Old 06-11-2024, 06:12   #76201 (permalink)
Blocked
Member: 1535468
Sonork: 100.161922
Thanks Meter: 1,009
lava z3 format and frp with cm2.....
Operation: Reset Settings/Format FS
Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X
[-] Wipe
[+] Userdata
[+] FRP
[-] Smart
WARNING: Reset may delete ALL USER DATA!
Wait...
1. Power Off the device
2. Wait 20 seconds
3. Connect USB cable to device [remember Vol+ | Vol-]
Waiting for device connection...
PTFN: MediaTek USB Port_V1632 (COM8)
MODE [0]: BOOTROM; PORT: 8
Waiting for BOOT ACK...
BROM: Init... Ok
CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766
CODE: Cervino
TYPE: MODERN [RAPHAEL]
MEID: D642D0E8F3D19B7A71AAC3C6E1CC70F1
BROM: Sec Level: 0x00000000 Mode: PLAIN
VER: 0x05 BL: 0xFE [BOOTROM]
SOCID: F53E725D6354DE2B7873996E9600CEA81D224DCEF913C73F25 44E6A57CF55F6D
AGENT: AUTO: 0_base: base_v2316
[1d5fdec4] C:\InfinityBox\boot\0_base\base_v2316\MTK_AllInOne _DA.1d5fdec4.bin
Looking for suitable BootChain in DA...
Found: MT6765; DA: MTK_DOWNLOAD_AGENT
BROM: Sending 1st DA...
DA sent
Jump to DA... Ok
Sync... Ok
DA: Agent Started
DA: SYNC
MODE: BROM
EXT_RAM NOT initialized
EMMC CID: D6010341334135353112E57E3FD0192D crc Ok
Ven: Foresee OEM: 259 ID: 413341353531 [A3A551] PRV: 0x12
SNN: 3850256336 [0xE57E3FD0]
MM/YY: 1/2022
EMI[2]: Init via internal database
EMI: INFINITY PRELOADER_INFINITY_2 with 8 memory type(s)
Push EMI... EXT_RAM CFG Passed
DA: Boot to 2nd DA...
2nd stage confirmed
DA: SYNC Ok
Load HW info...
RAM: SRAM: 0x0003A000 [ 232.00 Kb ]
RAM: DRAM: 0xC0000000 [ 3.00 Gb ]
MM/YY: 1/2022
BOOT1: 0x00400000 [ 4.00 Mb ]
BOOT2: 0x00400000 [ 4.00 Mb ]
RPMB: 0x01000000 [ 16.00 Mb ]
USER: 0x73A000000 [ 28.91 Gb ]
CODE: Cervino
RNID: 64CE8A475EF421E22B81406313C3B3EF
USB: HIGH-SPEED
Boot done MODERN [RAPHAEL]
Analyze PMT... Ok
PMT: PGPT [0x64] Records: 47
Strategy: [none|generic]
Verify config values...
Ok
Loaders Ok
Stage: Android OS
[1] ...
Create image... Ok Ok
[4] USERDATA... Ok
[5] USERDATA... Ok
Stage: FRP...
[1] PROTECTION...
Done
Reset port...
Trying to reboot...
Done: 00:00:34
Reconnect Power/Cable now
Bro....
zishanm
The Following User Says Thank You to zishanm For This Useful Post:
Old 06-13-2024, 09:14   #76202 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,778
Card found : S/N : 73CA70CC , v0160
Load File
File_Info : J106_4_61D_11C_128X160_PCB01_gprs_MT6261_S00.J016_ 04_11C_W13_52_MP_V10.bin
FileVersion : J016.04.11C.W13.52.MP.V10
Load File Ok
Operation : Flash [ v1.58 ]
======= Flash
Files set for flashing :
[ MCU ] : Clone Nokia 105-Nokia 106 MTK6261.bin
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 5 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 63BE5BD1BB34DA9C74EFC6A445EEB0B7
BROM Protocol Version : 05
Setting...
RTC/PowerLatch Settings Failed #1 (HW/Connection Error)
Boot Error!
Operation Failed
Elapsed: 00:00:08
Reconnect Power/Cable!
Finish at : [6/12/2024 / 1:56:59 PM]
Start at : [6/12/2024 / 1:57:25 PM]
======= Flash
Wait for phone...
Phone found! [ 5 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32
[0] : FLASH_DIE : 00C8 0060 0016 0000
[0] : FLASH_LEN : 0x00400000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Flash now
Erase region , wait ...
Write data , wait ...
Write : Clone Nokia 105-Nokia 106 MTK6261.bin
Done!
Elapsed: 00:00:46
Old 06-13-2024, 10:44   #76203 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,778
QMOBILE QALANDAR RESET PASSWORD DONE BY CM2
Card found : 73CA70CC , v0160
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
Operation : Reset Settings [ v1.07 ]
----- > Powered On :
1. Power On device
2. Connect USB cable
3. When device show StorageMode : Press '0' button for a 5 second!
----- > Powered Off :
1. Insert USB cable
2. Wait when device show Charge icon
Wait for device ...
Device Connected!
BOOT_PWR0 : 0x00600000
BOOT_INIT : 0x81C0024C
BOOT_MODE : DOWNLOAD
Setting BOOTROM mode
BOOT_MODE : BOOTROM
Boot_CPU : 0x88094009 : [RDA] : RDA8851CL
MEMD for flsh_spi32m Branch: none
Boot_CS0 : 0x161660C8 : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ]
Performing MemoryInit
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot IV : 0xFBA2A2E0
Boot done!
Preparing PMT
Verifying PMT
Erasing 1458176 bytes
FileSystem format done!
Done!
Elapsed: 00:01:08
Old 06-13-2024, 13:46   #76204 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,433
Smile Vgotel_new22
Operation: Reset Settings/Format FS [ v2.61 ]
[+] Smart Analyzer
[-] Wipe
[-] Userdata
[+] FRP
[-] Accounts
Reset Userdata is Off
If FRP still active after reset make [Userdata] On and repeat operation
Wait...
Port: Both [ B + P ]; High-Speed: On
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
- Power device Off [remember Test-Point]
- Connect cable [remember Vol+ | Vol-]
Waiting for device...
PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM3)
MODE [0]: PRELOADER PORT; PORT: 3
BROM: Init... Ok
CODE: Cervino
VER: 0xFF BL: 0x03 [PRELOADER PORT]
SOCID: 0510D8E67F94E7083136E5EE5DBDEAB4D56AB246EA7D89FE9C 127A1533FB09EC
AGENT:
[07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin
Looking for bootchain in DA...
DA sent
Jump to DA... Ok
Sync... Ok
DA: Agent Started
DA: SYNC
MODE: PRELOADER
EXT_RAM initialized
2nd stage confirmed
DA: SYNC Ok
Load HW info...
RAM: DRAM: 0x100000000 [ 4.00 Gb ]
EMMC
CID: D60103413341343432105B09892E8A3B crc Ok
Vendor: Foresee OEM: 259 ID: 413341343432 [A3A442] PRV: 0x10
Serial: 1527351598 0x5B09892E
MM/YY: 8/2023
USER: 0x1CCF000000 [ 115.23 Gb ]
CODE: Cervino
RNID: AB51A8DC479FADE53EDB11DD95FD200C
USB: HIGH-SPEED
HIGH-SPEED USB is Off!
