06-23-2024, 12:26 | #76216 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,433 | Xiaomi A2 Plus [+] Smart Analyzer [-] Wipe [-] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make [Userdata] On and repeat operation Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1632 (COM24) MODE [0]: BOOTROM; PORT: 24 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: B6BBC92B31E8CFEFDC2CA8DA3439FFC7 BROM: Sec Level: 0x000000E7 Mode: SBC+SLA+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 8F842E01E91F44B2CD80B02B5F0DC480AA0EA3CA9CC8AEF135 DC545835AF3284 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: B6BBC92B31E8CFEFDC2CA8DA3439FFC7 AGENT: [42c76018] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.2022-04-10.3365c4d2.bin [b307cb3a] C:\InfinityBox\CM2MT2\boot\Xiaomi\A1_A1+_A2_A2+_wa ter\preloader_water.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: D62D004D4D433634475119AEC38AAAD5 crc Ok Vendor: Foresee OEM: 11520 ID: 4D4D43363447 [MMC64G] PRV: 0x51 Serial: 430883722 0x19AEC38A MM/YY: 10/2023 EMI: Init via preloader_water.bin EMI: MT6765 preloader_water.bin with 7 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 3. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 7. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: D62D004D4D433634475119AEC38AAAD5 crc Ok Vendor: Foresee OEM: 11520 ID: 4D4D43363447 [MMC64G] PRV: 0x51 Serial: 430883722 0x19AEC38A MM/YY: 10/2023 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 9CECBD1EF64F1FA50AFE796514B6B3C0 MEID: B6BBC92B31E8CFEFDC2CA8DA3439FFC7 USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 47 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 56 Get slot info... a Probe boot... Ok 953 us Product Brand: Redmi Product Device: water Product Model: water Product Name: water_global SW: Redmi/water_global/water:12/SP1A.210812.016/V14.0.25.0.TGOMIXM:user/release-keys Patch Level: SP1A.210812.016 Display ID: SP1A.210812.016 SW Version: V14.0.25.0.TGOMIXM Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2024-03-01 Build Time: 07-Mar-24 8:00:41 AM Product Info: water SW: vnd_water-user 12 SP1A.210812.016 V14.0.25.0.TGOMIXM release-keys Product Manfct: Xiaomi Product Board: water Board Platform: mt6765 Device ID: redmi-xiaomi-water-water-global Strategy: [xiaomi] Firmware ID: MT6765_Xiaomi_water_OSv12_V14.0.25.0.TGOMIXM_SP1A. 210812.016_water_Redmi Android ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] EMMC CID: D62D004D4D433634475119AEC38AAAD5 crc Ok Vendor: Foresee OEM: 11520 ID: 4D4D43363447 [MMC64G] PRV: 0x51 Serial: 430883722 0x19AEC38A MM/YY: 10/2023 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Verify config values... Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6765__B6BBC92B31E8C FEFDC2CA8DA3439FFC7\ Items to check: 22 Read [24] NVRAM NVRAM: Items: 0xB5 Size: 0x0AD804 [SecLv: Vendor Signed] State: Ok WiFi MAC: AA006E742F76 BT MAC: 3050CEF88B0B Read [14] NVDATA Read [22] PROINFO Read [13] NVCFG Read [17] PROTECT1 Read [1] PGPT Read [20] PERSIST Read [0] PRELOADER Read [30] LK_A lk [fd7d1ee9] Read [44] LK_B Done 10 files 15 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6765__B6BBC92B31E8C FEFDC2CA8DA3439FFC7\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__B6BBC92B31E8C FEFDC2CA8DA3439FFC7.7z Enough [redmi-xiaomi-water-water-global] Stage: Android OS Off Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 1 min 38 sec Reconnect Power/Cable now |
06-23-2024, 14:23 | #76217 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,778 | Card found : S/N : 73CA70CC , v0160 Chinese Miracle II [MTK module] v 1.58 Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : B24AAC9CDEB34A29D37C36DD58C0978B BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 4942 PLock|MobTrack : Not active Done! Elapsed: 00:00:06 Reconnect Power/Cable! |
06-24-2024, 06:14 | #76218 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,433 | itel Vision1 Plus(P36 Pro LTE) Operation: Connect itel vision-1-plus Boot [FF] FireFly [v2.28a4 (beta)] Wait... - Power device Off - Connect cable [remember Vol+ | Vol-] [remember Test-Point] Waiting for device... Device found PTFN: SPRD U2S Diag (COM13) vid 0x1782 pid 0x4D00 boot: SPRD3 boot iLoader... Ok start iLoader... Ok Handshake... Ok boot xLoader... Ok start FireFly... Ok Loader exec Ok Dev UID: a7f7704de2cb11eeeb5b1d2aaca7daac35b6f52c183d261fbd 5495e34514a267 get storage info... EMMC CID: 8F010055593543533012E0840C06178D crc Ok Vendor: Unknown 0x008F OEM: 256 ID: 555935435330 [UY5CS0] PRV: 0x12 Serial: 3766750214 0xE0840C06 MM/YY: 1/2020 CSD: D02701320F5903FFFFFFFFEF8A404001 temp_write_protect: False perm_write_protect: False wp_group: 0x10 en 0x01 EXTCSD rev1.8 EMMC 5.1 FW: 12 ERASE_GROUP_DEF: 0x0400 BOOT_BUS_WIDTH: 0x00 PARTITION_CONFIG: 0x08 RST_N_FUNCTION: 0x01 PART_S_COMPLETED: False BOOT size: 0x400000 RPMB size: 0x400000 4.00 Mb WP_GRP_SIZE: 0x800000 8.00 Mb Size: Market 32 Gb Actual 0x750000000 29.25 Gb EOL: Status: Normal: Less than 80% reserved blocks used EOL_A: SLC status: 40% - 50% used EOL_B: MLC status: 60% - 70% used read extcsd... Ok extcsd stored: C:\InfinityBox\CM2SP3\backup\ext_csd\none_a7f7704d e2cb11ee_extcsd_008F-Unknown_0x008F_UY5CS0_5.1_2024-06-24.bin get partitions... Partitions: 40 Connected get sw info... 3 sec Patch Level: PPR1.180610.011 Display ID: L6501-F6311-9.0-OP-V051-20211223 SW Version: OP-V051-20211223 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2022-01-05 Build Time: 23-Dec-21 10:01:05 AM Product Model: itel L6501 Product