Old 02-19-2011, 11:11   #9001 (permalink)
joni_rajpura's Avatar
Member: 508072
Thanks Meter: 1,621
COM4 [VCP0] selected
module v3.26
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: write flash
"smart write" active
write: Firmware
HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.B025_8_G FIVE_L131_V121_2010-05-27_16m_En_Fr_Es_Id_Th_Hi_Urdu_Farsi_Pt_Ar.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:5803:000F
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98000300000001:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (05)
TCL-ID is absent
rom info detection finished
rom info ver: 05
sw version: HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.B025_8_G FIVE_L131_V121.BIN
project-id: B025_8_GFIVE_L131_V121, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.B025_8_G FIVE_L131_V121__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\HEXING25_08B_GEMI NI_PCB01_GPRS_MT6225_S00.B025_8_GFIVE_L131_V121__f fs_20110219-153522.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Code CRC check error fix...
firmware do not have "Code CRC check error" area
Special operation Done
====> Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
done
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 2 min 11 sec
Remove/Install battery now !
The Following 2 Users Say Thank You to joni_rajpura For This Useful Post:
Old 02-19-2011, 11:14   #9002 (permalink)
nhumanh's Avatar
Member: 56938
Sonork: 100.1590777
Thanks Meter: 152
Reset phone code EB-X100 done
Phone code become : 1234
COM9 selected
Device must be POWERED-ON !
Connecting, wait...
Device connected. Working...
Current Imei: 35x1xx00xx94xx0
SW Version: 1211.J25_G66
User Code reset Ok
(From *******)
The Following 2 Users Say Thank You to nhumanh For This Useful Post:
Old 02-19-2011, 11:38   #9003 (permalink)
Member: 508072
Thanks Meter: 1,621
COM23 ready
Action: "repair imei"
Model: Autodetect 6205-6239 NOR
Phone should be Switched ON !
Connecting, wait...
baud set to: 115200
Phone detected, wait...
imei-1: 356253746905513
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono CPU
new imei-1: 351847000344878
verification Ok
Finished, time used: 3 sec
Connecting, wait...
baud set to: 115200
imei-2: 356253746905514
imei write channel: imei #2 for dual sim/mono CPU
new imei-2: 352793018594550
verification Ok
Finished, time used: 4 sec
The Following 3 Users Say Thank You to joni_rajpura For This Useful Post:
Old 02-19-2011, 11:55   #9004 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,927
COM4 [VCP1] selected
module v3.26
Action: reset settings ("format ffs")
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 000120F:0006
status: FF
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
rom info structure: [standard] type (04)
TCL-ID is absent
rom info ver: 04
sw version: HX684_GEMINI_07B_HW.WX684_AR10_NT57_B2_V1_9ETEST--091124.BIN
project-id: WX684_AR10_NT57_B2_V1.9ETEST, 00000000
TCL-ID is absent
ffs/eeprom chip: 00
reading: HX684_GEMINI_07B_HW.WX684_AR10_NT57_B2_V1_9ETEST--091124__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\HX684_GEMINI_07B_ HW.WX684_AR10_NT57_B2_V1_9ETEST--091124__ffs_20110219-025435.B0E.bin
====> Write ...
Write Done
ffs formatting...
Finalization Done
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following 3 Users Say Thank You to cel_phon For This Useful Post:
Old 02-19-2011, 12:15   #9005 (permalink)
Member: 508072
Thanks Meter: 1,621
module v3.74
Device: Spice-S415-2008-03-19
advanced flash detection disabled
Action: "sp-unlock"
unlock method: standard fast
Unlock procedure can be faster if you skip ffs/eeprom area backup procedure.
Do you want to disable ffs/eeprom backup ?
ffs/eeprom backup disabled
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6205:8B00]...
CPU: MT6205
Boot Done
flash: 7F22C400000000:18E59F00000000
flash: T 2Mb
otp offset: 001F0000
Initialize Done
====> Set baud ...
921600
Set baud Done
interesting cpu type found
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
ffs/eeprom address can not be detected, value from database assigned: 001B0000/00050000
lock area found
detecting parameters to apply patch area 1...
required data found
Write: area 1 (pass 1)
area 1 patch applied Ok
====> Write ...
