![]() | #76516 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2021 Location: Nigeria
Member: 2993572 Status: Offline Thanks Meter: 198 ![]() | Infinix X652 frp reset done Code: CM2 - MT2 Service Tool v2.76 Probe UAC... Ok Probe libusb... v1.2.7.3 Wait... S/N: 00A6936825 v0163 Initalize log engine... Ok Build directories tree... Ok Firmware files: F:\Backup Files\ Backup files: C:\InfinityBox\CM2MT2\backup\ Compact backup files... Backup files: 49 dirs: 1 Load emi database... Internal: 28 custom: 0 Load IDBase v915508 Ok Build device list... Ok Load 158 profiles... Ok Initalize external tools... Ok Initialize libusb... Ok Software may need data from server but Username|Password is wrong. Set it via [Settings|Account] Ready Operation: Reset Settings/Format FS [ v2.76 ] WARNING: Reset may delete ALL USER DATA! Wipe On; Userdata On; FRP On; Accounts Off; Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM14) MODE: PRELOADER PORT; PORT: 14 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino Type: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005; Mode: SBC+SDA Ver: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 01DD6CCB5B9AF733697A95152848B181EC4F9A8EB8B7AAEABD30059064AA443D Agent: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending DA1... Reset Interface [1|1|0|0] PTFN: MediaTek USB Port_V1633 (COM13) MODE: BOOTROM; PORT: 13 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino Type: MODERN [RAPHAEL] MEID: 1F3D30F86FAEC6DA394401755193FC60 BROM: Sec Level: 0x000000E5; Mode: SBC+SDA+EXT Ver: 0x05 BL: 0xFE [BOOTROM] SOCID: 01DD6CCB5B9AF733697A95152848B181EC4F9A8EB8B7AAEABD30059064AA443D SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok [FF] Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 1F3D30F86FAEC6DA394401755193FC60 Agent: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending DA1... Ok [1|1|1|0] Jump to DA... Ok Sync... Ok DA sync... Ok DA Set Params... Ok Mode: BROM [1|1|1|0] EXT_RAM NOT initialized EMMC CID: 150100525036344D4201E3D4907AB657 crc Ok Vendor: Samsung OEM: 256 ID: 525036344D42 [RP64MB] PRV: 0x01 Serial: 3822358650 0xE3D4907A MM/YY: 11/2019 EMI: FireFly preloader_x652_h627.bin with 8 memory types slots: no 1. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 2. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 3. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb 4. eMMC DDR3 ID: 150100524836344142 Samsung RH64AB RAM: 4.00 Gb 5. eMMC DDR3 ID: 90014A484247346132 Hynix HBG4a2 RAM: 4.00 Gb 6. eMMC DDR3 ID: 150100525836344D42 Samsung RX64MB RAM: 4.00 Gb 7. eMMC DDR3 ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 8. eMMC DDR3 ID: 150100525036344D42 Samsung RP64MB RAM: 4.00 Gb Push EMI... EXT_RAM CFG Passed Boot DA2... Ok [1|1|1|28] DA Sync... Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100525036344D4201E3D4907AB657 crc Ok Vendor: Samsung OEM: 256 ID: 525036344D42 [RP64MB] PRV: 0x01 Serial: 3822358650 0xE3D4907A MM/YY: 11/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino Type: MODERN [RAPHAEL] RNID: 464398D1779268D25BCCE2CB3263BD96 MEID: 1F3D30F86FAEC6DA394401755193FC60 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] 12 sec Load partition table... Ok Partition table: PGPT [0x64] with 39 records Device has no slots Probe boot... Ok 703 us AndroidInfo: recovery;gzip;bootimage/loaded ramsidk size 0x7222E2/EDE400; Patch Level: PPR1.180610.011 Display ID: X652-H627AB-P-210513V451 SW Version: AB-210513V451 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2021-05-05 Build Time: 13/05/2021 07:55:21 Product Model: Infinix X652 Product Brand: Infinix Product Name: H627 Product Device: Infinix-X652 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: INFINIX MOBILITY LIMITED Product Info: x652_h627 SW: full_x652_h627-user 9 PPR1.180610.011 108317 release-keys Product Board: Infinix-X652 Board Platform: mt6765 Device ID: infinix-mobility-limited-infinix-x652-h627 Strategy: [infinix] Firmware ID: MT6765_INFINIX_MOBILITY_LIMITED_Infinix_X652_OSv9_X652-H627AB-P-210513V451_PPR1.180610.011_x652_h627 Android ver: 9 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Reset: Wipe... Step #1... Ok Step #2... Finished Reset: Userdata... [1] userdata... Create partition image... Make filesystem [0x03 f2fs]... Ok Ok Ok [2] cache... Create partition image... Make filesystem [0x02 ext4|8+]... Ok Ok Ok [4] metadata... process [metadata]... Ok verify [metadata] 128.00 Kb... reread... Ok Ok Reset: FRP... process [frp]... Ok verify [frp] 128.00 Kb... rewrite... Ok Completed Reset port... Trying to reboot... Finished Reset Settings/Format FS [ v2.76 ] 36 sec |
![]() | #76517 (permalink) |
Member: 2993572 Status: Offline Thanks Meter: 198 ![]() | Tecno pop 8 frp reset done Code: Operation: Connect tecno BG6i Boot [FF] FireFly [v2.32] Wait... Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... Device found PTFN: SPRD U2S Diag (COM19) 1782:4D00 boot: SPRD3 boot iLoader... Ok start iLoader... Ok Handshake... Ok boot xLoader... Ok start FireFly... Ok Loader exec [0] Ok Dev UID: bb9de0b2f1974c6e56b3073e1c7454a9195c4bea39299f69ed97421a28f4c389 stored 6 hwid cache items get storage info... MMC EMMC CID: 150100445036384D4202DE77D3B7295B crc Ok Vendor: Samsung OEM: 256 ID: 445036384D42 [DP68MB] PRV: 0x02 Serial: 3732394935 0xDE77D3B7 MM/YY: 2/2022 CSD: D02701320F5903FFF6DBFFEF8E404001 temp_write_protect: False perm_write_protect: False wp_group: 0x10 en 0x01 read extcsd... Ok EXTCSD rev1.8 EMMC 5.1 FW: 02 ERASE_GROUP_DEF: 0x0400 BOOT_BUS_WIDTH: 0x00 PARTITION_CONFIG: 0x08 RST_N_FUNCTION: 0x01 PART_S_COMPLETED: False BOOT size: 0x400000 RPMB size: 0x1000000 16.00 Mb WP_GRP_SIZE: 