![]() | #76591 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,778 | S/N: 0073CA70CC v0161 Chinese Miracle II - MT2 Service Tool v2.63 Init log engine... Ok Build directories tree... Ok Firmware files: C:\Users\Master Mobile\Desktop\New folder\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 75 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Check for updates [CM2MT2]... Socket Error # 11001 Host not found. Update configuration... Socket Error # 11001 Host not found. Get list of devices... Finished Build device list... Load IDBase v915508 Ok Load 159 profiles... Ok libusb: v1.2.6.0 Init environment... Ok Ready DA selected: Oppo | 2021 | MTK_AllInOne_DA_OP.bin Operation: Identify [ v2.63 ] Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM12) MODE [0]: PRELOADER PORT; PORT: 12 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: FA11A2518CB576C834300E3F6823805F12CBE27C12DB641A5C 6B9D7B224B4FFE AGENT: [f2f720fb] C:\InfinityBox\CM2MT2\boot\Oppo\2021\MTK_AllInOne_ DA_OP.bin Looking for bootchain in DA... Found: MT6768; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 13014E47324D32313220302B96FBBAD5 crc Ok Vendor: Micron OEM: 334 ID: 47324D323132 [G2M212] PRV: 0x20 Serial: 808163067 0x302B96FB MM/YY: 11/2023 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1F000000 [ 116.48 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 8F34F01449C6B7C9562735F23300BEC4 USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 15 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 61 STORAGE Life Status: eMMC : OK STORAGE OTP Status: UNLOCKED STORAGE RPMB Status: eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Saved: C:\InfinityBox\CM2MT2\phdata\key.json Get slot info... a Probe boot... Ok 1 sec Product Brand: oplus Product Device: ossi Product Model: ossi Product Name: ossi SW: oplus/ossi/ossi:12/SP1A.210812.016/1729537753134:user/release-keys Patch Level: SP1A.210812.016 Display ID: SP1A.210812.016 release-keys SW Version: 1729537753134 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2024-11-05 Build Time: 10/21/2024 7:09:13 PM Product Info: k69v1_64_k419 SW: vnd_k69v1_64_k419-user 12 SP1A.210812.016 1729537753134 release-keys Device ID: oplus-ossi Strategy: [realme] Firmware ID: MT6768_ossi_OSv12_SP1A.210812.016_k69v1_64_k419_op lus Verify firmware [MT6768_ossi_OSv12_SP1A.210812.016_k69v1_64_k419_op lus]... Socket Error # 11001 Host not found. Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Backup to C:\InfinityBox\CM2MT2\backup\MT6768__A50E0ADEFF15D 6D198B01EAA641DF1F0\ Items to check: 22 Read [39] NVRAM NVRAM: Items: 0xAA Size: 0x10535A State: Ok WiFi MAC: F8C4FA0FC53D BT MAC: F8C4FA0FC53C Read [19] NVDATA Read [37] PROINFO Read [18] NVCFG Read [21] PROTECT1 Read [1] PGPT Read [20] PERSIST Read [0] PRELOADER Read [41] OCDT Read [7] OPLUS_CUSTOM Read [29] LK_A lk [18f13ab5] Read [34] CDT_ENGINEERING_A Read [48] LK_B Read [53] CDT_ENGINEERING_B Done 14 files 9 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6768__A50E0ADEFF15D 6D198B01EAA641DF1F0\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6768__A50E0ADEFF15D 6D198B01EAA641DF1F0.7z Finished Analyze modem... Nothing Analyze nvram... PSN1: 00223650430922B2 EMMC CID: 13014E47324D32313220302B96FBBAD5 crc Ok Vendor: Micron OEM: 334 ID: 47324D323132 [G2M212] PRV: 0x20 Serial: 808163067 0x302B96FB MM/YY: 11/2023 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1F000000 [ 116.48 Gb ] Analyze preloader... EMI: MT6752 preloader_k69v1_64_k419.bin with 6 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb 3. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 6.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 6.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 8.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 69v1_64_k419.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 69v1_64_k419.bin [9ae72b43]... Finished Probe FRP... Most probably Off Reset port... Finished 37 sec Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [+] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM12) MODE [0]: PRELOADER PORT; PORT: 12 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: FA11A2518CB576C834300E3F6823805F12CBE27C12DB641A5C 6B9D7B224B4FFE AGENT: [f2f720fb] C:\InfinityBox\CM2MT2\boot\Oppo\2021\MTK_AllInOne_ DA_OP.bin Looking for bootchain in DA... Found: MT6768; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM12) MODE [0]: PRELOADER PORT; PORT: 12 Waiting for BOOT ACK... BROM: Init... Fail to init protocol Disconnect battery and cable Be sure SoC drivers installed well Change cable and USB port, do not use USB-hub Select another base|model|DA Finished 53 sec Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.63 ] [+] Smart Analyzer [+] Wipe [+] Userdata [+] FRP [-] Accounts WARNING: Reset may delete ALL USER DATA! Wait... Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM12) MODE [0]: PRELOADER PORT; PORT: 12 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: FA11A2518CB576C834300E3F6823805F12CBE27C12DB641A5C 6B9D7B224B4FFE AGENT: [f2f720fb] C:\InfinityBox\CM2MT2\boot\Oppo\2021\MTK_AllInOne_ DA_OP.bin Looking for bootchain in DA... Found: MT6768; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 13014E47324D32313220302B96FBBAD5 crc Ok Vendor: Micron OEM: 334 ID: 47324D323132 [G2M212] PRV: 0x20 Serial: 808163067 0x302B96FB MM/YY: 11/2023 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1F000000 [ 116.48 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 8F34F01449C6B7C9562735F23300BEC4 USB: HIGH-SPEED HIGH-SPEED USB is Off Boot done MODERN [RAPHAEL] 32 sec Analyze PMT... Ok PMT: PGPT [0x64] Records: 61 Get slot info... a Probe boot... Ok 1 sec Product Brand: oplus Product Device: ossi Product Model: ossi Product Name: ossi SW: oplus/ossi/ossi:12/SP1A.210812.016/1729537753134:user/release-keys Patch Level: SP1A.210812.016 Display ID: SP1A.210812.016 release-keys SW Version: 1729537753134 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2024-11-05 Build Time: 10/21/2024 7:09:13 PM Product Info: k69v1_64_k419 SW: vnd_k69v1_64_k419-user 12 SP1A.210812.016 1729537753134 release-keys Device ID: oplus-ossi Strategy: [realme] Firmware ID: MT6768_ossi_OSv12_SP1A.210812.016_k69v1_64_k419_op lus Android ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] EMMC CID: 13014E47324D32313220302B96FBBAD5 crc Ok Vendor: Micron OEM: 334 ID: 47324D323132 [G2M212] PRV: 0x20 Serial: 808163067 0x302B96FB MM/YY: 11/2023 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1F000000 [ 116.48 Gb ] Backup exist: C:\InfinityBox\CM2MT2\backup\MT6768__A50E0ADEFF15D 6D198B01EAA641DF1F0 Stage: Android OS [1] WIPE... Skip for Strategy [realme] [2] WIPE... Skip for Strategy [realme] [3] WIPE... Create partition image... Ok Ok [6] USERDATA... Ok [7] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 47 sec Reconnect Power/Cable now |
![]() | #76592 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | S/N: 0073CA70CC v0161 CM2 - SP3 Service Tool v2.28 Init log engine... Ok Build directories tree... Backup files: C:\InfinityBox\CM2SP3\backup\ Backup files: 0 dirs: 0 Check for updates [CM2SP3]... Installed v2.28 Infinity #CM2SP3 v2.32 - [Get boot files] issue fixed - Flash read and files load/convert speed increased - Bootloader lock/unlock state detection revised - T620 and T760 - Extract [bootlog] for [FDL] mode to get additional info about boot process and device hardware state - [Device ID] engine rebuilded to detect more issues with damaged data - OS version detection method for [FDL] mode updated - MDM process fixed for number of devices - [AppTool] for number of devices updated - minor fixes Required firmware v0163 Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Sales: https://infinity-box.com/buy/ Account: https://infinity-box.com/service/ Get list of devices... Ok Loaded 93 new of 1720 devices Build device list... Ok 1741 Ready Select SoC/Device or [Get boot files] Selected: Infinix X6525 Boot [FDL] ufs Selected: Infinix X6525 Boot [FF] FireFly ufs Selected device may be not supported by [FF] yet Operation: Connect Infinix X6525 Boot [FF] FireFly [v2.28] Wait... - Power device Off - Connect cable [remember Vol+ | Vol-] [remember Test-Point] Waiting for device... Device found PTFN: SPRD U2S Diag (COM19) vid 0x1782 pid 0x4D00 boot: SPRD3 boot iLoader... Ok start iLoader... Ok Handshake... Ok boot xLoader... Ok start FireFly... Ok Loader exec Ok Dev UID: f597aef225f3ab1a5874e75f7db60ad12a3659742a528c494e 1255bb90c15fed get storage info... EMMC CID: F401224152563131581350241C622B7B crc Ok Vendor: Biwin OEM: 290 ID: 415256313158 [ARV11X] PRV: 0x13 Serial: 1344543842 0x50241C62 MM/YY: 2/2024 CSD: D02701320F5903FFFFFFFFEF8A404001 temp_write_protect: False perm_write_protect: False wp_group: 0x10 en 0x01 EXTCSD rev1.8 EMMC 5.1 ERASE_GROUP_DEF: 0x0400 BOOT_BUS_WIDTH: 0x00 PARTITION_CONFIG: 0x08 RST_N_FUNCTION: 0x01 PART_S_COMPLETED: False BOOT size: 0x400000 RPMB size: 0x400000 4.00 Mb WP_GRP_SIZE: 0x800000 8.00 Mb Size: Market 64 Gb Actual 0xE90000000 58.25 Gb EOL: Status: Normal: Less than 80% reserved blocks used EOL_A: SLC status: 0% - 10% used EOL_B: MLC status: 0% - 10% used read extcsd... Ok extcsd stored: C:\InfinityBox\CM2SP3\backup\ext_csd\none_f597aef2 25f3ab1a_extcsd_00F4-Biwin_ARV11X_5.1_2024-12-20.bin get partitions... Partitions: 75 Connected get sw info... 21 sec Product Brand: Infinix Product Device: Infinix-X6525 Product Model: Infinix X6525 Product Name: X6525 SW: Infinix/X6525-OP/Infinix-X6525:13/TP1A.220624.014/240523V1572:user/release-keys Market Name: Infinix SMART 8 Patch Level: TP1A.220624.014 Display ID: X6525-F069ABCDEFGHIGaGbGcGdGeGfGgGhGiGmGnGoGq-TGo-OP-240523V1572 Product Name: X6525-OP Ver. CodeName: REL Ver. Release: 13 Sec. Patch: 2024-05-05 Build Time: 5/22/2024 8:19:06 PM Product Info: X6525 SW: X6525-user 13 TP1A.220624.014 482 release-keys SW Version: 240523V1572 Product Manfct: INFINIX Board Platform: ums9230 Product Board: Infinix-X6525 Android ver: 13 UserDataFS: 0x03 [f2fs] CacheFS: 0x03 [f2fs] Device ID: infinix-x6525-x6525-op-infinix-smart-8 Strategy: [infinix] Firmware ID: UMS9230_INFINIX_Infinix_X6525_OSv13_X6525-F069ABCDEFGHIGaGbGcGdGeGfGgGhGiGmGnGoGq-TGo-OP-240523V1572_TP1A.220624.014_X6525 Backup 11 items to: C:\InfinityBox\CM2SP3\backup\ums9230_f597aef225f3a b1a\ Read to C:\InfinityBox\CM2SP3\backup\ums9230_f597aef225f3a b1a\ Reading... Read [1/75] prodnv 64.00 Mb Ok Read [2/75] miscdata 1024.00 Kb Ok Read [8/75] uboot_a 3.00 Mb Ok Read [9/75] uboot_b 3.00 Mb Ok Read [13/75] l_fixnv1_a 2.00 Mb Ok Read [14/75] l_fixnv2_a 2.00 Mb Ok Read [15/75] l_fixnv1_b 2.00 Mb Ok Read [16/75] l_fixnv2_b 2.00 Mb Ok Read [69/75] calinv 2.00 Mb Ok Read [71/75] tkv_a 1024.00 Kb Ok Read [72/75] tkv_b 1024.00 Kb Ok Saved 11 of 11 images, 83.00 Mb of 83.00 Mb Done 11 files Compress: C:\InfinityBox\CM2SP3\backup\ums9230_f597aef225f3a b1a\ Cleanup... Ok Verify C:\InfinityBox\CM2SP3\backup\ums9230_f597aef225f3a b1a.7z Verified [351d03e7] get slots... slot: a MemTool load 75 items Finished 2 min 5 sec Operation: Reset | Format Infinix X6525 Boot [FF] FireFly [v2.28] WARNING: Reset may delete ALL USER DATA! Continue? Yes [+] Wipe [+] Userdata [+] FRP [+] Smart Wait... Backup exist: C:\InfinityBox\CM2SP3\backup\ums9230_f597aef225f3a b1a\ Process Wipe... Reading... Ok Writing... Ok Process FRP... Looking for items... 1 items found [1] Writing... Ok Process Userdata... [1] Format... Ok 8 sec [2] Format... Ok 4 sec [3] Format... Ok 4 sec Completed Process nvram... [17] Format... Ok [18] Format... Ok Completed Finished 22 sec Reboot... Disconnect cable if it freez CMD 0x05 return 0x8E PHONE_WAIT_INPUT_TIMEOUT Bye |
