Old 08-23-2024, 06:58   #76291 (permalink)
Member: 233142
Sonork: 100.1595099
Thanks Meter: 534
Telma f1 prime unlock done
Card found : CXXXXXXX, v0162
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14
Load IDBase v8331 Ok!
Operation : Identify [ v2.14 ]
BootMode : FLASH
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_2GB_1S
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : 0x0008
FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False
FDL : RAW : 0x0002
FDL : FLH : 0x400000
FDL : Control transfered!
Boot Done!
Device info :
Product Brand : Telma
Product Device : Telma_F1Prime4G
Product Model : F1 Prime 4G
Product Name : Telma_F1Prime4G
Patch Level : RP1A.201005.001
Display ID : Telma_F1_Prime_4G_V08_20210819
Ver. Incmt : 24611
Ver. CodeName : REL
Ver. Release : 11
Sec. Patch : 2022-05-05
Build Time : 21.06.2022
Product Manfct : Telma
Product Info : Telma_F1Prime4G
Product Board : sp9832e_1h10_go
Board Platform : sp9832e
Platform Version: MOCORTM_20A_W21.15.3_Debug
Project Version: sharklp
BASE Version: 4G_MODEM_20A_W21.15.3
HW Version: sc9832e_modem
CMP_Time : 04-14-2021 17:43:35
MODEM TAG : MOCORTM_20A_W21.15.3_Debug_4G_MODEM_20A_W21.15.3_s c9832e_modem_sharklp
USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption )
- > INFO : Remove cable from device to switch it off!
Done!
Elapsed: 00:01:07
Operation : SP Unlock [ v2.14 ]
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0008
FDL : RAW : 0x0002
Boot Done!
NVMng : SecurityInfo
IMEI[1] : 350334360744824
IMEI[2] : 350334360744832
IMEI[3] : 867400020316638
SEC : SLS:0, SKS:0, SKV:3
SLStatus : 31
Unlocking device ...
Sync data ...
Device unlocked!
Done!
Elapsed: 00:00:37
Old 08-23-2024, 12:55   #76292 (permalink)
Member: 1835756
Thanks Meter: 922
Nokia tab t20(ta-1397) pattern+frp done
Wait...
S/N: 00904B323D v0162
CM2 - SP3 Service Tool v2.28
Init log engine... Ok
Build directories tree...
Backup files: C:\InfinityBox\CM2SP3\backup\
Backup files: 0 dirs: 0
Build device list... Ok 1326
Ready
Selected: Nokia C01+ Boot [FF] FireFly mmc
[FF] protocol may be SLOW. For flash Read/Write use [FDL]
Selected: Nokia T20 Boot [FF] FireFly mmc
use test-point
Operation: Connect Nokia T20 Boot [FF] FireFly [v2.28]
Wait...
- Power device Off
- Connect cable [remember Vol+ | Vol-] [remember Test-Point]
Waiting for device...
Device found
PTFN: SPRD U2S Diag (COM12) vid 0x1782 pid 0x4D00
Handshake fail
Wrong connection mode?
Canceled
Finished 32 sec
Selected: Nokia T20 Boot [FDL] mmc
For advanced features use [FF]
use test-point
Operation: Connect Nokia T20 Boot [FDL] [v2.28]
Wait...
- Power device Off
Device found
Handshake fail
Canceled
Finished 24 sec
use test-point
Wait...
- Power device Off
Device found
PTFN: SPRD U2S Diag (COM9) vid 0x1782 pid 0x4D00
boot: SPRD3
boot iLoader... Ok
start iLoader... Ok
Handshake... Ok
boot xLoader... Ok
start FireFly... Ok
Loader exec Ok
Dev UID: 81c3c9fd377665a47cc8d240fbc70a955c32410304a8d1b119 50e07b71a0eca3
get storage info...
EMMC
CID: D60103413341353631113840A529680B crc Ok
Vendor: Foresee OEM: 259 ID: 413341353631 [A3A561] PRV: 0x11
Serial: 943760681 0x3840A529
MM/YY: 6/2021
CSD: D0FFFF329F5903FFFFFFFFEF964000FF
temp_write_protect: False
perm_write_protect: False
wp_group: 0x10 en 0x01
EXTCSD rev1.8 EMMC 5.1 FW: 11
ERASE_GROUP_DEF: 0x0400
BOOT_BUS_WIDTH: 0x00
PARTITION_CONFIG: 0x08
RST_N_FUNCTION: 0x01
PART_S_COMPLETED: False
BOOT size: 0x400000
RPMB size: 0x1000000 16.00 Mb
WP_GRP_SIZE: 0x800000 8.00 Mb
Size: Market 64 Gb Actual 0xE67800000 57.62 Gb
EOL: Status: Normal: Less than 80% reserved blocks used
EOL_A: SLC status: 0% - 10% used
EOL_B: MLC status: Not defined
read extcsd... Ok
extcsd stored: C:\InfinityBox\CM2SP3\backup\ext_csd\none_81c3c9fd 377665a4_extcsd_00D6-Foresee_A3A561_5.1_2024-08-23.bin
get partitions...
Partitions: 79
Connected
get sw info... 6 sec
SW: Nokia/Riddler_00WW/RDD:11/RP1A.201005.001/00WW_1_280:user/release-keys
Product Brand: Nokia
Product Device: RDD
Product Model: Nokia T20
Patch Level: RP1A.201005.001
Display ID: 6000F_1_280_B01-user
SW Version: 00WW_1_280
Ver. CodeName: REL
Ver. Release: 11
Sec. Patch: 2022-08-05
Build Time: 8/4/2022 4:19:03 PM
CPU: arm64-v8a,armeabi-v7a,armeabi
CPU: armeabi-v7a,armeabi
CPU: arm64-v8a
Product Info: RDD
SW: Riddler_user_11_RP1A.201005.001_00WW_1_280_B01_rel ease-keys
Product Board: Riddler
Board Platform: ums512
Product Manfct: HMD Global
Product Model: 00WW
Product Info: Riddler_00WW
Product Name: Riddler_00WW
Android ver: 11
UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+]
Device ID: rdd-hmd-global-nokia-t20-rdd-riddler-00ww
Strategy: [nokia]
Firmware ID: UMS512_HMD_Global_00WW_OSv11_6000F_1_280_B01_RP1A. 201005.001_Riddler_00WW_Nokia
Backup exist: C:\InfinityBox\CM2SP3\backup\ums512_81c3c9fd377665 a4\
get slots... slot: a
MemTool load 79 items
Finished 33 sec
Operation: Reset | Format Nokia T20 Boot [FF] FireFly [v2.28]
WARNING: Reset may delete ALL USER DATA!
Continue? Yes
[+] Wipe
[-] Userdata
[+] FRP
[+] Smart
Reset Userdata is Off
If FRP still active after reset make Userdata On and repeat operation
Wait...
Process Wipe...
Reading... Ok
Writing... Ok
Process FRP...
Looking for items... 1 items found
[1] Writing... Ok
Process nvram...
[17] Format... Ok
[18] Format... Ok
Completed
Finished 15 sec
Reboot... Disconnect cable if it freez
CMD 0x05 return 0x8E PHONE_WAIT_INPUT_TIMEOUT
Bye
The Following 3 Users Say Thank You to lalit bisht For This Useful Post:
Old 08-23-2024, 17:44   #76293 (permalink)
Member: 1797183
Thanks Meter: 153
Samsung A045M, Knox Guard (KG): Reset to Disabled... Ok
Wait...
S/N: 038B9B6F84 v0162
CM2 - MT2 Service Tool v2.64
Build directories tree... Ok
Firmware files: E:\Xiaomi\POCO M3 PRO MTK\camellian_global_images_V13.0.2.0.SKSMIXM_2022 0506.0000.00_12.0_global_bccb2c1e16\camellian_glob al_images_V13.0.2.0.SKSMIXM_20220506.0000.00_12.0_ global\
Backup files: C:\InfinityBox\CM2MT2\backup\
Compact backup files...