0x800000 8.00 Mb Size: Market 64 Gb Actual 0xE8F800000 58.24 Gb EOL: Status: Normal: Less than 80% reserved blocks used EOL_A: SLC status: 0% - 10% used EOL_B: MLC status: 0% - 10% used extcsd stored: C:\InfinityBox\CM2SP3\backup\ext_csd\none_bb9de0b2f1974c6e_extcsd_0015-Samsung_DP68MB_5.1_2024-12-07.bin get partitions... Load primary GPT... Load secondary GPT... Primary GPT state Ok Secondary GPT state Ok Partitions: 75 Connected Partitions: 75 get sw info... AndroidInfo: vendor_boot_a;lz4;bootimage/loaded ramsidk size 0x16E80F2/34EB400; 20 sec Product Brand: TECNO Product Device: TECNO-BG6i Product Model: TECNO BG6i Product Name: BG6i SW: TECNO/BG6i-OP/TECNO-BG6i:13/TP1A.220624.014/240103V152:user/release-keys Market Name: TECNO POP 8 Patch Level: TP1A.220624.014 Display ID: BG6i-F0610AB-TGo-OP-240103V152 Product Name: BG6i-OP Ver. CodeName: REL Ver. Release: 13 Sec. Patch: 2023-12-05 Build Time: 03/01/2024 05:57:08 Product Info: BG6i SW: BG6i-user 13 TP1A.220624.014 60 release-keys SW Version: 240103V152 Product Manfct: TECNO Board Platform: ums9230 Product Board: TECNO-BG6i Android ver: 13 UserDataFS: 0x03 [f2fs] CacheFS: 0x03 [f2fs] Device ID: tecno-bg6i-bg6i-op-tecno-pop-8 Strategy: [tecno] Firmware ID: UMS9230_TECNO_TECNO_BG6i_OSv13_BG6i-F0610AB-TGo-OP-240103V152_TP1A.220624.014_BG6i Read Device-ID... loaded 1 items IMEI1: 354373853XXXXXX IMEI2: 354373853XXXXXX IMEI3: 867400020XXXXXX IMEI4: 867400020XXXXXX BT MAC: c4:a4:51:47:1f:b0 WiFi MAC: c4:a4:51:47:1f:b1 PSN1: 116103741L005880 PSN2: N/A PSN3: N/A get slots... slot: b Probe bootloader... Method: known(9) known(1) b=>a Bootloader state: Empty [untouched] [MemTool] load 75 items Finished 46 sec Operation: Reset | Format tecno BG6i Boot [FF] FireFly [v2.32] WARNING: Reset may delete ALL USER DATA! Continue? Yes [-] Wipe [-] Userdata [+] FRP [+] nvram Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... Partitions: 75 Process FRP... Looking for items... 1 items found [1] Writing... Ok Process nvram... [17] Format... Ok [18] Format... Ok Completed Finished 3 sec Reboot... Disconnect cable if it freez CMD 0x05 0x8E PHONE_WAIT_INPUT_TIMEOUT Bye |
![]() | #76518 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: Pakistan karachi
Member: 314003 Status: Offline Thanks Meter: 3,003 | vivo PD1803 Format & Frp Code: Operation: Reset Settings/Format FS [ v2.54 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM9) MODE [0]: BOOTROM; PORT: 9 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: DF4A0DC49C86221B1A84D2ABFFEF8C73 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 58DF60744547E5156253D5614AA9CF883C66F083D2184FE57C7193BCC3E73BE9 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: DF4A0DC49C86221B1A84D2ABFFEF8C73 AGENT: AUTO: 0_base: base_v2316 [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for suitable bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 15010052483634414205F17E9A62554F crc Ok Vendor: Samsung OEM: 256 ID: 524836344142 [RH64AB] PRV: 0x05 Serial: 4051606114 0xF17E9A62 MM/YY: 5/2018 EMI: FireFly preloader_k62v1_64_bsp.bin with 6 memory type(s) 1. eMMC DDR3 ID: 150100524436344D42 Samsung RD64MB RAM: 4.00 Gb 2. eMMC DDR3 ID: 150100524836344142 Samsung RH64AB RAM: 4.00 Gb 3. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb 4. eMMC DDR3 ID: 90014A484247346132 Hynix HBG4a2 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100444836444D42 Samsung DH6DMB RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 15010052483634414205F17E9A62554F crc Ok Vendor: Samsung OEM: 256 ID: 524836344142 [RH64AB] PRV: 0x05 Serial: 4051606114 0xF17E9A62 MM/YY: 5/2018 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 86BAAD11A4226C6B74607F08A892E26B MEID: DF4A0DC49C86221B1A84D2ABFFEF8C73 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 43 Select info source... [recovery] Ok Patch Level: O11019 Display ID: O11019 release-keys SW Version: 1548163527 Ver. CodeName: REL Ver. Release: 8.1.0 Sec. Patch: 2019-01-05 Build Time: 22/01/2019 1:24:08 pm Product Model: vivo PD1803 Product Brand: vivo Product Name: PD1803 Product Device: PD1803 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: vivo Product Info: k62v1_64_bsp SW: full_k62v1_64_bsp-user 8.1.0 O11019 1548163527 release-keys Product Board: k62v1_64_bsp Board Platform: mt6765 Device ID: vivo-pd1803-k62v1-64-bsp-full-k62v1-64-bsp Strategy: [vivo] Firmware ID: MT6765_vivo_vivo_PD1803_OSv8.1.0_O11019_k62v1_64_bsp SmartInfo: Android Ver: 8 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 15010052483634414205F17E9A62554F crc Ok Vendor: Samsung OEM: 256 ID: 524836344142 [RH64AB] PRV: 0x05 Serial: 4051606114 0xF17E9A62 MM/YY: 5/2018 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Verify config values... Ok Stage: Android OS [1] ... Create partition image... Ok Ok [2] ... Create partition image... Ok Ok [4] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Ok Reset port... Trying to reboot... Done: 35 sec Reconnect Power/Cable now |
