11-28-2024, 16:27 | #76501 (permalink) |
Freak Poster Join Date: Jul 2021 Location: Nigeria
Member: 2993572 Status: Offline Thanks Meter: 189 | INFINIX HOT 50i x6531B FRP RESET DONE Code: Operation: Reset Settings/Format FS [ v2.76 ] WARNING: Reset may delete ALL USER DATA! Wipe Off; Userdata Off; FRP On; Accounts Off; Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM14) MODE: PRELOADER PORT; PORT: 14 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6768 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0707 SWv: 0x0000 Evo: 0x0000 Code: Talbot Type: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005; Mode: SBC+SDA Ver: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: EA0301C7FF1CB33D2A942E2AA1CB740360A3BD6DB80C7742DBAE51F462F1DBAE Agent: [46c0b1ae] C:\InfinityBox\CM2MT2\boot\Tecno\2024-08\MTK_AllInOne_DA_v2312.bf41.cca2a535.bin [bd322c2c] C:\InfinityBox\CM2MT2\boot\Tecno\2024-08\auth_sv5_24.auth Looking for bootchain in DA... Found: MT6768; DA: MTK_DOWNLOAD_AGENT BROM: Sending DA1... Ok [1|0|0|0] Jump to DA... Ok Sync... Ok DA sync... Ok DA Set Params... Ok Mode: PRELOADER [1|0|0|0] EXT_RAM initialized Boot DA2... Ok [1|0|0|28] DA Sync... Ok DA Auth Ok Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: F4012241524A34315811537808D97B83 crc Ok Vendor: Biwin OEM: 290 ID: 41524A343158 [ARJ41X] PRV: 0x11 Serial: 1400375513 0x537808D9 MM/YY: 7/2024 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x1CD0000000 [ 115.25 Gb ] CHIP: MT6768 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0707 SWv: 0x0001 Evo: 0x0000 Code: Talbot Type: MODERN [RAPHAEL] RNID: BD0477571DD56036381EB55F6EAB2B7D da pl engine nOk 0x01 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] 11 sec Load partition table... Ok Partition table: PGPT [0x64] with 55 records Get slot info... Active slot(v3): a Probe boot... Ok 812 us AndroidInfo: vendor_boot_a;lz4;bootimage/loaded ramsidk size 0x17F4C7F/3D23300; Product Brand: Infinix Product Device: Infinix-X6531B Product Model: Infinix X6531B Product Name: X6531B-OP SW: Infinix/X6531B-OP/Infinix-X6531B:12/SP1A.210812.016/240904V384:user/release-keys Patch Level: SP1A.210812.016 Display ID: X6531B-V631BAeAfAgAhAiAj-U-OP-240904V384 SW Version: 240904V384 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2024-07-05 Build Time: 04/09/2024 07:27:44 Product Info: x6531_v631 SW: vnd_x6531_v631-user 12 SP1A.210812.016 694928 release-keys Product Manfct: INFINIX Product Board: Infinix-X6531B Board Platform: mt6768 Device ID: infinix-x6531b-x6531b-op Strategy: [infinix] Firmware ID: MT6768_INFINIX_Infinix_X6531B_OSv12_X6531B-V631BAeAfAgAhAiAj-U-OP-240904V384_SP1A.210812.016_x6531_v631 Android ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify [DA] data... Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6768__93991E8278A257FFD8DC011C0B7F52F8 Reset: FRP... process [frp]... Ok verify [frp] 128.00 Kb... rewrite... read [boot_para] addr 0x0000 size 0x1A00000 [0xC0010001] Error read [proinfo] addr 0x0000 size 0x300000 [0xC0010001] Error read [tdfs] addr 0x0000 size 0x3800000 [0xC0010001] Error read [transec] addr 0x0000 size 0x3800000 [0xC0010001] Error read [misc] addr 0x0000 size 0x80000 [0xC0010001] Error read [para] addr 0x0000 size 0x80000 [0xC0010001] Error read [expdb] addr 0x0000 size 0x1400000 [0xC0010001] Error read [frp] addr 0x0000 size 0x100000 [0xC0010001] Error read [md_udc] addr 0x0000 size 0x169A000 [0xC0010001] Error read [metadata] addr 0x0000 size 0x2000000 [0xC0010001] Error read [nvcfg] addr 0x0000 size 0x2000000 [0xC0010001] Error read [nvdata] addr 0x0000 size 0x4000000 [0xC0010001] Error read [persist] addr 0x0000 size 0x3000000 [0xC0010001] Error read [protect1] addr 0x0000 size 0x800000 [0xC0010001] Error read [protect2] addr 0x0000 size 0xE5E000 [0xC0010001] Error read [sec1] addr 0x0000 size 0x200000 [0xC0010001] Error read [tranfs] addr 0x0000 size 0x12E00000 [0xC0010001] Error read [otp] addr 0x0000 size 0x2B00000 [0xC0010001] Error Completed If FRP still active make [Userdata] reset Reset port... Trying to reboot... Finished Reset Settings/Format FS [ v2.76 ] 24 sec |
11-29-2024, 07:50 | #76502 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,778 | QMOBILE X30 V3 HANG ON LOGO DONE BY CM2 Card found : 73CA70CC , v0161 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:39 |
11-29-2024, 17:57 | #76503 (permalink) |
Member: 2993572 Status: Offline Thanks Meter: 189 | Samsung a107f frp reset done Code: CM2 - MT2 Service Tool v2.76 Probe UAC... Ok Probe libusb... v1.2.7.3 Wait... S/N: 00A6936825 v0163 Initalize log engine... Ok Build directories tree... Ok Firmware files: F:\Download\ Backup files: C:\InfinityBox\CM2MT2\backup\ Compact backup files... Backup files: 42 dirs: 1 Load emi database... Internal: 28 custom: 0 Load IDBase v915508 Ok Build device list... Ok Load 158 profiles... Ok Initalize external tools... Ok Initialize libusb... Ok Software may need data from server but Username|Password is wrong. Set it via [Settings|Account] Ready Operation: Reset Settings/Format FS [ v2.76 ] WARNING: Reset may delete ALL USER DATA! Wipe Off; Userdata Off; FRP On; Accounts Off; Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM14) MODE: PRELOADER PORT; PORT: 14 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino Type: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005; Mode: SBC+SDA Ver: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: B1109E5B69B5B5F4FD9E379E6781ADF702799966B5B92148B8FAE558F5348C6D Agent: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending DA1... Reset Interface [1|1|0|0] PTFN: MediaTek USB Port_V1633 (COM13) MODE: BOOTROM; PORT: 13 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino Type: MODERN [RAPHAEL] MEID: 13B74D22A934E5B0A7CD69DA9D61FEBD BROM: Sec Level: 0x000000E5; Mode: SBC+SDA+EXT Ver: 0x05 BL: 0xFE [BOOTROM] SOCID: B1109E5B69B5B5F4FD9E379E6781ADF702799966B5B92148B8FAE558F5348C6D SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok [FF] Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 13B74D22A934E5B0A7CD69DA9D61FEBD Agent: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending DA1... Ok [1|1|1|0] Jump to DA... Ok Sync... Ok DA sync... Ok DA Set Params... Ok Mode: BROM [1|1|1|0] EXT_RAM NOT initialized EMMC CID: 150100514436334D4203045E96B1C6B9 crc Ok Vendor: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 Serial: 73307825 0x045E96B1 MM/YY: 12/2019 EMI: FireFly preloader_s96116aa1.bin with 3 memory types slots: no 1. eMMC DDR3 ID: 150100514436334D42 Samsung QD63MB RAM: 2.00 Gb 2. eMMC DDR3 ID: 700100464D42434541 Kingston FMBCEA RAM: 2.00 Gb 3. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed Boot DA2... Ok [1|1|1|28] DA Sync... Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 150100514436334D4203045E96B1C6B9 crc Ok Vendor: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 Serial: 73307825 0x045E96B1 MM/YY: 12/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino Type: MODERN [RAPHAEL] RNID: 7DFB580603DE0CA2E5A411BEC573E582 MEID: 13B74D22A934E5B0A7CD69DA9D61FEBD USB: HIGH-SPEED Boot done MODERN [RAPHAEL] 1 min 49 sec Load partition table... Ok Partition table: PGPT [0x64] with 39 records Device has no slots Probe boot... Ok 656 us AndroidInfo: recovery;gzip;bootimage/loaded ramsidk size 0x61C5F7/AA8800; Patch Level: PPR1.180610.011 Display ID: PPR1.180610.011.A107FXXU3ASK2 SW Version: A107FXXU3ASK2 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2019-12-01 Build Time: 28/11/2019 08:07:50 Product Model: SM-A107F Product Brand: samsung Product Info: a10s Product Name: a10sxx Product Device: a10s CPU: armeabi-v7a,armeabi Product Manfct: samsung SW: a10sxx-user 9 PPR1.180610.011 A107FXXU3ASK2 release-keys Product Board: S96116AA1 Board Platform: mt6765 Device ID: samsung-sm-a107f-a10s-a10sxx-s96116aa1 Strategy: [samsung] Firmware ID: MT6765_samsung_SM-A107F_OSv9_PPR1.180610.011.A107FXXU3ASK2_PPR1.180610.011_a10s Android ver: 9 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Backup 23 items to C:\InfinityBox\CM2MT2\backup\MT6765__13B74D22A934E5B0A7CD69DA9D61FEBD\ Read [5] nvram Ok 4 sec Read [14] nvdata Ok 4 sec Read [23] proinfo Ok 250 us Read [28] lk Ok 172 us lk [2aa6757e] Read [13] nvcfg Ok 2 sec Read [16] protect1 Ok 594 us Read [1] pgpt Ok 16 us Read [19] persist Ok 3 sec Read [20] persistent Ok 47 us Read [0] preloader Ok 297 us Read [6] efs Ok 562 us Read [7] sec_efs Ok 594 us Exist [20] persistent Done 12 files 18 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6765__13B74D22A934E5B0A7CD69DA9D61FEBD\ Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__13B74D22A934E5B0A7CD69DA9D61FEBD.7z Enough [samsung-sm-a107f-a10s-a10sxx-s96116aa1] Reset: FRP... process [frp]... Ok verify [frp] 128.00 Kb... rewrite... Ok process [persistent]... Ok Ok Completed If FRP still active make [Userdata] reset Reset port... Trying to reboot... Finished Reset Settings/Format FS [ v2.76 ] 3 min 5 sec |
11-30-2024, 17:10 | #76505 (permalink) |
Member: 2993572 Status: Offline Thanks Meter: 189 | Tecno ka7 factory reset & frp done Code: CM2 - MT2 Service Tool v2.76 Probe UAC... Ok Probe libusb... v1.2.7.3 Wait... S/N: 00A6936825 v0163 Initalize log engine... Ok Build directories tree... Ok Firmware files: F:\Download\ Backup files: C:\InfinityBox\CM2MT2\backup\ Compact backup files... Backup files: 44 dirs: 1 Load emi database... Internal: 28 custom: 0 Load IDBase v915508 Ok Build device list... Ok Load 158 profiles... Ok Initalize external tools... Ok Initialize libusb... Ok Software may need data from server but Username|Password is wrong. Set it via [Settings|Account] Ready Operation: Identify [ v2.76 ] Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM14) MODE: PRELOADER PORT; PORT: 14 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6580 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x6580 SWv: 0x0000 Evo: 0x0000 Type: LEGACY [MTK] BROM: Sec Level: 0x00000005; Mode: SBC+SDA Ver: 0xFF BL: 0x01 [PRELOADER PORT] Agent: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6580; DA: MTK_DOWNLOAD_AGENT BROM: Sending DA1... Reset Interface [1|0|0|0] PTFN: MediaTek USB Port_V1633 (COM13) MODE: BOOTROM; PORT: 13 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6580 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x6580 SWv: 0x0000 Evo: 0x0000 Type: LEGACY [MTK] MEID: 406AA873D69A8DCE55A27A4F78AC9F1E BROM: Sec Level: 0x00000005; Mode: SBC+SDA Ver: 0x05 BL: 0xFE [BOOTROM] SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok [FF] Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x00000001 EMI loaded by MEID: 406AA873D69A8DCE55A27A4F78AC9F1E Agent: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6580; DA: MTK_DOWNLOAD_AGENT BROM: Sending DA1... Ok [1|0|0|0] Jump to DA... Ok Sync... Ok NAND: DEVICE NOT FOUND EMMC: OK CID: 460001154D323645901F0342A185F69A DA v4.2.156 EXT_RAM NOT initialized EMMC: OK CID: 150100464536324D42031F909AF685A1 NAND: DEVICE NOT FOUND DRAM: 0x00BC EMI: FireFly preloader_ka7_h8024.bin with 7 memory types slots: no 1. eMMC DDR3 ID: 150100513732534D42 Samsung Q72SMB RAM: 1.00 Gb 2. eMMC DDR2 ID: 90014A483847316505 Hynix H8G1e RAM: 1.00 Gb 3. eMMC DDR2 ID: ADDE14A7424AAD Unknown 0x00AD §BJ* RAM: 512.00 Mb 4. eMMC DDR3 ID: 150100464536324D42 Samsung FE62MB RAM: 1.00 Gb 5. eMMC DDR3 ID: 700100454841454538 Kingston EHAEE8 RAM: 1.00 Gb 6. eMMC DDR3 ID: 150100514536334D42 Samsung QE63MB RAM: 2.00 Gb 7. eMMC DDR3 ID: 150100514436334D42 Samsung QD63MB RAM: 2.00 Gb INIT: 0x00BC DRAM [ 0x00000000 0 b ] RAM: DRAM: 0x400000001024.00 Mb DA: DRAM ready Boot DA2... Ok Load HW info... EMMC CID: 150100464536324D42031F909AF685A1 crc Ok Vendor: Samsung OEM: 256 ID: 464536324D42 [FE62MB] PRV: 0x03 Serial: 529570550 0x1F909AF6 MM/YY: 8/2018 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x3A3E00000 [ 14.56 Gb ] RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0x40000000 [ 1024.00 Mb ] CHIP: MT6580 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x6580 SWv: 0x0000 Evo: 0x0000 Type: LEGACY [MTK] RNID: 6DCAFE9FC68469B99D1E0A89A1500467 MEID: 406AA873D69A8DCE55A27A4F78AC9F1E DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: FULL-SPEED Set port High-Speed... PTFN: MediaTek DA USB VCOM (Android) (COM15) MODE: PRELOADER PORT; PORT: 15 Boot done LEGACY [MTK] 20 sec Load partition table... Ok Partition table LGPT [0x06] with 29 records Device has no slots Probe boot... Ok 1 sec AndroidInfo: recovery;gzip;bootimage/loaded ramsidk size 0x55B068/80B800; Patch Level: O11019 Display ID: KA7-H8024ABC-OGo-190513V205 SW Version: ABC-190513V205 Ver. CodeName: REL Ver. Release: 8.1.0 Sec. Patch: 2019-05-05 Build Time: 13/05/2019 09:36:24 Product Model: TECNO KA7 Product Brand: TECNO Product Name: H8024 Product Device: TECNO-KA7-GO CPU: armeabi-v7a,armeabi Product Manfct: TECNO MOBILE LIMITED Product Info: TECNO-KA7-GO SW: full_ka7_h8024-user 8.1.0 O11019 1557740189 release-keys Market Name: H8024 Market Name: TECNO SPARK 2 Board Platform: mt6580 Device ID: tecno-mobile-limited-tecno-ka7-tecno-ka7-go-h8024 Strategy: [tecno] Firmware ID: MT6580_TECNO_MOBILE_LIMITED_TECNO_KA7_OSv8.1.0_KA7-H8024ABC-OGo-190513V205_O11019_TECNO-KA7-GO Verify firmware [MT6580_TECNO_MOBILE_LIMITED_TECNO_KA7_OSv8.1.0_KA7-H8024ABC-OGo-190513V205_O11019_TECNO-KA7-GO]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Probe userdata... userData: fileSystem : [f2fs] with FDE [encryptable] Backup 23 items to C:\InfinityBox\CM2MT2\backup\MT6580__406AA873D69A8DCE55A27A4F78AC9F1E\ Read [3] nvram Ok 907 us Read [19] nvdata Ok 5 sec Read [2] proinfo Ok 562 us Read [8] lk Ok 79 us lk [eaa49181] Read [4] protect1 Ok 1 sec lda-pt: pgpt Read [6] persist Ok 8 sec Read [0] preloader Ok 750 us Done 7 files 18 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6580__406AA873D69A8DCE55A27A4F78AC9F1E\ Ok Verify C:\InfinityBox\CM2MT2\backup\MT6580__406AA873D69A8DCE55A27A4F78AC9F1E.7z Enough [tecno-mobile-limited-tecno-ka7-tecno-ka7-go-h8024] get modem info... absent Load nvram items... NVRAM size: 0x029994; 119 items; State: Ok WiFi MAC: 14:11:14:A3:2F:71 BT MAC: 14:11:14:A2:E1:51 IMEI1: 352779100983165 IMEI2: 352779100983173 PSN1: 037440989S017266 Reset port... Trying to reboot... Finished Identify [ v2.76 ] 55 sec Code: Operation: Reset Settings/Format FS [ v2.76 ] WARNING: Reset may delete ALL USER DATA! Wipe On; Userdata On; FRP On; Accounts Off; Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM14) MODE: PRELOADER PORT; PORT: 14 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6580 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x6580 SWv: 0x0000 Evo: 0x0000 Type: LEGACY [MTK] BROM: Sec Level: 0x00000005; Mode: SBC+SDA Ver: 0xFF BL: 0x01 [PRELOADER PORT] Agent: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6580; DA: MTK_DOWNLOAD_AGENT BROM: Sending DA1... Reset Interface [1|0|0|0] PTFN: MediaTek USB Port_V1633 (COM13) MODE: BOOTROM; PORT: 13 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6580 