Brand: Itel Product Name: F6311 Product Device: itel-L6501 Market Name: itel Vision1 Plus(P36 Pro LTE) CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: itel Product Info: L6501 SW: L6501-user 9 PPR1.180610.011 593 release-keys Product Board: L6501 Board Platform: sp9863a Product Name: L6501 Product Device: L6501 Android ver: 9 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Device ID: itel-l6501-f6311-itel-vision1-plus-p36-pro-lte- Strategy: [itel] Firmware ID: SP9863A_itel_itel_L6501_OSv9_L6501-F6311-9.0-OP-V051-20211223_PPR1.180610.011_L6501_Itel Backup 5 items to: C:\InfinityBox\CM2SP3\backup\sp9863a_a7f7704de2cb1 1ee\ Read to C:\InfinityBox\CM2SP3\backup\sp9863a_a7f7704de2cb1 1ee\ Reading... Read [1/40] prodnv 5.00 Mb Ok Read [2/40] miscdata 1024.00 Kb Ok Read [9/40] uboot 1024.00 Kb Ok Read [14/40] l_fixnv1 2.00 Mb Ok Read [15/40] l_fixnv2 2.00 Mb Ok Saved 5 of 5 images, 11.00 Mb of 11.00 Mb Done 5 files Compress: C:\InfinityBox\CM2SP3\backup\sp9863a_a7f7704de2cb1 1ee\ Cleanup... Ok Verify C:\InfinityBox\CM2SP3\backup\sp9863a_a7f7704de2cb1 1ee.7z Verified [4fba1884] Read Device-ID... BT MAC: 88:1c:95:1a:74:bc WiFi MAC: 88:1c:95:1a:74:bd PSN1: 90PS0563714059101822 PSN2: N/A PSN3: N/A MemTool load 40 items Finished 44 sec Operation: Reset | Format itel vision-1-plus Boot [FF] FireFly [v2.28a4 (beta)] WARNING: Reset may delete ALL USER DATA! Continue? Yes [+] Wipe [-] Userdata [+] FRP [+] Smart Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... Backup exist: C:\InfinityBox\CM2SP3\backup\sp9863a_a7f7704de2cb1 1ee\ Process Wipe... Reading... Ok Writing... Ok Process FRP... Looking for items... 1 items found [1] Writing... Ok Process nvram... [16] Format... Ok [17] Format... Ok Completed Finished 6 sec Reboot... Disconnect cable if it freez fault 0x05 0x8E | BSL_PHONE_WAIT_INPUT_TIMEOUT Bye |
06-24-2024, 19:20 | #76219 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | LENOVO K6 HANG ON LOGO DONE BY CM2 Card found : 73CA70CC , v0160 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : 3762C395 ID_BLOCK_E : 00007A2A ID_BLOCK_L : 472B1AE0D492DD363B7854880396A5DC ID_BLOCK_L : C0AB8960750C31BE7FE55A9E1A7AFC4A Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
06-25-2024, 07:42 | #76220 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,433 | Digit4G-Bold Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [-] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1632 (COM8) MODE [0]: BOOTROM; PORT: 8 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] MEID: 1030B8DCD51B266ED9CFA317FB8A2793 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 27C36CB4053C09F03CBAD16CBA7A31E9C29DE23EAA5C20D425 73A1C682E4AC15 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 1030B8DCD51B266ED9CFA317FB8A2793 AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6739; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMI: FireFly preloader_fise6731_kaio_m.bin with 6 memory type(s) 1. eMMC DDR3 ID: 700100454534454434 Kingston EE4ED4 RAM: 512.00 Mb 2. eMMC DDR3 ID: F40122426977696E20 Biwin Biwin RAM: 512.00 Mb 3. eMMC DDR3 ID: 150100463558354342 Samsung F5X5CB RAM: 512.00 Mb 4. eMMC DDR3 ID: 150100464A32354142 Samsung FJ25AB RAM: 512.00 Mb 5. eMMC DDR3 ID: FE014E50314A39344D Micron P1J94M RAM: 512.00 Mb 6. eMMC DDR3 ID: 90014A483447326111 Hynix H4G2a RAM: 512.00 Mb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0x20000000 [ 512.00 Mb ] EMMC CID: 90014A4834473261110230D04CBB6531 crc Ok Vendor: Hynix OEM: 330 ID: 483447326111 [H4G2a] PRV: 0x02 Serial: 818957499 0x30D04CBB MM/YY: 6/2018 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE9000000 [ 3.64 Gb ] CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] RNID: 29EDCF9F8B72551BE9F651AF4E531EC3 MEID: 1030B8DCD51B266ED9CFA317FB8A2793 USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 14 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 34 Probe boot... Ok 203 us Patch Level: MRA58K Display ID: Digit_M42445P_DG_SW01_20201103_1851 SW Version: Digit_M42445P_DG_SW01_20201103_1851 Ver. CodeName: REL Ver. Release: 6.0 Sec. Patch: 2015-10-01 Build Time: 03-Nov-20 10:53:50 AM Product Model: Digit4G-Bold Product Brand: Digit Product Name: Digit4G-Bold Product Device: Digit4G-Bold Product Manfct: alps CPU: armeabi-v7a,armeabi Board Platform: mt6739 Product Info: Digit4G-Bold SW: full_fise6731_kaio_m-user 6.0 MRA58K 1604400770 dev-keys Product Model: mt6731 Device ID: digit4g-bold Strategy: [none|generic] Firmware ID: MT6739_alps_mt6731_OSv6.0_Digit_M42445P_DG_SW01_20 201103_1851_MRA58K_Digit4G-Bold Android ver: 6 UserDataFS: 0x01 [ext4|4+] CacheFS: 0x01 [ext4|4+] EMMC CID: 90014A4834473261110230D04CBB6531 crc Ok Vendor: Hynix OEM: 330 ID: 483447326111 [H4G2a] PRV: 0x02 Serial: 818957499 0x30D04CBB MM/YY: 6/2018 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE9000000 [ 3.64 Gb ] Backup to C:\InfinityBox\CM2MT2\backup\MT6739__1030B8DCD51B2 66ED9CFA317FB8A2793\ Items to check: 22 Read [21] NVRAM NVRAM: Items: 0x99 Size: 0x08B424 State: Ok WiFi MAC: 508A0FC2425D BT MAC: 508A0FC1F352 Read [8] NVDATA Read [14] PROINFO Read [22] LK lk [4ff5270b] Read [7] NVCFG Read [10] PROTECT1 Read [1] PGPT Read [0] PRELOADER Done 8 files 4 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6739__1030B8DCD51B2 66ED9CFA317FB8A2793\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6739__1030B8DCD51B2 66ED9CFA317FB8A2793.7z Enough [digit4g-bold] Stage: Android OS [1] ... Create partition image... Ok Ok [2] ... Create partition image... Ok Ok [4] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 46 sec Reconnect Power/Cable now |
