Old 10-17-2024, 15:51   #76411 (permalink)
Member: 233142
Sonork: 100.1595099
Thanks Meter: 535
Nokia 2.4 ta 1270 reset frp done
Operation: Identify [ v2.72 ]
Wait...
Connection: Boot [FF] FireFly
Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On
DA Key: custom; Local SLA: Off; Auto-EMI: On
Power device Off and connect cable now
Remember Volume Up/Down or Test-Point
Waiting for device...
PTFN: MediaTek USB Port (COM22)
MODE: BOOTROM; PORT: 22
Waiting for BOOT ACK...
BROM: Init... Ok
CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766
Code: Cervino
Type: MODERN [RAPHAEL]
MEID: A76D7128125992141B2465FEB8C755FE
BROM: Sec Level: 0x000000E7; Mode: SBC+SLA+SDA+EXT
Ver: 0x05 BL: 0xFE [BOOTROM]
SOCID: 31D02E192BF247708F498CB089AE992BA824F851CE032F92CD 12E98D6BCA9FB7
[FF] Init
Start Auth... Ok
Continue Auth... Ok
Start... Ok
Init Core... Ok
FireFly: Running: v06.05.06 on MT6765
EMMC init passed
extcsd stored: C:\InfinityBox\CM2MT2\backup\ext_csd\MT6765__extcs d_0088-Foresee_SLD64G_5.1_2024-10-17.bin
EMMC CID: 880103534C44363447551302D8231707 crc Ok
Vendor: Foresee OEM: 259 ID: 534C44363447 [SLD64G] PRV: 0x55
Serial: 318953507 0x1302D823
MM/YY: 1/2020
BOOT1: 0x00400000 [ 4.00 Mb ]
BOOT2: 0x00400000 [ 4.00 Mb ]
USER: 0xE67800000 [ 57.62 Gb ]
CSD: D0FFFF329F5903FFFFFFFFE79640001D
temp_write_protect: False
perm_write_protect: False
wp_group: 0x08 en 0x01
EXTCSD rev1.8 EMMC 5.1 FW: 020202
ERASE_GROUP_DEF: 0x0400
BOOT_BUS_WIDTH: 0x02
PARTITION_CONFIG: 0x48
RST_N_FUNCTION: 0x01
PART_S_COMPLETED: False
BOOT size: 0x400000
RPMB size: 0x400000 4.00 Mb
WP_GRP_SIZE: 0x400000 4.00 Mb
Size: Market 64 Gb Actual 0xE67800000 57.62 Gb
EOL: Status: Normal: Less than 80% reserved blocks used
EOL_A: SLC status: 10% - 20% used
EOL_B: MLC status: Not defined
Boot done MODERN [RAPHAEL] 55 sec
Analyze PMT... Ok
Partition table: PGPT [0x64] with 52 records
Get slot info... a
Probe boot... Finished 16 sec
AndroidInfo: boot_a;gzip;bootimage|loaded ramsidk size 0x9AE9C7|00;boot_b;gzip;bootimage|loaded ramsidk size 0x9AE9BC|00;
Probe core...
Mount[ext4] system_a@super 0x008EE07000/0x6371E000
Mount[ext4] system_b@super 0x019ED87000/0x6371E000
Mount[ext4] vendor_a@super 0x00F2525000/0x10DF9000
Mount[ext4] vendor_b@super 0x02024A5000/0x10DF8000
Mount[ext4] product_a@super 0x00315DB000/0x5D82C000
Mount[ext4] product_b@super 0x014155B000/0x5D82C000 Ok 20 sec
Product Brand: Nokia
Product Device: WVR_sprout
Product Model: Nokia 2.4
Product Name: Wolverine_00WW
SW: Nokia/Wolverine_00WW/WVR_sprout:12/SP1A.210812.016/00WW_3_47H:user/release-keys
Patch Level: SP1A.210812.016
Display ID: 00WW_3_47H
SW Version: 00WW_3_47H
Ver. CodeName: REL
Ver. Release: 12
Sec. Patch: 2023-10-01
Build Time: 10/10/2023 03:25:15
Product Model: 00WW
Product Info: Wolverine_00WW
Product Info: WVR_sprout
SW: full_T99651-user 12 SP1A.210812.016 00WW_3_47H release-keys
SW: Nokia/Wolverine_00WW/WVR_sprout:12/SP1A.210812.016/00WW_3_47G:user/release-keys
Display ID: 00WW_3_47G
SW Version: 00WW_3_47G
Sec. Patch: 2023-09-01
Build Time: 20/09/2023 10:22:09
SW: full_T99651-user 12 SP1A.210812.016 00WW_3_47G release-keys
Product Manfct: HMD Global
Product Board: MT6762
Board Platform: mt6765
Device ID: hmd-global-nokia-2.4-wvr-sprout-wolverine-00ww-mt6762
Strategy: [nokia]
Firmware ID: MT6765_HMD_Global_00WW_OSv12_00WW_3_47G_SP1A.21081 2.016_WVR_sprout_Nokia
Verify firmware [MT6765_HMD_Global_00WW_OSv12_00WW_3_47G_SP1A.21081 2.016_WVR_sprout_Nokia]... Socket Error # 11001
Host not found.
Analyze userdata...
Load userdata header... Ok
userData: plain
Backup 23 items to C:\InfinityBox\CM2MT2\backup\MT6765__A76D712812599 2141B2465FEB8C755FE\
Read [17] nvram Ok 49 sec
NVRAM seems as damaged, backup may be useless
Zero content file deleted: C:\InfinityBox\CM2MT2\backup\MT6765__A76D712812599 2141B2465FEB8C755FE\nvram.bin
Read [7] nvdata Ok 49 sec
Read [15] proinfo Ok 2 sec
Zero content file deleted: C:\InfinityBox\CM2MT2\backup\MT6765__A76D712812599 2141B2465FEB8C755FE\proinfo.bin
Read [6] nvcfg Ok 24 sec
Read [10] protect1 Ok 6 sec
Read [1] pgpt Ok 62 us
Read [13] persist Ok 36 sec
Read [0] preloader Ok 3 sec
Read [24] lk_a Ok 1 sec lk [056bda5a]
Read [39] lk_b Ok 827 us lk [c0890a3c]
Done 8 files 2 min 54 sec
Compress: C:\InfinityBox\CM2MT2\backup\MT6765__A76D712812599 2141B2465FEB8C755FE\ Ok
Verify C:\InfinityBox\CM2MT2\backup\MT6765__A76D712812599 2141B2465FEB8C755FE.7z Finished
get modem info... absent
Load nvram items...
PSN1: N/A
Secondary RPMB... Off
Analyze preloader...
EMI: MT6765 preloader_t99651.bin with 4 memory type(s)
1. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb
2. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb
3. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
4. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb
Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_t 99651.bin
Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_t 99651.bin [14d30ff4]... Finished
Probe FRP... Most probably Off
Probe bootloader... Seems as Unlocked
Reset port...
Finished 5 min 27 sec
Operation: Reset Settings/Format FS [ v2.72 ]
WARNING: Reset may delete ALL USER DATA!
Wipe On; Userdata On; FRP On; Accounts Off; Smart Analyzer On
Wait...
BROM: Init... Ok
Code: Cervino
[FF] Init
Start Auth... Ok
Continue Auth... Ok
Start... Ok
Init Core... Ok
EMMC init passed
File exist, skip: C:\InfinityBox\CM2MT2\backup\ext_csd\MT6765__extcs d_0088-Foresee_SLD64G_5.1_2024-10-17.bin
MM/YY: 1/2020
BOOT size: 0x400000
Boot done MODERN [RAPHAEL] 27 sec
Analyze PMT... Ok
Get slot info... a
Probe core...
Ver. CodeName: REL
Ver. Release: 12
Product Model: 00WW
Strategy: [nokia]
Android ver: 12
UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+]
Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__A76D712812599 2141B2465FEB8C755FE
Stage: Android OS
[2] para...
Wipe... Ok Ok
[3] userdata...
Create partition image...
Make filesystem [0x02 ext4|8+]... Ok Ok Ok
[6] metadata...
process [metadata]... Ok Ok
[7] md_udc...
process [md_udc]... Ok Ok
Stage: FRP...
process [frp]... Ok
Completed
Stage: Vendor... Noting for [nokia]
Reset port...
Trying to reboot...
Finished 1 min 21 sec
Old 10-18-2024, 07:43   #76412 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,778
Realme Narzo 50A Prime RMX3516 Reset FRP Done By CM2
Card found : 73CA70CC , v0161
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14
Load IDBase v8331 Ok!
Operation : Format FS / Reset Settings [ v2.14 ]
Mode : Default [ Reset Settings + FRP ]
BootMode : FLASH
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : Realme : RMX3581
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : 0x0020
FDL : RAW : 0x0002
FDL : FLH : 0x400000
FDL : Control transfered!
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Reconnect Power/Cable!
Done!
Elapsed: 00:00:17
Old 10-18-2024, 22:43   #76413 (permalink)
Member: 85718
Thanks Meter: 566
Tablet Mediapad K708 firmware read ok
Infinity-Box RockChip Service Tool [RKT] v2.02
Operation : Identify [ v2.02 ]
----- > Phone/Tablet :
1. Power Off device
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable! Press 'POWER_ON' button for a few second!