![]() | #76593 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | S/N: 0073CA70CC v0161 CM2 - SP3 Service Tool v2.28 Init log engine... Ok Build directories tree... Backup files: C:\InfinityBox\CM2SP3\backup\ Backup files: 0 dirs: 0 Build device list... Ok 1648 Ready Select SoC/Device or [Get boot files] Select SoC/Device or [Get boot files] Select SoC or device Get loader info... update required Get Infinix/Hot-12 Install... Ok Finished 33 sec fdl1-sign.00b3fc95.ldr fdl2-sign.00b3fc95.d02c259f.2022-04.ldr Selected: Infinix Hot-12 Boot [FDL] Operation: Connect Infinix Hot-12 Boot [FDL] [v2.28] Wait... - Power device Off - Connect cable [remember Vol+ | Vol-] [remember Test-Point] Waiting for device... Device found PTFN: SPRD U2S Diag (COM19) vid 0x1782 pid 0x4D00 boot: SPRD3 C:\InfinityBox\CM2SP3\boot\Infinix\Hot-12\fdl1-sign.00b3fc95.ldr C:\InfinityBox\CM2SP3\boot\Infinix\Hot-12\fdl2-sign.00b3fc95.d02c259f.2022-04.ldr Boot[1] Custom... Ok Exec[1]... Ok Boot ack: Spreadtrum Boot Block version 1.1 Loader ACK... Ok Set port speed... 2000000 Enable charge... Ok Boot[2]... Ok Exec[2]... Ok Version: 0x10 Random: 0x00 Enable RAW... Ok Loader exec Ok Dev UID: unknown get partitions... Partitions: 68 Load UBID... Ok Dev UID: 713391bfab172af5ee1e9339c9e1da8f80bc256b90ea48024f 88cf868af7d90d Connected get sw info... 3 sec SW: Infinix/F161/Infinix-X6817B:11/RP1A.201005.001/GL-V026-20220516:user/release-keys Product Brand: Infinix Product Device: Infinix-X6817B Product Model: Infinix X6817B Product Name: X6817B Patch Level: RP1A.201005.001 Display ID: X6817B-F161-11.0-GL-V026-20220516 SW Version: GL-V026-20220516 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2022-04-05 Build Time: 5/16/2022 7:38:07 AM Product Name: F161 Market Name: Infinix HOT 12 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: X6817B SW: X6817B-user 11 RP1A.201005.001 289 release-keys Product Board: X6817B Board Platform: ums9230 Product Manfct: INFINIX Android ver: 11 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Device ID: infinix-x6817b-f161-infinix-hot-12 Strategy: [infinix] Firmware ID: UMS9230_INFINIX_Infinix_X6817B_OSv11_X6817B-F161-11.0-GL-V026-20220516_RP1A.201005.001_X6817B Backup 8 items to: C:\InfinityBox\CM2SP3\backup\ums9230_713391bfab172 af5\ Read to C:\InfinityBox\CM2SP3\backup\ums9230_713391bfab172 af5\ Reading... Read [1/68] prodnv 10.00 Mb Ok Read [2/68] miscdata 1024.00 Kb Ok Read [8/68] uboot_a 3.00 Mb Ok Read [9/68] uboot_b 3.00 Mb Ok Read [13/68] l_fixnv1_a 2.00 Mb Ok Read [14/68] l_fixnv2_a 2.00 Mb Ok Read [15/68] l_fixnv1_b 2.00 Mb Ok Read [16/68] l_fixnv2_b 2.00 Mb Ok Saved 8 of 8 images, 25.00 Mb of 25.00 Mb Done 8 files Compress: C:\InfinityBox\CM2SP3\backup\ums9230_713391bfab172 af5\ Cleanup... Ok Verify C:\InfinityBox\CM2SP3\backup\ums9230_713391bfab172 af5.7z Verified [c70aa680] get slots... slot: b MemTool load 68 items Finished 47 sec Operation: Reset | Format Infinix Hot-12 Boot [FDL] [v2.28] WARNING: Reset may delete ALL USER DATA! Continue? Yes [+] Wipe [+] Userdata [+] FRP [+] Smart Wait... Backup exist: C:\InfinityBox\CM2SP3\backup\ums9230_713391bfab172 af5\ Process Wipe... Reading... Ok Writing... Ok Process FRP... Looking for items... 1 items found [1] Writing... Ok Process Userdata... [1] Format... Ok 0 us [2] Format... Ok 0 us [3] Format... Ok 15 us Completed Process nvram... [17] Format... Ok [18] Format... Ok Completed Finished 3 sec Reboot... Disconnect cable if it freez Bye |
![]() | #76594 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | S/N: 0073CA70CC v0161 CM2 - SP3 Service Tool v2.28 Init log engine... Ok Build directories tree... Backup files: C:\InfinityBox\CM2SP3\backup\ Backup files: 0 dirs: 0 Build device list... Ok 1741 Ready Selected: SoC sc9863 Boot [FF] FireFly mmc [FF] protocol may be SLOW. For flash Read/Write use [FDL] Select SoC/Device or [Get boot files] Select SoC/Device or [Get boot files] Select SoC/Device or [Get boot files] Select SoC or device Get loader info... update required Get Sparx/Neo-6 Install... Ok Get loader info... update required Get SoC/sc9863 Loaders for [SoC sc9863] exist. Delete existing loaders before update? No Install... Ok Finished 2 min 34 sec Selected: Sparx Neo-6 Boot [FF] FireFly mmc [FF] protocol may be SLOW. For flash Read/Write use [FDL] Operation: Connect Sparx Neo-6 Boot [FF] FireFly [v2.28] Wait... - Power device Off - Connect cable [remember Vol+ | Vol-] [remember Test-Point] Waiting for device... Device found PTFN: SPRD U2S Diag (COM19) vid 0x1782 pid 0x4D00 boot: SPRD3 boot iLoader... Ok start iLoader... Ok Handshake... Ok boot xLoader... Ok start FireFly... Ok Loader exec Ok Dev UID: c12416d94bd4b9175a897ea43adf1862b4be86d92446d548ca 25b66d06b9bacf get storage info... EMMC CID: 90014A68423861503E034C54EE591687 crc Ok Vendor: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 Serial: 1280634457 0x4C54EE59 MM/YY: 1/2019 CSD: D02700328F5903FFFFFFFFEF8E400000 temp_write_protect: False perm_write_protect: False wp_group: 0x10 en 0x01 EXTCSD rev1.8 EMMC 5.1 FW: 30303036 ERASE_GROUP_DEF: 0x0400 BOOT_BUS_WIDTH: 0x00 PARTITION_CONFIG: 0x08 RST_N_FUNCTION: 0x01 PART_S_COMPLETED: False BOOT size: 0x400000 RPMB size: 0x1000000 16.00 Mb WP_GRP_SIZE: 0x800000 8.00 Mb Size: Market 32 Gb Actual 0x747C00000 29.12 Gb EOL: Status: Normal: Less than 80% reserved blocks used EOL_A: SLC status: Not defined EOL_B: MLC status: 40% - 50% used read extcsd... Ok extcsd stored: C:\InfinityBox\CM2SP3\backup\ext_csd\none_c12416d9 4bd4b917_extcsd_0090-Hynix_hB8aP_5.1_2025-01-09.bin get partitions... Partitions: 72 Connected get sw info... 13 sec Product Brand: Sparx Product Device: NEO_6 Product Model: NEO_6 Product Name: NEO_6 SW: Sparx/NEO_6/NEO_6:12/S00812/1692858032:user/release-keys Patch Level: S00812 Display ID: Sparx_Neo_6_V05_24082023 SW Version: 1692858032 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-07-05 Build Time: 8/24/2023 7:14:14 AM Product Info: NEO_6 SW: NEO_6-user 12 S00812 1692858032 release-keys Product Manfct: NEO_6 Board Platform: sp9863a Product Board: s9863a1h10 Android ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Device ID: sparx-neo-6-s9863a1h10 Strategy: [none|generic] Firmware ID: SP9863A_NEO_6_NEO_6_OSv12_Sparx_Neo_6_V05_24082023 _S00812_NEO_6 Backup 8 items to: C:\InfinityBox\CM2SP3\backup\sp9863a_c12416d94bd4b 917\ Read to C:\InfinityBox\CM2SP3\backup\sp9863a_c12416d94bd4b 917\ Reading... Read [1/72] prodnv 10.00 Mb Ok Read [2/72] miscdata 1024.00 Kb Ok Read [8/72] uboot_a 1024.00 Kb Ok Read [9/72] uboot_b 1024.00 Kb Ok Read [13/72] l_fixnv1_a 2.00 Mb Ok Read [14/72] l_fixnv2_a 2.00 Mb Ok Read [15/72] l_fixnv1_b 2.00 Mb Ok Read [16/72] l_fixnv2_b 2.00 Mb Ok Saved 8 of 8 images, 21.00 Mb of 21.00 Mb Done 8 files Compress: C:\InfinityBox\CM2SP3\backup\sp9863a_c12416d94bd4b 917\ Cleanup... Ok Verify C:\InfinityBox\CM2SP3\backup\sp9863a_c12416d94bd4b 917.7z Verified [58e7d5d6] get slots... slot: a MemTool load 72 items Finished 48 sec Operation: Reset | Format Sparx Neo-6 Boot [FF] FireFly [v2.28] WARNING: Reset may delete ALL USER DATA! Continue? Yes [+] Wipe [+] Userdata [+] FRP [+] Smart Wait... Backup exist: C:\InfinityBox\CM2SP3\backup\sp9863a_c12416d94bd4b 917\ Process Wipe... Reading... Ok Writing... Ok Process FRP... Looking for items... 1 items found [1] Writing... Ok Process Userdata... [1] Format... Ok 7 sec [2] Format... Ok 6 sec [3] Format... Ok 1 sec Completed Process nvram... [17] Format... Ok [18] Format... Ok Completed Finished 20 sec Reboot... Disconnect cable if it freez CMD 0x05 return 0x8E PHONE_WAIT_INPUT_TIMEOUT Bye |
![]() | #76595 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | CALME CL100 RESET FRP DONE BY CM2 Card found : 73CA70CC , v0161 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.07 ] BootMode : FLASH 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] IMEI[1] : IMEI[2] : Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_096 7D13A4473_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
