.txt Saved: C:\Users\korisnik\Desktop\ACER B3-A40\MT8167_Acer_B3-A40_OSv7.0_Acer_AV0N0_B3-A40_A.001.00_WW_GEN1_NRD90M_acer_asgard\ Verify config values... Ok Loaders Ok Verify firmware [MT8167_Acer_B3-A40_OSv7.0_Acer_AV0N0_B3-A40_A.001.00_WW_GEN1_NRD90M_acer_asgard]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Upload file to server? No Reset port... Trying to reboot... Done: 00:04:58 Reconnect Power/Cable now ---------------------------------------------------- --------------------------------------------- |
04-26-2024, 23:53 | #76109 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 500 | Cubot X19 Firmware read ok Chinese Miracle II - MT2 Service Tool v2.57 Init log engine... Ok Build directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 11 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 85 profiles... Ok libusb: v1.2.6.0 Init environment... Ok Load IDBase v915508 Ok Operation: Identify [ v2.57 ] Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM (Android) (COM3) MODE [0]: PRELOADER PORT; PORT: 3 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6763 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0690 CODE: Bianco TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: F2DD20786794151457B96620593094B44170B77D9C8469E143 649CBE27CC6D36 AGENT: AUTO: 0_base: base_v2316 [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for suitable bootchain in DA... Found: MT6763; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00040000 [ 256.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100524331344D42010A9AE0FEB2E7 crc Ok Vendor: Samsung OEM: 256 ID: 524331344D42 [RC14MB] PRV: 0x01 Serial: 177922302 0x0A9AE0FE MM/YY: 11/2015 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6763 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0690 CODE: Bianco TYPE: MODERN [RAPHAEL] RNID: 80447AC7930AC12A08047B6C20FB5C68 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 33 Select info source... [recovery] Ok Patch Level: PPR1.180610.011 Display ID: CUBOT_X19_9021C_1_V10_20190723 SW Version: 20190723 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2019-07-05 Build Time: 23-07-2019 08:12:25 Product Model: X19 Product Brand: CUBOT Product Name: X19_EEA Product Device: X19 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: CUBOT Product Info: X19_EEA SW: full_q593-user 9 PPR1.180610.011 20190723 release-keys Product Board: CUBOT Board Platform: mt6763 Device ID: x19-x19-x19-eea-cubot Strategy: [none|generic] Firmware ID: MT6763_CUBOT_X19_OSv9_CUBOT_X19_9021C_1_V10_201907 23_PPR1.180610.011_X19_EEA Verify firmware [MT6763_CUBOT_X19_OSv9_CUBOT_X19_9021C_1_V10_201907 23_PPR1.180610.011_X19_EEA]... Exist (2) Analyze userdata... userData: fileSystem [ext4] with FDE [forced fde or fbe] Backup exist: C:\InfinityBox\CM2MT2\backup\MT6763__80447AC7930AC 12A08047B6C20FB5C68 Analyze modem... TK_MD_BASIC_MDBIN_PCB01_MT6763_S00.MOLY_LR12A_R2_M P_V86_37 Analyze nvram... Reading... Ok NVRAM: Items: 0xA0 Size: 0x0D2473 State: Ok WiFi MAC: CC73146B1B66 BT MAC: 7CB9603A494E IMEI[1]: 355303100716991 IMEI[2]: 355303101716990 Reading... Ok PSN1: N/A EMMC CID: 150100524331344D42010A9AE0FEB2E7 crc Ok Vendor: Samsung OEM: 256 ID: 524331344D42 [RC14MB] PRV: 0x01 Serial: 177922302 0x0A9AE0FE MM/YY: 11/2015 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Verify config values... Ok STORAGE Life Status: eMMC : OK STORAGE OTP Status: NOT Enabled STORAGE RPMB Status: eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Analyze preloader... EMI: MT6763 preloader_q593.bin with 4 memory type(s) 1. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 2. eMMC DDR3 ID: 150100524836344142 Samsung RH64AB RAM: 4.00 Gb 3. eMMC DDR3 ID: 150100524836344D42 Samsung RH64MB RAM: 4.00 Gb 4. eMMC DDR3 ID: 150100524331344D42 Samsung RC14MB RAM: 4.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_q 593.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_q 593.bin [258eb899]... Exist Probe FRP... Most probably Off Reset port... Trying to reboot... Finished 35 sec Reconnect Power/Cable now Operation: Read Flash [ v2.57 ] Destination: C:\Users\Hugo\Desktop\Cubot X19\ Disk free space: 178.76 Gb Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM (Android) (COM3) MODE [0]: PRELOADER PORT; PORT: 3 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6763 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0690 CODE: Bianco TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: F2DD20786794151457B96620593094B44170B77D9C8469E143 649CBE27CC6D36 AGENT: AUTO: 0_base: base_v2316 [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for suitable bootchain in DA... Found: MT6763; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00040000 [ 256.