06-27-2024, 07:04 | #76221 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,433 | Samsung A10s Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [-] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE [0]: PRELOADER PORT; PORT: 3 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 19F1ABC1959C424A43B8A44EDFBAF629C1DFFABBCA7A2BAB35 F2FECD7A010A15 AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin [415d0617] C:\InfinityBox\CM2MT2\boot\Samsung\SM-A107F\preloader_s96116aa1.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MediaTek USB Port_V1632 (COM8) MODE [0]: BOOTROM; PORT: 8 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 53103B931E5531342CFF28BC9A62C741 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 19F1ABC1959C424A43B8A44EDFBAF629C1DFFABBCA7A2BAB35 F2FECD7A010A15 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 53103B931E5531342CFF28BC9A62C741 AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin [415d0617] C:\InfinityBox\CM2MT2\boot\Samsung\SM-A107F\preloader_s96116aa1.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100514436334D42037E819B3337C7 crc Ok Vendor: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 Serial: 2122423091 0x7E819B33 MM/YY: 3/2020 EMI: Init via preloader_s96116aa1.bin EMI: MT6765 preloader_s96116aa1.bin with 3 memory type(s) 1. eMMC DDR3 ID: 150100514436334D42 Samsung QD63MB RAM: 2.00 Gb 2. eMMC DDR3 ID: 700100464D42434541 Kingston FMBCEA RAM: 2.00 Gb 3. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 150100514436334D42037E819B3337C7 crc Ok Vendor: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 Serial: 2122423091 0x7E819B33 MM/YY: 3/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 76CB1F970FC703555D86BBC44F02FE63 MEID: 53103B931E5531342CFF28BC9A62C741 USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 1 min 16 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 39 Probe boot... Ok 1 sec SW: samsung/a10sxx/a10s:11/RP1A.200720.012/A107FXXS8CWD3:user/release-keys Product Brand: samsung Product Device: a10s Product Model: SM-A107F Product Name: a10sxx Patch Level: RP1A.200720.012 Display ID: RP1A.200720.012.A107FXXS8CWD3 SW Version: A107FXXS8CWD3 Build Time: 24-Apr-23 4:16:46 AM Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-03-01 CPU: armeabi-v7a,armeabi Product Info: a10s SW: a10sxx-user 11 RP1A.200720.012 A107FXXS8CWD3 release-keys Product Board: S96116RA1 Board Platform: mt6765 Product Manfct: samsung Device ID: samsung-sm-a107f-a10s-a10sxx-s96116ra1-s96116aa1 Strategy: [samsung] Firmware ID: MT6765_samsung_SM-A107F_OSv11_RP1A.200720.012.A107FXXS8CWD3_RP1A.200 720.012_a10s Android ver: 11 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 150100514436334D42037E819B3337C7 crc Ok Vendor: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 Serial: 2122423091 0x7E819B33 MM/YY: 3/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] Verify config values... Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6765__53103B931E553 1342CFF28BC9A62C741\ Items to check: 22 Read [5] NVRAM NVRAM: Items: 0xBC Size: 0x0AD96C [SecLv: Vendor Signed] State: Ok WiFi MAC: 1089FB0EC1DE BT MAC: 1089FB0EC1DF IMEI[1]: IMEI[2]: Read [14] NVDATA Read [23] PROINFO Read [28] LK lk [3b211064] Read [13] NVCFG Read [16] PROTECT1 Read [1] PGPT Read [19] PERSIST Read [0] PRELOADER Read [6] EFS Read [7] SEC_EFS Read [20] PERSISTENT Done 12 files 17 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6765__53103B931E553 1342CFF28BC9A62C741\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__53103B931E553 1342CFF28BC9A62C741.7z Enough [samsung-sm-a107f-a10s-a10sxx-s96116ra1-s96116aa1] Stage: Android OS [1] ... Create partition image... Ok Ok [2] ... Create partition image... Ok Ok [4] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok 1 items found [1] Process... Done Stage: Smart... Ok Reset port... Trying to reboot... Finished 2 min 8 sec Reconnect Power/Cable now |
06-28-2024, 06:08 | #76222 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,433 | Vivo Y12S Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [-] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE [0]: PRELOADER PORT; PORT: 3 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 8ED7BB9CBF6E82A7A9310FBA471E899E7D9375F1FD05D868D7 70FC0B22361B1F AGENT: [ecb438fd] C:\InfinityBox\CM2MT2\boot\Vivo\2023-08\MTK_AllInOne_DA_v3.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 90014A68433961503301102CABCE5845 crc Ok Vendor: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 Serial: 271363022 0x102CABCE MM/YY: 5/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 8E27690131AB3167615B0CF608A02374 USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 11 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 47 Probe boot... Ok 1 sec SW: vivo/2026/2026:11/RP1A.200720.012/compiler0408154211:user/release-keys Product Brand: vivo Product Device: 2026 Product Model: V2026 Product Name: 2026 Patch Level: RP1A.200720.012 Display ID: RP1A.200720.012 release-keys Product Info: k65v1_64_bsp SW: full_k65v1_64_bsp-user 11 RP1A.200720.012 eng.compil.20240408.154559 release-keys SW Version: eng.compil.20240408.154559 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-05-01 Build Time: 08-Apr-24 7:42:11 AM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Board: k65v1_64_bsp Board Platform: mt6765 Product Manfct: vivo Device ID: vivo-v2026-k65v1-64-bsp Strategy: [vivo] Firmware ID: