Old 08-17-2009, 09:05   #781 (permalink)
Member: 348774
Thanks Meter: 66
ZTE A35 unlock by infinity
lock sa globe
cable pinout: RX,TX/TX,RX
just press SP-UNLOCKS
The Following User Says Thank You to tahod For This Useful Post:
Old 08-17-2009, 09:30   #782 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
NKTEL REPAIR OK
COM3 [VCP0] selected
module v2.87
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:A203:0007
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 89881200010001:89881200000000
flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 detection finished
identification#1 protocol ver: 04
ver. sw 1: KCM25_GEMINI_PCB01_GPRS_MT6225_S00.K7_PBLCD_PBCAME RA_T3_V3_1.BIN
ver. sw 2: k7_PbLCD_PbCamera_T3_V3.1, 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00F80000
Detected ffs/eeprom address is non-standard: 00F80000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00F80000
detecting ffs/eeprom size...
ffs/eeprom size: 00080000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00F80000-00FFFFFF
detect device identification#2...
detect device identification#2 finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 29 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to ehsas_ghum For This Useful Post:
Old 08-17-2009, 09:47   #783 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
Thanks Meter: 1,162
Touch screen calibration bypass with new method succesfull....
COM1 [VCP1] selected
module v2.89
Action: touchscreen calibration
How to calibrate touchscreen:
- for this operation you need to have full flash backup from phone
- if you have full flash backup already press "Yes", select full flash file and follow instructions given by software
- if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure
Do you have full flash backup ?
Loading file v.02...
MTK25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_12_59 __fullflash_20090817-121624.B0M.bin loaded
detected record size adjusted
Model: Autodetect 6205-6227 NOR
19200 autodetect
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:9203:000D
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: MAUI.06B.W07.12.59
Version: MTK25_06B_HW
44 byte(s) read
imei: 35044801123456
connection Ok
160 byte(s) read
reading data #2...
writing data...
verification...
verification Ok
Finished, time used: 10 sec
The Following User Says Thank You to zeel_zeel For This Useful Post:
Old 08-17-2009, 09:49   #784 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
Thanks Meter: 1,162
Another touch screen calibration bypass with new method done with ease ....
COM79 [VCP0] selected
module v2.89
N81_ABROAD_PCB01_GPRS_MT6225_S00.N81_ABROAD_S5LCD_ V1_1_8__fullflash_20090812-123318.B0M.bin loaded
19200 autodetect
CPU: MT6225
high speed boot On
chip: 0001:FF03:0004
status: FF
Date: 2006.06.14
Version: 1.0
Version: N81_ABROAD_S5LCD_V1.1.8
Version: M500_P3
67 byte(s) read
connection Ok
211 byte(s) read
reading data #2...
writing data...
verification...
verification Ok
Old 08-17-2009, 10:44   #785 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
ZTE X761 UNLOCK OK----------------- THANKS INFINTY TEAM
module v2.75
Action: unlock
unlock method: smart fast
Model: ZTE-X761
19200 autodetect
CPU: MT6225
chip: 0001:3C03:0000
status: FF
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: X761_Z2_SF_BFFA103
Version: ZTEMT25_07A_HW_C
44 byte(s) read
imei: 35787302204500
connection Ok
157 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
145 byte(s) read
reading data...
writing data...
verifying...
verification Ok
done
Finished, time used: 11 sec
Old 08-17-2009, 12:31   #786 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
Thanks Meter: 1,451
motorola c115 unlock
COM4 [VCP0] selected
Action: unlock
Device: C113(a),C114,C115,C116,C117,C118
Connect...
Press and HOLD Power button...
connection mode: 00
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
SW version: 1.0.49.E.
HW version: _E88
imei otp: 356480005660232
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _356480005660232_20090817-142906.18E.bin
imei eeprom: 356480005660232
Check Flash-2 Done
Write...
Write Done
Finished, time used: 23 sec
The Following User Says Thank You to guljee786 For This Useful Post:
Old 08-17-2009, 12:32   #787 (permalink)
Member: 70573
Thanks Meter: 24
Vodafone 228 unlock sucssefully. Thank Infinity Team again!
COM3 [Serial2] selected
module v1.69
Device: Vodafone-228
Action: unlock
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
230400
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
sw version: VDF-P108C1B03-DeTuCsFr-DE05 g3yBV2.0 EDTCF-DE-P108C1V1.0.0B08
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-228_eeprom-static_20090817-182043.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-228_eeprom-security_20090817-182044.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-228_eeprom-complete_20090817-182047.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-228_lock-area_20090817-182053.B1E.bin
backup critical area Done
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 31 sec
The Following User Says Thank You to dog_baby For This Useful Post:
Old 08-17-2009, 12:39   #788 (permalink)
Member: 70573
Thanks Meter: 24
Vodafone 228 unlock sucessfully!
module v1.69
Action: unlock
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
230400
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
loading data...
data loaded
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Old 08-17-2009, 12:41   #789 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
LG KG 195 REPAIR OK
module v2.75
Device: LG-KG195
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
chip: 0031:859A:17E7
status: FF
Boot Done
Initialize ...
flash: 98004900000002:29EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud ...