----- > IoT/Box :
1. Reset device power
2. PRESS and HOLD 'RESET' KEY!
3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second!
Wait for device ...
Device Connected!
Interface test : Passed
Device mode : 0x0006
SoC CPU : 3326
Flash CSx : 0x00
Flash Type : EMMC
Flash Vend : SAMSUNG
Flash Size : 0x0000000739800000 ( 28,90 GiB )
Flash Info : 524288/2048/40/0/1
Caps : 0x0015 : 0x0000
Connect Ok!
Done!
Elapsed: 00:00:30
Operation : Read Firmware [ v2.02 ]
1. Power Off device
----- > IoT/Box :
Wait for device ...
Device Connected!
SoC CPU : 3326
Flash CSx : 0x00
Flash Type : EMMC
Connect Ok!
Reading Flash Content ...
[Read Ok] : security.bin
[Read Ok] : uboot_a.bin
[Read Ok] : uboot_b.bin
[Read Ok] : trust_a.bin
[Read Ok] : trust_b.bin
[Read Ok] : misc.img
[Read Ok] : dtbo_a.bin
[Read Ok] : dtbo_b.bin
[Read Ok] : vbmeta_a.bin
[Read Ok] : vbmeta_b.bin
[Read Ok] : boot_a.bin
[Read Ok] : boot_b.bin
[Read Ok] : backup.img
[Read Ok] : baseparameter.bin
[Read Ok] : super.bin
Read finished!
Configuration : 3326 / EMMC
Firmware Size : 4,60 GiB
Done!
Elapsed: 00:10:06
The Following User Says Thank You to ct3im For This Useful Post:
Old 10-19-2024, 09:22   #76414 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,778
S/N: 0073CA70CC v0161
Chinese Miracle II - MT2 Service Tool v2.63
Init log engine...
Ok
Build directories tree...
Ok
Firmware files: C:\Users\Master Mobile\Desktop\New folder\
Backup files: C:\InfinityBox\CM2MT2\backup\
Backup files: 37 dirs: 0
Verify device database...
BuiltIn: 28 Custom: 0
Check for updates [CM2MT2]...
You have latest version [2.63] installed
Telegram Channel: @InfinityBox
Telegram Chat: @InfinityBoxTalks
Sales: https://infinity-box.com/buy/
Account: https://infinity-box.com/service/
Update configuration...
Configuration [12412] updated
Get list of devices...
Ok
Reloaded 2080 devices
Build device list...
Load IDBase v915508 Ok
Load 155 profiles...
Ok
libusb: v1.2.6.0
Init environment...
Ok
Ready
Operation: Identify [ v2.63 ]
Wait...
Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X
Port: Both [ B + P ]; High-Speed: On
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
- Power device Off [remember Test-Point]
- Connect cable
[remember Vol+ | Vol-]
PTFN: MediaTek USB Port_V1633 (COM4)
MODE [0]: BOOTROM; PORT: 4
BROM: Init...
Ok
CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707
CODE: Talbot
TYPE: MODERN [RAPHAEL]
MEID: C60EC12F4DFF93F891552C839E4C01CE
BROM: Sec Level: 0x000000E7 Mode: SBC+SLA+SDA+EXT
VER: 0x05 BL: 0xFE [BOOTROM]
SOCID: C7D074DD6DB8D1A4D29964271B6193020D7849536431CC4321 5AA1AC2DCAC424
SLA: Local Auth
[Forced mode]
Start Auth...
Ok
Continue Auth...
Ok
FF: Looking for EMI
Found
SLA: Start
0x15
Auth Passed; SEC: 0x000000E0
EMI loaded by MEID: C60EC12F4DFF93F891552C839E4C01CE
AGENT:
[07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin
Looking for bootchain in DA...
Found: MT6768; DA: MTK_DOWNLOAD_AGENT
BROM: Sending 1st DA...
DA sent
Jump to DA...
Ok
Sync...
Ok
DA: Agent Started
DA: SYNC
MODE: BROM
EXT_RAM NOT initialized
EMMC
CID: D62D004D4D43313238511B7F64587A47
crc Ok
Vendor: Foresee OEM: 11520 ID: 4D4D43313238 [MMC128] PRV: 0x51
Serial: 461333592 0x1B7F6458
MM/YY: 7/2023
EMI: FireFly preloader_earth.bin with 10 memory type(s)
2. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
3. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 6.00 Gb
4. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
5. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
6. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
7. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 6.00 Gb
8. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
9. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
10. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 6.00 Gb
Push EMI...
EXT_RAM CFG Passed
DA: Boot to 2nd DA...
2nd stage confirmed
DA: SYNC Ok
Load HW info...
RAM: SRAM: 0x00070000 [ 448.00 Kb ]
RAM: DRAM: 0x100000000 [ 4.00 Gb ]
EMMC
crc Ok
MM/YY: 7/2023
RPMB: 0x00400000 [ 4.00 Mb ]
USER: 0x1D1EC00000 [ 116.48 Gb ]
CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707
CODE: Talbot
RNID: 7D8780C9F04F174C2A343471F24C7F74
USB: HIGH-SPEED
HIGH-SPEED USB is Off
Boot done MODERN [RAPHAEL] 9 sec
Analyze PMT...
Ok
PMT: PGPT [0x64] Records: 58
STORAGE Life Status: eMMC : OK
STORAGE OTP Status: UNLOCKED
STORAGE RPMB Status: eMMC : RPMB KEY PROGRAMMED [UNUSABLE]
Saved: C:\InfinityBox\CM2MT2\phdata\key.json
Get slot info...
b
Probe boot...
Ok 1 sec
Product Brand: Redmi
Product Device: earth
Product Model: 22120RN86C
Product Name: vnd_earth
SW: Redmi/vnd_earth/earth:12/UP1A.231005.007/V816.0.5.0.UCVMIXM:user/release-keys
Patch Level: UP1A.231005.007
SW Version: V816.0.5.0.UCVMIXM
Ver. CodeName: REL
Ver. Release: 12
Sec. Patch: 2024-06-01
Build Time: 6/25/2024 4:00:58 AM
Product Info: earth
SW: vnd_earth-user 12 UP1A.231005.007 V816.0.5.0.UCVMIXM release-keys
Product Manfct: Xiaomi
Product Board: earth
Board Platform: mt6768
Device ID: redmi-xiaomi-22120rn86c-earth-vnd-earth
Strategy: [xiaomi]
Firmware ID: MT6768_Xiaomi_22120RN86C_OSv12_UP1A.231005.007_ear th_Redmi
Verify firmware [MT6768_Xiaomi_22120RN86C_OSv12_UP1A.231005.007_ear th_Redmi]...
Exist (1)
Analyze userdata...
userData: fileSystem : [f2fs] with FBE [file based encryption]
Backup to C:\InfinityBox\CM2MT2\backup\MT6768__C60EC12F4DFF9 3F891552C839E4C01CE\
Items to check: 22
Read [36] NVRAM
NVRAM: Items: 0xB5 Size: 0x0F44F9 [SecLv: Vendor Signed] State: Ok
WiFi MAC: AA006E742F76
BT MAC: 886C60B88865
IMEI[1]:
IMEI[2]:
Read [16] NVDATA
Read [33] PROINFO
Read [15] NVCFG
Read [19] PROTECT1
Read [1] PGPT
Read [17] PERSIST
Read [0] PRELOADER
Read [27] LK_A
lk [5605bab7]
Read [45] LK_B
Done 10 files 10 sec
Compress: C:\InfinityBox\CM2MT2\backup\MT6768__C60EC12F4DFF9 3F891552C839E4C01CE\
Cleanup...
Ok
Verify C:\InfinityBox\CM2MT2\backup\MT6768__C60EC12F4DFF9 3F891552C839E4C01CE.7z
Enough [redmi-xiaomi-22120rn86c-earth-vnd-earth]
Analyze modem...
Nothing
Analyze nvram...
PSN1: MB338W003809
EMMC
crc Ok
MM/YY: 7/2023
EMI: MT6752 preloader_earth.bin with 10 memory type(s)
Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_e arth.bin
Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_e arth.bin [a28dc949]...
Exist
Probe FRP...
Most probably Off
Analyze lk...
Verify config values...
Ok
Seems as Ok
Probe Mi Account...
status: off
Reset port...
Finished 55 sec
Operation: Reset Settings/Format FS [ v2.63 ]
[+] Smart Analyzer
[+] Wipe
[+] Userdata
[+] FRP
[-] Accounts
Wait...
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
- Connect cable
User break
Finished 6 sec
[+] Smart Analyzer
[+] Wipe
[+] Userdata
[+] FRP
[-] Accounts
Wait...
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
- Connect cable
BROM: Init...
Ok
CODE: Talbot
SLA: Local Auth
[Forced mode]
Start Auth...
Ok
Continue Auth...
Ok
EMI known
SLA: Start
0x15
AGENT:
DA sent
Jump to DA...
Ok
Sync...
Ok
DA: Agent Started
DA: SYNC
MODE: BROM
EMMC
crc Ok
MM/YY: 7/2023
Push EMI...
EXT_RAM CFG Passed
2nd stage confirmed
DA: SYNC Ok
Load HW info...
EMMC
crc Ok
MM/YY: 7/2023
CODE: Talbot
USB: HIGH-SPEED
Boot done MODERN [RAPHAEL] 10 sec
Analyze PMT...