MT6765_vivo_V2026_OSv11_RP1A.200720.012_k65v1_64_b sp Android ver: 11 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 90014A68433961503301102CABCE5845 crc Ok Vendor: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 Serial: 271363022 0x102CABCE MM/YY: 5/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Backup to C:\InfinityBox\CM2MT2\backup\MT6765__F5FE1DB2B5A29 7E6D565BC52351E897A\ Items to check: 22 Read [35] NVRAM NVRAM: Items: 0xB6 Size: 0x1250C6 State: Ok WiFi MAC: AA006E742F76 BT MAC: D09CAE6E0083 IMEI[1]: 8 IMEI[2]: 8 Read [10] NVDATA Read [25] PROINFO Read [36] LK lk [9e2a5d18] Read [9] NVCFG Read [20] PROTECT1 Read [1] PGPT Read [23] PERSIST Read [0] PRELOADER Done 9 files 9 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6765__F5FE1DB2B5A29 7E6D565BC52351E897A\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__F5FE1DB2B5A29 7E6D565BC52351E897A.7z Enough [vivo-v2026-k65v1-64-bsp] Stage: Android OS [1] ... Create partition image... Ok Ok [2] ... Create partition image... Ok Ok [4] USERDATA... Ok [5] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Ok Reset port... Trying to reboot... Finished 1 min 0 sec Reconnect Power/Cable now |
06-28-2024, 11:55 | #76223 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,433 | Sparx Neo_X Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [-] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM43) MODE [0]: PRELOADER PORT; PORT: 43 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 43600D6B7F310014B601E08801A3DA584E2A2D40E1FDAE7F65 B990E94047B8CB AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 90014A68433861503E02358D3FD438FB crc Ok Vendor: Hynix OEM: 330 ID: 68433861503E [hC8aP>] PRV: 0x02 Serial: 898449364 0x358D3FD4 MM/YY: 3/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: FF049F91E92164A3278421E7CBDEC38A USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 7 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 49 Get slot info... b Probe boot... Ok 547 us Build Time: 26-Aug-23 6:33:50 PM SW: Neo_X-user 12 SP1A.210812.016 1693074822 release-keys Display ID: SP1A.210812.016 release-keys Patch Level: SP1A.210812.016 Product Info: k65v1_64_bsp Ver. CodeName: REL SW Version: ASW2206_BD_1201_V2035 Ver. Release: 12 Sec. Patch: 2023-06-05 Product Board: Neo_X Product Brand: Sparx Product Device: Neo_X Product Manfct: Sparx Product Model: Neo X Product Name: Neo_X SW: Sparx/Neo_X/Neo_X:12/SP1A.210812.016/1693074822:user/release-keys Board Platform: mt6765 Product Board: k65v1_64_bsp Product Brand: alps Product Device: k65v1_64_bsp Product Manfct: alps Product Model: k65v1_64_bsp Product Name: vnd_k65v1_64_bsp Display ID: Sparx Neo X Product Info: Neo_X Device ID: sparx-neo-x-k65v1-64-bsp-vnd-k65v1-64-bsp Strategy: [none|generic] Firmware ID: MT6765_Sparx_Neo_X_OSv12_Sparx_Neo_X_SP1A.210812.0 16_Neo_X_alps Android ver: 12 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 90014A68433861503E02358D3FD438FB crc Ok Vendor: Hynix OEM: 330 ID: 68433861503E [hC8aP>] PRV: 0x02 Serial: 898449364 0x358D3FD4 MM/YY: 3/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Backup to C:\InfinityBox\CM2MT2\backup\MT6765__9A6D6532CF3E1 18F831DBAF3734C047B\ Items to check: 22 Read [17] NVRAM NVRAM: Items: 0xB5 Size: 0x0AC7BC State: Ok WiFi MAC: 20809723F1D8 BT MAC: 20809723DA2C IMEI[1]: 3 IMEI[2]: 3 Read [7] NVDATA Read [15] PROINFO Read [6] NVCFG Read [10] PROTECT1 Read [1] PGPT Read [13] PERSIST Read [0] PRELOADER Read [24] LK_A lk [ac4a5753] Read [38] LK_B Done 10 files 7 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6765__9A6D6532CF3E1 18F831DBAF3734C047B\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__9A6D6532CF3E1 18F831DBAF3734C047B.7z Enough [sparx-neo-x-k65v1-64-bsp-vnd-k65v1-64-bsp] Stage: Android OS [1] ... Create partition image... Ok Ok [4] USERDATA... Ok [5] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 38 sec Reconnect Power/Cable now |
07-03-2024, 00:12 | #76224 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,065 | Oppo A16k FRP Code: Operation: Reset Settings/Format FS [ v2.64a3 (beta) ] [+] Smart Analyzer [+] Wipe [+] Userdata [+] FRP [+] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [-] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM4) MODE [0]: PRELOADER PORT; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 6CB8CB0BC3DA98A0A1557A8BCC708EFC23A96D00E064AAFFCFDD253B4CD7491B AGENT: [ab6a11d9] C:\InfinityBox\CM2MT2\boot\Oppo\2022-10\MTK_AllInOne_DA.5419c171.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00038000 [ 224.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 90014A68423861503E0300880D2C98B5 crc Ok Vendor: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 Serial: 8916268 0x00880D2C MM/YY: 9/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 9E5598B8012AE4166FE6A938324EF24D USB: HIGH-SPEED Boot done MODERN [RAPHAEL] 9 sec Analyze PMT... Ok Partition Table: PGPT [0x64] Records: 48 Probe boot... vendor_boot;no ramdisk;recovery;boot; Finished 2 sec Probe core... Mount[erofs] system 0x0057D00000/0x5A2FC000 Mount[erofs] vendor 0x0040900000/0x172BA000 Mount[erofs] product 0x00B2000000/0x0116E000 Mount[erofs] odm 0x00B3200000/0x077B2000 Ok 3 sec SW: alps/sys_oplus_mssi_64_cn/oplus_mssi_64_cn:11/RP1A.200720.011/1688731040423:user/release-keys Product Brand: alps Product Device: oplus_mssi_64_cn Product Model: oplus_mssi_64_cn Product Name: sys_oplus_mssi_64_cn Patch Level: RP1A.200720.011 Display ID: RP1A.200720.011 release-keys SW Version: 1688731040423 