Old 02-15-2011, 07:05   #8881 (permalink)
niloy2007's Avatar
Member: 1426012
Sonork: ICQ#618627674
Thanks Meter: 886
nokia 5130 nokia with whit display successfull with low formate
card found: S/N 0000:00000
registered to: PAUL-TELECOME
Connect phone on selected interface...
UFS S/N 000000 boot - Ok
User confirm Format
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT ASICID : 000000010000022600010006030C192101033000
CMT EM0 ID : 00000296
CMT EM1 ID : 00000B22
CMT PUB ID : 0ED001049F2E7F56F78FA0FB10B586E4BDD55826
CMT MODE ID : 00
CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROM ID : 273F6D55DFAAF68F
CMT : Sending 2nd loader...
Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0
CMT Loader sent, Boot Ok
MCU Configuration
FLASHID : 89820089 , CMT , NOR
CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512
FLCNT : 00000000000000000000000000000000000000
FLASHID : 0000FFFF , CMT , MMC , EXT
CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok
Sending ALGO....
Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0
CMT Algo sent
CMT PAPUB : 917F11196FDB7378C18EF7260698CA4489DCA02700
Transmission mode : Dual (Ddr, TX2)
Boot Done!
Erase User Area now, Selected model : RM-495, 5130
Using TimeOut : 5 min ( 300 sec )
Erasing, wait.....
CMT : Format Ok
UserArea format done
Phone found!
Series 40 Device detected!
read info... - Ok
Core version : 1.16 , Rev : 2.1
Selected FlashSettings : Manual
Files Set for Flashing :
MCU : rm495__07.97.mcusw
PPM : rm495__07.97.ppm_qa
CNT : rm495__07.97.image_qa_blu
Check FlashFiles, Please, wait...
-> Check SW version...
FlashFile version : 07.97
Phone version : 07.97
13-09-10
RM-495
(c) Nokia
-> Check SW version : Reflash
Backup enabled, Will read Certificates now...
CRT308 Backup Created...
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
Sending ALGO....
Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1
CMT Algo sent
Boot Done!
CMT : Read NPC certificate...
Cert size : 20480 byte(s)
IMEI : 355246034520395
CMT : Read CCC certificate...
Cert size : 30600 byte(s)
CMT : Read HWC certificate...
CMT : Read VARIANT certificate...
Cert size : 0 byte(s)
Cert Read done!
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
SimLock Data saved...
SimLock Key saved...
WMDRM_PD Data saved...
RPL saved : C:\BEST_v1.15\Backup\Cert\355246034520395_2nd.rpl
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
Sending ALGO....
CMT Algo sent
Boot Done!
Erase : Processing rm495__07.97.mcusw
Found 6 areas to erase, erase group
Asic : CMT , Sub : NOR
CMT , NOR , Area : 0x00000000 - 0x000006BF
CMT , NOR , Area : 0x000006C0 - 0x0001FFFF
CMT , NOR , Area : 0x00040000 - 0x000BFFFF
CMT , NOR , Area : 0x000C0000 - 0x0013FFFF
CMT , NOR , Area : 0x00140000 - 0x0137FFFF
CMT , NOR , Area : 0x01380000 - 0x0151FFFF
Erasing, wait.....
CMT : Group erase Ok
TIME : Erase time : 00:01:37
Write : Processing rm495__07.97.mcusw
CMT: Writing Hash CERT [NOLO]
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [PASUBTOC]
CMT: Writing Hash CERT [PAPUBKEYS]
CMT: Writing Hash CERT [UPDAPP]
CMT: Writing Hash CERT [DSP0]
CMT: Writing Hash CERT [MCUSW]
Total writen 1169 blocks
TIME : Write time : 00:02:30
Erase : Processing rm495__07.97.ppm_qa
Found 1 areas to erase, erase group
CMT , NOR , Area : 0x01520000 - 0x01DBFFFF
Erasing, wait.....
