02-15-2011, 18:22 | #8911 (permalink) |
No Life Poster Join Date: May 2007 Location: IN {HUMEN}WORLD
Member: 510445 Status: Offline Sonork: 100.1638301 Thanks Meter: 353 | Ufone unlock G3610 with infinity thanks COM3 [VCP0] selected module v3.74 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G3610 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6CEE:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: G3610_V100R001B001C19SP03S Version: L75_HW 80 byte(s) read imei: 35398504440182 connection Ok 185 byte(s) read reading data... reading data #2... building new data... writing data... 173 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 13 sec Remove/Install battery now ! thanks great team |
The Following 2 Users Say Thank You to shakeel145 For This Useful Post: |
02-15-2011, 18:41 | #8912 (permalink) |
Member: 510445 Status: Offline Sonork: 100.1638301 Thanks Meter: 353 | read code working on ufone here is logs COM3 [VCP0] selected module v3.74 Action: read unlock codes unlock method: read codes Model: Huawei-G3610 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6CEE:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: G3610_V100R001B001C19SP03S Version: L75_HW 80 byte(s) read imei: 35398504440182 connection Ok 185 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 173 byte(s) read reading data... 972 byte(s) read lock[1] code: + 17895687 lock[2] code: + 56781234 lock[3] code: + 1122 lock[4] code: - 3344 lock[5] code: - 5566 lock[6] code: + 7788 lock[7] code: + 9900 if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 13 sec Remove/Install battery now ! |
02-16-2011, 05:55 | #8913 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | Huawei-C2801 unlocked --------------------------------------------------------- BOOT VER : 723:11:32Mar COMPILE : ( =? ) REALEASE : ( ) SW Version : C2801C02B105 BOOT --------------------------------------------------------- Phonce code : 0000 Finished, time used: 4 sec COM7 [VCP0] selected module v1.44 Device: Huawei-C2801 operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... disable minlock... Phones should be restarting now... Finished, time used: 5 sec |
The Following 2 Users Say Thank You to akashub For This Useful Post: |
02-16-2011, 07:45 | #8914 (permalink) |
No Life Poster Join Date: Aug 2007 Location: GREAT INDIA
Member: 559113 Status: Offline Sonork: 100.1596477 Thanks Meter: 760 | Haier c5000 unlock done .. COM44 [qcusbser0] selected module v1.44 Device: Haier-C5000 operation: SP-unlock Phone should be Switched ON ! connecting... HA5000MV06 Haier C5000 version 06 selected.. Sending command... patching in progress... Done... Phones should be restarting now... Finished, time used: 13 sec |
The Following 2 Users Say Thank You to sonu arya For This Useful Post: |
02-16-2011, 07:53 | #8915 (permalink) |
No Life Poster Join Date: Jul 2009 Location: chandigarh INDIA
Member: 1066865 Status: Offline Thanks Meter: 593 | nokia 7210c successfully language changed nokia 7210c successfully language changed Code: card found: S/N 0656:0118 registered to: mobiletech DLL not found... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 7210 Supernova Software ver : V 07.23 17-07-09 RM-436 (c) Nokia IMEI : 356930037080643 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR72_09w17 APE Test: PPM : V 07.23 17-07-09 RM-436 (c) Nokia MR CNT : Content: mr V 07.23 17-07-09 RM-436 (c) Nokia Product SN : KOI920418 Product code : 0581686 Base Prd.code: 0563951 Module code : 0203868 Long Prod.SN : 0 Hardware info======= HWID : 3005 Retu : 16 Tahvo : 22 Batery: 3879 mV Camera: CMT BT: 2222-143C APE BT: APE HW: LCDVer: SEIKO RF ic : Lock info =========== IMEI : 356930037080643 IMEI spNet : 3A 65 39 00 73 80 60 04 IMEI svNet : 33 65 39 00 73 80 60 44 F0 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created... :) User Code : not set MMC pwd : Backup saved UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : PPM : rm436__07.23.ppm_d CNT : rm436__07.23_ISM_002.image_d_ny_telenor_rs Flashing phone now... Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created... :) SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : G:\infinity box\Backup\Cert\356930037080643_SIM.rpl -> MMC pass Record found, saving... Getting product info... RAP_BOOT: 0803000302010000 RAP_PUBLIC: 0B30020710758C56D60C74A8469A80071B53D274 CMT_ROOTKEY: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP_PAPUBKEY: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm436__07.23_ISM_002.image_d_ny_telenor_rs ConvertImage: Page Size is 128K, no need convert Loader len: 306432, CHK: 6CEB ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : ASIC CMT select Ok ===Flashing [PPM]=== Erase : Processing rm436__07.23.ppm_d Found 1 areas to erase Erasing area 0x01340000 - 0x01BDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:10 Write : Processing rm436__07.23.ppm_d Total 474 [474/0/0] blocks to write, writing... TIME : Write time : 00:00:24 PPM Write done ===Flashing [CNT]=== Erase : Processing rm436__07.23_ISM_002.image_d_ny_telenor_rs Found 2 areas to erase Erasing area 0x01BE0000 - 0x01F7FFFF, NOR, CMT Result: 0000 Erasing area 0x01F80000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:06:17 Write : Processing rm436__07.23_ISM_002.image_d_ny_telenor_rs Total 1360 [1360/0/0] blocks to write, writing... TIME : Write time : 00:01:10 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:09:03 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 7210 Supernova Software Info: V 07.23 17-07-09 RM-436 (c) Nokia IMEI: 356930037080643 PPM version : V 07.23 17-07-09 RM-436 (c) Nokia D Product code: 0581686 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Resetting LifeTimer Error check LifeTimer Data, break :( Reset It manually, please Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! Set phone to Normal mode... AfterFlash operations done... Done! Elapsed: 00:09:56 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 4 Users Say Thank You to sunny_luthras99 For This Useful Post: |
02-16-2011, 07:59 | #8916 (permalink) |
Member: 1066865 Status: Offline Thanks Meter: 593 | nokia 5130c flashed successfully nokia 5130c flashed successfully Code: Connect phone on selected interface... Files Set for Flashing : MCU : rm495__07.91.mcusw PPM : rm495__07.91.ppm_ed CNT : rm495__07.91_ism_003.image_ed_si_red_tmo_hr_red FlashFile verify disabled Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0B800008F7B17D562FC80EC92179AB71A2CB39E5 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 89820089 < INTEL => 0046L0Y1GG FLASHID : 89820089 , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : 917F11196FDB7378C18EF7260698CA4489DCA02700 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT select Ok Erase : Processing rm495__07.91.mcusw CMT select Ok Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0137FFFF CMT , NOR , Area : 0x01380000 - 0x0151FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:40 Write : Processing rm495__07.91.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1169 blocks TIME : Write time : 00:01:54 Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0B800008F7B17D562FC80EC92179AB71A2CB39E5 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 89820089 < INTEL => 0046L0Y1GG FLASHID : 89820089 , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : 917F11196FDB7378C18EF7260698CA4489DCA02700 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT select Ok Erase : Processing rm495__07.91.ppm_ed CMT select Ok Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01DBFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:39 Write : Processing rm495__07.91.ppm_ed Total writen 443 blocks TIME : Write time : 00:00:41 Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0B800008F7B17D562FC80EC92179AB71A2CB39E5 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 89820089 < INTEL => 0046L0Y1GG FLASHID : 89820089 , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : 917F11196FDB7378C18EF7260698CA4489DCA02700 Transmission mode : Dual (Ddr, TX2) Boot Done! ConvertImage: Processing rm495__07.91_ism_003.image_ed_si_red_tmo_hr_red ConvertImage: Page Size is 128K, no need convert CMT select Ok Erase : Processing rm495__07.91_ism_003.image_ed_si_red_tmo_hr_red CMT select Ok Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF CMT , NOR , Area : 0x02160000 - 0x03FBFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:24 Write : Processing rm495__07.91_ism_003.image_ed_si_red_tmo_hr_red Total writen 832 blocks TIME : Write time : 00:01:18 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 5130c-2 Software Info: V 07.91 29-10-09 RM-495 (c) Nokia IMEI: 355232034474536 Product code: 0573693 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Reset LifeTimer ... Ok Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! |
The Following 3 Users Say Thank You to sunny_luthras99 For This Useful Post: |
02-16-2011, 08:25 | #8917 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 44