Boot done MODERN [RAPHAEL] 11 sec
Analyze PMT... Ok
PMT: PGPT [0x64] Records: 46
Get slot info... a
Probe boot... Ok 547 us
Product Brand: VGO_TEL
Product Device: NEW_22
Product Model: NEW 22
Product Name: NEW_22
SW: VGO_TEL/NEW_22/NEW_22:12/SP1A.210812.016/1664514689:user/release-keys
Patch Level: SP1A.210812.016
Display ID: VGOTEL_NEW22_V1.04
SW Version: 1664514689
Ver. CodeName: REL
Ver. Release: 12
Sec. Patch: 2022-09-01
Build Time: 30-Sep-22 5:11:29 AM
Product Info: NEW_22
SW: NEW_22-user 12 SP1A.210812.016 1664516992 release-keys
Product Manfct: SSH Telecom SMC (Pvt.) Ltd
Product Board: k62v1_64_bsp
Board Platform: mt6765
Device ID: vgo-tel-ssh-telecom-smc-pvt.-lt-new-22-k62v1-64-bsp
Firmware ID: MT6765_SSH_Telecom_SMC_Pvt._Ltd_NEW_22_OSv12_VGOTE L_NEW22_V1.04_SP1A.210812.016_NEW_22_VGO_TEL
Android ver: 12
UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+]
EMMC
MM/YY: 8/2023
Verify config values... Ok
Backup to C:\InfinityBox\CM2MT2\backup\MT6765__A5992A27D489E D5DC9013379C9F98B04\
Items to check: 22
Read [16] NVRAM
NVRAM: Items: 0x9F Size: 0x08C04A State: Ok
WiFi MAC: AA006E742F76
BT MAC: 1C9F4EE6ADA8
IMEI[1]: 351051060363965
IMEI[2]: 351051060363973
Read [8] NVDATA
Read [2] PROINFO
Read [7] NVCFG
Read [11] PROTECT1
Read [1] PGPT
Read [14] PERSIST
Read [0] PRELOADER
Read [23] LK_A
Read [36] LK_B
Zero content file deleted: C:\InfinityBox\CM2MT2\backup\MT6765__A5992A27D489E D5DC9013379C9F98B04\lk_b.bin
Done 9 files 7 sec
Compress: C:\InfinityBox\CM2MT2\backup\MT6765__A5992A27D489E D5DC9013379C9F98B04\
Cleanup...
Ok
Verify C:\InfinityBox\CM2MT2\backup\MT6765__A5992A27D489E D5DC9013379C9F98B04.7z Enough [vgo-tel-ssh-telecom-smc-pvt.-lt-new-22-k62v1-64-bsp]
Stage: Android OS Off
Stage: FRP...
[1] PROTECTION... Ok Ok
Done
Stage: Smart... Nothing to-do
Reset port...
Trying to reboot...
Finished 44 sec
Old 06-16-2024, 08:47   #76205 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,778
S/N: 0073CA70CC v0160
Chinese Miracle II - MT2 Service Tool v2.57
Init log engine...
Ok
Build directories tree...
Ok
Backup files: C:\InfinityBox\CM2MT2\backup\
Backup files: 0 dirs: 0
Verify device database...
BuiltIn: 28 Custom: 0
Build device list...
Ok
Scan 74 profiles...
Ok
libusb: v1.2.6.0
Init environment...
Ok
Load IDBase v915508 Ok
boot-pack is not installed or outdated
Check for updates [CM2MT2]...
Installed v2.57
Infinity #CM2MT2 v2.61
- Updated nvram backup method before firmware write
- Updated nvram backup method for format/reset process
- Issue with DA selection fixed
Required firmware v0160
Telegram Channel: @InfinityBox
Telegram Chat: @InfinityBoxTalks
Sales: https://infinity-box.com/buy/
Account: https://infinity-box.com/service/
Update configuration...
Configuration [12412] updated
DA selected: Oppo | 2021 | MTK_AllInOne_DA_OP.bin
DA selected: Oppo | A1K-A12-A31-A32 | MTK_AllInOne_DA.bin
Operation: Identify [ v2.57 ]
Wait...
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
- Connect cable
PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM3)
BROM: Init...
Ok
CODE: Cervino
BROM: Sec Level: 0x00000005 Mode: SBC+SDA
SOCID: 71579AEF70C6CECCE17C2E5D19A251E3855D902831CD52707B B2955D78089762
AGENT: AUTO: Oppo: A1K-A12-A31-A32
[27da5d71] C:\InfinityBox\CM2MT2\boot\0_base\base_v2044\MTK_A llInOne_DA.bin
Looking for suitable bootchain in DA...
Reset Interface
PTFN: MediaTek USB Port_V1633 (COM4)
MODE [0]: BOOTROM; PORT: 4
BROM: Init...
Ok
CODE: Cervino
MEID: 27A394D15A540570A19599FB76BD5ABE
BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT
SLA: Local Auth
[Forced mode]
Start Auth...
Ok
Continue Auth...
libusb exec warn conn enum v1.2.6.0 0x25
Protocol|Filter fault
- Check USB drivers
- Reinstall libusb https://infinity-box.com/?r=100232
Finished 17 sec
Wait...
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
- Connect cable
BROM: Init...
Ok
CODE: Cervino
AGENT: AUTO: Oppo: 2021
[f2f720fb] C:\InfinityBox\CM2MT2\boot\Oppo\2021\MTK_AllInOne_ DA_OP.bin
DA sent
Jump to DA...
Ok
Sync...
Ok
DA: Agent Started
DA: SYNC
MODE: PRELOADER
EXT_RAM initialized
2nd stage confirmed
DA: SYNC Ok
Load HW info...
RAM: SRAM: 0x00038000 [ 224.00 Kb ]
EMMC
CID: 9B01005932503036340045B244741A87
crc Ok
Vendor: Hynix OEM: 256 ID: 593250303634 [Y2P064] PRV: 0x00
Serial: 1169310836 0x45B24474
MM/YY: 1/2023
USER: 0xE8F800000 [ 58.24 Gb ]
CODE: Cervino
RNID: FE191189FFB3273D41A971E5E8514728
USB: HIGH-SPEED
Analyze PMT...
Ok
PMT: PGPT [0x64] Records: 55
Get slot info...
a
Select info source...
[vendor_boot_a]
[boot_a]
Ok
Product Brand: oplus
Product Device: ossi
Product Model: ossi
Product Name: ossi
SW: oplus/ossi/ossi:12/SP1A.210812.016/1677856828009:user/release-keys
Display ID: SP1A.210812.016 release-keys
SW Version: 1677856828009
Ver. CodeName: REL
Ver. Release: 12
Sec. Patch: 2023-03-05
Build Time: 3/3/2023 3:20:28 PM
Product Info: k65v1_64_bsp
SW: vnd_k65v1_64_bsp-user 12 SP1A.210812.016 1677856828009 release-keys
Product Manfct: oplus
Product Board: k65v1_64_bsp
Device ID: oplus-ossi-k65v1-64-bsp
Strategy: [realme]
Firmware ID: MT6765_oplus_ossi_OSv12_SP1A.210812.016_k65v1_64_b sp
Verify firmware [MT6765_oplus_ossi_OSv12_SP1A.210812.016_k65v1_64_b sp]...
Exist (3)
Analyze userdata...
userData: fileSystem : [f2fs] with FBE [file based encryption]
Backup to C:\InfinityBox\CM2MT2\backup\MT6765__623A29EEF6C96 BD0C0196E01F0E5D08B\
Items to check: 20
Read [20] NVRAM
NVRAM: Items: 0xAA Size: 0x102389 State: Ok
WiFi MAC: 386F6BCEBFA7
BT MAC: 386F6BCEBFA6
Read [11] NVDATA
Read [19] PROINFO
Read [10] NVCFG
Read [14] PROTECT1
Read [1] PGPT
Read [17] PERSIST
Read [0] PRELOADER
Read [7] OPLUS_CUSTOM
Read [21] OCDT
Done 10 files
Compress: C:\InfinityBox\CM2MT2\backup\MT6765__623A29EEF6C96 BD0C0196E01F0E5D08B\
Cleanup...