Backup files: 417 dirs: 28
Verify device database... BuiltIn: 28 Custom: 0
Load IDBase v915508 Ok
Load 149 profiles... Ok
libusb: v1.2.7.3
Init environment... Ok
Ready
Operation: Identify [ v2.64 ]
Wait...
Connection: Boot [DA] Factory
Port: Both [ B + P ]; High-Speed: On
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
- Power device Off [remember Test-Point]
PTFN: MediaTek PreLoader USB VCOM (Android) (COM106)
MODE [0]: PRELOADER PORT; PORT: 106
Waiting for BOOT ACK...
BROM: Init... Ok
CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766
CODE: Cervino
TYPE: MODERN [RAPHAEL]
BROM: Sec Level: 0x00000005 Mode: SBC+SDA
VER: 0xFF BL: 0x03 [PRELOADER PORT]
SOCID: E3B8C0008E34199DDA5AD328CA28D6085ACBBAF16430DA54B2 8D7C71842547A5
Agent:
[07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin
Looking for bootchain in DA...
Found: MT6765; DA: MTK_DOWNLOAD_AGENT
BROM: Sending 1st DA...
Reset Interface
PTFN: MediaTek USB Port (COM120)
MODE [0]: BOOTROM; PORT: 120
BROM: Init... Ok
CODE: Cervino
MEID: 13502D4435578D75A994C0AADAD1FA36
BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT
VER: 0x05 BL: 0xFE [BOOTROM]
SLA: Local Auth [Forced mode]
Start Auth... Ok
Continue Auth... Ok
FF: Looking for EMI Found
SLA: Start 0x15
Auth Passed; SEC: 0x000000E0
EMI loaded by MEID: 13502D4435578D75A994C0AADAD1FA36
Agent:
DA sent
Jump to DA... Ok
Sync... Ok
DA started
DA SYNC Ok
MODE: BROM
EXT_RAM NOT initialized
EMMC
CID: 1501004450364442420084A4E46AA903 crc Ok
Vendor: Samsung OEM: 256 ID: 445036444242 [DP6DBB] PRV: 0x00
Serial: 2225398890 0x84A4E46A
MM/YY: 10/2022
EMI: FireFly preloader_s96616aa1.bin with 9 memory type(s)
1. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb
2. eMMC LP_DDR4X ID: 150100345836324D42 Samsung 4X62MB RAM: 3.00 Gb
3. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb
4. eMMC LP_DDR4X ID: 150100444336444D42 Samsung DC6DMB RAM: 4.00 Gb
5. eMMC LP_DDR4X ID: 150100445036444242 Samsung DP6DBB RAM: 4.00 Gb
6. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb
7. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb
8. eMMC LP_DDR4X ID: 13014E473243323133 Micron G2C213 RAM: 4.00 Gb
9. eMMC LP_DDR4X ID: 13014E473243323139 Micron G2C219 RAM: 4.00 Gb
Push EMI... EXT_RAM CFG Passed
Boot to 2nd DA...
2nd stage confirmed
DA SYNC Ok
Load HW info...
RAM: SRAM: 0x0003A000 [ 232.00 Kb ]
RAM: DRAM: 0x100000000 [ 4.00 Gb ]
EMMC
MM/YY: 10/2022
BOOT1: 0x00400000 [ 4.00 Mb ]
BOOT2: 0x00400000 [ 4.00 Mb ]
RPMB: 0x01000000 [ 16.00 Mb ]
USER: 0xE8F800000 [ 58.24 Gb ]
CODE: Cervino
RNID: A58569FA2273B8FFC944EA29D2BD00C9
USB: HIGH-SPEED
Boot done MODERN [RAPHAEL] 27 sec
Analyze PMT... Ok
Partition Table: PGPT [0x64] Records: 50
Loading... Ok
STORAGE Life Status: eMMC : OK
STORAGE OTP Status: NOT Enabled
STORAGE RPMB Status: eMMC : RPMB KEY PROGRAMMED [UNUSABLE]
Saved: C:\InfinityBox\CM2MT2\phdata\key.json
Probe boot... Ok 1 sec
Product Brand: samsung
Product Device: a04
Product Model: SM-A045M
Product Name: a04ub
SW: samsung/a04ub/a04:12/SP1A.210812.016/A045MUBS4CXA1:user/release-keys
Patch Level: SP1A.210812.016
Display ID: SP1A.210812.016.A045MUBS4CXA1
SW Version: A045MUBS4CXA1
Ver. CodeName: REL
Ver. Release: 12
Sec. Patch: 2023-12-01
Build Time: 11-01-2024 18:33:55
Product Info: a04
SW: a04ub-user 12 SP1A.210812.016 A045MUBS4CXA1 release-keys
Product Manfct: samsung
Product Board: a04
Board Platform: mt6765
Device ID: a04-samsung-sm-a045m-a04ub
Strategy: [samsung]
Firmware ID: MT6765_samsung_SM-A045M_OSv12_SP1A.210812.016.A045MUBS4CXA1_SP1A.210 812.016_a04
Verify firmware [MT6765_samsung_SM-A045M_OSv12_SP1A.210812.016.A045MUBS4CXA1_SP1A.210 812.016_a04]... Firmware is unknown
Please upload https://infinity-box.com/?r=100020
Analyze userdata...
Load userdata header... Ok
userData: encryptable
Backup to C:\InfinityBox\CM2MT2\backup\MT6765__13502D4435578 D75A994C0AADAD1FA36\
Items to check: 22
Read [5] NVRAM
NVRAM: Items: 0xA6 Size: 0x08C36B State: Ok
WiFi MAC: AA006E742F76
BT MAC: BC52742E44A9
IMEI[1]: E2B064CA00B7F51
IMEI[2]: 4782E9CA0A98C6C
Read [26] NVDATA
Read [32] PROINFO
Read [12] LK
lk [d1641081]
Read [25] NVCFG
Read [16] PROTECT1
Read [1] PGPT
Read [37] PERSIST
Read [0] PRELOADER
Read [2] EFS
Read [3] SEC_EFS
Read [31] PERSISTENT
Done 12 files 16 sec
Compress: C:\InfinityBox\CM2MT2\backup\MT6765__13502D4435578 D75A994C0AADAD1FA36\
Cleanup...
Ok
Verify C:\InfinityBox\CM2MT2\backup\MT6765__13502D4435578 D75A994C0AADAD1FA36.7z Verified
Analyze modem...
TITAN_A04_R0MP1_K65V1_64_BSP_MDBIN_PCB01_MT6765_S0 0.MOLY_LR12A_R3_TC10_6M_PR_A04_SP_V1_P40
Analyze nvram...
PSN1: 73313EAC001JW
EMMC
MM/YY: 10/2022
Secondary RPMB... Off
Analyze preloader...
EMI: MT6765 preloader_s96616aa1.bin with 9 memory type(s)
Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_s 96616aa1.bin
Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_s 96616aa1.bin [9b260b41]... Exist
Probe FRP... Most probably On
Finished 1 min 15 sec
Keep connection
Operation: Reset Settings/Format FS [ v2.64 ]
[+] Smart Analyzer
[+] Wipe
[+] Userdata
[+] FRP
[+] Accounts
Wait...
Analyze PMT... Ok
Product Device: a04
Product Name: a04ub
Ver. CodeName: REL
Ver. Release: 12
Product Info: a04
Product Board: a04
Strategy: [samsung]
Android ver: 12
EMMC
MM/YY: 10/2022
Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__13502D4435578 D75A994C0AADAD1FA36
Stage: Android OS
[1] misc... Skip for Strategy [samsung]
[2] para... Skip for Strategy [samsung]
[3] userdata...
Create partition image... Ok Ok
[4] cache...
[6] metadata... Ok
[7] md_udc... Ok
Stage: FRP...
[1] frp... Ok
[1] verify 128.00 Kb... Ok 1 items found
[1] Process...
