11-04-2024, 21:13 | #76441 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 567 | Watch MyKi Firmware readed ok Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 22B08D8D20C7A2CFD0BD53800B284738 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : THREEG03D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_5 2_SP3_V1.bin FileVersion : MAUI.11C.W13.52.SP3.V1 Done! Elapsed: 00:00:07 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 22B08D8D20C7A2CFD0BD53800B284738 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Reading Flash Content now ... Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : THREEG03D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_5 2_SP3_V1.bin FileVersion : MAUI.11C.W13.52.SP3.V1 Saved to : C:\InfinityBox\CM2MTK\Read_out\THREEG03D_11C_PCB01 _gprs_MT6261_S00.MAUI_11C_W13_52_SP3_V1.bin Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
The Following User Says Thank You to ct3im For This Useful Post: |
11-06-2024, 06:58 | #76442 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,778 | S/N: 0073CA70CC v0161 Chinese Miracle II - MT2 Service Tool v2.63 Init log engine... Ok Build directories tree... Ok Firmware files: C:\Users\Master Mobile\Desktop\New folder\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 43 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Check for updates [CM2MT2]... Installed v2.63 Infinity #CM2MT2 v2.73 - Boot Authentication for number of devices updated - DAv6 parser updated - Autobackup process updated - huawei account processing revised, issues fixed - Device-ID method revised, issues fixed Required firmware v0163 Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Sales: https://infinity-box.com/buy/ Account: https://infinity-box.com/service/ Update configuration... Configuration [12412] updated Get list of devices... Ok Reloaded 2080 devices Build device list... Load IDBase v915508 Ok Load 155 profiles... Ok libusb: v1.2.6.0 Init environment... Ok Ready Operation: Identify [ v2.63 ] Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 84F2DBF3862D5BC84B41E2C5F94E4FCD BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: CF49BAF33D1C5C3085087ECCE8A0DA78D557C87BD921C52612 0370B2795C92E8 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 84F2DBF3862D5BC84B41E2C5F94E4FCD AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 90014A6843396150330110423B2DB761 crc Ok Vendor: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 Serial: 272775981 0x10423B2D MM/YY: 11/2020 EMI: FireFly preloader_k65v1_64_bsp.bin with 9 memory type(s) 1. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 2. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 5. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 9. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 90014A6843396150330110423B2DB761 crc Ok Vendor: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 Serial: 272775981 0x10423B2D MM/YY: 11/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: FC8F8DA3C1E44FD699B395523C4631FA MEID: 84F2DBF3862D5BC84B41E2C5F94E4FCD USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 10 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 47 STORAGE Life Status: eMMC : OK STORAGE OTP Status: UNLOCKED STORAGE RPMB Status: eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Saved: C:\InfinityBox\CM2MT2\phdata\key.json Probe boot... Ok 2 sec SW: vivo/2026/2026:11/RP1A.200720.012/compiler0106232541:user/release-keys Product Brand: vivo Product Device: 2026 Product Model: V2026 Product Name: 2026 Patch Level: RP1A.200720.012 Display ID: RP1A.200720.012 release-keys Product Info: k65v1_64_bsp SW: full_k65v1_64_bsp-user 11 RP1A.200720.012 eng.compil.20220106.232957 release-keys SW Version: eng.compil.20220106.232957 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2022-01-01 Build Time: 1/6/2022 3:25:41 PM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Board: k65v1_64_bsp Board Platform: mt6765 Product Manfct: vivo Device ID: vivo-v2026-k65v1-64-bsp Strategy: [vivo] Firmware ID: MT6765_vivo_V2026_OSv11_RP1A.200720.012_k65v1_64_b sp Verify firmware [MT6765_vivo_V2026_OSv11_RP1A.200720.012_k65v1_64_b sp]... Exist (2) Analyze userdata... userData: fileSystem [ext4] with FBE [file based encryption] Backup to C:\InfinityBox\CM2MT2\backup\MT6765__84F2DBF3862D5 BC84B41E2C5F94E4FCD\ Items to check: 22 Read [35] NVRAM NVRAM: Items: 0xB6 Size: 0x1250C6 State: Ok WiFi MAC: BC3ECBDC739F BT MAC: BC3ECBDC739E IMEI[1]: 863316056179670 IMEI[2]: 863316056179662 Read [10] NVDATA Read [25] PROINFO Read [36] LK lk [b16bfe3a] Read [9] NVCFG Read [20] PROTECT1 Read [1] PGPT Read [23] PERSIST Read [0] PRELOADER Done 9 files 12 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6765__84F2DBF3862D5 BC84B41E2C5F94E4FCD\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__84F2DBF3862D5 BC84B41E2C5F94E4FCD.7z Enough [vivo-v2026-k65v1-64-bsp] Analyze modem... BBK_R0MP1_K65V1_64_BSP_MDBIN_PCB01_MT6765_S00.MOLY _LR12A_R3_MP_V136_6_P96 Analyze nvram... PSN1: 0B1A967916714701 EMMC CID: 90014A6843396150330110423B2DB761 crc Ok Vendor: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 Serial: 272775981 0x10423B2D MM/YY: 11/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Analyze preloader... EMI: MT6765 preloader_k65v1_64_bsp.bin with 9 memory type(s) 1. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 2. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 5. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 9. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 65v1_64_bsp.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 65v1_64_bsp.bin [944853b1]... Exist Probe FRP... Most probably Off Reset port... Finished 1 min 9 sec Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [-] Wipe [-] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make [Userdata] On and repeat operation Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 84F2DBF3862D5BC84B41E2C5F94E4FCD BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: CF49BAF33D1C5C3085087ECCE8A0DA78D557C87BD921C52612 0370B2795C92E8 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok EMI known SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 84F2DBF3862D5BC84B41E2C5F94E4FCD AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 90014A6843396150330110423B2DB761 crc Ok Vendor: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 Serial: 272775981 0x10423B2D MM/YY: 11/2020 EMI: FireFly preloader_k65v1_64_bsp.bin with 9 memory type(s) 1. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 2. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 5. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 9. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 90014A6843396150330110423B2DB761 crc Ok Vendor: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 Serial: 272775981 0x10423B2D MM/YY: 11/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: FC8F8DA3C1E44FD699B395523C4631FA MEID: 84F2DBF3862D5BC84B41E2C5F94E4FCD USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 9 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 47 Probe boot... Ok 2 sec SW: vivo/2026/2026:11/RP1A.200720.012/compiler0106232541:user/release-keys Product Brand: vivo Product Device: 2026 Product Model: V2026 Product Name: 2026 Patch Level: RP1A.200720.012 Display ID: RP1A.200720.012 release-keys Product Info: k65v1_64_bsp SW: full_k65v1_64_bsp-user 11 RP1A.200720.012 eng.compil.20220106.232957 release-keys SW Version: eng.compil.20220106.232957 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2022-01-01 Build Time: 1/6/2022 3:25:41 PM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Board: k65v1_64_bsp Board Platform: mt6765 Product Manfct: vivo Device ID: vivo-v2026-k65v1-64-bsp Strategy: [vivo] Firmware ID: MT6765_vivo_V2026_OSv11_RP1A.200720.012_k65v1_64_b sp Android ver: 11 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 90014A6843396150330110423B2DB761 crc Ok Vendor: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 Serial: 272775981 0x10423B2D MM/YY: 11/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__84F2DBF3862D5 BC84B41E2C5F94E4FCD Stage: Android OS Off Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Ok Reset port... Trying to reboot... Finished 24 sec Reconnect Power/Cable now |
11-06-2024, 08:07 | #76443 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | S/N: 0073CA70CC v0161 Chinese Miracle II - MT2 Service Tool v2.63 Init log engine... Ok Build directories tree... Ok Firmware files: C:\Users\Master Mobile\Desktop\New folder\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 44 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Load IDBase v915508 Ok Load 158 profiles... Ok libusb: v1.2.6.0 Init environment... Ok Ready Operation: Identify [ v2.63 ] Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: B21E186F1EF47C96AF199C7250F30930 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: C35B891A24A72A9C4E5C3E40169B4566623C8E82F383155DC0 FA47F5A9227BE0 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: B21E186F1EF47C96AF199C7250F30930 AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 13014E47314A395238100C733555B779 crc Ok Vendor: Micron OEM: 334 ID: 47314A395238 [G1J9R8] PRV: 0x10 Serial: 208876885 0x0C733555 MM/YY: 11/2020 EMI: FireFly preloader_oppo6765.bin with 12 memory type(s) 1. eMMC LP_DDR4X ID: 1501003458364B4D42 Samsung 4X6KMB RAM: 2.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 2.00 Gb 4. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 6. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 10. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 12. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 13014E47314A395238100C733555B779 crc Ok Vendor: Micron OEM: 334 ID: 47314A395238 [G1J9R8] PRV: 0x10 Serial: 208876885 0x0C733555 MM/YY: 11/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: D5734456F2FB2CE0EED8157DB6DF844C MEID: B21E186F1EF47C96AF199C7250F30930 USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 15 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 47 STORAGE Life Status: eMMC : OK STORAGE OTP Status: UNLOCKED STORAGE RPMB Status: eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Saved: C:\InfinityBox\CM2MT2\phdata\key.json Probe boot... Ok 1 sec Patch Level: QP1A.190711.020 Display ID: QP1A.190711.020 release-keys Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2023-02-05 Build Time: 2/21/2024 4:44:37 PM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: oppo6765 SW: full_oppo6765-user 10 QP1A.190711.020 bedd37e98646d3a1 release-keys Device ID: oppo-MT6765_CPH2179PU_11_A.17_201228_8cedfeaf Strategy: [oppo] Firmware ID: MT6765_OSv10_QP1A.190711.020_oppo6765.MT6765_CPH21 79PU_11_A.17_201228_8cedfeaf Verify firmware [MT6765_OSv10_QP1A.190711.020_oppo6765.MT6765_CPH21 79PU_11_A.17_201228_8cedfeaf]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem [ext4] with FBE [file based encryption] Backup to C:\InfinityBox\CM2MT2\backup\MT6765__B21E186F1EF47 C96AF199C7250F30930\ Items to check: 22 Read [31] NVRAM NVRAM: Items: 0xAA Size: 0x08C87A State: Ok WiFi MAC: 8C34011190E3 BT MAC: 8C34011190E2 Read [14] NVDATA Read [22] PROINFO Read [36] LK lk [f5a8a9ec] Read [13] NVCFG Read [17] PROTECT1 Read [1] PGPT Read [20] PERSIST Read [0] PRELOADER Read [33] OCDT Read [5] OPPORESERVE1 Read [7] OPPORESERVE3 Read [8] OPPO_CUSTOM Read [32] CDT_ENGINEERING Done 14 files 13 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6765__B21E186F1EF47 C96AF199C7250F30930\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__B21E186F1EF47 C96AF199C7250F30930.7z Enough [oppo-mt6765-cph2179pu-11-a.17-201228-8cedfeaf] Analyze modem... OPPO6765_20271_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R 2_TC16_Q_G35_PR1_SP_V2_P211 Analyze nvram... PSN1: 0020271011180920 EMMC CID: 13014E47314A395238100C733555B779 crc Ok Vendor: Micron OEM: 334 ID: 47314A395238 [G1J9R8] PRV: 0x10 Serial: 208876885 0x0C733555 MM/YY: 11/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Analyze preloader... EMI: MT6765 preloader_oppo6765.bin with 12 memory type(s) 1. eMMC LP_DDR4X ID: 1501003458364B4D42 Samsung 4X6KMB RAM: 2.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 2.00 Gb 4. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 6. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 10. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 12. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_o ppo6765.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_o ppo6765.bin [58d907b5]... Exist Probe FRP... Most probably Off Reset port... Finished 1 min 6 sec Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [+] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: B21E186F1EF47C96AF199C7250F30930 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: C35B891A24A72A9C4E5C3E40169B4566623C8E82F383155DC0 FA47F5A9227BE0 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok EMI known SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: B21E186F1EF47C96AF199C7250F30930 AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 13014E47314A395238100C733555B779 crc Ok Vendor: Micron OEM: 334 ID: 47314A395238 [G1J9R8] PRV: 0x10 Serial: 208876885 0x0C733555 MM/YY: 11/2020 EMI: FireFly preloader_oppo6765.bin with 12 memory type(s) 1. eMMC LP_DDR4X ID: 1501003458364B4D42 Samsung 4X6KMB RAM: 2.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 2.00 Gb 4. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 6. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 10. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 12. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 13014E47314A395238100C733555B779 crc Ok Vendor: Micron OEM: 334 ID: 47314A395238 [G1J9R8] PRV: 0x10 Serial: 208876885 0x0C733555 MM/YY: 11/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: D5734456F2FB2CE0EED8157DB6DF844C MEID: B21E186F1EF47C96AF199C7250F30930 USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 19 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 47 Probe boot... Ok 1 sec Patch Level: QP1A.190711.020 Display ID: QP1A.190711.020 release-keys Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2023-02-05 Build Time: 2/21/2024 4:44:37 PM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: oppo6765 SW: full_oppo6765-user 10 QP1A.190711.020 bedd37e98646d3a1 release-keys Device ID: oppo-MT6765_CPH2179PU_11_A.17_201228_8cedfeaf Strategy: [oppo] Firmware ID: MT6765_OSv10_QP1A.190711.020_oppo6765.MT6765_CPH21 79PU_11_A.17_201228_8cedfeaf Android ver: 10 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 13014E47314A395238100C733555B779 crc Ok Vendor: Micron OEM: 334 ID: 47314A395238 [G1J9R8] PRV: 0x10 Serial: 208876885 0x0C733555 MM/YY: 11/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__B21E186F1EF47 C96AF199C7250F30930 Stage: Android OS [2] WIPE... Skip for Strategy [oppo] [3] WIPE... Create partition image... Ok Ok [4] WIPE... Create partition image... Ok Ok [6] USERDATA... Ok [7] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 39 sec Reconnect Power/Cable now |
11-06-2024, 08:15 | #76444 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | S/N: 0073CA70CC v0161 Chinese Miracle II - MT2 Service Tool v2.63 Init log engine... Ok Build directories tree... Ok Firmware files: C:\Users\Master Mobile\Desktop\New folder\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 45 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Check for updates [CM2MT2]... You have latest version [2.63] installed Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Sales: https://infinity-box.com/buy/ Account: https://infinity-box.com/service/ Update configuration... Configuration [12412] updated Get list of devices... Ok Reloaded 2118 devices Build device list... Load IDBase v915508 Ok Load 158 profiles... Ok libusb: v1.2.6.0 Init environment... Ok Ready Operation: Identify [ v2.63 ] Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 9121A7DDDD2CADBD4E763DE3DF6321CB BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: B2F4C461B2E1CA3E988F3F3E4D8567D0E613ABA0E84A20A8DA D5EF5E6F7603C9 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 9121A7DDDD2CADBD4E763DE3DF6321CB AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 90014A68423861503E03001EB81C67F1 crc Ok Vendor: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 Serial: 2013212 0x001EB81C MM/YY: 6/2020 EMI: FireFly preloader_oppo6765_19451.bin with 10 memory type(s) 1. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 5. eMMC DDR3 ID: 90014A484147346132 Hynix HAG4a2 RAM: 2.00 Gb 6. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 7. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 1501003458364B4D42 Samsung 4X6KMB RAM: 2.00 Gb 10. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 2.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 90014A68423861503E03001EB81C67F1 crc Ok Vendor: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 Serial: 2013212 0x001EB81C MM/YY: 6/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 378094DBE4CDC199E5599ABB77C95F2C MEID: 9121A7DDDD2CADBD4E763DE3DF6321CB USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 28 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 42 STORAGE Life Status: eMMC : OK STORAGE OTP Status: UNLOCKED STORAGE RPMB Status: eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Saved: C:\InfinityBox\CM2MT2\phdata\key.json Probe boot... Ok 1 sec Patch Level: PPR1.180610.011 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2022-01-05 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: OPPO SW: full_oppo6765_19451-user 9 PPR1.180610.011 1565076280 release-keys Build Time: 4/15/2024 3:26:36 AM Product Brand: OPPO Product Model: CPH2083 Product Info: CPH2083 Product Name: CPH2083 Product Device: OP4BFB SW OTA Version: CPH2083PUEX_11.A.71_0710_202404151024 Display ID: CPH2083EX_11_A.71 Display ID: CPH2083EX_11_A.71_240415 Kernel Info: 4.9.117 Device ID: oppo-cph2083-op4bfb-MT6765_CPH2083_11_A.45_201009_248b7f61 Strategy: [oppo] Firmware ID: MT6765_OPPO_CPH2083_OSv9_CPH2083EX_11_A.71_240415_ PPR1.180610.011_CPH2083.MT6765_CPH2083_11_A.45_201 009_248b7f61 Verify firmware [MT6765_OPPO_CPH2083_OSv9_CPH2083EX_11_A.71_240415_ PPR1.180610.011_CPH2083.MT6765_CPH2083_11_A.45_201 009_248b7f61]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem [ext4] with FBE [file based encryption] Backup to C:\InfinityBox\CM2MT2\backup\MT6765__9121A7DDDD2CA DBD4E763DE3DF6321CB\ Items to check: 22 Read [28] NVRAM NVRAM: Items: 0xBC Size: 0x0AFB20 State: Ok WiFi MAC: 388ABE32DFDD BT MAC: 388ABE32DFDC Read [12] NVDATA Read [19] PROINFO Read [29] LK lk [463a8f13] Read [11] NVCFG Read [14] PROTECT1 Read [1] PGPT Read [17] PERSIST Read [0] PRELOADER Read [5] OPPORESERVE1 Read [7] OPPORESERVE3 Read [8] OPPO_CUSTOM Done 12 files 12 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6765__9121A7DDDD2CA DBD4E763DE3DF6321CB\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__9121A7DDDD2CA DBD4E763DE3DF6321CB.7z Enough [oppo-cph2083-op4bfb-mt6765-cph2083-11-a.45-201009-248b7f61] Analyze modem... OPPO6765_19451_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R 2_PIE_P35_PR1_TC16_SP_V1_P112 Analyze nvram... PSN1: 001945100B150335 EMMC CID: 90014A68423861503E03001EB81C67F1 crc Ok Vendor: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 Serial: 2013212 0x001EB81C MM/YY: 6/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] Analyze preloader... EMI: MT6765 preloader_oppo6765_19451.bin with 10 memory type(s) 1. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 5. eMMC DDR3 ID: 90014A484147346132 Hynix HAG4a2 RAM: 2.00 Gb 6. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 7. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 1501003458364B4D42 Samsung 4X6KMB RAM: 2.00 Gb 10. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 2.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_o ppo6765_19451.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_o ppo6765_19451.bin [49dd6924]... Exist Probe FRP... Most probably Off Reset port... Finished 1 min 14 sec Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [+] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 9121A7DDDD2CADBD4E763DE3DF6321CB BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: B2F4C461B2E1CA3E988F3F3E4D8567D0E613ABA0E84A20A8DA D5EF5E6F7603C9 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok EMI known SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 9121A7DDDD2CADBD4E763DE3DF6321CB AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 90014A68423861503E03001EB81C67F1 crc Ok Vendor: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 Serial: 2013212 0x001EB81C MM/YY: 6/2020 EMI: FireFly preloader_oppo6765_19451.bin with 10 memory type(s) 1. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 5. eMMC DDR3 ID: 90014A484147346132 Hynix HAG4a2 RAM: 2.00 Gb 6. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 7. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 1501003458364B4D42 Samsung 4X6KMB RAM: 2.00 Gb 10. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 2.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 90014A68423861503E03001EB81C67F1 crc Ok Vendor: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 Serial: 2013212 0x001EB81C MM/YY: 6/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 378094DBE4CDC199E5599ABB77C95F2C MEID: 9121A7DDDD2CADBD4E763DE3DF6321CB USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 11 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 42 Probe boot... Ok 1 sec Patch Level: PPR1.180610.011 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2022-01-05 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: OPPO SW: full_oppo6765_19451-user 9 PPR1.180610.011 1565076280 release-keys Build Time: 4/15/2024 3:26:36 AM Product Brand: OPPO Product Model: CPH2083 Product Info: CPH2083 Product Name: CPH2083 Product Device: OP4BFB SW OTA Version: CPH2083PUEX_11.A.71_0710_202404151024 Display ID: CPH2083EX_11_A.71 Display ID: CPH2083EX_11_A.71_240415 Kernel Info: 4.9.117 Device ID: oppo-cph2083-op4bfb-MT6765_CPH2083_11_A.45_201009_248b7f61 Strategy: [oppo] Firmware ID: MT6765_OPPO_CPH2083_OSv9_CPH2083EX_11_A.71_240415_ PPR1.180610.011_CPH2083.MT6765_CPH2083_11_A.45_201 009_248b7f61 Android ver: 9 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 90014A68423861503E03001EB81C67F1 crc Ok Vendor: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 Serial: 2013212 0x001EB81C MM/YY: 6/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__9121A7DDDD2CA DBD4E763DE3DF6321CB Stage: Android OS [2] WIPE... Skip for Strategy [oppo] [3] WIPE... Create partition image... Ok Ok [4] WIPE... Create partition image... Ok Ok [6] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 27 sec Reconnect Power/Cable now |
11-06-2024, 08:22 | #76445 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | S/N: 0073CA70CC v0161 Chinese Miracle II - MT2 Service Tool v2.63 Init log engine... Ok Build directories tree... Ok Firmware files: C:\Users\Master Mobile\Desktop\New folder\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 46 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Load IDBase v915508 Ok Load 158 profiles... Ok libusb: v1.2.6.0 Init environment... Ok Ready DA selected: Oppo | 2021 | MTK_AllInOne_DA_OP.bin Operation: Identify [ v2.63 ] Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM5) MODE [0]: PRELOADER PORT; PORT: 5 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 5DD8530012349CCFD0B8F0F47E24C1805042BD77D27D783897 D9AF6BA13ADF26 AGENT: [f2f720fb] C:\InfinityBox\CM2MT2\boot\Oppo\2021\MTK_AllInOne_ DA_OP.bin Looking for bootchain in DA... Found: MT6768; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM5) MODE [0]: PRELOADER PORT; PORT: 5 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 5DD8530012349CCFD0B8F0F47E24C1805042BD77D27D783897 D9AF6BA13ADF26 AGENT: [f2f720fb] C:\InfinityBox\CM2MT2\boot\Oppo\2021\MTK_AllInOne_ DA_OP.bin Looking for bootchain in DA... Found: MT6768; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA SEND Error: 0x00007024 SECURE BOOT: SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! PRELOADER Level: CORRECT DA required: PL/PL_CRYPTO/SWSEC Request config values... => Try loaders: 1. [0656ff20] 0_base/base_v2112/mtk_allinone_da.2021-07-12 2. [3365c4d2] 0_base/base_v2216/mtk_allinone_da.2022-04-10 3. [caf6df7e] infinix/2023-05/mtk_allinone_da.2023-05-10 4. [ddce4fa3] infinix/g70[g80][g90]/mtk_allinone_da_g7xg8xg9x 5. [07fb00a6] MTK_AllInOne_DA.1d5fdec4.bin 6. [1d5fdec4] MTK_AllInOne_DA.bin 7. [917c6560] oppo/a31/mtk_allinone_da read manual - https://infinity-box.com/?r=100189 Connection fault Disconnect battery and cable Be sure SoC drivers installed well Change cable and USB port, do not use USB-hub Select another base|model|DA Finished 18 sec Reconnect Power/Cable now DA selected: Oppo | 2022-10 | MTK_AllInOne_DA.bin Operation: Identify [ v2.63 ] Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... User break Finished 10 sec DA selected: Vivo | 1802 | MTK_AllInOne_DA.2018-04-19.66e419cc.bin DA selected: Vivo | 2023-08 | MTK_AllInOne_DA_v3.fdaaf7f6.bin Operation: Identify [ v2.63 ] Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM5) MODE [0]: PRELOADER PORT; PORT: 5 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 5DD8530012349CCFD0B8F0F47E24C1805042BD77D27D783897 D9AF6BA13ADF26 AGENT: [ecb438fd] C:\InfinityBox\CM2MT2\boot\Vivo\2023-08\MTK_AllInOne_DA_v3.fdaaf7f6.bin Looking for bootchain in DA... Found: MT6768; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100445636444D4202123B90BFA6AF crc Ok Vendor: Samsung OEM: 256 ID: 445636444D42 [DV6DMB] PRV: 0x02 Serial: 305893567 0x123B90BF MM/YY: 10/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1EC00000 [ 116.48 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 7AD10FBCA8E59514D1BD30A757F61D5C USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 12 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 44 STORAGE Life Status: eMMC : OK STORAGE OTP Status: UNLOCKED STORAGE RPMB Status: eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Saved: C:\InfinityBox\CM2MT2\phdata\key.json Probe boot... Ok 2 sec Product Brand: vivo Product Device: 1915 Product Model: vivo 1915 Product Name: 1915N SW: vivo/1915N/1915:12/SP1A.210812.003/compiler03291714:user/release-keys Patch Level: SP1A.210812.003 Display ID: SP1A.210812.003 release-keys SW Version: compiler03291714 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-03-01 Build Time: 3/29/2023 9:13:14 AM Product Info: k68v1_64 SW: full_k68v1_64-user 12 SP1A.210812.003 compiler03291714 release-keys Product Manfct: vivo Product Board: k68v1_64 Board Platform: mt6768 Device ID: vivo-1915-1915n-k68v1-64 Strategy: [vivo] Firmware ID: MT6768_vivo_vivo_1915_OSv12_SP1A.210812.003_k68v1_ 64 Verify firmware [MT6768_vivo_vivo_1915_OSv12_SP1A.210812.003_k68v1_ 64]... Exist (1) Analyze userdata... userData: fileSystem [ext4] with FBE [file based encryption] Backup to C:\InfinityBox\CM2MT2\backup\MT6768__905715D14212E 9435F53AAAF67D5C4C1\ Items to check: 22 Read [24] NVRAM NVRAM: Items: 0xB5 Size: 0x0F6BAF State: Ok WiFi MAC: 18E7776D91C5 BT MAC: 18E7776D91C4 IMEI[1]: IMEI[2]: Read [15] NVDATA Read [21] PROINFO Read [34] LK lk [94cbb538] Read [14] NVCFG Read [17] PROTECT1 Read [1] PGPT Read [16] PERSIST Read [0] PRELOADER Done 9 files 9 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6768__905715D14212E 9435F53AAAF67D5C4C1\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6768__905715D14212E 9435F53AAAF67D5C4C1.7z Enough [vivo-1915-1915n-k68v1-64] Analyze modem... BBK_R0MP1_K68V1_64_BSP_MDBIN_PCB01_MT6768_S00.MOLY _LR12A_R3_MP_V136_6_P187 Analyze nvram... PSN1: 0B1A517902370201 EMMC CID: 150100445636444D4202123B90BFA6AF crc Ok Vendor: Samsung OEM: 256 ID: 445636444D42 [DV6DMB] PRV: 0x02 Serial: 305893567 0x123B90BF MM/YY: 10/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1EC00000 [ 116.48 Gb ] Analyze preloader... EMI: MT6752 preloader_k68v1_64.bin with 11 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 150100335636434D42 Samsung 3V6CMB RAM: 6.00 Gb 4. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 6. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 13014E47314A395139 Micron G1J9Q9 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 13014E47314331324C Micron G1C12L RAM: 8.00 Gb 9. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb 10. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 8.00 Gb 11. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 6.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 68v1_64.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 68v1_64.bin [f2cd1e08]... Exist Probe FRP... Most probably Off Reset port... Finished 1 min 15 sec Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [+] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM5) MODE [0]: PRELOADER PORT; PORT: 5 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 5DD8530012349CCFD0B8F0F47E24C1805042BD77D27D783897 D9AF6BA13ADF26 AGENT: [ecb438fd] C:\InfinityBox\CM2MT2\boot\Vivo\2023-08\MTK_AllInOne_DA_v3.fdaaf7f6.bin Looking for bootchain in DA... Found: MT6768; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100445636444D4202123B90BFA6AF crc Ok Vendor: Samsung OEM: 256 ID: 445636444D42 [DV6DMB] PRV: 0x02 Serial: 305893567 0x123B90BF MM/YY: 10/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1EC00000 [ 116.48 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 7AD10FBCA8E59514D1BD30A757F61D5C USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 13 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 44 Probe boot... Ok 2 sec Product Brand: vivo Product Device: 1915 Product Model: vivo 1915 Product Name: 1915N SW: vivo/1915N/1915:12/SP1A.210812.003/compiler03291714:user/release-keys Patch Level: SP1A.210812.003 Display ID: SP1A.210812.003 release-keys SW Version: compiler03291714 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-03-01 Build Time: 3/29/2023 9:13:14 AM Product Info: k68v1_64 SW: full_k68v1_64-user 12 SP1A.210812.003 compiler03291714 release-keys Product Manfct: vivo Product Board: k68v1_64 Board Platform: mt6768 Device ID: vivo-1915-1915n-k68v1-64 Strategy: [vivo] Firmware ID: MT6768_vivo_vivo_1915_OSv12_SP1A.210812.003_k68v1_ 64 Android ver: 12 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 150100445636444D4202123B90BFA6AF crc Ok Vendor: Samsung OEM: 256 ID: 445636444D42 [DV6DMB] PRV: 0x02 Serial: 305893567 0x123B90BF MM/YY: 10/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1EC00000 [ 116.48 Gb ] Backup exist: C:\InfinityBox\CM2MT2\backup\MT6768__905715D14212E 9435F53AAAF67D5C4C1 Stage: Android OS [1] WIPE... Skip for Strategy [vivo] [2] WIPE... Skip for Strategy [vivo] [3] WIPE... Create partition image... Ok Ok [4] WIPE... Create partition image... Ok Ok [6] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Ok Reset port... Trying to reboot... Finished 30 sec Reconnect Power/Cable now |