Ok
Get slot info...
b
Probe boot...
Ok 1 sec
Ver. CodeName: REL
Ver. Release: 12
Product Info: earth
Strategy: [xiaomi]
Android ver: 12
UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+]
EMMC
crc Ok
MM/YY: 7/2023
Backup exist: C:\InfinityBox\CM2MT2\backup\MT6768__C60EC12F4DFF9 3F891552C839E4C01CE
Stage: Android OS
[1] WIPE...
Skip for Strategy [xiaomi]
[2] WIPE...
[3] WIPE...
Ok
Ok
[6] USERDATA...
Ok
[7] USERDATA...
Ok
Stage: FRP...
[1] PROTECTION...
Ok
Ok
Done
Stage: Smart...
Nothing to-do
Reset port...
Trying to reboot...
Finished 34 sec
Reconnect Power/Cable now
Old 10-19-2024, 12:18   #76415 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,778
Init log engine...
Ok
Ok
Backup files: 38 dirs: 0
Ok
libusb: v1.2.6.0
Init environment...
Ok
Ready
Wait...
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
- Connect cable
BROM: Init...
Ok
CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0699
CODE: Zion
MEID: F4B9B0188B59746FA37120D1E93691E3
BROM: Sec Level: 0x00000000 Mode: PLAIN
SOCID: A4869A79B0E2154AF34B1FF60CB68205B2583C51D7004A57C7 A0B22597CFC7E2
BROM: EMI: Search
EMI: Continue
EMI: Found
AGENT:
Found: MT6739; DA: MTK_DOWNLOAD_AGENT
DA sent
Jump to DA...
Ok
Sync...
Ok
DA: Agent Started
DA: SYNC
MODE: BROM
EMI: FireFly preloader_k31v1_bsp_512.bin with 5 memory type(s)
1. eMMC DDR3 ID: 150100513732534D42 Samsung Q72SMB RAM: 1.00 Gb
2. eMMC DDR3 ID: 150100463732324D42 Samsung F722MB RAM: 1.00 Gb
3. eMMC DDR3 ID: 150100464E58324D42 Samsung FNX2MB RAM: 1.00 Gb
4. eMMC DDR3 ID: 90014A483847346132 Hynix H8G4a2 RAM: 1.00 Gb
5. eMMC DDR3 ID: 150100464E36324D42 Samsung FN62MB RAM: 1.00 Gb
Push EMI...
EXT_RAM CFG Passed
2nd stage confirmed
DA: SYNC Ok
Load HW info...
RAM: SRAM: 0x00020000 [ 128.00 Kb ]
RAM: DRAM: 0x40000000 [ 1024.00 Mb ]
EMMC
CID: 150100463732324D420097802177A7E9
crc Ok
Vendor: Samsung OEM: 256 ID: 463732324D42 [F722MB] PRV: 0x00
Serial: 2541756791 0x97802177
MM/YY: 10/2020
RPMB: 0x00080000 [ 512.00 Kb ]
USER: 0x1D2000000 [ 7.28 Gb ]
CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699
CODE: Zion
RNID: 87A755CD3010AAC68357DB9107096D58
USB: HIGH-SPEED
Boot done MODERN [RAPHAEL] 8 sec
Analyze PMT...
Ok
PMT: PGPT [0x64] Records: 34
STORAGE OTP Status: NOT Enabled
STORAGE RPMB Status: eMMC : RPMB KEY NOT PROGRAMMED [USABLE]
Probe boot...
Ok 328 us
Patch Level: O21020
Display ID: DigitOS8-M42868DG-V21-20231117-1132
SW Version: 1700191987
Ver. CodeName: REL
Ver. Release: 8.1.0
Sec. Patch: 2021-08-05
Build Time: 11/17/2023 3:33:05 AM
Product Model: Digit4G Energy
Product Brand: Digit
Product Name: Digit4G_Energy
Product Device: Digit4G_Energy
CPU: armeabi-v7a,armeabi
Product Manfct: Digit
Product Info: k31v1_bsp_512
SW: full_k31v1_bsp_512-user 8.1.0 O21020 1700191987 release-keys
Product Board: k31v1_bsp_512
Board Platform: mt6739
Device ID: digit4g-energy-k31v1-bsp-512-full-k31v1-bsp-512
Strategy: [none|generic]
Firmware ID: MT6739_Digit_Digit4G_Energy_OSv8.1.0_DigitOS8-M42868DG-V21-20231117-1132_O21020_k31v1_bsp_512
Verify firmware [MT6739_Digit_Digit4G_Energy_OSv8.1.0_DigitOS8-M42868DG-V21-20231117-1132_O21020_k31v1_bsp_512]...
Firmware is unknown
Please upload https://infinity-box.com/?r=100020
Analyze userdata...
userData: fileSystem : [f2fs] with FDE [encryptable]
Backup to C:\InfinityBox\CM2MT2\backup\MT6739__F4B9B0188B597 46FA37120D1E93691E3\
Items to check: 22
Read [21] NVRAM
NVRAM: Items: 0xB1 Size: 0x0ABDFC State: Ok
WiFi MAC: AA00656E646F
BT MAC: B09220505899
IMEI[1]:
IMEI[2]:
Read [8] NVDATA
Read [14] PROINFO
Read [22] LK
lk [811eb7cc]
Read [7] NVCFG
Read [10] PROTECT1
Read [1] PGPT
Read [0] PRELOADER
Done 8 files 3 sec
Compress: C:\InfinityBox\CM2MT2\backup\MT6739__F4B9B0188B597 46FA37120D1E93691E3\
Cleanup...
Ok
Verify C:\InfinityBox\CM2MT2\backup\MT6739__F4B9B0188B597 46FA37120D1E93691E3.7z
Enough [digit4g-energy-k31v1-bsp-512-full-k31v1-bsp-512]
Analyze modem...
TK_MD_BASIC_MDBIN_PCB01_MT6739_S00.MOLY_LR12A_R2_M P_V79_11_P9
Analyze nvram...
PSN1: D4GE222
EMMC
crc Ok
MM/YY: 10/2020
EMI: MT6739 preloader_k31v1_bsp_512.bin with 5 memory type(s)
Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 31v1_bsp_512.bin
Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 31v1_bsp_512.bin [f4d52bb8]...
Exist
Probe FRP...
Most probably Off
Reset port...
Finished 32 sec
[+] Smart Analyzer
[+] Wipe
[+] Userdata
[+] FRP
[-] Accounts
Wait...
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
- Connect cable
BROM: Init...
Ok
CODE: Zion
EMI loaded by MEID: F4B9B0188B59746FA37120D1E93691E3
AGENT:
DA sent
Jump to DA...
Ok
Sync...
Ok
DA: Agent Started
DA: SYNC
MODE: BROM
Push EMI...
EXT_RAM CFG Passed
2nd stage confirmed
DA: SYNC Ok
Load HW info...
EMMC
crc Ok
MM/YY: 10/2020
CODE: Zion
USB: HIGH-SPEED
Analyze PMT...
Ok
Probe boot...
Ok 329 us
Patch Level: O21020
Ver. CodeName: REL
Ver. Release: 8.1.0
Android ver: 8
EMMC
crc Ok
MM/YY: 10/2020
Backup exist: C:\InfinityBox\CM2MT2\backup\MT6739__F4B9B0188B597 46FA37120D1E93691E3
Stage: Android OS
[2] WIPE...
Ok
[3] WIPE...
Ok
Ok
[4] WIPE...
Ok
Ok
[6] USERDATA...
Ok
Stage: FRP...
[1] PROTECTION...
Ok
Ok
Done
Stage: Smart...
Nothing to-do
Reset port...
Trying to reboot...
Finished 26 sec
Old 10-19-2024, 19:53   #76416 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,778
VGOTEL S100 RESET PASSWORD DONE BY CM2
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
SPRD mode : SC6531 : REV : E000 : NOR : [ 4MB ]
Operation : Format FileSystem [ v1.07 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR SC6531 Loader v 1.2
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ]
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_198 C894723F1_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:17
Old 10-19-2024, 20:21   #76417 (permalink)
Member: 85718
Thanks Meter: 566
Lenovo Tab M11 TB330FU Firmware read ok
CM2 - MT2 Service Tool v2.72
probe UAC... Ok
probe libusb... v1.2.6.0
Wait...
S/N: 0005C0DF82 v0163
initalize log engine... Ok
Build directories tree... Ok
Firmware files: C:\Users\ct3im\Desktop\Lenovo TB330FU\
Backup files: 5 dirs: 0
load emi database... Internal: 28 custom: 0
Build device list... Ok
Load 155 profiles... Ok
initalize external tools... Ok
initialize libusb... Ok
Ready
Wait...
Connection: Boot [DA] Factory
PTFN: MediaTek PreLoader USB VCOM_V2023 (Android) (COM4)
MODE: PRELOADER PORT; PORT: 4
BROM: Init... Ok
Code: Talbot
BROM: Sec Level: 0x00000007; Mode: SBC+SLA+SDA
Ver: 0xFF BL: 0x03 [PRELOADER PORT]
SOCID: 1D9F71C48F5B6F282706A13C2EAA1F4DE800E4302F25A40BA7 580FF5D1C3096F
Agent:
BROM: Sending DA1...
