08-15-2009, 10:26 | #766 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Pakistan
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,422 | COM16 [VCP0] selected module v1.66 Device: LG-KG375 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: .00 ULC2GL Vodafone KG375 P16 FL 34 V10b 214-01 SEP 03 200 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG375_eeprom-static_20090815-140954.B1E.bin loading data... data loaded imei: 35876301706688800 reading eeprom-security_35876301706688800... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG375_eeprom-security_35876301706688800_20090815-140954.B1E.bin reading eeprom-complete_35876301706688800... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG375_eeprom-complete_35876301706688800_20090815-140956.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 15 sec Remove/Install battery now ! |
The Following User Says Thank You to shahzaadbutt For This Useful Post: |
08-15-2009, 10:33 | #767 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Islamic Republic Age: 37
Member: 466635 Status: Offline Sonork: 100.1614186 Thanks Meter: 482 | Zte-760 unlocked by infinitiy COM47 [VCP0] selected module v2.79 Action: unlock unlock method: smart fast Model: ZTE-X760 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:F203:0007 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: X760_Z15ES_FS_BFFA102 Version: ZTEMT25_07A_HW_C 44 byte(s) read imei: 3523530236**** connection Ok 157 byte(s) read reading data... building new data... writing data... 145 byte(s) read reading data... building new data... writing data... verifying... verification Ok done Finished, time used: 10 sec Remove/Install battery now ! B.R SHERRY MOBILES |
The Following 2 Users Say Thank You to oMeR_Rasheed For This Useful Post: |
08-15-2009, 12:36 | #768 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM7 [VCP0] selected module v2.75 Action: touchscreen calibration mode: 3 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:E203:000B Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: FXD-S3_FOREIGN_MR106_004_S5T24T-MC-C01-RF3198_V1.0.019_080605 Version: GINWAVE25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-4)... 0 1 2 3 4 5 6 7 8 9error: detection failed (10 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 21 sec Remove/Install battery now ! |
The Following User Says Thank You to cel_phon For This Useful Post: |
08-15-2009, 14:10 | #769 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM7 [VCP0] selected module v2.75 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:A803:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: Yz220_C046.6225.L10.F08.D39.C6.U2.V3.01 Version: Yawei25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 164 warning: wrong packet cs items cleared: 164 of 164 building list... done items remains: 0 Finished, time used: 25 sec Remove/Install battery now ! |
08-15-2009, 23:50 | #770 (permalink) |
Registered User Join Date: Dec 2007
Member: 642071 Status: Offline Thanks Meter: 54 | Lg kp 202 vodafone unlock COM3 [VCP0] selected module v1.38 Device: LG-KP202 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005258 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 354912014510901 current otp imei: 354912014510901 file saved: C:\Program Files\InfinityBox\LGA\eeprom_354912014510901_LG-KP202_20090815-174403.B1E.bin ... version: ure----LGELECKP20204d Check flash Done Check space ... current eeprom imei: 354912014510901 ................................. finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 33 sec Remove/Install battery now ! |
The Following User Says Thank You to Dwight07 For This Useful Post: |
08-16-2009, 09:44 | #771 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM7 [VCP0] selected module v2.75 Action: touchscreen calibration mode: 3 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0003:0002 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: A25_B_V2_L5.GEMINI.1.0 Version: VIGORTECH25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-4)... 0 2 3 4 5 7 8 9error: detection failed (8 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 9 sec Remove/Install battery now ! |
08-16-2009, 09:47 | #772 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM7 [VCP0] selected module v2.75 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:EC03:000A boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: GINWAVE25_06B_PCB01_GPRS_MT6225_S00.FXD-S1-ML_MR106_006_5S01-MC-C01-RF3198_V1_0_017_080226.BIN ver. sw 2: FXD-S1-ML_MR106_006_5S01-MC-C01-RF3198_V1.0.017_080226, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25082501:18E59F00000000 Finalization Done Finished, time used: 38 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
08-16-2009, 10:14 | #773 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 38
Member: 171512 Status: Offline Thanks Meter: 1,034 | SonyEricsson T303 unlock done. COM3 [VCP0] selected module v1.34 Device: Sony-Ericsson-T303 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb software version: 1209-8113 software version: R2CC001 Check hardware done Read data ... reading Sony-Ericsson-T303_eeprom_calibration-1... file saved: D:\Program Files\InfinityBox\HModule\Sony-Ericsson-T303_eeprom_calibration-1_20090719-132528.80E.bin Read data done Check data ... Check data done Write ... ........................... flash: 89890400040089:89890400000000 Write: simlock Write done Finished, time used: 199 sec Remove/Install battery now ! thanks infinity team |
The Following User Says Thank You to ehsas_ghum For This Useful Post: |