TIME : Erase time : 00:00:39
Write : Processing rm495__07.97.ppm_qa
Total writen 471 blocks
TIME : Write time : 00:00:59
ConvertImage: Processing rm495__07.97.image_qa_blu
ConvertImage: Page Size is 128K, no need convert
Erase : Processing rm495__07.97.image_qa_blu
Found 2 areas to erase, erase group
CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF
CMT , NOR , Area : 0x02160000 - 0x03FBFFFF
Erasing, wait.....
TIME : Erase time : 00:00:32
Write : Processing rm495__07.97.image_qa_blu
Total writen 720 blocks
TIME : Write time : 00:01:30
Init Service mode... Wait...
Reading Phone Info....
Connected phone - Nokia 5130c-2
Software Info: V 07.97
13-09-10
RM-495
(c) Nokia
IMEI: 355246034520395
Product code: 0585577
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Settings After Flash Defaults...
FullFactorySet...OK!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Checking User Certificates...
Total - 0 certs
Uploading certificates...
Error write : Baltimore CyberTrust Mobile Root
Writen 20 certs!
AfterFlash operations done... Reconnect, wait...
Phone found!
read info... - Ok
The Following 3 Users Say Thank You to niloy2007 For This Useful Post:
Old 02-15-2011, 07:49   #8882 (permalink)
niloy2007's Avatar
Member: 1426012
Thanks Meter: 886
7210 success fully revove contact service
card found: S/N 00000:000000
Phone found!
read info... - Ok
MCU : rm436__07.23.mcusw
PPM : rm436__07.23.ppm_mr
CNT : rm436__07.23.image_mr
FlashFile version : 07.23
Phone version : 05.60
10-12-08
RM-436
(c) Nokia
-> Check SW version : Upgrade
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT EM0 ID : 00000295
CMT PUB ID : 0FD0001237407D5612D9A8093853693745AA5915
CMT MODE ID : 00
MCU Configuration
Sending ALGO....
CMT Algo sent
CMT PAPUB : DCA5EA5203CD30A64D4D95ABCD621F4AB23026F100
Boot Done!
IMEI : 353180036949355
Cert Read done!
RPL saved : C:\BEST_v1.15\Backup\Cert\353180036949355.rpl
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
Sending ALGO....
CMT Algo sent
Boot Done!
Erase : Processing rm436__07.23.mcusw
CMT , NOR , Area : 0x00140000 - 0x0119FFFF
CMT , NOR , Area : 0x011A0000 - 0x0133FFFF
Erasing, wait.....
TIME : Erase time : 00:01:07
Write : Processing rm436__07.23.mcusw
Total writen 1161 blocks
TIME : Write time : 00:02:27
Erase : Processing rm436__07.23.ppm_mr
CMT , NOR , Area : 0x01340000 - 0x01BDFFFF
Erasing, wait.....
TIME : Erase time : 00:00:27
Write : Processing rm436__07.23.ppm_mr
Total writen 454 blocks
TIME : Write time : 00:00:56
CNT : Converted to 128k page data exist
Erase : Processing rm436__07.23.image_mr_128
CMT , NOR , Area : 0x01BE0000 - 0x01F7FFFF
CMT , NOR , Area : 0x01F80000 - 0x03FBFFFF
Erasing, wait.....
TIME : Erase time : 00:03:32
Write : Processing rm436__07.23.image_mr_128
Total writen 532 blocks
TIME : Write time : 00:01:05
Connected phone - Error
Software Info: Error
IMEI: Error
Product code: Error
Checking...
Security status : Security Damaged!!!!!
Read Info Done!
SwUpgradeSet...OK!
Product code update...
Resetting LifeTimer
Reset Done!
Total - 0 certs
Writen 21 certs!
Phone found!
read info... - Ok
Read Uniq key data started...
Phone Imei: 353180036949355
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
Key file updated...
Done!
Repair SD procedure started...
Key file exists, no need to read...
Operating mode is OK, no need change...