Reset Interface [1|1|0|0]
PTFN: MediaTek USB Port_V2023 (COM6)
MODE: BOOTROM; PORT: 6
BROM: Init... Ok
Code: Talbot
MEID: A25E2517D594187D73FEAE71EDB8CBBF
SLA: Local Auth [Forced mode]
Start Auth... Ok
Continue Auth... Ok
EMI known
SLA: Start 0x15
EMI loaded by MEID: A25E2517D594187D73FEAE71EDB8CBBF
Agent:
BROM: Sending DA1... Ok [1|1|1|0]
Jump to DA... Ok
Sync... Ok
DA sync... Ok
DA Set Params... Ok
Mode: BROM [1|1|1|0]
EMMC CID: D6010341334135363211BE0237289A1F crc Ok
Vendor: Foresee OEM: 259 ID: 413341353632 [A3A562] PRV: 0x11
Serial: 3187816232 0xBE023728
MM/YY: 9/2023
EMI: FireFly preloader_barley_row_wifi.bin with 7 memory type(s)
3. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
4. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 8.00 Gb
5. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 8.00 Gb
6. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
7. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
Push EMI... EXT_RAM CFG Passed
Boot DA2... Ok [1|1|1|28]
DA Sync... Ok
Load HW info...
MM/YY: 9/2023
RPMB: 0x01000000 [ 16.00 Mb ]
USER: 0x1CCF000000 [ 115.23 Gb ]
Code: Talbot
RNID: 363B0E4063D5CB2643E849CD1146CED3
USB: HIGH-SPEED
Boot done MODERN [RAPHAEL] 17 sec
Analyze PMT... Ok
Partition table: PGPT [0x64] with 54 records
Storage [eMMC] Life State: OK
Storage OTP Status: Unlocked
Storage [eMMC] RPMB State: RPMB KEY PROGRAMMED [UNUSABLE]
Get slot info... a
Probe boot... Finished 1 sec
AndroidInfo: vendor_boot_a;ramdisk size=0;boot_a;gzip;bootimage|loaded ramsidk size 0xB71FD1|00;vendor_boot_b;ramdisk size=0;boot_b;gzip;bootimage|loaded ramsidk size 0xB71CFE|00;
Probe core...
Mount[ext4] system_a@super 0x00E4A00000/0xF2F38000
Skip FS 0x2800A1000 system_a-cow
Skip FS 0x1E0555000 system_ext_a
Mount[ext4] vendor_a@super 0x01E4900000/0x1B6AE000
Mount[ext4] product_a@super 0x004F100000/0x95900000
Skip FS 0x22606C000 product_a-cow Ok 1 sec
Product Brand: Lenovo
Product Device: TB330FU
Product Model: TB330FU
Product Name: TB330FU
Patch Level: TQ1A.230105.002
Display ID: TB330FU_ROW_OPEN_USER_V14.218_T_ZUI_15.1.138_ST_24 0412
SW Version: TB330FU_ROW_OPEN_USER_V14.218_T_ZUI_15.1.138_ST_24 0412
SW Version: S2000958_240412_ROW
Ver. CodeName: REL
Ver. Release: 13
Sec. Patch: 2024-04-05
Build Time: 12/04/2024 15:31:15
Product Manfct: LENOVO
Product Info: mssi_t_64_cn_wifi
SW: sys_mssi_t_64_cn_wifi-user 13 TQ1A.230105.002 138 release-keys
Product Board: barley_row_wifi
Device ID: lenovo-tb330fu-barley-row-wifi
Strategy: [lenovo]
Firmware ID: MT6768_LENOVO_TB330FU_OSv13_TB330FU_ROW_OPEN_USER_ V14.218_T_ZUI_15.1.138_ST_240412_TQ1A.230105.002_m ssi_t_64_cn_wifi_Lenovo
Verify firmware [MT6768_LENOVO_TB330FU_OSv13_TB330FU_ROW_OPEN_USER_ V14.218_T_ZUI_15.1.138_ST_240412_TQ1A.230105.002_m ssi_t_64_cn_wifi_Lenovo]... Socket Error # 11001
Host not found.
Analyze userdata...
userData: encryptable
Backup exist: C:\InfinityBox\CM2MT2\backup\MT6768__A25E2517D5941 87D73FEAE71EDB8CBBF
Load nvram items...
NVRAM size: 0x022134; 7 items; State: Ok
WiFi MAC: AA:00:6E:74:2F:76
BT MAC: E0:1F:FC:22:CB:3E
PSN1: 8SSP69A6PV5LHA16
Secondary RPMB... On
EMI: MT6752 preloader_barley_row_wifi.bin with 7 memory type(s)
Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_b arley_row_wifi.bin
Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_b arley_row_wifi.bin [18ae46ba]... Finished
Probe bootloader... Seems as Locked
Reset port...
Finished 34 sec
Operation: Read Flash [ v2.72 ]
Destination: C:\Users\ct3im\Desktop\Lenovo TB330FU\
Disk free space: 75.10 Gb
Wait...
BROM: Init... Ok
Code: Talbot
Agent:
BROM: Init... Ok
Code: Talbot
Start Auth... Ok
Continue Auth... Ok
EMI known
SLA: Start 0x15
Agent:
Jump to DA... Ok
Sync... Ok
DA sync... Ok
DA Set Params... Ok
MM/YY: 9/2023
DA Sync... Ok
Load HW info...
MM/YY: 9/2023
Code: Talbot
USB: HIGH-SPEED
Analyze PMT... Ok
Device support slots: slotScheme v2
Get slot info... a
Active slot: a
Get slot info... a
Probe core...
Ver. CodeName: REL
Ver. Release: 13
Strategy: [lenovo]
Building report...
Verify data... Socket Error # 11001
Host not found.
Firmware has unknown partitions/structure!
Total size to read: 12.02 Gb
Read [1/57]: preloader.bin 4.00 Mb
Process file... Ok Ok [ 318.75 Kb ]
Read [3/57]: lenovolock.img 512.00 Kb
Process file... Ok Ok [ 0 B ]
Read [4/57]: lenovosku.img 512.00 Kb
Read [5/57]: lenovosku.img 512.00 Kb
Read [10/57]: vbmeta_a.img 8.00 Mb
Process file... Ok Ok [ 4.38 Kb ]
Read [11/57]: vbmeta_system_a.img 8.00 Mb
Process file... Ok Ok [ 1.67 Kb ]
Estimated time to end 13 min 36 sec
Read [12/57]: vbmeta_vendor_a.img 8.00 Mb
Process file... Ok Ok [ 1.63 Kb ]
Read [13/57]: vbmeta_b.img 8.00 Mb
Process file... Ok Ok [ 3.25 Kb ]
Read [14/57]: vbmeta_system_b.img 8.00 Mb
Process file... Ok Ok [ 2.23 Kb ]
Read [15/57]: vbmeta_vendor_b.img 8.00 Mb
Read [20/57]: persist.img 48.00 Mb
Process file...
Sparse... compression ratio: 100% Ok Ok [ 252.21 Kb ]
Read [24/57]: md1rom_a.img 128.00 Mb
Process file... Ok Ok [ 4.19 Kb ]
Read [25/57]: spmfw_a.img 1.00 Mb
Process file... Ok Ok [ 48.20 Kb ]
Read [26/57]: tinysys-scp_a.bin 6.00 Mb
Process file... Ok Ok [ 642.05 Kb ]
Read [27/57]: sspm_a.img 1.00 Mb
Process file... Ok Ok [ 493.42 Kb ]
Read [28/57]: gz_a.img 16.00 Mb
Process file... Ok Ok [ 2.70 Mb ]
Read [29/57]: lk_a.bin 2.00 Mb
Process file... Ok Ok [ 1.21 Mb ]
Read [30/57]: boot_a.img 32.00 Mb
Process file... Ok Ok [ 32.00 Mb ]
Read [31/57]: vendor_boot_a.img 64.00 Mb
Process file...
Read [32/57]: init_boot_a.img 8.00 Mb
Process file...
Read [33/57]: dtbo_a.img 8.00 Mb
Process file... Ok Ok [ 8.00 Mb ]
Read [34/57]: tz_a.img 6.00 Mb
Process file... Ok Ok [ 2.06 Mb ]
Read [35/57]: sec.img 2.00 Mb
Process file...
Read [36/57]: proinfo.img 3.00 Mb
Process file... Ok Ok [ 576 B ]
Read [38/57]: nvram.bin 64.00 Mb
Process file... Ok Ok [ 63.88 Mb ]
Read [39/57]: logo.bin 8.00 Mb
Process file... Ok Ok [ 2.22 Mb ]
Read [40/57]: lenovoraw.img 16.00 Mb
Process file...
Read [41/57]: lenovocust.img 305.00 Mb
Process file...
Sparse... compression ratio: 100% Ok Ok [ 404.10 Kb ]
Read [42/57]: md1rom_b.img 128.00 Mb
Read [43/57]: spmfw_b.img 1.00 Mb
Read [44/57]: tinysys-scp_b.bin 6.00 Mb
Read [45/57]: sspm_b.img 1.00 Mb
Read [46/57]: gz_b.img 16.00 Mb
Read [47/57]: lk_b.bin 2.00 Mb
Read [48/57]: boot_b.img 32.00 Mb
Read [49/57]: vendor_boot_b.img 64.00 Mb
Process file...
Read [50/57]: init_boot_b.img 8.00 Mb
Process file...
