Old 02-14-2011, 11:35   #8866 (permalink)
.::AZEEM::.'s Avatar
Member: 336212
Sonork: 100.1585000
Thanks Meter: 4,912
TS352F08Apr 23 2010
LG RD-3520 version 8 selected..
offline..
downloading mode..
sending boot..
patching in progress..
patching in progress 50%..
patching in progress 100%..
Done..
Finished, time used: 30 sec
The Following 2 Users Say Thank You to .::AZEEM::. For This Useful Post:
Old 02-14-2011, 11:47   #8867 (permalink)
gsmpointhrp's Avatar
Member: 416286
Sonork: 100.1622339
Thanks Meter: 759
COM6 [VCP4] selected
module v3.74
Device: Virgin-VM621i
Checking data, wait...
Action: rebuild security area
====> Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:E103:A005
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC240200000000:08EA0000000000
flash: Samsung K5L2833ATA T 16Mb
otp offset: 00FF0000
Initialize Done
====> Set baud ...
460800
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
search rom info finished
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.7D79E 63D.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_A9B8E7D8].rpl
New firmware found (v.3.74, database date: 11.02.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 7D79E63D
rom info ver: 05
sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN
project-id: MAUI.06B.W07.28.SP1.V38, D8E7B8A9
code offset: 00020000
ffs offset/size [01]: 00C00000/00400000
TCL-ID identification
version: 269
provider: 600X-2EVRGB1
customization: CJ26CW10
customization: XJ26CW10
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 00C00000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRD_COMMUNICATION_B82X_PRODUCTS
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is invalid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, cust) calculation...
error: security area (sec info, cust) header is invalid
security area (sec info, hash) calculation...
version is not found in database: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN
use default security area (sec info, hash) pattern
max address is too big, should be recalculated: 08BF8000->00006F54
error: can not recalculate address range, allowed offset is too small: 00006F54
error: can't calculate security area (sec info, hash)
identification header detected
customization name adjusted
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
max address is too big, should be recalculated: 08BF8000->08BF4004
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: FFFFFFFFFFFFFF
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Virgin-VM621i_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W0 7_28_SP1_V38__system_log_7D79E63D_A9B8E7D8_2011021 3-154726.B0X.bin
Finished, time used: 3 min 27 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following 2 Users Say Thank You to gsmpointhrp For This Useful Post:
Old 02-14-2011, 12:01   #8868 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
Thanks Meter: 382
Nokia E5 RM-632 Full flash done in one minute
Connect phone on selected interface...
Phone found!
Series 60 Device detected!
read info...  - Ok
Reading Phone Info....
Connected phone -    Nokia E5-00
Software ver : V ICPR82_10w18.13 16-07-10 RM-632 (c) Nokia
IMEI    :      35485904******
Ape Ver :      042.007
APE Var :      042.007042.007.23.01042.007.310.01
APE ADSP:      256
DSP Ver :       ICPR82_10w18.6
APE Test:      0.025
PPM     :
CNT     :
Product SN   :     0E3526FAA
Product code :     059C8R5
Base Prd.code:     0590165
Module code  :     0204475
Long Prod.SN :     0
Hardware info=======
HWID  : 3002
Retu  : 35
Tahvo : 00
Batery: 4694 mV
Camera:
CMT BT:
APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.
APE HW: 256
LCDVer:
RF ic :
Lock info ===========
IMEI       : 3548590********
IMEI spNet : 3A 45 58 09 84 75 80 06
IMEI svNet : 33 45 58 09 84 75 80 06 F7
Conf key     : 0000000000000000
Provider key : 2440700000000000
Provider    : AT&T;U.S.A. (3650)
Counters   : Key 0  [3] , Fbus 0  [10]
Blocks      : 7
LOCK STATUS :
BLK : 1
 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS :  All Open
CRT308 Backup Created... :)
User code : Crypted
UserDataExLevel : Low [Gallery]
Done!