![]() | #76596 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 567 ![]() | Tablet TYD TYD-108H Firmware read ok CM2 - MT2 Service Tool v2.77 Probe UAC... Ok Probe libusb... v1.2.6.0 Wait... S/N: 0005C0DF82 v0164 Initalize log engine... Ok Build directories tree... Ok Firmware files: C:\Users\ct3im\Desktop\Aocwei X700\G863D-MR\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 12 dirs: 0 Load emi database... Internal: 28 custom: 0 Load IDBase v915508 Ok Build device list... Ok Load 159 profiles... Ok Initalize external tools... Ok Initialize libusb... Ok Ready Operation: Identify [ v2.77 ] Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V2023 (Android) (COM4) MODE: PRELOADER PORT; PORT: 4 Waiting for BOOT ACK... Boot Init... Ok CHIP: MT6580 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x6580 SWv: 0x0000 Evo: 0x0000 Code: Type: LEGACY [MTK] Sec Level: 0x00000000; Mode: PLAIN Ver: 0xFF BL: 0x01 [PRELOADER PORT] Agent: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6580; DA: MTK_DOWNLOAD_AGENT Sending DA1... Ok [1|0|0|0] Jump to DA... Ok Sync... Ok NAND: DEVICE NOT FOUND EMMC: OK CID: 4D0001154732474129070043BF11FED3 DA v4.2.156 DA: DRAM ready Boot DA2... Ok Get hardware info... EMMC CID: 1501004D4147324743000729D3FE11BF crc Ok Vendor: Samsung OEM: 256 ID: 4D4147324743 [MAG2GC] PRV: 0x00 Serial: 120181758 0x0729D3FE MM/YY: 1/2014 BOOT1: 0x004000004.00 Mb BOOT2: 0x004000004.00 Mb RPMB: 0x00080000512.00 Kb USER: 0x3AB40000014.68 Gb RAM: SRAM: 0x00020000 128.00 Kb RAM: DRAM: 0x40000000 1024.00 Mb CHIP: MT6580 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x6580 SWv: 0x0000 Evo: 0x0000 Code: Type: LEGACY [MTK] RNID: 6211EB4A9E06E8A377656C8EE71E9F8B DA Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: HIGH-SPEED SoC drivers: MediaTek PreLoader USB VCOM_V2023 (Android) v3.0.1512.0; Boot done 15 sec Load partition table... Ok Partition table LGPT [0x06] with 25 records Load [MemTool]... Ok rpmb engine: Off If process will stop later - try with [SW info] Off Device has no slots Probe boot... boot: recovery;gzip;ramdisk size 0x51FA00;boot;gzip;ramdisk size 0x37BE00; Ok 1 sec Patch Level: NRD90M Display ID: MID-2020 SW Version: 1592378687 Ver. CodeName: REL Ver. Release: 7.0 Sec. Patch: 2017-07-05 Build Time: 17/06/2020 07:24:46 Product Model: KT107 Product Brand: ABAO Product Name: KT107 Product Device: KT107 Product Board: KT107 CPU: armeabi-v7a,armeabi Product Manfct: KTE Board Platform: mt6580 Product Info: Masstel_Tab10 SW: full_aeon6580_we_n-user 7.0 NRD90M 1592378687 release-keys Device ID: abao-kte-kt107 Strategy: [none|generic] Firmware ID: MT6580_KTE_KT107_OSv7.0_MID-2020_NRD90M_Masstel_Tab10_ABAO Verify firmware [MT6580_KTE_KT107_OSv7.0_MID-2020_NRD90M_Masstel_Tab10_ABAO]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Probe LK... load [lk] load Ok 203 us lk [7b2ff607] AEON6580_WE_N-AEON6580_WE_N Verify [lk] data... Ok 1 sec Probe userdata... userData: fileSystem [ext4] with FDE [encryptable] Backup 72 items to C:\InfinityBox\CM2MT2\backup\MT6580__6211EB4A9E06E 8A377656C8EE71E9F8B\ Read [6] seccfg Ok 110 us Skip zeroes file: C:\InfinityBox\CM2MT2\backup\MT6580__6211EB4A9E06E 8A377656C8EE71E9F8B\seccfg.bin Read [3] nvram Ok 1 sec Read [15] nvdata Ok 10 sec Read [2] proinfo Ok 984 us Read [8] lk Ok 172 us Read [4] protect1 Ok 3 sec lda-pt: pgpt Read [0] preloader Ok 1 sec Done 6 files 17 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6580__6211EB4A9E06E 8A377656C8EE71E9F8B\ Ok Verify C:\InfinityBox\CM2MT2\backup\MT6580__6211EB4A9E06E 8A377656C8EE71E9F8B.7z Finished Load nvram... NVRAM: 116 items; State: Ok WiFi MAC: 00:00:00:00:00:00 BT MAC: 00:00:46:65:80:01 IMEI1: 355431861461347 IMEI2: 355431861461348 PSN: N/A get modem info... Secondary RPMB... Off Probe preloader... Read preloader[0]... Ok EMI: MT6752 preloader_aeon6580_we_n.bin with 1 memory types [20200617-152618] slots: no 1. _UNK DDR2 RAM: 1.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_a eon6580_we_n.ee5ef8cc.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_a eon6580_we_n.ee5ef8cc.bin [4c09da6f]... Stored Probe FRP... Most probably On Probe bootloader... Seems as Locked Reset port... Finished Identify [ v2.77 ] 1 min 5 sec Operation: Read Flash [ v2.77 ] Destination: C:\Users\ct3im\Desktop\TYD TYD-108H\KT961A12_80_168_V2.0\ Disk free space: 40.51 Gb Pack/Sparse is On, it may takes up to 10 min for large files! Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V2023 (Android) (COM4) MODE: PRELOADER PORT; PORT: 4 Waiting for BOOT ACK... Boot Init... Fail Change USB cable and USB port, do not use USB-hub Latest SoC drivers or PC REBOOT may helps Finished Read Flash [ v2.77 ] 21 sec Operation: Read Flash [ v2.77 ] Destination: C:\Users\ct3im\Desktop\TYD TYD-108H\KT961A12_80_168_V2.0\ Disk free space: 40.53 Gb Pack/Sparse is On, it may takes up to 10 min for large files! Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V2023 (Android) (COM4) MODE: PRELOADER PORT; PORT: 4 Waiting for BOOT ACK... Boot Init... Ok CHIP: MT6580 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x6580 SWv: 0x0000 Evo: 0x0000 Code: Type: LEGACY [MTK] Sec Level: 0x00000000; Mode: PLAIN Ver: 0xFF BL: 0x01 [PRELOADER PORT] Agent: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6580; DA: MTK_DOWNLOAD_AGENT Sending DA1... Ok [1|0|0|0] Jump to DA... Ok Sync... Ok NAND: DEVICE NOT FOUND EMMC: OK CID: 4D0001154732474129070043BF11FED3 DA v4.2.156 DA: DRAM ready Boot DA2... Ok Get hardware info... EMMC CID: 1501004D4147324743000729D3FE11BF crc Ok Vendor: Samsung OEM: 256 ID: 4D4147324743 [MAG2GC] PRV: 0x00 Serial: 120181758 0x0729D3FE MM/YY: 1/2014 BOOT1: 0x004000004.00 Mb BOOT2: 0x004000004.00 Mb RPMB: 0x00080000512.00 Kb USER: 0x3AB40000014.68 Gb RAM: SRAM: 0x00020000 128.00 Kb RAM: DRAM: 0x40000000 1024.00 Mb CHIP: MT6580 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x6580 SWv: 0x0000 Evo: 0x0000 Code: Type: LEGACY [MTK] RNID: 6211EB4A9E06E8A377656C8EE71E9F8B DA Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: HIGH-SPEED SoC drivers: MediaTek PreLoader USB VCOM_V2023 (Android) v3.0.1512.0; Boot done 13 sec Load partition table... Ok Partition table LGPT [0x06] with 25 records Device has no slots Probe boot... boot: recovery;gzip;ramdisk size 0x51FA00;boot;gzip;ramdisk size 0x37BE00; Ok 1 sec Patch Level: NRD90M Display ID: MID-2020 SW Version: 1592378687 Ver. CodeName: REL Ver. Release: 7.0 Sec. Patch: 2017-07-05 Build Time: 17/06/2020 07:24:46 Product Model: KT107 Product Brand: ABAO Product Name: KT107 Product Device: KT107 Product Board: KT107 CPU: armeabi-v7a,armeabi Product Manfct: KTE Board Platform: mt6580 Product Info: Masstel_Tab10 SW: full_aeon6580_we_n-user 7.0 NRD90M 1592378687 release-keys Device ID: abao-kte-kt107 Strategy: [none|generic] Firmware ID: MT6580_KTE_KT107_OSv7.0_MID-2020_NRD90M_Masstel_Tab10_ABAO Device has no slots Total size to read: 2.56 Gb Read [1/25]: preloader.bin 4.00 Mb Ok Ok 122.00 Kb Read [3/25]: proinfo.img 3.00 Mb Ok Ok 96 b Read [4/25]: nvram.bin 5.00 Mb Ok Ok 4.88 Mb Read [8/25]: items.img 512.00 Kb Ok Ok 592 b Read [9/25]: lk.bin 512.00 Kb Ok Ok 349.30 Kb Read [10/25]: boot.img 16.00 Mb Ok Ok 7.96 Mb Estimated time to end 9 sec Read [11/25]: recovery.img 16.00 Mb Ok Ok 9.27 Mb Read [13/25]: logo.bin 8.00 Mb Ok Ok 1.48 Mb Read [19/25]: secro.img 6.00 Mb Ok Ok 132.00 Kb Read [21/25]: system.img 2.50 Gb Ok Sparse... blocks: 655360 compression ratio: 60% 4 min 52 sec Ok 1,02 Gb Build [22/25]: cache.img 256,00 Mb Create partition image... Make filesystem [0x01 ext4|4+]... Ok Ok Ok 0 b Build [23/25]: userdata.img 11,75 Gb Create partition image... Make filesystem [0x01 ext4|4+]... Ok Ok Ok 0 b Compact... Build scat... Ok Firmware size: 1.04 Gb Android Info saved: _Android_info.txt Scatter: MT6580_Android_scatter.txt Saved: C:\Users\ct3im\Desktop\TYD TYD-108H\KT961A12_80_168_V2.0\MT6580_KTE_KT107_OSv7.0_ MID-2020_NRD90M_Masstel_Tab10_ABAO\ Verify firmware [MT6580_KTE_KT107_OSv7.0_MID-2020_NRD90M_Masstel_Tab10_ABAO]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Upload file to server? No Reset port... Finished Read Flash [ v2.77 ] 18 min 28 sec |
The Following User Says Thank You to ct3im For This Useful Post: |
![]() | #76597 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: nigeria
Member: 757064 Status: Offline Sonork: 11111111 Thanks Meter: 381 ![]() | oppo cph2385 frp successful remove. CM2 - MT2 Service Tool v2.76 Probe UAC... Ok Probe libusb... v1.2.7.3 Wait... S/N: skyulock v0163 Initalize log engine... Ok Build directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 43 dirs: 0 Load emi database... Internal: 28 custom: 0 Load IDBase v915508 Ok Build device list... Ok Load 159 profiles... Ok Initalize external tools... Ok Initialize libusb... Ok Ready DA files missing Select another Device from list or Click to [Get boot files] DA selected: Oppo | 2021 | MTK_AllInOne_DA_OP.bin DA selected: 0_base | base_v2316 | MTK_AllInOne_DA.1d5fdec4.bin 5 DA available, try it one-by-one DA selected: 0_generic | 2022-09 [luci] MT6781 | DA_BR.2022-09-07.bin MT6781_Generic [LUCI] [flash_id.txt] supported memory types: MT064GASAO2U21 H9HQ15AFAMBDAR H9HQ16AECMMDAR H9HQ16AFAMMDAR H9HQ21AFAMADAR KM8B8001JM-BC0 KM8F8001JM-B813 MT128GASAO4U21 MT256GAXAU4U22 DA selected: 0_rare | MT6570_a | MTK_AllInOne_DA.c0d01ecb.bin 3 DA available, try it one-by-one DA files missing Select another Device from list or Click to [Get boot files] DA selected: Oppo | 2021 | MTK_AllInOne_DA_OP.bin DA files missing Select another Device from list or Click to [Get boot files] Get loader info... update required Get Oppo/CPH2387 Install... Ok Get loader info... Ok DA selected: Oppo | CPH2387 | MTK_AllInOne_DA.1d5fdec4.bin 5 DA available, try it one-by-one DA files missing Select another Device from list or Click to [Get boot files] DA selected: 0_base | base_v2316 | MTK_AllInOne_DA.1d5fdec4.bin 5 DA available, try it one-by-one DA selected: Oppo | 2021 | MTK_AllInOne_DA_OP.bin DA selected: Oppo | 2022-10 | MTK_AllInOne_DA.bin Get loader info... update required Get Oppo/2022-10 Loaders for [Oppo 2022-10] exist. Delete existing loaders before update? Yes Install... Ok DA selected: Oppo | 2022-10 | MTK_AllInOne_DA.5419c171.bin Operation: Identify [ v2.76 ] Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: Off DA Key: custom; Local SLA: Off; Auto-EMI: Off Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM6) MODE: PRELOADER PORT; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino Type: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005; Mode: SBC+SDA Ver: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 12AE9C8AC916EC1D155E52D23FB84F2D9585931227E695C888 14261A09E9C860 Agent: [ab6a11d9] C:\InfinityBox\CM2MT2\boot\Oppo\2022-10\MTK_AllInOne_DA.5419c171.