Read [51/57]: dtbo_b.img 8.00 Mb
Read [52/57]: tz_b.img 6.00 Mb
Read [53/57]: super.img 11.00 Gb
Process file...
Sparse... compression ratio: 1% Ok Ok [ 10.97 Gb ]
Build [54/57]: userdata.img 102.94 Gb
Make filesystem [0x02 ext4|8+]... Ok Ok Ok [ 0 B ]
Gathering image info...
Build scat... Ok
FW Size: 11.13 Gb
Android Info saved: _Android_info.txt
Scatter: MT6768_Android_scatter.txt
Saved: C:\Users\ct3im\Desktop\Lenovo TB330FU\MT6768_LENOVO_TB330FU_OSv13_TB330FU_ROW_OP EN_USER_V14.218_T_ZUI_15.1.138_ST_240412_TQ1A.2301 05.002_mssi_t_64_cn_wifi_Lenovo\
Verify firmware [MT6768_LENOVO_TB330FU_OSv13_TB330FU_ROW_OPEN_USER_ V14.218_T_ZUI_15.1.138_ST_240412_TQ1A.230105.002_m ssi_t_64_cn_wifi_Lenovo]... Firmware is unknown
Upload file to server? No
Reset port...
Finished 130 min 0 sec
Old 10-20-2024, 06:15   #76418 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,778
CALL ME C12 HANG ON LOGO DONE BY CM2 WITH OUT BOOT KEY
SCRD mode : AUTO
1. Power off device
2. Not hold any key on device!
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
SVC : DiagChannel opened!
Boot Done!
Format FFS Done!
Done!
Elapsed: 00:00:20
Old 10-20-2024, 15:27   #76419 (permalink)
Member: 85718
Thanks Meter: 566
Motorola Moto E20 XT2155-6 Firmware read ok
CM2 - SP3 Service Tool v2.30
probe UAC... Ok
Wait...
Firmware files: C:\Users\ct3im\Desktop\LNMBBS M820-EEA\V30_MB_V1.3 20220805\
Backup files: C:\InfinityBox\CM2SP3\backup\
Backup files: 0 dirs: 0
Build device list... Ok 1637
Ready
Select SoC/Device or [Get boot files]
Selected: Motorola moto-E20 Boot [FF] FireFly mmc
Boot [FF] FireFly protocol may be SLOW. For flash Read/Write use Boot [FDL] Factory
Get loader info... Ok
Finished 16 sec
Operation: Connect Motorola moto-E20 Boot [FF] FireFly [v2.30]
Wait...
Device found
PTFN: SPRD U2S Diag (COM5) vid 0x1782 pid 0x4D00
boot: SPRD3
boot iLoader... Ok
start iLoader... Ok
Handshake... Ok
boot xLoader... Ok
start FireFly... Ok
Loader exec Ok
Dev UID: 0de3c489f16db50088cc9b2a6c50ed68fa5716958eb40a5de6 f1c6c30a2b7243
stored 6 hwid cache items
get storage info... MMC
EMMC CID: D601034133413535311189C5442D89B5 crc Ok
Vendor: Foresee OEM: 259 ID: 413341353531 [A3A551] PRV: 0x11
Serial: 2311406637 0x89C5442D
MM/YY: 8/2022
CSD: D0FFFF329F5903FFFFFFFFEF964000FF
wp_group: 0x10 en 0x01
read extcsd... Ok
EXTCSD rev1.8 EMMC 5.1 FW: 11
BOOT_BUS_WIDTH: 0x00
PARTITION_CONFIG: 0x08
BOOT size: 0x400000
RPMB size: 0x1000000 16.00 Mb
WP_GRP_SIZE: 0x800000 8.00 Mb
Size: Market 32 Gb Actual 0x73A000000 28.91 Gb
EOL_A: SLC status: 20% - 30% used
extcsd backup exist, skip: C:\InfinityBox\CM2SP3\backup\ext_csd\none_0de3c489 f16db500_extcsd_00D6-Foresee_A3A551_5.1_2024-10-20.bin
get partitions...
Load primary GPT...
Load secondary GPT...
Primary GPT state Ok
Secondary GPT state Ok
Partitions: 70
Connected
get sw info... 8 sec
SW: motorola/aruba/aruba:11/RONS31.267-94-10/68532:user/release-keys
Product Brand: motorola
Product Device: aruba
Product Model: moto e20
Product Name: aruba
Patch Level: RONS31.267-94-10
Display ID: RONS31.267-94-10 release-keys
SW Version: 68532
Ver. CodeName: REL
Ver. Release: 11
Sec. Patch: 2023-07-05
Build Time: 14/07/2023 07:32:43
Product Info: ums9230_4h10_go
SW: ums9230_4h10_go_nv-user 11 RONS31.267-94-10 68532 release-keys
Product Board: ums9230_4h10_go
Board Platform: ums9230
Product Manfct: motorola
Android ver: 11
Device ID: motorola-moto-e20-aruba-ums9230-4h10-go
Strategy: [moto]
Firmware ID: UMS9230_motorola_moto_e20_OSv11_68532_RONS31.267-94-10_ums9230_4h10_go
Backup exist: C:\InfinityBox\CM2SP3\backup\ums9230_0de3c489f16db 500\
get slots... slot: b
[MemTool] load 70 items
Finished 25 sec
Operation: Read FW Motorola moto-E20 Boot [FF] FireFly [v2.30]
Wait...
Selected: C:\Users\ct3im\Desktop\Motorola E20 XT2155-6\
Disk free space: 66.48 Gb
Store to: C:\Users\ct3im\Desktop\Motorola E20 XT2155-6\UMS9230_motorola_moto_e20_OSv11_68532_RONS31.267-94-10_ums9230_4h10_go\
Items to read: 63
Read to C:\Users\ct3im\Desktop\Motorola E20 XT2155-6\UMS9230_motorola_moto_e20_OSv11_68532_RONS31.267-94-10_ums9230_4h10_go\
Reading...
Read [1/70] prodnv 10.00 Mb Ok [2.93 Mb] 14 sec
Read [2/70] miscdata 1024.00 Kb Ok [32.00 Kb] 1 sec
Read [3/70] factory 10.00 Mb Ok [32.00 Kb] 9 sec
Read [4/70] misc 1024.00 Kb Ok [64.00 Kb] 1 sec
Read [5/70] trustos_a 6.00 Mb Ok [1.71 Mb] 5 sec
Read [6/70] trustos_b 6.00 Mb Ok [1.71 Mb] 5 sec
Read [7/70] sml_a 1024.00 Kb Ok [67.85 Kb] 1 sec
Read [8/70] sml_b 1024.00 Kb Ok [67.85 Kb] 1 sec
Read [9/70] uboot_a 3.00 Mb Ok [1.11 Mb] 2 sec
Read [10/70] uboot_b 3.00 Mb Ok [1.11 Mb] 2 sec
Skip [11/70] uboot_log 4.00 Mb
Read [12/70] logo 8.00 Mb Ok [1.13 Mb] 7 sec
Read [13/70] logo_lenovo 8.00 Mb Useless data removed, nothing to save
Read [14/70] fbootlogo 8.00 Mb Ok [7.44 Mb] 7 sec
Read [15/70] l_fixnv1_a 2.00 Mb Ok [800.00 Kb] 2 sec
Read [16/70] l_fixnv2_a 2.00 Mb Ok [800.00 Kb] 1 sec
Read [17/70] l_fixnv1_b 2.00 Mb Ok [800.00 Kb] 1 sec
Estimated time to end 81 min 35 sec
Read [18/70] l_fixnv2_b 2.00 Mb Ok [800.00 Kb] 1 sec
Skip [19/70] l_runtimenv1 2.00 Mb
Skip [20/70] l_runtimenv2 2.00 Mb
Read [21/70] gnssmodem_a 1024.00 Kb Ok [608.00 Kb] 1 sec
Read [22/70] gnssmodem_b 1024.00 Kb Ok [608.00 Kb] 1 sec
Read [23/70] wcnmodem_a 10.00 Mb Ok [928.00 Kb] 8 sec
Read [24/70] wcnmodem_b 10.00 Mb Ok [928.00 Kb] 9 sec
Read [25/70] persist 2.00 Mb Useless data removed, nothing to save
Read [26/70] l_modem_a 25.00 Mb Ok
Read [27/70] l_modem_b 25.00 Mb Ok
Read [28/70] l_deltanv_a 1024.00 Kb Ok [128.00 Kb] 1 sec
Read [29/70] l_deltanv_b 1024.00 Kb Ok [128.00 Kb] 1 sec
Read [30/70] l_gdsp_a 10.00 Mb Ok
Read [31/70] l_gdsp_b 10.00 Mb Ok
Read [32/70] l_ldsp_a 20.00 Mb Ok
Read [33/70] l_ldsp_b 20.00 Mb Ok
Read [34/70] l_agdsp_a 6.00 Mb Ok
Read [35/70] l_agdsp_b 6.00 Mb Ok
Read [36/70] pm_sys_a 1024.00 Kb Ok
Read [37/70] pm_sys_b 1024.00 Kb Ok
Read [38/70] teecfg_a 1024.00 Kb Ok [121.65 Kb] 1 sec
Read [39/70] teecfg_b 1024.00 Kb Ok [121.65 Kb] 1 sec
Read [40/70] boot_a 64.00 Mb Ok
Read [41/70] boot_b 64.00 Mb Ok
Read [42/70] vendor_boot_a 100.00 Mb Useless data removed, nothing to save
Read [43/70] vendor_boot_b 100.00 Mb Useless data removed, nothing to save
Read [44/70] dtb_a 8.00 Mb Useless data removed, nothing to save
Read [45/70] dtb_b 8.00 Mb Useless data removed, nothing to save
Read [46/70] dtbo_a 8.00 Mb Ok
Read [47/70] dtbo_b 8.00 Mb Ok
Read [48/70] elabel 20.00 Mb Ok [3.57 Mb] 25 sec
Read [49/70] super 4.00 Gb Ok
Skip [50/70] cache 100,00 Mb
Read [51/70] socko_a 75,00 Mb Ok [6,88 Mb] 1 min 32 sec
Read [52/70] socko_b 75,00 Mb Ok [6,88 Mb] 1 min 31 sec
Read [53/70] odmko_a 25,00 Mb Ok [524,09 Kb] 30 sec
