08-12-2024, 14:13 | #76261 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,433 | Realme RMX2189 Frp Reset Done [+] Smart Analyzer [-] Wipe [-] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make [Userdata] On and repeat operation Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM27) MODE [0]: PRELOADER PORT; PORT: 27 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 78E8005833B7D91FD48192E67CAFAFA22E292F33631ECCE074 74ABF2AC559D17 AGENT: [ab6a11d9] C:\InfinityBox\CM2MT2\boot\Oppo\2022-10\MTK_AllInOne_DA.5419c171.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00038000 [ 224.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 90014A68423861503E035A46E5121749 crc Ok Vendor: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 Serial: 1514595602 0x5A46E512 MM/YY: 1/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 181D3A9DACBBEB171C6B2B1A8EEDC2E0 USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 25 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 47 Probe boot... Ok 1 sec Product Board: oppo6765 Board Platform: mt6765 Product Brand: alps Product Device: oppo6765 Product Manfct: alps Product Model: oppo6765 Product Name: vnd_oppo6765 Device ID: vnd-oppo6765-oppo6765-MT6765_RMX2189_11_A.67_200729_77a43fe3 Strategy: [oppo] Firmware ID: MT6765_alps_oppo6765.MT6765_RMX2189_11_A.67_200729 _77a43fe3 Android ver: 9 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 90014A68423861503E035A46E5121749 crc Ok Vendor: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 Serial: 1514595602 0x5A46E512 MM/YY: 1/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] Backup to C:\InfinityBox\CM2MT2\backup\MT6765__46B17E74D2843 378A53A187A8408ECE6\ Items to check: 22 Read [31] NVRAM NVRAM: Items: 0xAB Size: 0x08F8BF State: Ok WiFi MAC: C816DA6865ED BT MAC: C816DA6865EC Read [14] NVDATA Read [22] PROINFO Read [36] LK lk [12b4af88] Read [13] NVCFG Read [17] PROTECT1 Read [1] PGPT Read [20] PERSIST Read [0] PRELOADER Read [35] OCDT Zero content file deleted: C:\InfinityBox\CM2MT2\backup\MT6765__46B17E74D2843 378A53A187A8408ECE6\ocdt.bin Read [5] OPPORESERVE1 Read [7] OPPORESERVE3 Read [8] OPPO_CUSTOM Read [32] CDT_ENGINEERING Done 13 files 8 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6765__46B17E74D2843 378A53A187A8408ECE6\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__46B17E74D2843 378A53A187A8408ECE6.7z Enough [vnd-oppo6765-oppo6765-mt6765-rmx2189-11-a.67-200729-77a43fe3] Stage: Android OS Off Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 1 min 1 sec Reconnect Power/Cable now |
08-12-2024, 19:40 | #76262 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,778 | Vgotel i515 lcd fix done by cm2 Card found : S/N : 73CA70CC , v0161 Chinese Miracle II [MTK module] v 1.58 Load File File_Info : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F45.bin FileVersion : MAUI.11C.W13.52.MP.V2.F45 Load File Ok Operation : Flash [ v1.58 ] ======= Flash Files set for flashing : [ MCU ] : FISE61D_11C_PCB01_GPRS_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F45.BIN.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 54FFE30F4AB02070696AAAE82F72DC15 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F45.bin FileVersion : MAUI.11C.W13.52.MP.V2.F45 Flash now Erase region , wait ... Write data , wait ... Write : FISE61D_11C_PCB01_GPRS_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F45.BIN.bin Done! Elapsed: 00:00:45 Reconnect Power/Cable! |
08-12-2024, 19:48 | #76263 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | CLUB MOBILE M50 RESET PASSWORD DONE BY CM2 Card found : S/N : 73CA70CC , v0161 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : A394794FBC0299C5B987F0414CAABCA9 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : M05_S122_PCB01_gprs_MT6261_S00.6261D_M05_M50_CLUB_ V02_20190103.bin FileVersion : 6261D_M05_M50_CLUB_V02_20190103 Done! Elapsed: 00:00:06 Reconnect Power/Cable! Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : A394794FBC0299C5B987F0414CAABCA9 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