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100524331344D42010A9AE0FEB2E7 crc Ok Vendor: Samsung OEM: 256 ID: 524331344D42 [RC14MB] PRV: 0x01 Serial: 177922302 0x0A9AE0FE MM/YY: 11/2015 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6763 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0690 CODE: Bianco TYPE: MODERN [RAPHAEL] RNID: 80447AC7930AC12A08047B6C20FB5C68 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 33 Select info source... [recovery] Ok Patch Level: PPR1.180610.011 Display ID: CUBOT_X19_9021C_1_V10_20190723 SW Version: 20190723 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2019-07-05 Build Time: 23-07-2019 08:12:25 Product Model: X19 Product Brand: CUBOT Product Name: X19_EEA Product Device: X19 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: CUBOT Product Info: X19_EEA SW: full_q593-user 9 PPR1.180610.011 20190723 release-keys Product Board: CUBOT Board Platform: mt6763 Device ID: x19-x19-x19-eea-cubot Strategy: [none|generic] Firmware ID: MT6763_CUBOT_X19_OSv9_CUBOT_X19_9021C_1_V10_201907 23_PPR1.180610.011_X19_EEA Total size to read: 3.93 Gb Read [1/36]: preloader.bin 4.00 Mb Process file... Ok Ok [ 243.13 Kb ] Read [4/36]: recovery.img 32.00 Mb Process file... Ok Ok [ 13.67 Mb ] Read [14/36]: sec.img 2.00 Mb Process file... Read [15/36]: proinfo.img 3.00 Mb Process file... Ok Ok [ 336 B ] Read [16/36]: md1rom.img 64.00 Mb Process file... Ok Ok [ 17.59 Mb ] Read [17/36]: md1dsp.img 16.00 Mb Process file... Ok Ok [ 6.19 Mb ] Read [18/36]: spmfw.img 1.00 Mb Process file... Ok Ok [ 51.06 Kb ] Estimated time to end 3 min 35 sec Read [19/36]: sspm.img 1.00 Mb Process file... Ok Ok [ 378.25 Kb ] Read [20/36]: sspm.img 1.00 Mb Read [21/36]: gz.img 16.00 Mb Process file... Read [22/36]: gz.img 16.00 Mb Process file... Read [23/36]: nvram.bin 64.00 Mb Process file... Ok Ok [ 63.88 Mb ] Read [24/36]: lk.bin 1.00 Mb Process file... Ok Ok [ 636.55 Kb ] Read [25/36]: lk.bin 1.00 Mb Read [26/36]: boot.img 32.00 Mb Process file... Ok Ok [ 8.67 Mb ] Read [27/36]: logo.bin 8.00 Mb Process file... Ok Ok [ 1.71 Mb ] Read [28/36]: odmdtbo.img 16.00 Mb Process file... Ok Ok [ 45.95 Kb ] Read [29/36]: tz.img 5.00 Mb Process file... Ok Ok [ 808.33 Kb ] Read [30/36]: tz.img 9.00 Mb Read [31/36]: vendor.img 656.00 Mb Process file... Sparse... Compression ratio: 51% Ok Ok [ 321.98 Mb ] Read [32/36]: system.img 3.00 Gb Process file... Sparse... Compression ratio: 25% Ok Ok [ 2.25 Gb ] Build [33/36]: cache.img 432.00 Mb Create partition image... Ok Ok [ 0 B ] Build [34/36]: userdata.img 53.71 Gb Create partition image... Ok Ok [ 0 B ] Gathering image info... Build scat... Ok FW Size: 2.68 Gb Android Info saved: _Android_info.txt Scatter: MT6763_Android_scatter.txt Saved: C:\Users\Hugo\Desktop\Cubot X19\MT6763_CUBOT_X19_OSv9_CUBOT_X19_9021C_1_V10_20 190723_PPR1.180610.011_X19_EEA\ EMMC CID: 150100524331344D42010A9AE0FEB2E7 crc Ok Vendor: Samsung OEM: 256 ID: 524331344D42 [RC14MB] PRV: 0x01 Serial: 177922302 0x0A9AE0FE MM/YY: 11/2015 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Verify config values... Ok Verify firmware [MT6763_CUBOT_X19_OSv9_CUBOT_X19_9021C_1_V10_201907 23_PPR1.180610.011_X19_EEA]... Exist (2) Reset port... Trying to reboot... Finished 20 min 39 sec Reconnect Power/Cable now |
The Following User Says Thank You to ct3im For This Useful Post: |
04-27-2024, 00:14 | #76110 (permalink) |
Member: 85718 Status: Offline Thanks Meter: 500 | Cubot X19 FRP Remove CM2MT2 Chinese Miracle II - MT2 Service Tool v2.57 Init log engine... Ok Build directories tree... Ok Firmware files: C:\Users\Hugo\Desktop\Cubot X19\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 11 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 85 profiles... Ok libusb: v1.2.6.0 Init environment... Ok Load IDBase v915508 Ok Operation: Identify [ v2.57 ] Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM (Android) (COM3) MODE [0]: PRELOADER PORT; PORT: 3 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6763 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0690 CODE: Bianco TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: F2DD20786794151457B96620593094B44170B77D9C8469E143 649CBE27CC6D36 AGENT: AUTO: 0_base: base_v2316 [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for suitable bootchain in DA... Found: MT6763; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00040000 [ 256.