Read [54/70] odmko_b 25,00 Mb Ok [524,09 Kb] 30 sec
Read [55/70] vbmeta_a 1024,00 Kb Ok
Read [56/70] vbmeta_b 1024,00 Kb Ok
Skip [57/70] metadata 16,00 Mb
Skip [58/70] sysdumpdb 10,00 Mb
Read [59/70] vbmeta_system_a 1024,00 Kb Ok [4,00 Kb] 1 sec
Read [60/70] vbmeta_system_b 1024,00 Kb Ok [4,00 Kb] 1 sec
Read [61/70] vbmeta_vendor_a 1024,00 Kb Ok [4,00 Kb] 1 sec
Read [62/70] vbmeta_vendor_b 1024,00 Kb Ok [4,00 Kb] 1 sec
Read [63/70] vbmeta_system_ext_a 1024,00 Kb Ok [4,00 Kb] 1 sec
Read [64/70] vbmeta_system_ext_b 1024,00 Kb Ok [4,00 Kb] 1 sec
Read [65/70] vbmeta_product_a 1024,00 Kb Ok [4,00 Kb] 1 sec
Read [66/70] vbmeta_product_b 1024,00 Kb Ok [4,00 Kb] 1 sec
Read [67/70] odm_res 275,00 Mb Useless data removed, nothing to save
Skip [68/70] userdata 23,70 Gb
Read [69/70] splloader 4,00 Mb Ok [63,88 Kb] 3 sec
Read [70/70] splloader_bak 4,00 Mb Ok [63,88 Kb] 4 sec
Saved 56 of 63 images. 4,31 Gb of 5,08 Gb
Stored: C:\Users\ct3im\Desktop\Motorola E20 XT2155-6\UMS9230_motorola_moto_e20_OSv11_68532_RONS31.267-94-10_ums9230_4h10_go\
Verify firmware [UMS9230_motorola_moto_e20_OSv11_68532_RONS31.267-94-10_ums9230_4h10_go]... Firmware is unknown
Finished 81 min 48 sec
Old 10-20-2024, 16:33   #76420 (permalink)
Member: 85718
Thanks Meter: 566
Tablet Aocwei X700 firmware read ok
probe UAC... Ok
Wait...
Backup files: 6 dirs: 0
Ready
Wait...
BROM: Init... Ok
CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717
Code: Merlot
BROM: Sec Level: 0x00000000; Mode: PLAIN
SOCID: 4DCA7008534AF409E29175F6B83DF33576D577E46AC003E712 A488A1BA5EC89D
IRG: 0x00000080
Agent:
Found: MT6761; DA: MTK_DOWNLOAD_AGENT
Jump to DA... Ok
Sync... Ok
DA sync... Ok
DA Set Params... Ok
Mode: PRELOADER [1|1|1|0]
EXT_RAM initialized
DA Sync... Ok
Load HW info...
RAM: SRAM: 0x0003A600 [ 233.50 Kb ]
EMMC CID: EC29004154325339432008216BBD7A49 crc Ok
Vendor: Unknown 0x00EC OEM: 10496 ID: 415432533943 [AT2S9C] PRV: 0x20
Serial: 136407997 0x08216BBD
MM/YY: 7/2023
USER: 0xE8F800000 [ 58.24 Gb ]
CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717
Code: Merlot
RNID: 478D4894DD74200E5BA50C47DD5B724B
USB: HIGH-SPEED
Boot done MODERN [RAPHAEL] 11 sec
Analyze PMT... Ok
Partition table: PGPT [0x64] with 50 records
Storage [eMMC] RPMB State: RPMB KEY NOT PROGRAMMED [USABLE]
Get slot info... a
Probe boot... Ok 765 us
AndroidInfo: vendor_boot_a;ramdisk size=0;boot_a;gzip;bootimage|loaded ramsidk size 0xAFB23E|1A0B800;
Product Brand: Aocwei
Product Device: X700_EEA
Product Model: X700_EEA
Product Name: X700_EEA
SW: Aocwei/X700_EEA/X700_EEA:13/TP1A.220624.014/2023264:user/release-keys
Patch Level: TP1A.220624.014
Display ID: X700-EEA-MT8766_20230901
SW Version: 2023264
Ver. CodeName: REL
Ver. Release: 12
Sec. Patch: 2023-06-05
Build Time: 01/09/2023 02:06:33
Product Manfct: Aocwei
Product Info: X700_EEA
SW: vnd_g863dmr_v2_szy_x700_eea2_t-user 12 TP1A.220624.014 2023264 release-keys
Product Board: g863dmr_v2_szy_x700_eea2_t
Board Platform: mt6761
Device ID: aocwei-x700-eea-g863dmr-v2-szy-x700-eea2-t
Firmware ID: MT6761_Aocwei_X700_EEA_OSv12_X700-EEA-MT8766_20230901_TP1A.220624.014_X700_EEA
Verify firmware [MT6761_Aocwei_X700_EEA_OSv12_X700-EEA-MT8766_20230901_TP1A.220624.014_X700_EEA]... Firmware is unknown
Analyze userdata...
userData: fileSystem [ext4] with FBE [file based encryption]
Backup 23 items to C:\InfinityBox\CM2MT2\backup\MT6761__82FE667C96F09 72E4E9337F6A2DE7C1D\
Read [16] nvram Ok 1 sec
Read [7] nvdata Ok 1 sec
Read [15] proinfo Ok 125 us
Read [6] nvcfg Ok 843 us
Read [10] protect1 Ok 250 us
Read [1] pgpt Ok 16 us
Read [13] persist Ok 1 sec
Read [0] preloader Ok 140 us
Read [23] lk_a Ok 47 us lk [d6ec6737]
Read [37] lk_b Ok 47 us lk [a738ea1c]
Zero content file deleted: C:\InfinityBox\CM2MT2\backup\MT6761__82FE667C96F09 72E4E9337F6A2DE7C1D\lk_b.bin
Done 9 files 6 sec
Compress: C:\InfinityBox\CM2MT2\backup\MT6761__82FE667C96F09 72E4E9337F6A2DE7C1D\ Ok
Verify C:\InfinityBox\CM2MT2\backup\MT6761__82FE667C96F09 72E4E9337F6A2DE7C1D.7z Verified
Load nvram items...
NVRAM size: 0x022192; 6 items; State: Ok
WiFi MAC: 00:E4:9C:CD:67:F8
BT MAC: 00:E4:9C:CD:67:F9
PSN1: X7002023HGM18814
EMI: MT6761 preloader_g863dmr_v2_szy_x700_eea2_t.bin with 30 memory type(s)
2. eMMC DDR3 ID: 13014E51324A333643 Micron Q2J36C RAM: 2.00 Gb
3. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb
5. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb
7. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
10. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
11. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
12. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
13. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
14. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
15. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
16. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
17. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb
18. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb
19. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb
20. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
21. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
22. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
23. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
24. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
25. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
26. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
27. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb
28. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
29. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
30. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb
Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_g 863dmr_v2_szy_x700_eea2_t.bin
Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_g 863dmr_v2_szy_x700_eea2_t.bin [7a9faa4c]... Stored
Reset port...
Finished 44 sec
Destination: C:\Users\ct3im\Desktop\Aocwei X700\
Disk free space: 72.00 Gb
Wait...
BROM: Init... Ok
Code: Merlot
IRG: 0x00000080
Agent:
Jump to DA... Ok
Sync... Ok
DA sync... Ok
DA Set Params... Ok
EXT_RAM initialized
DA Sync... Ok
Load HW info...
MM/YY: 7/2023
Code: Merlot
USB: HIGH-SPEED
Boot done MODERN [RAPHAEL] 12 sec
Analyze PMT... Ok
Get slot info... a
Active slot: a
Get slot info... a
Probe boot... Ok 766 us
SW Version: 2023264
Ver. CodeName: REL
Ver. Release: 12
Total size to read: 5.64 Gb
Read [1/53]: preloader.bin 4.00 Mb
Process file... Ok Ok [ 243.45 Kb ]
Read [14/53]: persist.img 48.00 Mb
Process file...
Sparse... compression ratio: 89% Ok Ok [ 5.33 Mb ]
Read [15/53]: sec.img 2.00 Mb
Process file...