Ok
Verify C:\InfinityBox\CM2MT2\backup\MT6765__623A29EEF6C96 BD0C0196E01F0E5D08B.7z
Enough [oplus-ossi-k65v1-64-bsp]
Analyze modem...
Nothing
Analyze nvram...
Reading...
Ok
Reading...
Ok
PSN1: 0022264533220844
EMMC
crc Ok
MM/YY: 1/2023
Ok
STORAGE Life Status: eMMC : OK
STORAGE OTP Status: UNLOCKED
STORAGE RPMB Status: eMMC : RPMB KEY PROGRAMMED [UNUSABLE]
Analyze preloader...
EMI: MT6765 preloader_k65v1_64_bsp.bin with 6 memory type(s)
1. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb
2. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
3. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
4. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
5. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 6.00 Gb
6. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 65v1_64_bsp.bin
Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 65v1_64_bsp.bin [944853b1]...
Exist
Probe FRP...
Most probably Off
Reset port...
Trying to reboot...
Finished 1 min 4 sec
Operation: Reset Settings/Format FS [ v2.57 ]
[+] Smart Analyzer
[+] Wipe
[+] Userdata
[+] FRP
[-] Accounts
Wait...
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
- Connect cable
BROM: Init...
Ok
CODE: Cervino
DA sent
Jump to DA...
Ok
Sync...
Ok
DA: Agent Started
DA: SYNC
MODE: PRELOADER
EXT_RAM initialized
2nd stage confirmed
DA: SYNC Ok
Load HW info...
EMMC
crc Ok
MM/YY: 1/2023
CODE: Cervino
USB: HIGH-SPEED
Analyze PMT...
Ok
Get slot info...
a
[vendor_boot_a]
[boot_a]
Ok
Product Model: ossi
Product Name: ossi
Ver. CodeName: REL
Ver. Release: 12
Strategy: [realme]
Android ver: 12
EMMC
crc Ok
MM/YY: 1/2023
Ok
Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__623A29EEF6C96 BD0C0196E01F0E5D08B
Stage: Android OS
[2] WIPE...
Skip for Strategy [realme]
[3] WIPE...
Create partition image...
Ok
Ok
[6] USERDATA...
Ok
[7] USERDATA...
Ok
Stage: FRP...
[1] PROTECTION...
Ok
Ok
Done
Stage: Smart...
Nothing to-do
Reset port...
Trying to reboot...
Finished 32 sec
Old 06-16-2024, 09:01   #76206 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,778
Init log engine...
Ok
Ok
Backup files: 1 dirs: 0
Ok
Scan 74 profiles...
Ok
libusb: v1.2.6.0
Init environment...
Ok
Wait...
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
- Connect cable
PTFN: MediaTek USB Port_V1633 (COM6)
MODE [0]: BOOTROM; PORT: 6
BROM: Init...
Ok
CODE: Cervino
MEID: BA2144A773A8117F6F67E5D0B2B5B06F
SOCID: 2117BA38524AE127B1A4840A37C1742501CB1278EF7AD77F65 2C4D2D1F75AA29
SLA: Local Auth
[Forced mode]
Start Auth...
Ok
Continue Auth...
Ok
FF: Looking for EMI
Found
SLA: Start
0x15
Auth Passed; SEC: 0x000000E0
EMI loaded by MEID: BA2144A773A8117F6F67E5D0B2B5B06F
DA sent
Jump to DA...
Ok
Sync...
Ok
DA: Agent Started
DA: SYNC
MODE: BROM
EMMC
CID: 90014A68423861503E03A6F139CA6601
crc Ok
Vendor: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03
Serial: 2800826826 0xA6F139CA
MM/YY: 6/2019
EMI: FireFly preloader_oppo6765_18511.bin with 9 memory type(s)
1. eMMC DDR3 ID: 150100514536334D42 Samsung QE63MB RAM: 2.00 Gb
2. eMMC DDR3 ID: 90014A484147346132 Hynix HAG4a2 RAM: 2.00 Gb
3. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb
4. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb
5. eMMC DDR3 ID: 150100524436344D42 Samsung RD64MB RAM: 4.00 Gb
6. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb
7. eMMC DDR3 ID: 150100475036424D42 Samsung GP6BMB RAM: 3.00 Gb
8. eMMC DDR3 ID: 150100524836344142 Samsung RH64AB RAM: 4.00 Gb
9. eMMC DDR3 ID: 150100514436334D42 Samsung QD63MB RAM: 2.00 Gb
Push EMI...
EXT_RAM CFG Passed
2nd stage confirmed
DA: SYNC Ok
Load HW info...
EMMC
crc Ok
MM/YY: 6/2019
USER: 0x747C00000 [ 29.12 Gb ]
CODE: Cervino
RNID: FC36B0D9476789A03B2EC9D549EAE993
USB: HIGH-SPEED
Analyze PMT...
Ok
PMT: PGPT [0x64] Records: 40
[recovery]
Ok
Patch Level: O11019
Ver. CodeName: REL
Ver. Release: 8.1.0
Sec. Patch: 2021-04-05
CPU: arm64-v8a,armeabi-v7a,armeabi
CPU: armeabi-v7a,armeabi
CPU: arm64-v8a
Product Manfct: OPPO
SW: full_oppo6765_18511-user 8.1.0 O11019 1616154336 release-keys
Build Time: 3/19/2021 11:50:27 AM
SW Version: 1616154627
Product Brand: OPPO
Product Model: CPH1909
Product Info: CPH1909
Product Device: CPH1909
Product Name: CPH1909
SW OTA Version: CPH1909EX_11.A.46_0460_202103191930
Display ID: CPH1909EX_11_A.46
Kernel Info: 4.9.77
Device ID: oppo-cph1909-MT6765_CPH1909EX_11_A.24_190629_bbb2336d
Strategy: [oppo]
Firmware ID: MT6765_OPPO_CPH1909_OSv8.1.0_CPH1909EX_11_A.46_O11 019_CPH1909.MT6765_CPH1909EX_11_A.24_190629_bbb233 6d
Verify firmware [MT6765_OPPO_CPH1909_OSv8.1.0_CPH1909EX_11_A.46_O11 019_CPH1909.MT6765_CPH1909EX_11_A.24_190629_bbb233 6d]...
Firmware is unknown
Please upload https://infinity-box.com/?r=100020
Analyze userdata...
userData: fileSystem [ext4] with FDE [forced encrypt]
Backup to C:\InfinityBox\CM2MT2\backup\MT6765__BA2144A773A81 17F6F67E5D0B2B5B06F\
Items to check: 20
Read [27] NVRAM
NVRAM: Items: 0xBC Size: 0x0ACB13 State: Ok
WiFi MAC: AA00656E646F
BT MAC: C4E1A11CDDB0
Read [11] NVDATA
Read [18] PROINFO
Read [28] LK
Read [10] NVCFG
Read [13] PROTECT1
Read [1] PGPT
Read [16] PERSIST
Read [0] PRELOADER
Read [7] OPPO_CUSTOM
Done 10 files
Compress: C:\InfinityBox\CM2MT2\backup\MT6765__BA2144A773A81 17F6F67E5D0B2B5B06F\
Cleanup...
Ok
Verify C:\InfinityBox\CM2MT2\backup\MT6765__BA2144A773A81 17F6F67E5D0B2B5B06F.7z
Enough [oppo-cph1909-mt6765-cph1909ex-11-a.24-190629-bbb2336d]
Analyze modem...
