08-18-2024, 18:01 | #76276 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,778 | Card found : 73CA70CC , v0161 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 2687E70E ID_BLOCK_L : 9B6D07FF5EC4F1FCAB80705D9AE17159 ID_BLOCK_L : 42319F2E23B21CA92C8BCC050FE6F0DB Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : OPPO ProdName : A37f ProdModel : A37f Device : A37f AndroidVer: 5.1.1 SWVersion : A37fEX_11.A.28_INT_028_201710081545 Manufact. : OPPO SysPatch : LMY47V DevComTime: 10/8/2017 9:26:49 AM QLMxCPU : MSM8916 USERData : NORMAL GCSec : EMPTY Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 2687E70E ID_BLOCK_L : 9B6D07FF5EC4F1FCAB80705D9AE17159 ID_BLOCK_L : 42319F2E23B21CA92C8BCC050FE6F0DB Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
08-19-2024, 11:30 | #76277 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | S/N: 0073CA70CC v0161 Chinese Miracle II - MT2 Service Tool v2.63 Init log engine... Ok Build directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 11 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Check for updates [CM2MT2]... Installed v2.63 Infinity #CM2MT2 v2.64 - Boot process revised - New DA and new models supported - [RawTool] rebuilded - [Reset] process revised - META/SVC mode rebuilded - Flash chip EOL fault method detection revised - [AppTool] search feature - Privacy Lock Reset process revised - Software messages and hints updated Required firmware v0162 Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Sales: https://infinity-box.com/buy/ Account: https://infinity-box.com/service/ Update configuration... Configuration [12412] updated Get list of devices... Ok Reloaded 1998 devices Build device list... Load IDBase v915508 Ok Load 149 profiles... Ok libusb: v1.2.6.0 Init environment... Ok Ready Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [+] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM6) MODE [0]: BOOTROM; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: F4C9366BCA9593D78C08B1D289CC8B7F BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 00388B3AD30075C0DD77F70590A2312ADA75C1F33DBFC3BC50 52446703C9D6DD SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: F4C9366BCA9593D78C08B1D289CC8B7F AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100514436334D4203C5249AE87611 crc Ok Vendor: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 Serial: 3307510504 0xC5249AE8 MM/YY: 7/2019 EMI: FireFly preloader_oppo6762_18540.bin with 9 memory type(s) 1. eMMC DDR3 ID: 150100515836334142 Samsung QX63AB RAM: 2.00 Gb 2. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC DDR3 ID: 90014A484147346132 Hynix HAG4a2 RAM: 2.00 Gb 4. eMMC DDR3 ID: 13014E53304A394237 Micron S0J9B7 RAM: 3.00 Gb 5. eMMC DDR3 ID: 150100514536334D42 Samsung QE63MB RAM: 2.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 7. eMMC DDR3 ID: 150100524436344D42 Samsung RD64MB RAM: 4.00 Gb 8. eMMC DDR3 ID: 150100514436334D42 Samsung QD63MB RAM: 2.00 Gb 9. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 150100514436334D4203C5249AE87611 crc Ok Vendor: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 Serial: 3307510504 0xC5249AE8 MM/YY: 7/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: D02E8097B7A156E355368BC9A5F4FD1F MEID: F4C9366BCA9593D78C08B1D289CC8B7F USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 9 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 42 Probe boot... Ok 1 sec Patch Level: PPR1.180610.011 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2021-05-05 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: OPPO SW: full_oppo6762_18540-user 9 PPR1.180610.011 1608710123 release-keys Build Time: 3/29/2024 8:51:21 AM SW Version: 1711702281 Product Brand: OPPO Product Model: CPH1923 Product Info: CPH1923 Product Name: CPH1923 Product Device: OP486C SW OTA Version: CPH1923EX_11.A.42_0420_202403291551 Display ID: CPH1923EX_11_A.42 Kernel Info: 4.9.117 Device ID: oppo-cph1923-op486c-MT6765_CPH1923EX_11_A.18_190705_3e5fcc54 Strategy: [oppo] Firmware ID: MT6765_OPPO_CPH1923_OSv9_CPH1923EX_11_A.42_PPR1.18 0610.011_CPH1923.MT6765_CPH1923EX_11_A.18_190705_3 e5fcc54 Android ver: 9 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 150100514436334D4203C5249AE87611 crc Ok Vendor: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 Serial: 3307510504 0xC5249AE8 MM/YY: 7/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] Backup to C:\InfinityBox\CM2MT2\backup\MT6765__F4C9366BCA959 3D78C08B1D289CC8B7F\ Items to check: 22 Read [29] NVRAM NVRAM: Items: 0xBB