08-13-2024, 18:22 | #76264 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | INTEX HANG ON LOGO DONE BY CM2 Card found : 73CA70CC , v0161 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Reset Settings [ v1.07 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00000000 BOOT_INIT : 0x00000000 BOOT_MODE : DOWNLOAD Setting BOOTROM mode BOOT_MODE : BOOTROM Boot_CPU : 0x88094006 : [RDA] : RDA8851B MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x161640C8 : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A2E0 Boot done! Preparing PMT Verifying PMT Erasing 983040 bytes FileSystem format done! Done! Elapsed: 00:00:52 Reconnect Power/Cable! |
08-13-2024, 18:30 | #76265 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | ITEL P40 4G RESET FRP DONE BY CM2 Card found : 73CA70CC , v0161 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : iTel : itel-s663l.460f890f.04b4b7c0 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:17 |
08-13-2024, 19:52 | #76266 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | TECNO-BF7 Frp Code: Operation: Identify Device [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ] [+] High-Speed [+] Auto-EMI [+] FireFly-Over-DA extended protocol [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM12) MODE [0]: PRELOADER PORT; PORT: 12 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 1CDD22D47DB5BD00A6EFDC622869C24B11FC5DA5451114B8FED634386D583089 IRG: 0x00000080 AGENT: AUTO: Infinix: 2023-11 [d0ad8d98] C:\InfinityBox\CM2MT2\boot\Infinix\2023-11\MTK_AllInOne_DA_BR.bin [f835e4ca] C:\InfinityBox\CM2MT2\boot\Infinix\2023-11\auth_sv5.auth Looking for suitable BootChain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A600 [ 233.50 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: D62D004D4D433634475105716569C969 crc Ok Ven: Foresee OEM: 11520 ID: 4D4D43363447 [MMC64G] PRV: 0x51 SNN: 91317609 [0x05716569] MM/YY: 12/2022 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE90280000 [ 58.25 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 20FC5F23311223D8209ED06E2E32B364 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 50 Get slot info... a Select info source... boot_a [2000000] Ok Product Brand: TECNO Product Device: TECNO-BF7 Product Model: TECNO BF7 Product Name: BF7-GL SW: TECNO/BF7-GL/TECNO-BF7:12/SP1A.210812.016/230822V1327:user/release-keys Patch Level: SP1A.210812.016 Display ID: BF7-H6127ABCDSTUAdAeAfArAs-S-GL-230822V1327 SW Version: 230822V1327 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-07-05 Build Time: 21/08/2023 8:50:51 pm Product Info: bf7_h6127 SW: vnd_bf7_h6127-user 12 SP1A.210812.016 409861 release-keys Product Manfct: TECNO Product Board: TECNO-BF7 Board Platform: mt6761 Strategy: [none|generic] Firmware ID: MT6761_TECNO_TECNO_BF7_OSv12_BF7-H6127ABCDSTUAdAeAfArAs-S-GL-230822V1327_SP1A.210812.016_bf7_h6127 Verify firmware [MT6761_TECNO_TECNO_BF7_OSv12_BF7-H6127ABCDSTUAdAeAfArAs-S-GL-230822V1327_SP1A.210812.016_bf7_h6127]... Exist (1) Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0xA4 Size: 0x08F472 State: Ok WiFi MAC: 503CCA63D6E1 BlTh MAC: 503CCA63D6E0 IMEI[1]: IMEI[2]: Verify config values... Ok Loaders Ok STORAGE Life Status: eMMC : OK STORAGE OTP Status: UNLOCKED STORAGE RPMB Status: eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Reset port... Done: 00:00:33 Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [-] Userdata [+] FRP [-] Smart WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM12) MODE [0]: PRELOADER PORT; PORT: 12 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 1CDD22D47DB5BD00A6EFDC622869C24B11FC5DA5451114B8FED634386D583089 IRG: 0x00000080 AGENT: AUTO: Infinix: 2023-11 [d0ad8d98] C:\InfinityBox\CM2MT2\boot\Infinix\2023-11\MTK_AllInOne_DA_BR.bin [f835e4ca] C:\InfinityBox\CM2MT2\boot\Infinix\2023-11\auth_sv5.auth Looking for suitable BootChain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A600 [ 233.50 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: D62D004D4D433634475105716569C969 crc Ok Ven: Foresee OEM: 11520 ID: 4D4D43363447 [MMC64G] PRV: 0x51 SNN: 91317609 [0x05716569] MM/YY: 12/2022 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE90280000 [ 58.25 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 20FC5F23311223D8209ED06E2E32B364 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 50 Strategy: [none|generic] Verify config values... Ok Loaders Ok Stage: Android OS Off Stage: FRP... [1] PROTECTION... Done Reset port... Trying to reboot... Done: 00:00:25 Reconnect Power/Cable now |