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Nokia X6-00 RM-559 FLASH DONE BY BEST Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-559_30.0.003_prd.core.C00 PPM : RM-559_30.0.003_prd.rofs2.V12 PPM2 : RM-559_30.0.003_C02_prd.rofs3.fpsx CNT : RM-559_30.0.003_001_000_U004.uda.fpsx Flashing phone now... Check files done... -> Check SW version... FlashFile version : 30.0.003 Phone version : V 30.0.003 -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : F:\BEST-INFINITY\Backup\Cert\355964040854174_SIM.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Batery valtage : 3722 mV -> Batery voltage less, than 3,8V (3722mV). Continue at user risk Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101051103 EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 2120010C9CA800527A88CA8DF41CEA59F05A9C94 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing UPDAPP... Processing PAPUBKEYS... Processing UPDAPP... Boot Done! TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-559_30.0.003_prd.core.C00 Found 4 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x0B71FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:01 Write : Processing RM-559_30.0.003_prd.core.C00 Total 481 [481/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:32 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-559_30.0.003_prd.rofs2.V12 Found 1 areas to erase Erasing area 0x07920000 - 0x0A2FFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-559_30.0.003_prd.rofs2.V12 Total 87 [87/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:06 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-559_30.0.003_C02_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x0A300000 - 0x0B71FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-559_30.0.003_C02_prd.rofs3.fpsx Total 26 [26/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:01 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-559_30.0.003_001_000_U004.uda.fpsx Found 1 areas to erase Erasing area 0x0B720000 - 0x1EF7FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-559_30.0.003_001_000_U004.uda.fpsx Total 5 [5/0/0] blocks to write, writing... TIME : Write time : 00:00:00 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:42 Reboot phone now... Reading Phone Info.... Connected phone - Nokia X6-00 Software Info: V ICPR72_10w29.2.3 27-10-10 RM-559 (c) Nokia IMEI: 355964040854174 Ape Version: V 30.0.003 Product code: 059B1J6 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Set phone to Normal mode... AfterFlash operations done... Done! Elapsed: 00:01:26 Connect phone on selected interface... |
The Following 3 Users Say Thank You to sirnavid2010 For This Useful Post: |
02-16-2011, 08:27 | #8918 (permalink) |
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Nokia 7210 Supernova FLASH DONE BY BEST.1.15 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm436__07.23.mcusw PPM : rm436__07.23.ppm_mb CNT : rm436__07.23.image_mb Flashing phone now... Check files done... -> Check SW version... FlashFile version : 07.23 Phone version : 05.61 10-12-08 RM-436 (c) Nokia -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : F:\BEST-INFINITY\Backup\Cert\351962039672775_SIM.rpl Getting product info... RAP_BOOT: 0803000302010000 RAP_PUBLIC: 0260011708097D56AEED2DB57124C69E5417E77C CMT_ROOTKEY: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP_PAPUBKEY: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 Checking CNT sector PN<>FL PN CNT sector : 128 kb Converted content already exist, skip convert and using 128k Loader len: 306432, CHK: 6CEB ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm436__07.23.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0119FFFF, NOR, CMT Result: 0000 Erasing area 0x011A0000 - 0x0133FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:48 Write : Processing rm436__07.23.mcusw Total 1170 [1170/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:58 MCU Write done ===Flashing [PPM]=== Erase : Processing rm436__07.23.ppm_mb Found 1 areas to erase Erasing area 0x01340000 - 0x01BDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:51 Write : Processing rm436__07.23.ppm_mb Total 394 [394/0/0] blocks to write, writing... TIME : Write time : 00:00:20 PPM Write done ===Flashing [CNT]=== Erase : Processing rm436__07.23.image_mb_128 Found 2 areas to erase Erasing area 0x01BE0000 - 0x01F7FFFF, NOR, CMT Result: 0000 Erasing area 0x01F80000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:14 Write : Processing rm436__07.23.image_mb_128 Total 1296 [1296/0/0] blocks to write, writing... TIME : Write time : 00:01:06 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:10:19 Reboot phone now... Phone disconected! Connect phone on selected interface... -> Flashing Failed! Maybee HW error, or Downgrade try???! Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Elapsed: 00:12:33 Connect phone on selected interface... |
02-16-2011, 08:29 | #8919 (permalink) |
Insane Poster Join Date: Feb 2010
Member: 1243673 Status: Offline Thanks Meter: 42 | Micromax C111 Unlock CIK.4.01Jun 17 2010 MICROMAX C111 17 Jun 2010 selected.. Offline.. Downloading mode.. Sending Boot.. patching in progress.. patching in progress 50%.. patching in progress 100%.. Finished, time used: 36 sec |