Write: lock-area-1
Write Done
Finalization Done
Finished, time used: 25 sec
Old 02-19-2011, 12:29   #9006 (permalink)
naveedbutt's Avatar
Member: 1015336
Sonork: 100.1608410
Thanks Meter: 812
nktel ffs done
module v3.25
Do you want to make ffs/eeprom backup before format ?
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:CF03:0009
status: FF
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
rom info structure: [protected] type (04), 1 record(s)
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.85DB17F8.[5800_ABROAD_PCB01_GPRS_MT6225_S00.N96_P11_TOSHIBA_ S5LCD_V1_0_2.BIN_7F80B444].rpl
device-id: 85DB17F8
rom info ver: 04
sw version: 5800_ABROAD_PCB01_GPRS_MT6225_S00.N96_P11_TOSHIBA_ S5LCD_V1_0_2.BIN
project-id: N96_P11_TOSHIBA_S5LCD_V1.0.2, 44B4807F
TCL-ID is absent
ffs/eeprom chip: 00
reading: 5800_ABROAD_PCB01_GPRS_MT6225_S00.N96_P11_TOSHIBA_ S5LCD_V1_0_2__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\5800_ABROAD_PCB01 _GPRS_MT6225_S00.N96_P11_TOSHIBA_S5LCD_V1_0_2__ffs _20110219-032735.B0E.bin
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\5 800_ABROAD_PCB01_GPRS_MT6225_S00.N96_P11_TOSHIBA_S 5LCD_V1_0_2__system_log_85DB17F8_7F80B444_20110219-032813.B0X.bin
Finished, time used: 5 min 1 sec
The Following 3 Users Say Thank You to naveedbutt For This Useful Post:
Old 02-19-2011, 13:39   #9007 (permalink)
Member: 1505057
Thanks Meter: 38
LG RD3000 ded Handset successful
rd3000 ded handset success by repair blink(then scr upgrade)
COM20 [VCP0] selected
module v1.44
Device: LG-3000
operation: Repair "Blink"
connecting...
Repair blink lg-3500 version 08...
sending command....
fixing 1....
fixing 2....
fixing 3....
fixing 4....
fixing 5....
fixing 6....
fixing 7....
fixing 8....
fixing 9....
fixing 10....
fixing 11....
fixing 12....
fixing 13....
fixing 14....
fixing 15....
fixing 16....
fixing 17....
fixing 18....
fixing 19....
fixing 20....
done....
Finished, time used: 23 sec
The Following 2 Users Say Thank You to Rockybul25 For This Useful Post:
Old 02-19-2011, 14:01   #9008 (permalink)
Member: 530721
Thanks Meter: 157
COM1 [LGSIDIAG1] selected
module v1.44
Device: LG-3610
operation: SP-unlock
connecting...
OFFLINE...
sending boot...
sending command...
patching in progress...
patching in progress 50%...
patching in progress 100%...
Done...
Phones should be restarting now...
The Following User Says Thank You to Sandeep Mobiles For This Useful Post:
Old 02-19-2011, 15:23   #9009 (permalink)
Alexandro Monte's Avatar
Member: 846805
Sonork: alex cavalcante
Thanks Meter: 261
COM1 [Serial0] selected
Mَdulo v3.64
Dispositivo: Vodafone-345
Verificando Dados. Aguarde...
Detecçمo Avançada da Flash Habilitada
Action: rebuild security area
====> Boot ...
Pressione e SEGURE o Botمo de Ligar!
19200 fixed
Conectando. Aguarde...
Inicializando [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:7DE7:A00C
status: 01
Tamanho do Pacote de Inicializaçمo: 0400
Solte o Botمo de Ligar!
Boot Done
====> Inicializar ...
Flash 2088BAFFFFFFFF:2088BA00000000
Flash ST Intel std [def 003Fx010000 0008x002000] 4Mb
otp offset: 003F0000
Nْmero do Chip da Flash/Regiمo Detectada: 01/01
Inicializar Done
====> Determinar Velocidade ...
115200
Determinar Velocidade Done
====> Inicializar Cَdigo de Boot ...
