Old 08-18-2009, 17:24   #796 (permalink)
sajidashraf's Avatar
Member: 501674
Sonork: THEIF OF HEART
Thanks Meter: 883
Thumbs up c168 unauthorized phone
c168 unauthorized phone ok ........
first write eeprom
then repair eeprom ..
COM4 [VCP0] selected
module v1.32
Device: Motorola-C168
"advanced chip detection" active
Action: flash write
"smart write" active
Skip: Firmware
Skip: Flex
Skip: Language Pack
Skip: FFS/File system
Skip: Images
Skip: Melody
Write: Eeprom
Checking data, wait...
Boot ...
Press Power button now !
loading...
Boot done
Check connection ...
Check connection done
Set baud ...
812500
Set baud done
Check hardware ...
flash: 89886400010001:89886400000000
flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb
software version: 1500-000
software version: TCT-9-
Check hardware done
Read data ...
reading Motorola-C168_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Motorola-C168_eeprom_calibration-1_20090818-211900.69E.bin
reading Motorola-C168_ffs...
file saved: C:\Program Files\InfinityBox\HModule\Motorola-C168_ffs_20090818-211937.69E.bin
Read data done
Check data ...
Check data done
Write ...
Area: Eeprom
Write: Eeprom
Write done
Finished, time used: 77 sec
Remove/Install battery now !
module v1.32
Action: repair
Boot ...
loading...
Boot done
Set baud ...
812500
Set baud done
Check hardware ...
Check hardware done
Read data ...
file saved: C:\Program Files\InfinityBox\HModule\Motorola-C168_eeprom_calibration-1_20090818-212030.69E.bin
Read data done
Check data ...
Check data done
Write ...
......data prepared Ok
Write: eeprom
Write done
Finished, time used: 25 sec
..::S@JID::..
The Following User Says Thank You to sajidashraf For This Useful Post:
Old 08-19-2009, 06:44   #797 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
COM3 [VCP0] selected
Action: format
Device: C261
Connect...
Press and HOLD Power button...
rom version: 0411
Connecting...
initial boot phase complete
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
460800
Set Baud Done
Check Flash-1...
SW version: 0.1.66
HW version: MOTOROLA_E58S
LP ver: LP1_0166
Flex ver: FLEX_90_64_4102
cpu id: 08B6
imei eeprom: 3591970013790352
required SW version: 0.1.66
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _35919700137903_20090819-113712.34E.bin
Check Flash-2 Done
Write...
Write Done
Finished, time used: 87 sec
The Following User Says Thank You to cel_phon For This Useful Post:
Old 08-19-2009, 06:48   #798 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
COM7 [VCP1] selected
module v2.75
Device: Autodetect 6205-6227 NOR
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:1103:0008
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 01227E22202200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
New firmware detected (v.2.75, database date: 21.12.2009):
GINWAVE25_GEMINI_PCB01_GPRS_MT6225_S00.XL-BEETLE_02_V1-1-008_081211.BIN
- make "Read full flash" operation
- send flash backup files to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
identification#1 protocol ver: 04
ver. sw 1: GINWAVE25_GEMINI_PCB01_GPRS_MT6225_S00.XL-BEETLE_02_V1-1-008_081211.BIN
ver. sw 2: XL-BEETLE_02_V1-1-008_081211, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 41 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 08-19-2009, 10:01   #799 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
module v1.69
Device: Huawei-T156
Action: unlock
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-static_20090819-145436.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-security_20090819-145437.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-complete_20090819-145438.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_lock-area_20090819-145442.B1E.bin
backup critical area Done
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 24 sec
Old 08-19-2009, 10:02   #800 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,363
Beetel-EC003 SP Unlock log with MModule 2.84-
module v2.84
Device: Beetel-EC003
Action: "sp-unlock"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:2FBE:000C
status: FF
Boot Done
Initialize ...
flash: 01227E221A2201:2AEA0000000000
flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb
Initialize Done
Set baud ...
115200
Set baud Done
detect device rom info...
detect device rom info finished
rom info structure: 2nd [standard] generation
rom info detection finished
rom info protocol ver: 04
ver. sw 1: BEETEL_EC003_PCB01_GSM_MT6223_S00.KAAEC003_INE_EN_ HI_0_90_501.BIN
ver. sw 2: KAAEC003_INE_En_Hi_0.90.501, 00000000
ffs offset/size: 00320000/000E0000
ffs address assigned: 00320000
detect device sec info...
detect device sec info finished
reading: Beetel-EC003_BEETEL_EC003_PCB01_GSM_MT6223_S00.KAAEC003_I NE_EN_HI_0_90_501__ffs...
file saved: C:\Program Files\InfinityBox\MModule\Beetel-EC003_BEETEL_EC003_PCB01_GSM_MT6223_S00.KAAEC003_I NE_EN_HI_0_90_501__ffs_20090819-141641.B0E.bin
detection procedure, wait...
detection procedure completed
detecting parameters to apply patch area 0...
Write: area 01
area 0 patch applied Ok
Write ...
Write: eeprom
Write Done
Finalization ...
