![]() | #9616 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,932 | COM7 [VCP0] selected module v3.01 Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:FF03:0007 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: GDL138_JWT-GFIVE_DSIM_ST_V07 Version: GOLDDRAGON25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35403303004243 connection Ok detecting structure #1... 1 5 8 9 10 12 13 14 done 178 byte(s) read reading data #2... 166 byte(s) read Phone lock: On Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 22556644 Finished, time used: 343 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to Qaisar Mahmood For This Useful Post: |
![]() | #9617 (permalink) |
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,932 | TTN Mobile D530i Register Mercuriy Done Thanks Infinity Team COM7 [Serial2] selected module v3.04 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: repair "Register mercury" ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:9403:0002 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: STANDARD_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12. BIN project-id: MAUI.GEMINI.W08.12, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... checking psn code area... .................................... present: psn code area detecting psn code area... ........ found: psn code area flash: EC257E25082501:18E59F00000000 flash: EC257E25082501:18E59F00000000 Write: psn code area psn code area is fixed detecting psn code area... ...... found: psn code area flash: EC257E25082501:18E59F00000000 flash: EC257E25082501:18E59F00000000 Write: psn code area psn code area is fixed detecting psn code area... .................................................. .................................................. .................................................. .................................................. ......................................... psn code area is absent or fixed already Finished, time used: 2 min 7 sec Remove/Install battery now ! |
![]() | #9618 (permalink) |
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,932 | Nokia 6500s Successfully Flash Connect phone on selected interface... Core version : 1.16 , Rev : 2.1 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm240__10.30.mcusw PPM : rm240__10.30.ppm_c CNT : rm240__10.30_ISM_001.image_c_tr_ctv_tr Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 0FC0000CCC137D56E32B7B17B81C8C4B67E92A38 CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL Server confirm flashmode! ===Flashing [MCU]=== Erase : Processing rm240__10.30.mcusw Found 5 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x01480000 - 0x015FFFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0147FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:05 Write : Processing rm240__10.30.mcusw Total 1316 [1316/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:39 MCU Write done ===Flashing [PPM]=== Erase : Processing rm240__10.30.ppm_c Found 1 areas to erase Erasing area 0x01600000 - 0x01CBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:39 Write : Processing rm240__10.30.ppm_c Total 411 [411/0/0] blocks to write, writing... TIME : Write time : 00:00:32 PPM Write done ===Flashing [CNT]=== Erase : Processing rm240__10.30_ISM_001.image_c_tr_ctv_tr Found 2 areas to erase Erasing area 0x01FC0000 - 0x03F9FFFF, NOR, CMT Result: 0000 Erasing area 0x01CC0000 - 0x01FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:33 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm240__10.30_ISM_001.image_c_tr_ctv_tr Total 736 [736/0/0] blocks to write, writing... TIME : Write time : 00:00:53 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:09:24 Reboot phone now... |
![]() | #9619 (permalink) |
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,932 | Nokia 5630 Flashing Successfully Connect phone on selected interface... Core version : 1.17 , Rev : 2.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Bad file : rm431_013.009_08.01_Hebrew_prd.rofs2.fpsx Bad Flash files detected, will break procedure Core version : 1.17 , Rev : 2.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm431_013.009_prd.core.fpsx PPM2 : rm431_013.009_218.05_Cellcom_IL_BR_prd.rofs3.fpsx CNT : rm431_013.009_U000.000_prd.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102011104 EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 294001122D630344C8128A6335085B756B7674B9 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.4.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.4.0 Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 35--------------- Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\35--------------------_CRT_2nd.rpl ===Flashing [MCU]=== Erase : Processing rm431_013.009_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm431_013.009_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 332 blocks TIME : Write time : 00:00:13 MCU Write done ADL: Request programm status NAND status : 00000004 / 00000004 / 00000000 ===Flashing [PPM2]=== Erase : Processing rm431_013.009_218.05_Cellcom_IL_BR_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm431_013.009_218.05_Cellcom_IL_BR_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 18 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000004 / 00000004 / 00000000 ===Flashing [CNT]=== Erase : Processing rm431_013.009_U000.000_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm431_013.009_U000.000_prd.uda.fpsx Total writen 40 blocks TIME : Write time : 00:00:01 CNT Write done ADL: Request programm status NAND status : 00000004 / 00000004 / 00000000 ADL: Close_Session Content: 000300000000040000000400000000 ADL: Reboot Flashing done! Total flash time : 00:00:17 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5630 Software Info: V ICPR82_09w36.3 22-09-09 RM-431 (c) Nokia IMEI: 35-------------------- Ape Version: 013.009 Product code: 0574961 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Set phone to Normal mode... AfterFlash operations done... Done! |