08-15-2024, 13:51 | #76267 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,433 | Dura-l21 Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [-] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM11) MODE [0]: PRELOADER PORT; PORT: 11 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000003 Mode: SBC+SLA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: A80E4C54267467B22647A0B8F99643547436C223F7A863D0FE 759F0FEB0EE7CE AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6739; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MediaTek USB Port_V1632 (COM14) MODE [0]: BOOTROM; PORT: 14 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] MEID: 4F08B49BE97EC4D339EACFD47A3D20FE BROM: Sec Level: 0x000000E3 Mode: SBC+SLA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: A80E4C54267467B22647A0B8F99643547436C223F7A863D0FE 759F0FEB0EE7CE SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 4F08B49BE97EC4D339EACFD47A3D20FE AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6739; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMI: FireFly preloader_dura64.bin with 12 memory type(s) 1. eMMC DDR3 ID: 150100464536324D42 Samsung FE62MB RAM: 1.00 Gb 2. eMMC DDR3 ID: 700100454841434438 Kingston EHACD8 RAM: 1.00 Gb 3. eMMC DDR3 ID: 450100444634303136 Sandisk DF4016 RAM: 2.00 Gb 4. eMMC DDR3 ID: 150100514536334D42 Samsung QE63MB RAM: 2.00 Gb 5. eMMC DDR3 ID: 13014E53304A394836 Micron S0J9H6 RAM: 1.00 Gb 6. eMMC DDR3 ID: 90014A484147346132 Hynix HAG4a2 RAM: 2.00 Gb 7. eMMC DDR3 ID: 90014A484247346132 Hynix HBG4a2 RAM: 2.00 Gb 8. eMMC DDR3 ID: 150100514436334D42 Samsung QD63MB RAM: 2.00 Gb 9. eMMC DDR3 ID: 150100515831334D42 Samsung QX13MB RAM: 2.00 Gb 10. eMMC DDR3 ID: 13014E53304A394137 Micron S0J9A7 RAM: 2.00 Gb 11. eMMC DDR3 ID: 150100515836334142 Samsung QX63AB RAM: 2.00 Gb 12. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 2.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 150100514536334D420431C1AACBB571 crc Ok Vendor: Samsung OEM: 256 ID: 514536334D42 [QE63MB] PRV: 0x04 Serial: 834775755 0x31C1AACB MM/YY: 11/2018 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x3A3E00000 [ 14.56 Gb ] CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] RNID: C3EBF2790B36A4D7A47ABFAE8C70F9D2 MEID: 4F08B49BE97EC4D339EACFD47A3D20FE USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 1 min 22 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 45 Probe boot... Ok 1 sec HWModel : DURA-L21 HWMline : DRA-L21 HWBuild : DRA-L21 1.0.0.166(C432) HWOSver : 8.1.0 HWRegion: hw/eu Patch Level: O11019 Display ID: DUA-AL00-BD 1.0.0.37 SW Version: 1563826031 Ver. CodeName: REL Ver. Release: 8.1.0 Sec. Patch: 2018-01-05 Build Time: 22-Jul-19 8:07:09 PM Product Model: DUA-AL00 Product Brand: HONOR Product Name: DUA-AL00 Product Device: HWDUA-M CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: HUAWEI Product Info: dura64 SW: full_dura64-user 8.1.0 O11019 1563826031 release-keys Product Board: DUA-AL00 Board Platform: mt6739 Device ID: honor-huawei-dua-al00-hwdua-m-full-dura64-DURA-L21_8.1.0_DRA-L21_1.0.0.166(C432)_DRA-L21_hweu Strategy: [huawei] Firmware ID: MT6739_HUAWEI_DUA-AL00_OSv8.1.0_DUA-AL00-BD_1.0.0.37_O11019_dura64_HONOR.DURA-L21_8.1.0_DRA-L21_1.0.0.166_C432_DRA-L21_hweu Android ver: 8 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] EMMC CID: 150100514536334D420431C1AACBB571 crc Ok Vendor: Samsung OEM: 256 ID: 514536334D42 [QE63MB] PRV: 0x04 Serial: 834775755 0x31C1AACB MM/YY: 11/2018 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x3A3E00000 [ 14.56 Gb ] Backup to C:\InfinityBox\CM2MT2\backup\MT6739__4F08B49BE97EC 4D339EACFD47A3D20FE\ Items to check: 22 Read [21] NVRAM NVRAM: Items: 0xB3 Size: 0x0ABE18 State: Ok WiFi MAC: 881196788E2E BT MAC: 8811967C5EBE IMEI[1]: 86 IMEI[2]: 86 Read [7] NVDATA Read [14] PROINFO Read [26] LK lk [f2bdf3e1] Read [6] NVCFG Read [10] PROTECT1 Read [1] PGPT Read [0] PRELOADER Read [24] OEMINFO Done 9 files 6 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6739__4F08B49BE97EC 4D339EACFD47A3D20FE\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6739__4F08B49BE97EC 4D339EACFD47A3D20FE.7z Enough [honor-huawei-dua-al00-hwdua-m-full-dura64-dura-l21-8.1.0-dra-l21-1.0.0.166c432-dra-l21-hweu] Stage: Android OS [1] ... Create partition image... Ok Ok [2] ... Create partition image... Ok Ok [4] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Ok Reset port... Trying to reboot... Finished 1 min 53 sec Reconnect Power/Cable now |