OPPO6765_18511_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R 2_TC16_SP_V50_5_P97
Analyze nvram...
Reading...
Ok
Reading...
Ok
PSN1: 0018517298030956
EMMC
crc Ok
MM/YY: 6/2019
Ok
EMI: MT6765 preloader_oppo6765_18511.bin with 9 memory type(s)
Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_o ppo6765_18511.bin
Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_o ppo6765_18511.bin [209e89fc]...
Exist
Probe FRP...
Most probably Off
Reset port...
Trying to reboot...
Finished 1 min 55 sec
[+] Smart Analyzer
[-] Wipe
[-] Userdata
[+] FRP
[-] Accounts
Wait...
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
- Connect cable
BROM: Init...
Ok
CODE: Cervino
SLA: Local Auth
[Forced mode]
Start Auth...
Ok
Continue Auth...
Ok
EMI known
SLA: Start
0x15
DA sent
Jump to DA...
Ok
Sync...
Ok
DA: Agent Started
DA: SYNC
MODE: BROM
EMMC
crc Ok
MM/YY: 6/2019
Push EMI...
EXT_RAM CFG Passed
2nd stage confirmed
DA: SYNC Ok
Load HW info...
EMMC
crc Ok
MM/YY: 6/2019
CODE: Cervino
USB: HIGH-SPEED
Analyze PMT...
Ok
[recovery]
Ok
Patch Level: O11019
Ver. CodeName: REL
Ver. Release: 8.1.0
CPU: arm64-v8a
Product Brand: OPPO
Kernel Info: 4.9.77
Strategy: [oppo]
Android ver: 8
UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+]
EMMC
crc Ok
MM/YY: 6/2019
Ok
Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__BA2144A773A81 17F6F67E5D0B2B5B06F
Stage: Android OS
Off
Stage: FRP...
[1] PROTECTION...
Ok
Ok
Done
Stage: Smart...
Nothing to-do
Reset port...
Trying to reboot...
Finished 1 min 2 sec
Old 06-17-2024, 02:53   #76207 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,778
LG K330 RESET FRP DONE BY CM2
Infinity-Box LG Service Tool [ LGS ] v1.03
Operation : Reset Settings/Format FS [ v1.03 ]
2. PRESS and HOLD VOLUME UP KEY!
3. Insert USB cable, wait until Download mode screen will appear
Wait for phone...
Connection opened successfully!
Waiting for loader ...
Handshake passed!
Collect info...
Prepare passed, mode 0x01
Boot done!
Format UserData
Format Cache
Format done
Erase sFRP#3 Ok!
Done!
Elapsed: 00:00:30
Old 06-19-2024, 21:32   #76208 (permalink)
Member: 85718
Thanks Meter: 502
Facetel Q3 firmware read ok
Chinese Miracle II - MT2 Service Tool v2.58
Init log engine... Ok
Build directories tree... Ok
Firmware files: C:\Users\Hugo\Desktop\konrow SOFT5MAX\
Backup files: 17 dirs: 0
Verify device database... BuiltIn: 28 Custom: 0
Orphan link C:\InfinityBox\CM2MT2\boot\Tecno\SECURE_v2\Infinix .SECURE_BASE.link
Orphan link C:\InfinityBox\CM2MT2\boot\Wiko\Jerry-2_V2\Wikio.Lenny-4-plus.link
Orphan link C:\InfinityBox\CM2MT2\boot\Wiko\V3720\Wikio.Lenny-4-plus.link
Orphan link C:\InfinityBox\CM2MT2\boot\Wiko\V3961\Wikio.W3953. link
Orphan link C:\InfinityBox\CM2MT2\boot\Wiko\V3971\Wikio.W3953. link
Load 108 profiles... Ok
libusb: v1.2.6.0
codepage: 1252
Init environment... Ok
Ready
Operation: Identify [ v2.58 ]
Wait...
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
PTFN: MediaTek PreLoader USB VCOM (Android) (COM3)
BROM: Init... Ok
CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717
CODE: Merlot
SOCID: CC803C1B1825F687CD6275B2A05602E3A8FF9836BD7D933D0B 8890B6461A8BC4
IRG: 0x00000080
Found: MT6761; DA: MTK_DOWNLOAD_AGENT
DA sent
Jump to DA... Ok
Sync... Ok
DA: Agent Started
DA: SYNC
MODE: PRELOADER
EXT_RAM initialized
2nd stage confirmed
DA: SYNC Ok
Load HW info...
RAM: SRAM: 0x0003A600 [ 233.50 Kb ]
EMMC
CID: DF0118534341363447106585D6039A97 crc Ok
Vendor: Unknown 0x00DF OEM: 280 ID: 534341363447 [SCA64G] PRV: 0x10
Serial: 1703269891 0x6585D603
MM/YY: 9/2023
RPMB: 0x00400000 [ 4.00 Mb ]
USER: 0xE8F000000 [ 58.23 Gb ]
CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717
CODE: Merlot
RNID: 01A27317189FEC5421CB93130A0154C6
USB: HIGH-SPEED
Analyze PMT... Ok
PMT: PGPT [0x64] Records: 50
STORAGE RPMB Status: eMMC : RPMB KEY NOT PROGRAMMED [USABLE]
Get slot info... a
Probe boot...
Product Brand: Aocwei
Product Device: X700_EEA
Product Model: X700_EEA
Product Name: X700_EEA
SW: Aocwei/X700_EEA/X700_EEA:13/TP1A.220624.014/2023264:user/release-keys
Patch Level: TP1A.220624.014
Display ID: Q3-EEA-MT8766_20231020
SW Version: 2023264
Ver. CodeName: REL
Ver. Release: 12
Sec. Patch: 2023-06-05
Build Time: 20-10-2023 12:21:08
Product Manfct: Aocwei
Product Info: X700_EEA
SW: vnd_g863dmr_v2_szy_q3_eea_t-user 12 TP1A.220624.014 2023264 release-keys
Product Board: g863dmr_v2_szy_q3_eea_t
Board Platform: mt6761
Device ID: aocwei-x700-eea-g863dmr-v2-szy-q3-eea-t
Firmware ID: MT6761_Aocwei_X700_EEA_OSv12_Q3-EEA-MT8766_20231020_TP1A.220624.014_X700_EEA
Verify firmware [MT6761_Aocwei_X700_EEA_OSv12_Q3-EEA-MT8766_20231020_TP1A.220624.014_X700_EEA]... Firmware is unknown
Analyze userdata...
userData: fileSystem [ext4] with FBE [file based encryption]
Backup exist: C:\InfinityBox\CM2MT2\backup\MT6761__6B5B96BBA71E4 9834FE0DDF6D96221AD
Analyze modem... Nothing
Analyze nvram...
Reading... Ok
NVRAM: Items: 0x06 Size: 0x022192 State: Ok
BT MAC: 00E49CCE8B99
Reading... Ok
PSN1: Q32023HGM1880001
EMMC
MM/YY: 9/2023
EMI: MT6761 preloader_g863dmr_v2_szy_q3_eea_t.bin with 30 memory type(s)
2. eMMC DDR3 ID: 13014E51324A333643 Micron Q2J36C RAM: 2.00 Gb
3. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb
4. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb
5. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb
7. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
8. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
9. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
10. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
11. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
12. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
13. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
14. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
15. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
16. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
17. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb
18. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb
19. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb
20. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
21. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
22. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
23. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
24. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
25. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
26. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
27. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
28. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
29. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
30. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_g 863dmr_v2_szy_q3_eea_t.bin
Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_g 863dmr_v2_szy_q3_eea_t.bin [e809fa3e]... Exist
Probe FRP... Most probably Off
Reset port...
Trying to reboot...