Core version : 1.16 , Rev : 2.1
Selected FlashSettings : FullFlash
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm632_042.010_prd.core.fpsx
PPM : rm632_042.010_23.01_Baltian_QW2_prd.rofs2.fpsx
PPM2 : rm632_042.010_C00.01_DEFAULT_prd.rofs3.fpsx
CNT : rm632_042.010_U005.000_prd.uda.fpsx
Flashing phone now...
Check files done...
->  Check SW version...
FlashFile version : 042.010
Phone version : 042.007
->  Check SW version : Upgrade
Backup CRT308 data...
Check communication with phone....
ADL req restart
Communication verify done... Preparing...
Gathering phone info...
Reboot....
Connection opened successfully
Waiting for communication response...
[BB5 FLASH]: Bootrom Ok!
ASIC ID:       000000030000022600010007600C192102031104
EM0 ID:        00000C35
EM1 ID:        00000C30
PUBLIC ID:     1D70001469A20344C9C7C15CD4FBE65A85B37606
ASIC MODE ID:  00
ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
ROM ID:        E693EF0DAC22615B
Use RAPUv11_2nd.fg  ,  Rev : 3.0  Ver : 10.50.0
Processing RAWLOADER...
FLIC : 005000EC
Req : XSR 1.6
Use RAPUv11_XSR17_alg.fg  ,  Rev : 3.0  Ver : 10.50.0
Boot Done! :)
TIME : Boot time : 00:00:01
Reopening the connection...
Waiting for response: 30
ADL: Check mode
Select ASIC [C900]
ADL: phone is in flash mode
Backup enabled, will read all certificates...
Reading NPC certificate...
Reading CCC certificate...
Reading HWC certificate...
Reading R&D certificate...
Reading VARIANT certificate...
Cert Read done!
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
SimLock Data saved...
SimLock Key saved...
WMDRM_PD Data saved...
RPL saved : C:\Documents and Settings\Gsm-Unlimited\Desktop\GSM\Nokia\BEST_v1.15\Backup\Cert\354859048570866.rpl
   ===Flashing [MCU]===
Erase : Processing rm632_042.010_prd.core.fpsx
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:01
Write : Processing rm632_042.010_prd.core.fpsx
CMT: Writing Hash CERT [ADA]
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [RAP3NAND]
CMT: Writing Hash CERT [SOS+PMML]
CMT: Writing Hash CERT [PASUBTOC]
CMT: Writing Hash CERT [PAPUBKEYS]
CMT: Writing Hash CERT [GENIO_INIT]
CMT: Writing Hash CERT [SOS*UPDAPP]
CMT: Writing Hash CERT [SOS*DSP0]
CMT: Writing Hash CERT [LDSP]
CMT: Writing Hash CERT [SOS*ISASW]
CMT: Writing Hash CERT [SOS+CORE]
CMT: Writing Hash CERT [SOS+ROFS1]
Total writen 424 blocks
TIME : Write time : 00:00:15
MCU Write done
ADL: Request programm status
NAND status : 00000003 / 00000003 / 00000000
   ===Flashing [PPM]===
Erase : Processing rm632_042.010_23.01_Baltian_QW2_prd.rofs2.fpsx
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:00
Write : Processing rm632_042.010_23.01_Baltian_QW2_prd.rofs2.fpsx
CMT: Writing Hash CERT [SOS+ROFS2]
Total writen 267 blocks
TIME : Write time : 00:00:10
PPM Write done
   ===Flashing [PPM2]===
Erase : Processing rm632_042.010_C00.01_DEFAULT_prd.rofs3.fpsx
Erasing....
Erasing Ok...
Write : Processing rm632_042.010_C00.01_DEFAULT_prd.rofs3.fpsx
CMT: Writing Hash CERT [SOS+ROFS3]
Total writen 32 blocks
TIME : Write time : 00:00:01
PPM Write done
   ===Flashing [CNT]===
Erase : Processing rm632_042.010_U005.000_prd.uda.fpsx
Erasing....