Writing Super Dongle Key... Ok
Done!
Repair SL procedure started...
Writing SimLock Data... Ok
Writing SimLock Key... Ok
Done!
Local SX4 procedure started...
Step 1...
Step 2...
Step 3...
SX4 Auth - Ok
Done!
Uploading RF/Battery tune to phone...
Using : RM-436.pm
Field 1
Record 0 write - Ok
Record 2 write - Ok
Record 3 write - Ok
Record 4 write - Ok
Record 6 write - Ok
Record 7 write - Ok
Record 10 write - Ok
Record 11 write - Ok
Record 14 write - Ok
Record 17 write - Ok
Field 309
Record 0 write - Ok
Record 1 write - Ok
Record 2 write - Ok
Record 4 write - Ok
Record 5 write - Ok
Record 7 write - Ok
Record 8 write - Ok
Record 22 write - Ok
Check ST_SECURITY now...
Security status : ST_SECURITY => OK
Done!
Elapsed: 00:00:03
The Following 4 Users Say Thank You to niloy2007 For This Useful Post:
Old 02-15-2011, 08:24   #8883 (permalink)
joni_rajpura's Avatar
Member: 508072
Thanks Meter: 1,621
COM3 [VCP3] selected
module v1.73
Device: LG-KP106
Checking data, wait...
Action: reset settings ("format ffs")
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .01 ULC2GL INDIA OPEN KP106b KP106b 00 91 V10c 404-XX MAY-0
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP106_eeprom-static_20110215-125349.B1E.bin
loading data...
wrong database file: C:\Program Files\InfinityBox\Pana01\lge_gb3a_eep65535.cfg
error: can't load database v.0
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP106_eeprom-security_20110215-125349.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP106_eeprom-complete_20110215-125350.B1E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
reset...
done
Write Done
Finished, time used: 33 sec
Remove/Install battery now !
The Following 4 Users Say Thank You to joni_rajpura For This Useful Post:
Old 02-15-2011, 08:41   #8884 (permalink)
Member: 508072
Thanks Meter: 1,621
module v1.44
Device: Huawei-C2906
operation: SP-unlock
Phone should be Switched ON !
connecting...
checking version...
C2906C53B108
C2906C53B108
Huawei C2906 version B108 selected..
OFFLINE...
downloading mode...
erasing...
patching in progress...
patching in progress 20%...
patching in progress 40%...
patching in progress 60%...
patching in progress 80%...
patching in progress 100%...
DONE...
Phones should be restarting now...
Finished, time used: 56 sec
Old 02-15-2011, 08:46   #8885 (permalink)
OTIENOJULIUS's Avatar
Member: 898387
Sonork: 1000.2
Thanks Meter: 103
.....we hi the top and bottom.................we are universal!
infinity is simply the best coz it leads the leaders!
The Following User Says Thank You to OTIENOJULIUS For This Useful Post:
Old 02-15-2011, 09:22   #8886 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
2700с, flashing
Phone found!
read info...  - Ok
MCU : rm561__09.97.mcusw
PPM : rm561__09.97.ppm_el
CNT : rm561__09.97.image_el_red
FlashFile version : 09.97
Phone version : 07.80
18-08-09
RM-561
(c) Nokia
CRT308 Backup Created... :)
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT PUB ID  : 1E80011454DE8C56CE5F26D685543744CBB7130A
CMT MODE ID : 00
MCU Configuration
Sending ALGO....
CMT Algo sent
CMT PAPUB : A22A1DDA660002E56108DB5072A10F8709443FA800
Boot Done!
IMEI : 351501040384804
Cert Read done!
RPL saved C:\v1.15.2\Backup\Cert\351501040384804_2nd.rpl
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
Sending ALGO....
CMT Algo sent
Boot Done!
Erase : Processing rm561__09.97.mcusw
Erasing, wait.....