![]() | #76519 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | Oppo A16 Flash Code: Operation: Write FW [ v2.54 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Wait... [+] Re-Partition [-] Checksum Verify [+] Pre-Erase [+] Check compatibility [+] Backup [-] FLASH ERASE G:\OPPO File\A16 CPH2269\CPH2269export_11_A.09_2021112614370115\CPH2269export_11_A.09_2021112614370115.ofp2bin\ preloader_oppo6765.bin [ 249.42 Kb ] 7f64ac41 recovery.img [ 98.00 Mb ] opporeserve2.img [ 5.05 Mb ] 49d7fedb vbmeta_system.img [ 4.00 Kb ] afdf8177 vbmeta_vendor.img [ 4.00 Kb ] b4507ca1 cdt_engineering.img [ 1.00 Mb ] a6a183c5 md1img.img [ 48.58 Mb ] spmfw.img [ 62.58 Kb ] 005d3680 scp.img [ 385.98 Kb ] aa2477b3 scp.img [ 385.98 Kb ] aa2477b3 sspm.img [ 423.75 Kb ] e1907c95 sspm.img [ 423.75 Kb ] e1907c95 gz.img [ 2.48 Mb ] c3ed055f gz.img [ 2.48 Mb ] c3ed055f lk.img [ 4.30 Mb ] 3577f76b lk.img [ 4.30 Mb ] 3577f76b boot.img [ 32.00 Mb ] logo.bin [ 1.97 Mb ] cc1b0414 dtbo.img [ 274.47 Kb ] 5ae7f3c0 tee.img [ 880.22 Kb ] 6004e20a tee.img [ 880.22 Kb ] 6004e20a super.img [ 8.05 Gb ] vbmeta.img [ 4.00 Kb ] 86710035 cache.img [ 68.17 Kb ] a7c2a515 userdata.img [ 307.00 Mb ] Files: 25; Total size: 0x22371E3BC [ 8.55 Gb ] Product Board: oppo6765 Board Platform: mt6765 Product Brand: alps Product Device: oppo6765 Product Manfct: alps Product Model: oppo6765 Product Name: vnd_oppo6765 Firmware ID: MT6765_alps_oppo6765 - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM13) MODE [0]: PRELOADER PORT; PORT: 13 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 5C8F563D2F84718DB2903677D5CB0A6116F14428B610BD683441377342E22B51 AGENT: AUTO: 0_base: base_v2316 [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin [7f64ac41] G:\OPPO File\A16 CPH2269\CPH2269export_11_A.09_2021112614370115\CPH2269export_11_A.09_2021112614370115.ofp2bin\preloader_oppo6765.bin Looking for suitable bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MediaTek USB Port_V1633 (COM9) MODE [0]: BOOTROM; PORT: 9 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: F16980B190028485013BF334A4E5D73A BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 5C8F563D2F84718DB2903677D5CB0A6116F14428B610BD683441377342E22B51 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: F16980B190028485013BF334A4E5D73A AGENT: AUTO: 0_base: base_v2316 [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin [7f64ac41] G:\OPPO File\A16 CPH2269\CPH2269export_11_A.09_2021112614370115\CPH2269export_11_A.09_2021112614370115.ofp2bin\preloader_oppo6765.bin Looking for suitable bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100445836384D420909BECE7E7853 crc Ok Vendor: Samsung OEM: 256 ID: 445836384D42 [DX68MB] PRV: 0x09 Serial: 163499646 0x09BECE7E MM/YY: 7/2021 EMI: Init via preloader_oppo6765.bin EMI: MT6765 preloader_oppo6765.bin with 9 memory type(s) 1. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 2. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 4. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 8. eMMC LP_DDR4X ID: 150100445036444242 Samsung DP6DBB RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 150100445836384D420909BECE7E7853 crc Ok Vendor: Samsung OEM: 256 ID: 445836384D42 [DX68MB] PRV: 0x09 Serial: 163499646 0x09BECE7E MM/YY: 7/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 30BD06723DB580295984A24166C49A17 MEID: F16980B190028485013BF334A4E5D73A USB: HIGH-SPEED Boot done MODERN [RAPHAEL] HW verification... Ok Analyze PMT... Ok PMT: PGPT [0x64] Records: 48 EMMC CID: 150100445836384D420909BECE7E7853 crc Ok Vendor: Samsung OEM: 256 ID: 445836384D42 [DX68MB] PRV: 0x09 Serial: 163499646 0x09BECE7E MM/YY: 7/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] Verify config values... Ok Pre-Flash backup... Backup to C:\InfinityBox\CM2MT2\backup\MT6765__F16980B190028485013BF334A4E5D73A\ Items to check: 22 Read [35] NVRAM Read [14] NVDATA Read [22] PROINFO Read [36] LK Read [13] NVCFG Read [17] PROTECT1 Read [1] PGPT Read [20] PERSIST Read [0] PRELOADER Read [23] OCDT Read [5] OPPORESERVE1 Read [7] OPPORESERVE3 ZERO CONTENT file [64.00 Mb] deleted: C:\InfinityBox\CM2MT2\backup\MT6765__F16980B190028485013BF334A4E5D73A\opporeserve3.bin Read [8] OPPO_CUSTOM Read [26] CDT_ENGINEERING Done 13 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__F16980B190028485013BF334A4E5D73A\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__F16980B190028485013BF334A4E5D73A.7z Verified Verify PMT... Ok Verify SEC DL... Pre-Erase... Erase: 0x0000000000000000 0x0000000006388000 Erase: 0x0000000012C88000 0x0000000002500000 Erase: 0x0000000017188000 0x000000000769A000 Erase: 0x0000000023800000 0x0000000000200000 Erase: 0x000000002A500000 0x0000000009100000 Erase: 0x0000000037600000 0x00000002E8200000 RePartition... Ok Analyze PMT... Ok PMT: PGPT [0x64] Records: 48 Flash write... Write: PRELOADER [ 249.42 Kb ] Update bootloader backup copy [preloader_backup]... Ok Write: RECOVERY [ 98.00 Mb ] Ok Write: OPPORESERVE2 [ 5.05 Mb ] Ok Write: VBMETA_SYSTEM [ 4.00 Kb ] Ok Write: VBMETA_VENDOR [ 4.00 Kb ] Ok Write: CDT_ENGINEERING [ 1.00 Mb ] Ok Write: MD1IMG [ 48.58 Mb ] Ok Write: SPMFW [ 62.58 Kb ] Ok Write: SCP1 [ 385.98 Kb ] Ok Write: SCP2 [ 385.98 Kb ] Ok Write: SSPM_1 [ 423.75 Kb ] Ok Write: SSPM_2 [ 423.75 Kb ] Ok Write: GZ1 [ 2.48 Mb ] Ok Write: GZ2 [ 2.48 Mb ] Ok Write: LK [ 4.30 Mb ] Ok Write: LK2 [ 4.30 Mb ] Ok Write: BOOT [ 32.00 Mb ] Ok Write: LOGO [ 1.97 Mb ] Ok Write: DTBO [ 274.47 Kb ] Ok Write: TEE1 [ 880.22 Kb ] Ok Write: TEE2 [ 880.22 Kb ] Ok Write: SUPER [ 8.05 Gb ] Ok Write: VBMETA [ 4.00 Kb ] Ok Write: CACHE [ 68.17 Kb ] Ok Write: USERDATA [ 307.00 Mb ] Ok RePartition... Ok Reset port... Trying to reboot... Done: 6 min 52 sec Reconnect Power/Cable now |
![]() | #76520 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | Alcatel 5030U Frp Code: Product Brand : Alcatel Product Device : Jakarta Product Model : 5030U Product Name : 5030U Patch Level : QP1A.190711.020 Display ID : 5030U_ALAP_2SIM_V2.6_20211124_UNLOCK Ver. Incmt : 5030U_ALAP_2SIM_V2.6 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-11-05 Build Time : 24.11.2021 Product Info : 5030U Product Board : sp9863a_1h10 Board Platform : sp9863a Product Manfct : TCL NVMng : SecurityInfo IMEI[1] : IMEI[2] : IMEI[3] : SEC : SLS:2, SKS:0, SKV:4 Platform Version: MOCORTM_18B_W21.15.3_P1_Debug Project Version: sharkl3_pub BASE Version: FM_BASE_18B_W21.15.3_P1 HW Version: sc9863A_modem CMP_Time : 05-25-2021 13:11:05 MODEM TAG : MOCORTM_18B_W21.15.3_P1_Debug_FM_BASE_18B_W21.15.3_P1_sc9863A_modem_sharkl3_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:49 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : alcatel-tcl : 5030_D_X Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:12 |