Inicializar Cَdigo de Boot Done
====> Verificar Integridade do Firmware ...
TCL-ID is present
TCL-ID detection...
TCL-ID detection done
rom info ver: 05
sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN
project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000
ffs offset/size [01]: 003A0000/00058000
TCL-ID identification
Versمo: 83D
provider: V345X-2AVDNL1
Customizaçمo CM83FF92
Customizaçمo XM83FF92
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 003A0000
Estado do Travamento do Cartمo SIM: enabled
product id: JRD_COMMUNICATION_U91X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
security area (sec info, cust) calculation...
identification header detected
customization name adjusted
Escrever security area (sec info, cust)
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
max address is too big, should be recalculated: 0827D124->0827C9FC
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
Feito
Escrever security area (sec info, hash)
security area (sec info, hash) calculation done
Verificar Integridade do Firmware Done
====> Verificar Conteْdo do Firmware ...
Verificar Conteْdo do Firmware Done
====> Salvar Cَpia de Dados ...
IMEI Original: 00006A21041644
Salvar Cَpia de Dados Done
====> Programar Dados Necessلrios ...
Programar Dados Necessلrios Done
====> Operaçمo Especial ...
Operaçمo Especial Done
====> Escrever ...
Escrever Done
====> Finalizaçمo ...
FFS formatting...
Finalizaçمo Done
Arquivo Salvo: C:\Arquivos de programas\InfinityBox\MModule\backup_security\Voda fone-345_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W0 8_36_SP1_V28_F1__system_log__00000000_20110219-122212.B0X.bin
Finalizado. Tempo Gasto: 1 min 29 sec
Remova/Recoloque a Bateria!
The Following 3 Users Say Thank You to Alexandro Monte For This Useful Post:
Old 02-19-2011, 15:48   #9010 (permalink)
Member: 778251
Sonork: 19640
Thanks Meter: 63
module v3.73
Device: Motorola-WX295
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:9DB3:A00C
status: 01
Boot Done
flash: EC240200000000:2BEA0000000000
flash: Samsung K5L2833ATA T 16Mb
otp offset: 00FF0000
Initialize Done
====> Set baud ...
115200
Set baud Done
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is present
startup code area #1 backup saved: D:\Program Files\InfinityBox\MModule\backup_security\id.CAD60 4C2.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F5.BIN_00029750].rpl
TCL-ID detection...
device-id: CAD604C2
rom info ver: 05
sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F5.BIN
project-id: MAUI.08A.W08.36.SP1.V40.F5, 50970200
ffs offset/size [01]: 00C00000/00400000
version: 56B
provider: M295X-2BRGFRC
customization: CP56EK32
customization: XP56EK32
TCL-ID is present
ffs/eeprom address assigned: 00C00000
startup code area #1 fixed
sim-lock status: enabled
product id: JRD_COMMUNICATION_U82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
Write: security area (sec info, cust)
done
Write: security area (sec info, hash)
original imei: FFFFFFFFFFFFFF
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: D:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX295_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W0 8_36_SP1_V40_F5__system_log_CAD604C2_00029750_2011 0209-152312.B0X.bin
Finished, time used: 3 min 45 sec
The Following 3 Users Say Thank You to houssam19 For This Useful Post:
Old 02-19-2011, 17:24   #9011 (permalink)
sirnavid2010's Avatar
Member: 777729
Sonork: 100.1616470
Thanks Meter: 819
Nokia 5730 XpressMusic set factory done by best
Reading Phone Info....
Connected phone - Nokia 5730 XpressMusic
Software ver : V ICPR72_09w28.2 04-09-09 RM-465 (c) Nokia
IMEI : 351964033415540
Ape Ver : 200.12.87
APE Var : 200.12.87_rofs2200.12.87_rofs3
APE ADSP: 256
DSP Ver : ICPR72_09w26
APE Test: RM465ENOx0923v0.024
PPM :
CNT : 200.12.87
Product SN : CHI481143
Product code : 0579734
Base Prd.code: 0578138
Module code :
Long Prod.SN : 0
Hardware info=======
HWID : 0601
Retu : 16
Tahvo : 22
Batery: 4496 mV
Camera:
CMT BT:
APE BT:
APE HW: 256
LCDVer:
RF ic : |Vapaus_5.1 | ???