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending DA1... Ok [1|1|0|0] Jump to DA... Ok Sync... Ok DA sync... Ok DA Set Params... Ok Mode: PRELOADER [1|1|0|0] EXT_RAM initialized Boot DA2... Ok [1|1|1|28] DA Sync... Ok Load HW info... RAM: SRAM: 0x00038000 [ 224.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 15010044555442343202F0BA53C41AA3 crc Ok Vendor: Samsung OEM: 256 ID: 445554423432 [DUTB42] PRV: 0x02 Serial: 4038742980 0xF0BA53C4 MM/YY: 1/2023 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1EC00000 [ 116.48 Gb ] CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino Type: MODERN [RAPHAEL] RNID: 8928320487693DFB18C874DE405CE81E USB: HIGH-SPEED SoC drivers: MediaTek PreLoader USB VCOM_V1632 (Android) v3.0.1504.0; Boot done MODERN [RAPHAEL] 1 min 27 sec Load partition table... Ok Partition table: PGPT [0x64] with 55 records Storage [eMMC] Life State: OK Storage OTP Status: Unlocked Storage [eMMC] RPMB State: RPMB KEY PROGRAMMED [UNUSABLE] Load [MemTool]... Ok Get slot info... Active slot(v3): b Probe boot... Ok 8 sec AndroidInfo: vendor_boot_b;ramdisk size=0;boot_b;gzip;bootimage/loaded ramsidk size 0xFD4D47/00;vendor_boot_a;ramdisk size=0;boot_a;gzip;bootimage/loaded ramsidk size 0xFD5EFE/26C4F00; Product Brand: oplus Product Device: ossi Product Model: ossi Product Name: ossi SW: oplus/ossi/ossi:12/SP1A.210812.016/1703749755750:user/release-keys Patch Level: SP1A.210812.016 Display ID: SP1A.210812.016 release-keys SW Version: 1703749755750 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2024-01-05 Build Time: 12/28/2023 7:49:15 AM Product Info: k65v1_64_bsp SW: vnd_k65v1_64_bsp-user 12 SP1A.210812.016 1703749755750 release-keys Device ID: oplus-ossi Strategy: [realme] Firmware ID: MT6765_ossi_OSv12_SP1A.210812.016_k65v1_64_bsp_opl us Verify firmware [MT6765_ossi_OSv12_SP1A.210812.016_k65v1_64_bsp_opl us]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Probe userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Backup 23 items to C:\InfinityBox\CM2MT2\backup\MT6765__1B719156200A2 26E0FE13EE116C900EC\ Read [20] nvram Ok 2 sec Read [11] nvdata Ok 2 sec Read [19] proinfo Ok 156 us Read [10] nvcfg Ok 1 sec Read [14] protect1 Ok 406 us Read [1] pgpt Ok 16 us Read [17] persist Ok 1 sec Read [0] preloader Ok 187 us Read [21] ocdt Ok 625 us Read [7] oplus_custom Ok 63 us Read [30] lk_a Ok 469 us lk [6b43f1fe] Read [38] cdt_engineering_a Ok 563 us Read [44] lk_b Ok 219 us lk [60a3cc5a] Read [49] cdt_engineering_b Ok 688 us Done 14 files 23 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6765__1B719156200A2 26E0FE13EE116C900EC\ Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__1B719156200A2 26E0FE13EE116C900EC.7z Enough [oplus-ossi] get modem info... absent Load nvram items... NVRAM size: 0x105324; 169 items; State: Ok WiFi MAC: 74:86:69:7D:81:4F BT MAC: 74:86:69:7D:81:4E nvram imei data has unknown structure or damaged PSN1: 0021338032150357 Secondary RPMB... On Probe preloader... EMI: MT6765 preloader_k65v1_64_bsp.bin with 6 memory types slots: no 1. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 3. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 6.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 8.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 65v1_64_bsp.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 65v1_64_bsp.bin [041490e7]... Exist Probe FRP... Most probably Off Probe bootloader... Seems as Locked Finished Identify [ v2.76 ] 3 min 18 sec Keep connection Operation: Reset Settings/Format FS [ v2.76 ] WARNING: Reset may delete ALL USER DATA! Wipe Off; Userdata Off; FRP On; Accounts Off; Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: Off DA Key: custom; Local SLA: Off; Auto-EMI: Off Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM6) MODE: PRELOADER PORT; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino Type: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005; Mode: SBC+SDA Ver: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 12AE9C8AC916EC1D155E52D23FB84F2D9585931227E695C888 14261A09E9C860 Agent: [ab6a11d9] C:\InfinityBox\CM2MT2\boot\Oppo\2022-10\MTK_AllInOne_DA.5419c171.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending DA1... Ok [1|1|0|0] Jump to DA... Ok Sync... Ok DA sync... Ok DA Set Params... Ok Mode: PRELOADER [1|1|0|0] EXT_RAM initialized Boot DA2... Ok [1|1|1|28] DA Sync... Ok Load HW info... RAM: SRAM: 0x00038000 [ 224.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 15010044555442343202F0BA53C41AA3 crc Ok Vendor: Samsung OEM: 256 ID: 445554423432 [DUTB42] PRV: 0x02 Serial: 4038742980 0xF0BA53C4 MM/YY: 1/2023 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1EC00000 [ 116.48 Gb ] CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino Type: MODERN [RAPHAEL] RNID: 8928320487693DFB18C874DE405CE81E USB: HIGH-SPEED SoC drivers: MediaTek PreLoader USB VCOM_V1632 (Android) v3.0.1504.0; Boot done MODERN [RAPHAEL] 34 sec Load partition table... Ok Partition table: PGPT [0x64] with 55 records Get slot info... Active slot(v3): b Probe boot... Ok 4 sec AndroidInfo: vendor_boot_b;ramdisk size=0;boot_b;gzip;bootimage/loaded ramsidk size 0xFD4D47/00;vendor_boot_a;ramdisk size=0;boot_a;gzip;bootimage/loaded ramsidk size 0xFD5EFE/26C4F00; Product Brand: oplus Product Device: ossi Product Model: ossi Product Name: ossi SW: oplus/ossi/ossi:12/SP1A.210812.016/1703749755750:user/release-keys Patch Level: SP1A.210812.016 Display ID: SP1A.210812.016 release-keys SW Version: 1703749755750 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2024-01-05 Build Time: 12/28/2023 7:49:15 AM Product Info: k65v1_64_bsp SW: vnd_k65v1_64_bsp-user 12 SP1A.210812.016 1703749755750 release-keys Device ID: oplus-ossi Strategy: [realme] Firmware ID: MT6765_ossi_OSv12_SP1A.210812.016_k65v1_64_bsp_opl us Android ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__1B719156200A2 26E0FE13EE116C900EC Reset: FRP... process [frp]... Ok verify [frp] 128.00 Kb... rewrite... Ok Completed If FRP still active make [Userdata] reset Finished Reset Settings/Format FS [ v2.76 ] 1 min 6 sec Keep connection |
The Following User Says Thank You to skyulock For This Useful Post: |
![]() | #76598 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: Sindh Pakistan
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,436 | ![]() Operation: FRP Complete. Erase Userdata [ v2.77 ] Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM84) MODE: PRELOADER PORT; PORT: 84 Waiting for BOOT ACK... Boot Init... Ok CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino|P35|G35|G36|G37|G50 Type: MODERN [RAPHAEL] Sec Level: 0x00000005; Mode: SBC+SDA Ver: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: A53FBCAC04372E0BFCBA837E18CD572BD45EB75293BF46F9C6 C905F36E5DBAC5 Agent: [ecb438fd] C:\InfinityBox\CM2MT2\boot\Vivo\2023-08\MTK_AllInOne_DA_v3.fdaaf7f6.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT Sending DA1... Ok [1|1|0|0] Jump to DA... Ok Sync... Ok DA sync... Ok DA Set Params... Ok Mode: PRELOADER [1|1|0|0] EXT_RAM initialized Boot DA2... Ok [1|1|1|28] DA Sync... Ok Get hardware info... RAM: SRAM: 0x0003A000 232.00 Kb RAM: DRAM: 0x80000000 2.00 Gb EMMC CID: 90014A68423861503E0300641429A73F crc Ok Vendor: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 Serial: 6558761 0x00641429 MM/YY: 10/2020 BOOT1: 0x004000004.00 Mb BOOT2: 0x004000004.00 Mb RPMB: 0x0100000016.00 Mb USER: 0x747C0000029.12 Gb CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino|P35|G35|G36|G37|G50 Type: MODERN [RAPHAEL] RNID: C303FA48E8E8D43AE4F38F5956D4D87C MEID: 0E9D765B3DBB9BCC25EAD95FB430020B SOCID: A53FBCAC04372E0BFCBA837E18CD572BD45EB75293BF46F9C6 C905F36E5DBAC5 USB: HIGH-SPEED SoC drivers: MediaTek PreLoader USB VCOM_V1632 (Android) v3.0.1504.0; Boot done 11 sec Load partition table... Ok 16 us Partition table: PGPT [0x64] with 47 records Load [MemTool]... Ok Device has no slots Probe boot... boot: recovery;gzip;ramdisk size 0x4287C00;boot;gzip;ramdisk size 0x1B6D00; Finished 1 sec Probe core... Scan filesystem... Ok Mount[ext4] wo/cache cust 0x0015A88000/04000000 Mount[ext4] wo/cache system@super 0x0053900000/FD2CD000 Mount[ext4] wo/cache vendor@super 0x0150C00000/1EC31000 Ok 750 us SW: vivo/2015/2015:10/QP1A.190711.020/compiler11131052:user/release-keys Product Brand: vivo Product Device: k65v1_64_bsp Product Model: vivo 2015 Product Name: full_k65v1_64_bsp Patch Level: QP1A.190711.020 Display ID: QP1A.190711.020 release-keys SW Version: compiler11131052 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2023-03-01 Build Time: 13-Nov-24 3:08:10 AM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: k65v1_64_bsp SW: full_k65v1_64_bsp-user 10 QP1A.190711.020 compiler11131052 release-keys Device ID: vivo-2015-k65v1-64-bsp-full-k65v1-64-bsp Strategy: [vivo] Firmware ID: MT6765_vivo_2015_OSv10_QP1A.190711.020_k65v1_64_bs p Reset: FRP... #1 of 2... Ok Ok Reset: Userdata... [1] userdata... Create partition image... Make filesystem [0x02 ext4|8+]... Ok Ok Ok [2] cache... Create partition image... Make filesystem [0x02 ext4|8+]... Ok Ok Ok [4] metadata... Ok Ok [5] md_udc... Ok Ok Verification... #1 of 2... Ok Completed (1) Finished FRP Complete. Erase Userdata [ v2.77 ] 18 sec Keep connection Operation: Reboot [ v2.77 ] Reset port... Trying to reboot... Finished Reboot [ v2.77 ] 31 us |
![]() | #76599 (permalink) |