Size: 0x0ACAB4 State: Ok WiFi MAC: 70DDA8A7078C BT MAC: 70DDA8A7078B Read [13] NVDATA Read [20] PROINFO Read [30] LK lk [6cc30146] Read [12] NVCFG Read [15] PROTECT1 Read [1] PGPT Read [18] PERSIST Read [0] PRELOADER Read [5] OPPORESERVE1 Read [7] OPPORESERVE3 Zero content file deleted: C:\InfinityBox\CM2MT2\backup\MT6765__F4C9366BCA959 3D78C08B1D289CC8B7F\opporeserve3.bin Read [8] OPPO_CUSTOM Done 11 files 12 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6765__F4C9366BCA959 3D78C08B1D289CC8B7F\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__F4C9366BCA959 3D78C08B1D289CC8B7F.7z Enough [oppo-cph1923-op486c-mt6765-cph1923ex-11-a.18-190705-3e5fcc54] Stage: Android OS [2] WIPE... Skip for Strategy [oppo] [3] WIPE... Create partition image... Ok Ok [4] WIPE... Create partition image... Ok Ok [6] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 1 min 14 sec Reconnect Power/Cable now |
08-19-2024, 11:45 | #76278 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | QMobile ENERGY_X2 Flash Code: Load: C:\Users\MFQ\Downloads\Compressed\Qmobile_Energy_X2_MT6580_12282016_6.0\Qmobile_Energy_X2_MT6580_12282016_6.0\Firmware\MT6580_Android_scatter.txt Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : QMobile WWW.COMBINEFILE.COM Device Model : ENERGY_X2 Device CPU : MT6580 Device IntName : ENERGY_X2 Device Version : 6.0 Device Compile : 12/28/2016 2:12:35 AM Device Project : ALPS.W10.24.p0 Device ExtInfo : QMobile ENERGY X2 Firmware ID: MT6580_QMobile_ENERGY_X2_OSv6.0_MRA58K_ENERGY_X2 Verify firmware [MT6580_QMobile_ENERGY_X2_OSv6.0_MRA58K_ENERGY_X2]... Exist (1) Preloader [HW DEV]: EMI: MT6752 preloader_v3800.bin with 7 memory type(s) 1. eMMC DDR3 ID: 150100463832324D42 Samsung F822MB RAM: 1.00 Gb 2. eMMC DDR3 ID: 450100445331303038 Sandisk DS1008 RAM: 1.00 Gb 3. eMMC DDR3 ID: 90014A483847316505 Hynix H8G1e RAM: 1.00 Gb 4. eMMC DDR3 ID: 90014A484147326505 Hynix HAG2e RAM: 2.00 Gb 5. eMMC DDR3 ID: 150100463732324D42 Samsung F722MB RAM: 1.00 Gb 6. eMMC DDR3 ID: 700100454841434538 Kingston EHACE8 RAM: 1.00 Gb 7. eMMC DDR3 ID: 150100464E58324D42 Samsung FNX2MB RAM: 1.00 Gb Operation: Write Flash [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Wait... [+] Re-Partition [-] Checksum Verify [+] Pre-Erase [+] Check compatibility [-] Backup [-] FLASH ERASE C:\Users\MFQ\Downloads\Compressed\Qmobile_Energy_X2_MT6580_12282016_6.0\Qmobile_Energy_X2_MT6580_12282016_6.0\Firmware\ preloader_v3800.bin [ 115.68 Kb ] d303f3ac lk.bin [ 275.30 Kb ] 03cce3fd boot.img [ 7.48 Mb ] dba939eb recovery.img [ 8.34 Mb ] logo.bin [ 1.62 Mb ] 5878a613 secro.img [ 132.00 Kb ] f0702582 system.img [ 2.65 Gb ] cache.img [ 6.10 Mb ] 2b0d047d userdata.img [ 133.60 Mb ] Files: 9; Total size: 0xB368D028 [ 2.80 Gb ] Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : QMobile WWW.COMBINEFILE.COM Device Model : ENERGY_X2 Device CPU : MT6580 Device IntName : ENERGY_X2 Device Version : 6.0 Device Compile : 12/28/2016 2:12:35 AM Device Project : ALPS.W10.24.p0 Device ExtInfo : QMobile ENERGY X2 Firmware ID: MT6580_QMobile_ENERGY_X2_OSv6.0_MRA58K_ENERGY_X2 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM12) MODE [0]: PRELOADER PORT; PORT: 12 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x01 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v1712 [e600c7d1] C:\InfinityBox\CM2MT2\boot\0_base\base_v1712\MTK_AllInOne_DA.e600c7d1.bin [d303f3ac] C:\Users\MFQ\Downloads\Compressed\Qmobile_Energy_X2_MT6580_12282016_6.0\Qmobile_Energy_X2_MT6580_12282016_6.0\Firmware\preloader_v3800.bin Looking for suitable BootChain in DA... Found: MT6580; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started NAND: DEVICE NOT FOUND EMMC: OK CID: 484A019065324741DA3507058BB35AD9 DA v4.2.156 DA: DRAM ready Boot to 2nd DA... Ok Load HW info... EMMC CID: 90014A4841473265050735DAD95AB38B crc Ok Ven: Hynix OEM: 330 ID: 484147326505 [HAG2e] PRV: 0x07 SNN: 903534938 [0x35DAD95A] MM/YY: 11/2016 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x3AB800000 [ 14.68 Gb ] RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] RNID: 4E68A2BE59D4AF78431AABC8DA6ECD34 DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: HIGH-SPEED Boot done LEGACY [MTK] HW verification... Ok Analyze PMT... Ok PMT: LGPT [0x06] Records: 24 Verify config values... Ok Loaders Ok Verify PMT... Ok Verify SEC DL... SEC DL: Off [CUST] SEC_DL: SECURE USB DL DISABLED SEC ID: 0x35464646304237304435444533464335 Pre-Erase... Erase: 0x0000000000000000 0x0000000000080000 Erase: 0x0000000001CC0000 0x00000003A8AC0000 RePartition... Ok SecInit... Finished Flash write... Write: PRELOADER [ 115.68 Kb ] Update bootloader code... Ok Write: LK [ 275.30 Kb ] Ok Write: BOOT [ 7.48 Mb ] Ok Write: RECOVERY [ 8.34 Mb ] Ok Write: LOGO [ 1.62 Mb ] Ok Write: SECRO [ 132.00 Kb ] Ok Write: SYSTEM [ 2.65 Gb ] Ok Write: CACHE [ 6.10 Mb ] Ok Write: USERDATA [ 133.60 Mb ] Ok RePartition... Ok Reset port... Done: 00:04:17 Reconnect Power/Cable now |