Lock info ===========
IMEI spNet :
IMEI svNet :
Conf key : 0000000000000000
Provider key : 2440700000000000
Provider : AT&T;U.S.A. (3650)
Counters : Key 0 [3] , Fbus 0 [10]
Blocks : 7
LOCK STATUS :
BLK : 1
Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS : All Open
User code : Crypted
UserDataExLevel : Low [Gallery]
Done!
Reading User code...
User Code is: Error! Crypted user code!
Done!
Resetting selected items...
Check phone mode...
Phone in Local mode
Seting Test mode... wait...
Test mode set
Settings Full Factory Defaults...
Set OK!
Elapsed: 00:00:08
The Following 3 Users Say Thank You to sirnavid2010 For This Useful Post:
Old 02-20-2011, 06:04   #9012 (permalink)
niloy2007's Avatar
Member: 1426012
Sonork: ICQ#618627674
Thanks Meter: 886
nokia 7210c successfull flash by best and rebild imei
i back up imei with mx-key and then erase full flash and then flash with best tool and rebuild imei with best which i have back up with mx-key
log
card found: S/N 00000:000000
registered to: PAUL-TELECOME
Connect phone on selected interface...
UFS S/N 000000 boot - Ok
Read and Check phone data...
BB5 bus checking...
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT ASICID : 000000010000022600010006030C192101033000
CMT EM0 ID : 00000295
CMT EM1 ID : 00000B22
CMT PUB ID : 0610010A5DBC7E56852FF0915CA4A22340DEC23F
CMT MODE ID : 00
CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROM ID : 273F6D55DFAAF68F
CMT : Sending 2nd loader...
Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0
CMT Loader sent, Boot Ok
MCU Configuration
FLASHID : 89820089 , CMT , NOR
CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512
FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
FLASHID : 0000FFFF , CMT , MMC , EXT
CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok
Sending ALGO....
Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1
CMT Algo sent
PAPUBkeys blank (erased or HW failure)
Transmission mode : Dual (Ddr, TX2)
Boot Done!
Init Service mode... Wait...
Init Service Mode Failed, can't proceed checking...
Core version : 1.16 , Rev : 2.1
Selected FlashSettings : Manual
Files Set for Flashing :
MCU : rm436__07.23.mcusw
PPM : rm436__07.23.ppm_c
CNT : rm436__07.23.image_c_de
Check FlashFiles, Please, wait...
-> SWversion check skipped : Dead mode selected
Backup enabled, Will read Certificates now...
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
Sending ALGO....
CMT Algo sent
Boot Done!
CMT : Read NPC certificate...
Cert size : 0 byte(s)
CMT : Read CCC certificate...
CMT : Read HWC certificate...
CMT : Read VARIANT certificate...
No any CRT data (MCU damaged/CERT erased), skip saving
Init Service Mode Failed!
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
Sending ALGO....
CMT Algo sent
Boot Done!
Erase : Processing rm436__07.23.mcusw
Found 6 areas to erase, erase group
Asic : CMT , Sub : NOR
CMT , NOR , Area : 0x00000000 - 0x000006BF
CMT , NOR , Area : 0x000006C0 - 0x0001FFFF
CMT , NOR , Area : 0x00040000 - 0x000BFFFF
CMT , NOR , Area : 0x000C0000 - 0x0013FFFF
CMT , NOR , Area : 0x00140000 - 0x0119FFFF
CMT , NOR , Area : 0x011A0000 - 0x0133FFFF
Using TimeOut : 5 min ( 300 sec )
Erasing, wait.....
CMT : Group erase Ok
TIME : Erase time : 00:00:04
Write : Processing rm436__07.23.mcusw
CMT: Writing Hash CERT [NOLO]
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [PASUBTOC]
CMT: Writing Hash CERT [PAPUBKEYS]
CMT: Writing Hash CERT [UPDAPP]
CMT: Writing Hash CERT [DSP0]
CMT: Writing Hash CERT [MCUSW]
Total writen 1161 blocks
TIME : Write time : 00:02:13
Erase : Processing rm436__07.23.ppm_c
Found 1 areas to erase, erase group
CMT , NOR , Area : 0x01340000 - 0x01BDFFFF
Erasing, wait.....