Done
Stage: Smart... Ok
Stage: Accounts... Knox Guard (KG)
file: C:\InfinityBox\CM2MT2\backup\MT6765__13502D4435578 D75A994C0AADAD1FA36\rpmb.bin
Reading...
Ok
Finished 1 min 42 sec
Keep connection
Old 08-23-2024, 17:57   #76294 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,778
QMOBILE I10 RESET FRP DONE BY CM2
Card found : 73CA70CC , v0161
Operation : Format FS / Reset Settings [ v2.14 ]
Mode : Default [ Reset Settings + FRP ]
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0002
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Reconnect Power/Cable!
Done!
Elapsed: 00:00:18
The Following User Says Thank You to A.G.Shahid For This Useful Post:
Old 08-24-2024, 11:38   #76295 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 3,003
TECNO-PR651 Frp
Product Brand  : TECNO
Product Device : PR651
Product Model  : TECNO PR651
Product Name   : PR651
Display ID     : PR651-F6317-11.0-OP-V84-20230323
Ver. Incmt     : OP-V84-20230323
Ver. CodeName  : REL
Ver. Release   : 11
Sec. Patch     : 2023-03-05
Build Time     : 23.03.2023
Product Name   : F6317
Product Device : TECNO-PR651
Product Info   : PR651
Product Board  : PR651
Board Platform : sp9863a
Product Manfct : TECNO
IMEI[1] :
IMEI[2] :
IMEI[3] :
SEC : SLS:0, SKS:0, SKV:4
Platform Version: MOCORTM_20A_W22.14.4_P2_Debug
Project Version:   sharkl3_pub
BASE  Version:    4G_MODEM_20A_W22.14.4_P2
HW Version:        sc9863A_modem
CMP_Time : 06-07-2022 12:07:05
MODEM TAG : MOCORTM_20A_W22.14.4_P2_Debug_4G_MODEM_20A_W22.14.4_P2_sc9863A_modem_sharkl3_pub
Done!
Elapsed: 00:00:50
Mode : Reset FRP
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : TECNO : PR651
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0020
FDL : RAW : 0x0002
FDL : SEC : RSA auth required!
FDL : Process authentification ...
FDL : SEC : RSA auth passed!
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:00:18
Old 08-24-2024, 19:29   #76296 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 3,003
OPPO CPH1923 Format & Frp
Operation: Reset Settings/Format FS [ v2.52 ]
Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X
[-] Wipe
[+] Userdata
[+] FRP
[+] Smart
Wait...
1. Power Off the device
2. Wait 20 seconds
3. Connect USB cable to device [remember Vol+ | Vol-]
Waiting for device connection...
PTFN: MTK USB Port (COM28)
MODE [0]: BOOTROM; PORT: 28
BROM: Init... Ok
  CODE: Cervino
  MEID: 4822CF84E65577A873DC689D697DE29A
  SOCID: B824A58944C2448938BE730997A582E1CEA557999575CFFCB4D59B4F61BA30D8
  Start Auth... Ok
  Continue Auth... Ok
SLA: Start 0x15
EMI loaded by MEID: 4822CF84E65577A873DC689D697DE29A
AGENT: AUTO: 0_base: base_v2316
  [1d5fdec4] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin
Looking for suitable BootChain in DA...
  DA sent
Jump to DA... Ok
Sync... Ok
DA: Agent Started
DA: SYNC
  MODE: BROM
EMMC CID: 150100514436334D4203E829906F865D crc Ok
  Ven: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03
  SNN: 3895038063 [0xE829906F]
  MM/YY: 8/2019
EMI: FireFly preloader_oppo6762_18540.bin with 9 memory type(s)
  1. eMMC DDR3 ID: 150100515836334142   Samsung   QX63AB RAM: 2.00 Gb
  2. eMMC DDR3 ID: 90014A68423861503E   Hynix     hB8aP> RAM: 3.00 Gb
  3. eMMC DDR3 ID: 90014A484147346132   Hynix     HAG4a2 RAM: 2.00 Gb
  4. eMMC DDR3 ID: 13014E53304A394237   Micron    S0J9B7 RAM: 3.00 Gb
  5. eMMC DDR3 ID: 150100514536334D42   Samsung   QE63MB RAM: 2.00 Gb
  6. eMMC LP_DDR4X ID: 90014A484347386134   Hynix     HCG8a4 RAM: 4.00 Gb
  7. eMMC DDR3 ID: 150100524436344D42   Samsung   RD64MB RAM: 4.00 Gb
  8. eMMC DDR3 ID: 150100514436334D42   Samsung   QD63MB RAM: 2.00 Gb
  9. eMMC DDR3 ID: 150100474436424D42   Samsung   GD6BMB RAM: 3.00 Gb
DA: Boot to 2nd DA...
  2nd stage confirmed
DA: SYNC Ok
Load HW info...
RAM: DRAM: 0x80000000 [ 2.00 Gb ]
  MM/YY: 8/2019
  USER: 0x747C00000 [ 29.12 Gb ]
  CODE: Cervino
  RNID: F6B14B413E56A53936A3670C8CA6CB75
USB: HIGH-SPEED
Analyze PMT... Ok
PMT: PGPT [0x64] Records: 42
Select info source... recovery [2000000] Ok
  Patch Level: PPR1.180610.011
  Ver. CodeName: REL
  Ver. Release: 9
  Sec. Patch: 2021-05-05
  CPU: arm64-v8a
  Product Manfct: OPPO
  SW: full_oppo6762_18540-user 9 PPR1.180610.011 eng.root.20210506.165532 release-keys
  Build Time: 06/05/2021 9:00:08 am
  SW Version: 1620291608
  Product Brand: OPPO
  Product Model: CPH1923
  Product Info: CPH1923
  Product Name: CPH1923
  Product Device: OP486C
  SW OTA Version: CPH1923EX_11.A.40_0400_202105061633
  Display ID: CPH1923EX_11_A.40
  Kernel Info: 4.9.117
Strategy: [oppo]
SmartInfo: Android Ver: 9 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+]
Verify config values...
Ok
Loaders Ok
Stage: Android OS
[1] ...
Create image... Ok Ok
[2] ...
[4] USERDATA... Ok
Stage: FRP...
[1] PROTECTION...
Done
Stage: Smart...
region-lock looks like On
Reset? No
Reset port...
Trying to reboot...
Done: 00:00:40
Reconnect Power/Cable now
Old 08-25-2024, 07:48   #76297 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,778
QMOBILE N230 RESET PASSWORD DONE BY CM2
Card found : S/N : 73CA70CC , v0161
Operation : Reset UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 8 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 8D2D47FE66FE7FA3148B81D0369B619F
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:13
Old 08-25-2024, 10:09   #76298 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,433
Smile Xiaomi Redmi A2+
Operation: Reset Settings/Format FS [ v2.63 ]
[+] Smart Analyzer
[-] Wipe
[+] Userdata
[+] FRP
[-] Accounts
Wait...
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
PTFN: MediaTek USB Port_V1632 (COM6)
MODE [0]: BOOTROM; PORT: 6
BROM: Init... Ok
CODE: Cervino
MEID: 73CF42CAC3BD61EB97E378F53B2B1282
BROM: Sec Level: 0x000000E7 Mode: SBC+SLA+SDA+EXT
SOCID: C17DB9945B645E7FDDC423FB6C62E6A52896011DC52492C704 3B0443CC59E8FC
Start Auth... Ok
Continue Auth... Ok
SLA: Start 0x15
EMI loaded by MEID: 73CF42CAC3BD61EB97E378F53B2B1282
AGENT:
[42c76018] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.2022-04-10.3365c4d2.bin
[b307cb3a] C:\InfinityBox\CM2MT2\boot\Xiaomi\A1_A1+_A2_A2+_wa ter\preloader_water.bin
DA sent
Jump to DA... Ok
Sync... Ok
DA: Agent Started
DA: SYNC
MODE: BROM
EMMC
CID: 9B0100593053303634000BDA035F4A41 crc Ok
Vendor: Hynix OEM: 256 ID: 593053303634 [Y0S064] PRV: 0x00
Serial: 198837087 0x0BDA035F
MM/YY: 4/2023
EMI: Init via preloader_water.bin
EMI: MT6765 preloader_water.bin with 7 memory type(s)
1. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb
2. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb
3. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
4. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
5. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
6. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb
7. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
2nd stage confirmed
DA: SYNC Ok
Load HW info...