08-19-2024, 19:11 | #76279 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | E TACHI B13 PRO RESET PASSWORD DONE BY CM2 Card found : 73CA70CC , v0161 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.07 ] BootMode : FLASH 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] IMEI[1] : IMEI[2] : Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_106 35436E8AA_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
08-20-2024, 12:15 | #76280 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | S/N: 0073CA70CC v0161 Chinese Miracle II - MT2 Service Tool v2.63 Init log engine... Ok Build directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 12 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Load IDBase v915508 Ok Load 149 profiles... Ok libusb: v1.2.6.0 Init environment... Ok Ready Operation: Identify [ v2.63 ] Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM6) MODE [0]: BOOTROM; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 8060750C39A91E38E6590532110BD399 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: D5CB809AB7B99A7006FBCC1ACE656A8AEE4EC26FFCA36FD0DF 7E4D9B6235758F SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 8060750C39A91E38E6590532110BD399 AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 13014E47314A395339100EE5035B28B1 crc Ok Vendor: Micron OEM: 334 ID: 47314A395339 [G1J9S9] PRV: 0x10 Serial: 249889627 0x0EE5035B MM/YY: 2/2021 EMI: FireFly preloader_oppo6765.bin with 6 memory type(s) 1. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 2. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 4. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 13014E47314A395339100EE5035B28B1 crc Ok Vendor: Micron OEM: 334 ID: 47314A395339 [G1J9S9] PRV: 0x10 Serial: 249889627 0x0EE5035B MM/YY: 2/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1F000000 [ 116.48 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 0F718BAB5EB5191E31D479DE00E708ED MEID: 8060750C39A91E38E6590532110BD399 USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 1 min 37 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 47 STORAGE Life Status: eMMC : OK STORAGE OTP Status: UNLOCKED STORAGE RPMB Status: eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Saved: C:\InfinityBox\CM2MT2\phdata\key.json Probe boot... recovery;boot; Finished 2 sec Probe core... Mount[erofs] system 0x0055900000/0x5B76E000 Mount[erofs] vendor 0x00B106E000/0x18756000 Mount[erofs] product 0x00C97C4000/0x0116E000 Mount[erofs] odm 0x00CE9EB000/0x07C14000 Ok 3 sec SW: alps/sys_oplus_mssi_64_cn/oplus_mssi_64_cn:11/RP1A.200720.011/1644304518397:user/release-keys Product Brand: alps Product Device: oplus_mssi_64_cn Product Model: oplus_mssi_64_cn Product Name: sys_oplus_mssi_64_cn Patch Level: RP1A.200720.011 Display ID: RP1A.200720.011 release-keys SW Version: 1644304518397 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2022-02-05 Build Time: 2/8/2022 7:34:11 AM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: oplus_mssi_64_cn SW: sys_oplus_mssi_64_cn-user 11 RP1A.200720.011 1644304518397 release-keys Build Time: 2/8/2022 8:01:29 AM Product Brand: OPPO Product Info: CPH2239 Display ID: CPH2239_11_C.01 Display ID: CPH2239_11_C.01_220208 Device ID: oppo-oplus-mssi-64-cn-sys-oplus-mssi-64-cn-MT6765_CPH2239_11_A.01_210317_8f7e093b Strategy: [oppo] Firmware ID: MT6765_oplus_mssi_64_cn_OSv11_CPH2239_11_C.01_2202 08_RP1A.200720.011_CPH2239_OPPO_alps.MT6765_CPH223 9_11_A.01_210317_8f7e093b Verify firmware [MT6765_oplus_mssi_64_cn_OSv11_CPH2239_11_C.01_2202 08_RP1A.200720.011_CPH2239_OPPO_alps.MT6765_CPH223 9_11_A.01_210317_8f7e093b]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem [ext4] with FBE [file based encryption] Backup to C:\InfinityBox\CM2MT2\backup\MT6765__8060750C39A91 E38E6590532110BD399\ Items to check: 22 Read [31] NVRAM NVRAM: Items: 0xAC Size: 0x105316 State: Ok WiFi MAC: 540E580C9315 BT MAC: 540E580C9314 Read [14] NVDATA Read [22] PROINFO Read [36] LK lk [e674c73a] Read [13] NVCFG Read [17] PROTECT1 Read [1] PGPT Read [20] PERSIST Read [0] PRELOADER Read [33] OCDT Read [5] OPPORESERVE1 