Erasing Ok...
Write : Processing rm632_042.010_U005.000_prd.uda.fpsx
Total writen 87 blocks
TIME : Write time : 00:00:04
CNT Write done
ADL: Close_Session
Content: 000300000000030000000300000000
ADL: Reboot
Flashing done!
Total flash time : 00:00:34
Reboot phone now...
Software Info:     V ICPR82_10w18.16 27-08-10 RM-632 (c) Nokia
IMEI:  35485*************
Ape Version: 042.010
Product code:  059C8R5
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Settings After Flash Defaults...
FullFactorySet...OK!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Product code update...
Set phone to Normal mode...
AfterFlash operations done...
Done!
Elapsed: 00:01:00
Phone found!
read info...  - Ok
The Following 4 Users Say Thank You to fun For This Useful Post:
Old 02-14-2011, 12:15   #8869 (permalink)
Member: 587940
Thanks Meter: 8
1800 death condition and Done by BEST_v1.15
UFS S/N 7xxxx boot - Ok
Selected FlashSettings : Manual
MCU : rm653_005.800
PPM : rm653_005.80me
CNT : rm6530_nai05.80me_nlt
Infineon flashing...
Booting phone now....
Sync Ok , A2
CPU ID : XGOLD , A200341100
Boot Ok , 01
PBL : SE0_091125 F11
Algo Ok , 01
SBL mode Ok
SBL : Default_RAM_Bootloader
EPP CFG [Bering]...
FLASH ID : 00EC000000542200
FLASH ID : Samsung, K8S6415E
Boot Done!
File : rm653_005.800
Image : hw_b2_rm653_r05.800.fls
Cert block found, sending....
Cert sent
Found 3 region(s)
Processing Region 1/3
Erase , Start : 0x00800000 , Len : 0x00210000
Erasing, wait ...
Erase done
Write , Start : 0x00800000 , Len : 0x00210000
Flashing , wait ...
Region flash done
Processing Region 2/3
Erase , Start : 0x00C60000 , Len : 0x00208CC0
Erasing, wait ...
Erase done
Write , Start : 0x00C60000 , Len : 0x00208CC0
Flashing , wait ...
Region flash done
Processing Region 3/3
Erase , Start : 0x00FFC000 , Len : 0x00000040
Erasing, wait ...
Erase done
Write , Start : 0x00FFC000 , Len : 0x00000040
Flashing , wait ...
Region flash done
Check : 074E
File : rm653_005.80me
Image : hw_b2_rm653_005.80me.fls
Cert sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x00210000 , Len : 0x001F0A80
Erasing, wait ...
Erase done
Write , Start : 0x00210000 , Len : 0x001F0A80
Flashing , wait ...
Region flash done
Check : F994
File : rm6530_nai05.80me_nlt
Image : hw_b2_rm6530_nai05.80me_nlt.fls
Cert sent
Found 1 region(s)
Erase , Start : 0x00EB0000 , Len : 0x0008CB80
Erasing, wait ...
Erase done
Write , Start : 0x00EB0000 , Len : 0x0008CB80
Flashing , wait ...
Region flash done
Check : 554E
Flashing done, rebooting...
-> Infineon info : Do FullFactory Sets after flashing
Flashing Done!
Init Service mode... Wait...
Afterflash settings...
SW ver : V 05.80
06-08-10
RM-653
(c) Nokia
IMEI : 353412048452056
PCode : 0594913
All done!
Phone found!
Series 40 Device detected!
read info... - Ok
Phone found!
read info... - Ok
SW ver : V 05.80 06-08-10 RM-653 (c) Nokia
PPM : V 05.80
06-08-10
RM-653
(c) Nokia
ME
PCode : 0594913
BPCode : 059C7R8
HWID : 2007
LCDVer : INNO:BOHAIv93
NT39121
Sl Conf : 001-01-00000000000
Sl Prof : 000000000003000-2
Sl Aux : 000B0000
Hw Sig : 60AA64801883D749
Provider : Default Test Operator
Lock info:
Block 1
L1:Open; L2:Open; L3:Open; L4:Open; L5:Open;
Block 2
Block 3
Block 4
Block 5
Block 6
Block 7
Done!