Member: 85718 Status: Offline Thanks Meter: 567 ![]() | Hammer_Energy_2_2022 firmware read ok CM2 - MT2 Service Tool v2.77 Probe UAC... Ok Probe libusb... v1.2.6.0 Wait... S/N: 0005C0DF82 v0164 Initalize log engine... Ok Build directories tree... Ok Firmware files: C:\Users\ct3im\Desktop\Blackview BV4900 Pro\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 14 dirs: 0 Load emi database... Internal: 28 custom: 0 Check for updates [CM2MT2]... You have latest version [2.77] installed Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Sales: https://infinity-box.com/buy/ Account: https://infinity-box.com/service/ Update configuration... Configuration [12412] updated Get list of devices... Ok Reloaded 2175 devices Load IDBase v915508 Ok Build device list... Ok Load 159 profiles... Ok Initalize external tools... Ok Initialize libusb... Ok Ready Operation: Identify [ v2.77 ] Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V2023 (Android) (COM4) MODE: PRELOADER PORT; PORT: 4 Waiting for BOOT ACK... Boot Init... Ok CHIP: MT6761 HWs: 0x8A00 HWv: 0xCA01 HWc: 0x0717 SWv: 0x0200 Evo: 0x0000 Code: Merlot|A20|A22 Type: MODERN [RAPHAEL] Sec Level: 0x00000000; Mode: PLAIN Ver: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 2050CF67F01F7D8ED244ABBD0EB74CB05777123461690C34F4 82134786DFF032 IRG: 0x00000080 Agent: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT Sending DA1... Ok [1|1|1|0] Jump to DA... Ok Sync... Ok DA sync... Ok DA Set Params... Ok Mode: PRELOADER [1|1|1|0] EXT_RAM initialized Boot DA2... Ok [1|1|1|28] DA Sync... Ok Get hardware info... RAM: SRAM: 0x0003A600 233.50 Kb RAM: DRAM: 0xC0000000 3.00 Gb EMMC CID: 90014A68423861503E0217B4595B3827 crc Ok Vendor: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x02 Serial: 397695323 0x17B4595B MM/YY: 3/2021 BOOT1: 0x004000004.00 Mb BOOT2: 0x004000004.00 Mb RPMB: 0x0100000016.00 Mb USER: 0x747C0000029.12 Gb CHIP: MT6761 HWs: 0x8A00 HWv: 0xCA01 HWc: 0x0717 SWv: 0x0000 Evo: 0x0000 Code: Merlot|A20|A22 Type: MODERN [RAPHAEL] RNID: F66C53724DA2C3086E4A1D8E8B3BAF1B MEID: E503B6C4F5FAC14AA38BE413C8F711D2 SOCID: 2050CF67F01F7D8ED244ABBD0EB74CB05777123461690C34F4 82134786DFF032 USB: HIGH-SPEED SoC drivers: MediaTek PreLoader USB VCOM_V2023 (Android) v3.0.1512.0; Boot done 14 sec Load partition table... Ok 16 us Partition table: PGPT [0x64] with 40 records Load [MemTool]... Ok RPMB Off: RPMB Key not programmed [USABLE] rpmb engine: Off Storage [MMC] Life State: OK Storage OTP Status: Unlocked Storage [MMC] RPMB State: RPMB Key not programmed [USABLE] If process will stop later - try with [SW info] Off Device has no slots Probe boot... boot: vendor_boot;ramsidk size=0;recovery;gzip;ramdisk size 0x113BEE9;boot;gzip;ramdisk size 0x170F00; Finished 609 us Probe core... Scan filesystem... Ok Mount[ext4] wo/cache system@super 0x0027900000/51239000 Mount[ext4] wo/cache vendor@super 0x0078B39000/15079000 Mount[ext4] wo/cache product@super 0x008DBB2000/605EF000 Ok 1 sec SW: Hammer/Energy_2_2022_EEA/Energy_2_2022:11/RP1A.200720.011/1636636519:user/release-keys Product Brand: Hammer Product Device: Energy_2_2022 Product Model: Hammer_Energy_2_2022 Product Name: Energy_2_2022_EEA Patch Level: RP1A.200720.011 Display ID: Hammer_Energy_2_2022_v11.0.11_20220418 SW Version: 1636636519 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2021-10-05 Build Time: 18/04/2022 03:37:25 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: pd8d23_xwp_v31_he2_v4 SW: full_pd8d23_xwp_v31_he2_v4-user 11 RP1A.200720.011 1636636519 release-keys Device ID: mptech-hammer-energy-2-2022-energy-2-2022-eea-pd8d23-xwp-v31-he2-v4 Strategy: [none|generic] Firmware ID: MT6761_Hammer_Energy_2_2022_OSv11_Hammer_Energy_2_ 2022_v11.0.11_20220418_RP1A.200720.011_pd8d23_xwp_ v31_he2_v4 Verify firmware [MT6761_Hammer_Energy_2_2022_OSv11_Hammer_Energy_2_ 2022_v11.0.11_20220418_RP1A.200720.011_pd8d23_xwp_ v31_he2_v4]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Probe LK... load [lk] load Ok 63 us lk [b4cea40e] pd8d23_xwp_v31_he2_v4-6c4171daa-20220415171431-20220418114809 Verify [lk] data... Ok 2 sec Probe userdata... Load userdata header... Ok userData: encrypted Backup 72 items to C:\InfinityBox\CM2MT2\backup\MT6761__E503B6C4F5FAC 14AA38BE413C8F711D2\ Read [15] seccfg Ok 235 us Read [27] nvram Ok 1 sec Read [10] nvdata Ok 1 sec Read [18] proinfo Ok 110 us Read [28] lk Ok 47 us Read [9] nvcfg Ok 937 us Read [13] protect1 Ok 313 us Read [1] pgpt Ok 15 us Read [16] persist Ok 1 sec Read [0] preloader Ok 140 us Done 10 files 9 sec Compress: C:\InfinityBox\CM2MT2\backup\MT6761__E503B6C4F5FAC 14AA38BE413C8F711D2\ Ok Verify C:\InfinityBox\CM2MT2\backup\MT6761__E503B6C4F5FAC 14AA38BE413C8F711D2.7z Verified Load nvram... NVRAM: 160 items; State: Ok WiFi MAC: AA:00:6E:74:2F:76 BT MAC: 98:80:BB:C1:25:B2 IMEI1: 353813113012644 IMEI2: 353813113012651 PSN1: 202113004503 get modem info... load [md1img] load Ok 2 sec TK_MD_BASIC_MDBIN_PCB01_MT6761_S00.MOLY_LR12A_R3_M P_V184_4_P4 Secondary RPMB... On Probe preloader... Read preloader[0]... Ok EMI: MT6761 preloader_pd8d23_xwp_v31_he2_v4.bin with 6 memory types [20220418-114215] slots: no 1. eMMC DDR3 ID: 90014A484247346132 HBG4a2 HBG4a2 RAM: 3.00 Gb 2. eMMC DDR3 ID: 150100474436424D42 GD6BMB GD6BMB RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 150100444436384D42 DD68MB DD68MB RAM: 3.00 Gb 4. eMMC DDR3 ID: 150100475836424142 GX6BAB GX6BAB RAM: 3.00 Gb 5. eMMC LP_DDR4X ID: 150100445836384D42 DX68MB DX68MB RAM: 3.00 Gb 6. eMMC DDR3 ID: 90014A68423861503E hB8aP> hB8aP> RAM: 3.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_p d8d23_xwp_v31_he2_v4.54d7862b.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_p d8d23_xwp_v31_he2_v4.54d7862b.bin [3ced0377]... Exist Probe FRP... Most probably On Probe bootloader... Seems as Locked Reset port... Finished Identify [ v2.77 ] 46 sec Operation: Read Flash [ v2.77 ] Destination: C:\Users\ct3im\Desktop\Hammer Energy 2 eco\ Disk free space: 47.91 Gb Pack/Sparse is On, it may takes up to 10 min for large files! Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V2023 (Android) (COM4) MODE: PRELOADER PORT; PORT: 4 Waiting for BOOT ACK... Boot Init... Ok CHIP: MT6761 HWs: 0x8A00 HWv: 0xCA01 HWc: 0x0717 SWv: 0x0200 Evo: 0x0000 Code: Merlot|A20|A22 Type: MODERN [RAPHAEL] Sec Level: 0x00000000; Mode: PLAIN Ver: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 2050CF67F01F7D8ED244ABBD0EB74CB05777123461690C34F4 82134786DFF032 IRG: 0x00000080 Agent: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT Sending DA1... Ok [1|1|1|0] Jump to DA... Ok Sync... Ok DA sync... Ok DA Set Params... Ok Mode: PRELOADER [1|1|1|0] EXT_RAM initialized Boot DA2... Ok [1|1|1|28] DA Sync... Ok Get hardware info... RAM: SRAM: 0x0003A600 233.50 Kb RAM: DRAM: 0xC0000000 3.00 Gb EMMC CID: 90014A68423861503E0217B4595B3827 crc Ok Vendor: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x02 Serial: 397695323 0x17B4595B MM/YY: 3/2021 BOOT1: 0x004000004.00 Mb BOOT2: 0x004000004.00 Mb RPMB: 0x0100000016.00 Mb USER: 0x747C0000029.12 Gb CHIP: MT6761 HWs: 0x8A00 HWv: 0xCA01 HWc: 0x0717 SWv: 0x0000 Evo: 0x0000 Code: Merlot|A20|A22 Type: MODERN [RAPHAEL] RNID: F66C53724DA2C3086E4A1D8E8B3BAF1B MEID: E503B6C4F5FAC14AA38BE413C8F711D2 SOCID: 2050CF67F01F7D8ED244ABBD0EB74CB05777123461690C34F4 82134786DFF032 USB: HIGH-SPEED SoC drivers: MediaTek PreLoader USB VCOM_V2023 (Android) v3.0.1512.0; Boot done 15 sec Load partition table... Ok 16 us Partition table: PGPT [0x64] with 40 records Device has no slots Probe boot... boot: vendor_boot;ramsidk size=0;recovery;gzip;ramdisk size 0x113BEE9;boot;gzip;ramdisk size 0x170F00; Finished 625 us Probe core... Scan filesystem... Ok Mount[ext4] wo/cache system@super 0x0027900000/51239000 Mount[ext4] wo/cache vendor@super 0x0078B39000/15079000 Mount[ext4] wo/cache product@super 0x008DBB2000/605EF000 Ok 1 sec SW: Hammer/Energy_2_2022_EEA/Energy_2_2022:11/RP1A.200720.011/1636636519:user/release-keys Product Brand: Hammer Product Device: Energy_2_2022 Product Model: Hammer_Energy_2_2022 Product Name: Energy_2_2022_EEA Patch Level: RP1A.200720.011 Display ID: Hammer_Energy_2_2022_v11.0.11_20220418 SW Version: 1636636519 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2021-10-05 Build Time: 18/04/2022 03:37:25 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: pd8d23_xwp_v31_he2_v4 SW: full_pd8d23_xwp_v31_he2_v4-user 11 RP1A.200720.011 1636636519 release-keys Device ID: mptech-hammer-energy-2-2022-energy-2-2022-eea-pd8d23-xwp-v31-he2-v4 Strategy: [none|generic] Firmware ID: MT6761_Hammer_Energy_2_2022_OSv11_Hammer_Energy_2_ 2022_v11.0.11_20220418_RP1A.200720.011_pd8d23_xwp_ v31_he2_v4 Device has no slots Total size to read: 4.43 Gb Read [1/43]: preloader.bin 4.00 Mb Ok Ok 226.53 Kb Read [4/43]: recovery.img 32.00 Mb Ok Ok 32.00 Mb Read [7/43]: vbmeta_system.img 8.00 Mb Ok Ok 2.20 Kb Read [8/43]: vbmeta_vendor.img 8.00 Mb Ok Ok 1.64 Kb Read [17/43]: persist.img 48.00 Mb Ok Sparse... blocks: 12288 compression ratio: 92% 1 sec Ok 4.31 Mb Read [18/43]: sec.img 2.00 Mb Ok Read [19/43]: proinfo.img 3.00 Mb Ok Ok 336 b Estimated time to end 6 sec Read [20/43]: md1rom.img 100.00 Mb Ok Ok 46.96 Mb Read [21/43]: spmfw.img 1.00 Mb Ok Ok 62.92 Kb Read [22/43]: tinysys-scp.bin 1.00 Mb Ok Ok 540.66 Kb Read [23/43]: tinysys-scp.bin 1.00 Mb Read [24/43]: sspm.img 1.00 Mb Ok Ok 432.13 Kb Read [25/43]: sspm.img 1.00 Mb Read [26/43]: gz.img 16.00 Mb Ok Read [27/43]: gz.img 16.00 Mb Ok Read [28/43]: nvram.bin 64.00 Mb Ok Ok 63.88 Mb Read [29/43]: lk.bin 1.00 Mb Ok Ok 857.81 Kb Read [30/43]: lk.bin 1.00 Mb Read [31/43]: boot.img 32.00 Mb Ok Ok 32.00 Mb Read [32/43]: vendor_boot.img 64.00 Mb Ok Read [33/43]: logo.bin 8.00 Mb Ok Ok 2.28 Mb Read [34/43]: dtbo.img 8.00 Mb Ok Ok 43.86 Kb Read [35/43]: tz.img 5.00 Mb Ok Ok 1.98 Mb Read [36/43]: tz.img 11.00 Mb Read [37/43]: super.img 4.00 Gb Ok Sparse... blocks: 1048576 compression ratio: 23% 14 min 14 sec Ok 3,09 Gb Read [38/43]: vbmeta.img 8,00 Mb Ok Ok 2,91 Kb Build [39/43]: cache.img 432,00 Mb Create partition image... Make filesystem [0x02 ext4|8+]... Ok Ok Ok 0 b Build [40/43]: userdata.img 24,02 Gb Create partition image... Make filesystem [0x02 ext4|8+]... Ok Ok Ok 0 b Compact... Build scat... Ok Firmware size: 3.27 Gb Android Info saved: _Android_info.txt Scatter: MT6761_Android_scatter.txt Saved: C:\Users\ct3im\Desktop\Hammer Energy 2 eco\MT6761_Hammer_Energy_2_2022_OSv11_Hammer_Energ y_2_2022_v11.0.11_20220418_RP1A.200720.011_pd8d23_ xwp_v31_he2_v4\ Verify firmware [MT6761_Hammer_Energy_2_2022_OSv11_Hammer_Energy_2_ 2022_v11.0.11_20220418_RP1A.200720.011_pd8d23_xwp_ v31_he2_v4]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Upload file to server? No Reset port... Finished Read Flash [ v2.77 ] 17 min 1 sec |
![]() | #76600 (permalink) |