11-06-2024, 08:29 | #76446 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | S/N: 0073CA70CC v0161 Chinese Miracle II - MT2 Service Tool v2.63 Init log engine... Ok Build directories tree... Ok Firmware files: C:\Users\Master Mobile\Desktop\New folder\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 47 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Load IDBase v915508 Ok Load 158 profiles... Ok libusb: v1.2.6.0 Init environment... Ok Ready Operation: Identify [ v2.63 ] Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM6) MODE [0]: BOOTROM; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6735 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0335 TYPE: LEGACY [MTK] MEID: EEF2E564CCBA0D9C6CAC747C89585541 BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0x05 BL: 0xFE [BOOTROM] BROM: EMI: Search EMI: Continue EMI: Found AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6735; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started NAND: DEVICE NOT FOUND EMMC: OK CID: 90014A483847346132A4250010040199 DA v4.2.155 EXT_RAM NOT initialized EMMC: OK CID: 484A0190613447380025A43299010410 NAND: DEVICE NOT FOUND DRAM: 0x00BC EMI: FireFly preloader_m01_32_35m.bin with 8 memory type(s) 1. ID: 90014A483847316505 Hynix H8G1e RAM: 1.00 Gb 2. ID: 150100513758534142 Samsung Q7XSAB RAM: 1.00 Gb 3. ID: 150100513732534D42 Samsung Q72SMB RAM: 1.00 Gb 4. ID: 150100464E31324D42 Samsung FN12MB RAM: 1.00 Gb 5. ID: 150100464E58324D42 Samsung FNX2MB RAM: 1.00 Gb 6. ID: 150100463732324D42 Samsung F722MB RAM: 1.00 Gb 7. ID: 90014A483847346132 Hynix H8G4a2 RAM: 1.00 Gb 8. ID: 90014A483847346192 Hynix H8G4a? RAM: 1.00 Gb INIT: 0x00BC DRAM [ 0x00000000 [ 0 B ] ] RAM: DRAM: 0x40000000 [ 1.00 Gb ] DA: DRAM ready Boot to 2nd DA... Ok Load HW info... EMMC CID: 90014A483847346132A4250010049699 crc Ok Vendor: Hynix OEM: 330 ID: 483847346132 [H8G4a2] PRV: 0xA4 Serial: 620761092 0x25001004 MM/YY: 9/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x1D2000000 [ 7.28 Gb ] RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0x40000000 [ 1024.00 Mb ] CHIP: MT6735 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0335 TYPE: LEGACY [MTK] RNID: 43716A30BA0812A70A98B1D2DE686517 MEID: EEF2E564CCBA0D9C6CAC747C89585541 DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: FULL-SPEED Set port Speed... PTFN: MediaTek DA USB VCOM (Android) (COM28) MODE: PRELOADER PORT; PORT: 28 Boot done LEGACY [MTK] 10 sec Analyze PMT... Ok PMT: LGPT [0x06] Records: 26 Saved: C:\InfinityBox\CM2MT2\phdata\key.json Probe boot... Ok 719 us Patch Level: NRD90M Display ID: CALME_4G_LITE_V03_F SW Version: 1721382230 Ver. CodeName: REL Ver. Release: 7.0 Sec. Patch: 2017-05-05 Build Time: 7/19/2024 9:43:48 AM Product Model: 4G LITE Product Brand: CALME Product Name: full_m01_32_35m Product Device: m01_32_35m CPU: armeabi-v7a,armeabi Product Manfct: CALME Board Platform: mt6735m Product Info: m01_32_35m SW: full_m01_32_35m-user 7.0 NRD90M 1721382230 test-keys Device ID: calme-4g-lite-m01-32-35m-full-m01-32-35m Strategy: [none|generic] Firmware ID: MT6735M_CALME_4G_LITE_OSv7.0_CALME_4G_LITE_V03_F_N RD90M_m01_32_35m Verify firmware [MT6735M_CALME_4G_LITE_OSv7.0_CALME_4G_LITE_V03_F_N RD90M_m01_32_35m]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem [ext4] with FDE [encryptable] Backup to C:\InfinityBox\CM2MT2\backup\MT6735__EEF2E564CCBA0 D9C6CAC747C89585541\ Items to check: 22 Read [3] NVRAM NVRAM: Items: 0x12D Size: 0x067840 State: Ok WiFi MAC: 001297110622 BT MAC: 000046033501 IMEI[1]: IMEI[2]: Read [19] NVDATA Read [2] PROINFO Read [6] LK lk [e934a948] Read [4] PROTECT1 lda-pt: pgpt Read [0] PRELOADER Done 6 files 9 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6735__EEF2E564CCBA0 D9C6CAC747C89585541\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6735__EEF2E564CCBA0 D9C6CAC747C89585541.7z Enough [calme-4g-lite-m01-32-35m-full-m01-32-35m] Analyze modem... Nothing Analyze nvram... PSN1: N/A EMMC CID: 90014A483847346132A4250010049699 crc Ok Vendor: Hynix OEM: 330 ID: 483847346132 [H8G4a2] PRV: 0xA4 Serial: 620761092 0x25001004 MM/YY: 9/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x1D2000000 [ 7.28 Gb ] Analyze preloader... EMI: MT6752 preloader_m01_32_35m.bin with 8 memory type(s) 1. eMMC DDR3 ID: 90014A483847316505 Hynix H8G1e RAM: 1.00 Gb 2. eMMC DDR3 ID: 150100513758534142 Samsung Q7XSAB RAM: 1.00 Gb 3. eMMC DDR3 ID: 150100513732534D42 Samsung Q72SMB RAM: 1.00 Gb 4. eMMC DDR3 ID: 150100464E31324D42 Samsung FN12MB RAM: 1.00 Gb 5. eMMC DDR3 ID: 150100464E58324D42 Samsung FNX2MB RAM: 1.00 Gb 6. eMMC DDR3 ID: 150100463732324D42 Samsung F722MB RAM: 1.00 Gb 7. eMMC DDR3 ID: 90014A483847346132 Hynix H8G4a2 RAM: 1.00 Gb 8. eMMC DDR3 ID: 90014A483847346192 Hynix H8G4a? RAM: 1.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_m 01_32_35m.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_m 01_32_35m.bin [5020b4ac]... Exist Probe FRP... Most probably Off Reset port... Finished 42 sec Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [+] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM6) MODE [0]: BOOTROM; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6735 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0335 TYPE: LEGACY [MTK] MEID: EEF2E564CCBA0D9C6CAC747C89585541 BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0x05 BL: 0xFE [BOOTROM] EMI loaded by MEID: EEF2E564CCBA0D9C6CAC747C89585541 AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6735; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started NAND: DEVICE NOT FOUND EMMC: OK CID: 90014A483847346132A4250010040199 DA v4.2.155 EXT_RAM NOT initialized EMMC: OK CID: 484A0190613447380025A43299010410 NAND: DEVICE NOT FOUND DRAM: 0x00BC EMI: FireFly preloader_m01_32_35m.bin with 8 memory type(s) 1. ID: 90014A483847316505 Hynix H8G1e RAM: 1.00 Gb 2. ID: 150100513758534142 Samsung Q7XSAB RAM: 1.00 Gb 3. ID: 150100513732534D42 Samsung Q72SMB RAM: 1.00 Gb 4. ID: 150100464E31324D42 Samsung FN12MB RAM: 1.00 Gb 5. ID: 150100464E58324D42 Samsung FNX2MB RAM: 1.00 Gb 6. ID: 150100463732324D42 Samsung F722MB RAM: 1.00 Gb 7. ID: 90014A483847346132 Hynix H8G4a2 RAM: 1.00 Gb 8. ID: 90014A483847346192 Hynix H8G4a? RAM: 1.00 Gb INIT: 0x00BC DRAM [ 0x00000000 [ 0 B ] ] RAM: DRAM: 0x40000000 [ 1.00 Gb ] DA: DRAM ready Boot to 2nd DA... Ok Load HW info... EMMC CID: 90014A483847346132A4250010049699 crc Ok Vendor: Hynix OEM: 330 ID: 483847346132 [H8G4a2] PRV: 0xA4 Serial: 620761092 0x25001004 MM/YY: 9/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x1D2000000 [ 7.28 Gb ] RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0x40000000 [ 1024.00 Mb ] CHIP: MT6735 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0335 TYPE: LEGACY [MTK] RNID: 43716A30BA0812A70A98B1D2DE686517 MEID: EEF2E564CCBA0D9C6CAC747C89585541 DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: FULL-SPEED Set port Speed... PTFN: MediaTek DA USB VCOM (Android) (COM28) MODE: PRELOADER PORT; PORT: 28 Boot done LEGACY [MTK] 11 sec Analyze PMT... Ok PMT: LGPT [0x06] Records: 26 Probe boot... Ok 734 us Patch Level: NRD90M Display ID: CALME_4G_LITE_V03_F SW Version: 1721382230 Ver. CodeName: REL Ver. Release: 7.0 Sec. Patch: 2017-05-05 Build Time: 7/19/2024 9:43:48 AM Product Model: 4G LITE Product Brand: CALME Product Name: full_m01_32_35m Product Device: m01_32_35m CPU: armeabi-v7a,armeabi Product Manfct: CALME Board Platform: mt6735m Product Info: m01_32_35m SW: full_m01_32_35m-user 7.0 NRD90M 1721382230 test-keys Device ID: calme-4g-lite-m01-32-35m-full-m01-32-35m Strategy: [none|generic] Firmware ID: MT6735M_CALME_4G_LITE_OSv7.0_CALME_4G_LITE_V03_F_N RD90M_m01_32_35m Android ver: 7 UserDataFS: 0x01 [ext4|4+] CacheFS: 0x01 [ext4|4+] EMMC CID: 90014A483847346132A4250010049699 crc Ok Vendor: Hynix OEM: 330 ID: 483847346132 [H8G4a2] PRV: 0xA4 Serial: 620761092 0x25001004 MM/YY: 9/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x1D2000000 [ 7.28 Gb ] Backup exist: C:\InfinityBox\CM2MT2\backup\MT6735__EEF2E564CCBA0 D9C6CAC747C89585541 Stage: Android OS [2] WIPE... Ok [3] WIPE... Create partition image... Ok Ok [4] WIPE... Create partition image... Ok Ok [6] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 28 sec Reconnect Power/Cable now |
11-06-2024, 13:10 | #76447 (permalink) |
No Life Poster Join Date: Apr 2008 Location: nigeria
Member: 757064 Status: Offline Sonork: 11111111 Thanks Meter: 381 | nokia ta-1433 password and frp successfull remove CM2 - SP3 Service Tool v2.30 probe UAC... Ok Wait... S/N: skyulockv0163 initalize log engine... Ok Build directories tree... Backup files: C:\InfinityBox\CM2SP3\backup\ Backup files: 0 dirs: 0 Check for updates [CM2SP3]... You have latest version [2.30] installed Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Sales: https://infinity-box.com/buy/ Account: https://infinity-box.com/service/ Get list of devices... Ok Loaded 2 new of 1630 devices Build device list... Ok 1638 Ready Select SoC/Device or [Get boot files] Select SoC/Device or [Get boot files] Select SoC or device Get loader info... update required Get Nokia/C21-plus Install... Ok Get loader info... Ok Finished 1 min 1 sec Selected: Nokia C21-plus Boot [FF] FireFly nor Boot [FF] FireFly protocol may be SLOW. For flash Read/Write use Boot [FDL] Factory Operation: Connect Nokia C21-plus Boot [FF] FireFly [v2.30] Wait... Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... User break Canceled Finished 42 sec Operation: Connect Nokia C21-plus Boot [FF] FireFly [v2.30] Wait... Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... Device found PTFN: SPRD U2S Diag (COM78) vid 0x1782 pid 0x4D00 boot: SPRD3 boot iLoader... Ok start iLoader... Ok Handshake... Ok boot xLoader... Ok start FireFly... Ok Loader exec Ok Dev UID: 740cc09febe2e285a491e8ccfee70cee10812050f9f13a96f2 5cb61c2a20aafa stored 6 hwid cache items get storage info... MMC EMMC CID: D60103413341353531123B0011D0C909 crc Ok Vendor: Foresee OEM: 259 ID: 413341353531 [A3A551] PRV: 0x12 Serial: 989860304 0x3B0011D0 MM/YY: 12/2022 CSD: D0FFFF329F5903FFFFFFFFEF964000FF temp_write_protect: False perm_write_protect: False wp_group: 0x10 en 0x01 read extcsd... Ok EXTCSD rev1.8 EMMC 5.1 FW: 12 ERASE_GROUP_DEF: 0x0400 BOOT_BUS_WIDTH: 0x00 PARTITION_CONFIG: 0x08 RST_N_FUNCTION: 0x01 PART_S_COMPLETED: False BOOT size: 0x400000 RPMB size: 0x1000000 16.00 Mb WP_GRP_SIZE: 0x800000 8.00 Mb Size: Market 32 Gb Actual 0x73A000000 28.91 Gb EOL: Status: Normal: Less than 80% reserved blocks used EOL_A: SLC status: 40% - 50% used EOL_B: MLC status: Not defined extcsd stored: C:\InfinityBox\CM2SP3\backup\ext_csd\none_740cc09f ebe2e285_extcsd_00D6-Foresee_A3A551_5.1_2024-11-06.bin get partitions... Load primary GPT... Load secondary GPT... Primary GPT state Ok Secondary GPT state Ok Partitions: 79 Connected get sw info... 5 sec SW: Nokia/Hope_00WW/HPE:11/RP1A.201005.001/00WW_1_27H:user/release-keys Product Brand: Nokia Product Model: Nokia C21 Plus Product Device: HPE Patch Level: RP1A.201005.001 Display ID: 00WW_1_270_SP05 SW Version: 00WW_1_27H Product Info: HPE Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2024-03-01 Build Time: 18/03/2024 10:44:21 CPU: armeabi-v7a,armeabi SW: T19661AA1_Natv-user 11 RP1A.201005.001 12134 release-keys Product Board: Hope Board Platform: sp9863a Product Manfct: HMD Global Android ver: 11 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Device ID: hpe-hmd-global-nokia-c21-plus-hpe-hope Strategy: [nokia] Firmware ID: SP9863A_HMD_Global_Nokia_C21_Plus_OSv11_00WW_1_270 _SP05_RP1A.201005.001_HPE Backup 11 items to: C:\InfinityBox\CM2SP3\backup\sp9863a_740cc09febe2e 285\ Read to C:\InfinityBox\CM2SP3\backup\sp9863a_740cc09febe2e 285\ Reading... Read [1/79] prodnv 10.00 Mb Ok Read [3/79] miscdata 1024.00 Kb Ok Read [9/79] protect_data 8.00 Mb Ok Read [10/79] uboot_a 1024.00 Kb Ok Read [11/79] uboot_b 1024.00 Kb Ok Read [16/79] l_fixnv1_a 2.00 Mb Ok Read [17/79] l_fixnv2_a 2.00 Mb Ok Read [18/79] l_fixnv1_b 2.00 Mb Ok Read [19/79] l_fixnv2_b 2.00 Mb Ok Estimated time to end 9 sec Read [78/79] splloader 4.00 Mb Ok Read [79/79] splloader_bak 4.00 Mb Ok Saved 11 of 11 images. 37.00 Mb of 37.00 Mb Done 11 files Compress: C:\InfinityBox\CM2SP3\backup\sp9863a_740cc09febe2e 285\ Cleanup... Ok Verify C:\InfinityBox\CM2SP3\backup\sp9863a_740cc09febe2e 285.7z Verified [4ed4da50] get slots... slot: b [MemTool] load 79 items Finished 23 min 18 sec Operation: Reset | Format Nokia C21-plus Boot [FF] FireFly [v2.30] WARNING: Reset may delete ALL USER DATA! Continue? Yes [-] Wipe [+] Userdata [+] FRP [+] Smart Wait... Partitions: 79 Backup exist: C:\InfinityBox\CM2SP3\backup\sp9863a_740cc09febe2e 285\ Process FRP... Looking for items... 1 items found [1] Writing... Ok Process Userdata... [1] Format... Ok 15 sec [2] Format... Ok 3 sec [3] Format... [erase] [metadata] addr 0x106C00000+0000 size 0x1000000 Completed Process nvram... [20] Format... [erase] [l_runtimenv1] addr 0x4800000+0000 size 0x200000 Nothing Finished 29 sec |
The Following User Says Thank You to skyulock For This Useful Post: |
11-07-2024, 11:09 | #76449 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,436 | Pd1732f_ex Operation: Reset Settings/Format FS [ v2.74 ] WARNING: Reset may delete ALL USER DATA! Wipe Off; Userdata On; FRP On; Accounts Off; Smart Analyzer On Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM7) MODE: PRELOADER PORT; PORT: 7 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino Type: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005; Mode: SBC+SDA Ver: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: CF00441021A9A14F74E7528CFBFFB51E6A96F9846BA6E2EB7C 6FDFD030B2EF9A Agent: [ecb438fd] C:\InfinityBox\CM2MT2\boot\Vivo\2023-08\MTK_AllInOne_DA_v3.fdaaf7f6.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending DA1... Ok [1|1|0|0] Jump to DA... Ok Sync... Ok DA sync... Ok DA Set Params... Ok Mode: PRELOADER [1|1|0|0] EXT_RAM initialized Boot DA2... Ok [1|1|1|28] DA Sync... Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 150100475036424D4201BDEDD8F4858B crc Ok Vendor: Samsung OEM: 256 ID: 475036424D42 [GP6BMB] PRV: 0x01 Serial: 3186481396 0xBDEDD8F4 MM/YY: 8/2018 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino Type: MODERN [RAPHAEL] RNID: 18889C2C02636D291D39A27565BFFD87 USB: HIGH-SPEED SoC drivers: MediaTek PreLoader USB VCOM_V1632 (Android) v3.0.1504.0; Boot done MODERN [RAPHAEL] 7 sec Analyze PMT... Ok Partition table: PGPT [0x64] with 43 records Device has no slots Probe boot... Ok 656 us AndroidInfo: recovery;gzip;bootimage/loaded ramsidk size 0xD8AF3C/1EF6C00; Patch Level: O11019 Display ID: O11019 release-keys SW Version: 1625667558 Ver. CodeName: REL Ver. Release: 8.1.0 Sec. Patch: 2021-05-01 Build Time: 07-Jul-21 2:19:12 PM Product Model: vivo 1808 Product Brand: vivo Product Name: PD1732F_EX Product Device: PD1732F_EX CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: vivo Product Info: k62v1_64_bsp SW: full_k62v1_64_bsp-user 8.1.0 O11019 1625667558 release-keys Product Model: PD1732F_EX Product Board: k62v1_64_bsp Board Platform: mt6765 Device ID: vivo-1808-pd1732f-ex-k62v1-64-bsp-full-k62v1-64-bsp Strategy: [vivo] Firmware ID: MT6765_vivo_PD1732F_EX_OSv8.1.0_O11019_k62v1_64_bs p Android ver: 8 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Reset: Userdata... [1] userdata... Create partition image... Make filesystem [0x02 ext4|8+]... Ok Ok Ok [2] cache... Create partition image... Make filesystem [0x02 ext4|8+]... Ok Ok Ok [4] metadata... process [metadata]... Ok verify [metadata] 128.00 Kb... reread... Ok Ok Reset: FRP... process [frp]... Ok verify [frp] 128.00 Kb... rewrite... Ok Completed Finished Reset Settings/Format FS [ v2.74 ] 28 sec Keep connection |
11-07-2024, 11:16 | #76450 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,436 | Oppo CPH2269 Operation: Reset Settings/Format FS [ v2.74 ] WARNING: Reset may delete ALL USER DATA! Wipe Off; Userdata On; FRP On; Accounts Off; Smart Analyzer On Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE: PRELOADER PORT; PORT: 3 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino Type: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005; Mode: SBC+SDA Ver: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: D927D2F90A891BB769DA688F5B234711B475017E600C9693F9 A92C8A0B4B5360 Agent: [ab6a11d9] C:\InfinityBox\CM2MT2\boot\Oppo\2022-10\MTK_AllInOne_DA.5419c171.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending DA1... Ok [1|1|0|0] Jump to DA... Ok Sync... Ok DA sync... Ok DA Set Params... Ok Mode: PRELOADER [1|1|0|0] EXT_RAM initialized Boot DA2... Ok [1|1|1|28] DA Sync... Ok Load HW info... RAM: SRAM: 0x00038000 [ 224.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 1501004450364442420282CADCC4B849 crc Ok Vendor: Samsung OEM: 256 ID: 445036444242 [DP6DBB] PRV: 0x02 Serial: 2194332868 0x82CADCC4 MM/YY: 11/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino Type: MODERN [RAPHAEL] RNID: FF2C56023C409835F0C3F2E626E77E48 USB: HIGH-SPEED SoC drivers: MediaTek PreLoader USB VCOM_V1632 (Android) v3.0.1504.0; Boot done MODERN [RAPHAEL] 1 min 7 sec Analyze PMT... Ok Partition table: PGPT [0x64] with 48 records Device has no slots Probe boot... Finished 2 sec AndroidInfo: vendor_boot;ramdisk size=0;recovery;gzip;bootimage/loaded ramsidk size 0x2CC6893/60ECE00;boot;gzip;bootimage/loaded ramsidk size 0x15E5E9/2FBB00; Probe core... Mount[erofs] wo/cache system@super 0x0062300000/0x2BD99000 Mount[erofs] wo/cache system_ext@super 0x0056DB7000/0x0B549000 fs: nid 9539608 datalayout 0x03 not supported; Mount[erofs] wo/cache vendor@super 0x0040900000/0x16469000 Mount[ext4] wo/cache product@super 0x00DF900000/0x0020C000 fs: nid 356853 datalayout 0x03 not supported; Mount[erofs] wo/cache odm@super 0x00DFC00000/0x0878F000 Finished 1 sec Probe uboot... Finished 172 us Probe items... Finished 0 us Device ID: MT6765_CPH2269_export_11_A.09_2021112614370115 Strategy: [oppo] Firmware ID: MT6765.MT6765_CPH2269_export_11_A.09_2021112614370 115 Android ver: 9 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Reset: Userdata... [1] userdata... Create partition image... Make filesystem [0x03 f2fs]... Ok Ok Ok [2] cache... Create partition image... Make filesystem [0x02 ext4|8+]... Ok Ok Ok [4] metadata... process [metadata]... Ok verify [metadata] 128.00 Kb... reread... Ok Ok [5] md_udc... process [md_udc]... Ok verify [md_udc] 128.00 Kb... reread... Ok Ok Reset: FRP... process [frp]... Ok verify [frp] 128.00 Kb... rewrite... Ok Completed Finished Reset Settings/Format FS [ v2.74 ] 1 min 29 sec Keep connection |
11-07-2024, 11:23 | #76451 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,436 | Infinix-X609 Operation: Reset Settings/Format FS [ v2.74 ] WARNING: Reset may delete ALL USER DATA! Wipe Off; Userdata On; FRP On; Accounts Off; Smart Analyzer On Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM7) MODE: PRELOADER PORT; PORT: 7 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6580 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x6580 SWv: 0x0000 Evo: 0x0000 Type: LEGACY [MTK] BROM: Sec Level: 0x00000005; Mode: SBC+SDA Ver: 0xFF BL: 0x01 [PRELOADER PORT] Agent: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6580; DA: MTK_DOWNLOAD_AGENT BROM: Sending DA1... Reset Interface [1|0|0|0] PTFN: MediaTek USB Port_V1632 (COM6) MODE: BOOTROM; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6580 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x6580 SWv: 0x0000 Evo: 0x0000 Type: LEGACY [MTK] MEID: BC68CBC38A4A9FA6E4277DF4778DB635 BROM: Sec Level: 0x00000005; Mode: SBC+SDA Ver: 0x05 BL: 0xFE [BOOTROM] SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok [FF] Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x00000001 EMI loaded by MEID: BC68CBC38A4A9FA6E4277DF4778DB635 Agent: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6580; DA: MTK_DOWNLOAD_AGENT BROM: Sending DA1... Ok [1|0|0|0] Jump to DA... Ok Sync... Ok NAND: DEVICE NOT FOUND EMMC: OK CID: 460001154D32364520A20342CF16C1D4 DA v4.2.156 EXT_RAM NOT initialized EMMC: OK CID: 150100464536324D4203A220D4C116CF NAND: DEVICE NOT FOUND DRAM: 0x00BC EMI: FireFly preloader_bsp_h8025.bin with 10 memory types slots: no 1. eMMC DDR3 ID: 150100513732534D42 Samsung Q72SMB RAM: 1.00 Gb 2. eMMC DDR2 ID: 90014A483847316505 Hynix H8G1e RAM: 1.00 Gb 3. eMMC DDR2 ID: ADDE14A7424AAD Unknown 0x00AD §BJ* RAM: 512.00 Mb 4. eMMC DDR3 ID: 150100464536324D42 Samsung FE62MB RAM: 1.00 Gb 5. eMMC DDR3 ID: 700100454841454538 Kingston EHAEE8 RAM: 1.00 Gb 6. eMMC DDR3 ID: 700100454838454434 Kingston EH8ED4 RAM: 512.00 Mb 7. eMMC DDR3 ID: 150100464E36324D42 Samsung FN62MB RAM: 1.00 Gb 8. eMMC DDR3 ID: 700100454838434434 Kingston EH8CD4 RAM: 512.00 Mb 9. eMMC DDR3 ID: 150100464E58324D42 Samsung FNX2MB RAM: 1.00 Gb 10. eMMC DDR3 ID: 700100464D41454538 Kingston FMAEE8 RAM: 1.00 Gb INIT: 0x00BC DRAM [ 0x00000000 0 b ] RAM: DRAM: 