TIME : Erase time : 00:00:02
Write : Processing rm436__07.23.ppm_c
Total writen 448 blocks
TIME : Write time : 00:00:50
ConvertImage: Processing rm436__07.23.image_c_de
ConvertImage: Page Size is 128K, no need convert
Erase : Processing rm436__07.23.image_c_de
Found 2 areas to erase, erase group
CMT , NOR , Area : 0x01BE0000 - 0x01F7FFFF
CMT , NOR , Area : 0x01F80000 - 0x03FBFFFF
Erasing, wait.....
TIME : Erase time : 00:00:08
Write : Processing rm436__07.23.image_c_de
Total writen 1424 blocks
TIME : Write time : 00:02:40
Connected phone - Nokia 7210 Supernova
Software Info: V 07.23
17-07-09
RM-436
(c) Nokia
IMEI: 12345610654321?
Product code: 0572879
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Settings After Flash Defaults...
FullFactorySet...OK!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Product code update...
Checking User Certificates...
Total - 0 certs
Uploading certificates...
Writen 21 certs!
AfterFlash operations done... Reconnect, wait...
Phone found!
Series 40 Device detected!
read info... - Ok
Will Write RPL keys now...
Check RPL file...
NPC Data found!
CCC Data found!
HWC Data found!
SimLock Data found!
SimLock key found!
SuperDongle Key found!
CMLA key found!
WMDRM key found!
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
FLCNT : 00000000000000000000000000000000000000
Sending ALGO....
CMT Algo sent
CMT PAPUB : DCA5EA5203CD30A64D4D95ABCD621F4AB23026F100
Boot Done!
Preparing for write certificates...
CMT : NPC erase Ok
Writing NPC... Ok
CMT : CCC erase Ok
Writing CCC... Ok
CMT : HWC erase Ok
Writing HWC... Ok
Check phone mode...
Phone in Local mode
Test mode set
Writing SimLock Data... Ok
Writing SimLock Key... Ok
Writing Super Dongle Key... Ok
SDD Key status : SD Data is Ok
Done!
Phone found!
read info... - Ok
The Following 3 Users Say Thank You to niloy2007 For This Useful Post:
Old 02-20-2011, 08:29   #9013 (permalink)
naveedbutt's Avatar
Member: 1015336
Sonork: 100.1608410
Thanks Meter: 812
module v3.25
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:7F03:0001
status: FF
Boot Done
flash: B0001D00000000:B0001D00000000
flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
115200
Set baud Done
warning: wrong data size at 0x00021718, retry...
error: too many retries during read operation
TCL-ID is absent
error: no any expected answer
error: can't read startup code area #1
rom info ver: 04
sw version: BB13_PCB01_GPRS_MT6225_S00.BB13-2_BLE_L7EN_210_080709_HRILI9320_SIV0_WI75_CTF_BT_R DAFM.BIN
project-id: BB13-2_BLE_L7EN_210_080709_HRILI9320_SIV0_WI75_CTF_BT_R DAFM, E2623F70
TCL-ID is absent
error: no any expected answer : wrong answer after chip id request
error: no any expected answer : wrong answer after chip cfi request
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
ffs/eeprom chip: 00
error: unexpected termination/freez: 00000000
error: connection lost
Finished, time used: 2 min 2 sec
The Following 2 Users Say Thank You to naveedbutt For This Useful Post:
Old 02-20-2011, 08:31   #9014 (permalink)
Member: 777729
Sonork: 100.1616470
Thanks Meter: 819
n81 flash done by best 1.16
MCU : RM223_24.0.002_prd.C00
PPM : RM223_24.0.002_prd_0801.V08
CNT : RM223_24.0.002_003_000_U02_uda.fpsx
Flashing phone now...
Check files done...
-> Check SW version...
FlashFile version : 24.0.002
Phone version : 11.0.045
-> Check SW version : Upgrade
Backup CRT308 data...
CRT308 Backup Created...
SimLock Data saved...
SimLock Key saved...
WMDRM_PD Data saved...
