03-27-2011, 09:27 | #10321 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 534 | module v3.80 Device: Alcatel-305X, 305A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:A88A:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.634757A1 .[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_6B2FA2BD].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 634757A1 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, BDA22F6B code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 164 provider: 305X-2DVDKE1 customization: CP16CH10 customization: XP16CH10 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XP16CH10 customization name adjusted flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2BEA0000000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__system_log_634757A1_6B2FA2BD_201 10327-002258.B0X.bin Finished, time used: 3 min 13 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to KYEJUSA For This Useful Post: |
03-27-2011, 11:31 | #10322 (permalink) |
No Life Poster Join Date: May 2010 Location: Shaker-Telecom BaNgLaDeSh
Member: 1296389 Status: Offline Sonork: 100.1618052 Thanks Meter: 268 | Nokia 6303 Report ok card found: S/N 0433:0118 registered to: saker2050 Connect phone on selected interface... Connect phone on selected interface... Core version : 1.18 , Rev : 3.0 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm443__10.10.mcusw PPM : rm443__10.10.ppm_i CNT : rm443__10.10.image_i_silverbrown Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! [BB5 FLASH]: GetFirstBlock Failed, Aborting -> Error answer from BootRom -> 1. Try make battery charge -> 2. Try insert charger, without pressing poweron -> 3. Try change USB port, if driver hang - restart PC Connect phone on selected interface... -> Error while flashing... Core version : 1.18 , Rev : 3.0 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm443__10.10.mcusw PPM : rm443__10.10.ppm_i CNT : rm443__10.10.image_i_silverbrown Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 17D00009539D7D56F7426BDC5AF19F95E871FF80 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm443__10.10.mcusw Found 8 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x0005FFFF, NOR, CMT Result: 0000 Erasing area 0x00060000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x0015FFFF, NOR, CMT Result: 0000 Erasing area 0x00160000 - 0x0023FFFF, NOR, CMT Result: 0000 Erasing area 0x01740000 - 0x0191FFFF, NOR, CMT Result: 0000 Erasing area 0x00240000 - 0x0173FFFF, NOR, CMT Result: 0000 Erasing area 0x022E0000 - 0x0261FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:30 Write : Processing rm443__10.10.mcusw Total 1597 [1597/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [ISA+DYNSW] TIME : Write time : 00:01:04 MCU Write done ===Flashing [PPM]=== Erase : Processing rm443__10.10.ppm_i Found 1 areas to erase Erasing area 0x01920000 - 0x022DFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:12 Write : Processing rm443__10.10.ppm_i Total 429 [429/0/0] blocks to write, writing... TIME : Write time : 00:00:17 PPM Write done ===Flashing [CNT]=== Erase : Processing rm443__10.10.image_i_silverbrown Found 2 areas to erase Erasing area 0x02620000 - 0x029BFFFF, NOR, CMT Result: 0000 Erasing area 0x029C0000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:04:23 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm443__10.10.image_i_silverbrown Total 640 [640/0/0] blocks to write, writing... TIME : Write time : 00:00:26 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:10:55 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6303 classic Software Info: V 10.10 18-11-09 RM-443 (c) Nokia IMEI: 356036030407401 PPM version : V 10.10 18-11-09 RM-443 (c) Nokia I Product code: 0569439 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! |
The Following 3 Users Say Thank You to saker2050 For This Useful Post: |
03-27-2011, 13:52 | #10323 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 354975 Status: Offline Sonork: Love For All Thanks Meter: 462 | G6620 unlock done with infinty COM15 [VCP0] selected module v3.80 Action: read unlock codes unlock method: read codes Model: Huawei-G6620 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: G6620SS.C210.M40.04.05 Version: CKT53_12832_09B_HW 116 byte(s) read imei: 35194804262110 connection Ok 217 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 205 byte(s) read reading data... 220 byte(s) read lock[1] code: + 41173801 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 13 sec Remove/Install battery now ! |
The Following User Says Thank You to niceraees For This Useful Post: |
03-27-2011, 13:52 | #10324 (permalink) |