RAM: DRAM: 0xC0000000 [ 3.00 Gb ]
EMMC
MM/YY: 4/2023
USER: 0xE90000000 [ 58.25 Gb ]
CODE: Cervino
RNID: 40B82B9662892A33A507CB88F7FFF828
USB: HIGH-SPEED
HIGH-SPEED USB is Off
Boot done MODERN [RAPHAEL] 25 sec
Analyze PMT... Ok
PMT: PGPT [0x64] Records: 56
Get slot info... a
Probe boot... Ok 953 us
Product Brand: Redmi
Product Device: water
Product Model: water
Product Name: water_global
SW: Redmi/water_global/water:12/SP1A.210812.016/V14.0.14.0.TGOMIXM:user/release-keys
SW Version: V14.0.14.0.TGOMIXM
Ver. CodeName: REL
Ver. Release: 12
Sec. Patch: 2023-07-01
Build Time: 28-Jul-23 6:10:00 AM
Product Info: water
SW: vnd_water-user 12 SP1A.210812.016 V14.0.14.0.TGOMIXM release-keys
Product Manfct: Xiaomi
Product Board: water
Device ID: redmi-xiaomi-water-water-global
Strategy: [xiaomi]
Firmware ID: MT6765_Xiaomi_water_OSv12_V14.0.14.0.TGOMIXM_SP1A. 210812.016_water_Redmi
Android ver: 12
UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+]
EMMC
MM/YY: 4/2023
Verify config values... Ok
Backup to C:\InfinityBox\CM2MT2\backup\MT6765__73CF42CAC3BD6 1EB97E378F53B2B1282\
Items to check: 22
Read [24] NVRAM
NVRAM: Items: 0xB5 Size: 0x0AD804 [SecLv: Vendor Signed] State: Ok
WiFi MAC: 14993E801C7C
BT MAC: 14993E801C7D
Read [14] NVDATA
Read [22] PROINFO
Read [13] NVCFG
Read [17] PROTECT1
Read [1] PGPT
Read [20] PERSIST
Read [0] PRELOADER
Read [30] LK_A
lk [a85a51a1]
Read [44] LK_B
Done 10 files 15 sec
Compress: C:\InfinityBox\CM2MT2\backup\MT6765__73CF42CAC3BD6 1EB97E378F53B2B1282\
Cleanup...
Ok
Verify C:\InfinityBox\CM2MT2\backup\MT6765__73CF42CAC3BD6 1EB97E378F53B2B1282.7z Enough [redmi-xiaomi-water-water-global]
Stage: Android OS
[1] ...
[4] USERDATA... Ok
[5] USERDATA... Ok
Stage: FRP...
[1] PROTECTION... Ok Ok
Done
Stage: Smart... Nothing to-do
Reset port...
Trying to reboot...
Finished 1 min 2 sec
Old 08-25-2024, 11:35   #76299 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 3,003
Infinix-X609 Flash
Operation: Write Flash [ v2.52 ]
Wait...
[+] Re-Partition
[-] Checksum Verify
[+] Pre-Erase
[+] Check compatibility
[+] Backup
[-] FLASH ERASE
D:\China File\Inifinix\X609-H8025AB-OGo-200820V222\
  preloader_bsp_h8025.bin [ 115.81 Kb ] d7e92b3a
  lk-sign.img [ 332.54 Kb ] 0a184f1d
  boot-sign.img [ 6.59 Mb ] a432dfcd
  recovery-sign.img [ 10.14 Mb ]
  logo-sign.bin [ 1.02 Mb ] fadfe2cb
  odmdtbo-sign.img [ 48.54 Kb ] 2f32fb77
  vendor-sign.img [ 252.52 Mb ]
  tee-sign.img [ 163.29 Kb ] 4d69faa1
  secro-sign.img [ 148.54 Kb ] 3ceb90e7
  system-sign.img [ 1.15 Gb ]
  cache-sign.img [ 5.68 Mb ] e80cd613
  userdata-sign.img [ 72.88 Kb ] 971bd230
Files: 14; Total size: 0x5B103C28 [ 1.42 Gb ]
  Patch Level: O11019
  Display ID: X609-H8025AB-OGo-200820V222
  SW Version: AB-200820V222
  Ver. CodeName: REL
  Ver. Release: 8.1.0
  Sec. Patch: 2020-09-05
  Build Time: 20/08/2020 9:40:07 am
  Product Brand: Infinix
  Product Name: H8025
  Product Device: Infinix-X609
  Product Info: Infinix-X609
  Product Model: Infinix X609
  Product Manfct: INFINIX MOBILITY LIMITED
  SW: full_bsp_h8025-user 8.1.0 O11019 1597916422 release-keys
  Product Board: Infinix-X609
  Board Platform: mt6580
Firmware ID: MT6580_INFINIX_MOBILITY_LIMITED_Infinix_X609_OSv8.1.0_X609-H8025AB-OGo-200820V222_O11019_Infinix-X609
2. Wait 20 seconds
PTFN: MediaTek PreLoader USB VCOM (Android) (COM12)
MODE [0]: PRELOADER PORT; PORT: 12
BROM: Init... Ok
CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580
  TYPE: LEGACY  [MTK]
  VER: 0xFF BL: 0x01 [PRELOADER PORT]
AGENT: AUTO: 0_base: base_v1712
  [e600c7d1] C:\InfinityBox\CM2MT2\boot\0_base\base_v1712\MTK_AllInOne_DA.e600c7d1.bin
  [d7e92b3a] D:\China File\Inifinix\X609-H8025AB-OGo-200820V222\preloader_bsp_h8025.bin
Found: MT6580; DA: MTK_DOWNLOAD_AGENT
  Reset Interface
BROM: Init... Ok
  TYPE: LEGACY  [MTK]
  MEID: 4FED52A7DB1B9C493781A9BA61D2B61D
  Start Auth... Ok
  Continue Auth... Ok
SLA: Start 0x15
  Auth Passed; SEC: 0x00000001
EMI loaded by MEID: 4FED52A7DB1B9C493781A9BA61D2B61D
  DA sent
Jump to DA... Ok
Sync... Ok
DA: Agent Started
NAND: DEVICE NOT FOUND
EMMC: OK
  CID: 460001154D3236457B2903423BB593F2
DA v4.2.156
EMMC: OK
  CID: 150100464536324D4203297BF293B53B
DRAM: 0x00BC
EMI: Init via preloader_bsp_h8025.bin
EMI: MT6580 preloader_bsp_h8025.bin with 10 memory type(s)
  1. ID: 150100513732534D42   Samsung   Q72SMB RAM: 1.00 Gb
  2. ID: 90014A483847316505   Hynix     H8G1e RAM: 1.00 Gb
  3. ID: ADDE14A7424AAD       Unknown 0x00AD §BJ* RAM: 512.00 Mb
  4. ID: 150100464536324D42   Samsung   FE62MB RAM: 1.00 Gb
  5. ID: 700100454841454538   Kingston  EHAEE8 RAM: 1.00 Gb
  6. ID: 700100454838454434   Kingston  EH8ED4 RAM: 512.00 Mb
  7. ID: 150100464E36324D42   Samsung   FN62MB RAM: 1.00 Gb
  8. ID: 700100454838434434   Kingston  EH8CD4 RAM: 512.00 Mb
  9. ID: 150100464E58324D42   Samsung   FNX2MB RAM: 1.00 Gb
  10. ID: 700100464D41454538   Kingston  FMAEE8 RAM: 1.00 Gb
INIT: 0x00BC DRAM [ 0x00000000  [ 0 B ] ]
RAM: DRAM: 0x40000000 [ 1.00 Gb ]
DA: DRAM ready
Boot to 2nd DA... Ok
Load HW info...