TIME : Erase time : 00:01:35
Write : Processing rm561__09.97.mcusw
Total writen 1247 blocks
TIME : Write time : 00:02:19
Erase : Processing rm561__09.97.ppm_el
Erasing, wait.....
Write : Processing rm561__09.97.ppm_el
Total writen 327 blocks
TIME : Write time : 00:00:35
ConvertImage: Processing rm561__09.97.image_el_red
Erase : Processing rm561__09.97.image_el_red
Erasing, wait.....
TIME : Erase time : 00:03:51
Write : Processing rm561__09.97.image_el_red
Total writen 688 blocks
TIME : Write time : 00:01:13
Connected phone -   Nokia 2700 classic
Software Info:     V 09.97
18-06-10
RM-561
(c) Nokia
IMEI:  351501040384804
Product code:  0581964
Checking...
Read Info Done!
SwUpgradeSet...OK!
Resetting LifeTimer
Reset Done!
Total - 0 certs
Writen 21 certs!
Phone found!
read info...  - Ok
The Following 5 Users Say Thank You to Dzirt For This Useful Post:
Old 02-15-2011, 09:45   #8887 (permalink)
xheti's Avatar
Member: 209400
Thanks Meter: 63
motorola wx395 sucessful unlocked
COM60 [VCP0] selected
module v3.71
Device: Motorola-WX395
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:3503:A005
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC240200000000:08EA0000000000
flash: Samsung K5L2833ATA T 16Mb
otp offset: 00FF0000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
search rom info finished
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.E16AD E7A.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_D5D1415C].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: E16ADE7A
rom info ver: 05
sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN
project-id: MAUI.06B.W07.28.SP1.V38, 5C41D1D5
code offset: 00020000
ffs offset/size [01]: 00C00000/00400000
TCL-ID identification
version: 27G
provider: M395X-2BTBHR1
customization: CJ27YV72
customization: XJ27YV72
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 00C00000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRD_COMMUNICATION_B82X_PRODUCTS
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is invalid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, cust) calculation...
error: security area (sec info, cust) header is invalid
security area (sec info, hash) calculation...
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
identification header detected
customization name adjusted
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
version is not found in database: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN
use default security area (sec info, hash) pattern
max address is too big, should be recalculated: 08BF8000->08BF4004
done
done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: FFFFFFFFFFFFFF
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX395_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07 _28_SP1_V38__system_log_E16ADE7A_D5D1415C_20110215-091944.B0X.bin
Finished, time used: 3 min 57 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
thx infinity box team
The Following 2 Users Say Thank You to xheti For This Useful Post:
Old 02-15-2011, 10:09   #8888 (permalink)
kmaxmax's Avatar
Member: 553000
Thanks Meter: 2,302
Huawei-G6600 unlock done !!
COM3 [VCP1] selected
module v3.75
Action: "sp-unlock"
unlock method: smart fast
Model: Huawei-G6600
19200 autodetect
Initializing [6235:8A04:8A01]...
CPU: MT6235
chip: 0000:0000:0003
status: FF
rom: 4D573031
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6235,E04
Date: 2000.00.00
Version: 1.0
Version: E5.2AV01V01.04
Version: BYD35_09A_PMWY_HW
82 byte(s) read
imei: 357510xxxxxxxx
connection Ok
189 byte(s) read
reading data...
building new data...
writing data...
177 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 59 sec
The Following 4 Users Say Thank You to kmaxmax For This Useful Post:
Old 02-15-2011, 10:49   #8889 (permalink)
Member: 778251
Sonork: 19640
Thanks Meter: 63
!module v3.66
Action: "sp-unlock"
Model: SFR-114
19200 autodetect
CPU: MT6225
chip: 0001703:000B
status: FF
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: FES-FR-SFR-P103D1V1.0.1B01
44 byte(s) read
imei: 35852003233385
connection Ok
157 byte(s) read
reading data...
writing data...