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-07-05 Build Time: 7/7/2023 12:19:30 PM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: oplus_mssi_64_cn SW: sys_oplus_mssi_64_cn-user 11 RP1A.200720.011 1688731040423 release-keys Product Info: CPH2349 Kernel Info: 4.19.127 Display ID: CPH2349_11_A.01_230707 Display ID: CPH2349_11_A.01 Device ID: oplus-mssi-64-cn-sys-oplus-mssi-64-cn-MT6765_CPH2349_export_11_A.06_2021092503050231 Strategy: [realme] Firmware ID: MT6765_oplus_mssi_64_cn_OSv11_CPH2349_11_A.01_RP1A.200720.011_CPH2349_alps.MT6765_CPH2349_export_11_A.06_2021092503050231 Android ver: 11 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] EMMC CID: 90014A68423861503E0300880D2C98B5 crc Ok Vendor: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 Serial: 8916268 0x00880D2C MM/YY: 9/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__845F443614A5193AA73972B795A55A64 Stage: Android OS [2] WIPE... Skip for Strategy [realme] [3] WIPE... Create partition image... Ok Ok [4] WIPE... Create partition image... Ok Ok [6] USERDATA... Ok [7] USERDATA... Ok Stage: FRP... Reset [1 of 2] frp... Ok Verify [1 of 2] 128.00 Kb... Ok Done Stage: Smart... Nothing to-do Stage: Accounts... regionlock Finished 28 sec Keep connection |
07-04-2024, 06:58 | #76225 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,433 | Dcode ds_cl3 Operation: Reset Settings/Format FS [ v2.64a3 (beta) ] [+] Smart Analyzer [-] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM6) MODE [0]: PRELOADER PORT; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000001 Mode: SBC VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 4356CD48B7E7D5915CF06E09123C101A5E29DADED7850AFBE4 7F3EE4FEBC94A8 AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MediaTek USB Port_V1632 (COM3) MODE [0]: BOOTROM; PORT: 3 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: B50C4F0815453CCBD840C808773A830A BROM: Sec Level: 0x000000E1 Mode: SBC+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 4356CD48B7E7D5915CF06E09123C101A5E29DADED7850AFBE4 7F3EE4FEBC94A8 EMI loaded by MEID: B50C4F0815453CCBD840C808773A830A AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: D6010341334135363112D1F2DDD019D7 crc Ok Vendor: Foresee OEM: 259 ID: 413341353631 [A3A561] PRV: 0x12 Serial: 3522354640 0xD1F2DDD0 MM/YY: 1/2022 EMI: FireFly preloader_k65v1_64_bsp.bin with 4 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb 3. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: D6010341334135363112D1F2DDD019D7 crc Ok Vendor: Foresee OEM: 259 ID: 413341353631 [A3A561] PRV: 0x12 Serial: 3522354640 0xD1F2DDD0 MM/YY: 1/2022 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE67800000 [ 57.62 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 9F9D85E695EE3EF7F73F52F5E0846957 MEID: B50C4F0815453CCBD840C808773A830A USB: HIGH-SPEED Boot done MODERN [RAPHAEL] 13 sec Analyze PMT... Ok Partition Table: PGPT [0x64] Records: 46 Get slot info... a Probe boot... Ok 1 sec Product Brand: DCODE Product Device: DS_CL3 Product Model: DS-CL3 Product Name: DS_CL3 SW: DCODE/DS_CL3/DS_CL3:13/TP1A.220624.014/1690367777:user/release-keys Patch Level: SP1A.210812.016 Display ID: DS_CL3_H1_20230726_V7.0 SW Version: 1690367777 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-06-05 Build Time: 26-Jul-23 10:36:17 AM Product Info: DS_CL3 SW: DS_CL3-user 12 SP1A.210812.016 1690367777 release-keys Product Manfct: Premier Code (PRIVATE) LIMITED Product Board: k65v1_64_bsp Board Platform: mt6765 Device ID: dcode-premier-code-private-li-ds-cl3-k65v1-64-bsp Strategy: [none|generic] Firmware ID: MT6765_Premier_Code_PRIVATE_LIMITED_DS-CL3_OSv12_DS_CL3_H1_20230726_V7.0_SP1A.210812.016_ DS_CL3_DCODE Android ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] EMMC CID: D6010341334135363112D1F2DDD019D7 crc Ok Vendor: Foresee OEM: 259 ID: 413341353631 [A3A561] PRV: 0x12 Serial: 3522354640 0xD1F2DDD0 MM/YY: 1/2022 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE67800000 [ 57.62 Gb ] Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__B50C4F0815453 CCBD840C808773A830A Stage: Android OS [1] ... Create partition image... Ok Ok [4] USERDATA... Ok [5] USERDATA... Ok Stage: FRP... Reset [1 of 2] frp... Ok Verify [1 of 2] 128.00 Kb... Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 34 sec Reconnect Power/Cable now |
07-04-2024, 08:18 | #76226 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,433 | TECNO-KE5k Operation: Reset Settings/Format FS [ v2.64a3 (beta) ] [+] Smart Analyzer [-] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1632 (COM10) MODE [0]: BOOTROM; PORT: 10 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: BDD24A9FB8FFF564461BF1DCF7EFED47 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: ADF5C54FBD5A08594B56E9AB45E9AEE760AE4A6F6646C4167E 136AA17F3FC608 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: BDD24A9FB8FFF564461BF1DCF7EFED47 AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100445036444142028C19904D1803 crc Ok Vendor: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 Serial: 2350485581 0x8C19904D MM/YY: 1/2021 EMI: FireFly preloader_ke5k_h6122.bin with 20 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 150100444836444D42 Samsung DH6DMB RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100334836434142 Samsung 3H6CAB RAM: 6.00 Gb 5. eMMC LP_DDR4X ID: 150100335636434D42 Samsung 3V6CMB RAM: 6.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 6.00 Gb 10. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 150100445036384D42 Samsung DP68MB RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 17. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 18. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 19. eMMC LP_DDR4X ID: 13014E53304A333741 Micron S0J37A RAM: 3.00 Gb 20. eMMC LP_DDR4X ID: 150100445036444242 Samsung DP6DBB RAM: 4.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100445036444142028C19904D1803 crc Ok Vendor: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 Serial: 2350485581 0x8C19904D MM/YY: 1/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: D16828076D686DE591AA7BCB98057070 MEID: BDD24A9FB8FFF564461BF1DCF7EFED47 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] 44 sec Analyze PMT... Ok Partition Table: PGPT [0x64] Records: 41 Probe boot... Ok 703 us SW: TECNO/KE5k-OP/TECNO-KE5k:10/QP1A.190711.020/CD-OP-220216V214:user/release-keys Product Brand: TECNO Product Device: TECNO-KE5k Product Model: TECNO KE5k Product Name: KE5k-OP Patch Level: QP1A.190711.020 Display ID: KE5k-H6122CD-Q-OP-220216V214 SW Version: CD-OP-220216V214 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-02-05 Build Time: 16-Feb-22 2:39:48 PM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: ke5k_h6122 SW: full_ke5k_h6122-user 10 QP1A.190711.020 241221 release-keys Product Board: TECNO-KE5k Board Platform: mt6765 Product Manfct: TECNO MOBILE LIMITED Device ID: tecno-mobile-limited-tecno-ke5k-ke5k-op Strategy: [tecno] Firmware ID: MT6765_TECNO_MOBILE_LIMITED_TECNO_KE5k_OSv10_KE5k-H6122CD-Q-OP-220216V214_QP1A.190711.020_ke5k_h6122 Android ver: 10 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] EMMC CID: 150100445036444142028C19904D1803 crc Ok Vendor: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 Serial: 2350485581 0x8C19904D MM/YY: 1/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Backup to C:\InfinityBox\CM2MT2\backup\MT6765__BDD24A9FB8FFF 564461BF1DCF7EFED47\ Items to check: 22 Read [26] NVRAM NVRAM: Items: 0xA3 Size: 0x101A86 State: Ok WiFi MAC: AA006E742F76 BT MAC: 58356B40A9B3 IMEI[1]: 3507 IMEI[2]: 350 Read [10] NVDATA Read [3] PROINFO Read [27] LK lk [ae975818] Read [9] NVCFG Read [12] PROTECT1 Read [1] PGPT Read [11] PERSIST Read [0] PRELOADER Done 9 files 17 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6765__BDD24A9FB8FFF 564461BF1DCF7EFED47\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__BDD24A9FB8FFF 564461BF1DCF7EFED47.7z Enough [tecno-mobile-limited-tecno-ke5k-ke5k-op] Stage: Android OS [1] ... Create partition image... Ok Ok [2] ... Create partition image... Ok Ok [4] USERDATA... Ok [5] USERDATA... Ok Stage: FRP... Reset [1 of 2] frp... Ok Verify [1 of 2] 128.00 Kb... Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 1 min 23 sec Reconnect Power/Cable now |
07-05-2024, 16:35 | #76227 (permalink) |
Insane Poster Join Date: Feb 2017 Location: Accra,Ghana
Member: 2687410 Status: Offline Thanks Meter: 1 | KJ5 DA Error Operation: Identify [ v2.63 ] Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM (Android) (COM203) MODE [0]: PRELOADER PORT; PORT: 203 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: A6B7DB4EF60F46082ACED9C8D0D7C8B0B4042BC5D4AEB0F0E9 65D3A9493D82D3 AGENT: [d0ad8d98] C:\InfinityBox\CM2MT2\boot\Infinix\2023-11\MTK_AllInOne_DA_BR.bin [f835e4ca] C:\InfinityBox\CM2MT2\boot\Infinix\2023-11\auth_sv5.auth Looking for bootchain in DA... Found: MT6768; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA version is older than required by device! Select newer DA version for this device Use Test-Point if no DA available! Finished 7 sec Reconnect Power/Cable now DA selected: Tecno | KJ5 | MTK_AllInOne_DA_BR.bin | auth_sv5.auth Preloader Mode without test-point/disassembly. More versions supported, f.e. KI5q-H6127AlAmAnAoApAq-T-GL-230901V872 try 2023-05, 2023-10, 2023-11 Operation: Bootloader unlock [ v2.63 ] Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM (Android) (COM203) MODE [0]: PRELOADER PORT; PORT: 203 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: A6B7DB4EF60F46082ACED9C8D0D7C8B0B4042BC5D4AEB0F0E9 65D3A9493D82D3 AGENT: [d0ad8d98] C:\InfinityBox\CM2MT2\boot\Infinix\2023-11\MTK_AllInOne_DA_BR.bin [f835e4ca] C:\InfinityBox\CM2MT2\boot\Infinix\2023-11\auth_sv5.auth Looking for bootchain in DA... Found: MT6768; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA version is older than required by device! Select newer DA version for this device Use Test-Point if no DA available! Finished 13 sec Reconnect Power/Cable now please help me |
07-06-2024, 08:00 | #76228 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,433 | Infinix X612B Operation: Reset Settings/Format FS [ v2.64a3 (beta) ] [+] Smart Analyzer [-] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM19) MODE [0]: PRELOADER PORT; PORT: 19 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 198EBBD5945765DC4807DB5A0D511D0F959610A878F32E9916 9EA89D822F0B25 IRG: 0x00000090 AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MediaTek USB Port_V1632 (COM10) MODE [0]: BOOTROM; PORT: 10 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: F0BF4C5AFDB1D8FB3ED2D3608DE30575 BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 198EBBD5945765DC4807DB5A0D511D0F959610A878F32E9916 9EA89D822F0B25 BROM: EMI: Search EMI: Continue EMI: Found AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100515836334142033B23E480285D crc Ok Vendor: Samsung OEM: 256 ID: 515836334142 [QX63AB] PRV: 0x03 Serial: 992208000 0x3B23E480 MM/YY: 2/2021 EMI: FireFly preloader_infinix_x612b.bin with 9 memory type(s) 1. eMMC DDR3 ID: 150100515836334142 Samsung QX63AB RAM: 2.00 Gb 2. eMMC DDR3 ID: 700100474D424D4541 Kingston GMBMEA RAM: 2.00 Gb 3. eMMC DDR3 ID: 90014A484247346132 Hynix HBG4a2 RAM: 3.00 Gb 4. eMMC DDR3 ID: 150100514536334D42 Samsung QE63MB RAM: 2.00 Gb 5. eMMC DDR3 ID: 150100514436334D42 Samsung QD63MB RAM: 2.00 Gb 6. eMMC DDR3 ID: 700100474D41474441 Kingston GMAGDA RAM: 2.00 Gb 7. eMMC DDR3 ID: 700100474D42474541 Kingston GMBGEA RAM: 2.00 Gb 8. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 9. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A600 [ 233.50 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 150100515836334142033B23E480285D crc Ok Vendor: Samsung OEM: 256 ID: 515836334142 [QX63AB] PRV: 0x03 Serial: 992208000 0x3B23E480 MM/YY: 2/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 5C9453D7F9F761AD2478241A19DD4DEB MEID: F0BF4C5AFDB1D8FB3ED2D3608DE30575 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] 12 sec Analyze PMT... Ok Partition Table: PGPT [0x64] Records: 39 Probe boot... Ok 703 us SW: Infinix/X612B-GL/Infinix-X612B:10/QP1A.190711.020/BC-GL-211111V037:user/release-keys Product Brand: Infinix Product Device: Infinix-X612B Product Model: Infinix X612B Product Name: X612B-GL Patch Level: QP1A.190711.020 Display ID: X612B-X612BBC-QGo-GL-211111V037 SW Version: BC-GL-211111V037 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2021-11-05 Build Time: 11-Nov-21 11:41:55 AM CPU: armeabi-v7a,armeabi Product Info: BC3-OP SW: X612B-GL-user 10 QP1A.190711.020 BC-GL-211111V037 release-keys Product Board: infinix_x612b Board Platform: mt6761 Product Manfct: INFINIX MOBILITY LIMITED Market Name: Infinix SMART HD Product Info: X612B-GL Device ID: infinix-mobility-limited-infinix-x612b-x612b-gl-infinix-smart-hd Strategy: [infinix] Firmware ID: MT6761_INFINIX_MOBILITY_LIMITED_Infinix_X612B_OSv1 0_X612B-X612BBC-QGo-GL-211111V037_QP1A.190711.020_X612B-GL Android ver: 10 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] EMMC CID: 150100515836334142033B23E480285D crc Ok Vendor: Samsung OEM: 256 ID: 515836334142 [QX63AB] PRV: 0x03 Serial: 992208000 0x3B23E480 MM/YY: 2/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] Backup to C:\InfinityBox\CM2MT2\backup\MT6761__F0BF4C5AFDB1D 8FB3ED2D3608DE30575\ Items to check: 22 Read [27] NVRAM NVRAM: Items: 0xB4 Size: 0x0AC5D2 State: Ok WiFi MAC: E8C2DDD7F227 BT MAC: E8C2DDD7F226 IMEI[1]: 359 IMEI[2]: 359 Read [10] NVDATA Read [18] PROINFO Read [28] LK lk [4d4d9a98] Read [9] NVCFG Read [13] PROTECT1 Read [1] PGPT Read [16] PERSIST Read [0] PRELOADER Done 9 files 16 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6761__F0BF4C5AFDB1D 8FB3ED2D3608DE30575\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6761__F0BF4C5AFDB1D 8FB3ED2D3608DE30575.7z Enough [infinix-mobility-limited-infinix-x612b-x612b-gl-infinix-smart-hd] Stage: Android OS [1] ... Create partition image... Ok Ok [2] ... Create partition image... Ok Ok [4] USERDATA... Ok [5] USERDATA... Ok Stage: FRP... Reset [1 of 2] frp... Ok Verify [1 of 2] 128.00 Kb... Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 1 min 16 sec Reconnect Power/Cable now |
07-07-2024, 01:44 | #76229 (permalink) |
Member: 890926 Status: Offline Thanks Meter: 2,065 | Realme Note 50 password Code: Operation: Connect SoC UMS9230 Boot [FF] FireFly [v2.28a5 (beta)] Wait... - Power device Off - Connect cable [remember Vol+ | Vol-] [remember Test-Point] Waiting for device... Device found PTFN: SPRD U2S Diag (COM15) vid 0x1782 pid 0x4D00 boot: SPRD3 boot iLoader... Ok start iLoader... Ok Handshake... Ok boot xLoader... Ok start FireFly... Ok Loader exec Ok Dev UID: ee4689e6c1d5fbdaac852e512ecce722a5910b4c846350f55db35dbe8007cd2a get storage info... EMMC CID: 3201014D4D43363447516C69E85FAA0D crc Ok Vendor: Unknown 0x0032 OEM: 257 ID: 4D4D43363447 [MMC64G] PRV: 0x51 Serial: 1818880095 0x6C69E85F MM/YY: 10/2023 CSD: D04F01328F5903FFFFFFFFEF8A400001 temp_write_protect: False perm_write_protect: False wp_group: 0x10 en 0x01 EXTCSD rev1.8 EMMC 5.1 FW: 03 ERASE_GROUP_DEF: 0x0400 BOOT_BUS_WIDTH: 0x00 PARTITION_CONFIG: 0x08 RST_N_FUNCTION: 0x01 PART_S_COMPLETED: False BOOT size: 0x400000 RPMB size: 0x400000 4.00 Mb WP_GRP_SIZE: 0x800000 8.00 Mb Size: Market 64 Gb Actual 0xE8F800000 58.24 Gb EOL: Status: Normal: Less than 80% reserved blocks used EOL_A: SLC status: 0% - 10% used EOL_B: MLC status: 0% - 10% used read extcsd... Ok extcsd stored: C:\InfinityBox\CM2SP3\backup\ext_csd\none_ee4689e6c1d5fbda_extcsd_0032-Unknown_0x0032_MMC64G_5.1_2024-07-06.bin get partitions... Partitions: 79 Connected get sw info... 26 sec Product Brand: realme Product Device: RE5C9F Product Model: ums9230_hulk_Natv Product Name: RMX3834 SW OTA Version: RMX3834export_13.A.39_0390_202405072006 SW: realme/RMX3834/RE5C9F:13/TP1A.220624.014/T.R4T2.1715083581:user/release-keys Patch Level: TP1A.220624.014 Display ID: RMX3834export_13_A.39 SW Version: 1919 Ver. CodeName: REL Ver. Release: 13 Sec. Patch: 2024-05-05 Build Time: 5/7/2024 12:58:33 PM Product Info: ums9230_hulk SW: ums9230_hulk_Natv-user 13 TP1A.220624.014 1919 release-keys Product Manfct: realme Board Platform: ums9230 Product Board: ums9230_hulk Android ver: 13 UserDataFS: 0x03 [f2fs] CacheFS: 0x03 [f2fs] Device ID: realme-ums9230-hulk-natv-re5c9f-rmx3834 Strategy: [oppo] Firmware ID: UMS9230_realme_ums9230_hulk_Natv_OSv13_RMX3834export_13_A.39_TP1A.220624.014_ums9230_hulk Backup 11 items to: C:\InfinityBox\CM2SP3\backup\ums9230_ee4689e6c1d5fbda\ Read to