Old 09-07-2009, 11:23   #901 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
C2500 REPAIR OK
COM3 [VCP0] selected
module v2.75
Action: reset settings
Model: Kyocera-C2500
Checking data, wait...
19200 autodetect
Initializing [6217:8A00]...
CPU: MT6217
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6217,E00
Date: 2004.07.02
Version: 1.1.1.4
Version: ARIZONA6217.W05.12.V31.4A
Version: ARIZONA6217.HW.B5
44 byte(s) read
imei: 10101010101010
connection Ok
building list...
done
items to clear: 174
warning: wrong packet cs
items cleared: 172 of 174
items remains: 0
Finished, time used: 58 sec
Remove/Install battery now !
The Following 2 Users Say Thank You to ehsas_ghum For This Useful Post:
Old 09-07-2009, 11:26   #902 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
KP199 USER LOCK OK
module v2.75
Action: read codes
unlock method: read codes
Model: LG-KP199
19200 autodetect
Initializing [6226:8A02:8A01]...
CPU: MT6226
chip: 0031:212C:4BCA
status: FF
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: 7S7339SA00-002-R1C
Version: EP2_HW
44 byte(s) read
imei: 35313302361841
connection Ok
157 byte(s) read
Phone lock: On
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 246810
Finished, time used: 15 sec
Old 09-07-2009, 17:21   #903 (permalink)
Member: 311615
Sonork: 100.1591575
Thanks Meter: 72
Its working
module v2.79
Action: unlock
unlock method: smart fast
Model: Fly-SX200
19200 autodetect
Initializing [6225:8A03:8A00]...
CPU: MT6225
chip: 0001:6503:0007
status: FF
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: MAUI.07A.W07.36.MP.V23
Version: EZIO25_07A_HW
44 byte(s) read
imei: 35342302011605
connection Ok
157 byte(s) read
reading data...
building new data...
writing data...
145 byte(s) read
reading data...
writing data...
verifying...
verification Ok
done
Finished, time used: 24 sec
I have unlock four pieces of these phone today after i created my own cable pinout
The Following 2 Users Say Thank You to Abishalom For This Useful Post:
Old 09-08-2009, 09:53   #904 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
COM4 [VCP0] selected
module v2.91
Device: Autodetect 6205-6227 NOR
Action: write NOR flash
write: Firmware
MT6225_GEMINI_PCB01_GPRS_MT6225_S00.SYGJ_6300_2_1_ 3_2__Nokia-6300-RM-249-2sim_16m_En_Ru_Fr_Es_Th_Vn_Tr_Farsi_Pt_Ar.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:ED03:0006
status: FF
boot packet size: 0400
Boot Done
Initialize ...
flash: 89881500010001:89881500000000
flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
921600
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device rom info...
detection phase #1...
detect device rom info finished
rom info structure: 2nd [standard] generation
rom info detection finished
rom info protocol ver: 04
ver. sw 1: MT6225_GEMINI_PCB01_GPRS_MT6225_S00.SYGJ_6300_2_1_ 3_2.BIN
ver. sw 2: SYGJ.6300.2.1.3.2, 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detect device sec info...
detect device sec info finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: MT6225_GEMINI_PCB01_GPRS_MT6225_S00.SYGJ_6300_2_1_ 3_2__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\MT6225_GEMINI_PCB 01_GPRS_MT6225_S00.SYGJ_6300_2_1_3_2__ffs_20090908-021442.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
startup code area #1 check...
startup code area #1 fixed
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Write Done
Finalization ...
Finalization Done
Finished, time used: 1274 sec
The Following 2 Users Say Thank You to cel_phon For This Useful Post:
Old 09-08-2009, 11:59   #905 (permalink)
R@ZIB-BD's Avatar
Member: 718425
Thanks Meter: 5,875
zte vodafone 125 unlock done
COM6 [VCP0] selected
Device: ZTE-125
Action: unlock
unlock method-1
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 01
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sta_20090908-160134.B1E.bin
loading data...
data loaded
reading [eeprom-sec]...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sec_20090908-160140.B1E.bin
reading [eeprom-complete]...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20090908-160148.B1E.bin
reading additional data...
done
backup critical area Done
Check memory...
current status: 0
Check memory Done
Write...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, Remove/Install battery now !
Time used: 48 sec
Unlock instruction:
1. Power-On phone
2. Enter code: 12345678
The Following 2 Users Say Thank You to R@ZIB-BD For This Useful Post:
Old 09-08-2009, 12:20   #906 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
module v2.91
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6226
high speed boot Off
chip: 0031FC1:AF46
status: FF
Date: 2005.04.12
Version: 1.0
Version: V860_B6.SUM.YL7770_1.2
Version: MTK_HW_JAVA
detecting structure #2...
done
60 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
building list...
done
items to clear: 206
items cleared: 206 of 206
building list...
done
items remains: 0
Finished, time used: 35 sec
Old 09-08-2009, 12:21   #907 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
module v2.91
19200 autodetect
CPU: MT6226
high speed boot Off
chip: 0031FC1:AF46
status: FF
Date: 2005.04.12
Version: 1.0
done
60 byte(s) read
connection Ok
building list...
done
items to clear: 206
building list...
done
items remains: 0
Old 09-08-2009, 13:43   #908 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
module v1.37
Device: Sony-Ericsson-K200i
"advanced chip detection" active
Action: flash write
skip: Firmware
skip: Flex/Customization
skip: Language Pack
write: FFS/File system
K200i_repair_ffs_01_master-reset[1].80E.bin
skip: Images
skip: Melody
skip: Eeprom
Boot ...