145 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 16 sec
The Following 2 Users Say Thank You to houssam19 For This Useful Post:
Old 02-15-2011, 11:04   #8890 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
COM14 [VCP3] selected
module  v3.08
Device: Autodetect 6205-6227 NOR
ffs/eeprom backup enabled, it may takes several minutes !
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:6B03:0009
status: FF
Boot Done
flash: EC240200000000:18E59F00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====>  Set baud ...
921600
Set baud Done
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
rom info structure: 2nd [standard] generation
TCL-ID is absent
New firmware detected (v.3.08, database date: 03.02.2010):
LC6225_GEMINI_PCB01_GPRS_MT6225_S00.LBBKY27_8_12_1_3T05M0324_M571.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 04
sw version: LC6225_GEMINI_PCB01_GPRS_MT6225_S00.LBBKY27_8_12_1_3T05M0324_M571.BIN
project-id: LBBKY27.8.12.1.3T05M0324_M571, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00080000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
reading: LC6225_GEMINI_PCB01_GPRS_MT6225_S00.LBBKY27_8_12_1_3T05M0324_M571__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\LC6225_GEMINI_PCB01_GPRS_MT6225_S00.LBBKY27_8_12_1_3T05M0324_M571__ffs_20110215-143251.B0E.bin
====>  Write ...
Write Done
ffs formatting...
Finalization Done
Finished, time used: 4 min 42 sec
The Following 2 Users Say Thank You to nadirghazi For This Useful Post:
Old 02-15-2011, 11:23   #8891 (permalink)
rizalaa's Avatar
Member: 861211
Sonork: 000000
Thanks Meter: 127
3110c simlock failed done with best.
Before
Phone found!
read info... - Ok
Connected phone - Nokia 6300
Software ver : V 07.21 05-11-08 RM-217 (c) Nokia.
IMEI : 359317020806332
Ape Ver :
APE Var :
APE ADSP:
DSP Ver : ICPR61_08w10
APE Test:
PPM : V 07.21 05-11-08 RM-217 (c) Nokia. X
CNT : Content: x V 07.21 05-11-08 RM-217 (c) Nokia.
Product SN : CTG817317
Product code : 0537685
Base Prd.code: 0537040
Module code : 0203166
Long Prod.SN :
Hardware info=======
HWID : 6000
Retu : 32
Tahvo : 53
Batery: 4727 mV
Camera:
CMT BT: 06cc-P9.1
APE BT:
APE HW:
LCDVer:
RF ic :
Lock info ===========
IMEI spNet : 3A 95 13 07 02 08 36 03
IMEI svNet : 33 95 13 07 02 08 36 23 F5
Conf key : FFFFFFFFFFFFFFFF
Provider key : FFFFFFFFFFFFFFFF
Provider : Unknown Provider
Counters : Key 0 [3] , Fbus 0 [10]
Blocks : 1
LOCK STATUS :
BLK : 1
Lock1:Close
LOCKS : Closed
User Code : 12345
MMC pwd : no any record found
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
After
Phone Imei: 359317020806332
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT ASICID : 000000010000022600010006010C192101001101
CMT EM0 ID : 00000232
CMT EM1 ID : 00000353
CMT PUB ID : 1970010E214B7D5645BD67F35B0F3B5273D37000
CMT MODE ID : 00
CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
CMT ROM ID : 191EC665DFAAF68F
Key file updated...
Done!
Done!
Done!
Step 1...
Step 2...
Step 3...
SX4 Auth - Ok
Done!
Using : RM-217.pm
Field 1
Record 0 write - Ok
Record 2 write - Ok
Record 4 write - Ok
Record 6 write - Ok
Record 8 write - Ok
Record 13 write - Ok
Record 16 write - Ok
Record 18 write - Ok
Record 20 write - Ok
Record 25 write - Ok
Record 29 write - Ok
Record 34 write - Ok
Field 309
Record 0 write - Ok
Record 1 write - Ok
Record 2 write - Ok
Record 4 write - Ok
Record 5 write - Ok
Record 7 write - Ok
Record 8 write - Ok
Done!