Resetting User Code to default (12345)...
Code reset done, now it 12345
Done
Resetting selected items...
Check phone mode...
Phone in Local mode
Seting Test mode... wait...
Test mode set
Settings Full Factory Defaults...
Set OK!
Elapsed: 00:00:08
Phone disconected!
The Following 4 Users Say Thank You to agselfira For This Useful Post:
Old 02-14-2011, 12:21   #8870 (permalink)
ahmadge's Avatar
Member: 603971
Thanks Meter: 730
Wink C5 flash done.
MCU : rm645_061.005_prd.core.fpsx
PPM : rm645_061.005_01.01_Euro1_prd.rofs2.fpsx
PPM2 : rm645_061.005_201.02_Swisscom_CH_prd.rofs3.fpsx
CNT : rm645_ENO_v_0.NCP17_APEONLY.fpsx
APE : rm645_061.005_U000.000_prd.uda.fpsx
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
--- Insert cable and charger or press phone's power button! ---
EM0 ID:        00000C35
EM1 ID:        00000C30
PUBLIC ID:     17600211B2A40344E5C2F1AF9A510A94F95F8F25
ASIC MODE ID:  00
FLIC : 00400020
Req : XSR 1.6
Boot Done! :)
Waiting for response: 29
ADL: Check mode
Select ASIC [C900]
IMEI : 354847042968491
Cert Read done!
RPL saved : M:\Infinity Best\BEST_v1.15\BEST_v1.15\Backup\Cert\354847042968491_CRT.rpl
Erase : Processing rm645_061.005_prd.core.fpsx
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
Write : Processing rm645_061.005_prd.core.fpsx
Total writen 393 blocks
MCU Write done
NAND status : 00000001 / 00000001 / 00000000
Erase : Processing rm645_061.005_01.01_Euro1_prd.rofs2.fpsx
Erasing....
Erasing Ok...
Write : Processing rm645_061.005_01.01_Euro1_prd.rofs2.fpsx
Total writen 177 blocks
TIME : Write time : 00:00:07
PPM Write done
Erase : Processing rm645_061.005_201.02_Swisscom_CH_prd.rofs3.fpsx
Erasing....
Erasing Ok...
Write : Processing rm645_061.005_201.02_Swisscom_CH_prd.rofs3.fpsx
Total writen 41 blocks
PPM Write done
Erase : Processing rm645_ENO_v_0.NCP17_APEONLY.fpsx
Erasing....
Erasing Ok...
Write : Processing rm645_ENO_v_0.NCP17_APEONLY.fpsx
CMT: Writing Hash CERT [SOS*ENO]
Total writen 11 blocks
TIME : Write time : 00:00:00
CNT Write done
   ===Flashing [APE]===
Erase : Processing rm645_061.005_U000.000_prd.uda.fpsx
Erasing....
Erasing Ok...
Write : Processing rm645_061.005_U000.000_prd.uda.fpsx
Total writen 8 blocks
APE Write done
ADL: Close_Session
Content: 000300000000010000000100000000
ADL: Reboot
Flashing done!
Total flash time : 00:00:28
{Ahmadge}
The Following 3 Users Say Thank You to ahmadge For This Useful Post:
Old 02-14-2011, 12:21   #8871 (permalink)
danrachita's Avatar
Member: 428861
Sonork: 100.1619141
Thanks Meter: 1,629
K220i
Sonny Ericsson K220i succesfully unlocked.
Thank you Infinity Team.
BR.