EMMC CID: 150100464536324D4203297BF293B53B crc Ok
  Ven: Samsung OEM: 256 ID: 464536324D42 [FE62MB] PRV: 0x03
  SNN: 695988883 [0x297BF293]
  MM/YY: 11/2018
  RPMB: 0x00400000 [ 4.00 Mb ]
  USER: 0x3A3E00000 [ 14.56 Gb ]
RAM: SRAM: 0x00020000 [ 128.00 Kb ]
RAM: DRAM: 0x40000000 [ 1024.00 Mb ]
  TYPE: LEGACY  [MTK]
  RNID: 1863C38423A50B437627E553C2867C4C
DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT
USB: FULL-SPEED
Set port Speed...
  PTFN: MediaTek DA USB VCOM (Android) (COM34)
  MODE: PRELOADER PORT; PORT: 34
Boot done LEGACY  [MTK]
HW verification... Ok
Analyze PMT... Ok
PMT: LGPT [0x06] Records: 31
Ok
Loaders Ok
Pre-Flash backup...
Backup to C:\InfinityBox\CM2MT2\backup\MT6580__4FED52A7DB1B9C493781A9BA61D2B61D\
Items to check: 22
Read [3] NVRAM
Read [20] NVDATA
Read [2] PROINFO
Read [8] LK
Read [4] PROTECT1
lda-pt: pgpt
Read [6] PERSIST
Read [0] PRELOADER
Done 7 files
Compress: C:\InfinityBox\CM2MT2\backup\MT6580__4FED52A7DB1B9C493781A9BA61D2B61D\
Cleanup...
Ok
Verify C:\InfinityBox\CM2MT2\backup\MT6580__4FED52A7DB1B9C493781A9BA61D2B61D.7z
Verified
Verify PMT... Ok
Verify SEC DL...
SEC DL: On [CUST]
SEC_DL: SECURE USB DL ENABLED
SEC ID: 0x63616334633434326462376361623562
Pre-Erase...
Erase: 0x0000000000000000 0x0000000000080000
Erase: 0x0000000004CC0000 0x00000000F0B40000
RePartition... Ok
SecInit...
SecInit: LK
SecInit: LK2
SecInit: BOOT
SecInit: RECOVERY
SecInit: LOGO
SecInit: ODMDTBO
SecInit: VENDOR
SecInit: TEE1
SecInit: TEE2
SecInit: SECRO
SecInit: SYSTEM
SecInit: CACHE
SecInit: USERDATA
Finished
Flash write...
Write: PRELOADER [ 115.81 Kb ]
Update bootloader code... Ok
Write: LK [ 332.54 Kb ] Ok
Write: LK2 [ 332.54 Kb ] Ok
Write: BOOT [ 6.59 Mb ] Ok
Write: RECOVERY [ 10.14 Mb ] Ok
Write: LOGO [ 1.02 Mb ] Ok
Write: ODMDTBO [ 48.54 Kb ] Ok
Write: VENDOR [ 252.52 Mb ] Ok
Write: TEE1 [ 163.29 Kb ] Ok
Write: TEE2 [ 163.29 Kb ] Ok
Write: SECRO [ 148.54 Kb ] Ok
Write: SYSTEM [ 1.15 Gb ] Ok
Write: CACHE [ 5.68 Mb ] Ok
Write: USERDATA [ 72.88 Kb ] Ok
SEC DL: Write...
SEC DL: OK
SEC DL: On [CUST]
RePartition... Ok
Reset port...
Done: 00:03:09
Old 08-25-2024, 12:45   #76300 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 3,003
TECNO-CG6j Frp
  Product Brand: TECNO
  Product Device: TECNO-CG6j
  Product Model: TECNO CG6j
  Product Name: CG6j-OP
  SW: TECNO/CG6j-OP/TECNO-CG6j:12/SP1A.210812.016/230420V1000:user/release-keys
  Display ID: CG6j-H696XYZAuBdBe-S-OP-230420V1000
  SW Version: 230420V1000
  Ver. CodeName: REL
  Ver. Release: 12
  Sec. Patch: 2023-04-05
  Build Time: 20/04/2023 1:01:00 pm
  Product Info: cg6j_h696
  SW: vnd_cg6j_h696-user 12 SP1A.210812.016 306496 release-keys
  Product Manfct: TECNO MOBILE LIMITED
  Product Board: TECNO-CG6j
  Board Platform: mt6768
Strategy: [none|generic]
Firmware ID: MT6768_TECNO_MOBILE_LIMITED_TECNO_CG6j_OSv12_CG6j-H696XYZAuBdBe-S-OP-230420V1000_SP1A.210812.016_cg6j_h696
Verify firmware [MT6768_TECNO_MOBILE_LIMITED_TECNO_CG6j_OSv12_CG6j-H696XYZAuBdBe-S-OP-230420V1000_SP1A.210812.016_cg6j_h696]...
Firmware is unknown
Analyze userdata...
userData: fileSystem : [f2fs]  with FBE [file based encryption]
Analyze modem... Nothing
Analyze nvram...
NVRAM: Items: 0xB8 Size: 0x122373 State: Ok
  WiFi MAC: 58356B3C4010
  BlTh MAC: 58356B3C400F
  IMEI[1]:
  IMEI[2]:
Ok
Loaders Ok
STORAGE OTP Status: UNLOCKED
STORAGE RPMB Status: eMMC : RPMB  KEY NOT PROGRAMMED [USABLE]
Reset port...
Done: 00:00:33
[-] Wipe
[-] Userdata
[+] FRP
[-] Smart
Wait...
2. Wait 20 seconds
BROM: Init... Ok
CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707
  CODE: Talbot
  MEID: 8002A75C87458E92143C7E3B68F6DB1A
  SOCID: A296766F9265B3F986C19C5B439812F56D51901D1461F6FB877A2E1CCE2473F7
  Start Auth... Ok
  Continue Auth... Ok
EMI known
SLA: Start 0x15
EMI loaded by MEID: 8002A75C87458E92143C7E3B68F6DB1A
Found: MT6768; DA: MTK_DOWNLOAD_AGENT
  DA sent
Jump to DA... Ok
Sync... Ok
DA: Agent Started
DA: SYNC
  MODE: BROM
EMMC CID: 15010033563643414202F9F9D0DE3889 crc Ok
  Ven: Samsung OEM: 256 ID: 335636434142 [3V6CAB] PRV: 0x02
  SNN: 4193898718 [0xF9F9D0DE]
  MM/YY: 3/2021
EMI: FireFly preloader_cg6j_h696.bin with 18 memory type(s)
  3. eMMC LP_DDR4X ID: 90014A684445615033   Hynix     hDEaP3 RAM: 6.00 Gb
  4. eMMC LP_DDR4X ID: 90014A68433861503E   Hynix     hC8aP> RAM: 3.00 Gb
  5. eMMC LP_DDR4X ID: 90014A684339615033   Hynix     hC9aP3 RAM: 4.00 Gb
  6. eMMC LP_DDR4X ID: 13014E53304A394B39   Micron    S0J9K9 RAM: 4.00 Gb
  7. eMMC LP_DDR4X ID: 150100445036384D42   Samsung   DP68MB RAM: 3.00 Gb
  8. eMMC LP_DDR4X ID: 150100444836444142   Samsung   DH6DAB RAM: 4.00 Gb
  9. eMMC LP_DDR4X ID: 150100334836434142   Samsung   3H6CAB RAM: 6.00 Gb
  10. eMMC LP_DDR4X ID: 150100445636444142   Samsung   DV6DAB RAM: 4.00 Gb
  11. eMMC LP_DDR4X ID: 150100445036444142   Samsung   DP6DAB RAM: 4.00 Gb
  12. eMMC LP_DDR4X ID: 13014E47314A395339   Micron    G1J9S9 RAM: 4.00 Gb
  13. eMMC LP_DDR4X ID: 150100335636434D42   Samsung   3V6CMB RAM: 6.00 Gb
  14. eMMC LP_DDR4X ID: 150100335636434142   Samsung   3V6CAB RAM: 6.00 Gb
  15. eMMC LP_DDR4X ID: 150100445636444D42   Samsung   DV6DMB RAM: 4.00 Gb
  16. eMMC LP_DDR4X ID: 150100335636434242   Samsung   3V6CBB RAM: 6.00 Gb
  17. DRAM LP_DDR4X ID: NOT_DEFINED          Unknown 0x0000  RAM: 8.00 Gb
  18. DRAM LP_DDR4X ID: NOT_DEFINED          Unknown 0x0000  RAM: 8.00 Gb
  2nd stage confirmed
DA: SYNC Ok
Load HW info...