08-15-2024, 14:35 | #76268 (permalink) |
Junior Member Join Date: Apr 2010
Member: 1290755 Status: Offline Thanks Meter: 1 | TECNO POVA 5 PRO {LH8N} FRP Operation: Reset Settings/Format FS [ v2.64a9 (beta) ] [+] Smart Analyzer [-] Wipe [-] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make [Userdata] On and repeat operation Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM (Android) (COM20) MODE [0]: PRELOADER PORT; PORT: 20 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6833 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0989 CODE: Palmer TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: E36E4A1DA9BDE9713860EB29D5498EC08D123AFEBF9AFB22E4 C467D964F372FF Agent: [d0ad8d98] C:\InfinityBox\CM2MT2\boot\Infinix\2023-11\MTK_AllInOne_DA_BR.d937c2ef.bin [f835e4ca] C:\InfinityBox\CM2MT2\boot\Infinix\2023-11\auth_sv5.auth Looking for bootchain in DA... Found: MT6833; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA started DA SYNC Ok MODE: PRELOADER EXT_RAM initialized Boot to 2nd DA... 2nd stage confirmed DA SYNC Ok Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] UFS CID: CE014B4D384C393030314A4D2D423632 Ven: 0x01CE VID: KM8L9001JM-B62 IFW: 0700 LU0: 0x00400000 [ 4.00 Mb ] LU1: 0x00400000 [ 4.00 Mb ] LU2: 0x1DCB000000 [ 119.17 Gb ] FSN: 77d4b2d44938 REG: 0x101010000 CHIP: MT6833 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0989 CODE: Palmer TYPE: MODERN [RAPHAEL] RNID: 07FB5336C88DA0EEDD175B2B22E6170F USB: HIGH-SPEED Boot done MODERN [RAPHAEL] 19 sec Analyze PMT... Ok Partition Table: PGPT [0x64] Records: 58 Get slot info... a Probe boot... Ok 1 sec Product Brand: TECNO Product Device: TECNO-LH8n Product Model: TECNO LH8n Product Name: LH8n-GL SW: TECNO/LH8n-GL/TECNO-LH8n:12/SP1A.210812.016/230726V943:user/release-keys Patch Level: SP1A.210812.016 Display ID: LH8N-H333M-S-230726V943 SW Version: 230726V943 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-06-05 Build Time: 25-07-2023 21:34:59 Product Info: lh8n_h333 SW: vnd_lh8n_h333-user 12 SP1A.210812.016 387870 release-keys Product Manfct: TECNO Product Board: TECNO-LH8n Board Platform: mt6833 Device ID: tecno-lh8n-lh8n-gl Strategy: [tecno] Firmware ID: MT6833_TECNO_TECNO_LH8n_OSv12_LH8N-H333M-S-230726V943_SP1A.210812.016_lh8n_h333 Android ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] UFS CID: CE014B4D384C393030314A4D2D423632 Ven: 0x01CE VID: KM8L9001JM-B62 IFW: 0700 LU0: 0x00400000 [ 4.00 Mb ] LU1: 0x00400000 [ 4.00 Mb ] LU2: 0x1DCB000000 [ 119.17 Gb ] FSN: 77d4b2d44938 REG: 0x101010000 Backup exist: C:\InfinityBox\CM2MT2\backup\MT6833__B617146043473 8555B27BC8C4973D052 Stage: Android OS Off Stage: FRP... [1] frp... Ok [1] verify 128.00 Kb... Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 41 sec Reconnect Power/Cable now Last edited by superst; 08-15-2024 at 14:38. Reason: HEADLINE MISSING |
08-16-2024, 06:34 | #76269 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | CALME CL66 RESET PASSWORD DONE BY CM2 Card found : 73CA70CC , v0161 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Format FFS Done! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
08-16-2024, 12:11 | #76270 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,433 | Cph2179 Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [-] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1632 (COM6) MODE [0]: BOOTROM; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: EB44E9F56C293EA658B48EF0C8623195 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 5B637FF7C01F0909140B40E0E0AB8D339522E35B5D900F7725 EEC0423065C727 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: EB44E9F56C293EA658B48EF0C8623195 AGENT: [ab6a11d9] C:\InfinityBox\CM2MT2\boot\Oppo\2022-10\MTK_AllInOne_DA.5419c171.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 13014E47314A395238101126C46738B3 crc Ok Vendor: Micron OEM: 334 ID: 47314A395238 [G1J9R8] PRV: 0x10 Serial: 287753319 0x1126C467 MM/YY: 3/2021 EMI: FireFly preloader_oppo6765.bin with 12 memory type(s) 1. eMMC LP_DDR4X ID: 1501003458364B4D42 Samsung 4X6KMB RAM: 2.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 2.00 Gb 4. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 6. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 10. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 12. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00038000 [ 224.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 13014E47314A395238101126C46738B3 crc Ok Vendor: Micron OEM: 334 ID: 47314A395238 [G1J9R8] PRV: 0x10 Serial: 287753319 0x1126C467 MM/YY: 3/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 9DB08A1E3275C7CA3AE5A35C27145295 MEID: EB44E9F56C293EA658B48EF0C8623195 USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 1 min 51 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 47 Probe boot... Ok 2 sec Patch Level: QP1A.190711.020 Display ID: QP1A.190711.020 release-keys Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2023-02-05 Build Time: 09-Sep-23 11:26:43 AM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: oppo6765 SW: full_oppo6765-user 10 QP1A.190711.020 bedd37e98646d3a1 release-keys Device ID: oppo-MT6765_CPH2179PU_11_A.21_210214_c79501ea Strategy: [oppo] Firmware ID: MT6765_OSv10_QP1A.190711.020_oppo6765.MT6765_CPH21 79PU_11_A.21_210214_c79501ea Android ver: 10 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 13014E47314A395238101126C46738B3 crc Ok Vendor: Micron OEM: 334 ID: 47314A395238 [G1J9R8] PRV: 0x10 Serial: 287753319 0x1126C467 MM/YY: 3/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Backup to C:\InfinityBox\CM2MT2\backup\MT6765__EB44E9F56C293 EA658B48EF0C8623195\ Items to check: 22 Read [31] NVRAM NVRAM: Items: 0xAA Size: 0x08C87A State: Ok WiFi MAC: 408C1FE7B041 BT MAC: 408C1FE7B040 Read [14] NVDATA Read [22] PROINFO Read [36] LK lk [e9111129] Read [13] NVCFG Read [17] PROTECT1 Read [1] PGPT Read [20] PERSIST Read [0] PRELOADER Read [33] OCDT Read [5] OPPORESERVE1 Read [7] OPPORESERVE3 Read [8] OPPO_CUSTOM Read [32] CDT_ENGINEERING Done 14 files 21 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6765__EB44E9F56C293 EA658B48EF0C8623195\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__EB44E9F56C293 EA658B48EF0C8623195.7z Enough [oppo-mt6765-cph2179pu-11-a.21-210214-c79501ea] Stage: Android OS [1] ... Create partition image... Ok Ok [2] ... Create partition image... Ok Ok [4] USERDATA... Ok [5] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 2 min 45 sec Reconnect Power/Cable now |
08-16-2024, 14:07 | #76271 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | S/N: 0073CA70CC v0161 Chinese Miracle II - MT2 Service Tool v2.63 Init log engine... Ok Build directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 10 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Check for updates [CM2MT2]... Installed v2.63 Infinity #CM2MT2 v2.64 - Boot process revised - New DA and new models supported - [RawTool] rebuilded - [Reset] process revised - META/SVC mode rebuilded - Flash chip EOL fault method detection revised - [AppTool] search feature - Privacy Lock Reset process revised - Software messages and hints updated Required firmware v0162 Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Sales: https://infinity-box.com/buy/ Account: https://infinity-box.com/service/ Update configuration... Configuration [12412] updated Get list of devices... Ok Reloaded 1998 devices Build device list... Load IDBase v915508 Ok Load 149 profiles... Ok libusb: v1.2.6.0 Init environment... Ok Ready Operation: Identify [ v2.63 ] Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM6) MODE [0]: BOOTROM; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: CC99C14978880C85AE8A2A6B029A0A2E BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 0CFB721617001BEFB25BA818FAE9939A3F43CC9BC1538CB4E8 061B38FB53F0CE SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: CC99C14978880C85AE8A2A6B029A0A2E AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100445836384D420904B3CE5A3891 crc Ok Vendor: Samsung OEM: 256 ID: 445836384D42 [DX68MB] PRV: 0x09 Serial: 78892634 0x04B3CE5A MM/YY: 3/2021 EMI: FireFly preloader_x688b_h659.bin with 20 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 6.00 Gb 10. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 150100445036384D42 Samsung DP68MB RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 17. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 18. eMMC LP_DDR4X ID: 150100445036444242 Samsung DP6DBB RAM: 4.00 Gb 19. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 20. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 150100445836384D420904B3CE5A3891 crc Ok Vendor: Samsung OEM: 256 ID: 445836384D42 [DX68MB] PRV: 0x09 Serial: 78892634 0x04B3CE5A MM/YY: 3/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 2296EE9D87B94D2F085A605B164E7712 MEID: CC99C14978880C85AE8A2A6B029A0A2E USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 11 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 41 STORAGE Life Status: eMMC : OK STORAGE OTP Status: UNLOCKED STORAGE RPMB Status: eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Saved: C:\InfinityBox\CM2MT2\phdata\key.json Probe boot... Ok 640 us SW: Infinix/X688B-GL/Infinix-X688B:11/RP1A.200720.011/221213V614:user/release-keys Product Brand: Infinix Product Device: Infinix-X688B Product Model: Infinix X688B Product Name: X688B-GL Patch Level: RP1A.200720.011 Display ID: X688B-H659ABCDEFGHIJKLMNO-R-GL-221213V614 SW Version: 221213V614 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2022-12-05 Build Time: 12/13/2022 2:16:59 PM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: x688b_h659 SW: vnd_x688b_h659-user 11 RP1A.200720.011 189425 release-keys Product Board: Infinix-X688B Board Platform: mt6765 Product Manfct: INFINIX MOBILITY LIMITED Device ID: infinix-mobility-limited-infinix-x688b-x688b-gl Strategy: [infinix] Firmware ID: MT6765_INFINIX_MOBILITY_LIMITED_Infinix_X688B_OSv1 1_X688B-H659ABCDEFGHIJKLMNO-R-GL-221213V614_RP1A.200720.011_x688b_h659 Verify firmware [MT6765_INFINIX_MOBILITY_LIMITED_Infinix_X688B_OSv1 1_X688B-H659ABCDEFGHIJKLMNO-R-GL-221213V614_RP1A.200720.011_x688b_h659]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Backup to C:\InfinityBox\CM2MT2\backup\MT6765__CC99C14978880 C85AE8A2A6B029A0A2E\ Items to check: 22 Read [26] NVRAM NVRAM: Items: 0xA2 Size: 0x08C02F State: Ok WiFi MAC: 5810B7B97601 BT MAC: 5810B7B97600 IMEI[1]: IMEI[2]: Read [10] NVDATA Read [3] PROINFO Read [27] LK lk [5358c7a6] Read [9] NVCFG Read [12] PROTECT1 Read [1] PGPT Read [11] PERSIST Read [0] PRELOADER Done 9 files 10 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6765__CC99C14978880 C85AE8A2A6B029A0A2E\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__CC99C14978880 C85AE8A2A6B029A0A2E.7z Enough [infinix-mobility-limited-infinix-x688b-x688b-gl] Analyze modem... TK_MD_BASIC_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R3_M P_V149_4_P60 Analyze nvram... PSN1: 0688725168012271 EMMC CID: 150100445836384D420904B3CE5A3891 crc Ok Vendor: Samsung OEM: 256 ID: 445836384D42 [DX68MB] PRV: 0x09 Serial: 78892634 0x04B3CE5A MM/YY: 3/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] Analyze preloader... EMI: MT6765 preloader_x688b_h659.bin with 20 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 6.00 Gb 10. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 150100445036384D42 Samsung DP68MB RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 17. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 18. eMMC LP_DDR4X ID: 150100445036444242 Samsung DP6DBB RAM: 4.00 Gb 19. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 20. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_x 688b_h659.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_x 688b_h659.bin [2632a5f8]... Exist Probe FRP... Most probably Off Reset port... Finished 51 sec Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [+] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM6) MODE [0]: BOOTROM; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: CC99C14978880C85AE8A2A6B029A0A2E BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 0CFB721617001BEFB25BA818FAE9939A3F43CC9BC1538CB4E8 061B38FB53F0CE SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok EMI known SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: CC99C14978880C85AE8A2A6B029A0A2E AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100445836384D420904B3CE5A3891 crc Ok Vendor: Samsung OEM: 256 ID: 445836384D42 [DX68MB] PRV: 0x09 Serial: 78892634 0x04B3CE5A MM/YY: 3/2021 EMI: FireFly preloader_x688b_h659.bin with 20 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 6.00 Gb 10. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 150100445036384D42 Samsung DP68MB RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 17. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 18. eMMC LP_DDR4X ID: 150100445036444242 Samsung DP6DBB RAM: 4.00 Gb 19. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 20. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 150100445836384D420904B3CE5A3891 crc Ok Vendor: Samsung OEM: 256 ID: 445836384D42 [DX68MB] PRV: 0x09 Serial: 78892634 0x04B3CE5A MM/YY: 3/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 2296EE9D87B94D2F085A605B164E7712 MEID: CC99C14978880C85AE8A2A6B029A0A2E USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 10 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 41 Probe boot... Ok 672 us SW: Infinix/X688B-GL/Infinix-X688B:11/RP1A.200720.011/221213V614:user/release-keys Product Brand: Infinix Product Device: Infinix-X688B Product Model: Infinix X688B Product Name: X688B-GL Patch Level: RP1A.200720.011 Display ID: X688B-H659ABCDEFGHIJKLMNO-R-GL-221213V614 SW Version: 221213V614 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2022-12-05 Build Time: 12/13/2022 2:16:59 PM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: x688b_h659 SW: vnd_x688b_h659-user 11 RP1A.200720.011 189425 release-keys Product Board: Infinix-X688B Board Platform: mt6765 Product Manfct: INFINIX MOBILITY LIMITED Device ID: infinix-mobility-limited-infinix-x688b-x688b-gl Strategy: [infinix] Firmware ID: MT6765_INFINIX_MOBILITY_LIMITED_Infinix_X688B_OSv1 1_X688B-H659ABCDEFGHIJKLMNO-R-GL-221213V614_RP1A.200720.011_x688b_h659 Android ver: 11 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] EMMC CID: 150100445836384D420904B3CE5A3891 crc Ok Vendor: Samsung OEM: 256 ID: 445836384D42 [DX68MB] PRV: 0x09 Serial: 78892634 0x04B3CE5A MM/YY: 3/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__CC99C14978880 C85AE8A2A6B029A0A2E Stage: Android OS [2] WIPE... Ok [3] WIPE... Create partition image... Ok Ok [4] WIPE... Create partition image... Ok Ok [6] USERDATA... Ok [7] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 25 sec Reconnect Power/Cable now |
08-16-2024, 19:00 | #76272 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | Realme Narzo 50A Prime RMX3516 Reset FRP Done By CM2 Card found : 73CA70CC , v0161 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Realme : RMX3581 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:17 |
08-18-2024, 16:19 | #76273 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | Moto C Plus Frp Code: Patch Level: NRD90M.01.041 Display ID: NRD90M.01 041 SW Version: 041 Ver. CodeName: REL Ver. Release: 7.0 Sec. Patch: 2018-09-05 Build Time: 01/04/2019 3:29:55 am Product Model: Moto C Plus Product Brand: motorola Product Name: panell_23_d Product Device: panell_d Product Board: MT6737 CPU: armeabi-v7a,armeabi Product Manfct: motorola Board Platform: mt6737m SW: panell_23_d-user 7.0 NRD90M.01.041 release-keys Strategy: [none|generic] Firmware ID: MT6737M_motorola_Moto_C_Plus_OSv7.0_NRD90M.01_041_NRD90M.01.041 Verify firmware [MT6737M_motorola_Moto_C_Plus_OSv7.0_NRD90M.01_041_NRD90M.01.041]... Exist (1) Analyze userdata... userData: fileSystem [ext4] with FDE [encryptable] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0x153 Size: 0x069066 State: Ok WiFi MAC: A89675FADAA9 BlTh MAC: A89675F6E7A5 Verify config values... Ok Loaders Ok Reset port... Done: 00:00:25 Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [-] Userdata [+] FRP [-] Smart WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM12) MODE [0]: PRELOADER PORT; PORT: 12 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6735 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0335 TYPE: LEGACY [MTK] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x01 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v1712 [e600c7d1] C:\InfinityBox\CM2MT2\boot\0_base\base_v1712\MTK_AllInOne_DA.e600c7d1.bin Looking for suitable BootChain in DA... Found: MT6735; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MTK USB Port (COM28) MODE [0]: BOOTROM; PORT: 28 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6735 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0335 TYPE: LEGACY [MTK] MEID: 004ACDEF3F1A590D7863B0036B993C84 BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0x05 BL: 0xFE [BOOTROM] SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok EMI known SLA: Start 0x15 Auth Passed; SEC: 0x00000001 EMI loaded by MEID: 004ACDEF3F1A590D7863B0036B993C84 