Member: 85718 Status: Offline Thanks Meter: 567 ![]() | TCL 30 SE (6165H) firmware read ok CM2 - MT2 Service Tool v2.77 Probe UAC... Ok Probe libusb... v1.2.6.0 Wait... S/N: 0005C0DF82 v0164 Initalize log engine... Ok Build directories tree... Ok Firmware files: C:\Users\ct3im\Desktop\Hammer Energy 2 eco\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 16 dirs: 0 Load emi database... Internal: 28 custom: 0 Load IDBase v915508 Ok Build device list... Ok Load 159 profiles... Ok Initalize external tools... Ok Initialize libusb... Ok Ready Operation: Identify [ v2.77 ] Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek USB Port_V2023 (COM6) MODE: BOOTROM; PORT: 6 Waiting for BOOT ACK... Boot Init... Ok CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino|P35|G35|G36|G37|G50 Type: MODERN [RAPHAEL] MEID: 3359386CF94EB1E06C7695D105EABCCA Sec Level: 0x000000E7; Mode: SBC+SLA+SDA+EXT Ver: 0x05 BL: 0xFE [BOOTROM] SOCID: 4909016F8498E8ED2995961FBC9DB7C3683652D2478BB660E3 EB728BF5C8BA50 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok EMI known SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID Agent: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT Sending DA1... Ok [1|1|1|0] Jump to DA... Ok Sync... Ok DA sync... Ok DA Set Params... Ok Mode: BROM [1|1|1|0] EXT_RAM NOT initialized EMMC CID: 880103534C443132385503AA37B0B841 crc Ok Vendor: Foresee OEM: 259 ID: 534C44313238 [SLD128] PRV: 0x55 Serial: 61487024 0x03AA37B0 MM/YY: 11/2021 EMI: FireFly preloader_cruzepro_62.bin with 5 memory types slots: no 1. DRAM LP_DDR4X ID: NOT_DEFINED RAM: 512.00 Mb 2. DRAM LP_DDR4X ID: NOT_DEFINED RAM: 4.00 Gb 3. DRAM LP_DDR4X ID: NOT_DEFINED RAM: 4.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED RAM: 4.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED RAM: 6.00 Gb Push EMI... EXT_RAM CFG Passed Boot DA2... Ok [1|1|1|28] DA Sync... Ok Get hardware info... RAM: SRAM: 0x0003A000 232.00 Kb RAM: DRAM: 0x100000000 4.00 Gb EMMC CID: 880103534C443132385503AA37B0B841 crc Ok Vendor: Foresee OEM: 259 ID: 534C44313238 [SLD128] PRV: 0x55 Serial: 61487024 0x03AA37B0 MM/YY: 11/2021 BOOT1: 0x004000004.00 Mb BOOT2: 0x004000004.00 Mb RPMB: 0x004000004.00 Mb USER: 0x1CCF000000115.23 Gb CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino|P35|G35|G36|G37|G50 Type: MODERN [RAPHAEL] RNID: 6A164190EA380C594FE4EDDF806F3CB5 MEID: 3359386CF94EB1E06C7695D105EABCCA SOCID: 4909016F8498E8ED2995961FBC9DB7C3683652D2478BB660E3 EB728BF5C8BA50 USB: HIGH-SPEED SoC drivers: MediaTek USB Port_V2023 v3.0.1512.0; Boot done 17 sec Load partition table... Ok 31 us Partition table: PGPT [0x64] with 63 records Load [MemTool]... Ok rpmb engine: On RPMB size 0x400000 RPMB counter 0x0000005C Storage [MMC] Life State: OK Storage OTP Status: Locked Storage [MMC] RPMB State: RPMB Key programmed [UNUSABLE] If process will stop later - try with [SW info] Off Get slot info... Active slot(v3): b Probe boot... boot: vendor_boot_b;ramsidk size=0;boot_b;gzip;ramdisk size 0x1ADA100; Ok 1 sec Patch Level: SP1A.210812.016 Display ID: SP1A.210812.016 release-keys SW Version: 1ADR Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2024-02-01 Build Time: 27/02/2024 03:00:11 Product Brand: TCL Product Info: cruzepro_62 SW: vnd_cruzepro_62-user 12 SP1A.210812.016 1ADR release-keys Product Manfct: TCL Product Board: MT6765 Board Platform: mt6765 Device ID: tcl-tcl-mt6765 Strategy: [alcatel|tcl] Firmware ID: MT6765_TCL_OSv12_SP1A.210812.016_cruzepro_62 Verify firmware [MT6765_TCL_OSv12_SP1A.210812.016_cruzepro_62]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Probe LK... load [lk_b] load Ok 125 us lk_b [b9085f5a] cruzepro_62-016d718-20231221200335-20240227111208 Verify [lk] data... Ok 781 us Probe userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__3359386CF94EB 1E06C7695D105EABCCA.7z Load nvram... nvram: unsupported sec structure; NVRAM: 178 items; State: Ok WiFi MAC: AA:00:6E:74:2F:76 BT MAC: 00:22:33:44:55:66 IMEI1: N/A IMEI2: N/A Unsupported (or damaged) nvram sec structure You may try via META [SVC] PSN1: 31232701 get modem info... load [md1img_a] load Ok 3 sec TK_MD_L4_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R3_MP_V 190_8_P36 Secondary RPMB... Off Probe preloader... Read preloader[0]... Ok EMI: MT6765 preloader_cruzepro_62.bin with 5 memory types slots: no 1. DRAM LP_DDR4X ID: NOT_DEFINED RAM: 512.00 Mb 2. DRAM LP_DDR4X ID: NOT_DEFINED RAM: 4.00 Gb 3. DRAM LP_DDR4X ID: NOT_DEFINED RAM: 4.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED RAM: 4.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED RAM: 6.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_c ruzepro_62.b30c2721.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_c ruzepro_62.b30c2721.bin [8d766adf]... Exist Probe FRP... Most probably On Probe bootloader... Seems as Locked Reset port... Finished Identify [ v2.77 ] 32 sec Operation: Read Flash [ v2.77 ] Destination: C:\Users\ct3im\Desktop\TCL 30 SE (6165H) firmware read CM2MT2\ Disk free space: 43.08 Gb Pack/Sparse is On, it may takes up to 10 min for large files! Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek USB Port_V2023 (COM6) MODE: BOOTROM; PORT: 6 Waiting for BOOT ACK... Boot Init... Ok CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino|P35|G35|G36|G37|G50 Type: MODERN [RAPHAEL] MEID: 3359386CF94EB1E06C7695D105EABCCA Sec Level: 0x000000E7; Mode: SBC+SLA+SDA+EXT Ver: 0x05 BL: 0xFE [BOOTROM] SOCID: 4909016F8498E8ED2995961FBC9DB7C3683652D2478BB660E3 EB728BF5C8BA50 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok EMI known SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID Agent: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT Sending DA1... Ok [1|1|1|0] Jump to DA... Ok Sync... Ok DA sync... Ok DA Set Params... Ok Mode: BROM [1|1|1|0] EXT_RAM NOT initialized EMMC CID: 880103534C443132385503AA37B0B841 crc Ok Vendor: Foresee OEM: 259 ID: 534C44313238 [SLD128] PRV: 0x55 Serial: 61487024 0x03AA37B0 MM/YY: 11/2021 EMI: FireFly preloader_cruzepro_62.bin with 5 memory types slots: no 1. DRAM LP_DDR4X ID: NOT_DEFINED RAM: 512.00 Mb 2. DRAM LP_DDR4X ID: NOT_DEFINED RAM: 4.00 Gb 3. DRAM LP_DDR4X ID: NOT_DEFINED RAM: 4.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED RAM: 4.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED RAM: 6.00 Gb Push EMI... EXT_RAM CFG Passed Boot DA2... Ok [1|1|1|28] DA Sync... Ok Get hardware info... RAM: SRAM: 0x0003A000 232.00 Kb RAM: DRAM: 0x100000000 4.00 Gb EMMC CID: 880103534C443132385503AA37B0B841 crc Ok Vendor: Foresee OEM: 259 ID: 534C44313238 [SLD128] PRV: 0x55 Serial: 61487024 0x03AA37B0 MM/YY: 11/2021 BOOT1: 0x004000004.00 Mb BOOT2: 0x004000004.00 Mb RPMB: 0x004000004.00 Mb USER: 0x1CCF000000115.23 Gb CHIP: MT6765 HWs: 0x8A00 HWv: 0xCA00 HWc: 0x0766 SWv: 0x0000 Evo: 0x0000 Code: Cervino|P35|G35|G36|G37|G50 Type: MODERN [RAPHAEL] RNID: 6A164190EA380C594FE4EDDF806F3CB5 MEID: 3359386CF94EB1E06C7695D105EABCCA SOCID: 4909016F8498E8ED2995961FBC9DB7C3683652D2478BB660E3 EB728BF5C8BA50 USB: HIGH-SPEED SoC drivers: MediaTek USB Port_V2023 v3.0.1512.0; Boot done 17 sec Load partition table... Ok 31 us Partition table: PGPT [0x64] with 63 records Get slot info... Active slot(v3): b Probe boot... boot: vendor_boot_b;ramsidk size=0;boot_b;gzip;ramdisk size 0x1ADA100; Ok 1 sec Patch Level: SP1A.210812.016 Display ID: SP1A.210812.016 release-keys SW Version: 1ADR Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2024-02-01 Build Time: 27/02/2024 03:00:11 Product Brand: TCL Product Info: cruzepro_62 SW: vnd_cruzepro_62-user 12 SP1A.210812.016 1ADR release-keys Product Manfct: TCL Product Board: MT6765 Board Platform: mt6765 Device ID: tcl-tcl-mt6765 Strategy: [alcatel|tcl] Firmware ID: MT6765_TCL_OSv12_SP1A.210812.016_cruzepro_62 Device support slots: Scheme v2 w/super Active slot: b Total size to read: 21.91 Gb Read [1/66]: preloader.bin 4.00 Mb Ok Ok 250.47 Kb Read [13/66]: oembin.img 8.00 Mb Ok Ok 20.03 Kb Read [15/66]: simlock.img 15.50 Mb Ok Ok 59.47 Kb Read [16/66]: persist.img 48.00 Mb Ok Sparse... blocks: 12288 compression ratio: 99% 2 sec Ok 872.33 Kb Read [17/66]: sec.img 2.00 Mb Ok Read [18/66]: proinfo.img 3.00 Mb Ok Ok 130.19 Kb Read [19/66]: efuse.img 512.00 Kb Ok Ok 704 b Estimated time to end 6 sec Read [20/66]: swversion.img 1.00 Mb Ok Ok 96 b Read [21/66]: nvram.bin 64.00 Mb Ok Ok 63.88 Mb Read [22/66]: oempersist.img 8.00 Mb Ok Sparse... blocks: 2048 compression ratio: 96% 406 us Ok 328.07 Kb Read [23/66]: tcdpersist.img 50.00 Mb Ok Read [24/66]: minipersist.img 50.00 Mb Ok Read [25/66]: lcmreserved.img 1.00 Mb Ok Read [26/66]: smart.img 10.00 Mb Ok Read [27/66]: logo.bin 10.50 Mb Ok Ok 2.07 Mb Read [28/66]: md1rom_a.img 100.00 Mb Ok Ok 54.19 Mb Read [29/66]: spmfw_a.img 1.00 Mb Ok Ok 62.67 Kb Read [30/66]: lcmparameter_a.img 1.00 Mb Ok Ok 27.34 Kb Read [31/66]: tinysys-scp_a.bin 1.00 Mb Ok Ok 562.23 Kb Read [32/66]: sspm_a.img 1.00 Mb Ok Ok 424.86 Kb Read [33/66]: gz_a.img 16.00 Mb Ok Ok 2.69 Mb Read [34/66]: lk_a.bin 2.00 Mb Ok Ok 1.08 Mb Read [35/66]: boot_a.img 32.00 Mb Ok Ok 32.00 Mb Read [36/66]: vendor_boot_a.img 64.00 Mb Ok Read [37/66]: dtbo_a.img 8.00 Mb Ok Ok 8.00 Mb Read [38/66]: tz_a.img 5.00 Mb Ok Ok 872.41 Kb Read [39/66]: vbmeta_a.img 8.00 Mb Ok Ok 3.25 Kb Read [40/66]: vbmeta_system_a.img 8.00 Mb Ok Ok 2.17 Kb Read [41/66]: vbmeta_vendor_a.img 9.00 Mb Ok Ok 1.63 Kb Read [42/66]: md1rom_b.img 100.00 Mb Ok Ok 54.18 Mb Read [43/66]: spmfw_b.img 1.00 Mb Ok Ok 62.67 Kb Read [44/66]: lcmparameter_b.img 1.00 Mb Ok Ok 27.34 Kb Read [45/66]: tinysys-scp_b.bin 1.00 Mb Ok Ok 562.23 Kb Read [46/66]: sspm_b.img 1.00 Mb Ok Ok 424.86 Kb Read [47/66]: gz_b.img 16.00 Mb Ok Ok 2.69 Mb Read [48/66]: lk_b.bin 2.00 Mb Ok Ok 1.08 Mb Read [49/66]: boot_b.img 32.00 Mb Ok Ok 32.00 Mb Read [50/66]: vendor_boot_b.img 64.00 Mb Ok Read [51/66]: dtbo_b.img 8.00 Mb Ok Ok 8.00 Mb Read [52/66]: tz_b.img 6.00 Mb Ok Ok 872.41 Kb Read [53/66]: super.img 10.57 Gb Ok Sparse... blocks: 2770944 compression ratio: 6% 45 min 45 sec Ok 9.99 Gb Read [54/66]: odm_a.img 50.00 Mb Ok Sparse... blocks: 12800 compression ratio: 86% 2 sec Ok 7.47 Mb Read [55/66]: product_a.img 1.90 Gb Ok Sparse... blocks: 498944 compression ratio: 0% 8 min 46 sec Ok 1.90 Gb Read [56/66]: vendor_a.img 556.00 Mb Ok Sparse... blocks: 142336 compression ratio: 1% 2 min 28 sec Ok 554.32 Mb Read [57/66]: system_a.img 2.78 Gb Ok Sparse... blocks: 729344 compression ratio: 1% 12 min 42 sec Ok 2.78 Gb Read [58/66]: preload_a.img 1.43 Gb Ok Sparse... blocks: 375296 compression ratio: 0% 6 min 25 sec Ok 1.43 Gb Read [59/66]: oem_a.img 3.86 Gb Ok Sparse... blocks: 1011968 compression ratio: 14% 15 min 17 sec Ok 3.33 Gb Read [60/66]: vbmeta_b.img 8.00 Mb Ok Ok 3.25 Kb Read [61/66]: vbmeta_system_b.img 8.00 Mb Ok Ok 2.17 Kb Read [62/66]: vbmeta_vendor_b.img 8.00 Mb Ok Ok 1.63 Kb Build [63/66]: userdata.img 103.65 Gb Create partition image... Make filesystem [0x03 f2fs]... Ok Ok Ok 0 b Compact... Build scat... Ok Firmware size: 20.24 Gb Android Info saved: _Android_info.txt Scatter: MT6765_Android_scatter.txt Saved: C:\Users\ct3im\Desktop\TCL 30 SE (6165H) firmware read CM2MT2\MT6765_TCL_OSv12_SP1A.210812.016_cruzepro_6 2\ Verify firmware [MT6765_TCL_OSv12_SP1A.210812.016_cruzepro_62]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Upload file to server? No Reset port... Finished Read Flash [ v2.77 ] 107 min 9 sec |