RAM: SRAM: 0x00070000 [ 448.00 Kb ]
  MM/YY: 3/2021
  USER: 0x1D1EC00000 [ 116.48 Gb ]
CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707
  CODE: Talbot
  RNID: 82666B5ACED8B12CFFEFEDDD40B65EA1
USB: HIGH-SPEED
Analyze PMT... Ok
PMT: PGPT [0x64] Records: 51
Ok
Loaders Ok
Stage: Android OS Off
Stage: FRP...
[1] PROTECTION...
Done
Reset port...
Trying to reboot...
Done: 00:00:20
Old 08-26-2024, 12:13   #76301 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 3,003
Vivo V2111 Format & Frp
Operation: Reset Settings/Format FS [ v2.54 ]
[-] Wipe
[+] Userdata
[+] FRP
[+] Smart
Wait...
PTFN: MediaTek USB Port (COM22)
MODE [0]: BOOTROM; PORT: 22
BROM: Init... Ok
  CODE: Cervino
  MEID: B9055836E9067C31DEC9BA16C4C618BB
BROM: Sec Level: 0x00000000 Mode: PLAIN
  SOCID: 24FBA7ACC47A4F1FA963937AC8317C3D29027963ED93CF2A33F14FE7BAB8A2CB
BROM: EMI: Search
  EMI: Continue libusb exec warn conn enum v1.2.7.3 0x25
  EMI: Not found
AGENT: AUTO: Vivo: 2022-12
  [7c77dd2d] C:\InfinityBox\CM2MT2\boot\Vivo\2022-12\MTK_AllInOne_DA_2.bin
Looking for suitable bootchain in DA...
  DA sent
Jump to DA... Ok
Sync... Ok
DA: Agent Started
DA: SYNC
  MODE: BROM
EMMC
CID: 1501004450364441420327D268F7A7A3 crc Ok
  Vendor: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x03
  Serial: 668100855 0x27D268F7
  MM/YY: 10/2020
EMI[0]: Init via internal database
EMI: INFINITY PRELOADER_INFINITY_0 with 2 memory type(s)
  2nd stage confirmed
DA: SYNC Ok
Load HW info...
EMMC
  MM/YY: 10/2020
  CODE: Cervino
  RNID: 1F7722225FA6751D42C7071B4E3D2041
USB: HIGH-SPEED
Analyze PMT... Ok
PMT: PGPT [0x64] Records: 45
Select info source... [recovery] Ok
  SW: vivo/2111N/2111:11/RP1A.200720.012/compiler0820230021:user/release-keys
  Product Brand: vivo
  Product Device: 2111
  Product Model: V2111
  Product Name: 2111N
  Patch Level: RP1A.200720.012
  Display ID: RP1A.200720.012 release-keys
  Product Info: k65v1_64_bsp
  SW: full_k65v1_64_bsp-user 11 RP1A.200720.012 eng.compil.20210820.230249 release-keys
  SW Version: eng.compil.20210820.230249
  Ver. CodeName: REL
  Ver. Release: 11
  Sec. Patch: 2021-08-01
  Build Time: 20/08/2021 3:00:21 pm
  CPU: arm64-v8a
  Product Board: k65v1_64_bsp
  Product Manfct: vivo
Device ID: vivo-v2111-2111n-k65v1-64-bsp
Strategy: [vivo]
Firmware ID: MT6765_vivo_V2111_OSv11_RP1A.200720.012_k65v1_64_bsp
SmartInfo: Android Ver: 11 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+]
EMMC
  MM/YY: 10/2020
Backup to C:\InfinityBox\CM2MT2\backup\MT6765__B9055836E9067C31DEC9BA16C4C618BB\
Items to check: 22
Read [33] NVRAM
Read [10] NVDATA
Read [23] PROINFO
ZERO CONTENT file [3.00 Mb] deleted: C:\InfinityBox\CM2MT2\backup\MT6765__B9055836E9067C31DEC9BA16C4C618BB\proinfo.bin
Read [34] LK
Read [9] NVCFG
Read [18] PROTECT1
Read [1] PGPT
Read [21] PERSIST
Read [0] PRELOADER
Done 8 files
Compress: C:\InfinityBox\CM2MT2\backup\MT6765__B9055836E9067C31DEC9BA16C4C618BB\
Cleanup...
Ok
Stage: Android OS
[1] ...
[2] ...
[4] USERDATA... Ok
Stage: FRP...
Done
Stage: Smart... Ok
Reset port...
Trying to reboot...
Done: 1 min 2 sec
Old 08-26-2024, 16:34   #76302 (permalink)
Member: 1100570
Thanks Meter: 23
Motorola XT2333-5 G23 FRP done by CM2
Wait...
S/N: 0047C6XXXX v0162
Firmware files: C:\Users\shani\Desktop\
Backup files: 103 dirs: 0
libusb: v1.2.7.3
Ready
Wait...
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
PTFN: MediaTek PreLoader USB VCOM (Android) (COM6)
MODE [0]: PRELOADER PORT; PORT: 6
BROM: Init... Ok
CODE: Talbot
SOCID: 9FD75834556B704F968D9BC1CEE232FA5A2A18F688A319E5C3 440A020E93EAC4
Agent:
Reset Interface
BROM: Init... Ok
CODE: Talbot
Agent:
DA send error: 0x00007024 SECURE BOOT: SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE!
PRELOADER Level: CORRECT DA required: PL/PL_CRYPTO/SWSEC
Request config values...
=> Try loaders:
1. [0656ff20] 0_base/base_v2112/mtk_allinone_da.2021-07-12
2. [3365c4d2] 0_base/base_v2216/mtk_allinone_da.2022-04-10
3. [caf6df7e] infinix/2023-05/mtk_allinone_da.2023-05-10
4. [ddce4fa3] infinix/g70[g80][g90]/mtk_allinone_da_g7xg8xg9x
5. [07fb00a6] MTK_AllInOne_DA.1d5fdec4.bin
6. [1d5fdec4] MTK_AllInOne_DA.bin
7. [917c6560] oppo/a31/mtk_allinone_da
read manual - https://infinity-box.com/?r=100189
Connection fault
Disconnect battery and cable
Be sure SoC drivers installed well
Change cable and USB port, do not use USB-hub
Select another base|model|DA
Finished 39 sec
DA: C:\Users\shani\Downloads\DA_PL_NO_CERT_V6.bin
Wait...
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
BROM: Init... Ok
CODE: Talbot
Agent:
[5839808b] C:\Users\shani\Downloads\DA_PL_NO_CERT_V6.bin
DA sent
Jump to DA... Ok
Sync... Ok
DA started
DA SYNC Ok
MODE: PRELOADER
EXT_RAM initialized
Boot to 2nd DA...
2nd stage confirmed
DA SYNC Ok
Load HW info...