The Following 3 Users Say Thank You to Qaisar Mahmood For This Useful Post: |
![]() | #9620 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2007 Location: udaipur, I N D I A Age: 38
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | Repair " No license to Produce" DONE. Phone brand Airfone Model No. Af-111 ![]() Fw LInk http://rapidshare.com/files/45139979...0110307-203953 Code: COM6 [VCP0] selected module v3.27 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware GOLDDRAGON23D_09B_PCB01_GPRS_MT6223_S00.GD1101_V2_FDT_T32T3W0_DSIM_L3_V10__fullflash_20110307-203953.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:9888:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 2D0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.27, database date: 11.11.2009): GOLDDRAGON23D_09B_PCB01_GPRS_MT6223_S00.GD1101_V2_FDT_T32T3W0_DSIM_L3_V10.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: GOLDDRAGON23D_09B_PCB01_GPRS_MT6223_S00.GD1101_V2_FDT_T32T3W0_DSIM_L3_V10.BIN project-id: GD1101_V2_FDT_T32T3W0_DSIM_L3_V10, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: GOLDDRAGON23D_09B_PCB01_GPRS_MT6223_S00.GD1101_V2_FDT_T32T3W0_DSIM_L3_V10__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\GOLDDRAGON23D_09B_PCB01_GPRS_MT6223_S00.GD1101_V2_FDT_T32T3W0_DSIM_L3_V10__ffs_20110307-204336.B0E.bin flash: 2088C4FFFF0043:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... No licensed to produce fix... No licensed to produce done Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 2088C4FFFF0043:2088C400000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 2 min 19 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to himanshu taldar For This Useful Post: |
![]() | #9621 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,270 ![]() | Rm-365 3120c Report ok Code: registered to: mohsin Connect phone on selected interface... Core version : 1.17 , Rev : 2.3 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm364__10.00.mcusw PPM : rm364__10.00.ppm_m4 CNT : rm365__10.00_ISM_012.image_m4_graphite Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 15300015B59E025484E7FFD0D1012BC7602C7FAE CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm364__10.00.mcusw Found 5 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x01480000 - 0x015FFFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0147FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:44 Write : Processing rm364__10.00.mcusw Total 112 [112/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:53 MCU Write done ===Flashing [PPM]=== Erase : Processing rm364__10.00.ppm_m4 Found 1 areas to erase Erasing area 0x01600000 - 0x01CBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:26 Write : Processing rm364__10.00.ppm_m4 Total 20 [20/0/0] blocks to write, writing... TIME : Write time : 00:00:30 PPM Write done ===Flashing [CNT]=== Erase : Processing rm364__10.00_ISM_012.image_m4_graphite Found 2 areas to erase Erasing area 0x01FC0000 - 0x03F9FFFF, NOR, CMT Result: 0000 Erasing area 0x01CC0000 - 0x01FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:10 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm365__10.00_ISM_012.image_m4_graphite Total 35 [35/0/0] blocks to write, writing... TIME : Write time : 00:00:45 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:08:30 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 3120 classic Software Info: V 10.00 06-03-09 RM-365 (c) Nokia IMEI: 3557230233***** PPM version : V 10.00 06-03-09 RM-364 (c) Nokia M4 Product code: 0564517 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! Set phone to Normal mode... AfterFlash operations done... Done! Elapsed: 00:09:06 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 3 Users Say Thank You to Mohsin-* For This Useful Post: |
![]() | #9622 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2008 Location: Dubai
Member: 778507 Status: Offline Sonork: 100.1640413 Thanks Meter: 265 | Unlock N5000d-2 (RM-362) lock to Sun Cellular network heres the logs... Code: card found: S/N UTOL... registered to: Aermacchi ® Connect phone on selected interface... UFS S/N 34482 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! [DCT4+] read info... - Ok Reading Phone Info.... SW ver : V 05.27 05-11-08 RM-362 (c) Nokia IMEI : Error PPM : Error CNT : Content: opv_sun_green V 05.27 05-11-08 RM-362 (c) Nokia DSP Ver : Error PCode : Error BPCode : Error HWID : Error LCDVer : Error IMEI : Error Sl Conf : 515-05-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B5555 Hw Sig : 8801D7740B7A2B92 Provider : Sun Cellular ;Philippines Lock info: Block 1 L1:Close; Done! Write SL RPL procedure procedure started... Read Lock Info Locked to Sun Cellular ;Philippines Unlocking... All done ! Reading Phone Info.... SW ver : V 05.27 05-11-08 RM-362 (c) Nokia IMEI : Error PPM : Error CNT : Content: opv_sun_green V 05.27 05-11-08 RM-362 (c) Nokia DSP Ver : Error PCode : Error BPCode : Error HWID : Error LCDVer : Error IMEI : Error Sl Conf : 001-01-00000000000 Sl Prof : 000000000003000-B Sl Aux : 000B5555 Hw Sig : 8801D7740B7A2B92 Provider : Default Test Operator Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Done! |
The Following 3 Users Say Thank You to aermacchi For This Useful Post: |
![]() | #9623 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2006 Location: infinity cm2 best tool