0x400000001024.00 Mb DA: DRAM ready Boot DA2... Ok Load HW info... EMMC CID: 150100464536324D4203A220D4C116CF crc Ok Vendor: Samsung OEM: 256 ID: 464536324D42 [FE62MB] PRV: 0x03 Serial: 2720060609 0xA220D4C1 MM/YY: 1/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x3A3E00000 [ 14.56 Gb ] RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0x40000000 [ 1024.00 Mb ] CHIP: MT6580 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x6580 SWv: 0x0000 Evo: 0x0000 Type: LEGACY [MTK] RNID: 768C312ECE01177F54BBF06B576EC424 MEID: BC68CBC38A4A9FA6E4277DF4778DB635 DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: FULL-SPEED Set port High-Speed... PTFN: MediaTek DA USB VCOM (Android) (COM4) MODE: PRELOADER PORT; PORT: 4 SoC drivers: MediaTek DA USB VCOM (Android) v3.0.1504.0; Boot done LEGACY [MTK] 38 sec Analyze PMT... Ok Partition table LGPT [0x06] with 31 records Device has no slots Probe boot... Ok 937 us AndroidInfo: recovery;gzip;bootimage/loaded ramsidk size 0x48A2FB/786700; Patch Level: O11019 Display ID: X609-H8025AB-OGo-200820V222 SW Version: AB-200820V222 Ver. CodeName: REL Ver. Release: 8.1.0 Sec. Patch: 2020-09-05 Build Time: 20-Aug-20 9:40:07 AM Product Brand: Infinix Product Name: H8025 Product Device: Infinix-X609 Product Info: Infinix-X609 Product Model: Infinix X609 Product Manfct: INFINIX MOBILITY LIMITED Market Name: Infinix Smart 2 HD CPU: armeabi-v7a,armeabi SW: full_bsp_h8025-user 8.1.0 O11019 1597916422 release-keys Product Board: Infinix-X609 Board Platform: mt6580 Device ID: infinix-mobility-limited-infinix-x609-h8025-infinix-smart-2-hd Strategy: [infinix] Firmware ID: MT6580_INFINIX_MOBILITY_LIMITED_Infinix_X609_OSv8. 1.0_X609-H8025AB-OGo-200820V222_O11019_Infinix-X609 Android ver: 8 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Reset: Userdata... [1] userdata... Create partition image... Make filesystem [0x03 f2fs]... Ok Ok Ok [2] cache... Create partition image... Make filesystem [0x02 ext4|8+]... Ok Ok Ok [4] metadata... process [metadata]... Ok Ok Reset: FRP... process [frp]... Ok Completed Finished Reset Settings/Format FS [ v2.74 ] 54 sec Keep connection |
11-07-2024, 13:09 | #76452 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,778 | S/N: 0073CA70CC v0161 Chinese Miracle II - MT2 Service Tool v2.63 Init log engine... Ok Build directories tree... Ok Firmware files: C:\Users\Master Mobile\Desktop\New folder\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 47 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Load IDBase v915508 Ok Load 158 profiles... Ok libusb: v1.2.6.0 Init environment... Ok Ready Operation: Read Flash [ v2.63 ] Destination: C:\Users\Master Mobile\Desktop\New folder\ Disk free space: 75.54 Gb Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM6) MODE [0]: BOOTROM; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6735 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0335 TYPE: LEGACY [MTK] MEID: EEF2E564CCBA0D9C6CAC747C89585541 BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0x05 BL: 0xFE [BOOTROM] EMI loaded by MEID: EEF2E564CCBA0D9C6CAC747C89585541 AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6735; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started NAND: DEVICE NOT FOUND EMMC: OK CID: 90014A483847346132A4250010040199 DA v4.2.155 EXT_RAM NOT initialized EMMC: OK CID: 484A0190613447380025A43299010410 NAND: DEVICE NOT FOUND DRAM: 0x00BC EMI: FireFly preloader_m01_32_35m.bin with 8 memory type(s) 1. ID: 90014A483847316505 Hynix H8G1e RAM: 1.00 Gb 2. ID: 150100513758534142 Samsung Q7XSAB RAM: 1.00 Gb 3. ID: 150100513732534D42 Samsung Q72SMB RAM: 1.00 Gb 4. ID: 150100464E31324D42 Samsung FN12MB RAM: 1.00 Gb 5. ID: 150100464E58324D42 Samsung FNX2MB RAM: 1.00 Gb 6. ID: 150100463732324D42 Samsung F722MB RAM: 1.00 Gb 7. ID: 90014A483847346132 Hynix H8G4a2 RAM: 1.00 Gb 8. ID: 90014A483847346192 Hynix H8G4a? RAM: 1.00 Gb INIT: 0x00BC DRAM [ 0x00000000 [ 0 B ] ] RAM: DRAM: 0x40000000 [ 1.00 Gb ] DA: DRAM ready Boot to 2nd DA... Ok Load HW info... EMMC CID: 90014A483847346132A4250010049699 crc Ok Vendor: Hynix OEM: 330 ID: 483847346132 [H8G4a2] PRV: 0xA4 Serial: 620761092 0x25001004 MM/YY: 9/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x1D2000000 [ 7.28 Gb ] RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0x40000000 [ 1024.00 Mb ] CHIP: MT6735 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0335 TYPE: LEGACY [MTK] RNID: 43716A30BA0812A70A98B1D2DE686517 MEID: EEF2E564CCBA0D9C6CAC747C89585541 DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: FULL-SPEED Set port Speed... Can not setup HIGH-SPEED USB port Set [HIGH-SPEED] Off and try again Fail to init protocol Disconnect battery and cable Be sure SoC drivers installed well Change cable and USB port, do not use USB-hub Select another base|model|DA Finished 31 sec Reconnect Power/Cable now Operation: Read Flash [ v2.63 ] Destination: C:\Users\Master Mobile\Desktop\New folder\ Disk free space: 75.54 Gb Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM13) MODE [0]: BOOTROM; PORT: 13 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6735 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0335 TYPE: LEGACY [MTK] MEID: EEF2E564CCBA0D9C6CAC747C89585541 BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0x05 BL: 0xFE [BOOTROM] EMI loaded by MEID: EEF2E564CCBA0D9C6CAC747C89585541 AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6735; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started NAND: DEVICE NOT FOUND EMMC: OK CID: 90014A483847346132A4250010040199 DA v4.2.155 EXT_RAM NOT initialized EMMC: OK CID: 484A0190613447380025A43299010410 NAND: DEVICE NOT FOUND DRAM: 0x00BC EMI: FireFly preloader_m01_32_35m.bin with 8 memory type(s) 1. ID: 90014A483847316505 Hynix H8G1e RAM: 1.00 Gb 2. ID: 150100513758534142 Samsung Q7XSAB RAM: 1.00 Gb 3. ID: 150100513732534D42 Samsung Q72SMB RAM: 1.00 Gb 4. ID: 150100464E31324D42 Samsung FN12MB RAM: 1.00 Gb 5. ID: 150100464E58324D42 Samsung FNX2MB RAM: 1.00 Gb 6. ID: 150100463732324D42 Samsung F722MB RAM: 1.00 Gb 7. ID: 90014A483847346132 Hynix H8G4a2 RAM: 1.00 Gb 8. ID: 90014A483847346192 Hynix H8G4a? RAM: 1.00 Gb INIT: 0x00BC DRAM [ 0x00000000 [ 0 B ] ] RAM: DRAM: 0x40000000 [ 1.00 Gb ] DA: DRAM ready Boot to 2nd DA... Ok Load HW info... EMMC CID: 90014A483847346132A4250010049699 crc Ok Vendor: Hynix OEM: 330 ID: 483847346132 [H8G4a2] PRV: 0xA4 Serial: 620761092 0x25001004 MM/YY: 9/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x1D2000000 [ 7.28 Gb ] RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0x40000000 [ 1024.00 Mb ] CHIP: MT6735 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0335 TYPE: LEGACY [MTK] RNID: 43716A30BA0812A70A98B1D2DE686517 MEID: EEF2E564CCBA0D9C6CAC747C89585541 DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: FULL-SPEED Set port Speed... PTFN: MediaTek DA USB VCOM (Android) (COM29) MODE: PRELOADER PORT; PORT: 29 Boot done LEGACY [MTK] 10 sec Analyze PMT... Ok PMT: LGPT [0x06] Records: 26 Probe boot... Ok 703 us Patch Level: NRD90M Display ID: CALME_4G_LITE_V03_F SW Version: 1721382230 Ver. CodeName: REL Ver. Release: 7.0 Sec. Patch: 2017-05-05 Build Time: 7/19/2024 9:43:48 AM Product Model: 4G LITE Product Brand: CALME Product Name: full_m01_32_35m Product Device: m01_32_35m CPU: armeabi-v7a,armeabi Product Manfct: CALME Board Platform: mt6735m Product Info: m01_32_35m SW: full_m01_32_35m-user 7.0 NRD90M 1721382230 test-keys Device ID: calme-4g-lite-m01-32-35m-full-m01-32-35m Strategy: [none|generic] Firmware ID: MT6735M_CALME_4G_LITE_OSv7.0_CALME_4G_LITE_V03_F_N RD90M_m01_32_35m Total size to read: 2.07 Gb Read [1/26]: preloader.bin 4.00 Mb Process file... Ok Ok [ 122.00 Kb ] Read [3/26]: proinfo.img 3.00 Mb Process file... Ok Ok [ 336 B ] Read [4/26]: nvram.bin 5.00 Mb Process file... Ok Ok [ 4.88 Mb ] Read [7/26]: lk.bin 512.00 Kb Process file... Ok Ok [ 292.25 Kb ] Read [9/26]: boot.img 16.00 Mb Process file... Ok Ok [ 8.36 Mb ] Read [10/26]: recovery.img 16.00 Mb Process file... Ok Ok [ 9.67 Mb ] Estimated time to end 6 min 44 sec Read [11/26]: logo.bin 8.00 Mb Process file... Ok Ok [ 120.25 Kb ] Read [15/26]: secro.img 6.00 Mb Process file... Ok Ok [ 132.25 Kb ] Read [17/26]: tz.img 5.00 Mb Process file... Ok Ok [ 62.78 Kb ] Read [18/26]: tz.img 5.00 Mb Read [22/26]: system.img 2.00 Gb Process file... Sparse... Compression ratio: 45% Ok Ok [ 1.11 Gb ] Build [23/26]: cache.img 400.00 Mb Create partition image... Ok Ok [ 0 B ] Build [24/26]: userdata.img 4.70 Gb Create partition image... Ok Ok [ 0 B ] Gathering image info... Build scat... Ok FW Size: 1.13 Gb Android Info saved: _Android_info.txt Scatter: MT6735M_Android_scatter.txt Saved: C:\Users\Master Mobile\Desktop\New folder\MT6735M_CALME_4G_LITE_OSv7.0_CALME_4G_LITE_ V03_F_NRD90M_m01_32_35m\ EMMC CID: 90014A483847346132A4250010049699 crc Ok Vendor: Hynix OEM: 330 ID: 483847346132 [H8G4a2] PRV: 0xA4 Serial: 620761092 0x25001004 MM/YY: 9/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x1D2000000 [ 7.28 Gb ] Verify firmware [MT6735M_CALME_4G_LITE_OSv7.0_CALME_4G_LITE_V03_F_N RD90M_m01_32_35m]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Upload file to server? No Reset port... Finished 15 min 52 sec |