EMMC
CID: D6010341334135363211C353692D8A09 crc Ok
Vendor: Foresee OEM: 259 ID: 413341353632 [A3A562] PRV: 0x11
Serial: 3277023533 0xC353692D
MM/YY: 8/2023
USER: 0x1CCF000000 [ 115.23 Gb ]
CODE: Talbot
RNID: 1EB70DCF4683546BBB71CB006505EA16
USB: HIGH-SPEED
Boot done MODERN [RAPHAEL] 22 sec
Analyze PMT... Ok
Partition Table: PGPT [0x64] Records: 65
Loading...
addr 0x0000; code 0xC0040001 UNSUPPORT OPERATION
addr 0x0000; code 0xC0040001 UNSUPPORT OPERATION Ok
Get slot info... none
Probe boot...
size 0x1000 addr 0x0000; code 0xC0040001 UNSUPPORT OPERATION
size 0x1000 addr 0x0000; code 0xC0040001 UNSUPPORT OPERATION AndroidInfo: vendor_boot_a;block read fail;boot_a;block read fail;vendor_boot_b;block read
fail;boot_b;block read fail; Finished 47 us
Probe core...
size 0x100000 addr 0x0000; code 0xC0040001 UNSUPPORT OPERATION
Skip FS 0x45000000 super Finished 47 us
Probe uboot...
size 0x200000 addr 0x0000; code 0xC0040001 UNSUPPORT OPERATION Finished 16 us
Probe items... Finished 15 us
If process will stop later - try with [SW info] Off
Firmware ID: MT6768
Analyze userdata...
userData: unknown
Backup to C:\InfinityBox\CM2MT2\backup\MT6768__7F754335A8889 F587C7857372ED72011\
Items to check: 22
Read [36] NVRAM
NVRAM: Items: 0xA4 Size: 0x128618 [SecLv: Vendor Signed] State: Ok
BT MAC: 50131D852290
IMEI[1]: EEE6D4DEBBA2E21
IMEI[2]: EF23D57C373369B
Read [18] NVDATA
Read [34] PROINFO
Read [17] NVCFG
Read [20] PROTECT1
Read [1] PGPT
Read [19] PERSIST
Read [0] PRELOADER
Read [28] LK_A
lk [1a382f48]
Read [57] LK_B
Done 10 files 9 sec
Compress: C:\InfinityBox\CM2MT2\backup\MT6768__7F754335A8889 F587C7857372ED72011\
Cleanup...
Ok
Verify C:\InfinityBox\CM2MT2\backup\MT6768__7F754335A8889 F587C7857372ED72011.7z Skip
Analyze nvram...
PSN1: ZY22J4B4FM
EMMC
MM/YY: 8/2023
Secondary RPMB...
size 0x100000 addr 0x0000; code 0xC0040001 UNSUPPORT OPERATION Off
EMI: MT6752 preloader_penangf.bin with 9 memory type(s)
2. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb
3. eMMC LP_DDR4X ID: 13014E473243323133 Micron G2C213 RAM: 4.00 Gb
4. eMMC LP_DDR4X ID: D60103534845414178 Foresee SHEAAx RAM: 4.00 Gb
6. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
7. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
9. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 8.00 Gb
Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_p enangf.bin
Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_p enangf.bin [d5bddf66]... Exist
Probe FRP... Off
Finished 51 sec
Keep connection
[+] Smart Analyzer
[-] Wipe
[-] Userdata
[+] FRP
[-] Accounts
If FRP still active after reset make [Userdata] On and repeat operation
Wait...
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
BROM: Init... Ok
CODE: Talbot
Agent:
DA sent
Jump to DA... Ok
Sync... Ok
DA started
DA SYNC Ok
MODE: PRELOADER
EXT_RAM initialized
Boot to 2nd DA...
2nd stage confirmed
DA SYNC Ok
Load HW info...
EMMC
MM/YY: 8/2023
CODE: Talbot
USB: HIGH-SPEED
Boot done MODERN [RAPHAEL] 47 sec
Analyze PMT... Ok
Probe boot...
Probe core...
Probe uboot...
size 0x200000 addr 0x0000; code 0xC0040001 UNSUPPORT OPERATION Finished 15 us
Probe items... Finished 0 us
Firmware ID: MT6768
Android ver: 12
EMMC
MM/YY: 8/2023
Backup exist: C:\InfinityBox\CM2MT2\backup\MT6768__7F754335A8889 F587C7857372ED72011
Stage: FRP...
[1] frp... Ok
Done
Finished 1 min 5 sec
Keep connection
The Following 3 Users Say Thank You to shaniufs For This Useful Post:
Old 08-27-2024, 11:51   #76303 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 3,003
itel-L6502 Frp
Product Brand  : Itel
Product Device : L6502
Product Model  : itel L6502
Product Name   : L6502
Patch Level    : QP1A.190711.020
Display ID     : L6502-F3208-10.0-IN-V59-20221025
Ver. Incmt     : IN-V59-20221025
Ver. CodeName  : REL
Ver. Release   : 10
Sec. Patch     : 2022-10-05
Build Time     : 25.10.2022
Product Name   : F3208
Product Device : itel-L6502
Product Info   : L6502
Product Board  : L6502
Product Manfct : itel
IMEI[1] :
IMEI[2] :
IMEI[3] :
WIFIMAC : FFFFFFFFFFFF
BT_MAC  : FFFFFFFFFFFF
Platform Version: MOCORTM_18A_ITELQ_W22.24.3_Debug
Project Version:   sharkle_Smart_Phone
BASE  Version:    FM_BASE_18A_ITELQ_W22.24.3
CMP_Time : 06-15-2022 05:30:26
MODEM TAG : MOCORTM_18A_ITELQ_W22.24.3_Debug_FM_BASE_18A_ITELQ_W22.24.3_sc9832e_modem_sharkle_Smart_Phone
USERDATA : FILESYSTEM : F2FS  with FDE ( Full Disk Encryption ***)
Done!
Elapsed: 00:00:51
Mode : Reset FRP
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : Itel : itel-L6502-vision-1-pro.4c90559d.7f01f5cc
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0008
FDL : RAW : 0x0002
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:00:18
Old 08-28-2024, 14:10   #76304 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Infinix-X650
[+] Smart Analyzer
[-] Wipe
[+] Userdata
[+] FRP
[-] Accounts
Wait...
Connection: Boot [FF] FireFly
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
PTFN: MediaTek USB Port_V1632 (COM14)
MODE [0]: BOOTROM; PORT: 14
BROM: Init... Ok
TYPE: LEGACY [MTK]
MEID: 830599582FA848FA3867DEADA20EA8F1
FireFly: Init
Start Auth... Ok
Continue Auth... Ok
Start... Ok
Init Core... Ok
FireFly: Running: v06.05.06 on MT6580
EMMC init passed
extcsd stored: C:\InfinityBox\CM2MT2\backup\ext_csd\MT6580__extcs d_0070-Kingston_FMBCEA_5.1_2024-08-28.bin
EMMC
CID: 700100464D42434541202E9DE245C633 crc Ok
Vendor: Kingston OEM: 256 ID: 464D42434541 [FMBCEA] PRV: 0x20
Serial: 782099013 0x2E9DE245
MM/YY: 12/2019
USER: 0x74A000000 [ 29.16 Gb ]
CSD: D04F01320F5903FFFFFFFFEF8A400061
EXTCSD rev1.8 EMMC 5.1 FW: 23
PARTITION_CONFIG: 0x48
BOOT size: 0x400000
RPMB size: 0x400000 4.00 Mb
Size: Market 32 Gb Actual 0x74A000000 29.16 Gb
EOL_A: SLC status: 80% - 90% used
EOL_B: MLC status: 90% - 100% used
USB: HIGH-SPEED
Boot done FireFly 14 sec
Analyze PMT... Ok
Partition Table: PGPT [0x64] Records: 28
Probe boot... Ok 9 sec
Patch Level: O11019
Display ID: X650-H8029AB-OGo-210716V484
SW Version: AB-210716V484
Ver. CodeName: REL
Ver. Release: 8.1.0
Sec. Patch: 2021-07-05
Build Time: 16-Jul-21 9:10:32 AM
Product Name: H8029
Product Device: Infinix-X650
Product Info: Infinix-X650
Product Model: Infinix X650
SW: full_x650_h8029-user 8.1.0 O11019 1626426640 release-keys
Product Board: Infinix-X650
Device ID: infinix-mobility-limited-infinix-x650-h8029
Strategy: [infinix]
Firmware ID: MT6580_INFINIX_MOBILITY_LIMITED_Infinix_X650_OSv8. 1.0_X650-H8029AB-OGo-210716V484_O11019_Infinix-X650
Android ver: 8
EMMC
MM/YY: 12/2019
BOOT size: 0x400000
Backup to C:\InfinityBox\CM2MT2\backup\MT6580__830599582FA84 8FA3867DEADA20EA8F1\
Items to check: 22
Read [19] NVRAM
NVRAM: Items: 0x77 Size: 0x0297DE State: Ok
WiFi MAC: AA00656E646F
BT MAC: 80795D0ACC54
IMEI[1]: 353
IMEI[2]: 353
Read [13] NVDATA
Read [2] PROINFO
Read [15] LK
lk [6a657a48]
Read [9] PROTECT1
Read [1] PGPT
Read [11] PERSIST
Read [0] PRELOADER
Done 8 files 3 min 24 sec
Compress: C:\InfinityBox\CM2MT2\backup\MT6580__830599582FA84 8FA3867DEADA20EA8F1\
Cleanup...