Press Power button now !
loading...
Boot done
Check connection ...
Check connection done
Set baud ...
203125
Set baud done
Check hardware ...
flash: 01227E22212200:92EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
software version: R1AB003
software version: CXC1250831
version flex: CDA102773/54
imei: 35617701515363
Check hardware done
Read data ...
reading Sony-Ericsson-K200i_35617701515363_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K200i_35617701515363_eeprom_calibration-1_20090908-063523.80E.bin
reading Sony-Ericsson-K200i_35617701515363_eeprom_calibration-2...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K200i_35617701515363_eeprom_calibration-2_20090908-063529.80E.bin
reading Sony-Ericsson-K200i_35617701515363_ffs...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K200i_35617701515363_ffs_20090908-063913.80E.bin
Read data done
Check data ...
Check data done
Write ...
Area: FFS/File system
flash: 01227E22212200:46237300000000
Write: FFS/File system
Write done
Finished, time used: 491 sec
Old 09-08-2009, 15:33   #909 (permalink)
shuric's Avatar
Member: 444532
Sonork: 100.1576960
Thanks Meter: 218
Alcatel C701x spunlock OK, thanks infinity team.
module v2.85
Device: Alcatel-C701X, C701A
"smart write" active
"format ffs" active
write: Firmware
C701X-2AALRU1_XC18BN27_JRD26_06A_PCB01_GPRS_MT6226_S02.M AUI_06A_W06_52_SP1_V17_2007-07-21_simfree_En_De_Ru_Bg_Ua.B0M.bin
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A03:8A02]...
CPU: MT6226
chip: 0031:647D:A000
status: 01
Boot Done
Initialize ...
flash: 01227E22302200:2BEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb
Initialize Done
Set baud ...
460800
Set baud Done
rom info structure: 2nd [enhanced] generation
startup code area #1 is Ok
startup code area #1 backup saved: D:\Program Files\InfinityBox\MModule\backup_security\id.04319 82D.[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V24.BIN_5534D09C].rpl
device-id: 0431982D
rom info protocol ver: 05
ver. sw 1: JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V24.BIN
ver. sw 2: MAUI.06A.W06.52.SP1.V24, 632FCBAA
ffs offset/size: 01200000/00E00000
ffs address assigned: 01200000
sim-lock status: disabled
original imei: 35320501148074
Write ...
startup code area #1 calculation...
file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-C701X,C701A_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_0 6A_W06_52_SP1_V24__system_log_0431982D_5534D09C_20 090908-212916.B0X.bin
Area: Firmware
Write: Firmware
security area (sec info, part #2) calculation...
customization: CC18BN27
done
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
security area (sec info, part #1) calculation...
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
Write Done
Finalization ...
ffs formatting...
Finalization Done
file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-C701X,C701A_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_0 6A_W06_52_SP1_V24__system_log_0431982D_5534D09C_20 090908-214426.B0X.bin
Finished, time used: 945 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following 2 Users Say Thank You to shuric For This Useful Post:
Old 09-08-2009, 15:45   #910 (permalink)
SHOEB AHMED's Avatar
Member: 161115
Sonork: Here you can find it...
Thanks Meter: 3,039
ZTE G R321 (Orange-Rome)
SP Unlock Successful
COM18[VCP0] selected
module v2.86
Action: unlock
Model: Orange-Rome
19200 autodetect
Initializing [6235:8A04:8A01]...
CPU: MT6235
chip: 0000:0000:0003
status: FF
rom: 4D573031
Hardware: MT6235,E04
Date: 2000.00.00
Version: 1.0
Version: ORANGE_ENG_EN_P107A1V1.0.4B02
Version: 08BZTENJ35_OG_08B
80 byte(s) read
imei: 35424903018737
connection Ok
186 byte(s) read
reading data...
reading data #4...
writing data...
174 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
The Following 2 Users Say Thank You to SHOEB AHMED For This Useful Post:
Old 09-09-2009, 08:59   #911 (permalink)
Member: 98928
Thanks Meter: 475
unlock J132 ok new security rom 502
here the log unlock J132 new security rom 502 thanks infinity team
==== log: [9/8/2009 9:32:05 AM] ====
COM12 [VCP2] selected
module v1.35
Device: Sony-Ericsson-J132
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Set baud ...