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x6580 SWv: 0x0000 Evo: 0x0000 Type: LEGACY [MTK] MEID: 406AA873D69A8DCE55A27A4F78AC9F1E BROM: Sec Level: 0x00000005; Mode: SBC+SDA Ver: 0x05 BL: 0xFE [BOOTROM] SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok EMI known SLA: Start 0x15 Auth Passed; SEC: 0x00000001 EMI loaded by MEID: 406AA873D69A8DCE55A27A4F78AC9F1E Agent: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6580; DA: MTK_DOWNLOAD_AGENT BROM: Sending DA1... Ok [1|0|0|0] Jump to DA... Ok Sync... Ok NAND: DEVICE NOT FOUND EMMC: OK CID: 460001154D323645901F0342A185F69A DA v4.2.156 EXT_RAM NOT initialized EMMC: OK CID: 150100464536324D42031F909AF685A1 NAND: DEVICE NOT FOUND DRAM: 0x00BC EMI: FireFly preloader_ka7_h8024.bin with 7 memory types slots: no 1. eMMC DDR3 ID: 150100513732534D42 Samsung Q72SMB RAM: 1.00 Gb 2. eMMC DDR2 ID: 90014A483847316505 Hynix H8G1e RAM: 1.00 Gb 3. eMMC DDR2 ID: ADDE14A7424AAD Unknown 0x00AD §BJ* RAM: 512.00 Mb 4. eMMC DDR3 ID: 150100464536324D42 Samsung FE62MB RAM: 1.00 Gb 5. eMMC DDR3 ID: 700100454841454538 Kingston EHAEE8 RAM: 1.00 Gb 6. eMMC DDR3 ID: 150100514536334D42 Samsung QE63MB RAM: 2.00 Gb 7. eMMC DDR3 ID: 150100514436334D42 Samsung QD63MB RAM: 2.00 Gb INIT: 0x00BC DRAM [ 0x00000000 0 b ] RAM: DRAM: 0x400000001024.00 Mb DA: DRAM ready Boot DA2... Ok Load HW info... EMMC CID: 150100464536324D42031F909AF685A1 crc Ok Vendor: Samsung OEM: 256 ID: 464536324D42 [FE62MB] PRV: 0x03 Serial: 529570550 0x1F909AF6 MM/YY: 8/2018 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x3A3E00000 [ 14.56 Gb ] RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0x40000000 [ 1024.00 Mb ] CHIP: MT6580 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x6580 SWv: 0x0000 Evo: 0x0000 Type: LEGACY [MTK] RNID: 6DCAFE9FC68469B99D1E0A89A1500467 MEID: 406AA873D69A8DCE55A27A4F78AC9F1E DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: FULL-SPEED Set port High-Speed... PTFN: MediaTek DA USB VCOM (Android) (COM15) MODE: PRELOADER PORT; PORT: 15 Boot done LEGACY [MTK] 16 sec Load partition table... Ok Partition table LGPT [0x06] with 29 records Device has no slots Probe boot... Ok 1 sec AndroidInfo: recovery;gzip;bootimage/loaded ramsidk size 0x55B068/80B800; Patch Level: O11019 Display ID: KA7-H8024ABC-OGo-190513V205 SW Version: ABC-190513V205 Ver. CodeName: REL Ver. Release: 8.1.0 Sec. Patch: 2019-05-05 Build Time: 13/05/2019 09:36:24 Product Model: TECNO KA7 Product Brand: TECNO Product Name: H8024 Product Device: TECNO-KA7-GO CPU: armeabi-v7a,armeabi Product Manfct: TECNO MOBILE LIMITED Product Info: TECNO-KA7-GO SW: full_ka7_h8024-user 8.1.0 O11019 1557740189 release-keys Market Name: H8024 Market Name: TECNO SPARK 2 Board Platform: mt6580 Device ID: tecno-mobile-limited-tecno-ka7-tecno-ka7-go-h8024 Strategy: [tecno] Firmware ID: MT6580_TECNO_MOBILE_LIMITED_TECNO_KA7_OSv8.1.0_KA7-H8024ABC-OGo-190513V205_O11019_TECNO-KA7-GO Android ver: 8 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Backup exist: C:\InfinityBox\CM2MT2\backup\MT6580__406AA873D69A8DCE55A27A4F78AC9F1E Reset: Wipe... Step #1... Ok Step #2... Finished Reset: Userdata... [1] userdata... Create partition image... Make filesystem [0x03 f2fs]... Ok Ok Ok [2] cache... Create partition image... Make filesystem [0x02 ext4|8+]... Ok Ok Ok [4] metadata... process [metadata]... Ok Ok Reset: FRP... process [frp]... Ok Completed Reset port... Trying to reboot... Finished Reset Settings/Format FS [ v2.76 ] 28 sec |
12-01-2024, 05:59 | #76506 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | S/N: 0073CA70CC v0161 Chinese Miracle II - MT2 Service Tool v2.63 Init log engine... Ok Build directories tree... Ok Firmware files: C:\Users\Master Mobile\Desktop\New folder\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 65 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Load IDBase v915508 Ok Load 159 profiles... Ok libusb: v1.2.6.0 Init environment... Ok Ready Operation: Identify [ v2.63 ] Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM3) MODE [0]: PRELOADER PORT; PORT: 3 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 103256E1C694D9CC3B33714AB109E2C0649693A05F635C5DBE 7F13EA664C8F5C AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MediaTek USB Port_V1633 (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 9ED2BD259354CFAD2DEE8D1B8C162D07 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 103256E1C694D9CC3B33714AB109E2C0649693A05F635C5DBE 7F13EA664C8F5C SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 9ED2BD259354CFAD2DEE8D1B8C162D07 AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 7001005441323833322332EBE6813725 crc Ok Vendor: Kingston OEM: 256 ID: 544132383332 [TA2832] PRV: 0x23 Serial: 854320769 0x32EBE681 MM/YY: 3/2020 EMI: FireFly preloader_x655_h6210.bin with 6 memory type(s) 1. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 3. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 4. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 5. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 6. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 7001005441323833322332EBE6813725 crc Ok Vendor: Kingston OEM: 256 ID: 544132383332 [TA2832] PRV: 0x23 Serial: 854320769 0x32EBE681 MM/YY: 3/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x74A000000 [ 29.16 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: E4D6832517B4B114B6D967A8EFAF2951 MEID: 9ED2BD259354CFAD2DEE8D1B8C162D07 USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 19 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 41 STORAGE Life Status: eMMC : BAD! LIFE CYCLE END! READ-ONLY STATE STORAGE OTP Status: UNLOCKED STORAGE RPMB Status: eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Memory chip may be faulty! Saved: C:\InfinityBox\CM2MT2\phdata\key.json Probe boot... Ok 562 us SW: Infinix/X655-OP/Infinix-X655:10/QP1A.190711.020/ABFG-OP-220823V559:user/release-keys Product Brand: Infinix Product Device: Infinix-X655 Product Model: Infinix X655 Product Name: X655-OP Patch Level: QP1A.190711.020 Display ID: X655-H6210ABFG-Q-OP-220823V559 SW Version: ABFG-OP-220823V559 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-08-01 Build Time: 8/23/2022 12:09:08 PM CPU: armeabi-v7a,armeabi Product Info: x655_h6210 SW: full_x655_h6210-user 10 QP1A.190711.020 65716 release-keys Product Board: Infinix-X655 Board Platform: mt6765 Product Manfct: INFINIX MOBILITY LIMITED Device ID: infinix-mobility-limited-infinix-x655-x655-op Strategy: [infinix] Firmware ID: MT6765_INFINIX_MOBILITY_LIMITED_Infinix_X655_OSv10 _X655-H6210ABFG-Q-OP-220823V559_QP1A.190711.020_x655_h6210 Verify firmware [MT6765_INFINIX_MOBILITY_LIMITED_Infinix_X655_OSv10 _X655-H6210ABFG-Q-OP-220823V559_QP1A.190711.020_x655_h6210]... Exist (1) Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Backup to C:\InfinityBox\CM2MT2\backup\MT6765__9ED2BD259354C FAD2DEE8D1B8C162D07\ Items to check: 22 Read [26] NVRAM NVRAM: Items: 0xA3 Size: 0x1019F2 State: Ok WiFi MAC: 80795D5ED2E7 BT MAC: 80795D5ED2E6 IMEI[1]: 354191110103107 IMEI[2]: 354191110103115 Read [10] NVDATA Read [3] PROINFO Read [27] LK lk [84d4211d] Read [9] NVCFG Read [12] PROTECT1 Read [1] PGPT Read [11] PERSIST Read [0] PRELOADER Done 9 files 10 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6765__9ED2BD259354C FAD2DEE8D1B8C162D07\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__9ED2BD259354C FAD2DEE8D1B8C162D07.7z Enough [infinix-mobility-limited-infinix-x655-x655-op] Analyze modem... TK_MD_BASIC_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R3_M P_V94_4_P53 Analyze nvram... PSN1: 054823705O103452 EMMC CID: 7001005441323833322332EBE6813725 crc Ok Vendor: Kingston OEM: 256 ID: 544132383332 [TA2832] PRV: 0x23 Serial: 854320769 0x32EBE681 MM/YY: 3/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x74A000000 [ 29.16 Gb ] Analyze preloader... EMI: MT6765 preloader_x655_h6210.bin with 6 memory type(s) 1. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 3. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 4. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 5. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 6. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_x 655_h6210.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_x 655_h6210.bin [3e4d2592]... Exist Probe FRP... Most probably Off Reset port... Finished 1 min 5 sec Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [+] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM3) MODE [0]: PRELOADER PORT; PORT: 3 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 103256E1C694D9CC3B33714AB109E2C0649693A05F635C5DBE 7F13EA664C8F5C AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MediaTek USB Port_V1633 (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 9ED2BD259354CFAD2DEE8D1B8C162D07 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 103256E1C694D9CC3B33714AB109E2C0649693A05F635C5DBE 7F13EA664C8F5C SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok EMI known SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 9ED2BD259354CFAD2DEE8D1B8C162D07 AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 7001005441323833322332EBE6813725 crc Ok Vendor: Kingston OEM: 256 ID: 544132383332 [TA2832] PRV: 0x23 Serial: 854320769 0x32EBE681 MM/YY: 3/2020 EMI: FireFly preloader_x655_h6210.bin with 6 memory type(s) 1. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 3. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 4. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 5. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 6. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 7001005441323833322332EBE6813725 crc Ok Vendor: Kingston OEM: 256 ID: 544132383332 [TA2832] PRV: 0x23 Serial: 854320769 0x32EBE681 MM/YY: 3/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x74A000000 [ 29.16 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: E4D6832517B4B114B6D967A8EFAF2951 MEID: 9ED2BD259354CFAD2DEE8D1B8C162D07 USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 13 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 41 Probe boot... Ok 562 us SW: Infinix/X655-OP/Infinix-X655:10/QP1A.190711.020/ABFG-OP-220823V559:user/release-keys Product Brand: Infinix Product Device: Infinix-X655 Product Model: Infinix X655 Product Name: X655-OP Patch Level: QP1A.190711.020 Display ID: X655-H6210ABFG-Q-OP-220823V559 SW Version: ABFG-OP-220823V559 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-08-01 Build Time: 8/23/2022 12:09:08 PM CPU: armeabi-v7a,armeabi Product Info: x655_h6210 SW: full_x655_h6210-user 10 QP1A.190711.020 65716 release-keys Product Board: Infinix-X655 Board Platform: mt6765 Product Manfct: INFINIX MOBILITY LIMITED Device ID: infinix-mobility-limited-infinix-x655-x655-op Strategy: [infinix] Firmware ID: MT6765_INFINIX_MOBILITY_LIMITED_Infinix_X655_OSv10 _X655-H6210ABFG-Q-OP-220823V559_QP1A.190711.020_x655_h6210 Android ver: 10 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] EMMC CID: 7001005441323833322332EBE6813725 crc Ok Vendor: Kingston OEM: 256 ID: 544132383332 [TA2832] PRV: 0x23 Serial: 854320769 0x32EBE681 MM/YY: 3/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x74A000000 [ 29.16 Gb ] Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__9ED2BD259354C FAD2DEE8D1B8C162D07 Stage: Android OS [2] WIPE... Ok [3] WIPE... Create partition image... Ok Ok [4] WIPE... Create partition image... Ok Ok [6] USERDATA... Ok [7] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 28 sec Reconnect Power/Cable now |
12-03-2024, 19:27 | #76507 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | Infinix-X650 Format & Frp Code: Operation: Reset Settings/Format FS [ v2.54 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM9) MODE [0]: BOOTROM; PORT: 9 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] MEID: FB8647A3B07433AB34558188F4C9539E BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0x05 BL: 0xFE [BOOTROM] SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x00000001 EMI loaded by MEID: FB8647A3B07433AB34558188F4C9539E AGENT: AUTO: 0_base: base_v1712 [7d645779] C:\InfinityBox\CM2MT2\boot\0_base\base_v1712\MTK_AllInOne_DA.e600c7d1.bin Looking for suitable bootchain in DA... Found: MT6580; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started NAND: DEVICE NOT FOUND EMMC: OK CID: 510001154D3336441C910142F317B99A DA v4.2.156 EXT_RAM NOT initialized EMMC: OK CID: 150100514436334D4201911C9AB917F3 NAND: DEVICE NOT FOUND DRAM: 0x00BC EMI: FireFly preloader_x650_h8029.bin with 8 memory type(s) 1. ID: 150100514536334D42 Samsung QE63MB RAM: 2.00 Gb 2. ID: 150100464536324D42 Samsung FE62MB RAM: 1.00 Gb 3. ID: 90014A484247346132 Hynix HBG4a2 RAM: 2.00 Gb 4. ID: 700100464D41454538 Kingston FMAEE8 RAM: 1.00 Gb 5. ID: 700100464D42434541 Kingston FMBCEA RAM: 2.00 Gb 6. ID: 90014A68423861503E Hynix hB8aP> RAM: 2.00 Gb 7. ID: 150100514436334D42 Samsung QD63MB RAM: 2.00 Gb 8. ID: 150100515836334142 Samsung QX63AB RAM: 2.00 Gb INIT: 0x00BC DRAM [ 0x00000000 [ 0 B ] ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] DA: DRAM ready Boot to 2nd DA... Ok Load HW info... EMMC CID: 150100514436334D4201911C9AB917F3 crc Ok Vendor: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x01 Serial: 2434570937 0x911C9AB9 MM/YY: 1/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] RNID: 7D60DB469DFFC4529546D319A5CD753F MEID: FB8647A3B07433AB34558188F4C9539E DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: FULL-SPEED Set port Speed... PTFN: MediaTek DA USB VCOM (Android) (COM10) MODE: PRELOADER PORT; PORT: 10 Boot done LEGACY [MTK] Analyze PMT... Ok PMT: LGPT [0x06] Records: 31 Select info source... [recovery] Ok Patch Level: O11019 Display ID: X650-H8029AB-OGo-210716V484 SW Version: AB-210716V484 Ver. CodeName: REL Ver. Release: 8.1.0 Sec. Patch: 2021-07-05 Build Time: 16/07/2021 9:10:32 am Product Brand: Infinix Product Name: H8029 Product Device: Infinix-X650 Product Info: Infinix-X650 Product Model: Infinix X650 Product Manfct: INFINIX MOBILITY LIMITED CPU: armeabi-v7a,armeabi SW: full_x650_h8029-user 8.1.0 O11019 1626426640 release-keys Product Board: Infinix-X650 Board Platform: mt6580 Device ID: infinix-mobility-limited-infinix-x650-h8029 Strategy: [infinix] Firmware ID: MT6580_INFINIX_MOBILITY_LIMITED_Infinix_X650_OSv8.1.0_X650-H8029AB-OGo-210716V484_O11019_Infinix-X650 SmartInfo: Android Ver: 8 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] EMMC CID: 150100514436334D4201911C9AB917F3 crc Ok Vendor: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x01 Serial: 2434570937 0x911C9AB9 MM/YY: 1/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] Verify config values... Ok Stage: Android OS [1] ... Create partition image... Ok Ok [2] ... Create partition image... Ok Ok [4] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Done: 35 sec Reconnect Power/Cable now |