Read [16/53]: proinfo.img 3.00 Mb
Process file... Ok Ok [ 1.13 Mb ]
Read [17/53]: nvram.bin 64.00 Mb
Process file... Ok Ok [ 63.38 Mb ]
Read [18/53]: logo.bin 11.00 Mb
Process file... Ok Ok [ 1.32 Mb ]
Read [19/53]: md1rom_a.img 100.00 Mb
Process file... Ok Ok [ 4.20 Kb ]
Estimated time to end 10 min 38 sec
Read [20/53]: spmfw_a.img 1.00 Mb
Process file... Ok Ok [ 62.95 Kb ]
Read [21/53]: tinysys-scp_a.bin 1.00 Mb
Process file... Ok Ok [ 163.83 Kb ]
Read [22/53]: sspm_a.img 1.00 Mb
Process file... Ok Ok [ 432.53 Kb ]
Read [23/53]: gz_a.img 16.00 Mb
Process file...
Read [24/53]: lk_a.bin 1.00 Mb
Process file... Ok Ok [ 840.41 Kb ]
Read [25/53]: boot_a.img 32.00 Mb
Read [26/53]: vendor_boot_a.img 64.00 Mb
Process file...
Read [27/53]: init_boot_a.img 8.00 Mb
Process file...
Read [28/53]: dtbo_a.img 8.00 Mb
Read [29/53]: tz_a.img 8.00 Mb
Process file... Ok Ok [ 814.78 Kb ]
Read [30/53]: vbmeta_a.img 8.00 Mb
Read [31/53]: vbmeta_system_a.img 8.00 Mb
Process file... Ok Ok [ 2.17 Kb ]
Read [32/53]: vbmeta_vendor_a.img 8.00 Mb
Read [33/53]: md1rom_b.img 100.00 Mb
Process file...
Read [34/53]: spmfw_b.img 1.00 Mb
Process file...
Read [35/53]: tinysys-scp_b.bin 1.00 Mb
Process file...
Read [36/53]: sspm_b.img 1.00 Mb
Process file...
Read [37/53]: gz_b.img 16.00 Mb
Process file...
Read [38/53]: lk_b.bin 1.00 Mb
Process file...
Read [39/53]: boot_b.img 32.00 Mb
Process file...
Read [40/53]: vendor_boot_b.img 64.00 Mb
Process file...
Read [41/53]: init_boot_b.img 8.00 Mb
Process file...
Read [42/53]: dtbo_b.img 8.00 Mb
Process file...
Read [43/53]: tz_b.img 5.00 Mb
Process file...
Read [44/53]: teksunhw_a.img 1.00 Mb
Process file... Ok Ok [ 45.81 Kb ]
Read [45/53]: teksunhw_b.img 2.00 Mb
Process file...
Read [46/53]: super.img 5.00 Gb
Process file...
Sparse... compression ratio: 11% Ok Ok [ 4.47 Gb ]
Read [47/53]: vbmeta_b.img 8.00 Mb
Process file...
Read [48/53]: vbmeta_system_b.img 8.00 Mb
Process file...
Read [49/53]: vbmeta_vendor_b.img 8.00 Mb
Process file...
Build [50/53]: userdata.img 52.35 Gb
Build scat... Ok
FW Size: 4.58 Gb
Scatter: MT6761_Android_scatter.txt
Saved: C:\Users\ct3im\Desktop\Aocwei X700\MT6761_Aocwei_X700_EEA_OSv12_X700-EEA-MT8766_20230901_TP1A.220624.014_X700_EEA\
Reset port...
Finished 43 min 10 sec
Old 10-20-2024, 16:47   #76421 (permalink)
Member: 2715775
Thanks Meter: 2
Smile INFINIX HOT 30 ( X6831 ) SECURITY august 2024 TESTED DONE
JUST SELECT THIS DA
Tecno\2024-08\MTK_AllInOne_DA_v2312.bf41.cca2a535.bin
PTFN: MediaTek PreLoader USB VCOM (Android) (COM18)
MODE: PRELOADER PORT; PORT: 18
BROM: Init... Ok
Code: Talbot
BROM: Sec Level: 0x00000005; Mode: SBC+SDA
SOCID: 80CD6924AB1277C95985347FAE5D75C97FEDF05069C2B173D7 71A9F0A989E21E
Agent:
[46c0b1ae] C:\InfinityBox\CM2MT2\boot\Tecno\2024-08\MTK_AllInOne_DA_v2312.bf41.cca2a535.bin
[bd322c2c] C:\InfinityBox\CM2MT2\boot\Tecno\2024-08\auth_sv5_24.auth
BROM: Sending DA1... Ok [1|0|0|0]
Jump to DA... Ok
Sync... Ok
DA sync... Ok
DA Set Params... Ok
Mode: PRELOADER [1|0|0|0]
EXT_RAM initialized
Boot DA2... Ok [1|0|0|28]
DA Sync... Ok
DA Auth Ok
Load HW info...
EMMC CID: D62D004D4D4332353651265881D87AB7 crc Ok
Vendor: Foresee OEM: 11520 ID: 4D4D43323536 [MMC256] PRV: 0x51
Serial: 643334616 0x265881D8
MM/YY: 7/2023
USER: 0x3A40A00000 [ 233.01 Gb ]
CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0707
Code: Talbot
RNID: 43C174BAA421E29ACC787CBD8D0031FE
da pl engine nOk 0x01
USB: HIGH-SPEED
Boot done MODERN [RAPHAEL] 23 sec
Analyze PMT... Ok
Partition table: PGPT [0x64] with 53 records
Load [MemTool]... Ok
Get slot info... a
AndroidInfo: vendor_boot_a;ramdisk size=0;boot_a;gzip;bootimage|loaded ramsidk size 0xF1B8ED|00;vendor_boot_b;ramdisk size=0;boot_b;gzip;bootimage|loaded ramsidk size 0xF1B8E3|00;
Probe core...
Mount[ext4] system_a@super 0x015EE00000/0x504F5000
Mount[ext4] system_ext_a@super 0x01AF300000/0x887F3000
Mount[ext4] vendor_a@super 0x0237B00000/0x3A5A6000
Mount[ext4] product_a@super 0x003C100000/0x11279E000
Skip FS 0x29E735000 product_a-cow Ok 1 sec
Product Brand: Infinix
Product Device: FULL-64-ARMV82
Product Name: TSSI
SW: Infinix/TSSI/FULL-64-ARMV82:13/TP1A.220624.014/240814V1725:user/release-keys
Display ID: INFINIX-T-64-ARMV82-240814V1725
SW Version: 240814V2771
Ver. CodeName: REL
Ver. Release: 13
Sec. Patch: 2024-08-05
Build Time: 8/14/2024 9:57:26 AM
Product Info: tssi_64_armv82_infinix
SW: sys_tssi_64_armv82_infinix-user 13 TP1A.220624.014 680177 release-keys
Product Device: Infinix-X6831
Product Manfct: INFINIX
Product Model: Infinix X6831
Product Name: X6831-OP
Product Board: Infinix-X6831
Device ID: x6831-op-infinix-x6831-full-64-armv82-tssi
Strategy: [infinix]
Firmware ID: MT6768_INFINIX_Infinix_X6831_OSv13_INFINIX-T-64-ARMV82-240814V1725_TP1A.220624.014_tssi_64_armv82_infinix
Verify firmware [MT6768_INFINIX_Infinix_X6831_OSv13_INFINIX-T-64-ARMV82-240814V1725_TP1A.220624.014_tssi_64_armv82_infinix]... Firmware is unknown
Analyze userdata...
Backup 23 items to C:\InfinityBox\CM2MT2\backup\MT6768__DDD007A077F9B 7D9DEF4A0359BE1AB44\
Read [37] nvram Ok 1 sec
Read [19] nvdata Ok 1 sec
Read [3] proinfo Ok 109 us
Read [18] nvcfg Ok 875 us
Read [21] protect1 Ok 250 us
Read [20] persist Ok 1 sec
Read [29] lk_a Ok 79 us lk [c7318d62]
Read [43] lk_b Ok 78 us lk [9af1612b]
Done 10 files 7 sec
Compress: C:\InfinityBox\CM2MT2\backup\MT6768__DDD007A077F9B 7D9DEF4A0359BE1AB44\ Ok
Verify C:\InfinityBox\CM2MT2\backup\MT6768__DDD007A077F9B 7D9DEF4A0359BE1AB44.7z Enough [x6831-op-infinix-x6831-full-64-armv82-tssi]
Old 10-20-2024, 21:21   #76422 (permalink)
Member: 85718
Thanks Meter: 566
Tablet Facetel Q3 firmware read ok
probe UAC... Ok
Wait...
Firmware files: C:\Users\ct3im\Desktop\Facetel Q3\G863D-MR\
Backup files: 8 dirs: 0
Ready
Wait...
BROM: Init... Ok
Code: Merlot
SOCID: C496058053C7F23E38179E221B8F77C99E38977B0F874F3C97 1AFA06BD3CB9AC
IRG: 0x00000080
Agent:
Jump to DA... Ok
Sync... Ok
DA sync... Ok
DA Set Params... Ok
EXT_RAM initialized
DA Sync... Ok
Load HW info...