115200
Set baud done
Check hardware ...
flash: 2088C0FFFFFFFF:2088C000000000
flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb
Check hardware done
Read data ...
reading Sony-Ericsson-J132_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20090908-093315.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 84 sec
The Following 2 Users Say Thank You to bavesore For This Useful Post:
Old 09-09-2009, 09:09   #912 (permalink)
Cheater -Don't Deal with him-
Member: 283204
Sonork: 100.1577140
Thanks Meter: 1,098
<<<<Succsessfully unlock rome from orange r231 with infinity box>>>>
Here is log:
module v2.85
Action: unlock
Model: ZTE-R231
19200 autodetect
CPU: MT6235
status: FF
rom: 4D573031
Date: 2000.00.00
Version: 1.0
80 byte(s) read
imei: 35424903011073
connection Ok
186 byte(s) read
reading data...
reading data #2...
writing data...
174 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Br:
Harkishan
The Following 3 Users Say Thank You to Harkishan singh For This Useful Post:
Old 09-09-2009, 12:37   #913 (permalink)
Member: 679135
Sonork: 100.1606448
Thanks Meter: 436
UTstarcom GPRS779
COM2 [VCP0] selected
module v1.37
Device: UTstarcom-GPRS779
Action: unlock
Boot ...
boot version: 00020602
connecting...
Boot done
Set baud ...
812500
Set baud done
Check hardware ...
flash: 01227E22212200:8AEA0000000000
flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb
Check hardware done
Read data ...
reading UTstarcom-GPRS779_eeprom_calibration-1...
file saved: C:\Archivos de programa\InfinityBox\HModule\UTstarcom-GPRS779_eeprom_calibration-1_20090907-185049.92E.bin
reading UTstarcom-GPRS779_eeprom_calibration-2...
file saved: C:\Archivos de programa\InfinityBox\HModule\UTstarcom-GPRS779_eeprom_calibration-2_20090907-185452.92E.bin
Read data done
Check data ...
file saved: C:\Archivos de programa\InfinityBox\HModule\eeprom_20090907-185858.92E.bin
wait...
pass-1...
pass-2...
Check data done
Write ...
flash: 01227E22022201:FFFFFF00000000
Write: eeprom
Write done
Finished, time used: 533 sec
module v1.37
Action: unlock
Boot ...
connecting...
Boot done
Set baud ...
812500
Set baud done
Check hardware ...
Check hardware done
Read data ...
Read data done
Check data ...
wait...
pass-1...
pass-2...
Check data done
Write ...
Write: eeprom
Write done
The Following User Says Thank You to hvalero2001 For This Useful Post:
Old 09-09-2009, 12:40   #914 (permalink)
Member: 679135
Sonork: 100.1606448
Thanks Meter: 436
Motorola C139 u2
"repair mode" active
"soft restore" active
Action: flash
Write: Firmware
Write: Language Pack
Write: Flex
Skip: Eeprom
Device: C139,C140
Connect...
Press and HOLD Power button...
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
921600
Set Baud Done
Check Flash-1...
SW version: 1.3.07
HW version: _E88
LP ver: LPL_C139_LATAM_Z0G
Flex ver: FFL_C139_2P_Z2G
imei otp: 010802001098158
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Archivos de programa\InfinityBox\Moto01\backup_eeprom_calibrat ion_010802001098158_20090908-221003.31E.bin
imei eeprom: 010802001098158
Check Flash-2 Done
Write...
Writing: Firmware
Writing: Language Pack
Writing: Flex
Write Done
Finished, time used: 112 sec
Action: unlock
Device: C139,C140
Connect...
Connect Done
Boot...
Boot Done
Set Baud...
921600
Set Baud Done
Check Flash-1...
SW version: 1.3.07
HW version: _E88
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Archivos de programa\InfinityBox\Moto01\backup_eeprom_calibrat ion_010802001098158_20090908-220402.31E.bin
extra method pass-1...
reading ...
extra method pass-2...
Check Flash-2 Done
Write...
Write Done
Finished, time used: 63 sec
Old 09-09-2009, 12:43   #915 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
NOKIA 5800 REPAIR OK
module v2.91
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001E03:0000
status: FF
Boot Done
Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
Initialize Done
Set baud ...
921600
Set baud Done
New firmware detected (v.2.91, database date: 27.08.2009):
E90N_L2SM_PCB01_GPRS_MT6225_S00.E90N_L2SM_P1_V07_0 81122_WQVGA_CM30_SS75_CTF_BT_FM.BIN
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
ver. sw 1: E90N_L2SM_PCB01_GPRS_MT6225_S00.E90N_L2SM_P1_V07_0 81122_WQVGA_CM30_SS75_CTF_BT_FM.BIN
ver. sw 2: E90N_L2SM_P1_V07_081122_WQVGA_CM30_SS75_CTF_BT_FM, 00000000
ffs/eeprom found near: 00E00000
ffs/eeprom chip: 00
Write ...
Write Done
Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 39 sec
The Following User Says Thank You to ehsas_ghum For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.63527 seconds with 10 queries