12-04-2024, 20:11 | #76508 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | TECNO-KE5k Format & Frp Code: SW: TECNO/KE5k-OP/TECNO-KE5k:10/QP1A.190711.020/CD-OP-221010V241:user/release-keys Product Brand: TECNO Product Device: TECNO-KE5k Product Model: TECNO KE5k Product Name: KE5k-OP Patch Level: QP1A.190711.020 Display ID: KE5k-H6122CD-Q-OP-221010V241 SW Version: CD-OP-221010V241 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-10-05 Build Time: 10/10/2022 9:06:58 am CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: ke5k_h6122 SW: full_ke5k_h6122-user 10 QP1A.190711.020 117739 release-keys Product Board: TECNO-KE5k Board Platform: mt6765 Product Manfct: TECNO MOBILE LIMITED Device ID: tecno-mobile-limited-tecno-ke5k-ke5k-op Strategy: [tecno] Firmware ID: MT6765_TECNO_MOBILE_LIMITED_TECNO_KE5k_OSv10_KE5k-H6122CD-Q-OP-221010V241_QP1A.190711.020_ke5k_h6122 Verify firmware [MT6765_TECNO_MOBILE_LIMITED_TECNO_KE5k_OSv10_KE5k-H6122CD-Q-OP-221010V241_QP1A.190711.020_ke5k_h6122]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... TK_MD_BASIC_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R3_MP_V118_11_P53 Analyze nvram... NVRAM: Items: 0xA3 Size: 0x101A86 State: Ok WiFi MAC: AA006E742F76 BlTh MAC: 58356B424DAD IMEI[1]: IMEI[2]: EMMC CID: 15010044503644414202F2DB909D4801 crc Ok Vendor: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 Serial: 4074475677 0xF2DB909D MM/YY: 4/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Verify config values... Ok STORAGE Life Status: eMMC : OK STORAGE OTP Status: UNLOCKED STORAGE RPMB Status: eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Analyze preloader... EMI: MT6765 preloader_ke5k_h6122.bin with 20 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 150100444836444D42 Samsung DH6DMB RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100334836434142 Samsung 3H6CAB RAM: 6.00 Gb 5. eMMC LP_DDR4X ID: 150100335636434D42 Samsung 3V6CMB RAM: 6.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 6.00 Gb 10. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 150100445036384D42 Samsung DP68MB RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 17. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 18. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 19. eMMC LP_DDR4X ID: 13014E53304A333741 Micron S0J37A RAM: 3.00 Gb 20. eMMC LP_DDR4X ID: 150100445036444242 Samsung DP6DBB RAM: 4.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_ke5k_h6122.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_ke5k_h6122.bin [9db6441f]... Exist Probe FRP... Most probably Off Reset port... Trying to reboot... Done: 34 sec Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.54 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [-] Userdata [+] FRP [-] Smart WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make [Userdata] On and repeat operation Wait... - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM9) MODE [0]: BOOTROM; PORT: 9 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 2004155520A42BDA74BECEB6F8E71FC4 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 88A97B27E5AC666F5065F778A117CA3450F28546132EA2C90A30DF31053BED86 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok EMI known SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 2004155520A42BDA74BECEB6F8E71FC4 AGENT: AUTO: 0_base: base_v2316 [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for suitable bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 15010044503644414202F2DB909D4801 crc Ok Vendor: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 Serial: 4074475677 0xF2DB909D MM/YY: 4/2021 EMI: FireFly preloader_ke5k_h6122.bin with 20 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 150100444836444D42 Samsung DH6DMB RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100334836434142 Samsung 3H6CAB RAM: 6.00 Gb 5. eMMC LP_DDR4X ID: 150100335636434D42 Samsung 3V6CMB RAM: 6.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 6.00 Gb 10. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 150100445036384D42 Samsung DP68MB RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 17. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 18. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 19. eMMC LP_DDR4X ID: 13014E53304A333741 Micron S0J37A RAM: 3.00 Gb 20. eMMC LP_DDR4X ID: 150100445036444242 Samsung DP6DBB RAM: 4.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 15010044503644414202F2DB909D4801 crc Ok Vendor: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 Serial: 4074475677 0xF2DB909D MM/YY: 4/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 02E8CC127063BAA145378625DECC2FE1 MEID: 2004155520A42BDA74BECEB6F8E71FC4 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 41 EMMC CID: 15010044503644414202F2DB909D4801 crc Ok Vendor: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 Serial: 4074475677 0xF2DB909D MM/YY: 4/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Verify config values... Ok Stage: Android OS Off Stage: FRP... [1] PROTECTION... Ok Ok Done Reset port... Trying to reboot... Done: 21 sec Reconnect Power/Cable now |
12-05-2024, 08:21 | #76509 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | Card found : S/N : 73CA70CC , v0161 Chinese Miracle II [MTK module] v 1.58 Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : E5F6CE97CCFC4254C807BEA57F996CB2 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 784512 PLock|MobTrack : Not active Done! Elapsed: 00:00:05 Reconnect Power/Cable! |
12-05-2024, 18:14 | #76510 (permalink) |
Super Moderator Join Date: Dec 1999 Location: In EveryOne's Heart
Member: 824 Status: Offline Thanks Meter: 25,340 | CM2 - MT2 Service Tool v2.76 Probe UAC... Ok Probe libusb... v1.2.6.0 Wait... S/N: 00387228C4 v0163 Initalize log engine... Ok Build directories tree... Ok Firmware files: G:\infinix\smsat 5\X657C backup\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 10 dirs: 0 Load emi database... Internal: 28 custom: 0 Check for updates [CM2MT2]... You have latest version [2.76] installed Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Sales: https://infinity-box.com/buy/ Account: https://infinity-box.com/service/ Update configuration... Software may need data from server but Username|Password is wrong. Set it via [Settings|Account] Get list of devices... Ok Reloaded 2173 devices Load IDBase v915508 Ok Build device list... Ok Load 158 profiles... Ok Initalize external tools... Ok Initialize libusb... Ok Ready Operation: Reset Settings/Format FS [ v2.76 ] WARNING: Reset may delete ALL USER DATA! Wipe On; Userdata Off; FRP On; Accounts Off; Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek PreLoader USB VCOM (Android) (COM21) MODE: PRELOADER PORT; PORT: 21 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino Type: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005; Mode: SBC+SDA Ver: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 4F03E48720DCD42B15206EA62912F139AB88F9992C0FB51A4F 1E362F43EFB493 Agent: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending DA1... Reset Interface [1|1|0|0] PTFN: MediaTek USB Port (COM66) MODE: BOOTROM; PORT: 66 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino Type: MODERN [RAPHAEL] MEID: 93234B905850A8409C9F3E32972ABA6B BROM: Sec Level: 0x000000E5; Mode: SBC+SDA+EXT Ver: 0x05 BL: 0xFE [BOOTROM] SOCID: 4F03E48720DCD42B15206EA62912F139AB88F9992C0FB51A4F 1E362F43EFB493 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok [FF] Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 93234B905850A8409C9F3E32972ABA6B Agent: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending DA1... Ok [1|1|1|0] Jump to DA... Ok Sync... Ok DA sync... Ok DA Set Params... Ok Mode: BROM [1|1|1|0] EXT_RAM NOT initialized EMMC CID: 150100514436334D42031D2F067E864D crc Ok Vendor: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 Serial: 489621118 0x1D2F067E MM/YY: 8/2019 EMI: FireFly preloader_s96116ra1.bin with 8 memory types slots: no 1. eMMC DDR3 ID: 150100514436334D42 Samsung QD63MB RAM: 2.00 Gb 2. eMMC DDR3 ID: 700100464D42434541 Kingston FMBCEA RAM: 2.00 Gb 3. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb 4. eMMC DDR3 ID: 150100515836334D42 Samsung QX63MB RAM: 2.00 Gb 5. eMMC DDR3 ID: 150100515836334142 Samsung QX63AB RAM: 2.00 Gb 6. eMMC DDR3 ID: 150100475836424142 Samsung GX6BAB RAM: 3.00 Gb 7. eMMC DDR3 ID: 150100475836424D42 Samsung GX6BMB RAM: 3.00 Gb 8. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 2.00 Gb Push EMI... EXT_RAM CFG Passed Boot DA2... Ok [1|1|1|28] DA Sync... Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 150100514436334D42031D2F067E864D crc Ok Vendor: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 Serial: 489621118 0x1D2F067E MM/YY: 8/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino Type: MODERN [RAPHAEL] RNID: 1BA820352F325D341F62C86D24D79BEC MEID: 93234B905850A8409C9F3E32972ABA6B USB: HIGH-SPEED SoC drivers: MediaTek USB Port v3.2.0.0; Boot done MODERN [RAPHAEL] 31 sec Load partition table... Ok Partition table: PGPT [0x64] with 39 records Device has no slots Probe boot... Finished 797 us AndroidInfo: recovery;gzip;bootimage/loaded ramsidk size 0xD86B1F/00;boot;ramdisk size=0; Probe core... Mount[ext4] wo/cache system 0x0058800000/0xDB000000 Mount[ext4] wo/cache vendor 0x0021800000/0x1C000000 Mount[ext4] wo/cache product 0x003D800000/0x1B000000 Ok 2 sec SW: samsung/a10sxx/a10s:11/RP1A.200720.012/A107FXXS8CWD3:user/release-keys Product Brand: samsung Product Device: a10s Product Model: SM-A107F Product Name: a10sxx Patch Level: RP1A.200720.012 Display ID: RP1A.200720.012.A107FXXS8CWD3 SW Version: A107FXXS8CWD3 Build Time: 4/24/2023 4:16:46 AM Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-03-01 CPU: armeabi-v7a,armeabi Product Info: a10s SW: a10sxx-user 11 RP1A.200720.012 A107FXXS8CWD3 release-keys Product Board: S96116RA1 Board Platform: mt6765 Product Manfct: samsung Device ID: samsung-sm-a107f-a10s-a10sxx-s96116ra1-s96116aa1 Strategy: [samsung] Firmware ID: MT6765_samsung_SM-A107F_OSv11_RP1A.200720.012.A107FXXS8CWD3_RP1A.200 720.012_a10s Android ver: 11 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Backup 23 items to C:\InfinityBox\CM2MT2\backup\MT6765__93234B905850A 8409C9F3E32972ABA6B\ Read [5] nvram Ok 2 sec Read [14] nvdata Ok 2 sec Read [23] proinfo Ok 156 us Read [28] lk Ok 109 us lk [3b211064] Read [13] nvcfg Ok 1 sec Read [16] protect1 Ok 359 us Read [1] pgpt Ok 16 us Read [19] persist Ok 1 sec Read [20] persistent Ok 32 us Read [0] preloader Ok 188 us Read [6] efs Ok 344 us Read [7] sec_efs Ok 343 us Exist [20] persistent Done 12 files 11 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6765__93234B905850A 8409C9F3E32972ABA6B\ Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__93234B905850A 8409C9F3E32972ABA6B.7z Enough [samsung-sm-a107f-a10s-a10sxx-s96116ra1-s96116aa1] Reset: Wipe... process [persistent]... Ok verify [persistent] 128.00 Kb... rewrite... Ok Reset: FRP... process [frp]... Ok verify [frp] 128.00 Kb... rewrite... Ok Completed If FRP still active make [Userdata] reset In case of issue with Wipe make [Userdata] reset Finished Reset Settings/Format FS [ v2.76 ] 1 min 8 sec Keep connection
__________________ Just Follow the Rules and Be Polite Saying "thank you" can be hard. But it's so important. |
12-05-2024, 18:39 | #76511 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | Infinix-X653C Format & Frp Code: Operation: Reset Settings/Format FS [ v2.54 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM6) MODE [0]: PRELOADER PORT; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: B42B7DB4063B0D505EC38AE297CCA78F3093D766FE07EBCB8FA56593C28E5593 IRG: 0x00000080 AGENT: AUTO: 0_base: base_v2316 [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for suitable bootchain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MediaTek USB Port_V1633 (COM9) MODE [0]: BOOTROM; PORT: 9 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: 792B79F1B3F26A7E6DC286A5AC6EFFC7 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: B42B7DB4063B0D505EC38AE297CCA78F3093D766FE07EBCB8FA56593C28E5593 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 792B79F1B3F26A7E6DC286A5AC6EFFC7 AGENT: AUTO: 0_base: base_v2316 [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for suitable bootchain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 700100464D42434541201E6983FF966B crc Ok Vendor: Kingston OEM: 256 ID: 464D42434541 [FMBCEA] PRV: 0x20 Serial: 510231551 0x1E6983FF MM/YY: 9/2019 EMI: FireFly preloader_x653c_h6114go.bin with 14 memory type(s) 1. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 2. eMMC DDR3 ID: FE014A333232344433 Micron 3224D3 RAM: 3.00 Gb 3. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 4. eMMC DDR3 ID: 150100514536334D42 Samsung QE63MB RAM: 2.00 Gb 5. eMMC DDR3 ID: 150100464536324D42 Samsung FE62MB RAM: 1.00 Gb 6. eMMC DDR3 ID: 90014A484147346132 Hynix HAG4a2 RAM: 2.00 Gb 7. eMMC DDR3 ID: 150100514436334D42 Samsung QD63MB RAM: 2.00 Gb 8. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 2.00 Gb 9. eMMC DDR3 ID: 700100464D42434541 Kingston FMBCEA RAM: 2.00 Gb 10. eMMC DDR3 ID: 150100524836344142 Samsung RH64AB RAM: 4.00 Gb 11. eMMC DDR3 ID: 700100464D41454538 Kingston FMAEE8 RAM: 1.00 Gb 12. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb 13. eMMC DDR3 ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 14. eMMC DDR3 ID: 150100525036344D42 Samsung RP64MB RAM: 4.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A600 [ 233.50 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 700100464D42434541201E6983FF966B crc Ok Vendor: Kingston OEM: 256 ID: 464D42434541 [FMBCEA] PRV: 0x20 Serial: 510231551 0x1E6983FF MM/YY: 9/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x74A000000 [ 29.16 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: FC6932DD62D7BBD5AC19A6725D2F90A0 MEID: 792B79F1B3F26A7E6DC286A5AC6EFFC7 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 38 Select info source... [recovery] Ok Patch Level: PPR1.180610.011 Display ID: X653C-H6114GH-PGo-210831V271 SW Version: GH-210831V271 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2021-09-05 Build Time: 31/08/2021 9:00:38 am Product Model: Infinix X653C Product Brand: Infinix Product Name: H6114 Product Device: Infinix-X653C CPU: armeabi-v7a,armeabi Product Manfct: INFINIX MOBILITY LIMITED Product Info: x653c_h6114go SW: full_x653c_h6114go-user 9 PPR1.180610.011 153046 release-keys Product Board: Infinix-X653C Board Platform: mt6761 Device ID: infinix-mobility-limited-infinix-x653c-h6114 Strategy: [infinix] Firmware ID: MT6761_INFINIX_MOBILITY_LIMITED_Infinix_X653C_OSv9_X653C-H6114GH-PGo-210831V271_PPR1.180610.011_x653c_h6114go SmartInfo: Android Ver: 9 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] EMMC CID: 700100464D42434541201E6983FF966B crc Ok Vendor: Kingston OEM: 256 ID: 464D42434541 [FMBCEA] PRV: 0x20 Serial: 510231551 0x1E6983FF MM/YY: 9/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x74A000000 [ 29.16 Gb ] Verify config values... Ok Stage: Android OS [1] ... Create partition image... Ok Ok [2] ... Create partition image... Ok Ok [4] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Done: 37 sec Reconnect Power/Cable now |