11-07-2024, 13:16 | #76453 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | S/N: 0073CA70CC v0161 Chinese Miracle II - MT2 Service Tool v2.63 Init log engine... Ok Build directories tree... Ok Firmware files: C:\Users\Master Mobile\Desktop\New folder\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 48 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Check for updates [CM2MT2]... Installed v2.63 Infinity #CM2MT2 v2.74 - Preloader parser updated - OS version detection via DAv6 method updated - MDM process fixed for number of devices - [AppTool] for number of devices updated - Print SoC drivers version - Slots management updated for latest devices - Reset/Format updated for latest devices Required firmware v0163 Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Sales: https://infinity-box.com/buy/ Account: https://infinity-box.com/service/ Update configuration... Configuration [12412] updated Get list of devices... Ok Reloaded 2118 devices Build device list... Load IDBase v915508 Ok Load 158 profiles... Ok libusb: v1.2.6.0 Init environment... Ok Ready Operation: Identify [ v2.63 ] Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: A4FD919FCA1390227569045C5E176063 BROM: Sec Level: 0x000000E7 Mode: SBC+SLA+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: CE1B0F5DC104C0A1F19D1336565F642E568E7682BFE483E18F 6565565D0543EE SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: A4FD919FCA1390227569045C5E176063 AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 9B010059325030333200C0F5589E89E1 crc Ok Vendor: Hynix OEM: 256 ID: 593250303332 [Y2P032] PRV: 0x00 Serial: 3237304478 0xC0F5589E MM/YY: 8/2022 EMI: FireFly preloader_ice.bin with 8 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 4. eMMC DDR3 ID: 90014A484247346132 Hynix HBG4a2 RAM: 3.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 7. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 8. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A600 [ 233.50 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 9B010059325030333200C0F5589E89E1 crc Ok Vendor: Hynix OEM: 256 ID: 593250303332 [Y2P032] PRV: 0x00 Serial: 3237304478 0xC0F5589E MM/YY: 8/2022 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 44E83CCA18EBE44903459C4E8BA134BC MEID: A4FD919FCA1390227569045C5E176063 USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 9 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 52 STORAGE Life Status: eMMC : OK STORAGE OTP Status: UNLOCKED STORAGE RPMB Status: eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Saved: C:\InfinityBox\CM2MT2\phdata\key.json Get slot info... a Probe boot... Ok 1 sec Product Brand: Redmi Product Device: ice Product Model: ice Product Name: ice_global SW: Redmi/ice_global/ice:12/SP1A.210812.016/V13.0.23.0.SGMMIXM:user/release-keys Patch Level: SP1A.210812.016 Display ID: 12 V13.0.23.0.SGMMIXM SW Version: V13.0.23.0.SGMMIXM Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2024-06-01 Build Time: 6/3/2024 9:24:12 AM Product Info: ice SW: vnd_ice-user 12 SP1A.210812.016 V13.0.23.0.SGMMIXM release-keys Product Manfct: Xiaomi Product Board: ice Board Platform: mt6761 Device ID: redmi-xiaomi-ice-ice-global Strategy: [xiaomi] Firmware ID: MT6761_Xiaomi_ice_OSv12_12_V13.0.23.0.SGMMIXM_SP1A .210812.016_ice_Redmi Verify firmware [MT6761_Xiaomi_ice_OSv12_12_V13.0.23.0.SGMMIXM_SP1A .210812.016_ice_Redmi]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Backup to C:\InfinityBox\CM2MT2\backup\MT6761__A4FD919FCA139 0227569045C5E176063\ Items to check: 22 Read [23] NVRAM NVRAM: Items: 0xA0 Size: 0x08D015 [SecLv: Vendor Signed] State: Ok WiFi MAC: AA006E742F76 BT MAC: 78D8400D1299 Read [13] NVDATA Read [21] PROINFO Read [12] NVCFG Read [16] PROTECT1 Read [1] PGPT Read [19] PERSIST Read [0] PRELOADER Read [29] LK_A lk [c6fad767] Read [42] LK_B Done 10 files 10 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6761__A4FD919FCA139 0227569045C5E176063\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6761__A4FD919FCA139 0227569045C5E176063.7z Enough [redmi-xiaomi-ice-ice-global] Analyze modem... Nothing Analyze nvram... PSN1: 43289/T3NS03347 EMMC CID: 9B010059325030333200C0F5589E89E1 crc Ok Vendor: Hynix OEM: 256 ID: 593250303332 [Y2P032] PRV: 0x00 Serial: 3237304478 0xC0F5589E MM/YY: 8/2022 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] Analyze preloader... EMI: MT6761 preloader_ice.bin with 8 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 4. eMMC DDR3 ID: 90014A484247346132 Hynix HBG4a2 RAM: 3.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 7. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 8. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_i ce.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_i ce.bin [c66b3883]... Exist Probe FRP... Most probably Off Analyze lk... Verify config values... Ok Seems as Ok Probe Mi Account... Account is Off or not detected Reset port... Finished 53 sec Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [+] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: A4FD919FCA1390227569045C5E176063 BROM: Sec Level: 0x000000E7 Mode: SBC+SLA+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: CE1B0F5DC104C0A1F19D1336565F642E568E7682BFE483E18F 6565565D0543EE SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok EMI known SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: A4FD919FCA1390227569045C5E176063 AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 9B010059325030333200C0F5589E89E1 crc Ok Vendor: Hynix OEM: 256 ID: 593250303332 [Y2P032] PRV: 0x00 Serial: 3237304478 0xC0F5589E MM/YY: 8/2022 EMI: FireFly preloader_ice.bin with 8 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 4. eMMC DDR3 ID: 90014A484247346132 Hynix HBG4a2 RAM: 3.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 7. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 8. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A600 [ 233.50 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 9B010059325030333200C0F5589E89E1 crc Ok Vendor: Hynix OEM: 256 ID: 593250303332 [Y2P032] PRV: 0x00 Serial: 3237304478 0xC0F5589E MM/YY: 8/2022 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 44E83CCA18EBE44903459C4E8BA134BC MEID: A4FD919FCA1390227569045C5E176063 USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 8 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 52 Get slot info... a Probe boot... Ok 843 us Product Brand: Redmi Product Device: ice Product Model: ice Product Name: ice_global SW: Redmi/ice_global/ice:12/SP1A.210812.016/V13.0.23.0.SGMMIXM:user/release-keys Patch Level: SP1A.210812.016 Display ID: 12 V13.0.23.0.SGMMIXM SW Version: V13.0.23.0.SGMMIXM Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2024-06-01 Build Time: 6/3/2024 9:24:12 AM Product Info: ice SW: vnd_ice-user 12 SP1A.210812.016 V13.0.23.0.SGMMIXM release-keys Product Manfct: Xiaomi Product Board: ice Board Platform: mt6761 Device ID: redmi-xiaomi-ice-ice-global Strategy: [xiaomi] Firmware ID: MT6761_Xiaomi_ice_OSv12_12_V13.0.23.0.SGMMIXM_SP1A .210812.016_ice_Redmi Android ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] EMMC CID: 9B010059325030333200C0F5589E89E1 crc Ok Vendor: Hynix OEM: 256 ID: 593250303332 [Y2P032] PRV: 0x00 Serial: 3237304478 0xC0F5589E MM/YY: 8/2022 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] Backup exist: C:\InfinityBox\CM2MT2\backup\MT6761__A4FD919FCA139 0227569045C5E176063 Stage: Android OS [1] WIPE... Skip for Strategy [xiaomi] [2] WIPE... Skip for Strategy [xiaomi] [3] WIPE... Create partition image... Ok Ok [6] USERDATA... Ok [7] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 21 sec Reconnect Power/Cable now |
11-07-2024, 23:43 | #76454 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,080 | Realme C11 FRP Code: Operation: Identify [ v2.74 ] Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek USB Port_V2023 (COM4) MODE: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino Type: MODERN [RAPHAEL] MEID: 5AC90B101ED7CC6210C343C3703C54B5 BROM: Sec Level: 0x000000E5; Mode: SBC+SDA+EXT Ver: 0x05 BL: 0xFE [BOOTROM] SOCID: 6BDF5ED9BCAE8E7103C20F3E16E604D2058180EA60F8E217DDBE817EFFEC825C SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok [FF] Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 5AC90B101ED7CC6210C343C3703C54B5 Agent: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending DA1... Ok [1|1|1|0] Jump to DA... Ok Sync... Ok DA sync... Ok DA Set Params... Ok Mode: BROM [1|1|1|0] EXT_RAM NOT initialized EMMC CID: 1501003458364B4D4203609BCE8C874D crc Ok Vendor: Samsung OEM: 256 ID: 3458364B4D42 [4X6KMB] PRV: 0x03 Serial: 1620823692 0x609BCE8C MM/YY: 8/2020 EMI: FireFly preloader_oppo6765.bin with 10 memory types slots: no 1. eMMC LP_DDR4X ID: 1501003458364B4D42 Samsung 4X6KMB RAM: 2.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 2.00 Gb 4. eMMC LP_DDR4X ID: 150100445036384D42 Samsung DP68MB RAM: 3.00 Gb 5. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 7. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 10. eMMC LP_DDR4X ID: 450100444134313238 Sandisk DA4128 RAM: 4.00 Gb Push EMI... EXT_RAM CFG Passed Boot DA2... Ok [1|1|1|28] DA Sync... Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 1501003458364B4D4203609BCE8C874D crc Ok Vendor: Samsung OEM: 256 ID: 3458364B4D42 [4X6KMB] PRV: 0x03 Serial: 1620823692 0x609BCE8C MM/YY: 8/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino Type: MODERN [RAPHAEL] RNID: 8826E4FC533C4ED0ACB58960DFDDA0F7 MEID: 5AC90B101ED7CC6210C343C3703C54B5 USB: HIGH-SPEED SoC drivers: MediaTek USB Port_V2023 v3.0.1512.0; Boot done MODERN [RAPHAEL] 13 sec Analyze PMT... Ok Partition table: PGPT [0x64] with 47 records Storage [eMMC] Life State: WARNING. Near death. Storage OTP Status: Unlocked Storage [eMMC] RPMB State: RPMB KEY PROGRAMMED [UNUSABLE] Memory chip may be faulty! Load [MemTool]... Ok Device has no slots Probe boot... Finished 2 sec AndroidInfo: recovery;gzip;bootimage/loaded ramsidk size 0x18BBE33/00;boot;gzip;bootimage/loaded ramsidk size 0xCEF5A/00; Probe core... Mount[ext4] wo/cache system@super 0x0075D1D000/0x1411C7000 Mount[ext4] wo/cache vendor@super 0x01BC658000/0x2613C000 Ok 1 sec Patch Level: QP1A.190711.020 Display ID: QP1A.190711.020 release-keys Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-08-05 Build Time: 01/08/2022 10:23:38 am CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: oppo6765 SW: full_oppo6765-user 10 QP1A.190711.020 bedd37e98646d3a1 release-keys Product Board: oppo6765 Board Platform: mt6765 Device ID: oppo6765-MT6765_RMX2185_11_A.77_200930_bb2784aa Strategy: [oppo] Firmware ID: MT6765_OSv10_QP1A.190711.020_oppo6765.MT6765_RMX2185_11_A.77_200930_bb2784aa Verify firmware [MT6765_OSv10_QP1A.190711.020_oppo6765.MT6765_RMX2185_11_A.77_200930_bb2784aa]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Probe userdata... Load userdata header... Ok userData: plain Backup 23 items to C:\InfinityBox\CM2MT2\backup\MT6765__5AC90B101ED7CC6210C343C3703C54B5\ Read [31] nvram Ok 4 sec Read [14] nvdata Ok 4 sec Read [22] proinfo Ok 235 us Read [36] lk Ok 328 us lk [76f4dff7] Read [13] nvcfg Ok 2 sec Read [17] protect1 Ok 656 us Read [1] pgpt Ok 15 us Read [20] persist Ok 3 sec Read [0] preloader Ok 312 us Read [35] ocdt Ok 578 us Zero content file deleted: C:\InfinityBox\CM2MT2\backup\MT6765__5AC90B101ED7CC6210C343C3703C54B5\ocdt.bin Read [5] opporeserve1 Ok 563 us Read [7] opporeserve3 Ok 4 sec Read [8] oppo_custom Ok 78 us Read [32] cdt_engineering Ok 562 us Done 13 files 22 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6765__5AC90B101ED7CC6210C343C3703C54B5\ Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__5AC90B101ED7CC6210C343C3703C54B5.7z Verified get modem info... loaded 15 us OPPO6765_206A1_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R2_TC16_Q_G35_PR1_SP_V1_P50 Load nvram items... NVRAM size: 0x08C87A; 170 items; State: Ok WiFi MAC: 94:8A:C6:34:86:5F BT MAC: 94:8A:C6:34:86:5E nvram imei data has unknown structure or damaged PSN1: 00206A350A142441 Secondary RPMB... On Probe preloader... EMI: MT6765 preloader_oppo6765.bin with 10 memory types slots: no 1. eMMC LP_DDR4X ID: 1501003458364B4D42 Samsung 4X6KMB RAM: 2.