08-16-2009, 10:14 | #774 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM7 [VCP0] selected module v2.75 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:EC03:000A boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.95E537E4.[V490_PCB01_GPRS_MT6226_S01.L3P4T02_7_12_1_0T02M071 4_M510A.BIN_F7A6AFBA].rpl identification#1 detection finished device-id: 95E537E4 identification#1 protocol ver: 04 ver. sw 1: V490_PCB01_GPRS_MT6226_S01.L3P4T02_7_12_1_0T02M071 4_M510A.BIN ver. sw 2: L3P4T02.7.12.1.0T02M0714_M510A, 45505908 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:2AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[V490_PCB01_GPRS_MT6226_S01.L3P4T02_7_12_1_0T02M071 4_M510A.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[V490_PCB01_GPRS_MT6226_S01.L3P4T02_7_12_1_0T02M071 4_M510A.BIN]_20090816-151003.B0E.bin flash: EC257E25082501:2AEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_95E537E4_V490_PCB01_GPRS_MT6226_S01.L3P4 T02_7_12_1_0T02M0714_M510A.BIN_F7A6AFBA_20090816-151007.B0X.bin Area: Eeprom/ffs flash: EC257E25082501:2AEA0000000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . detect device identification#2 finished Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_95E537E4_V490_PCB01_GPRS_MT6226_S01.L3P4 T02_7_12_1_0T02M0714_M510A.BIN_F7A6AFBA_20090816-151120.B0X.bin Finished, time used: 192 sec Remove/Install battery now ! |
08-16-2009, 10:17 | #775 (permalink) |
Member: 171512 Status: Offline Thanks Meter: 1,034 | zong a136 unlock ok COM44 [VCP0] selected module v1.65 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090725-122411.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090725-122412.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090725-122414.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090725-122418.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 26 sec Remove/Install battery now ! |
08-16-2009, 10:22 | #776 (permalink) |
Member: 171512 Status: Offline Thanks Meter: 1,034 | I unlocked T303 & T280i by infinity here is the LOG of T208i module v1.34 Device: Sony-Ericsson-T280i "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb Check hardware done Read data ... reading Sony-Ericsson-T280i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T280i_eeprom_calibration-1_20090221-120619.80E.bin Read data done Check data ... Check data done Write ... ........................ flash: 89890400040089:89890400000000 Write: simlock Write done Finished, time used: 228 sec Remove/Install battery now ! |
08-16-2009, 11:12 | #777 (permalink) |
Member: 171512 Status: Offline Thanks Meter: 1,034 | NOKIA N95 8GB IN SMALL SIZE REPAIR OK COM3 [VCP0] selected module v2.87 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:8003:0006 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.3FF362A9.[C95_3_PCB01_GPRS_MT6225_S00.00_1.BIN_FBBA1112].rpl identification#1 detection finished device-id: 3FF362A9 identification#1 protocol ver: 04 ver. sw 1: C95_3_PCB01_GPRS_MT6225_S00.00_1.BIN ver. sw 2: C95_3.00.1, EDEE4504 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device identification#2... detection phase #1... . detect device identification#2 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25082501:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\C 95_3_PCB01_GPRS_MT6225_S00.00_1__system_log_3FF362 A9_FBBA1112_20090816-145101.B0X.bin Finished, time used: 47 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
08-16-2009, 12:07 | #778 (permalink) |
Registered User Join Date: Dec 2007 Location: fazal Haroonabad Pakistan Age: 46
Member: 650213 Status: Offline Sonork: 100.1581739:333 Thanks Meter: 133 | Sony Ericsson T280i successfully flashed Sony Ericsson T280i successfully flashed COM6 [VCP0] selected module v1.30 Device: Sony-Ericsson-T280i "advanced chip detection" active Action: flash write Write: Firmware Write: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb Check hardware done Read data ... reading Sony-Ericsson-T280i_eeprom_calibration-1... file saved: D:\Program Files\InfinityBox\HModule\Sony-Ericsson-T280i_eeprom_calibration-1_20090816-032630.80E.bin Read data done Check data ... Check data done Write ... Area: Firmware flash: 89890400040089:89890400000000 Write: Firmware Area: Flex flash: 89890400040089:89890400000000 Write: Flex Write done Finished, time used: 1999 sec Remove/Install battery now ! |
The Following User Says Thank You to gsm5378 For This Useful Post: |
08-16-2009, 15:01 | #779 (permalink) |
Member: 171512 Status: Offline Thanks Meter: 1,034 | xtelcome v8000 repair ok COM3 [VCP1] selected module v2.87 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:95C1:E5BE status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.89FE83B2.[MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN_E7D1D8F9].rpl identification#1 detection finished device-id: 89FE83B2 identification#1 protocol ver: 04 ver. sw 1: MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN ver. sw 2: MAUI.05C.W06.16, 06272E18 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 01227E22202200:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device identification#2... detection phase #1... . detect device identification#2 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 01227E22202200:29EA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 01227E22202200:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\M TK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W06 _16__system_log_89FE83B2_E7D1D8F9_20090816-181312.B0X.bin Finished, time used: 144 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
08-16-2009, 15:36 | #780 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | ==== log: [8/16/2009 6:54:29 PM] ==== COM21 [VCP0] selected module v1.32 Device: Sony-Ericsson-T250i "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89880900010001:89880900000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb Check hardware done Read data ... reading Sony-Ericsson-T250i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T250i_eeprom_calibration-1_20090816-185608.80E.bin Read data done Check data ... Check data done Write ... .......... flash: 89880900010001:89880900000000 Write: simlock Write done Finished, time used: 199 sec Remove/Install battery now ! |
The Following User Says Thank You to Shakeel_pattoki For This Useful Post: |