COM65 [VCP0] selected
module v1.38
Device: Sony-Ericsson-K220i
"advanced chip detection" active
Action: unlock
Boot ...
Press Power button now !
loading...
Boot done
Check connection ...
Check connection done
Set baud ...
406250
Set baud done
Check hardware ...
flash: 01227E22212200:92EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
software version: R1AD001
software version: CXC1251013
version flex: CDA102807/43
imei: 352434023581xxxCheck hardware done
Read data ...
reading Sony-Ericsson-K220i_35243402358xxx_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35243402358181_eeprom_calibration-1_20110214-130858.80E.bin
reading Sony-Ericsson-K220i_35243402358xxx_eeprom_calibration-2...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35243402358xxx_eeprom_calibration-2_20110214-130904.80E.bin
Read data done
Check data ...
Check data done
Write ...
flash: 01227E22212200:46237300000000
Write: eeprom
Write: eeprom
locks cleared
Write done
Finished, time used: 36 sec
The Following 2 Users Say Thank You to danrachita For This Useful Post:
Old 02-14-2011, 12:24   #8872 (permalink)
danrachita's Avatar
Member: 428861
Sonork: 100.1619141
Thanks Meter: 1,629
K220i
BR.
module v1.38
Action: unlock
Boot ...
loading...
Boot done
Set baud ...
406250
Set baud done
Check hardware ...
software version: R1AB003
version flex: CDA102773/58
imei: 35871701209xxx
Check hardware done
Read data ...
reading Sony-Ericsson-K220i_35871701209xxx_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35871701209177_eeprom_calibration-1_20110214-132240.80E.bin
reading Sony-Ericsson-K220i_35871701209xxx_eeprom_calibration-2...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35871701209xxx_eeprom_calibration-2_20110214-132245.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: eeprom
Write: eeprom
locks cleared
Write done
Finished, time used: 49 sec
Old 02-14-2011, 14:55   #8873 (permalink)
d.jain's Avatar
Member: 670629
Sonork: 100.1590208
Thanks Meter: 431
COM12 [VCP1] selected
module v1.44
Device: Huawei-C2906
operation: SP-unlock
Phone should be Switched ON !
connecting...
checking version...
C2906C53B108
C2906C53B108
Huawei C2906 version B108 selected..
OFFLINE...
downloading mode...
erasing...
patching in progress...
patching in progress 20%...
patching in progress 40%...
patching in progress 60%...
patching in progress 80%...
patching in progress 100%...
DONE...
Phones should be restarting now...
Finished, time used: 59 sec
The Following 2 Users Say Thank You to d.jain For This Useful Post:
Old 02-14-2011, 15:38   #8874 (permalink)
sonu arya's Avatar
Member: 559113
Sonork: 100.1596477
Thanks Meter: 760
Huawei c2900i unlock done ..
COM1 [VCP0] selected
module v1.44
Device: Huawei-C2900I
connecting...
OFFLINE...
disable minlock...
Finished, time used: 5 sec
The Following 2 Users Say Thank You to sonu arya For This Useful Post:
Old 02-14-2011, 15:40   #8875 (permalink)
d.jain's Avatar
Member: 670629
Sonork: 100.1590208
Thanks Meter: 431
COM26 [QCUSB_COM26_1] selected
module v1.44
Device: ZTE-S100
connecting...
OFFLINE...
send spc...
disabling minlock...
Done...
Finished, time used: 6 sec
Old 02-14-2011, 16:37   #8876 (permalink)
sonu arya's Avatar
Member: 559113
Sonork: 100.1596477
Thanks Meter: 760
LG RD3510 Blink done ..
QSC6010-RD3510
QSC6010-RD3510
LG RD3510 selected..
erasing...
done....
Finished, time used: 29 sec
Old 02-14-2011, 17:04   #8877 (permalink)
Member: 633231
Thanks Meter: 666
COM8 [VCP4] selected
module v1.38
Device: Alcatel-E201
Action: user code
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Set baud ...