Finished 26 sec
Operation: Read Flash [ v2.58 ]
Destination: C:\Users\Hugo\Desktop\Facetel Q3\
Disk free space: 166.29 Gb
Wait...
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
BROM: Init... Ok
CODE: Merlot
IRG: 0x00000080
DA sent
Jump to DA... Ok
Sync... Ok
DA: Agent Started
DA: SYNC
MODE: PRELOADER
EXT_RAM initialized
2nd stage confirmed
DA: SYNC Ok
Load HW info...
EMMC
MM/YY: 9/2023
CODE: Merlot
USB: HIGH-SPEED
Analyze PMT... Ok
Device support slots: slotScheme v2
Get slot info... a
Active slot: a
Get slot info... a
Probe boot...
SW Version: 2023264
Ver. CodeName: REL
Ver. Release: 12
Total size to read: 5.64 Gb
Read [1/53]: preloader.bin 4.00 Mb
Process file... Ok Ok [ 243.48 Kb ]
Read [14/53]: persist.img 48.00 Mb
Process file...
Sparse...
Compression ratio: 93% Ok Ok [ 3.41 Mb ]
Read [15/53]: sec.img 2.00 Mb
Process file...
Read [16/53]: proinfo.img 3.00 Mb
Process file... Ok Ok [ 1.13 Mb ]
Read [17/53]: nvram.bin 64.00 Mb
Process file... Ok Ok [ 63.38 Mb ]
Read [18/53]: logo.bin 11.00 Mb
Process file... Ok Ok [ 1.33 Mb ]
Read [19/53]: md1rom_a.img 100.00 Mb
Process file... Ok Ok [ 4.20 Kb ]
Estimated time to end 8 min 32 sec
Read [20/53]: spmfw_a.img 1.00 Mb
Process file... Ok Ok [ 62.95 Kb ]
Read [21/53]: tinysys-scp_a.bin 1.00 Mb
Process file... Ok Ok [ 163.81 Kb ]
Read [22/53]: sspm_a.img 1.00 Mb
Process file... Ok Ok [ 432.53 Kb ]
Read [23/53]: gz_a.img 16.00 Mb
Process file...
Read [24/53]: lk_a.bin 1.00 Mb
Process file... Ok Ok [ 840.64 Kb ]
Read [25/53]: boot_a.img 32.00 Mb
Process file... Ok Ok [ 32.00 Mb ]
Read [26/53]: vendor_boot_a.img 64.00 Mb
Process file...
Read [27/53]: init_boot_a.img 8.00 Mb
Process file...
Read [28/53]: dtbo_a.img 8.00 Mb
Process file... Ok Ok [ 8.00 Mb ]
Read [29/53]: tz_a.img 8.00 Mb
Process file... Ok Ok [ 814.78 Kb ]
Read [30/53]: vbmeta_a.img 8.00 Mb
Process file... Ok Ok [ 3.25 Kb ]
Read [31/53]: vbmeta_system_a.img 8.00 Mb
Process file... Ok Ok [ 2.17 Kb ]
Read [32/53]: vbmeta_vendor_a.img 8.00 Mb
Process file... Ok Ok [ 1.63 Kb ]
Read [33/53]: md1rom_b.img 100.00 Mb
Process file...
Read [34/53]: spmfw_b.img 1.00 Mb
Process file...
Read [35/53]: tinysys-scp_b.bin 1.00 Mb
Process file...
Read [36/53]: sspm_b.img 1.00 Mb
Process file...
Read [37/53]: gz_b.img 16.00 Mb
Process file...
Read [38/53]: lk_b.bin 1.00 Mb
Process file...
Read [39/53]: boot_b.img 32.00 Mb
Process file...
Read [40/53]: vendor_boot_b.img 64.00 Mb
Process file...
Read [41/53]: init_boot_b.img 8.00 Mb
Process file...
Read [42/53]: dtbo_b.img 8.00 Mb
Process file...
Read [43/53]: tz_b.img 5.00 Mb
Process file...
Read [44/53]: teksunhw_a.img 1.00 Mb
Process file... Ok Ok [ 46.78 Kb ]
Read [45/53]: teksunhw_b.img 2.00 Mb
Process file...
Read [46/53]: super.img 5.00 Gb
Process file...
Sparse...
Compression ratio: 16% Ok Ok [ 4.22 Gb ]
Read [47/53]: vbmeta_b.img 8.00 Mb
Process file...
Read [48/53]: vbmeta_system_b.img 8.00 Mb
Process file...
Read [49/53]: vbmeta_vendor_b.img 8.00 Mb
Process file...
Build [50/53]: userdata.img 52.34 Gb
Create partition image... Ok Ok [ 0 B ]
Gathering image info...
Build scat... Ok
FW Size: 4.33 Gb
Android Info saved: _Android_info.txt
Scatter: MT6761_Android_scatter.txt
Saved: C:\Users\Hugo\Desktop\Facetel Q3\MT6761_Aocwei_X700_EEA_OSv12_Q3-EEA-MT8766_20231020_TP1A.220624.014_X700_EEA\
EMMC
MM/YY: 9/2023
Upload file to server? Yes
Reset port...
Trying to reboot...
Finished 30 min 41 sec
The Following User Says Thank You to ct3im For This Useful Post:
Old 06-21-2024, 00:09   #76209 (permalink)
Member: 85718
Thanks Meter: 502
Blackview BV4900 user code + FRP reset ok
Firmware files: C:\Users\Hugo\Desktop\Facetel Q3\
Backup files: 18 dirs: 0
libusb: v1.2.6.0
codepage: 1252
Ready
Wait...
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
BROM: Init... Ok
CODE: Merlot
SOCID: E66AA8F8A66CAF5888435A33216EE8370E355F8359CBF5518B 13353A22BB8154
IRG: 0x00000090
DA sent
Jump to DA... Ok
Sync... Ok
DA: Agent Started
DA: SYNC
MODE: PRELOADER
EXT_RAM initialized
2nd stage confirmed
DA: SYNC Ok
Load HW info...
EMMC
CID: 90014A484247346132A534364E3C3517 crc Ok
Vendor: Hynix OEM: 330 ID: 484247346132 [HBG4a2] PRV: 0xA5
Serial: 875974204 0x34364E3C
MM/YY: 3/2018
CODE: Merlot
RNID: 9AE28DEC6002E3509149813384EADF3B
USB: HIGH-SPEED
Analyze PMT... Ok
PMT: PGPT [0x64] Records: 39
Probe boot...
SW: Blackview/BV4900_EEA/BV4900:10/QP1A.190711.020/1616136391:user/release-keys
Product Brand: Blackview
Product Device: BV4900
Product Model: BV4900
Product Name: BV4900_EEA
Patch Level: QP1A.190711.020
Display ID: BV4900_EEA_ZN128e_V1.0_20210319V12
SW Version: 1616136391
Ver. CodeName: REL
Ver. Release: 10
Sec. Patch: 2021-02-05
Build Time: 19-03-2021 07:53:18
CPU: arm64-v8a
Product Info: BV4900_EEA
SW: full_k61v1_64_bsp-user 10 QP1A.190711.020 mp1V9221 release-keys
Product Board: k61v1_64_bsp
Product Manfct: Blackview
Device ID: blackview-bv4900-bv4900-eea-k61v1-64-bsp
Firmware ID: MT6761_Blackview_BV4900_OSv10_BV4900_EEA_ZN128e_V1 .0_20210319V12_QP1A.190711.020_BV4900_EEA
Verify firmware [MT6761_Blackview_BV4900_OSv10_BV4900_EEA_ZN128e_V1 .0_20210319V12_QP1A.190711.020_BV4900_EEA]... Firmware is unknown
Analyze userdata...