Read [7] OPPORESERVE3 Zero content file deleted: C:\InfinityBox\CM2MT2\backup\MT6765__8060750C39A91 E38E6590532110BD399\opporeserve3.bin Read [8] OPPO_CUSTOM Read [32] CDT_ENGINEERING Done 13 files 13 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6765__8060750C39A91 E38E6590532110BD399\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__8060750C39A91 E38E6590532110BD399.7z Verified Analyze modem... OPPO6765_20361_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R 2_TC16_Q_G35_PR1_SP_V6_P28 Analyze nvram... PSN1: 0020361013110322 EMMC CID: 13014E47314A395339100EE5035B28B1 crc Ok Vendor: Micron OEM: 334 ID: 47314A395339 [G1J9S9] PRV: 0x10 Serial: 249889627 0x0EE5035B MM/YY: 2/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1F000000 [ 116.48 Gb ] Analyze preloader... EMI: MT6765 preloader_oppo6765.bin with 6 memory type(s) 1. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 2. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 4. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_o ppo6765.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_o ppo6765.bin [58d907b5]... Exist Probe FRP... Most probably Off Reset port... Finished 2 min 44 sec Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [+] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM6) MODE [0]: BOOTROM; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 8060750C39A91E38E6590532110BD399 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: D5CB809AB7B99A7006FBCC1ACE656A8AEE4EC26FFCA36FD0DF 7E4D9B6235758F SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok EMI known SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 8060750C39A91E38E6590532110BD399 AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 13014E47314A395339100EE5035B28B1 crc Ok Vendor: Micron OEM: 334 ID: 47314A395339 [G1J9S9] PRV: 0x10 Serial: 249889627 0x0EE5035B MM/YY: 2/2021 EMI: FireFly preloader_oppo6765.bin with 6 memory type(s) 1. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 2. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 4. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 13014E47314A395339100EE5035B28B1 crc Ok Vendor: Micron OEM: 334 ID: 47314A395339 [G1J9S9] PRV: 0x10 Serial: 249889627 0x0EE5035B MM/YY: 2/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1F000000 [ 116.48 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 0F718BAB5EB5191E31D479DE00E708ED MEID: 8060750C39A91E38E6590532110BD399 USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 25 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 47 Probe boot... recovery;boot; Finished 2 sec Probe core... Mount[erofs] system 0x0055900000/0x5B76E000 Mount[erofs] vendor 0x00B106E000/0x18756000 Mount[erofs] product 0x00C97C4000/0x0116E000 Mount[erofs] odm 0x00CE9EB000/0x07C14000 Ok 3 sec SW: alps/sys_oplus_mssi_64_cn/oplus_mssi_64_cn:11/RP1A.200720.011/1644304518397:user/release-keys Product Brand: alps Product Device: oplus_mssi_64_cn Product Model: oplus_mssi_64_cn Product Name: sys_oplus_mssi_64_cn Patch Level: RP1A.200720.011 Display ID: RP1A.200720.011 release-keys SW Version: 1644304518397 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2022-02-05 Build Time: 2/8/2022 7:34:11 AM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: oplus_mssi_64_cn SW: sys_oplus_mssi_64_cn-user 11 RP1A.200720.011 1644304518397 release-keys Build Time: 2/8/2022 8:01:29 AM Product Brand: OPPO Product Info: CPH2239 Display ID: CPH2239_11_C.01 Display ID: CPH2239_11_C.01_220208 Device ID: oppo-oplus-mssi-64-cn-sys-oplus-mssi-64-cn-MT6765_CPH2239_11_A.01_210317_8f7e093b Strategy: [oppo] Firmware ID: MT6765_oplus_mssi_64_cn_OSv11_CPH2239_11_C.01_2202 08_RP1A.200720.011_CPH2239_OPPO_alps.MT6765_CPH223 9_11_A.01_210317_8f7e093b Android ver: 11 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 13014E47314A395339100EE5035B28B1 crc Ok Vendor: Micron OEM: 334 ID: 47314A395339 [G1J9S9] PRV: 0x10 Serial: 249889627 0x0EE5035B MM/YY: 2/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1F000000 [ 116.48 Gb ] Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__8060750C39A91 E38E6590532110BD399 Stage: Android OS [2] WIPE... Skip for Strategy [oppo] [3] WIPE... Create partition image... Ok Ok [4] WIPE... Create partition image... Ok Ok [6] USERDATA... Ok [7] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 50 sec Reconnect Power/Cable now |