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100524331344D42010A9AE0FEB2E7 crc Ok Vendor: Samsung OEM: 256 ID: 524331344D42 [RC14MB] PRV: 0x01 Serial: 177922302 0x0A9AE0FE MM/YY: 11/2015 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6763 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0690 CODE: Bianco TYPE: MODERN [RAPHAEL] RNID: 80447AC7930AC12A08047B6C20FB5C68 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 33 Select info source... [recovery] Ok Patch Level: PPR1.180610.011 Display ID: CUBOT_X19_9021C_1_V10_20190723 SW Version: 20190723 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2019-07-05 Build Time: 23-07-2019 08:12:25 Product Model: X19 Product Brand: CUBOT Product Name: X19_EEA Product Device: X19 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: CUBOT Product Info: X19_EEA SW: full_q593-user 9 PPR1.180610.011 20190723 release-keys Product Board: CUBOT Board Platform: mt6763 Device ID: x19-x19-x19-eea-cubot Strategy: [none|generic] Firmware ID: MT6763_CUBOT_X19_OSv9_CUBOT_X19_9021C_1_V10_201907 23_PPR1.180610.011_X19_EEA Verify firmware [MT6763_CUBOT_X19_OSv9_CUBOT_X19_9021C_1_V10_201907 23_PPR1.180610.011_X19_EEA]... Exist (2) Analyze userdata... userData: fileSystem [ext4] with FDE [forced fde or fbe] Backup exist: C:\InfinityBox\CM2MT2\backup\MT6763__80447AC7930AC 12A08047B6C20FB5C68 Analyze modem... TK_MD_BASIC_MDBIN_PCB01_MT6763_S00.MOLY_LR12A_R2_M P_V86_37 Analyze nvram... Reading... Ok NVRAM: Items: 0xA0 Size: 0x0D2473 State: Ok WiFi MAC: CC73146B1B66 BT MAC: 7CB9603A494E IMEI[1]: 355303100716991 IMEI[2]: 355303101716990 Reading... Ok PSN1: N/A EMMC CID: 150100524331344D42010A9AE0FEB2E7 crc Ok Vendor: Samsung OEM: 256 ID: 524331344D42 [RC14MB] PRV: 0x01 Serial: 177922302 0x0A9AE0FE MM/YY: 11/2015 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Verify config values... Ok STORAGE Life Status: eMMC : OK STORAGE OTP Status: NOT Enabled STORAGE RPMB Status: eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Analyze preloader... EMI: MT6763 preloader_q593.bin with 4 memory type(s) 1. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 2. eMMC DDR3 ID: 150100524836344142 Samsung RH64AB RAM: 4.00 Gb 3. eMMC DDR3 ID: 150100524836344D42 Samsung RH64MB RAM: 4.00 Gb 4. eMMC DDR3 ID: 150100524331344D42 Samsung RC14MB RAM: 4.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_q 593.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_q 593.bin [258eb899]... Exist Probe FRP... Most probably Off Reset port... Trying to reboot... Finished 35 sec Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.57 ] [+] Smart Analyzer [+] Wipe [-] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make [Userdata] On and repeat operation Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM (Android) (COM3) MODE [0]: PRELOADER PORT; PORT: 3 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6763 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0690 CODE: Bianco TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: F2DD20786794151457B96620593094B44170B77D9C8469E143 649CBE27CC6D36 AGENT: AUTO: 0_base: base_v2316 [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for suitable bootchain in DA... Found: MT6763; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00040000 [ 256.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100524331344D42010A9AE0FEB2E7 crc Ok Vendor: Samsung OEM: 256 ID: 524331344D42 [RC14MB] PRV: 0x01 Serial: 177922302 0x0A9AE0FE MM/YY: 11/2015 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6763 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0690 CODE: Bianco TYPE: MODERN [RAPHAEL] RNID: 80447AC7930AC12A08047B6C20FB5C68 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 33 Select info source... [recovery] Ok Patch Level: PPR1.180610.011 Display ID: CUBOT_X19_9021C_1_V10_20190723 SW Version: 20190723 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2019-07-05 Build Time: 23-07-2019 08:12:25 Product Model: X19 Product Brand: CUBOT Product Name: X19_EEA Product Device: X19 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: CUBOT Product Info: X19_EEA SW: full_q593-user 9 PPR1.180610.011 20190723 release-keys Product Board: CUBOT Board Platform: mt6763 Device ID: x19-x19-x19-eea-cubot Strategy: [none|generic] Firmware ID: MT6763_CUBOT_X19_OSv9_CUBOT_X19_9021C_1_V10_201907 23_PPR1.180610.011_X19_EEA Android ver: 9 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 150100524331344D42010A9AE0FEB2E7 crc Ok Vendor: Samsung OEM: 256 ID: 524331344D42 [RC14MB] PRV: 0x01 Serial: 177922302 0x0A9AE0FE MM/YY: 11/2015 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Verify config values... Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6763__80447AC7930AC 12A08047B6C20FB5C68 Stage: Android OS [2] WIPE... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 40 sec Reconnect Power/Cable now |