12-05-2024, 20:22 | #76512 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 567 | Tablet Blackview Tab 5 kids firmware read ok Operation : Identify [ v2.02 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : 0x0006 SoC CPU : 3326 Flash CSx : 0x00 Flash Type : EMMC Flash Vend : SAMSUNG Flash Size : 0x0000000E8F000000 ( 58,23 GiB ) Flash Info : 524288/2048/40/0/1 Caps : 0x0615 : 0x0000 Connect Ok! Done! Elapsed: 00:00:42 Operation : Read Firmware [ v2.02 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : 0x0006 SoC CPU : 3326 Flash CSx : 0x00 Flash Type : EMMC Flash Vend : SAMSUNG Flash Size : 0x0000000E8F000000 ( 58,23 GiB ) Flash Info : 524288/2048/40/0/1 Caps : 0x0615 : 0x0000 Connect Ok! Reading Flash Content ... [Read Ok] : security.bin [Read Ok] : uboot_a.bin [Read Ok] : uboot_b.bin [Read Ok] : trust_a.bin [Read Ok] : trust_b.bin [Read Ok] : misc.img [Read Ok] : dtbo_a.bin [Read Ok] : dtbo_b.bin [Read Ok] : vbmeta_a.bin [Read Ok] : vbmeta_b.bin [Read Ok] : boot_a.bin [Read Ok] : boot_b.bin [Read Ok] : backup.img [Read Ok] : baseparameter.bin [Read Ok] : super.bin Read finished! Configuration : 3326 / EMMC Firmware Size : 5,50 GiB Done! Elapsed: 00:11:50 |
The Following User Says Thank You to ct3im For This Useful Post: |
12-06-2024, 11:52 | #76513 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | S/N: 0073CA70CC v0161 Chinese Miracle II - MT2 Service Tool v2.63 Init log engine... Ok Build directories tree... Ok Firmware files: C:\Users\Master Mobile\Desktop\New folder\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 66 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Check for updates [CM2MT2]... Installed v2.63 Infinity #CM2MT2 v2.76 - Connection protocol improved to avoid lost connection with low-quality cables - Flash Read sparse/pack method updated Required firmware v0163 Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Sales: https://infinity-box.com/buy/ Account: https://infinity-box.com/service/ Update configuration... Configuration [12412] updated Get list of devices... Ok Reloaded 2174 devices Build device list... Load IDBase v915508 Ok Load 159 profiles... Ok libusb: v1.2.6.0 Init environment... Ok Ready DA selected: 0_base | base_v2316 | MTK_AllInOne_DA.1d5fdec4.bin DA selected: 0_base | base_v2316 | MTK_AllInOne_DA.1d5fdec4.bin DA selected: Oppo | 2021 | MTK_AllInOne_DA_OP.bin Operation: Identify [ v2.63 ] Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM12) MODE [0]: PRELOADER PORT; PORT: 12 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 559124B3DE144255B496605F0D48BCD252A6B00CA4B98DC8D3 8E62EEDB2E5473 AGENT: [f2f720fb] C:\InfinityBox\CM2MT2\boot\Oppo\2021\MTK_AllInOne_ DA_OP.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00038000 [ 224.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 9B01005932503036340022082CC78A21 crc Ok Vendor: Hynix OEM: 256 ID: 593250303634 [Y2P064] PRV: 0x00 Serial: 570961095 0x22082CC7 MM/YY: 8/2023 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: ACCC3F4131A6E697A0A731015162B7F9 USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 8 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 55 STORAGE Life Status: eMMC : OK STORAGE OTP Status: UNLOCKED STORAGE RPMB Status: eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Saved: C:\InfinityBox\CM2MT2\phdata\key.json Get slot info... b Probe boot... Ok 1 sec Product Brand: oplus Product Device: ossi Product Model: ossi Product Name: ossi SW: oplus/ossi/ossi:12/SP1A.210812.016/1722308975346:user/release-keys Patch Level: SP1A.210812.016 Display ID: SP1A.210812.016 release-keys SW Version: 1722308975346 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2024-08-05 Build Time: 7/30/2024 3:09:35 AM Product Info: k65v1_64_bsp SW: vnd_k65v1_64_bsp-user 12 SP1A.210812.016 1722308975346 release-keys Product Manfct: oplus Product Board: k65v1_64_bsp Board Platform: mt6765 Device ID: oplus-ossi-k65v1-64-bsp Strategy: [realme] Firmware ID: MT6765_oplus_ossi_OSv12_SP1A.210812.016_k65v1_64_b sp Verify firmware [MT6765_oplus_ossi_OSv12_SP1A.210812.016_k65v1_64_b sp]... Exist (3) Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Backup to C:\InfinityBox\CM2MT2\backup\MT6765__8C6026509112C 4387B98B7FE23156BB7\ Items to check: 22 Read [20] NVRAM NVRAM: Items: 0xAA Size: 0x102389 State: Ok WiFi MAC: D4BAFA7C33DF BT MAC: D4BAFA7C33DE Read [11] NVDATA Read [19] PROINFO Read [10] NVCFG Read [14] PROTECT1 Read [1] PGPT Read [17] PERSIST Read [0] PRELOADER Read [21] OCDT Read [7] OPLUS_CUSTOM Read [30] LK_A lk [b29ceabe] Read [38] CDT_ENGINEERING_A Read [44] LK_B Read [49] CDT_ENGINEERING_B Done 14 files 10 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6765__8C6026509112C 4387B98B7FE23156BB7\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__8C6026509112C 4387B98B7FE23156BB7.7z Enough [oplus-ossi-k65v1-64-bsp] Analyze modem... Nothing Analyze nvram... PSN1: 0022264539070844 EMMC CID: 9B01005932503036340022082CC78A21 crc Ok Vendor: Hynix OEM: 256 ID: 593250303634 [Y2P064] PRV: 0x00 Serial: 570961095 0x22082CC7 MM/YY: 8/2023 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Analyze preloader... EMI: MT6765 preloader_k65v1_64_bsp.bin with 6 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 3. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 6.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 65v1_64_bsp.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 65v1_64_bsp.bin [944853b1]... Exist Probe FRP... Most probably Off Reset port... Finished 55 sec Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [-] Wipe [-] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make [Userdata] On and repeat operation Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM12) MODE [0]: PRELOADER PORT; PORT: 12 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 559124B3DE144255B496605F0D48BCD252A6B00CA4B98DC8D3 8E62EEDB2E5473 AGENT: [f2f720fb] C:\InfinityBox\CM2MT2\boot\Oppo\2021\MTK_AllInOne_ DA_OP.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00038000 [ 224.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 9B01005932503036340022082CC78A21 crc Ok Vendor: Hynix OEM: 256 ID: 593250303634 [Y2P064] PRV: 0x00 Serial: 570961095 0x22082CC7 MM/YY: 8/2023 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: ACCC3F4131A6E697A0A731015162B7F9 USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 8 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 55 Get slot info... b Probe boot... Ok 1 sec Product Brand: oplus Product Device: ossi Product Model: ossi Product Name: ossi SW: oplus/ossi/ossi:12/SP1A.210812.016/1722308975346:user/release-keys Patch Level: SP1A.210812.016 Display ID: SP1A.210812.016 release-keys SW Version: 1722308975346 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2024-08-05 Build Time: 7/30/2024 3:09:35 AM Product Info: k65v1_64_bsp SW: vnd_k65v1_64_bsp-user 12 SP1A.210812.016 1722308975346 release-keys Product Manfct: oplus Product Board: k65v1_64_bsp Board Platform: mt6765 Device ID: oplus-ossi-k65v1-64-bsp Strategy: [realme] Firmware ID: MT6765_oplus_ossi_OSv12_SP1A.210812.016_k65v1_64_b sp Android ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] EMMC CID: 9B01005932503036340022082CC78A21 crc Ok Vendor: Hynix OEM: 256 ID: 593250303634 [Y2P064] PRV: 0x00 Serial: 570961095 0x22082CC7 MM/YY: 8/2023 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__8C6026509112C 4387B98B7FE23156BB7 Stage: Android OS Off Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 21 sec Reconnect Power/Cable now |