08-20-2024, 13:34 | #76281 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,433 | ViVo PD1934 Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [-] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM7) MODE [0]: PRELOADER PORT; PORT: 7 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 2F175BC9094A030199E6C1B8A44CD29B8991A1D84D998BD89A A6F3C78437F972 AGENT: [ecb438fd] C:\InfinityBox\CM2MT2\boot\Vivo\2023-08\MTK_AllInOne_DA_v3.fdaaf7f6.bin Looking for bootchain in DA... Found: MT6768; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 90014A684445615033030035CCE54793 crc Ok Vendor: Hynix OEM: 330 ID: 684445615033 [hDEaP3] PRV: 0x03 Serial: 3525861 0x0035CCE5 MM/YY: 4/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1F000000 [ 116.48 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: EB9065EDAE8B1BA1B0B7A35F47F82EF7 USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 29 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 44 Probe boot... Ok 1 sec Patch Level: PPR1.180610.011 Display ID: PPR1.180610.011 release-keys SW Version: compiler05281759 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2021-04-01 Build Time: 28-May-21 9:58:39 AM Product Model: vivo Product Brand: vivo Product Name: PD1934 Product Device: PD1934 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: vivo Product Info: k68v1_64 SW: full_k68v1_64-user 9 PPR1.180610.011 compiler05281759 release-keys Product Board: k68v1_64 Board Platform: mt6768 Product Name: full_k68v1_64 Product Device: k68v1_64 Device ID: full-k68v1-64-vivo-pd1934-k68v1-64 Strategy: [none|generic] Firmware ID: MT6768_vivo_vivo_OSv9_PPR1.180610.011_k68v1_64 Android ver: 9 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 90014A684445615033030035CCE54793 crc Ok Vendor: Hynix OEM: 330 ID: 684445615033 [hDEaP3] PRV: 0x03 Serial: 3525861 0x0035CCE5 MM/YY: 4/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1F000000 [ 116.48 Gb ] Backup to C:\InfinityBox\CM2MT2\backup\MT6768__C4250F485B8FC 6D163C2F9FA21514FE6\ Items to check: 22 Read [24] NVRAM NVRAM: Items: 0xBD Size: 0x0F7F9B State: Ok WiFi MAC: 000000000000 BT MAC: 207454E87D46 IMEI[1]: 86 IMEI[2]: 86 Read [15] NVDATA Read [21] PROINFO Read [34] LK lk [aa03b22c] Read [14] NVCFG Read [17] PROTECT1 Read [1] PGPT Read [16] PERSIST Read [0] PRELOADER Done 9 files 7 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6768__C4250F485B8FC 6D163C2F9FA21514FE6\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6768__C4250F485B8FC 6D163C2F9FA21514FE6.7z Enough [full-k68v1-64-vivo-pd1934-k68v1-64] Stage: Android OS [1] ... Create partition image... Ok Ok [2] ... Create partition image... Ok Ok [4] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 1 min 11 sec Reconnect Power/Cable now |
08-20-2024, 16:58 | #76282 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | CALL ME C12 HANG ON LOGO DONE BY CM2 WITH OUT BOOT KEY Card found : 73CA70CC , v0161 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.07 ] BootMode : SVC 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : SPRD ( Legacy ) ModemInfo : Project Version: SC6531EFM_BAR BASE Version: BASE_SVN HW Version: SC6531EFM_BAR CMP_Time : 01-15-2020 11:04:51 SecInfo : IMEI[1] : IMEI[2] : IMEI[3] : WIFIMAC : FFFFFFFFFFFF BT_MAC : 018321094528 SEC_ID : 7B9EFFFF39A561D3 Done! Elapsed: 00:00:20 Reconnect Power/Cable! Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Format FFS Done! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
08-20-2024, 17:36 | #76283 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | ITEL W5006 RESET FRP DONE BY CM2 Card found : 73CA70CC , v0161 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : iTel : W5006X-F3112_A17 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:31 |
08-21-2024, 05:28 | #76284 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | Tecno POP RESET FRP DONE BY CM2 Card found : 73CA70CC , v0161 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:35 |
08-21-2024, 14:23 | #76285 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | Infinix-X688B Format & Frp Code: Operation: Reset Settings/Format FS [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MTK USB Port (COM28) MODE [0]: BOOTROM; PORT: 28 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 35A2A344CB78F14145A40A695FA42420 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: F4ABC13845669296AFF68E2C185A388D36CF5C9B7C49FB171BD13974EDD1886B SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 35A2A344CB78F14145A40A695FA42420 AGENT: AUTO: 0_base: base_v2316 [1d5fdec4] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for suitable BootChain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 90014A68433861503E03102B246598A5 crc Ok Ven: Hynix OEM: 330 ID: 68433861503E [hC8aP>] PRV: 0x03 SNN: 271262821 [0x102B2465] MM/YY: 9/2021 EMI: FireFly preloader_x688b_h659.bin with 20 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 6.00 Gb 10. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 150100445036384D42 Samsung DP68MB RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 17. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 18. eMMC LP_DDR4X ID: 150100445036444242 Samsung DP6DBB RAM: 4.00 Gb 19. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 20. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 90014A68433861503E03102B246598A5 crc Ok Ven: Hynix OEM: 330 ID: 68433861503E [hC8aP>] PRV: 0x03 SNN: 271262821 [0x102B2465] MM/YY: 9/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 203FF4FACAFDE89DC2F062E89FD16D5C MEID: 35A2A344CB78F14145A40A695FA42420 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 41 Select info source... recovery [2700000] Ok SW: Infinix/X688B-GL/Infinix-X688B:11/RP1A.200720.011/230324V619:user/release-keys Product Brand: Infinix Product Device: Infinix-X688B Product Model: Infinix X688B Product Name: X688B-GL Patch Level: RP1A.200720.011 Display ID: X688B-H659ABCDEFGHIJKLMNO-R-GL-230324V619 SW Version: 230324V619 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-03-05 Build Time: 24/03/2023 10:02:24 am CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: x688b_h659 SW: vnd_x688b_h659-user 11 RP1A.200720.011 282777 release-keys Product Board: Infinix-X688B Board Platform: mt6765 Product Manfct: INFINIX MOBILITY LIMITED Strategy: [none|generic] SmartInfo: Android Ver: 11 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify config values... Ok Loaders Ok Stage: Android OS [1] ... Create image... Ok Ok [2] ... Create image... Ok Ok [4] USERDATA... Ok [5] USERDATA... Ok Stage: FRP... [1] PROTECTION... Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Done: 00:00:34 Reconnect Power/Cable now |
08-21-2024, 18:03 | #76286 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | TECNO SPARK 8C Format & Frp Code: Operation: Connect [T606 Boot FireFly] [v2.23] Wait... - Power device Off - Connect cable [remember Vol+ | Vol-] [remember Test-Point] Waiting for device... Device found PTFN: SPRD U2S Diag (COM91) vid 0x1782 pid 0x4D00 boot: SPRD3 boot iLoader... Ok start iLoader... Ok Handshake... Ok boot xLoader... Ok start FireFly... Ok Loader exec Ok Dev UID: a65f91ce8e01167e5787a34112d8aefa889343a35ee7a0c5520612c4acfe645a get storage info... EMMC CID: 15010044563644424202567EFECFC86D crc Ok Vendor: Samsung OEM: 256 ID: 445636444242 [DV6DBB] PRV: 0x02 Serial: 1451163343 0x567EFECF MM/YY: 12/2021 CSD: D02701320F5903FFF6DBFFEF8E404001 temp_write_protect: False perm_write_protect: False wp_group: 0x10 en 0x01 EXTCSD rev1.8 EMMC 5.1 FW: 02 ERASE_GROUP_DEF: 0x0400 BOOT_BUS_WIDTH: 0x00 PARTITION_CONFIG: 0x08 RST_N_FUNCTION: 0x01 PART_S_COMPLETED: False BOOT0/BOOT1 size: 0x400000 4.00 Mb RPMB size: 0x1000000 16.00 Mb WP_GRP_SIZE: 0x800000 8.00 Mb Size: Market 128 Gb Actual 0x1D1EC00000 116.48 Gb EOL: Status: Normal: Less than 80% reserved blocks used EOL_A: SLC status: 0% - 10% used EOL_B: MLC status: 0% - 10% used read extcsd... Ok extcsd stored: C:\InfinityBox\CM2SP3\backup\ext_csd\sc9230_a65f91ce8e01167e_extcsd_0015-Samsung_DV6DBB_5.1_2024-02-18.bin Verify config values... Ok get partitions... Partitions: 66 items Connected get slots... slot: a get sw info... probe boot... [vendor_boot_a] [boot_a] SW: TECNO/F062/TECNO-KG5k:11/RP1A.201005.001/GL-V255-20231122:user/release-keys Product Brand: TECNO Product Device: TECNO-KG5k Product Model: TECNO KG5k Product Name: KG5k Patch Level: RP1A.201005.001 Display ID: KG5k-F062-11.0-GL-V255-20231122 SW Version: GL-V255-20231122 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-11-05 Build Time: 22/11/2023 9:45:50 am Product Name: F062 Market Name: TECNO SPARK 8C CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: KG5k SW: KG5k-user 11 RP1A.201005.001 696 release-keys Product Board: KG5k Board Platform: ums9230 Product Manfct: TECNO MOBILE LIMITED Android Ver: 11; UserDataFS: 0x02 [ext4|8+]; CacheFS: 0x02 [ext4|8+] Device ID: tecno-mobile-limited-tecno-kg5k-f062-tecno-spark-8c Strategy: [tecno] Firmware ID: UMS9230_TECNO_MOBILE_LIMITED_TECNO_KG5k_OSv11_KG5k-F062-11.0-GL-V255-20231122_RP1A.201005.001_KG5k Read Device-ID... IMEI[0]: IMEI[1]: IMEI[2]: IMEI[3]: BT MAC: c0:ad:97:b3:2f:4a WiFi MAC: c0:ad:97:b3:2f:4b Backup 8 items to: C:\InfinityBox\CM2SP3\backup\sc9230_a65f91ce8e01167e\ Read [1/8] prodnv 10.00 Mb Ok Read [2/8] miscdata 1024.00 Kb Ok Read [3/8] uboot_a 2.00 Mb Ok Read [4/8] uboot_b 2.00 Mb Ok Read [5/8] l_fixnv1_a 2.00 Mb Ok Read [6/8] l_fixnv2_a 2.00 Mb Ok Read [7/8] l_fixnv1_b 2.00 Mb Ok Read [8/8] l_fixnv2_b 2.00 Mb Ok Done 8 files Compress: C:\InfinityBox\CM2SP3\backup\sc9230_a65f91ce8e01167e\ Cleanup... Ok Verify C:\InfinityBox\CM2SP3\backup\sc9230_a65f91ce8e01167e.7z Verified [ca0f51f4] MemTool 66 items Finished 2 min 2 sec Operation: Reset Settings / Format FS [T606 Boot FireFly] [v2.23] WARNING: Reset may delete ALL USER DATA! Continue? Yes [-] Wipe [+] Userdata [+] FRP [+] Smart Wait... Stage: FRP... Looking for items... 1 items found [1] Writing... Ok Completed Stage: Userdata... [1] Format... Ok 500 us [2] Format... Ok 3 sec [3] Format... Ok 3 sec Completed Stage: Smart... [17] Format... Ok [18] Format... Ok Completed Finished 11 sec Reboot... Disconnect cable if it freez fault 0x05 0x8E | BSL_PHONE_WAIT_INPUT_TIMEOUT Bye [0] |
08-21-2024, 18:19 | #76287 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | QMOBILE i6i SPD 7731E RESET FRP DONE BY CM2 Card found : 73CA70CC , v0161 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:17 |
08-22-2024, 11:13 | #76288 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | Redmi water_global Frp Code: Product Brand: Redmi Product Device: water Product Model: water Product Name: water_global SW: Redmi/water_global/water:12/SP1A.210812.016/V14.0.15.0.TGOMIXM:user/release-keys Patch Level: SP1A.210812.016 Display ID: SP1A.210812.016 SW Version: V14.0.15.0.TGOMIXM Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-08-01 Build Time: 14/08/2023 1:46:18 pm Product Info: water SW: vnd_water-user 12 SP1A.210812.016 V14.0.15.0.TGOMIXM release-keys Product Manfct: Xiaomi Product Board: water Board Platform: mt6765 Strategy: [xiaomi] Firmware ID: MT6765_Xiaomi_water_OSv12_V14.0.15.0.TGOMIXM_SP1A.210812.016_water_Redmi Verify firmware [MT6765_Xiaomi_water_OSv12_V14.0.15.0.TGOMIXM_SP1A.210812.016_water_Redmi]... Exist (1) Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0xB4 Size: 0x0AD76B [SecLv: Vendor Signed] State: Ok WiFi MAC: AA006E742F76 BlTh MAC: 3050CEFBDAD3 Verify config values... Ok Loaders Ok STORAGE Life Status: eMMC : OK STORAGE OTP Status: UNLOCKED STORAGE RPMB Status: eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Reset port... Done: 00:00:32 Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [-] Userdata [+] FRP [-] Smart WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MTK USB Port (COM28) MODE [0]: BOOTROM; PORT: 28 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 01A45A6AF08DCFB2C3C32D8BED6B2CF2 BROM: Sec Level: 0x000000E7 Mode: SBC+SLA+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 0B47EDAF6098D3EBE145D4C3D053A61D646E29AE13FBAF6CC61FAB8D2A6800C2 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok EMI known SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 01A45A6AF08DCFB2C3C32D8BED6B2CF2 AGENT: AUTO: 0_base: base_v2316 [1d5fdec4] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for suitable BootChain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: D62D004D4D4336344751186F8DD6AA95 crc Ok Ven: Foresee OEM: 11520 ID: 4D4D43363447 [MMC64G] PRV: 0x51 SNN: 409963990 [0x186F8DD6] MM/YY: 10/2023 EMI: FireFly preloader_water.bin with 9 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 3. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 7. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 8. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 6.00 Gb 9. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: D62D004D4D4336344751186F8DD6AA95 crc Ok Ven: Foresee OEM: 11520 ID: 4D4D43363447 [MMC64G] PRV: 0x51 SNN: 409963990 [0x186F8DD6] MM/YY: 10/2023 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 7F0E59FD81B3ECD58E23732E3D3F632E MEID: 01A45A6AF08DCFB2C3C32D8BED6B2CF2 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 56 Strategy: [none|generic] Verify config values... Ok Loaders Ok Stage: Android OS Off Stage: FRP... [1] PROTECTION... Done Reset port... Trying to reboot... Done: 00:00:22 Reconnect Power/Cable now |