115200
Set baud done
Check hardware ...
flash: 012A7E2A242A00:54000000000000
flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb
Check hardware done
Read data ...
reading Alcatel-E201_eeprom_calibration-1...
file saved: C:\Archivos de programa\InfinityBox\HModule\Alcatel-E201_eeprom_calibration-1_20110214-000028.80E.bin
reading Alcatel-E201_ffs...
file saved: C:\Archivos de programa\InfinityBox\HModule\Alcatel-E201_ffs_20110214-000153.80E.bin
Read data done
Check data ...
pass-1...
pass-2...
Check data done
Write ...
Write: ffs
Write done
Finished, time used: 1436 min 40 sec
The Following 2 Users Say Thank You to thewolverine For This Useful Post:
Old 02-15-2011, 05:40   #8878 (permalink)
naveedbutt's Avatar
Member: 1015336
Sonork: 100.1608410
Thanks Meter: 813
motorola f3 unlock ok
COM4 [VCP0] selected
Loading data, wait...
Device: F3
Press and Hold Power button...
rom version: 0502
Connecting...
booting...
finalizing...
working, one more step...
flash: 0020:8824
Finished, time used: 45 sec
The Following 2 Users Say Thank You to naveedbutt For This Useful Post:
Old 02-15-2011, 05:59   #8879 (permalink)
Member: 583468
Sonork: 100.1592004
Thanks Meter: 106
Sucessfully Unlock Vodafone-226FM
module v1.78
Device: Vodafone-226FM
Action: "sp-unlock"
unlock method-1
Boot ...
e-gold: 820010
loading...
middle part...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
sw version: 8 EDI_IF EDI_IF_040108_1352 040108_1352 Thhmm Dddmmmyyyy 0123
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-static_20110215-102144.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-security_20110215-102145.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-complete_20110215-102150.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_lock-area_20110215-102156.B1E.bin
backup critical area Done
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 56 sec
The Following 2 Users Say Thank You to jmzboudh For This Useful Post:
Old 02-15-2011, 07:00   #8880 (permalink)
ahmadge's Avatar
Member: 603971
Thanks Meter: 730
Wink 1800 Flash Done.
MCU : rm653_005.050
PPM : rm653_005.05ia
CNT : rm6530_nai05.05ia
Sync Ok , A2
Boot Ok , 01
Algo Ok , 01
SBL mode Ok
EPP CFG [Bering]...
Boot Done!
File : rm653_005.050
Image : hw_b2_rm653_r05.050.fls
Cert sent
Found 3 region(s)
Erasing, wait ...
Erase done
Flashing , wait ...
Region flash done
Erase , Start : 0x00C60000 , Len : 0x00206080
Erasing, wait ...
Erase done
Write , Start : 0x00C60000 , Len : 0x00206080
Flashing , wait ...
Region flash done
Erasing, wait ...
Erase done
Flashing , wait ...
Region flash done
Check : 86ED
File : rm653_005.05ia
Image : hw_b2_rm653_005.05ia.fls
Cert sent
Found 1 region(s)
Erase , Start : 0x00210000 , Len : 0x001F3780
Erasing, wait ...
Erase done
Write , Start : 0x00210000 , Len : 0x001F3780
Flashing , wait ...
Region flash done
Check : F00B
File : rm6530_nai05.05ia
Image : hw_b2_rm6530_nai05.05ia.fls
Cert sent
Found 1 region(s)
Erase , Start : 0x00EB0000 , Len : 0x00052B00
Erasing, wait ...
Erase done
Write , Start : 0x00EB0000 , Len : 0x00052B00
Flashing , wait ...
Region flash done
Check : E8AC
Flashing Done!
SW ver : V 05.05
24-05-10
RM-653
(c) Nokia
IMEI   : 3527070*******
PCode  : 0594990
SwUpgradeSet...OK!
All done!
{Ahmadge}
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.68562 seconds with 10 queries