The Following 2 Users Say Thank You to hemgoyal_1990 For This Useful Post: |
02-16-2011, 10:33 | #8920 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Online Sonork: TAKE NO CHANCES Thanks Meter: 534 | ZTE-S213 UNLOCKED SUCCESSFULY module v3.75 Action: "sp-unlock" unlock method: smart fast Model: ZTE-S213 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:4204:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: E-UGD-P109A14V1.0.0B03 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 35959003561035 connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 15 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to KYEJUSA For This Useful Post: |
02-16-2011, 10:57 | #8921 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | LG -Kg370 factory settings ok COM3 [VCP0] selected module v1.78 Device: LG-KG370 Checking data, wait... Action: reset settings ("format ffs")\ Boot ... Press and HOLD Power button now !\ e-gold: 820000\ loading...\ next part...\ boot answer: 01 Release Power button now Boot Done\ Set Baud ... 460800\ Set Baud Done Connecting ... flash: 00EC:257E\ Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .00 ULC2GL KG370 P16 ARB V10d XXX-XX OCT 22 2007 +0 ,\ Check parameters Done\ backup critical area ...\ reading eeprom-static...\ file saved: C:\\Program Files\\InfinityBox\\Pana01\\LG-KG370_eeprom-static_20110204-195553.B1E.bin\ loading data...\ data loaded\ imei: 35297702326189700\ reading eeprom-security_35297702326189700...\ file saved: C:\\Program Files\\InfinityBox\\Pana01\\LG-KG370_eeprom-security_35297702326189700_20110204-195553.B1E.bin\ reading eeprom-complete_35297702326189700...\ file saved: C:\\Program Files\\InfinityBox\\Pana01\\LG-KG370_eeprom-complete_35297702326189700_20110204-195555.B1E.bin\ backup critical area Done\ Check memory ...\ Check memory Done\ Write ...\ reset...\ done\ Write Done\ Finished, time used: 44 sec Remove/Install battery now ! } |
The Following 2 Users Say Thank You to amn32 For This Useful Post: |
02-16-2011, 12:29 | #8922 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab(india) Age: 46
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | nokia 7210c flashing done card found: S/N 0390:0118 registered to: jindalgsm4255 Connect phone on selected interface... Core version : 1.16 , Rev : 2.1 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm436__07.23.mcusw PPM : rm436__07.23.ppm_c CNT : rm436__07.23.image_c_de Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 27E0011532027D5651DF0D0C493442CEA998C9B5 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm436__07.23.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0119FFFF, NOR, CMT Result: 0000 Erasing area 0x011A0000 - 0x0133FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:49 Write : Processing rm436__07.23.mcusw Total 1170 [1170/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:54 MCU Write done ===Flashing [PPM]=== Erase : Processing rm436__07.23.ppm_c Found 1 areas to erase Erasing area 0x01340000 - 0x01BDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:49 Write : Processing rm436__07.23.ppm_c Total 448 [448/0/0] blocks to write, writing... TIME : Write time : 00:00:21 PPM Write done ===Flashing [CNT]=== Erase : Processing rm436__07.23.image_c_de Found 2 areas to erase Erasing area 0x01BE0000 - 0x01F7FFFF, NOR, CMT Result: 0000 Erasing area 0x01F80000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:27 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm436__07.23.image_c_de Total 1424 [1424/0/0] blocks to write, writing... TIME : Write time : 00:01:06 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:10:28 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 7210 Supernova Software Info: V 07.23 17-07-09 RM-436 (c) Nokia IMEI: 351962038442949 PPM version : V 07.23 17-07-09 RM-436 (c) Nokia C Product code: 0572571 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:11:33 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 3 Users Say Thank You to JINDALGSM™ For This Useful Post: |
02-16-2011, 14:18 | #8923 (permalink) |