08-22-2024, 11:58 | #76289 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | TECNO-CH6h Format & Frp Code: Operation: Reset Settings/Format FS [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MTK USB Port (COM28) MODE [0]: BOOTROM; PORT: 28 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: 8F8BBBFE07311881D8CB80EBBDAA4384 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 67A11A53C4201FD34F501B6D4C5EDDD867688CA0D4C6E7C359D85798753E0489 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 8F8BBBFE07311881D8CB80EBBDAA4384 AGENT: AUTO: 0_base: base_v2316 [1d5fdec4] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for suitable BootChain in DA... Found: MT6768; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100445636444142028317FA28C869 crc Ok Ven: Samsung OEM: 256 ID: 445636444142 [DV6DAB] PRV: 0x02 SNN: 2199386664 [0x8317FA28] MM/YY: 12/2021 EMI: FireFly preloader_ch6h_h698.bin with 7 memory type(s) 1. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 2. eMMC LP_DDR4X ID: 150100335636434142 Samsung 3V6CAB RAM: 6.00 Gb 3. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 5. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100445636444142028317FA28C869 crc Ok Ven: Samsung OEM: 256 ID: 445636444142 [DV6DAB] PRV: 0x02 SNN: 2199386664 [0x8317FA28] MM/YY: 12/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1EC00000 [ 116.48 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 9A52F92655D20712BDC5BB581747EF35 MEID: 8F8BBBFE07311881D8CB80EBBDAA4384 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 49 Get slot info... a Select info source... boot_a [2000000] Ok Product Brand: TECNO Product Device: TECNO-CH6h Product Model: TECNO CH6h Product Name: CH6h-AS SW: TECNO/CH6h-AS/TECNO-CH6h:12/SP1A.210812.016/231011V656:user/release-keys Patch Level: SP1A.210812.016 Display ID: CH6h-H698I-S-AS-231011V656 SW Version: 231011V656 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-10-05 Build Time: 11/10/2023 10:02:43 am Product Info: ch6h_h698 SW: vnd_ch6h_h698-user 12 SP1A.210812.016 450360 release-keys Product Manfct: TECNO MOBILE LIMITED Product Board: TECNO-CH6h Board Platform: mt6768 Strategy: [none|generic] SmartInfo: Android Ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify config values... Ok Loaders Ok Stage: Android OS [1] ... Create image... Ok Ok [4] USERDATA... Ok [5] USERDATA... Ok Stage: FRP... [1] PROTECTION... Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Done: 00:00:51 Reconnect Power/Cable now |
08-22-2024, 12:44 | #76290 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | Infinix HOT 4 Frp Code: Patch Level: MRA58K Display ID: X557-H807A1-M-161014V126 SW Version: 1476386379 Ver. CodeName: REL Ver. Release: 6.0 Sec. Patch: 2016-10-05 Build Time: 13/10/2016 7:24:42 pm Product Model: Infinix HOT 4 Product Brand: Infinix Product Device: X557 Product Name: X557A1 CPU: armeabi-v7a,armeabi Product Manfct: Infinix Board Platform: mt6580 Product Info: Infinix-X557 SW: Infinix-X557-user 6.0 MRA58K 1454504785 release-keys Strategy: [none|generic] Firmware ID: MT6580_Infinix_Infinix_HOT_4_OSv6.0_X557-H807A1-M-161014V126_MRA58K_Infinix-X557 Verify firmware [MT6580_Infinix_Infinix_HOT_4_OSv6.0_X557-H807A1-M-161014V126_MRA58K_Infinix-X557]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem [ext4] with FDE [encryptable] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0x75 Size: 0x0292D8 State: Ok WiFi MAC: 787D48206ED1 BlTh MAC: 787D4820AD51 IMEI[1]: IMEI[2]: Verify config values... Ok Loaders Ok Reset port... Done: 00:00:23 Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [-] Userdata [+] FRP [-] Smart WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM12) MODE [0]: PRELOADER PORT; PORT: 12 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x01 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v1712 [e600c7d1] C:\InfinityBox\CM2MT2\boot\0_base\base_v1712\MTK_AllInOne_DA.e600c7d1.bin Looking for suitable BootChain in DA... Found: MT6580; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started NAND: DEVICE NOT FOUND EMMC: OK CID: 510001154D3332386EE20042F983AFD2 DA v4.2.156 DA: DRAM ready Boot to 2nd DA... Ok Load HW info... EMMC CID: 150100513832334D4200E26ED2AF83F9 crc Ok Ven: Samsung OEM: 256 ID: 513832334D42 [Q823MB] PRV: 0x00 SNN: 3798913711 [0xE26ED2AF] MM/YY: 8/2016 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x3A3E00000 [ 14.56 Gb ] RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] RNID: 109D54D95C922F6ADFCD883C7BBA9C4D DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: HIGH-SPEED Boot done LEGACY [MTK] Analyze PMT... Ok PMT: LGPT [0x06] Records: 24 Strategy: [none|generic] Verify config values... Ok Loaders Ok Stage: Android OS Off Stage: FRP... [1] PROTECTION... Done Reset port... Trying to reboot... Done: 00:00:18 Reconnect Power/Cable now |