12-07-2024, 16:55 | #76514 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | Infinix X627 Frp Code: Patch Level: PPR1.180610.011 Display ID: X627-H624STXYZAa-P-190725V253 SW Version: STXYZAa-190725V253 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2019-07-05 Build Time: 25/07/2019 2:57:23 am Product Model: Infinix X627 Product Brand: Infinix Product Name: H624 Product Device: Infinix-X627STU CPU: armeabi-v7a,armeabi Product Manfct: INFINIX MOBILITY LIMITED Product Info: x627_h624 SW: full_x627_h624-user 9 PPR1.180610.011 36552 release-keys Product Board: Infinix-X627 Board Platform: mt6761 Device ID: infinix-mobility-limited-infinix-x627-infinix-x627stu-h624 Strategy: [infinix] Firmware ID: MT6761_INFINIX_MOBILITY_LIMITED_Infinix_X627_OSv9_X627-H624STXYZAa-P-190725V253_PPR1.180610.011_x627_h624 Verify firmware [MT6761_INFINIX_MOBILITY_LIMITED_Infinix_X627_OSv9_X627-H624STXYZAa-P-190725V253_PPR1.180610.011_x627_h624]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem : [f2fs] with FDE [forced encrypt] Analyze modem... TK_MD_BASIC_MDBIN_PCB01_MT6761_S00.MOLY_LR12A_R3_MP_V48_P17 Analyze nvram... NVRAM: Items: 0xA2 Size: 0x1018EA State: Ok WiFi MAC: AA006E742F76 BlTh MAC: 74C17D7179D3 IMEI[1]: IMEI[2]: EMMC CID: 700100544132383332230F4BF3706637 crc Ok Vendor: Kingston OEM: 256 ID: 544132383332 [TA2832] PRV: 0x23 Serial: 256635760 0x0F4BF370 MM/YY: 6/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x74A000000 [ 29.16 Gb ] Verify config values... Ok STORAGE Life Status: eMMC : BAD! LIFE CYCLE END! READ-ONLY STATE STORAGE OTP Status: UNLOCKED STORAGE RPMB Status: eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Memory chip may be faulty! Analyze preloader... EMI: MT6761 preloader_x627_h624.bin with 11 memory type(s) 1. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. eMMC DDR3 ID: 150100514536334D42 Samsung QE63MB RAM: 2.00 Gb 3. eMMC DDR3 ID: 150100464536324D42 Samsung FE62MB RAM: 1.00 Gb 4. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 5. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 6. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 7. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 8. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 9. DRAM LP_DDR4 ID: 88 Foresee RAM: 1.00 Gb 10. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 11. DRAM LP_DDR4 ID: 70 Kingston RAM: 1.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_x627_h624.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_x627_h624.bin [ac04cdc4]... Exist Probe FRP... Most probably Off Reset port... Trying to reboot... Done: 45 sec Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.54 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [-] Userdata [+] FRP [-] Smart WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make [Userdata] On and repeat operation Wait... - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM9) MODE [0]: BOOTROM; PORT: 9 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: A6391B2AE021E48DB3155FC9D9FDD0FC BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 2C970C133912360C169D956C65A8F1B45B5098C6EF84F9C21CBA27BEF0C9439A SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok EMI known SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: A6391B2AE021E48DB3155FC9D9FDD0FC AGENT: AUTO: 0_base: base_v2316 [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for suitable bootchain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 700100544132383332230F4BF3706637 crc Ok Vendor: Kingston OEM: 256 ID: 544132383332 [TA2832] PRV: 0x23 Serial: 256635760 0x0F4BF370 MM/YY: 6/2019 EMI: FireFly preloader_x627_h624.bin with 11 memory type(s) 1. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. eMMC DDR3 ID: 150100514536334D42 Samsung QE63MB RAM: 2.00 Gb 3. eMMC DDR3 ID: 150100464536324D42 Samsung FE62MB RAM: 1.00 Gb 4. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 5. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 6. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 7. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 8. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 9. DRAM LP_DDR4 ID: 88 Foresee RAM: 1.00 Gb 10. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 11. DRAM LP_DDR4 ID: 70 Kingston RAM: 1.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A600 [ 233.50 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 700100544132383332230F4BF3706637 crc Ok Vendor: Kingston OEM: 256 ID: 544132383332 [TA2832] PRV: 0x23 Serial: 256635760 0x0F4BF370 MM/YY: 6/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x74A000000 [ 29.16 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 94BCAEC5C4D9426534D855A034691B44 MEID: A6391B2AE021E48DB3155FC9D9FDD0FC USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 39 EMMC CID: 700100544132383332230F4BF3706637 crc Ok Vendor: Kingston OEM: 256 ID: 544132383332 [TA2832] PRV: 0x23 Serial: 256635760 0x0F4BF370 MM/YY: 6/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x74A000000 [ 29.16 Gb ] Verify config values... Ok Stage: Android OS Off Stage: FRP... [1] PROTECTION... Ok Ok Done Reset port... Trying to reboot... Done: 18 sec Reconnect Power/Cable now |
12-07-2024, 17:14 | #76515 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | HOTWAV Pearl_K2 Format & Frp Code: Operation: Reset Settings/Format FS [ v2.54 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM6) MODE [0]: PRELOADER PORT; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 569DAFA75CFAD9A724EC1106B1E51306DDAF381B7FC10905E605B56EFAD4334F AGENT: AUTO: 0_base: base_v2316 [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for suitable bootchain in DA... Found: MT6739; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 90014A484247346132A52300883564C7 crc Ok Vendor: Hynix OEM: 330 ID: 484247346132 [HBG4a2] PRV: 0xA5 Serial: 587237429 0x23008835 MM/YY: 6/2017 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] RNID: AED16C71CAD3B9774B8309FBBAB21081 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 35 Select info source... [recovery] Ok Patch Level: PPR1.180610.011 Display ID: HOTWAV_J413_K2_V9.0_20190629 SW Version: 1561808070 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2019-06-05 Build Time: 29/06/2019 11:32:24 am Product Model: Pearl K2 Product Brand: HOTWAV Product Name: Pearl_K2 Product Device: Pearl_K2 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: HOTWAV Product Info: Pearl_K2 SW: full_k39tv1_64_bsp-user 9 PPR1.180610.011 1561808070 release-keys Product Board: k39tv1_64_bsp Board Platform: mt6739 Device ID: hotwav-pearl-k2-k39tv1-64-bsp Strategy: [none|generic] Firmware ID: MT6739_HOTWAV_Pearl_K2_OSv9_HOTWAV_J413_K2_V9.0_20190629_PPR1.180610.011_Pearl_K2 SmartInfo: Android Ver: 9 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 90014A484247346132A52300883564C7 crc Ok Vendor: Hynix OEM: 330 ID: 484247346132 [HBG4a2] PRV: 0xA5 Serial: 587237429 0x23008835 MM/YY: 6/2017 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] Verify config values... Ok Stage: Android OS [1] ... Create partition image... Ok Ok [2] ... Create partition image... Ok Ok [4] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Done: 1 min 4 sec Reconnect Power/Cable now |