Finalization Done
Finished, time used: 167 sec
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 08-19-2009, 14:49   #801 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
china n72
COM10 [VCP0] selected
module v2.85
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:BFB5:C4D4
status: FF
high speed boot Off
boot packet size: 0002
Boot Done
Initialize ...
flash: 01227E22212200:29EA0000000000
Initialize Done
Set baud ...
115200
Set baud Done
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
New firmware detected (v.2.85, database date: 20.07.2009):
TCL26_05C_PCB01_GPRS_MT6226_S01.N910_26B-ARABIC400_0210.BIN
This firmware is missing in support area. If this phone is good and working:
ver. sw 1: TCL26_05C_PCB01_GPRS_MT6226_S01.N910_26B-ARABIC400_0210.BIN
ver. sw 2: N910_26B-ARABIC400_0210, 00000000
ffs/eeprom chip: 00
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 140 sec
The Following User Says Thank You to ehsas_ghum For This Useful Post:
Old 08-20-2009, 05:26   #802 (permalink)
Member: 655997
Thanks Meter: 9
LG kp110 simcard error,memory card error done
on display appears simcard error and memory card error when power on
cant go to new message and hangs on mp3
use infinity lga module
reset settings/format ffs
==== log: [8/20/2009 11:56:48 AM] ====
COM7 [VCP0] selected
module  v1.39
Device: LG-KP110
Action: read flash
Boot ...
Connecting, wait...
flash: 01227E22212200:FEEA0000000000
Boot Done
Set baud ...
115200
Set baud Done
Check flash ...
current eeprom imei: 352008021525545
file saved: C:\Program Files\InfinityBox\LGA\eeprom_352008021525545_LG-KP110_20090820-115732.B1E.bin
reading _part_1_of_2_352008021525545...
file saved: C:\Program Files\InfinityBox\LGA\kp110 back up\_part_1_of_2_352008021525545_LG-KP110_20090820-121418.B1X.bin
reading _part_2_of_2_352008021525545...
file saved: C:\Program Files\InfinityBox\LGA\kp110 back up\_part_2_of_2_352008021525545_LG-KP110_20090820-123527.B1X.bin
flash: 01227E22212200:F0B0FF00000000
Finished, time used: 2320 sec
WARNING ! Settings will be cleared, user data erased !
Make eeprom backup before this operation !
Continue ?
Testing COM7 at 115200...
==== log: [8/20/2009 12:36:21 PM] ====
module  v1.39
Device: LG-KP110
Action: reset
Boot ...
Connecting, wait...
Boot Done
Set baud ...
115200
Set baud Done
Check flash ...
file saved: C:\Program Files\InfinityBox\LGA\eeprom_352008021525545_LG-KP110_20090820-123657.B1E.bin
reading _eeprom-ffs_352008021525545...
file saved: C:\Program Files\InfinityBox\LGA\kp110 back up\eeprom\_eeprom-ffs_352008021525545_LG-KP110_20090820-124113.B1E.bin
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
Write Done
Finished, time used: 321 sec
The Following User Says Thank You to kevin182029 For This Useful Post:
Old 08-20-2009, 05:47   #803 (permalink)
shahid41's Avatar
Member: 623703
Sonork: 100.1614330
Thanks Meter: 441
zte sfr 231 unlock ok infinitybox
COM5 [VCP0] selected
module v2.84
Device: SFR-231
Action: "sp-unlock"
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
chip: 0001:A403:0002
status: FF
Boot Done
Initialize ...
flash: EC257E25082501:2AEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
Initialize Done
Set baud ...
460800
Set baud Done
ver. sw 1: ZTENJ25_07A_PMJ_PCB01_GPRS_MT6225_S00.FR_SFR_P109B 2V1_0_3B04.BIN
ver. sw 2: FR_SFR_P109B2V1.0.3B04, 00000000
ffs offset/size: 00B00000/00500000
ffs address assigned: 00B00000
reading: SFR-231_ZTENJ25_07A_PMJ_PCB01_GPRS_MT6225_S00.FR_SFR_P 109B2V1_0_3B04__ffs...
file saved: C:\Program Files\InfinityBox\MModule\SFR-231_ZTENJ25_07A_PMJ_PCB01_GPRS_MT6225_S00.FR_SFR_P 109B2V1_0_3B04__ffs_20090820-094111.B0E.bin
Write: area 01
Write ...
Write: eeprom
Write Done
Finalization ...
Finalization Done
Finished, time used: 298 sec
The Following User Says Thank You to shahid41 For This Useful Post:
Old 08-20-2009, 06:46   #804 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
kp105
module v1.66
Device: LG-KP105
Action: reset
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .01 ULC2GL KP105 KP100 P16 00 ARB V10b ARB-XX DEC-27-2007
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP105_eeprom-static_20090819-113249.B1E.bin
loading data...
data loaded
imei: 35996001817000300
reading eeprom-security_35996001817000300...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP105_eeprom-security_35996001817000300_20090819-113250.B1E.bin
reading eeprom-complete_35996001817000300...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP105_eeprom-complete_35996001817000300_20090819-113256.B1E.bin
Check memory ...