![]() | #76523 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | OPPO CPH1923 Format & Frp Code: Operation: Reset Settings/Format FS [ v2.54 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM9) MODE [0]: BOOTROM; PORT: 9 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 51F301CEB23DCC9E7B0381F18C4A07F3 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 175157509488D0CC362E09108B664AE791D6733E8A6657F0823F4C4E939684DC SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 51F301CEB23DCC9E7B0381F18C4A07F3 AGENT: AUTO: 0_base: base_v2316 [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for suitable bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100514436334D4203D7836AE27687 crc Ok Vendor: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 Serial: 3615714018 0xD7836AE2 MM/YY: 7/2019 EMI: FireFly preloader_oppo6762_18540.bin with 9 memory type(s) 1. eMMC DDR3 ID: 150100515836334142 Samsung QX63AB RAM: 2.00 Gb 2. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC DDR3 ID: 90014A484147346132 Hynix HAG4a2 RAM: 2.00 Gb 4. eMMC DDR3 ID: 13014E53304A394237 Micron S0J9B7 RAM: 3.00 Gb 5. eMMC DDR3 ID: 150100514536334D42 Samsung QE63MB RAM: 2.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 7. eMMC DDR3 ID: 150100524436344D42 Samsung RD64MB RAM: 4.00 Gb 8. eMMC DDR3 ID: 150100514436334D42 Samsung QD63MB RAM: 2.00 Gb 9. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 150100514436334D4203D7836AE27687 crc Ok Vendor: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 Serial: 3615714018 0xD7836AE2 MM/YY: 7/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 222AC01FF4CC780D84ED56EBF68E1586 MEID: 51F301CEB23DCC9E7B0381F18C4A07F3 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 42 Select info source... [recovery] Ok Patch Level: PPR1.180610.011 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2021-05-05 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: OPPO SW: full_oppo6762_18540-user 9 PPR1.180610.011 eng.root.20210506.165532 release-keys Build Time: 06/05/2021 9:00:08 am SW Version: 1620291608 Product Brand: OPPO Product Model: CPH1923 Product Info: CPH1923 Product Name: CPH1923 Product Device: OP486C SW OTA Version: CPH1923EX_11.A.40_0400_202105061633 Display ID: CPH1923EX_11_A.40 Kernel Info: 4.9.117 Device ID: oppo-cph1923-op486c-MT6765_CPH1923EX_11_A.18_190705_3e5fcc54 Strategy: [oppo] Firmware ID: MT6765_OPPO_CPH1923_OSv9_CPH1923EX_11_A.40_PPR1.180610.011_CPH1923.MT6765_CPH1923EX_11_A.18_190705_3e5fcc54 SmartInfo: Android Ver: 9 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 150100514436334D4203D7836AE27687 crc Ok Vendor: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 Serial: 3615714018 0xD7836AE2 MM/YY: 7/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] Verify config values... Ok Stage: Android OS [1] ... Create partition image... Ok Ok [2] ... Create partition image... Ok Ok [4] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... regionlock looks like On Reset? No Reset port... Trying to reboot... Done: 39 sec Reconnect Power/Cable now |
![]() | #76524 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | vivo V2026 Format & Frp Code: Operation: Reset Settings/Format FS [ v2.54 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM6) MODE [0]: PRELOADER PORT; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 29B779EC9E69D331FA86BE5007DE1EAE4786E249F1D3EA223BB2498786414230 AGENT: AUTO: Vivo: 2022-12 [7c77dd2d] C:\InfinityBox\CM2MT2\boot\Vivo\2022-12\MTK_AllInOne_DA_2.bin Looking for suitable bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 90014A684339615033011034B1C6C729 crc Ok Vendor: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 Serial: 271888838 0x1034B1C6 MM/YY: 12/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 373FDF1793FB263D5FD83D03BC65F351 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 47 Select info source... [recovery] Ok SW: vivo/2026/2026:11/RP1A.200720.012/compiler0504145542:user/release-keys Product Brand: vivo Product Device: 2026 Product Model: V2026 Product Name: 2026 Patch Level: RP1A.200720.012 Display ID: RP1A.200720.012 release-keys Product Info: k65v1_64_bsp SW: full_k65v1_64_bsp-user 11 RP1A.200720.012 eng.compil.20230504.145730 release-keys SW Version: eng.compil.20230504.145730 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-05-01 Build Time: 04/05/2023 6:55:42 am CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Board: k65v1_64_bsp Board Platform: mt6765 Product Manfct: vivo Device ID: vivo-v2026-k65v1-64-bsp Strategy: [vivo] Firmware ID: MT6765_vivo_V2026_OSv11_RP1A.200720.012_k65v1_64_bsp SmartInfo: Android Ver: 11 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 90014A684339615033011034B1C6C729 crc Ok Vendor: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 Serial: 271888838 0x1034B1C6 MM/YY: 12/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Verify config values... Ok Stage: Android OS [1] ... Create partition image... Ok Ok [2] ... Create partition image... Ok Ok [4] USERDATA... Ok [5] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Ok Reset port... Trying to reboot... Done: 32 sec Reconnect Power/Cable now |