Member: 416063 Status: Offline Thanks Meter: 27 | nokia 5220 sucessfull flash registered to: sarfaraz Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.17 , Rev : 2.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm411__07.23.mcusw PPM : rm411__07.23.ppm_mb CNT : rm411__07.23.image_mb_b_grey Flashing phone now... Check files done... -> Check SW version... FlashFile version : 07.23 Phone version : 07.23 17-07-09 RM-411 (c) Nokia -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created... ![]() SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\353662013552641_SI M.rpl Getting product info... RAP_BOOT: 0803000302010000 RAP_PUBLIC: 1510020DE4D35550E815B24E0CC5F073D16B2996 CMT_ROOTKEY: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP_PAPUBKEY: D93826B23E9B093BE4DD7304FBAA6778996AE60B Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm411__07.23.image_mb_b_grey ConvertImage: Page Size is 128K, no need convert Loader len: 307008, CHK: C0CE ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 Waiting for response: 26 Waiting for response: 25 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm411__07.23.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:32 Write : Processing rm411__07.23.mcusw Total 1289 [1289/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:42 MCU Write done ===Flashing [PPM]=== Erase : Processing rm411__07.23.ppm_mb Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:02 Write : Processing rm411__07.23.ppm_mb Total 400 [400/0/0] blocks to write, writing... TIME : Write time : 00:00:20 PPM Write done ===Flashing [CNT]=== Erase : Processing rm411__07.23.image_mb_b_grey Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:06:21 Write : Processing rm411__07.23.image_mb_b_grey Total 472 [472/0/0] blocks to write, writing... TIME : Write time : 00:00:23 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:12:23 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5220 XpressMusic Software Info: V 07.23 17-07-09 RM-411 (c) Nokia IMEI: 353662013552641 PPM version : V 07.23 17-07-09 RM-411 (c) Nokia MB Product code: 0577202 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:13:21 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 3 Users Say Thank You to raajaa For This Useful Post: |
![]() | #9624 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2007
Member: 633231 Status: Offline Thanks Meter: 666 | COM10 [VCP0] selected module v3.77 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G5010 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:A793:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: A1.1DC01V01.05 Version: BYD23C_08B_PMWY_HW ==================== New firmware found (v.3.77, database date: 01.03.2011): A1.1DC01V01.05 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 80 byte(s) read imei: 01211500246715 connection Ok 185 byte(s) read reading data... building new data... writing data... 173 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 17 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to thewolverine For This Useful Post: |
![]() | #9625 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | Lg Kg110 rapaired COM6 [VCP0] selected module v1.36 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 354701015005825 current otp imei: 354701015005825 file saved: C:\Program Files\InfinityBox\LGA\eeprom_354701015005825_LG-KG110_20110307-185232.B1E.bin ........ version: 404-XXV20a91KG110P40FL reading 404-XXV20a91KG110P40FL_eeprom-ffs_354701015005825... file saved: C:\Program Files\InfinityBox\LGA\404-XXV20a91KG110P40FL_eeprom-ffs_354701015005825_LG-KG110_20110307-185646.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 305 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to akashub For This Useful Post: |
![]() | #9626 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM2 [VCP1] selected module v3.78 Device: Spice-S410 Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write method: mode-3 new imei: 353923031599703 ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: STANDARD_PCB01_GSM_MT6205B_DN.KACS410_INA_EN_HI_4_ 02_330.BIN project-id: KACS410_INA_EN_HI_4.02_330, 00000000 code offset: 00000000 ffs offset/size [01]: 00380000/00080000 rom info structure: [standard] type (04) TCL-ID is absent ffs/eeprom address assigned: 00380000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Spice-S410_STANDARD_PCB01_GSM_MT6205B_DN.KACS410_INA_EN_ HI_4_02_330__ffs... file saved: C:\InfinityBox\MModule\Spice-S410_STANDARD_PCB01_GSM_MT6205B_DN.KACS410_INA_EN_ HI_4_02_330__ffs_20110308-104304.B0E.bin flash: 01227E221A2201:18E59F00000000 Backup required data Done ====> Patch required data ... 2 step(s) required Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 01227E221A2201:18E59F00000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 55 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to joni_rajpura For This Useful Post: |
![]() | #9627 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007 Location: shirdi..sai baba.. Age: 37
Member: 662678 Status: Offline Thanks Meter: 2,541 | COM16 [VCP0] selected module v1.48 Device: Samsung-SCH-B139, B189 operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 20 sec |
The Following User Says Thank You to ..::ohm::.. For This Useful Post: |
![]() | #9628 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2009 Location: kanpur
Member: 1108057 Status: Offline Sonork: harvinder Thanks Meter: 131 | COM60 [QCUSB_COM60_2] selected module v1.48 Device: ZTE-S131 operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... send spc... disabling minlock... Done... Phones should be restarting now... Finished, time used: 6 sec |
The Following 2 Users Say Thank You to harvinder43 For This Useful Post: |
![]() | #9629 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007 Location: Mumbai--Great INDIA
Member: 665441 Status: Offline Sonork: 100.1670531 Thanks Meter: 603 | CIK.4.01Jun 30 2010 MICROMAX C111 30 Jun 2010 selected.. Offline.. Sending Boot.. patching in progress.. patching in progress 50%... patching in progress 100%... Done... Finished, time used: 29 sec |
The Following 2 Users Say Thank You to hanif007 For This Useful Post: |