Check memory Done
Write ...
reset...
done
Write Done
Finished, time used: 67 sec
Old 08-20-2009, 10:49   #805 (permalink)
adreesas's Avatar
Member: 752606
Sonork: 100.1587361
Thanks Meter: 110
LG KP235 Unlock Successfull
module v1.36
Device: LG-KP235
Action: unlock
unlock method: enhanced
Boot ...
Connecting, wait...
flash: 89881600010001:89881600000000
flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb
Boot Done
Set baud ...
115200
Set baud Done
Check flash ...
current eeprom imei: 352127023943942
file saved: C:\Program Files\InfinityBox\LgA\eeprom_352127023943942_LG-KP235_20090820-154546.B1E.bin
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
write: lock area-1
Write Done
Finished, time used: 35 sec
USMAN COMUNICATIONS CHAKSWARI
0092-3435019287
[email protected]
The Following User Says Thank You to adreesas For This Useful Post:
Old 08-20-2009, 12:30   #806 (permalink)
adreesas's Avatar
Member: 752606
Sonork: 100.1587361
Thanks Meter: 110
LG Kp100 unlocked successfully
module v1.60
Device: LG-KP100
Action: unlock
direct unlock method #2 (Airtel etc.)
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .01 ULC2GL 2008-03-06 1.0 TMO_UK KP100 01 FL 44 V10a 234-30 M
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090820-172007.B1E.bin
loading data...
data loaded
imei: 35847902140834300
reading eeprom-security_35847902140834300...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35847902140834300_20090820-172008.B1E.bin
reading eeprom-complete_35847902140834300...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35847902140834300_20090820-172014.B1E.bin
Check memory ...
Check memory Done
Write ...
Erasing: eeprom-security
Writing: eeprom-security
probably you need to restore original imei after unlock process
Write Done
Finished, time used: 102 sec
USMAN COMUNICATIONS
0092-343-5019287
[email protected]
Old 08-20-2009, 22:13   #807 (permalink)
WILUNLOCK's Avatar
Member: 726741
Thanks Meter: 1,259
modulo v2.84
Action: unlock
Metodo unlock: smart fast
Modelo: ZTE-X761
Checkeando datos, espere...
El Telefono deberia estar APAGADO !
Mantenga Presionado el boton Power !
19200 autodetect
Iniciando [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:2B03:0005
status: FF
Connecting at 19200, wait...
Deje de presionar el boton power ahora !
Telefono detectado, espere...
Hardware: MT6225,E05
Dato: 2006.06.14
Version: 1.0
Version: X761_Z0_S_AFFA106
Version: ZTEMT25_07A_HW_C
44 byte(s) read
imei: 357873022xxxxxx
coneccion Ok
157 byte(s) read
Leyendo datos...
construcción de nuevos datos..
escribiendo datos...
145 byte(s) read
Leyendo datos...
verifying...
verificacion Ok
Listo
Finalizado, tiempo usado: 9 sec
Quite/coloque la bateria ahora !
The Following User Says Thank You to WILUNLOCK For This Useful Post:
Old 08-21-2009, 06:31   #808 (permalink)
Member: 406299
Sonork: none
Thanks Meter: 280
torque D90 read lock code by infinity
pin out
Rx:7 Tx:8
logs
COM11 [VCP0] selected
module v2.89
Action: read codes
unlock method: read codes
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6225
high speed boot On
chip: 0001:ED03:000C
status: FF
Phone detected, wait...
Date: 2006.06.14
Version: 1.0
Version: BM587.COMP_MCP.TORQUE.08
Version: HEXING25_GEMINI_HW
detecting structure #2...
5 11 done
67 byte(s) read
imei: 35358045001472
connection Ok
detecting structure #1...
1 5 8 9 10 12 13 14 done
178 byte(s) read
reading data #2...
Phone lock: On
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 1922
Finished, time used: 18 sec
The Following User Says Thank You to JMJ ALBERT For This Useful Post:
Old 08-21-2009, 10:26   #809 (permalink)
Member: 130995
Thanks Meter: 35,228
Originally Posted by albertprimoblan View Post
pin out
Rx:7 Tx:8
logs
module v2.89
Action: read codes
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
5 11 done
67 byte(s) read
connection Ok
178 byte(s) read
reading data #2...
Phone lock: On
Network lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 1922
Hello,
Thanks for good test report !
What is this phone connector type ?
How many pins ?
Old 08-21-2009, 13:22   #810 (permalink)
Member: 695023
Thanks Meter: 53
lg kp130 unlock done
i love my infinity...
COM1 selected
module v1.38
Device: LG-KP130
Action: unlock
Boot ...
Connecting, wait...
Boot Done
Set baud ...
115200
Set baud Done
Check flash ...
current eeprom imei: 352126023658153
file saved: C:\Program Files\InfinityBox\LGA\eeprom_352126023658153_LG-KP130_20090821-200446.B1E.bin
version: -
Check flash Done
Check space ...
finalization done
Check space Done
Erase ...
Erase Done
Write ...
write: lock area-1
Write Done
Finished, time used: 61 sec
The Following User Says Thank You to ACID_ICED For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 13.19526 seconds with 10 queries