Backup exist: C:\InfinityBox\CM2MT2\backup\MT6761__DEEC38743152E E6790338B8144D32F6D
Analyze modem...
TK_MD_BASIC_MDBIN_PCB01_MT6761_S00.MOLY_LR12A_R3_M P_V149_6
Analyze nvram...
Reading... Ok
NVRAM: Items: 0xA2 Size: 0x08BF35 State: Ok
BT MAC: 6E5E46B3091F
IMEI[1]: 357039421752483
IMEI[2]: 357039421752491
Reading... Ok
PSN1: ZN128S1070702224
EMMC
MM/YY: 3/2018
EMI: MT6761 preloader_k61v1_64_bsp.bin with 17 memory type(s)
1. eMMC DDR3 ID: 150100474536424D42 Samsung GE6BMB RAM: 3.00 Gb
2. eMMC DDR3 ID: 150100524531424D42 Samsung RE1BMB RAM: 3.00 Gb
3. eMMC DDR3 ID: 90014A484147 Hynix HAG RAM: 3.00 Gb
4. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb
5. eMMC DDR3 ID: 90014A484247346132 Hynix HBG4a2 RAM: 3.00 Gb
6. eMMC DDR3 ID: 13014E53304A394237 Micron S0J9B7 RAM: 3.00 Gb
7. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb
8. eMMC DDR3 ID: 13014E51324A393756 Micron Q2J97V RAM: 3.00 Gb
9. eMMC DDR3 ID: 150100525831424D42 Samsung RX1BMB RAM: 3.00 Gb
10. eMMC DDR3 ID: 150100475836424D42 Samsung GX6BMB RAM: 3.00 Gb
11. eMMC DDR3 ID: 150100524836344142 Samsung RH64AB RAM: 4.00 Gb
12. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb
13. eMMC DDR3 ID: 150100524836344D42 Samsung RH64MB RAM: 4.00 Gb
14. eMMC DDR3 ID: 13014E53304A394638 Micron S0J9F8 RAM: 4.00 Gb
15. eMMC DDR3 ID: 150100475836424142 Samsung GX6BAB RAM: 3.00 Gb
16. eMMC DDR3 ID: 150100524331344D42 Samsung RC14MB RAM: 4.00 Gb
17. eMMC DDR3 ID: 150100525036344D42 Samsung RP64MB RAM: 4.00 Gb
Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 61v1_64_bsp.bin
Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 61v1_64_bsp.bin [fe94d327]... Exist
Reset port...
Trying to reboot...
Finished 31 sec
Operation: Reset Settings/Format FS [ v2.58 ]
[+] Smart Analyzer
[+] Wipe
[+] Userdata
[+] FRP
[-] Accounts
Wait...
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
BROM: Init... Ok
CODE: Merlot
IRG: 0x00000090
DA sent
Jump to DA... Ok
Sync... Ok
DA: Agent Started
DA: SYNC
MODE: PRELOADER
EXT_RAM initialized
2nd stage confirmed
DA: SYNC Ok
Load HW info...
EMMC
MM/YY: 3/2018
CODE: Merlot
USB: HIGH-SPEED
Analyze PMT... Ok
Probe boot...
Ver. CodeName: REL
Ver. Release: 10
CPU: arm64-v8a
Android ver: 10
EMMC
MM/YY: 3/2018
Stage: Android OS
[2] WIPE... Ok
[3] WIPE...
[4] WIPE...
[6] USERDATA... Ok
[7] USERDATA... Ok
Stage: FRP...
Done
Reset port...
Trying to reboot...
Finished 27 sec
Old 06-21-2024, 00:56   #76210 (permalink)
Member: 85718
Thanks Meter: 502
Blackview BV4900 Firmware readed sucessfully
Destination: C:\Users\Hugo\Desktop\Blackview BV4900\
Disk free space: 194.45 Gb
Wait...
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
BROM: Init... Ok
CODE: Merlot
IRG: 0x00000090
DA sent
Jump to DA... Ok
Sync... Ok
DA: Agent Started
DA: SYNC
MODE: PRELOADER
EXT_RAM initialized
2nd stage confirmed
DA: SYNC Ok
Load HW info...
EMMC
MM/YY: 3/2018
CODE: Merlot
USB: HIGH-SPEED
Analyze PMT... Ok
Probe boot...
Ver. CodeName: REL
Ver. Release: 10
CPU: arm64-v8a
Total size to read: 4.37 Gb
Read [1/42]: preloader.bin 4.00 Mb
Process file... Ok Ok [ 230.61 Kb ]
Read [4/42]: recovery.img 32.00 Mb
Read [7/42]: vbmeta_system.img 8.00 Mb
Process file... Ok Ok [ 1.89 Kb ]
Read [8/42]: vbmeta_vendor.img 8.00 Mb
Process file... Ok Ok [ 1.48 Kb ]
Read [17/42]: persist.img 48.00 Mb
Process file...
Sparse...
Compression ratio: 84% Ok Ok [ 8.15 Mb ]
Read [18/42]: sec.img 2.00 Mb
Process file...
Read [19/42]: proinfo.img 3.00 Mb
Process file... Ok Ok [ 1.50 Mb ]
Estimated time to end 11 min 4 sec
Read [20/42]: md1rom.img 100.00 Mb
Process file... Ok Ok [ 47.51 Mb ]
Read [21/42]: spmfw.img 1.00 Mb
Process file... Ok Ok [ 62.92 Kb ]
Read [22/42]: tinysys-scp.bin 1.00 Mb
Process file... Ok Ok [ 599.41 Kb ]
Read [23/42]: tinysys-scp.bin 1.00 Mb
Read [24/42]: sspm.img 1.00 Mb
Process file... Ok Ok [ 428.27 Kb ]
Read [25/42]: sspm.img 1.00 Mb
Read [26/42]: gz.img 16.00 Mb
Process file...
Read [27/42]: gz.img 16.00 Mb
Process file...
Read [28/42]: nvram.bin 64.00 Mb
Process file... Ok Ok [ 63.88 Mb ]
Read [29/42]: lk.bin 1.00 Mb
Process file... Ok Ok [ 832.73 Kb ]
Read [30/42]: lk.bin 1.00 Mb
Read [31/42]: boot.img 32.00 Mb
Read [32/42]: logo.bin 8.00 Mb
Process file... Ok Ok [ 2.56 Mb ]
Read [33/42]: dtbo.img 8.00 Mb
Read [34/42]: tz.img 5.00 Mb
Process file... Ok Ok [ 759.22 Kb ]
Read [35/42]: tz.img 11.00 Mb
Read [36/42]: super.img 4.00 Gb
Process file...
Sparse...
Compression ratio: 23% Ok Ok [ 3.09 Gb ]
Read [37/42]: vbmeta.img 8.00 Mb
Process file... Ok Ok [ 3.72 Kb ]
Build [38/42]: cache.img 432.00 Mb
Build [39/42]: userdata.img 24.08 Gb
Build scat... Ok
FW Size: 3.29 Gb
Saved: C:\Users\Hugo\Desktop\Blackview BV4900\MT6761_Blackview_BV4900_OSv10_BV4900_EEA_ZN 128e_V1.0_20210319V12_QP1A.190711.020_BV4900_EEA\
EMMC
MM/YY: 3/2018
Upload file to server? No
Reset port...
Trying to reboot...
Finished 24 min 4 sec
Old 06-21-2024, 06:04   #76211 (permalink)
Member: 953334
Sonork: 100.1614005
Smile itel-A551L-Pro
Operation: Connect itel A551L Boot [FF] FireFly [v2.27]
Wait...