![]() | #76525 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | Infinix-X652B Format & Frp Code: Operation: Reset Settings/Format FS [ v2.54 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port_V1633 (COM9) MODE [0]: BOOTROM; PORT: 9 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 8530CFCEC098F106B63CB6D220A50070 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 6ED28C723EF520F4AA75F0011230A1DCA7495BACD50142F95CBE7B6BF66447AB SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 8530CFCEC098F106B63CB6D220A50070 AGENT: AUTO: 0_base: base_v2316 [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for suitable bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100525036344D42010AF06AD627AB crc Ok Vendor: Samsung OEM: 256 ID: 525036344D42 [RP64MB] PRV: 0x01 Serial: 183528150 0x0AF06AD6 MM/YY: 2/2020 EMI: FireFly preloader_x652b_h627.bin with 8 memory type(s) 1. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 2. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 3. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb 4. eMMC DDR3 ID: 150100524836344142 Samsung RH64AB RAM: 4.00 Gb 5. eMMC DDR3 ID: 90014A484247346132 Hynix HBG4a2 RAM: 4.00 Gb 6. eMMC DDR3 ID: 150100525836344D42 Samsung RX64MB RAM: 4.00 Gb 7. eMMC DDR3 ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 8. eMMC DDR3 ID: 150100525036344D42 Samsung RP64MB RAM: 4.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100525036344D42010AF06AD627AB crc Ok Vendor: Samsung OEM: 256 ID: 525036344D42 [RP64MB] PRV: 0x01 Serial: 183528150 0x0AF06AD6 MM/YY: 2/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: A3EA07397C6A6712FFAB9C72D0883030 MEID: 8530CFCEC098F106B63CB6D220A50070 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 39 Select info source... [recovery] Ok Patch Level: PPR1.180610.011 Display ID: X652B-H627CDM-P-210831V270 SW Version: CDM-210831V270 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2021-09-05 Build Time: 31/08/2021 8:30:30 am Product Model: Infinix X652B Product Brand: Infinix Product Name: H627 Product Device: Infinix-X652B CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: INFINIX MOBILITY LIMITED Product Info: x652b_h627 SW: full_x652b_h627-user 9 PPR1.180610.011 153024 release-keys Product Board: Infinix-X652B Board Platform: mt6765 Product Brand: orange Device ID: orange-infinix-mobility-limited-infinix-x652b-h627 Strategy: [infinix] Firmware ID: MT6765_INFINIX_MOBILITY_LIMITED_Infinix_X652B_OSv9_X652B-H627CDM-P-210831V270_PPR1.180610.011_x652b_h627_orange SmartInfo: Android Ver: 9 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] EMMC CID: 150100525036344D42010AF06AD627AB crc Ok Vendor: Samsung OEM: 256 ID: 525036344D42 [RP64MB] PRV: 0x01 Serial: 183528150 0x0AF06AD6 MM/YY: 2/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Verify config values... Ok Stage: Android OS [1] ... Create partition image... Ok Ok [2] ... Create partition image... Ok Ok [4] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Done: 1 min 7 sec Reconnect Power/Cable now |
![]() | #76526 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,432 | KYOCERA-BASIO 4 KYV47 FRP DoNE Operation: Identify [ v2.77d1 (beta) ] Code: Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek PreLoader USB VCOM (Android) (COM3) MODE: PRELOADER PORT; PORT: 3 Waiting for BOOT ACK... Boot Init... Ok CHIP: MT6761 HWs: 0x8A00 HWv: 0xCA01 HWc: 0x0717 SWv: 0x0200 Evo: 0x0000 Code: Merlot|A20|A22 Type: MODERN [RAPHAEL] Sec Level: 0x00000005; Mode: SBC+SDA Ver: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: D444F694B086561D6FE56617019C0B23A2B42FB092A737A9FA55FC47DE78C3E3 IRG: 0x00000080 Agent: [07fb00a6] F:\infinity\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT Sending DA1... Reset Interface [1|1|0|0] PTFN: MediaTek USB Port (COM30) MODE: BOOTROM; PORT: 30 Waiting for BOOT ACK... Boot Init... Ok CHIP: MT6761 HWs: 0x8A00 HWv: 0xCA01 HWc: 0x0717 SWv: 0x0200 Evo: 0x0000 Code: Merlot|A20|A22 Type: MODERN [RAPHAEL] MEID: 2D57C8D430AE7D802442B8597BCD6F1D Sec Level: 0x000000E5; Mode: SBC+SDA+EXT Ver: 0x05 BL: 0xFE [BOOTROM] SOCID: D444F694B086561D6FE56617019C0B23A2B42FB092A737A9FA55FC47DE78C3E3 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok [FF] Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 2D57C8D430AE7D802442B8597BCD6F1D Agent: [07fb00a6] F:\infinity\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT Sending DA1... Ok [1|1|1|0] Jump to DA... Ok Sync... Ok DA sync... Ok DA Set Params... Ok Mode: BROM [1|1|1|0] EXT_RAM NOT initialized EMMC CID: 90014A68423861503E03290B10F12769 crc Ok Vendor: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 Serial: 688591089 0x290B10F1 MM/YY: 2/2020 EMI: FireFly preloader_k61v1_64_bsp.bin with 5 memory types slots: no 1. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 2. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 3. eMMC DDR3 ID: 90014A484247346132 Hynix HBG4a2 RAM: 3.00 Gb 4. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb 5. eMMC DDR3 ID: 150100475836424142 Samsung GX6BAB RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed Boot DA2... Ok [1|1|1|28] DA Sync... Ok Get hardware info... RAM: SRAM: 0x0003A600 [ 233.50 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 90014A68423861503E03290B10F12769 crc Ok Vendor: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 Serial: 688591089 0x290B10F1 MM/YY: 2/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6761 HWs: 0x8A00 HWv: 0xCA01 HWc: 0x0717 SWv: 0x0000 Evo: 0x0000 Code: Merlot|A20|A22 Type: MODERN [RAPHAEL] RNID: FE7F75677A25BC9FA732A22D04278AE0 MEID: 2D57C8D430AE7D802442B8597BCD6F1D USB: HIGH-SPEED SoC drivers: MediaTek USB Port v3.0.1504.0; Boot done MODERN [RAPHAEL] 26 sec Load partition table... Ok Partition table: PGPT [0x64] with 52 records Load [MemTool]... Ok Storage [eMMC] Life State: OK Storage OTP Status: Unlocked Storage [eMMC] RPMB State: RPMB Key programmed [UNUSABLE] If process will stop later - try with [SW info] Off Get slot info... Active slot(v3): b Probe boot... Ok 766 us AndroidInfo: boot_b;gzip;bootimage/loaded ramsidk size 0x8696C9/1366700; SW: KYOCERA/KYV47_jp_kdi/KYV47:11/3.220HA.0250.a/3.220HA.0250.a:user/release-keys Product Brand: KYOCERA Product Device: KYV47 Product Model: KYV47 Product Name: KYV47_jp_kdi Patch Level: 3.220HA.0250.a Display ID: 3.220HA SW Version: 3.220HA.0250.a Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2022-03-01 Build Time: 3/28/2024 7:48:52 PM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: KYV47 SW: KYV47_jp_kdi-user 11 3.220HA.0250.a 3.220HA.0250.a release-keys Product Board: KYV47 Board Platform: mt6761 Product Manfct: KYOCERA Device ID: kyocera-kyv47-kyv47-jp-kdi Strategy: [none|generic] Firmware ID: MT6761_KYOCERA_KYV47_OSv11_3.220HA_3.220HA.0250.a_KYV47 Verify firmware [MT6761_KYOCERA_KYV47_OSv11_3.220HA_3.220HA.0250.a_KYV47]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Probe LK... load [lk_b] load Ok 62 us lk_b [f87f7853] k61v1_64_bsp-094c71a-20221114170305-20240329045041 Verify [lk] data... Ok Probe userdata... userData: fileSystem [ext4] with FBE [file based encryption] Backup 69 items to F:\infinity\CM2MT2\backup\MT6761__2D57C8D430AE7D802442B8597BCD6F1D\ Read [25] nvram Ok 2 sec Read [7] nvdata Ok 2 sec Read [23] proinfo Ok 156 us Read [6] nvcfg Ok 1 sec Read [14] protect1 Ok 375 us Read [1] pgpt Ok 16 us Read [17] persist Ok 1 sec Read [0] preloader Ok 203 us Read [31] lk_a Ok 375 us Read [42] lk_b Ok 62 us Done 10 files 12 sec Compress: F:\infinity\CM2MT2\backup\MT6761__2D57C8D430AE7D802442B8597BCD6F1D\ Ok Verify F:\infinity\CM2MT2\backup\MT6761__2D57C8D430AE7D802442B8597BCD6F1D.7z Enough [kyocera-kyv47-kyv47-jp-kdi] Load nvram... NVRAM: 157 items; State: Ok WiFi MAC: 00:ED:B8:42:BB:1F BT MAC: 00:ED:B8:34:FF:7F IMEI1: 358607105864029 IMEI2: FFFFFFFFFFFFFFF PSN1: 5844215819 get modem info... load [md1img_a] load Ok 4 sec Modem: KYOCERA_KDDI_R0MP1_K61V1_64_BSP_MDBIN_PCB01_MT6761_S00.MOLY_LR12A_R3_TC31_R_PR_SP_V1_P11 Secondary RPMB... Off Probe preloader... Read preloader[0]... Ok EMI: MT6761 preloader_k61v1_64_bsp.bin with 5 memory types slots: no 1. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 2. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 3. eMMC DDR3 ID: 90014A484247346132 Hynix HBG4a2 RAM: 3.00 Gb 4. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb 5. eMMC DDR3 ID: 150100475836424142 Samsung GX6BAB RAM: 3.00 Gb Preloader saved: F:\infinity\CM2MT2\backup\preloader\preloader_k61v1_64_bsp.628b2047.bin Verify F:\infinity\CM2MT2\backup\preloader\preloader_k61v1_64_bsp.628b2047.bin [75261a47]... Exist Probe FRP... Most probably On Probe bootloader... Seems as Locked Finished Identify [ v2.77d1 (beta) ] 1 min 15 sec Keep connection Code: WARNING: Reset may delete ALL USER DATA! Smart Analyzer On; Wipe On; Userdata On; Wait... Load partition table... Ok Partition table: PGPT [0x64] with 52 records Android ver: 11 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Backup exist: F:\infinity\CM2MT2\backup\MT6761__2D57C8D430AE7D802442B8597BCD6F1D.7z Reset: Smart... Noting for [none|generic] Reset: Wipe... #1... Ok #2... Finished Reset: Userdata... [1] userdata... Create partition image... Make filesystem [0x02 ext4|8+]... Ok Ok Ok [4] metadata... Ok Ok [5] md_udc... Ok Ok Finished Reset Settings/Format FS [ v2.77d1 (beta) ] 12 sec Keep connection Wait... Code: Load partition table... Ok Partition table: PGPT [0x64] with 52 records SW: KYOCERA/KYV47_jp_kdi/KYV47:11/3.220HA.0250.a/3.220HA.0250.a:user/release-keys Product Brand: KYOCERA Product Device: KYV47 Product Model: KYV47 Product Name: KYV47_jp_kdi Patch Level: 3.220HA.0250.a Display ID: 3.220HA SW Version: 3.220HA.0250.a Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2022-03-01 Build Time: 3/28/2024 7:48:52 PM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: KYV47 SW: KYV47_jp_kdi-user 11 3.220HA.0250.a 3.220HA.0250.a release-keys Product Board: KYV47 Board Platform: mt6761 Product Manfct: KYOCERA Device ID: kyocera-kyv47-kyv47-jp-kdi Strategy: [none|generic] Firmware ID: MT6761_KYOCERA_KYV47_OSv11_3.220HA_3.220HA.0250.a_KYV47 Backup exist: F:\infinity\CM2MT2\backup\MT6761__2D57C8D430AE7D802442B8597BCD6F1D.7z Reset: FRP... #1 of 2... Ok Ok Completed(1) If FRP still active, make Wipe or Userdata reset Finished FRP Safe. Keep Userdata [ v2.77d1 (beta) ] 7 sec Keep connection Operation: Reboot [ v2.77d1 (beta) ] |
The Following User Says Thank You to Kirumira For This Useful Post: |
![]() | #76527 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | vivo V2026 Frp Code: Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [-] Wipe [-] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make [Userdata] On and repeat operation Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM (Android) (COM131) MODE [0]: PRELOADER PORT; PORT: 131 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 4CA5ECDAD2FCA0E6B32F39EAF1FD473AC82D250EDC361934B7A16B1338EA00F3 AGENT: [7c77dd2d] C:\InfinityBox\CM2MT2\boot\Vivo\2022-12\MTK_AllInOne_DA_2.a054144e.