EMMC CID: DF011853434136344710A37FD6039A7B crc Ok
Vendor: Unknown 0x00DF OEM: 280 ID: 534341363447 [SCA64G] PRV: 0x10
Serial: 2743064067 0xA37FD603
MM/YY: 9/2023
USER: 0xE8F000000 [ 58.23 Gb ]
Code: Merlot
RNID: 6DB562873C8B0BAB622E0F7C32E57D4B
USB: HIGH-SPEED
Analyze PMT... Ok
Get slot info... a
Probe boot... Ok 750 us
AndroidInfo: vendor_boot_a;ramdisk size=0;boot_a;gzip;bootimage|loaded ramsidk size 0xAFB118|1A0B800;
Display ID: Q3-EEA-MT8766_20231020
SW Version: 2023264
Ver. CodeName: REL
Ver. Release: 12
Build Time: 20/10/2023 12:21:08
SW: vnd_g863dmr_v2_szy_q3_eea_t-user 12 TP1A.220624.014 2023264 release-keys
Product Board: g863dmr_v2_szy_q3_eea_t
Device ID: aocwei-x700-eea-g863dmr-v2-szy-q3-eea-t
Firmware ID: MT6761_Aocwei_X700_EEA_OSv12_Q3-EEA-MT8766_20231020_TP1A.220624.014_X700_EEA
Verify firmware [MT6761_Aocwei_X700_EEA_OSv12_Q3-EEA-MT8766_20231020_TP1A.220624.014_X700_EEA]... Firmware is unknown
Analyze userdata...
Backup exist: C:\InfinityBox\CM2MT2\backup\MT6761__EDD23029D9521 5489E28E2DFB3AFD3BA
Load nvram items...
WiFi MAC: 00:E4:9C:CE:9E:C6
BT MAC: 00:E4:9C:CE:9E:C7
PSN1: Q32023HGM1880006
EMI: MT6761 preloader_g863dmr_v2_szy_q3_eea_t.bin with 30 memory type(s)
Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_g 863dmr_v2_szy_q3_eea_t.bin
Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_g 863dmr_v2_szy_q3_eea_t.bin [e809fa3e]... Exist
Reset port...
Finished 25 sec
Destination: C:\Users\ct3im\Desktop\Facetel Q3\G863D-MR\
Disk free space: 71.92 Gb
Wait...
BROM: Init... Ok
Code: Merlot
IRG: 0x00000080
Agent:
Jump to DA... Ok
Sync... Ok
DA sync... Ok
DA Set Params... Ok
EXT_RAM initialized
DA Sync... Ok
Load HW info...
MM/YY: 9/2023
Code: Merlot
USB: HIGH-SPEED
Boot done MODERN [RAPHAEL] 13 sec
Analyze PMT... Ok
Get slot info... a
Active slot: a
Get slot info... a
SW Version: 2023264
Ver. CodeName: REL
Ver. Release: 12
Process file... Ok Ok [ 243.48 Kb ]
Process file...
Sparse... compression ratio: 93% Ok Ok [ 3.39 Mb ]
Process file...
Process file... Ok Ok [ 1.33 Mb ]
Estimated time to end 9 min 40 sec
Process file... Ok Ok [ 163.81 Kb ]
Process file...
Process file... Ok Ok [ 840.64 Kb ]
Process file...
Process file...
Process file...
Process file...
Process file...
Process file...
Process file...
Process file...
Process file...
Process file...
Process file...
Process file...
Process file...
Process file... Ok Ok [ 46.78 Kb ]
Process file...
Process file...
Sparse... compression ratio: 16% Ok Ok [ 4.22 Gb ]
Process file...
Process file...
Process file...
Build [50/53]: userdata.img 52.34 Gb
Build scat... Ok
FW Size: 4.33 Gb
Saved: C:\Users\ct3im\Desktop\Facetel Q3\G863D-MR\MT6761_Aocwei_X700_EEA_OSv12_Q3-EEA-MT8766_20231020_TP1A.220624.014_X700_EEA\
Reset port...
Finished 41 min 55 sec
Old 10-21-2024, 11:56   #76423 (permalink)
Member: 233142
Sonork: 100.1595099
Thanks Meter: 535
ITEL circle 1 read code done
Operation : Read UserCode [ v1.07 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootVersion : Infinity SCR 6531EFM v2.0 (c)2019
Port speed : 921600
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Reading data ...
STATE : ACTIVE : CODE : 0007
Done!
Elapsed: 00:00:34
Old 10-22-2024, 10:14   #76424 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,778
Init log engine...
Ok
Ok
Backup files: 40 dirs: 0
Ok
libusb: v1.2.6.0
Init environment...
Ok
Ready
[+] Smart Analyzer
[+] Wipe
[+] Userdata
[+] FRP
[-] Accounts
Wait...
[-] Force BROM
[-] Local SLA
[+] Auto-EMI
[+] FireFly-Over-DA
- Connect cable
BROM: Init...
Ok
CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCC00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0699
CODE: Zion
MEID: 17651EF93D26F4B23020FD1942717E46
SOCID: 6ADD020100E95675B35091232305CF38E1A1FE89A8CF21874A 353D1C89BC4BA5
EMI loaded by MEID: 17651EF93D26F4B23020FD1942717E46
AGENT:
DA sent
Jump to DA...
Ok
Sync...
Ok
DA: Agent Started
DA: SYNC
MODE: BROM
Push EMI...
EXT_RAM CFG Passed
2nd stage confirmed
DA: SYNC Ok
Load HW info...
EMMC
CID: 90014A483847346132A52641813E85AD
crc Ok
Vendor: Hynix OEM: 330 ID: 483847346132 [H8G4a2] PRV: 0xA5
Serial: 641827134 0x2641813E
MM/YY: 8/2018
CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCC00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699
CODE: Zion
RNID: 901963412253DAAE06D9CD807FD09F85
USB: HIGH-SPEED
Boot done MODERN [RAPHAEL] 15 sec
Analyze PMT...
Ok
Probe boot...
Ok 312 us
Patch Level: O21020
Display ID: DigitOS8_M42481DG_NB_INT_SW04_20231124
SW Version: 1700811048
Ver. CodeName: REL
Ver. Release: 8.1.0
Build Time: 11/24/2023 7:30:46 AM
Product Model: Digit4G E2 PRO
Product Name: Digit4G_E2_PRO
Product Device: Digit4G_E2_PRO
SW: full_k31v1_bsp_512-user 8.1.0 O21020 1700811048 release-keys
Device ID: digit4g-e2-pro-k31v1-bsp-512-full-k31v1-bsp-512
Firmware ID: MT6739_Digit_Digit4G_E2_PRO_OSv8.1.0_DigitOS8_M424 81DG_NB_INT_SW04_20231124_O21020_k31v1_bsp_512
Android ver: 8
EMMC
crc Ok
MM/YY: 8/2018
Backup exist: C:\InfinityBox\CM2MT2\backup\MT6739__17651EF93D26F 4B23020FD1942717E46
Stage: Android OS
[2] WIPE...
Ok
[3] WIPE...
Ok
Ok
[4] WIPE...
Ok
Ok
[6] USERDATA...
Ok
Stage: FRP...
[1] PROTECTION...
Ok
Ok
Done
Stage: Smart...
Nothing to-do
Reset port...
Trying to reboot...
Finished 31 sec
Old 10-22-2024, 17:46   #76425 (permalink)
Member: 227454
Thanks Meter: 51
Realme RMX3834 Pay joy permanent remove done
Operation: Load Apps Realme RMX3834 Boot [FDL] Factory [v2.30]
Wait...
Loading...
A lot of data should be collected, be patient!
Mount[erofs] system_a@super 0x0099A00000/0xADC70000
Load... 3731 items
Mount[erofs] system_ext_a@super 0x0147700000/0x2327A000
Load... 598 items
Mount[erofs] vendor_a@super 0x016AA00000/0x201C4000
Load... 2721 items
Mount[erofs] product_a@super 0x018AC00000/0x60458000
Load... 668 items
Mount[erofs] vendor_dlkm_a@super 0x01FF200000/0x0097B000
Load... 134 items
Mount[erofs] odm_a@super 0x01EB100000/0x1409B000
Load... 980 items
AppTool load 302 items, 1 [-]
Finished 17 min 2 sec
Found [48] /system/app/realme/Oplus_PayJoy/Oplus_PayJoy.apk
Found [145] /system/priv-app/realme/PayJoyAccess/PayJoyAccess.apk
Found [146] /system/priv-app/realme/PayJoyAccess_MX/PayJoyAccess_MX.apk
[-] /system/app/realme/Oplus_PayJoy/Oplus_PayJoy.apk
[-] /system/app/realme/Oplus_PayJoy_MX/Oplus_PayJoy_MX.apk
[-] /system/priv-app/realme/PayJoyAccess/PayJoyAccess.apk
[-] /system/priv-app/realme/PayJoyAccess_MX/PayJoyAccess_MX.apk
Operation: Apply Realme RMX3834 Boot [FDL] Factory [v2.30]
Wait...
Update 5 Apps? Yes
Mount[erofs] system_a@super 0x0099A00000/0xADC70000 erofs processed 1 parts
Modified 1 parts
Be sure Bootloader is unlocked otherwise device can not Power On!
Finished 21 min 36 sec
prodnv: sync before load;
protect_data: sync before load;
Reboot... Disconnect cable if it freez
Bye
The Following 3 Users Say Thank You to mgbhatti For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 1.04654 seconds with 10 queries