C:\InfinityBox\CM2SP3\backup\ums9230_ee4689e6c1d5fbda\ Reading... Read [1/79] prodnv 64.00 Mb Ok Read [2/79] miscdata 1024.00 Kb Ok Read [8/79] uboot_a 3.00 Mb Ok Read [9/79] uboot_b 3.00 Mb Ok Read [13/79] l_fixnv1_a 2.00 Mb Ok Read [14/79] l_fixnv2_a 2.00 Mb Ok Read [15/79] l_fixnv1_b 2.00 Mb Ok Read [16/79] l_fixnv2_b 2.00 Mb Ok Read [53/79] ocdt_a 8.00 Mb Ok Read [54/79] ocdt_b 8.00 Mb Ok Read [73/79] calinv 2.00 Mb Ok Saved 11 of 11 images, 97.00 Mb of 97.00 Mb Done 11 files Compress: C:\InfinityBox\CM2SP3\backup\ums9230_ee4689e6c1d5fbda\ Cleanup... Ok Verify C:\InfinityBox\CM2SP3\backup\ums9230_ee4689e6c1d5fbda.7z Finished Read Device-ID... IMEI[0]: 867400020316612 IMEI[1]: 867400020316620 IMEI[2]: 867400020316638 IMEI[3]: 867400020316646 BT MAC: 98:ac:ef:37:21:9e WiFi MAC: 98:ac:ef:37:21:9f PSN1: 90PS0N14130I22111DCF PSN2: 00111110 PSN3: N/A get slots... slot: a MemTool load 79 items Finished 2 min 34 sec Operation: Reset | Format SoC UMS9230 Boot [FF] FireFly [v2.28a5 (beta)] WARNING: Reset may delete ALL USER DATA! Continue? Yes [+] Wipe [+] Userdata [+] FRP [+] Smart Wait... Backup exist: C:\InfinityBox\CM2SP3\backup\ums9230_ee4689e6c1d5fbda\ Process Wipe... Reading... Ok Writing... Ok Process FRP... Looking for items... 1 items found [1] Writing... Ok Process Userdata... [1] Format... Ok 47 sec [2] Format... Ok 23 sec [3] Format... Ok 24 sec Completed Process nvram... [17] Format... Ok [18] Format... Ok Completed Finished 1 min 44 sec Operation: Reset | Format SoC UMS9230 Boot [FF] FireFly [v2.28a5 (beta)] WARNING: Reset may delete ALL USER DATA! Continue? Yes [-] Wipe [-] Userdata [-] FRP [+] Smart Wait... Backup exist: C:\InfinityBox\CM2SP3\backup\ums9230_ee4689e6c1d5fbda\ Process nvram... [17] Format... Ok [18] Format... Ok Completed Finished 4 sec |
07-08-2024, 16:12 | #76230 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,454 | Realme c33 frp Code: Chinese Miracle II - SP3 Service Tool v2.28a5 (beta) Init log engine... Ok Build directories tree... Backup files: C:\InfinityBox\CM2SP3\backup\ Backup files: 0 dirs: 0 Build device list... Ok 1328 Ready Selected: Realme C11-2021 Boot [FF] FireFly mmc [FF] protocol may be SLOW. For flash Read/Write use [FDL] Selected: Realme C33-2023 Boot [FDL] ufs Operation: Connect Realme C33-2023 Boot [FDL] [v2.28a5 (beta)] Wait... - Power device Off - Connect cable [remember Vol+ | Vol-] [remember Test-Point] Waiting for device... Device found PTFN: SPRD U2S Diag (COM9) vid 0x1782 pid 0x4D00 Handshake fail Wrong connection mode? Canceled Finished 15 sec Operation: Connect Realme C33-2023 Boot [FDL] [v2.28a5 (beta)] Wait... - Power device Off - Connect cable [remember Vol+ | Vol-] [remember Test-Point] Waiting for device... Device found PTFN: SPRD U2S Diag (COM9) vid 0x1782 pid 0x4D00 boot: SPRD3 C:\InfinityBox\CM2SP3\boot\Realme\C33-2023\fdl1-sign.beeba65b.ldr C:\InfinityBox\CM2SP3\boot\Realme\C33-2023\fdl2-sign.beeba65b.80755141.ldr Boot[1] Custom... Ok Exec[1]... Ok Boot ack: Spreadtrum Boot Block version 1.1 Loader ACK... Ok Set port speed... 2000000 Enable charge... Ok Boot[2]... Ok Exec[2]... Ok Version: 0x10 Random: 0x00 Enable RAW... Ok Loader exec Ok Dev UID: unknown get partitions... Partitions: 79 Load UBID... Ok Dev UID: b6e01a0d4b8d2acbd1e633adde3078566dd85830fa685c34fd30b0c5cefadeb7 Connected get sw info... 5 sec Product Brand: realme Product Model: RMX3624 Product Name: RMX3624 Product Device: REE2B4 SW OTA Version: RMX3624_12.A.35_0350_20231212161322 Display ID: RMX3624_12.A.35 SW Version: S.202312121631 SW: realme/RMX3624/REE2B4:12/SP1A.210812.016/S.202312121631:user/release-keys Patch Level: SP1A.210812.016 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-11-05 Build Time: 12/12/2023 8:30:55 AM Product Info: RMX3624 SW: RMX3624_Natv-user 12 SP1A.210812.016 50240 release-keys Product Manfct: realme Product Board: RMX3624 Board Platform: ums9230 Android ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Device ID: realme-rmx3624-ree2b4 Strategy: [oppo] Firmware ID: UMS9230_realme_RMX3624_OSv12_RMX3624_12.A.35_SP1A.210812.016_RMX3624 Backup 10 items to: C:\InfinityBox\CM2SP3\backup\ums9230_b6e01a0d4b8d2acb\ Read to C:\InfinityBox\CM2SP3\backup\ums9230_b6e01a0d4b8d2acb\ Reading... Read [1/79] prodnv 10.00 Mb Ok Read [2/79] miscdata 1024.00 Kb Ok Read [8/79] uboot_a 3.00 Mb Ok Read [9/79] uboot_b 3.00 Mb Ok Read [13/79] l_fixnv1_a 2.00 Mb Ok Read [14/79] l_fixnv2_a 2.00 Mb Ok Read [15/79] l_fixnv1_b 2.00 Mb Ok Read [16/79] l_fixnv2_b 2.00 Mb Ok Read [54/79] ocdt_a 1024.00 Kb Ok Read [55/79] ocdt_b 1024.00 Kb Ok Saved 10 of 10 images, 27.00 Mb of 27.00 Mb Done 10 files Compress: C:\InfinityBox\CM2SP3\backup\ums9230_b6e01a0d4b8d2acb\ Cleanup... Ok Verify C:\InfinityBox\CM2SP3\backup\ums9230_b6e01a0d4b8d2acb.7z Verified [a7b190b2] Read Device-ID... IMEI[0]: 86740002 IMEI[1]: 86740002 IMEI[2]: 86740002 IMEI[3]: 867400020 BT MAC: e4:6a:35:1a:d8:7a WiFi MAC: e4:6a:35:1a:d8:7b PSN1: 51PS102270903505293110FA08KG PSN2: N/A PSN3: N/A get slots... slot: b MemTool load 79 items Finished 45 sec Operation: Reset | Format Realme C33-2023 Boot [FDL] [v2.28a5 (beta)] WARNING: Reset may delete ALL USER DATA! Continue? Yes [-] Wipe [-] Userdata [+] FRP [+] Smart Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... Backup exist: C:\InfinityBox\CM2SP3\backup\ums9230_b6e01a0d4b8d2acb\ Process FRP... Looking for items... 1 items found [1] Writing... Ok Process nvram... [17] Format... Ok [18] Format... Ok Completed Finished 11 sec Reboot... Disconnect cable if it freez Bye |