Ok
Verify C:\InfinityBox\CM2MT2\backup\MT6580__830599582FA84 8FA3867DEADA20EA8F1.7z Enough [infinix-mobility-limited-infinix-x650-h8029]
Stage: Android OS
[1] userdata...
[2] cache...
[4] metadata... Ok
Stage: FRP...
[1] frp... Ok
Done
Reset port...
Trying to reboot...
Finished 4 min 15 sec
Old 08-29-2024, 05:38   #76305 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,309
PCD P63L network Unlock Done
Chinese Miracle II - MT2 Service Tool v2.64a7 (beta)
Operation: Identify [ v2.64a7 (beta) ]
Wait...
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM58)
MODE [0]: PRELOADER PORT; PORT: 58
BROM: Init... Ok
CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCC00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0699
CODE: Zion
SOCID: 107F220F79A700589BB4899639F80E5CE37C4D41B2ED21C5F9 4BA9B12DC10D0D
Agent:
Found: MT6739; DA: MTK_DOWNLOAD_AGENT
DA sent
Jump to DA... Ok
Sync... Ok
DA: Agent Started
DA: SYNC
MODE: PRELOADER
EXT_RAM initialized
2nd stage confirmed
DA: SYNC Ok
Load HW info...
EMMC
CID: 150100514531334D42072CE0AA6713E9 crc Ok
Vendor: Samsung OEM: 256 ID: 514531334D42 [QE13MB] PRV: 0x07
Serial: 752921191 0x2CE0AA67
MM/YY: 1/2016
CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCC00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699
CODE: Zion
RNID: 2705325B53674741B1444E155F8A0EAE
USB: HIGH-SPEED
Boot done MODERN [RAPHAEL] 1 min 11 sec
Analyze PMT... Ok
Partition Table: PGPT [0x64] Records: 39
Loading... Ok
Probe boot... Ok 484 us
Product Brand: PCD
Product Device: P63L
Product Model: P63L
Product Name: BENGAL
SW: PCD/BENGAL/P63L:12/SP1A.210812.016/1717575667:user/release-keys
Display ID: PCD_P63L_iWIRELESS_US_V3.4
SW Version: 1717575667
Ver. CodeName: REL
Ver. Release: 12
Sec. Patch: 2024-06-05
Build Time: 6/25/2024 10:09:19 AM
Product Info: k39tv1_bsp_1g_k419
SW: vnd_k39tv1_bsp_1g_k419-user 12 SP1A.210812.016 1717575667 release-keys
Product Manfct: PCD
Product Board: k39tv1_bsp_1g_k419
Board Platform: mt6739
Device ID: pcd-pcd-p63l-bengal-k39tv1-bsp-1g-k419
Firmware ID: MT6739_PCD_P63L_OSv12_PCD_P63L_iWIRELESS_US_V3.4_S P1A.210812.016_k39tv1_bsp_1g_k419
Verify firmware [MT6739_PCD_P63L_OSv12_PCD_P63L_iWIRELESS_US_V3.4_S P1A.210812.016_k39tv1_bsp_1g_k419]...
Firmware uploaded @ https://stock-rom.com
Analyze userdata...
Backup to C:\InfinityBox\CM2MT2\backup\MT6739__2705325B53674 741B1444E155F8A0EAE\
Items to check: 20
Read [26] NVRAM
NVRAM: Items: 0x9D Size: 0x08B7CF State: Ok
BT MAC: xxxxxxxx
IMEI[1]: xxxxxxxxxxxxxx
IMEI[2]: FFFFFFFFFFFFFFF
Read [11] NVDATA
Read [19] PROINFO
Read [27] LK
lk [805e6f46]
Read [10] NVCFG
Read [14] PROTECT1
Read [1] PGPT
Read [17] PERSIST
Read [0] PRELOADER
Done 9 files 5 sec
Compress: C:\InfinityBox\CM2MT2\backup\MT6739__2705325B53674 741B1444E155F8A0EAE\
Cleanup...
Ok
Verify C:\InfinityBox\CM2MT2\backup\MT6739__2705325B53674 741B1444E155F8A0EAE.7z Verified
Analyze modem...
TK_MD_BASIC_MDBIN_PCB01_MT6739_S00.MOLY_LR12A_R3_M P_V324
Analyze nvram...
PSN1: P6201B2310026447
EMMC
MM/YY: 1/2016
Secondary RPMB... On
EMI: MT6739 preloader_k39tv1_bsp_1g_k419.bin with 5 memory type(s)
1. eMMC DDR3 ID: D601004D4D43333247 Foresee MMC32G RAM: 2.00 Gb
2. eMMC DDR3 ID: 90014A484147346132 Hynix HAG4a2 RAM: 2.00 Gb
3. eMMC DDR3 ID: 150100514536334D42 Samsung QE63MB RAM: 2.00 Gb
4. eMMC DDR3 ID: 150100514531334D42 Samsung QE13MB RAM: 2.00 Gb
5. eMMC DDR3 ID: 150100513331334D42 Samsung Q313MB RAM: 2.00 Gb
Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 39tv1_bsp_1g_k419.bin
Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 39tv1_bsp_1g_k419.bin [1615de67]... Exist
Probe FRP... Most probably Off
Finished 1 min 32 sec
Keep connection
Operation: SP Unlock [ v2.64a7 (beta) ]
Wait...
Connection: META [SVC]
- Connect cable
MODE [1]: PRELOADER PORT; PORT: 58
META timeout: 16
Waiting for boot logo...
META [SVC] confirmed
Boot done 1 min 23 sec
AP_CHIP: MT6739
AP_SWTM: Tue Jun 25 17 41 16 CST 2024
AP_SWVR: alps-mp-s0.mp1-V16.29.1
Switch protocol...
MD_CHIP: MT6739
MD_SWTM: 2000.00.00
MD_DSPV: 1.0
MD_DSPP: MOLY.LR12A.R3.MP.V324
MD_SWVR: TK_MD_BASIC_HW
MD_HWVR: Unknown
IMEI[1]:
Lock[1] On; MNC: 2048; CNT: 255; Code: 20xxxxx
Lock[2] Off; MNC: 0; CNT: 5; Code: 56xxxx
Lock[3] On; MNC: 512; CNT: 5; Code: 20190501
Lock[4] Off; MNC: 0; CNT: 5; Code: 33334444
Lock[5] Off; MNC: 0; CNT: 5; Code: 55556666
Lock[6] Off; MNC: 0; CNT: 5; Code: 77778888
Lock[7] Off; MNC: 0; CNT: 5; Code: 99990000
Lock[1] On; MNC: 2048; CNT: 5; Code: 20190501
Lock[2] Off; MNC: 0; CNT: 5; Code: 56781234
Finished 1 min 46 sec
Keep connection
Operation: Reboot [ v2.64a7 (beta) ]
Finished 32 us
Keep connection
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.52897 seconds with 10 queries