Read info
Ape Ver :
APE Var :
APE ADSP:
APE Test:
PPM : V 07.21
05-11-08
RM-217
(c) Nokia.
X
CNT : Content: x
V 07.21
05-11-08
RM-217
(c) Nokia.
Long Prod.SN :
HWID : 6000
Retu : 32
Tahvo : 53
Batery: 4773 mV
Camera:
CMT BT: 06cc-P9.1
APE BT:
APE HW:
LCDVer:
RF ic : 17211721
IMEI spNet :
IMEI svNet :
Conf key : 0000000000000000
Provider key : 2440700000000000
Provider : AT&T;U.S.A. (3650)
Blocks : 7
LOCK STATUS :
BLK : 1
Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS : All Open
User Code : 12345
Done!
Thank's for Best Dongle Infinity Team.
The Following 4 Users Say Thank You to rizalaa For This Useful Post:
Old 02-15-2011, 11:58   #8892 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
COM3 [VCP0] selected
module v1.39
Device: LG-KG130
Action: reset
Boot ...
Connecting, wait...
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
current eeprom imei: 355311016181184
current otp imei: 355311017554272
file saved: C:\Program Files\InfinityBox\LGA\eeprom_355311016181184_LG-KG130_20110215-155657.B1E.bin
version: 234-30V10a44KG130P40FL
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
Write Done
Finished, time used: 38 sec
The Following 2 Users Say Thank You to cel_phon For This Useful Post:
Old 02-15-2011, 12:47   #8893 (permalink)
Member: 508072
Thanks Meter: 1,621
COM4 [VCP5] selected
module v3.26
Device: Autodetect 6205-6239 NOR
Action: "repair imei"
imei write channel: imei #1 (default imei inside firmware)
new imei: 350724309634849
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:3403:000F
status: FF
Boot Done
flash: 01227E22202200:18E59F00000000
otp offset: 00000000
Initialize Done
====> Set baud ...
921600
Set baud Done
rom info structure: [protected] type (04), 1 record(s)
TCL-ID is absent
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.869E10D2.[KB8108_PCB01_GPRS_MT6225_S00.KB8108-L8HV1_20-080307FSK1.BIN_75A91F3A].rpl
device-id: 869E10D2
rom info ver: 04
sw version: KB8108_PCB01_GPRS_MT6225_S00.KB8108-L8HV1_20-080307FSK1.BIN
project-id: KB8108-L8HV1.20-080307FSK1, 3A1FA975
TCL-ID is absent
standard ffs/eeprom offset confirmed: 00E00000
ffs/eeprom chip: 00
firmware area: 00000000-00DFFFFF
detecting startup code area #2...
startup code area #2 is absent
detecting ffs/eeprom structure pass 2...
ffs/eeprom: detect std location pass #1...
ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok element #2
imei default found: 13579024681122
====> Write ...
Write: imei
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\K B8108_PCB01_GPRS_MT6225_S00.KB8108-L8HV1_20-080307FSK1__system_log_869E10D2_75A91F3A_20110215-171541.B0X.bin
Finished, time used: 2 min 24 sec
The Following 3 Users Say Thank You to joni_rajpura For This Useful Post:
Old 02-15-2011, 12:48   #8894 (permalink)
Member: 508072
Thanks Meter: 1,621
module v1.44
Device: Huawei-C2809
connecting...
checking version...
Apr 24 2009C2809C02B105
Huawei C2809 version B105 selected..
Downloading mode...
Erasing...
patching in progress 33%...
patching in progress 66%...
patching in progress 99%...
done...
Finished, time used: 29 sec
Old 02-15-2011, 12:48   #8895 (permalink)
Member: 508072
Thanks Meter: 1,621
module v1.44
operation: Repair "Contact Service"
connecting...
Contact Service Remover...
Finished, time used: 10 sec
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.72598 seconds with 10 queries