- Power device Off
- Connect cable [remember Vol+ | Vol-] [remember Test-Point]
Device found
PTFN: SPRD U2S Diag (COM21) vid 0x1782 pid 0x4D00
boot: SPRD3
boot iLoader... Ok
start iLoader... Ok
Handshake... Ok
boot xLoader... Ok
start FireFly... Ok
Loader exec Ok
Dev UID: 6aed148f86adbd67239796d5c5759a4a6ed9f13bd87b3c970d 72c7beb33aeb0e
get storage info...
EMMC
CID: 1501005158363341420369BD0642A881 crc Ok
Vendor: Samsung OEM: 256 ID: 515836334142 [QX63AB] PRV: 0x03
Serial: 1773995586 0x69BD0642
MM/YY: 10/2021
CSD: D02701320F5903FFF6DBFFEF8E404001
temp_write_protect: False
perm_write_protect: False
wp_group: 0x10 en 0x01
EXTCSD rev1.8 EMMC 5.1 FW: 03
ERASE_GROUP_DEF: 0x0400
BOOT_BUS_WIDTH: 0x00
PARTITION_CONFIG: 0x08
RST_N_FUNCTION: 0x01
PART_S_COMPLETED: False
BOOT size: 0x400000
RPMB size: 0x400000 4.00 Mb
WP_GRP_SIZE: 0x800000 8.00 Mb
Size: Market 32 Gb Actual 0x747C00000 29.12 Gb
EOL: Status: Normal: Less than 80% reserved blocks used
EOL_A: SLC status: 0% - 10% used
EOL_B: MLC status: 0% - 10% used
read extcsd... Ok
extcsd stored: C:\InfinityBox\CM2SP3\backup\ext_csd\none_6aed148f 86adbd67_extcsd_0015-Samsung_QX63AB_5.1_2024-06-21.bin
get partitions...
Partitions: 74
Connected
get sw info... 3 sec
SW: Itel/SU360O/itel-A551L-Pro:11/RP1A.201005.001/OP-V016-20220610:user/release-keys
Product Brand: Itel
Product Device: itel-A551L-Pro
Product Model: itel A551L
Product Name: SU360O
Patch Level: RP1A.201005.001
Display ID: A551L-Pro-SU360O-11.0-OP-V016-20220610
SW Version: OP-V016-20220610
Ver. CodeName: REL
Ver. Release: 11
Sec. Patch: 2022-06-05
Build Time: 10-Jun-22 11:17:37 AM
Product Info: A551L
SW: A551L-Pro-SU360O-11.0-OP-V016-20220610
Product Manfct: ITEL MOBILE LIMITED
Market Name: itel A27(P17 Pro 4G)
Product Board: A551L
Board Platform: sp9832e
Android ver: 11
Device ID: itel-mobile-limited-itel-a551l-itel-a551l-pro-su360o-itel-a27-p17-pro-4g-
Strategy: [itel]
Firmware ID: SP9832E_ITEL_MOBILE_LIMITED_itel_A551L_OSv11_A551L-Pro-SU360O-11.0-OP-V016-20220610_RP1A.201005.001_A551L_Itel
Backup 8 items to: C:\InfinityBox\CM2SP3\backup\sp9832e_6aed148f86adb d67\
Read to C:\InfinityBox\CM2SP3\backup\sp9832e_6aed148f86adb d67\
Reading...
Read [1/74] prodnv 10.00 Mb Ok
Read [2/74] miscdata 1024.00 Kb Ok
Read [8/74] uboot_a 1024.00 Kb Ok
Read [9/74] uboot_b 1024.00 Kb Ok
Read [13/74] l_fixnv1_a 2.00 Mb Ok
Read [14/74] l_fixnv2_a 2.00 Mb Ok
Read [15/74] l_fixnv1_b 2.00 Mb Ok
Read [16/74] l_fixnv2_b 2.00 Mb Ok
Saved 8 of 8 images, 21.00 Mb of 21.00 Mb
Done 8 files
Compress: C:\InfinityBox\CM2SP3\backup\sp9832e_6aed148f86adb d67\
Cleanup...
Ok
Verify C:\InfinityBox\CM2SP3\backup\sp9832e_6aed148f86adb d67.7z Verified [39668e44]
Read Device-ID...
BT MAC: c8:1e:c2:22:c3:c1
WiFi MAC: c8:1e:c2:22:c3:c2
PSN1: 90PS077124525D009686
PSN2: N/A
PSN3: N/A
get slots... slot: b
MemTool load 74 items
Finished 35 sec
Operation: Reset | Format itel A551L Boot [FF] FireFly [v2.27]
Continue? Yes
[+] Wipe
[-] Userdata
[+] FRP
[+] Smart
If FRP still active after reset make Userdata On and repeat operation
Wait...
Backup exist: C:\InfinityBox\CM2SP3\backup\sp9832e_6aed148f86adb d67\
Stage: Wipe...
Reading... Ok
Writing... Ok
Stage: FRP...
Looking for items... 1 items found
[1] Writing... Ok
Completed
Stage: Smart...
[17] Format... Ok
[18] Format... Ok
Completed
Finished 5 sec
Reboot... Disconnect cable if it freez
fault 0x05 0x8E | BSL_PHONE_WAIT_INPUT_TIMEOUT
Bye
Old 06-21-2024, 07:48   #76212 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Infinix X680F
Operation: Reset Settings/Format FS [ v2.62 ]
[+] Smart Analyzer
[-] Wipe
[+] Userdata
[+] FRP
[-] Accounts
Wait...
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
BROM: Init... Ok
CODE: Cervino
MEID: BFBA735981EBB370EDBFE829EAA122D0
SOCID: 9AF9759F29FE7318829581437D51135E492F1A3199FAF26523 6608CB46149AD4
SLA: Local Auth [Forced mode]
Start Auth... Ok
Continue Auth... Ok
FF: Looking for EMI Found
SLA: Start 0x15
EMI loaded by MEID: BFBA735981EBB370EDBFE829EAA122D0
AGENT:
[35607fde] C:\InfinityBox\CM2MT2\boot\Infinix\X657C\MTK_AllIn One_DA.94cdc12e.bin
DA sent
Jump to DA... Ok
Sync... Ok
DA: Agent Started
DA: SYNC
MODE: BROM
EMMC
CID: 90014A484347386134A2106190075737 crc Ok
Vendor: Hynix OEM: 330 ID: 484347386134 [HCG8a4] PRV: 0xA2
Serial: 274829319 0x10619007
MM/YY: 5/2020
EMI: FireFly preloader_x680f_h6116.bin with 4 memory type(s)
1. eMMC DDR3 ID: 150100475836424142 Samsung GX6BAB RAM: 3.00 Gb
2. eMMC DDR3 ID: 150100514436334D42 Samsung QD63MB RAM: 2.00 Gb
3. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb
4. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb
2nd stage confirmed
DA: SYNC Ok
Load HW info...