AGENT: AUTO: 0_base: base_v1712 [e600c7d1] C:\InfinityBox\CM2MT2\boot\0_base\base_v1712\MTK_AllInOne_DA.e600c7d1.bin Looking for suitable BootChain in DA... Found: MT6735; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started NAND: DEVICE NOT FOUND EMMC: OK CID: 150100514531334D420DFCF768EF3BBD DA v4.2.155 EXT_RAM NOT initialized EMMC: OK CID: 510001154D333145F7FC0D42BD3BEF68 NAND: DEVICE NOT FOUND DRAM: 0x00BC EMI: FireFly preloader_a158.bin with 3 memory type(s) 1. ID: 150100514531334D42 Samsung QE13MB RAM: 2.00 Gb 2. ID: 90014A484147346132 Hynix HAG4a2 RAM: 2.00 Gb 3. ID: 150100514536334D42 Samsung QE63MB RAM: 2.00 Gb INIT: 0x00BC DRAM [ 0x00000000 [ 0 B ] ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] DA: DRAM ready Boot to 2nd DA... Ok Load HW info... EMMC CID: 150100514531334D420DFCF768EF54BD crc Ok Ven: Samsung OEM: 256 ID: 514531334D42 [QE13MB] PRV: 0x0D SNN: 4244072687 [0xFCF768EF] MM/YY: 5/2017 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x3A3E00000 [ 14.56 Gb ] RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] CHIP: MT6735 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0335 TYPE: LEGACY [MTK] RNID: EEC022361DED0C668F63AA296BA2E886 MEID: 004ACDEF3F1A590D7863B0036B993C84 DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: FULL-SPEED Set port Speed... PTFN: MediaTek DA USB VCOM (Android) (COM34) MODE: PRELOADER PORT; PORT: 34 Boot done LEGACY [MTK] Analyze PMT... Ok PMT: LGPT [0x06] Records: 27 Strategy: [none|generic] Verify config values... Ok Loaders Ok Stage: Android OS Off Stage: FRP... [1] PROTECTION... Done Reset port... Trying to reboot... Done: 00:00:25 Reconnect Power/Cable now |
08-18-2024, 17:49 | #76274 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | ITEL A571L RESET FRP DONE BY CM2 Card found : 73CA70CC , v0161 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : A571L_A26 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:19 |
08-18-2024, 17:50 | #76275 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | Oppo CPH2349 Format & Frp Code: Operation: Reset Settings/Format FS [ v2.53a8 (beta) ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: OPPO PreLoader USB VCOM (Android) (COM107) MODE [0]: PRELOADER PORT; PORT: 107 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 5DA0978453AB8E87F25C7FC64B81E448CA7DB2B10AFC45FB0AC225812A44CC54 AGENT: AUTO: Oppo: 2021 [f2f720fb] C:\Users\MFQ\Downloads\Compressed\CM2MT2_2.53a8\boot\Oppo\2021\MTK_AllInOne_DA_OP.bin Looking for suitable bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00038000 [ 224.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 90014A68433861503E0300037805A859 crc Ok Vendor: Hynix OEM: 330 ID: 68433861503E [hC8aP>] PRV: 0x03 Serial: 227333 0x00037805 MM/YY: 10/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: B3CF246572663927F10338F69407AB65 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 48 Select info source... [vendor_boot] [recovery] [boot] Finished Probe core... Ok Product Info: CPH2349 Kernel Info: 4.19.127 Display ID: CPH2349_11_A.01_231103 Display ID: CPH2349_11_A.01 Device ID: oplus-mssi-64-cn-MT6765_CPH2349_export_11_A.08_2021120320180000 Strategy: [oppo] Firmware ID: MT6765_CPH2349_11_A.01_CPH2349.MT6765_CPH2349_export_11_A.08_2021120320180000 SmartInfo: Android Ver: 9 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify config values... Ok Verify config values... Ok Backup to C:\Users\MFQ\Downloads\Compressed\CM2MT2_2.53a8\backup\MT6765__DCBD1171211F8C6FE8512C97CB6F72C7\ Items to check: 22 Read [35] NVRAM Read [14] NVDATA Read [22] PROINFO Read [36] LK Read [13] NVCFG Read [17] PROTECT1 Read [1] PGPT Read [20] PERSIST Read [0] PRELOADER Read [23] OCDT Read [5] OPPORESERVE1 Read [7] OPPORESERVE3 Read [8] OPPO_CUSTOM Read [26] CDT_ENGINEERING Done 14 files Compress: C:\Users\MFQ\Downloads\Compressed\CM2MT2_2.53a8\backup\MT6765__DCBD1171211F8C6FE8512C97CB6F72C7\ Cleanup... Ok Verify C:\Users\MFQ\Downloads\Compressed\CM2MT2_2.53a8\backup\MT6765__DCBD1171211F8C6FE8512C97CB6F72C7.7z Verified Stage: Android OS [1] ... Create partition image... Ok Ok [2] ... Create partition image... Ok Ok [4] USERDATA... Ok [5] USERDATA... Ok Stage: FRP... [1] PROTECTION... Done Stage: Smart... Reset port... Trying to reboot... Done: 1 min 26 sec Reconnect Power/Cable now |