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 90014A6843396150330100786DF0C79F crc Ok Vendor: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 Serial: 7892464 0x00786DF0 MM/YY: 12/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 73B2BE77A65F7B55083265480766E859 USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 7 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 47 Probe boot... Ok 1 sec SW: vivo/2026/2026:11/RP1A.200720.012/compiler1021181211:user/release-keys Product Brand: vivo Product Device: 2026 Product Model: V2026 Product Name: 2026 Patch Level: RP1A.200720.012 Display ID: RP1A.200720.012 release-keys Product Info: k65v1_64_bsp SW: full_k65v1_64_bsp-user 11 RP1A.200720.012 eng.compil.20241021.181531 release-keys SW Version: eng.compil.20241021.181531 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-05-01 Build Time: 21-Oct-24 10:12:11 AM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Board: k65v1_64_bsp Board Platform: mt6765 Product Manfct: vivo Device ID: vivo-v2026-k65v1-64-bsp Strategy: [vivo] Firmware ID: MT6765_vivo_V2026_OSv11_RP1A.200720.012_k65v1_64_bsp Android ver: 11 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 90014A6843396150330100786DF0C79F crc Ok Vendor: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 Serial: 7892464 0x00786DF0 MM/YY: 12/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Stage: Android OS Off Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Ok Reset port... Trying to reboot... Finished 20 sec Reconnect Power/Cable now |
![]() | #76528 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | Infinix-X688B Frp Code: Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [-] Wipe [-] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make [Userdata] On and repeat operation Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port (COM132) MODE [0]: BOOTROM; PORT: 132 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 0B5E73D0F7530D4ED459E515F05C3AB2 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 2DC745618EC39F1B87AC2C2D561678AA47B9367EA793395B09E0642180B865C5 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 0B5E73D0F7530D4ED459E515F05C3AB2 AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 90014A684339615033010049C8C318DB crc Ok Vendor: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 Serial: 4835523 0x0049C8C3 MM/YY: 1/2021 EMI: FireFly preloader_x688b_h659.bin with 20 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 6.00 Gb 10. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 150100445036384D42 Samsung DP68MB RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 17. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 18. eMMC LP_DDR4X ID: 150100445036444242 Samsung DP6DBB RAM: 4.00 Gb 19. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 20. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 90014A684339615033010049C8C318DB crc Ok Vendor: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 Serial: 4835523 0x0049C8C3 MM/YY: 1/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: B461D1D31D3574C798C45C33F1FD4C38 MEID: 0B5E73D0F7530D4ED459E515F05C3AB2 USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 11 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 41 Probe boot... Ok 765 us SW: Infinix/X688B-GL/Infinix-X688B:11/RP1A.200720.011/230324V619:user/release-keys Product Brand: Infinix Product Device: Infinix-X688B Product Model: Infinix X688B Product Name: X688B-GL Patch Level: RP1A.200720.011 Display ID: X688B-H659ABCDEFGHIJKLMNO-R-GL-230324V619 SW Version: 230324V619 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-03-05 Build Time: 24-Mar-23 10:02:24 AM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: x688b_h659 SW: vnd_x688b_h659-user 11 RP1A.200720.011 282777 release-keys Product Board: Infinix-X688B Board Platform: mt6765 Product Manfct: INFINIX MOBILITY LIMITED Device ID: infinix-mobility-limited-infinix-x688b-x688b-gl Strategy: [infinix] Firmware ID: MT6765_INFINIX_MOBILITY_LIMITED_Infinix_X688B_OSv11_X688B-H659ABCDEFGHIJKLMNO-R-GL-230324V619_RP1A.200720.011_x688b_h659 Android ver: 11 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] EMMC CID: 90014A684339615033010049C8C318DB crc Ok Vendor: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 Serial: 4835523 0x0049C8C3 MM/YY: 1/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Stage: Android OS Off Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 23 sec Reconnect Power/Cable now |
![]() | #76529 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | TECNO-KE5k Format & Frp Code: Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [-] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM (Android) (COM159) MODE [0]: PRELOADER PORT; PORT: 159 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: EC0E5BF1898E69AE34441FA9F83D1B75A4A4AA54F1FA2881171BC4008F8129EA AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MediaTek USB Port (COM158) MODE [0]: BOOTROM; PORT: 158 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 284635DC5249B086AF92B7162810B0AF BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: EC0E5BF1898E69AE34441FA9F83D1B75A4A4AA54F1FA2881171BC4008F8129EA SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 284635DC5249B086AF92B7162810B0AF AGENT: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100445036444142029B92906718CD crc Ok Vendor: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 Serial: 2610073703 0x9B929067 MM/YY: 1/2021 EMI: FireFly preloader_ke5k_h6122.bin with 20 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 150100444836444D42 Samsung DH6DMB RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100334836434142 Samsung 3H6CAB RAM: 6.00 Gb 5. eMMC LP_DDR4X ID: 150100335636434D42 Samsung 3V6CMB RAM: 6.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 6.00 Gb 10. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 150100445036384D42 Samsung DP68MB RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 17. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 18. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 19. eMMC LP_DDR4X ID: 13014E53304A333741 Micron S0J37A RAM: 3.00 Gb 20. eMMC LP_DDR4X ID: 150100445036444242 Samsung DP6DBB RAM: 4.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100445036444142029B92906718CD crc Ok Vendor: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 Serial: 2610073703 0x9B929067 MM/YY: 1/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 290491390C34064CF6B5C6A91284D875 MEID: 284635DC5249B086AF92B7162810B0AF USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 45 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 41 Probe boot... Ok 718 us SW: TECNO/KE5k-OP/TECNO-KE5k:10/QP1A.190711.020/CD-OP-221010V241:user/release-keys Product Brand: TECNO Product Device: TECNO-KE5k Product Model: TECNO KE5k Product Name: KE5k-OP Patch Level: QP1A.190711.020 Display ID: KE5k-H6122CD-Q-OP-221010V241 SW Version: CD-OP-221010V241 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-10-05 Build Time: 10-Oct-22 9:06:58 AM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: ke5k_h6122 SW: full_ke5k_h6122-user 10 QP1A.190711.020 117739 release-keys Product Board: TECNO-KE5k Board Platform: mt6765 Product Manfct: TECNO MOBILE LIMITED Device ID: tecno-mobile-limited-tecno-ke5k-ke5k-op Strategy: [tecno] Firmware ID: MT6765_TECNO_MOBILE_LIMITED_TECNO_KE5k_OSv10_KE5k-H6122CD-Q-OP-221010V241_QP1A.190711.020_ke5k_h6122 Android ver: 10 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] EMMC CID: 150100445036444142029B92906718CD crc Ok Vendor: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 Serial: 2610073703 0x9B929067 MM/YY: 1/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Stage: Android OS [1] ... Create partition image... Ok Ok [2] ... Create partition image... Ok Ok [4] USERDATA... Ok [5] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 1 min 6 sec Reconnect Power/Cable now |
![]() | #76530 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | TECNO-BB4k Format & Frp Code: Operation: Reset Settings/Format FS [ v2.54 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM6) MODE [0]: PRELOADER PORT; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 6BFEE55BC58A0C07B563CC4EDD2070639315A8ACA565486D23A03B2A9856A426 IRG: 0x00000080 AGENT: AUTO: 0_base: base_v2316 [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for suitable bootchain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MediaTek USB Port_V1633 (COM9) MODE [0]: BOOTROM; PORT: 9 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: 7340F00114D3E7198FF4D3D093D1E174 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 6BFEE55BC58A0C07B563CC4EDD2070639315A8ACA565486D23A03B2A9856A426 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 7340F00114D3E7198FF4D3D093D1E174 AGENT: AUTO: 0_base: base_v2316 [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for suitable bootchain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100514436334D4201EFDAD47A670B crc Ok Vendor: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x01 Serial: 4024095866 0xEFDAD47A MM/YY: 6/2020 EMI: FireFly preloader_bb4k_h6114.bin with 13 memory type(s) 1. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 2. eMMC DDR3 ID: FE014A333232344433 Micron 3224D3 RAM: 3.00 Gb 3. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 4. eMMC DDR3 ID: 150100514536334D42 Samsung QE63MB RAM: 2.00 Gb 5. eMMC DDR3 ID: 150100464536324D42 Samsung FE62MB RAM: 1.00 Gb 6. eMMC DDR3 ID: 90014A484147346132 Hynix HAG4a2 RAM: 2.00 Gb 7. eMMC DDR3 ID: 150100514436334D42 Samsung QD63MB RAM: 2.00 Gb 8. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 2.00 Gb 9. eMMC DDR3 ID: 700100464D42434541 Kingston FMBCEA RAM: 2.00 Gb 10. eMMC DDR3 ID: 150100524836344142 Samsung RH64AB RAM: 4.00 Gb 11. eMMC DDR3 ID: 700100464D41454538 Kingston FMAEE8 RAM: 1.00 Gb 12. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb 13. eMMC DDR3 ID: 150100515836334142 Samsung QX63AB RAM: 2.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A600 [ 233.50 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 150100514436334D4201EFDAD47A670B crc Ok Vendor: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x01 Serial: 4024095866 0xEFDAD47A MM/YY: 6/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 1D7AA268A939EE3CB5C63416252CB744 MEID: 7340F00114D3E7198FF4D3D093D1E174 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 38 Select info source... [recovery] Ok Patch Level: PPR1.180610.011 Display ID: BB4k-H6114UVW-PGo-211026V137 SW Version: UVW-211026V137 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2021-11-05 Build Time: 26/10/2021 6:48:41 am Product Model: TECNO BB4k Product Brand: TECNO Product Name: H6114 Product Device: TECNO-BB4k CPU: armeabi-v7a,armeabi Product Manfct: TECNO MOBILE LIMITED Product Info: bb4k_h6114 SW: full_bb4k_h6114-user 9 PPR1.180610.011 180071 release-keys Product Board: TECNO-BB4k Board Platform: mt6761 Device ID: tecno-mobile-limited-tecno-bb4k-h6114 Strategy: [tecno] Firmware ID: MT6761_TECNO_MOBILE_LIMITED_TECNO_BB4k_OSv9_BB4k-H6114UVW-PGo-211026V137_PPR1.180610.011_bb4k_h6114 SmartInfo: Android Ver: 9 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] EMMC CID: 150100514436334D4201EFDAD47A670B crc Ok Vendor: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x01 Serial: 4024095866 0xEFDAD47A MM/YY: 6/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] Verify config values... Ok Stage: Android OS [1] ... Create partition image... Ok Ok [2] ... Create partition image... Ok Ok [4] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Done: 1 min 6 sec Reconnect Power/Cable now |