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 2.00 Gb 4. eMMC LP_DDR4X ID: 150100445036384D42 Samsung DP68MB RAM: 3.00 Gb 5. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 7. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 10. eMMC LP_DDR4X ID: 450100444134313238 Sandisk DA4128 RAM: 4.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_oppo6765.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_oppo6765.bin [32bb7f00]... Exist Probe FRP... Most probably Off Probe bootloader... Seems as Locked Finished Identify [ v2.74 ] 1 min 11 sec Keep connection Operation: Reset Settings/Format FS [ v2.74 ] WARNING: Reset may delete ALL USER DATA! Wipe On; Userdata Off; FRP On; Accounts On; Smart Analyzer On Wait... Analyze PMT... Ok Partition table: PGPT [0x64] with 47 records Patch Level: QP1A.190711.020 Display ID: QP1A.190711.020 release-keys Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-08-05 Build Time: 01/08/2022 10:23:38 am CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: oppo6765 SW: full_oppo6765-user 10 QP1A.190711.020 bedd37e98646d3a1 release-keys Product Board: oppo6765 Board Platform: mt6765 Device ID: oppo6765-MT6765_RMX2185_11_A.77_200930_bb2784aa Strategy: [oppo] Firmware ID: MT6765_OSv10_QP1A.190711.020_oppo6765.MT6765_RMX2185_11_A.77_200930_bb2784aa Android ver: 10 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__5AC90B101ED7CC6210C343C3703C54B5 Reset: Wipe... Noting for [oppo] Reset: FRP... process [frp]... Ok verify [frp] 128.00 Kb... rewrite... Ok Completed Reset: Accounts... probe regionlock regionlock looks like Off Reset anyway? Yes Fail If FRP still active make [Userdata] reset In case of issue with Wipe make [Userdata] reset Finished Reset Settings/Format FS [ v2.74 ] 12 sec Keep connection DA selected: 0_generic | 2022-09 [luci] MT6781 | DA_BR.2022-09-07.bin MT6781_Generic [LUCI] [flash_id.txt] supported memory types: MT064GASAO2U21 H9HQ15AFAMBDAR H9HQ16AECMMDAR H9HQ16AFAMMDAR H9HQ21AFAMADAR KM8B8001JM-BC0 KM8F8001JM-B813 MT128GASAO4U21 MT256GAXAU4U22 Keep connection DA selected: 0_base | base_v2316 | MTK_AllInOne_DA.1d5fdec4.bin 5 DA available, try it one-by-one Keep connection DA selected: 0_base | base_v2216 | MTK_AllInOne_DA.2022-04-10.3365c4d2.bin 5 DA available, try it one-by-one Keep connection Operation: Identify [ v2.74 ] Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek USB Port_V2023 (COM4) MODE: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino Type: MODERN [RAPHAEL] MEID: 5AC90B101ED7CC6210C343C3703C54B5 BROM: Sec Level: 0x000000E5; Mode: SBC+SDA+EXT Ver: 0x05 BL: 0xFE [BOOTROM] SOCID: 6BDF5ED9BCAE8E7103C20F3E16E604D2058180EA60F8E217DDBE817EFFEC825C SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok EMI known SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 5AC90B101ED7CC6210C343C3703C54B5 Agent: [42c76018] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.2022-04-10.3365c4d2.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending DA1... Ok [1|1|1|0] Jump to DA... Ok Sync... Ok DA sync... Ok DA Set Params... Ok Mode: BROM [1|1|1|0] EXT_RAM NOT initialized EMMC CID: 1501003458364B4D4203609BCE8C874D crc Ok Vendor: Samsung OEM: 256 ID: 3458364B4D42 [4X6KMB] PRV: 0x03 Serial: 1620823692 0x609BCE8C MM/YY: 8/2020 EMI: FireFly preloader_oppo6765.bin with 10 memory types slots: no 1. eMMC LP_DDR4X ID: 1501003458364B4D42 Samsung 4X6KMB RAM: 2.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 2.00 Gb 4. eMMC LP_DDR4X ID: 150100445036384D42 Samsung DP68MB RAM: 3.00 Gb 5. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 7. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 10. eMMC LP_DDR4X ID: 450100444134313238 Sandisk DA4128 RAM: 4.00 Gb Push EMI... EXT_RAM CFG Passed Boot DA2... Ok [1|1|1|28] DA Sync... Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 1501003458364B4D4203609BCE8C874D crc Ok Vendor: Samsung OEM: 256 ID: 3458364B4D42 [4X6KMB] PRV: 0x03 Serial: 1620823692 0x609BCE8C MM/YY: 8/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino Type: MODERN [RAPHAEL] RNID: 8826E4FC533C4ED0ACB58960DFDDA0F7 MEID: 5AC90B101ED7CC6210C343C3703C54B5 USB: HIGH-SPEED SoC drivers: MediaTek USB Port_V2023 v3.0.1512.0; Boot done MODERN [RAPHAEL] 17 sec Analyze PMT... Ok Partition table: PGPT [0x64] with 47 records Storage [eMMC] Life State: WARNING. Near death. Storage OTP Status: Unlocked Storage [eMMC] RPMB State: RPMB KEY PROGRAMMED [UNUSABLE] Memory chip may be faulty! Load [MemTool]... Ok Device has no slots Probe boot... Finished 2 sec AndroidInfo: recovery;gzip;bootimage/loaded ramsidk size 0x18BBE33/00;boot;gzip;bootimage/loaded ramsidk size 0xCEF5A/00; Probe core... Mount[ext4] wo/cache system@super 0x0075D1D000/0x1411C7000 Mount[ext4] wo/cache vendor@super 0x01BC658000/0x2613C000 Ok 1 sec Patch Level: QP1A.190711.020 Display ID: QP1A.190711.020 release-keys Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-08-05 Build Time: 01/08/2022 10:23:38 am CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: oppo6765 SW: full_oppo6765-user 10 QP1A.190711.020 bedd37e98646d3a1 release-keys Product Board: oppo6765 Board Platform: mt6765 Device ID: oppo6765-MT6765_RMX2185_11_A.77_200930_bb2784aa Strategy: [oppo] Firmware ID: MT6765_OSv10_QP1A.190711.020_oppo6765.MT6765_RMX2185_11_A.77_200930_bb2784aa Verify firmware [MT6765_OSv10_QP1A.190711.020_oppo6765.MT6765_RMX2185_11_A.77_200930_bb2784aa]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Probe userdata... Load userdata header... Ok userData: plain Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__5AC90B101ED7CC6210C343C3703C54B5 get modem info... loaded 15 us OPPO6765_206A1_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R2_TC16_Q_G35_PR1_SP_V1_P50 Load nvram items... NVRAM size: 0x08C87A; 170 items; State: Ok WiFi MAC: 94:8A:C6:34:86:5F BT MAC: 94:8A:C6:34:86:5E nvram imei data has unknown structure or damaged PSN1: 00206A350A142441 Secondary RPMB... On Probe preloader... EMI: MT6765 preloader_oppo6765.bin with 10 memory types slots: no 1. eMMC LP_DDR4X ID: 1501003458364B4D42 Samsung 4X6KMB RAM: 2.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 2.00 Gb 4. eMMC LP_DDR4X ID: 150100445036384D42 Samsung DP68MB RAM: 3.00 Gb 5. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 7. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 10. eMMC LP_DDR4X ID: 450100444134313238 Sandisk DA4128 RAM: 4.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_oppo6765.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_oppo6765.bin [32bb7f00]... Exist Probe FRP... Most probably Off Probe bootloader... Seems as Locked Finished Identify [ v2.74 ] 43 sec Keep connection |
11-08-2024, 07:28 | #76455 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 1,029 | Premio X87 Frp Done Operation: Connect SoC sc7731 Boot [FF] FireFly [v2.30] Wait... Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... Device found PTFN: SPRD U2S Diag (COM237) vid 0x1782 pid 0x4D00 boot: SPRD3 boot iLoader... Ok start iLoader... Ok Handshake... Ok boot xLoader... Ok start FireFly... Ok Loader exec Ok Dev UID: cc1a87226926e9ad601d15099fc034fde4d52c52f2dce8fbba 1ec6ea65ddfc1e stored 6 hwid cache items get storage info... MMC EMMC CID: 90014A484147346132A417D8A04B7317 crc Ok Vendor: Hynix OEM: 330 ID: 484147346132 [HAG4a2] PRV: 0xA4 Serial: 400072779 0x17D8A04B MM/YY: 7/2016 CSD: D02701328F5903FFFFFFFFE78A400001 temp_write_protect: False perm_write_protect: False wp_group: 0x08 en 0x01 read extcsd... Ok EXTCSD rev1.8 EMMC 5.1 FW: A4 ERASE_GROUP_DEF: 0x0400 BOOT_BUS_WIDTH: 0x00 PARTITION_CONFIG: 0x08 RST_N_FUNCTION: 0x01 PART_S_COMPLETED: False BOOT size: 0x400000 RPMB size: 0x400000 4.00 Mb WP_GRP_SIZE: 0x400000 4.00 Mb Size: Market 16 Gb Actual 0x3AB400000 14.68 Gb EOL: Status: Normal: Less than 80% reserved blocks used EOL_A: SLC status: 0% - 10% used EOL_B: MLC status: 50% - 60% used extcsd stored: C:\InfinityBox\CM2SP3\backup\ext_csd\none_cc1a8722 6926e9ad_extcsd_0090-Hynix_HAG4a2_5.1_2024-11-08.bin get partitions... Load primary GPT... Load secondary GPT... Primary GPT state Ok Secondary GPT state Ok Partitions: 72 Connected get sw info... 46 sec SW: PREMIO/X87/X87:11/RP1A.201005.001/46216:user/release-keys Product Brand: PREMIO Product Device: X87 Product Model: X87 Product Name: X87 Patch Level: RP1A.201005.001 Display ID: J527B_KC6101B_PREMIO_X87_V01_20211116 SW Version: 46216 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2021-10-05 Build Time: 2021/11/16 08:20:21 am Product Manfct: PREMIO Product Info: X87 CPU: armeabi-v7a,armeabi SW: sp7731e_1h10_native-user 11 RP1A.201005.001 46216 release-keys Product Board: sp7731e_1h10 Board Platform: sp7731e Android ver: 11 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Device ID: x87-premio-x87-sp7731e-1h10-x87 Strategy: [none|generic] Firmware ID: SP7731E_PREMIO_X87_OSv11_J527B_KC6101B_PREMIO_X87_ V01_20211116_RP1A.201005.001_X87 get slots... slot: a [MemTool] load 72 items Finished 1 min 26 sec Operation: Reset | Format SoC sc7731 Boot [FF] FireFly [v2.30] WARNING: Reset may delete ALL USER DATA! Continue? Yes [+] Wipe [+] Userdata [+] FRP [+] Smart Wait... Partitions: 72 Process Wipe... Reading... Ok Writing... Ok Process FRP... Looking for items... 1 items found [1] Writing... Ok Process Userdata... [1] Format... Ok 8 sec [2] Format... [erase] [cache] addr 0xC0900000+0000 size 0x1400000 Completed Process nvram... [17] Format... [erase] [w_runtimenv1] addr 0x3300000+0000 size 0x100000 Nothing Finished 29 sec prodnv: sync before load; miscdata: sync before load; protect_data: sync before load; uboot: sync before load; trustos: sync before load; Reboot... Disconnect cable if it freez CMD 0x05 0x8E PHONE_WAIT_INPUT_TIMEOUT Bye |