![]() | #76601 (permalink) |
Member: 85718 Status: Offline Thanks Meter: 567 ![]() | Backup new update CM2 - MT2 Service Tool v2.77 Probe UAC... Ok Probe libusb... v1.2.6.0 Wait... S/N: 0005C0DF82 v0164 Initalize log engine... Ok Build directories tree... Ok Firmware files: C:\Users\ct3im\Desktop\TCL 30 SE (6165H) firmware read CM2MT2\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 16 dirs: 0 Load emi database... Internal: 28 custom: 0 Load IDBase v915508 Ok Build device list... Ok Load 159 profiles... Ok Initalize external tools... Ok Initialize libusb... Ok Ready Operation: Identify [ v2.77 ] Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V2023 (Android) (COM4) MODE: PRELOADER PORT; PORT: 4 Waiting for BOOT ACK... Boot Init... Ok CHIP: MT6761 HWs: 0x8A00 HWv: 0xCA01 HWc: 0x0717 SWv: 0x0200 Evo: 0x0000 Code: Merlot|A20|A22 Type: MODERN [RAPHAEL] Sec Level: 0x00000000; Mode: PLAIN Ver: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 2050CF67F01F7D8ED244ABBD0EB74CB05777123461690C34F4 82134786DFF032 IRG: 0x00000080 Agent: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT Sending DA1... Ok [1|1|1|0] Jump to DA... Ok Sync... Ok DA sync... Ok DA Set Params... Ok Mode: PRELOADER [1|1|1|0] EXT_RAM initialized Boot DA2... Ok [1|1|1|28] DA Sync... Ok Get hardware info... RAM: SRAM: 0x0003A600 233.50 Kb RAM: DRAM: 0xC0000000 3.00 Gb EMMC CID: 90014A68423861503E0217B4595B3827 crc Ok Vendor: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x02 Serial: 397695323 0x17B4595B MM/YY: 3/2021 BOOT1: 0x004000004.00 Mb BOOT2: 0x004000004.00 Mb RPMB: 0x0100000016.00 Mb USER: 0x747C0000029.12 Gb CHIP: MT6761 HWs: 0x8A00 HWv: 0xCA01 HWc: 0x0717 SWv: 0x0000 Evo: 0x0000 Code: Merlot|A20|A22 Type: MODERN [RAPHAEL] RNID: F66C53724DA2C3086E4A1D8E8B3BAF1B MEID: E503B6C4F5FAC14AA38BE413C8F711D2 SOCID: 2050CF67F01F7D8ED244ABBD0EB74CB05777123461690C34F4 82134786DFF032 USB: HIGH-SPEED SoC drivers: MediaTek PreLoader USB VCOM_V2023 (Android) v3.0.1512.0; Boot done 21 sec Load partition table... Ok 16 us Partition table: PGPT [0x64] with 40 records Load [MemTool]... Ok RPMB Off: RPMB Key not programmed [USABLE] rpmb engine: Off Storage [MMC] Life State: OK Storage OTP Status: Unlocked Storage [MMC] RPMB State: RPMB Key not programmed [USABLE] If process will stop later - try with [SW info] Off Device has no slots Probe boot... boot: vendor_boot;ramsidk size=0;recovery;gzip;ramdisk size 0x113BEE9;boot;gzip;ramdisk size 0x170F00; Finished 829 us Probe core... Scan filesystem... Ok Mount[ext4] wo/cache system@super 0x0027900000/51A94000 Mount[ext4] wo/cache vendor@super 0x0079394000/15084000 Mount[ext4] wo/cache product@super 0x008E418000/62F51000 Ok 2 sec SW: Hammer/Energy_2_2022_EEA/Energy_2_2022:11/RP1A.200720.011/1655380753:user/release-keys Product Brand: Hammer Product Device: Energy_2_2022 Product Model: Hammer_Energy_2_2022 Product Name: Energy_2_2022_EEA Patch Level: RP1A.200720.011 Display ID: Hammer_Energy_2_2022_v11.0.12_20220713 SW Version: 1655380753 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2022-05-05 Build Time: 13/07/2022 04:03:22 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: pd8d23_xwp_v31_he2_v4 SW: full_pd8d23_xwp_v31_he2_v4-user 11 RP1A.200720.011 1655380753 release-keys Device ID: mptech-hammer-energy-2-2022-energy-2-2022-eea-pd8d23-xwp-v31-he2-v4 Strategy: [none|generic] Firmware ID: MT6761_Hammer_Energy_2_2022_OSv11_Hammer_Energy_2_ 2022_v11.0.12_20220713_RP1A.200720.011_pd8d23_xwp_ v31_he2_v4 Verify firmware [MT6761_Hammer_Energy_2_2022_OSv11_Hammer_Energy_2_ 2022_v11.0.12_20220713_RP1A.200720.011_pd8d23_xwp_ v31_he2_v4]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Probe LK... load [lk] load Ok 78 us lk [741e7349] pd8d23_xwp_v31_he2_v4-79f468127-20220711135900-20220713121727 Verify [lk] data... Ok 2 sec Probe userdata... Load userdata header... Ok userData: encrypted Backup exist: C:\InfinityBox\CM2MT2\backup\MT6761__E503B6C4F5FAC 14AA38BE413C8F711D2.7z Load nvram... NVRAM: 160 items; State: Ok WiFi MAC: AA:00:6E:74:2F:76 BT MAC: 98:80:BB:C1:25:B2 IMEI1: 353813113012644 IMEI2: 353813113012651 PSN1: 202113004503 get modem info... load [md1img] load Ok 3 sec TK_MD_BASIC_MDBIN_PCB01_MT6761_S00.MOLY_LR12A_R3_M P_V184_4_P4 Secondary RPMB... On Probe preloader... Read preloader[0]... Ok EMI: MT6761 preloader_pd8d23_xwp_v31_he2_v4.bin with 6 memory types [20220713-120835] slots: no 1. eMMC DDR3 ID: 90014A484247346132 HBG4a2 HBG4a2 RAM: 3.00 Gb 2. eMMC DDR3 ID: 150100474436424D42 GD6BMB GD6BMB RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 150100444436384D42 DD68MB DD68MB RAM: 3.00 Gb 4. eMMC DDR3 ID: 150100475836424142 GX6BAB GX6BAB RAM: 3.00 Gb 5. eMMC LP_DDR4X ID: 150100445836384D42 DX68MB DX68MB RAM: 3.00 Gb 6. eMMC DDR3 ID: 90014A68423861503E hB8aP> hB8aP> RAM: 3.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_p d8d23_xwp_v31_he2_v4.43b827a5.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_p d8d23_xwp_v31_he2_v4.43b827a5.bin [28554978]... Exist Probe FRP... Most probably On Probe bootloader... Seems as Locked Reset port... Finished Identify [ v2.77 ] 44 sec Operation: Read Flash [ v2.77 ] Destination: C:\Users\ct3im\Desktop\Hammer Energy 2 eco\ Disk free space: 21.01 Gb Pack/Sparse is On, it may takes up to 10 min for large files! Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V2023 (Android) (COM4) MODE: PRELOADER PORT; PORT: 4 Waiting for BOOT ACK... Boot Init... Fail Change USB cable and USB port, do not use USB-hub Latest SoC drivers or PC REBOOT may helps Finished Read Flash [ v2.77 ] 21 sec Operation: Read Flash [ v2.77 ] Destination: C:\Users\ct3im\Desktop\Hammer Energy 2 eco\ Disk free space: 21.13 Gb Pack/Sparse is On, it may takes up to 10 min for large files! Wait... Connection: Boot [DA] Factory Port: Both [ B + P ]; Force BROM: Off; USB High-Speed: On DA Key: custom; Local SLA: Off; Auto-EMI: On Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V2023 (Android) (COM4) MODE: PRELOADER PORT; PORT: 4 Waiting for BOOT ACK... Boot Init... Ok CHIP: MT6761 HWs: 0x8A00 HWv: 0xCA01 HWc: 0x0717 SWv: 0x0200 Evo: 0x0000 Code: Merlot|A20|A22 Type: MODERN [RAPHAEL] Sec Level: 0x00000000; Mode: PLAIN Ver: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 2050CF67F01F7D8ED244ABBD0EB74CB05777123461690C34F4 82134786DFF032 IRG: 0x00000080 Agent: [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for bootchain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT Sending DA1... Ok [1|1|1|0] Jump to DA... Ok Sync... Ok DA sync... Ok DA Set Params... Ok Mode: PRELOADER [1|1|1|0] EXT_RAM initialized Boot DA2... Ok [1|1|1|28] DA Sync... Ok Get hardware info... RAM: SRAM: 0x0003A600 233.50 Kb RAM: DRAM: 0xC0000000 3.00 Gb EMMC CID: 90014A68423861503E0217B4595B3827 crc Ok Vendor: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x02 Serial: 397695323 0x17B4595B MM/YY: 3/2021 BOOT1: 0x004000004.00 Mb BOOT2: 0x004000004.00 Mb RPMB: 0x0100000016.00 Mb USER: 0x747C0000029.12 Gb CHIP: MT6761 HWs: 0x8A00 HWv: 0xCA01 HWc: 0x0717 SWv: 0x0000 Evo: 0x0000 Code: Merlot|A20|A22 Type: MODERN [RAPHAEL] RNID: F66C53724DA2C3086E4A1D8E8B3BAF1B MEID: E503B6C4F5FAC14AA38BE413C8F711D2 SOCID: 2050CF67F01F7D8ED244ABBD0EB74CB05777123461690C34F4 82134786DFF032 USB: HIGH-SPEED SoC drivers: MediaTek PreLoader USB VCOM_V2023 (Android) v3.0.1512.0; Boot done 22 sec Load partition table... Ok 16 us Partition table: PGPT [0x64] with 40 records Device has no slots Probe boot... boot: vendor_boot;ramsidk size=0;recovery;gzip;ramdisk size 0x113BEE9;boot;gzip;ramdisk size 0x170F00; Finished 797 us Probe core... Scan filesystem... Ok Mount[ext4] wo/cache system@super 0x0027900000/51A94000 Mount[ext4] wo/cache vendor@super 0x0079394000/15084000 Mount[ext4] wo/cache product@super 0x008E418000/62F51000 Ok 2 sec SW: Hammer/Energy_2_2022_EEA/Energy_2_2022:11/RP1A.200720.011/1655380753:user/release-keys Product Brand: Hammer Product Device: Energy_2_2022 Product Model: Hammer_Energy_2_2022 Product Name: Energy_2_2022_EEA Patch Level: RP1A.200720.011 Display ID: Hammer_Energy_2_2022_v11.0.12_20220713 SW Version: 1655380753 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2022-05-05 Build Time: 13/07/2022 04:03:22 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: pd8d23_xwp_v31_he2_v4 SW: full_pd8d23_xwp_v31_he2_v4-user 11 RP1A.200720.011 1655380753 release-keys Device ID: mptech-hammer-energy-2-2022-energy-2-2022-eea-pd8d23-xwp-v31-he2-v4 Strategy: [none|generic] Firmware ID: MT6761_Hammer_Energy_2_2022_OSv11_Hammer_Energy_2_ 2022_v11.0.12_20220713_RP1A.200720.011_pd8d23_xwp_ v31_he2_v4 Device has no slots Total size to read: 4.43 Gb Read [1/43]: preloader.bin 4.00 Mb Ok Ok 226.66 Kb Read [4/43]: recovery.img 32.00 Mb Ok Ok 32.00 Mb Read [7/43]: vbmeta_system.img 8.00 Mb Ok Ok 2.20 Kb Read [8/43]: vbmeta_vendor.img 8.00 Mb Ok Ok 1.64 Kb Read [17/43]: persist.img 48.00 Mb Ok Sparse... blocks: 12288 compression ratio: 92% 3 sec Ok 4.31 Mb Read [18/43]: sec.img 2.00 Mb Ok Read [19/43]: proinfo.img 3.00 Mb Ok Ok 336 b Estimated time to end 7 sec Read [20/43]: md1rom.img 100.00 Mb Ok Ok 46.96 Mb Read [21/43]: spmfw.img 1.00 Mb Ok Ok 62.92 Kb Read [22/43]: tinysys-scp.bin 1.00 Mb Ok Ok 540.66 Kb Read [23/43]: tinysys-scp.bin 1.00 Mb Read [24/43]: sspm.img 1.00 Mb Ok Ok 432.13 Kb Read [25/43]: sspm.img 1.00 Mb Read [26/43]: gz.img 16.00 Mb Ok Read [27/43]: gz.img 16.00 Mb Ok Read [28/43]: nvram.bin 64.00 Mb Ok Ok 63.88 Mb Read [29/43]: lk.bin 1.00 Mb Ok Ok 857.81 Kb Read [30/43]: lk.bin 1.00 Mb Read [31/43]: boot.img 32.00 Mb Ok Ok 32.00 Mb Read [32/43]: vendor_boot.img 64.00 Mb Ok Read [33/43]: logo.bin 8.00 Mb Ok Ok 2.28 Mb Read [34/43]: dtbo.img 8.00 Mb Ok Ok 43.86 Kb Read [35/43]: tz.img 5.00 Mb Ok Ok 1.98 Mb Read [36/43]: tz.img 11.00 Mb Read [37/43]: super.img 4.00 Gb Ok Sparse... blocks: 1048576 compression ratio: 22% 24 min 29 sec Ok 3.14 Gb Read [38/43]: vbmeta.img 8.00 Mb Ok Ok 2.91 Kb Build [39/43]: cache.img 432.00 Mb Create partition image... Make filesystem [0x02 ext4|8+]... Ok Ok Ok 0 b Build [40/43]: userdata.img 24.02 Gb Create partition image... Make filesystem [0x02 ext4|8+]... Ok Ok Ok 0 b Compact... Build scat... Ok Firmware size: 3.32 Gb Android Info saved: _Android_info.txt Scatter: MT6761_Android_scatter.txt Saved: C:\Users\ct3im\Desktop\Hammer Energy 2 eco\MT6761_Hammer_Energy_2_2022_OSv11_Hammer_Energ y_2_2022_v11.0.12_20220713_RP1A.200720.011_pd8d23_ xwp_v31_he2_v4\ Verify firmware [MT6761_Hammer_Energy_2_2022_OSv11_Hammer_Energy_2_ 2022_v11.0.12_20220713_RP1A.200720.011_pd8d23_xwp_ v31_he2_v4]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Upload file to server? No Reset port... Finished Read Flash [ v2.77 ] 27 min 58 sec |
![]() | #76602 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,345 | Nokia C1 2nd Edition TA-1380 Flash Done ! CM2 - SP3 Service Tool v2.33 Probe UAC... Ok Wait... S/N: Initalize log engine... Ok Build directories tree... Firmware files: E:\Nokia\Ta-1380_C1_2nd_Edition_CM2_Backup_stock-rom.com\ Backup files: C:\InfinityBox\CM2SP3\backup\ Backup files: 0 dirs: 0 Build device list... Ok 1727 Ready Operation: Connect SoC SC7731 Boot [FDL] Factory [v2.33] Wait... Power device Off and connect cable now Remember Volume Up/Down or Test-Point Waiting for device... Device found PTFN: SPRD U2S Diag (COM36) 1782:4D00 boot: SPRD3 C:\InfinityBox\CM2SP3\boot\SoC\SC7731\FDL1.240fc3d 0.ldr C:\InfinityBox\CM2SP3\boot\SoC\SC7731\FDL2.240fc3d 0.e48ef1e6.ldr Boot[1] [+] Custom... Ok Exec[1]... Ok Boot ack: Spreadtrum Boot Block version 1.1 Loader ACK... Ok Set port speed... 2000000 Enable charge... Ok Boot[2] [+] [-]... Ok Exec[2]... Ok Version: 0x10 Random: 0x00 Enable RAW... Ok Disable transcode... Ok Loader exec [0] Ok Dev UID: 93303e6f752592c0f043de33d2a7e79985769aee8b673ea2e3 b5d98ea6430d8f hwid cache absent get storage info... MMC For advanced features use Boot [FF] FireFly EXTCSD: Select connection mode [Boot [FF] FireFly] Load partition table... Partitions: 75 Connected [MemTool] load 75 items Finished Connect [ v2.33 ] 23 sec Layout: E:\Nokia\Ta-1380_C1_2nd_Edition_CM2_Backup_stock-rom.com\STOCK-ROM.COM_TA-1380_SP7731E_HMD_Global_Nokia_C1_2nd_Edition_OSv11 _RP1A.201005.001_IRU\layout.txt get firmware info... Ok SW: Nokia/Irisumts_00WW/IRU:11/RP1A.201005.001/00WW_1_22G:user/release-keys Product Brand: Nokia Product Model: Nokia C1 2nd Edition Product Device: IRU Patch Level: RP1A.201005.001 SW Version: 00WW_1_22G Product Info: IRU Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-07-05 Build Time: 7/12/2023 2:45:57 PM CPU: armeabi-v7a,armeabi SW: T18546AA1_native-user 11 RP1A.201005.001 28322 release-keys Product Board: Irisumts Board Platform: sp7731e Product Manfct: HMD Global SW: Nokia/Irisumts_00WW/IRU:11/RP1A.201005.001/00WW_1_22H:user/release-keys SW Version: 00WW_1_22H Sec. Patch: 2023-09-05 Build Time: 8/29/2023 5:22:02 PM SW: T18546AA1_native-user 11 RP1A.201005.001 35301 release-keys Android ver: 11 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Device ID: iru-hmd-global-nokia-c1-2nd-edition-iru-irisumts Strategy: [nokia] Firmware ID: SP7731E_HMD_Global_Nokia_C1_2nd_Edition_OSv11_RP1A .201005.001_IRU os image: Firmware has unknown or damaged structure ldsp absent Loaded 75, selected 61 boot area write Off boot area write Off Operation: Write FW SoC SC7731 Boot [FDL] Factory [v2.33] Wait... E:\Nokia\Ta-1380_C1_2nd_Edition_CM2_Backup_stock-rom.com\STOCK-ROM.COM_TA-1380_SP7731E_HMD_Global_Nokia_C1_2nd_Edition_OSv11 _RP1A.201005.001_IRU\layout.txt Device/File partition tables are the same Repartition: Off Partitions: 75 Reset Userdata: Off Erase [4/75] misc 1024.00 Kb Ok Erase [11/75] uboot_log 4.00 Mb Ok Erase [18/75] w_runtimenv1 1024.00 Kb Ok Erase [53/75] vbmeta_a 1024.00 Kb Ok Erase [54/75] vbmeta_b 1024.00 Kb Ok Erase [55/75] sysdumpdb 10.00 Mb Ok Erase [57/75] vbmeta_system_a 1024.00 Kb Ok Erase [58/75] vbmeta_system_b 1024.00 Kb Ok Erase [59/75] vbmeta_vendor_a 1024.00 Kb Ok Erase [60/75] vbmeta_vendor_b 1024.00 Kb Ok Erase [61/75] vbmeta_hmdodm_a 1024.00 Kb Ok Erase [62/75] vbmeta_hmdodm_b 1024.00 Kb Ok Erase [63/75] vbmeta_system_ext_a 1024.00 Kb Ok Erase [64/75] vbmeta_system_ext_b 1024.00 Kb Ok Erase [65/75] vbmeta_product_a 1024.00 Kb Ok Erase [66/75] vbmeta_product_b 1024.00 Kb Ok Erase [67/75] vbmeta_odm_a 1024.00 Kb Ok Erase [68/75] vbmeta_odm_b 1024.00 Kb Ok Erase [69/75] avbmeta_rs_a 1024.00 Kb Ok Erase [70/75] avbmeta_rs_b 1024.00 Kb Ok Writing... Write [1/75] vbmeta_a 1024.00 Kb Ok 140 us Write [2/75] vbmeta_b 1024.00 Kb Ok 141 us Write [3/75] vbmeta_system_a 1024.00 Kb Ok 47 us Write [4/75] vbmeta_system_b 1024.00 Kb Ok 47 us Write [5/75] vbmeta_vendor_a 1024.00 Kb Ok 47 us Write [6/75] vbmeta_vendor_b 1024.00 Kb Ok 47 us Write [7/75] vbmeta_hmdodm_a 1024.00 Kb Ok 47 us Write [8/75] vbmeta_hmdodm_b 1024.00 Kb Ok 47 us Write [9/75] vbmeta_system_ext_a 1024.00 Kb Ok 62 us Write [10/75] vbmeta_system_ext_b 1024.00 Kb Ok 47 us Write [11/75] vbmeta_product_a 1024.00 Kb Ok 47 us Write [12/75] vbmeta_product_b 1024.00 Kb Ok 47 us Write [13/75] vbmeta_odm_a 1024.00 Kb Ok 47 us Write [14/75] vbmeta_odm_b 1024.00 Kb Ok 47 us Skip [15/75] prodnv 10.00 Mb [Off] Write [16/75] elabel 5.00 Mb Ok 63 us Skip [17/75] miscdata 1024.00 Kb [Off] Write [18/75] misc 1024.00 Kb Ok 32 us Estimated time to end 1 sec Write [19/75] trustos_a 6.00 Mb Ok 141 us Write [20/75] trustos_b 6.00 Mb Ok 125 us Write [21/75] sml_a 1024.00 Kb Ok 32 us Write [22/75] sml_b 1024.00 Kb Ok 31 us Skip [23/75] uboot_a 1024.00 Kb [Off] Skip [24/75] uboot_b 1024.00 Kb [Off] Skip [25/75] uboot_log 4.00 Mb [Off] Write [26/75] logo 7.00 Mb Ok 32 us Write [27/75] fbootlogo 7.00 Mb Ok 172 us Skip [28/75] w_fixnv1_a 1024.00 Kb [Off] Skip [29/75] w_fixnv2_a 1024.00 Kb [Off] Skip [30/75] w_fixnv1_b 1024.00 Kb [Off] Skip [31/75] w_fixnv2_b 1024.00 Kb [Off] Skip [32/75] w_runtimenv1 1024.00 Kb [Off] Skip [33/75] w_runtimenv2 1024.00 Kb [Off] Skip [34/75] persist 2.00 Mb [Off] Write [35/75] gpsgl_a 1024.00 Kb Ok 94 us Write [36/75] gpsgl_b 1024.00 Kb Ok 109 us Write [37/75] gpsbd_a 1024.00 Kb Ok 94 us Write [38/75] gpsbd_b 1024.00 Kb Ok 93 us Write [39/75] wcnmodem_a 10.00 Mb Ok 125 us Write [40/75] wcnmodem_b 10.00 Mb Ok 140 us Write [41/75] w_modem_a 16.00 Mb Ok 1 sec Write [42/75] w_modem_b 16.00 Mb Ok 1 sec Write [43/75] w_deltanv_a 1024.00 Kb Ok 31 us Write [44/75] w_deltanv_b 1024.00 Kb Ok 31 us Write [45/75] w_gdsp_a 10.00 Mb Ok 875 us Write [46/75] w_gdsp_b 10.00 Mb Ok 890 us Write [47/75] pm_sys_a 1024.00 Kb Ok 157 us Write [48/75] pm_sys_b 1024.00 Kb Ok 109 us Write [49/75] teecfg_a 1024.00 Kb Ok 31 us Write [50/75] teecfg_b 1024.00 Kb Ok 31 us Write [51/75] hypervsior_a 2.00 Mb Ok 16 us Write [52/75] hypervsior_b 2.00 Mb Ok 31 us Write [53/75] boot_a 64.00 Mb Ok 5 sec Write [54/75] boot_b 64.00 Mb Ok 5 sec Write [55/75] vendor_boot_a 100.00 Mb Ok 46 us Write [56/75] vendor_boot_b 100.00 Mb Ok 32 us Write [57/75] dtb_a 8.00 Mb Ok 31 us Write [58/75] dtb_b 8.00 Mb Ok 31 us Write [59/75] dtbo_a 8.00 Mb Ok 765 us Write [60/75] dtbo_b 8.00 Mb Ok 797 us Write [61/75] super 2.57 Gb Ok 1 min 20 sec Skip [62/75] cache 20.00 Mb [Off] Write [63/75] socko_a 75.00 Mb Ok 6 sec Write [64/75] socko_b 75.00 Mb Ok 6 sec Write [65/75] odmko_a 25.00 Mb Ok 2 sec Write [66/75] odmko_b 25.00 Mb Ok 2 sec Skip [67/75] sysdumpdb 10.00 Mb [Off] Skip [68/75] metadata 16.00 Mb [Off] Write [69/75] avbmeta_rs_a 1024.00 Kb Ok 47 us Write [70/75] avbmeta_rs_b 1024.00 Kb Ok 78 us Write [71/75] common_rs1_a 2.00 Mb Ok 31 us Write [72/75] common_rs1_b 2.00 Mb Ok 63 us Skip [73/75] userdata 11.13 Gb [Off] Skip [74/75] splloader 512.00 Kb [Off] Skip [75/75] splloader_bak 512.00 Kb [Off] Completed 57 of 57 Finished Write FW [ v2.33 ] 1 min 59 sec Finished Identify | Get info [ v2.33 ] 1 sec Reboot... Disconnect cable if it freez Bye |
![]() | #76603 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,778 | ITEL VISION 3 RESET FRP DONE BY CM2 Card found : 73CA70CC , v0161 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : iTel : S661L_Vision-3 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:21 |
![]() | #76604 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | CALL ME C12 HANG ON LOGO DONE BY CM2 WITH OUT BOOT KEY Card found : 73CA70CC , v0161 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.07 ] BootMode : SVC 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : SPRD ( Legacy ) ModemInfo : Project Version: SC6531EFM_BAR BASE Version: BASE_SVN HW Version: SC6531EFM_BAR CMP_Time : 01-15-2020 11:04:51 SecInfo : IMEI[1] : IMEI[2] : IMEI[3] : WIFIMAC : FFFFFFFFFFFF BT_MAC : 018321094528 SEC_ID : 7B9EFFFF39A561D3 Done! Elapsed: 00:00:20 Reconnect Power/Cable! Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Format FFS Done! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
![]() | #76605 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | GFIVE DISCO (E301) V2.0 HANG ON LOGO DONE BY CM2 Card found : 73CA70CC , v0161 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.07 ] BootMode : FLASH 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] IMEI[1] : IMEI[2] : Done! Elapsed: 00:00:21 Reconnect Power/Cable! Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1D9 2609B0B17_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