Member: 1066865 Status: Offline Thanks Meter: 593 | another nokia 7210c flashed successfully another nokia 7210c flashed successfully Code: Phone found! Series 40 Device detected! read info... - Ok Selected FlashSettings : Manual Files Set for Flashing : MCU : rm436__07.23.mcusw PPM : rm436__07.23.ppm_mr CNT : rm436__07.23.image_mr Check FlashFiles, Please, wait... -> Check SW version... FlashFile version : 07.23 Phone version : 07.23 17-07-09 RM-436 (c) Nokia -> Check SW version : Reflash Backup enabled, Will read Certificates now... CRT308 Backup Created... :) Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 032001026AC27D569CFD9F5985F1BDF3F9A011F0 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : DCA5EA5203CD30A64D4D95ABCD621F4AB23026F100 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 353180038998962 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... RPL saved : G:\infinity box\Backup\Cert\353180038998962_2nd.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 032001026AC27D569CFD9F5985F1BDF3F9A011F0 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : DCA5EA5203CD30A64D4D95ABCD621F4AB23026F100 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm436__07.23.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0119FFFF CMT , NOR , Area : 0x011A0000 - 0x0133FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:19 Transmission mode : Dual (Ddr, TX2) Write : Processing rm436__07.23.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1161 blocks TIME : Write time : 00:02:24 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm436__07.23.ppm_mr Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01340000 - 0x01BDFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:31 Transmission mode : Dual (Ddr, TX2) Write : Processing rm436__07.23.ppm_mr Total writen 454 blocks TIME : Write time : 00:00:55 ConvertImage: Processing rm436__07.23.image_mr ConvertImage: Page Size is 128K, no need convert Transmission mode : Dual (Ddr, TX2) Erase : Processing rm436__07.23.image_mr Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01BE0000 - 0x01F7FFFF CMT , NOR , Area : 0x01F80000 - 0x03FBFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:02:56 Transmission mode : Dual (Ddr, TX2) Write : Processing rm436__07.23.image_mr Total writen 496 blocks TIME : Write time : 00:01:00 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 7210 Supernova Software Info: V 07.23 17-07-09 RM-436 (c) Nokia IMEI: 353180038998962 Product code: Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Resetting LifeTimer Reset Done! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Set phone in Normal mode... Restarting... Done! |
02-16-2011, 14:28 | #8924 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 39
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Code: COM2 [VCP4] selected module v1.38 Device: Sony-Ericsson-J120i "advanced chip detection" active Action: reset settings Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 208814FFFFFFFF:20881400000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb software version: 1030-000 software version: MLD-5- Check hardware done Read data ... reading Sony-Ericsson-J120i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J120i_eeprom_calibration-1_20110216-185203.6AE.bin reading Sony-Ericsson-J120i_ffs... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J120i_ffs_20110216-185212.6AE.bin Read data done Check data ... Check data done Write ... flash: 208814FFFFFFFF:20881400000000 Erase: ffs Write done Finished, time used: 28 sec Remove/Install battery now ! WBR sahil2000ind |
The Following 2 Users Say Thank You to sahil2000ind For This Useful Post: |
02-16-2011, 15:30 | #8925 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 35
Member: 1157320 Status: Offline Thanks Meter: 6,192 | 7370 repair SLD, Security, SX4 Code: Repair SL procedure started... Phone Imei: 357612006372313 Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000352 CMT PUB ID : 2B300208852500546D40CAF473B7F62B953BCDD3 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... CMT Loader sent, Boot Ok Init Service mode... Wait... Key file updated... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Writing SimLock Data... Ok Writing SimLock Key... Ok Done! Repair SD procedure started... Phone Imei: 357612006372313 Key file exists, no need to read... Operating mode is OK, no need change... Writing Super Dongle Key... Ok Done! Local SX4 procedure started... Phone Imei: 357612006372313 Key file exists, no need to read... Step 1... Step 2... Step 3... SX4 Auth - Ok Done! Uploading RF/Battery tune to phone... Using : RM-70.pm Operating mode is OK, no need change... Field 1 Record 0 write - Ok Record 2 write - Ok Record 4 write - Ok Record 6 write - Ok Record 8 write - Ok Record 13 write - Ok Record 16 write - Ok Record 18 write - Ok Record 20 write - Ok Record 25 write - Ok Record 29 write - Ok Record 34 write - Ok Field 309 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 4 write - Ok Record 5 write - Ok Record 7 write - Ok Record 8 write - Ok Record 17 write - Ok Check ST_SECURITY now... Security status : ST_SECURITY => OK Done! Elapsed: 00:00:00 |
The Following 2 Users Say Thank You to Dzirt For This Useful Post: |