115200
Set baud Done
ver. sw 1: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001-R1D.BIN
ver. sw 2: 7S7332SA00-001-R1D, 00000000
sim-lock status: unknown
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 25 sec
Old 08-17-2009, 12:44   #790 (permalink)
Member: 93284
Thanks Meter: 202
Orange Vegas Unlock Succesful
module v2.83
Action: unlock
Model: Orange-Vegas
19200 autodetect
CPU: MT6225
chip: 0001:4703:000C
status: FF
Date: 2006.06.14
Version: 1.0
Version: X760_Z15ES_FS_BFFA102
44 byte(s) read
imei: 352353********
connection Ok
157 byte(s) read
reading data...
reading data #4...
writing data...
145 byte(s) read
reading data...
writing data...
verifying...
verification Ok
done
Thanks
The Following User Says Thank You to owiec77 For This Useful Post:
Old 08-17-2009, 13:47   #791 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
COM7 [VCP0] selected
module v2.75
Action: reset settings
19200 autodetect
CPU: MT6226
high speed boot Off
chip: 0031:B1DE:E7D1
Connecting, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: GM699-V01-2008-03-31
Version: D421_05C_HW
detecting structure #2...
done
60 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
building list...
done
items to clear: 197
warning: wrong packet cs
items cleared: 197 of 197
building list...
done
items remains: 0
Finished, time used: 49 sec
The Following User Says Thank You to cel_phon For This Useful Post:
Old 08-18-2009, 11:41   #792 (permalink)
Member: 701779
Sonork: 100.1622334
Thanks Meter: 121
s21 succesfully unlocked nice job infinity
==== log: [8/18/2009 7:00:48 PM] ====
COM8 [VCP1] selected
module v2.83
Device: MyPhone-S21
Action: "sp-unlock"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:32DE:000C
status: FF
Boot Done
Initialize ...
flash: 01227E22202200:2AEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Initialize Done
Set baud ...
115200
Set baud Done
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.B10BF 238.[TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736 _MP_FMCAM-FTP_V0_08.BIN_61396B89].rpl
device-id: B10BF238
ver. sw 1: TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736 _MP_FMCAM-FTP_V0_08.BIN
ver. sw 2: T01_23.07A.W0736.MP.FMCAM-FTP_V0.08, 7694C69E
ffs offset/size: 00800000/00800000
ffs address assigned: 00800000
security area (code #1) check...
security area (code #1) fixed
reading: MyPhone-S21_TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W 0736_MP_FMCAM-FTP_V0_08__ffs...
file saved: C:\Program Files\InfinityBox\MModule\s21 ffs read\MyPhone-S21_TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W 0736_MP_FMCAM-FTP_V0_08__ffs_20090818-191531.B0E.bin
detection procedure, wait...
detection procedure completed
detecting parameters to apply patch area 0/...
Write: area 0/1
area 0/ patch applied Ok
Write ...
Write: eeprom
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\MyPhone-S21_TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W 0736_MP_FMCAM-FTP_V0_08__system_log_B10BF238_61396B89_20090818-192928.B0X.bin
Finished, time used: 1702 sec
The Following User Says Thank You to lorenzo roberto For This Useful Post:
Old 08-18-2009, 12:57   #793 (permalink)
Member: 86448
Sonork: 100.113881
Thanks Meter: 106
ZTE x760 Unlocked :: Big Thanks to Infinity Team
Connected phone to Spider Man with L10C and did in infinity Works Great for Me.
OM21 [VCP0] selected
module  v2.84
Action: unlock
Model: ZTE-X760
19200 autodetect
CPU: MT6225
chip: 0001:6703:0008
status: FF
Date: 2006.06.14
Version: 1.0
Version: X760_Z10DE_GD_B07A105
44 byte(s) read
imei: 35235302981120
connection Ok
157 byte(s) read
reading data...
reading data #2...
writing data...
145 byte(s) read
reading data...
writing data...
verifying...
verification Ok
done
Finished, time used: 13 sec
The Following 2 Users Say Thank You to Sandeep9669 For This Useful Post:
Old 08-18-2009, 13:01   #794 (permalink)
Member: 86448
Sonork: 100.113881
Thanks Meter: 106
Please move post to https://forum.gsmhosting.com/vbb/f296/successfully-unlocked-repaired-phones-infinity-box-725574/
Thanks.
The Following User Says Thank You to Sandeep9669 For This Useful Post:
Old 08-18-2009, 14:37   #795 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
Smile Moto w200(Cdma) Unlock done
Motorolla w200(Cdma) unlock done in infintity. .
for unlock just flash with flex file only
w200_Flex_FFN_A66_1011_022_ChinaUnicom.B2F
Device: Motorola-W200
connection mode: Standard connection
Action: Flash write
"safe mode" enabled
Skip: Firmware
Write: Flex/Customization
Skip: Language pack
Skip: FFS/File system
Skip: Eeprom
Connect...
Phone must be Powered-Off
Connecting, wait...
Connecting, wait...
Connect Done
Initialize...
detecting chip[01]...
flash: 8988C400010001:8988C400000000
flash: Intel I28F320C3B-T T 4Mb
Initialize Done
Set baud...
slowest
Set baud Done
Check parameters...
reading [Motorola-W200_eeprom]...
file saved: C:\Documents and Settings\KK Mobile\Desktop\Motorola-W200_eeprom_20090818-184900.B2E.bin
software version: 2.2.07.
flex version: FFN_A66_0111_036
LP version: LPH_A66_ASIA2_016
hardware version: MOTOROLA_A66
ESN: 1B892605
Check flash...
Check flash Done
Write...
Area: Flex/Customization
Write Done
Finished, time used: 78 sec
The Following User Says Thank You to KK Mobile For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 11.83626 seconds with 10 queries
