05-01-2008, 15:31 | #78 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Gsm World Age: 36
Member: 611165 Status: Offline Thanks Meter: 36 | Chinese ZTC ZT989 dead solve by format on infinity Chinese ZTC ZT989 dead solve by format on infinity Here is log of format...... COM14 [VCP0] selected Device: Spice S410 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: STANDARD_PCB01_GSM_MT6205B_DN.KACS410_INA_EN_HI_4_ 02_330.BIN ver. sw2: KACS410_INA_EN_HI_4.02_330, 00000000 ffs offset/size: 00380000/00080000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[STANDARD_PCB01_GSM_MT6205B_DN.KACS410_INA_EN_HI_4_ 02_330.BIN]]... file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom[STANDARD_PCB01_GSM_MT6205B_DN.KACS410_INA_EN_HI_4_ 02_330.BIN]_20080501-191727.B0E.bin flash: 01227E221A2201:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E221A2201:18E59F00000000 Finalization Done Finished, time used: 75 sec Remove/Install battery now ! |
The Following User Says Thank You to Ravvi For This Useful Post: |
05-25-2008, 10:45 | #80 (permalink) |
Freak Poster Join Date: Mar 2007 Location: The Earth
Member: 459470 Status: Offline Thanks Meter: 20 | But i can't understand ...i still never get connected properly though i always follow the pin outs instructions.cbale tx,cable rx,and cable gnd....what else should i do please....: |
05-26-2008, 12:19 | #81 (permalink) |
Freak Poster Join Date: Jun 2007 Location: ..:: Great Gujarat ::.. Age: 37
Member: 526644 Status: Offline Thanks Meter: 56 | Cect_t689 Complate After Formate CECT_T689 COMPLATE AFTER FORMATE [Infinity Box] v2.45 S/N: ### Wait... Device: Autodetect 6205-6227 NOR Done COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:1B8B:E32F high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.FB5A677A.[E550_A5ARABBT_E550_GPRS_MT6226_S01.E550_A5ARAB_01_ 0.BIN_CA0A8660].rpl identification#1 detection finished device-id: FB5A677A identification#1 protocol ver: 04 ver. sw1: E550_A5ARABBT_E550_GPRS_MT6226_S01.E550_A5ARAB_01_ 0.BIN ver. sw2: E550_A5ARAB.01.0, 9F79F535 ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [flash[E550_A5ARABBT_E550_GPRS_MT6226_S01.E550_A5ARAB_01_ 0.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_flash[E550_A5ARABBT_E550_GPRS_MT6226_S01.E550_A5ARAB_01_ 0.BIN]_20080526-161902.B0M.bin file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _FB5A677A_E550_A5ARABBT_E550_GPRS_MT6226_S01.E550_ A5ARAB_01_0.BIN_CA0A8660_20080526-161950.B0X.bin Finished, time used: 1907 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM3 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:1B8B:E32F Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: E550_A5ARAB.01.0_26S01 Version: M500Z_05C_HW detecting structure #2... done 60 byte(s) read imei: 35410100024132 connection Ok building list... done items to clear: 210 190 of 210 items cleared building list... done 2 items remains Finished, time used: 128 sec Remove/Install battery now ! |
05-28-2008, 04:30 | #82 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | flying f826 pinout via pinfinder: software version: 1.09 cable type: 2x6 (L12B) platform: MT62xx (autodetect) searching adapter at COM3... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6226 result: Rx:7 Tx:6 time required: 34 sec Power On ! saved: Flying_F826 chinese miracle v2.45 unlock phone code successfully, tnx infinity |
05-29-2008, 21:05 | #84 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Earth
Member: 593876 Status: Offline Thanks Meter: 302 | pen calibration touch screen repair success today come nokla n95 mtk6226 prob show on display pen calibration.at first start infinity select nokla n95 run detect mtk chiness miracle 2.46 ver select comport calibrate touch screen repair security area cable use super doctor cgc cable i use two box super doctor and infinity for this success .thanks infinity team for add touch screen pen cali erase solution |
05-30-2008, 15:21 | #86 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
If phone can not be detected by software you must double check your cable (probably need to swap Rx <-> Tx) and check COM port selection. | |
06-07-2008, 07:25 | #89 (permalink) |
No Life Poster Join Date: May 2008 Location: PAKISTAN Age: 35
Member: 772820 Status: Offline Sonork: BE MASTERMIND Thanks Meter: 124 | infinity is the best for all chinese and many others phones i have solved 98% sets with infinity we need update it from other devices plz include many new features in infinity |
06-07-2008, 20:33 | #90 (permalink) |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | I AM FORMAT SONY COLON & success by INFINITY BOX HEAR IS LOG:-COM6 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:497D:5200 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: BB04.6.36.1.0T05_20071017_Yan Version: BB04MBV02 detecting structure #2... done 60 byte(s) read imei: 35440500467085 connection Ok building list... done items to clear: 202 warning: wrong packet cs warning: wrong packet cs 201 of 202 items cleared building list... done 1 items remains Finished, time used: 36 sec Remove/Install battery now ! sony colon pinout:-rx-8,tx-7 |
The Following User Says Thank You to debmobile For This Useful Post: |