RPL saved : F:\BEST-INFINITY\Backup\Cert\356994014975324_SIM.rpl
Check communication with phone....
ADL req restart
Communication verify done... Preparing...
Gathering phone info...
Reboot....
Connection opened successfully
Waiting for communication response...
[BB5 FLASH]: Bootrom Ok!
ASIC ID: 000000010000022600010006400C192101021103
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 14800103BF59005207CE4B752D40CC389193B0DB
ASIC MODE ID: 00
ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C
ROM ID: A8C1D6713E691FF8
PatchRAWLoader: Patched OK
Processing RAWLOADER...
Processing UPDAPP...
Boot Done!
TIME : Boot time : 00:00:04
Reopening the connection...
Waiting for response: 30
Waiting for response: 29
ADL Server confirm flashmode!
Get req info : empty
ADL : ASIC CMT select Ok
===Flashing [MCU]===
Erase : Processing RM223_24.0.002_prd.C00
Found 3 areas to erase
Erasing area 0x00040000 - 0x00082FFF, NAND, CMT
Result: 0000
Erasing area 0x00083400 - 0x0087FFFF, NAND, CMT
Result: 0000
Erasing area 0x00B80000 - 0x05F7FFFF, NAND, CMT
Result: 0000
Partition erase not allowed by loader
Partitioning : Ok [6]
TIME : Erase time : 00:00:01
Write : Processing RM223_24.0.002_prd.C00
Total 421 [421/0/0] blocks to write, writing...
CMT : Writing Hash CERT [ADA]
CMT : Writing Hash CERT [KEYS]
CMT : Writing Hash CERT [PRIMAPP]
CMT : Writing Hash CERT [RAP3NAND]
CMT : Writing Hash CERT [PASUBTOC]
CMT : Writing Hash CERT [PAPUBKEYS]
CMT : Writing Hash CERT [SOS*UPDAPP]
CMT : Writing Hash CERT [SOS*DSP0]
CMT : Writing Hash CERT [SOS*ISASW]
CMT : Writing Hash CERT [SOS*CORE]
CMT : Writing Hash CERT [SOS+ROFS]
TIME : Write time : 00:01:10
MCU Write done
===Flashing [PPM]===
Erase : Processing RM223_24.0.002_prd_0801.V08
Erasing area 0x03730000 - 0x05F7FFFF, NAND, CMT
Result: 0000
TIME : Erase time : 00:00:00
Write : Processing RM223_24.0.002_prd_0801.V08
Total 236 [236/0/0] blocks to write, writing...
CMT : Writing Hash CERT [SOS+ROFX]
TIME : Write time : 00:00:48
PPM Write done
===Flashing [CNT]===
Erase : Processing RM223_24.0.002_003_000_U02_uda.fpsx
Erasing area 0x05F80000 - 0x079DFFFF, NAND, CMT
Result: 0000
Write : Processing RM223_24.0.002_003_000_U02_uda.fpsx
Total 1 [1/0/0] blocks to write, writing...
TIME : Write time : 00:00:00
CNT Write done
ADL : End flashing
ADL : Finalize...
Flashing done!
Total flash time : 00:02:00
Reboot phone now...
Connected phone - Nokia N81
Software Info: V 06wk41v62.7 06-10-09 RM-223 (c) Nokia
IMEI: 356994014975324
Ape Version: 24.0.002
Product code: 0550147
Checking...
Read Info Done!
SwUpgradeSet...OK!
Set phone to Normal mode...
Done!
Elapsed: 00:02:43
Phone found!
Series 60 Device detected!
read info... - Ok
Old 02-20-2011, 08:31   #9015 (permalink)
Member: 777262
Sonork: m_alis
Thanks Meter: 31
Talking Samsung-SCH- B319 unlocking done
COM105 [VCP0] selected
module v1.41
Device: Samsung-SCH-B209, B309, B319, B619, B339FM
connecting...
Connecting, wait...
step-1/1 done
step-1/2 done
step-1/3 done
step-1/4 done
step-1/5 done
step-2 done
step-3 done
operation finished
Finished, time used: 24 sec
The Following User Says Thank You to m_alis For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.60768 seconds with 9 queries