RAM: SRAM: 0x00040000 [ 256.00 Kb ]
EMMC
MM/YY: 5/2020
CODE: Cervino
RNID: DB9AC15A60598B23D04055F1ED8FCBDB
USB: HIGH-SPEED
Boot done MODERN [RAPHAEL] 10 sec
Analyze PMT... Ok
PMT: PGPT [0x64] Records: 41
Probe boot... Ok 672 us
SW: Infinix/X680F-OP/Infinix-X680F:10/QP1A.190711.020/P-OP-220718V463:user/release-keys
Product Brand: Infinix
Product Device: Infinix-X680F
Product Model: Infinix X680F
Product Name: X680F-OP
Display ID: X680F-H6116P-Q-OP-220718V463
SW Version: P-OP-220718V463
Ver. CodeName: REL
Ver. Release: 10
Sec. Patch: 2022-07-05
Build Time: 18-Jul-22 2:53:59 PM
CPU: arm64-v8a
Product Info: x680f_h6116
SW: full_x680f_h6116-user 10 QP1A.190711.020 22438 release-keys
Product Board: Infinix-X680F
Product Manfct: INFINIX MOBILITY LIMITED
Device ID: infinix-mobility-limited-infinix-x680f-x680f-op
Strategy: [infinix]
Firmware ID: MT6765_INFINIX_MOBILITY_LIMITED_Infinix_X680F_OSv1 0_X680F-H6116P-Q-OP-220718V463_QP1A.190711.020_x680f_h6116
Android ver: 10
EMMC
MM/YY: 5/2020
Backup to C:\InfinityBox\CM2MT2\backup\MT6765__BFBA735981EBB 370EDBFE829EAA122D0\
Items to check: 22
Read [26] NVRAM
NVRAM: Items: 0xA2 Size: 0x08C02F State: Ok
BT MAC: AC2334A2460E
IMEI[1]: 352
IMEI[2]: 352
Read [10] NVDATA
Read [3] PROINFO
Read [27] LK
lk [8e904b4e]
Read [9] NVCFG
Read [12] PROTECT1
Read [1] PGPT
Read [11] PERSIST
Read [0] PRELOADER
Done 9 files 17 sec
Compress: C:\InfinityBox\CM2MT2\backup\MT6765__BFBA735981EBB 370EDBFE829EAA122D0\
Cleanup...
Ok
Verify C:\InfinityBox\CM2MT2\backup\MT6765__BFBA735981EBB 370EDBFE829EAA122D0.7z Enough [infinix-mobility-limited-infinix-x680f-x680f-op]
Stage: Android OS
[1] ...
[2] ...
[4] USERDATA... Ok
[5] USERDATA... Ok
Stage: FRP...
Done
Reset port...
Trying to reboot...
Finished 49 sec
Old 06-21-2024, 12:29   #76213 (permalink)
Member: 1835756
Thanks Meter: 922
Infinix smart 6(x6511b)frp done
Operation: Reset | Format Infinix X6511b Boot [FF] FireFly [v2.28a3 (beta)]
Continue? Yes
[-] Wipe
[-] Userdata
[+] FRP
[+] Smart
Wait...
Backup exist: C:\Users\mobitech\Desktop\INFINITY SETUPS\CM2SP3_2.28a3\backup\sp9863a_21d85d9ac709d0 ae\
Stage: FRP...
[1] Writing...
fault 0x79 0x84 | BSL_REP_OPERATION_FAILED
fault 0x78 0x84 | BSL_REP_OPERATION_FAILED
[persist] addr 0x0000 size 0x200000
Finished
Stage: Smart...
[17] Format... Ok
[18] Format... Ok
Completed
Finished 9 sec
Bye
The Following User Says Thank You to lalit bisht For This Useful Post:
Old 06-22-2024, 06:08   #76214 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Infinix-X659B
[+] Smart Analyzer
[-] Wipe
[+] Userdata
[+] FRP
[-] Accounts
Wait...
Platform: FireFly SmartPhone - MT6580/67:35|39|52|53|61|65|68|71
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
PTFN: MediaTek USB Port_V1632 (COM24)
MODE [0]: BOOTROM; PORT: 24
BROM: Init... Ok
CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707
CODE: Talbot
MEID: 25FEE844A227C1F1A3F3E93FC2DB22B0
SOCID: 3C189F25F02C91A69B7BF5BC5C4F87FB76DB5A69129E17D8A8 82559412BB3383
FireFly: Init
Start Auth... Ok
Continue Auth... Ok
Start... Ok
Init Core... Ok
FireFly: Running: v06.05.06 on MT6768
EMMC init passed
extcsd stored: C:\InfinityBox\CM2MT2\backup\ext_csd\MT6768__extcs d_0013-Micron_G1J9S9_5.1_2024-06-22.bin
EMMC
CID: 13014E47314A395339100FED868A284B crc Ok
Vendor: Micron OEM: 334 ID: 47314A395339 [G1J9S9] PRV: 0x10
Serial: 267224714 0x0FED868A
MM/YY: 2/2021
USER: 0x1D1F000000 [ 116.48 Gb ]
CSD: D04F01328F5913FFFFFFFFEF8A400083
EXTCSD rev1.8 EMMC 5.1 FW: 0302
BOOT_BUS_WIDTH: 0x02
PARTITION_CONFIG: 0x48
BOOT size: 0x400000
RPMB size: 0x1000000 16.00 Mb
Size: Market 128 Gb Actual 0x1D1F000000 116.48 Gb
USB: HIGH-SPEED
Boot done FireFly 7 sec
Analyze PMT... Ok
PMT: PGPT [0x64] Records: 51
Get slot info... a
Probe boot... Ok 6 sec
SW: Infinix/X659B-OP/Infinix-X659B:11/RP1A.200720.011/221217V224:user/release-keys
Product Device: Infinix-X659B
Product Model: Infinix X659B
Product Name: X659B-OP
Patch Level: RP1A.200720.011
Display ID: X659B-H696AvAw-R-OP-221217V224
SW Version: 221217V224
Ver. CodeName: REL
Ver. Release: 11
Sec. Patch: 2022-12-05
Build Time: 16-Dec-22 6:16:57 PM
CPU: arm64-v8a
Product Info: x659b_h696
SW: vnd_x659b_h696-user 11 RP1A.200720.011 193255 release-keys
Product Board: Infinix-X659B
Board Platform: mt6768
Device ID: infinix-mobility-limited-infinix-x659b-x659b-op
Strategy: [infinix]
Firmware ID: MT6768_INFINIX_MOBILITY_LIMITED_Infinix_X659B_OSv1 1_X659B-H696AvAw-R-OP-221217V224_RP1A.200720.011_x659b_h696
Android ver: 11
EMMC
MM/YY: 2/2021
BOOT size: 0x400000
Backup to C:\InfinityBox\CM2MT2\backup\MT6768__25FEE844A227C 1F1A3F3E93FC2DB22B0\
Items to check: 22
Read [36] NVRAM
NVRAM: Items: 0xB8 Size: 0x122373 State: Ok
BT MAC: 5810B74B0248
Read [19] NVDATA
Read [3] PROINFO
Read [18] NVCFG
Read [21] PROTECT1
Read [1] PGPT
Read [20] PERSIST
Read [0] PRELOADER
Read [29] LK_A
lk [f625703c]
Read [42] LK_B
Done 10 files 2 min 44 sec
Compress: C:\InfinityBox\CM2MT2\backup\MT6768__25FEE844A227C 1F1A3F3E93FC2DB22B0\
Cleanup...
Ok
Verify C:\InfinityBox\CM2MT2\backup\MT6768__25FEE844A227C 1F1A3F3E93FC2DB22B0.7z Enough [infinix-mobility-limited-infinix-x659b-x659b-op]
Stage: Android OS
[1] ...
[4] USERDATA... Ok
[5] USERDATA... Ok
Stage: FRP...
Done
Reset port...
Trying to reboot...
Finished 3 min 21 sec
Old 06-22-2024, 06:28   #76215 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,929
Condor p8 lite pgn610 frp remove done
original poster
brahim21329 DZGSM
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 41 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 520001154D42314564B20742DF8001EE
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BMB1E
[eMMC] : FLASH_CID : 150100524531424D4207B264EE0193DF
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0x216B188E139AE91410F4C645ACC79D0B
INT RAM : 0x00020000
EXT RAM : 0xC0000000 [3 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:12
The Following User Says Thank You to profkefah For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.73271 seconds with 10 queries