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 534 | VODAFONE-150 UNLOCKED module v3.80 Device: Vodafone-150 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:56E9:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 8C22F60000000D:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 00390000/00068000 TCL-ID identification version: 16H provider: 150X-2AVDKE1 customization: CW16CD60 customization: XW16CD60 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 00390000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XW16CD60 customization name adjusted flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: 8C22F60000000D:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 8C22F60000000D:2BEA0000000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Vodafone-150_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W0 8_36_SP1_V28_F1__system_log__00000000_20110327-045004.B0X.bin Finished, time used: 1 min 59 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
03-27-2011, 13:57 | #10325 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 35
Member: 1157320 Status: Offline Thanks Meter: 6,192 | N73, was dead, JAF only Checking Code: Connect phone on selected interface... Opening Connection... Device Location: 00000033 Connect Ok! Initializing Connection... JAF Firmware: 01.B1 JAF S/N ODJAF000 boot - Ok Connect phone on selected interface... Ready for operations... Read and Check phone data... Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 9D22AB1D1DFDF8BE969C687FFDF5F085503713AC APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 0810010E1F8C4F5088216061C5927A943C0CD876 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU configuration CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLASHID : 22E800EC , CMT , NOR FLCNT : 00000000000000000000000000000000000000 CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok FLASHID : 0000FFFF , CMT , MMC , EXT TransmissionReq : 16 bit, Single TransmissionReq : Accepted, 16 bit, Single Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent! TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual PAPUBKeys : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBD APE : Sending 2nd loader... Use : helen3_2nd.fg APE Loader sent, Boot Ok MCU configuration APE Flash ID : 00A100EC < SAMSUNG [SEC] => K5E1G12ACM [NAND] FLASHID : 00A100EC , APE , NAND FLCNT : 010100FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Sending ALGO.... Use : h3_xsr15_flash_alg.fg APE Algo sent! TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual PAPUBKeys : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBD Boot done! Switch jaf to FBUS... FbusMode set Ok Phone not found :( Flashing Code: Ready for operations... Core version : 1.18 , Rev : 3.0 Selected FlashSettings : Manual Files Set for Flashing : MCU : N73_4.0839.42.0.1_western_C00_PRD_cc.fpsx PPM : N73_rofx_4.0839.42.0.1_PRD.V05 CNT : N73_userarea_4.0839.42.0.1.U01 Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 9D22AB1D1DFDF8BE969C687FFDF5F085503713AC APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 0810010E1F8C4F5088216061C5927A943C0CD876 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU configuration CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLASHID : 22E800EC , CMT , NOR FLCNT : 00000000000000000000000000000000000000 CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok FLASHID : 0000FFFF , CMT , MMC , EXT TransmissionReq : 16 bit, Single TransmissionReq : Accepted, 16 bit, Single Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent! TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual PAPUBKeys : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBD APE : Sending 2nd loader... Use : helen3_2nd.fg APE Loader sent, Boot Ok MCU configuration APE Flash ID : 00A100EC < SAMSUNG [SEC] => K5E1G12ACM [NAND] FLASHID : 00A100EC , APE , NAND FLCNT : 010100FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Sending ALGO.... Use : h3_xsr15_flash_alg.fg APE Algo sent! TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual PAPUBKeys : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBD Boot done! CMT : Read NPC certificate... IMEI : 353546024492410 CMT : Read CCC certificate... CMT : Read HWC certificate... APE : Read NPC certificate... APE : Read CCC certificate... APE : Read HWC certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... (APE) RPL saved : C:\BEST\1.19\Backup\Cert\353546024492410_CRT.rpl Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 9D22AB1D1DFDF8BE969C687FFDF5F085503713AC APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 0810010E1F8C4F5088216061C5927A943C0CD876 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU configuration CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLASHID : 22E800EC , CMT , NOR FLCNT : 00000000000000000000000000000000000000 CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok FLASHID : 0000FFFF , CMT , MMC , EXT TransmissionReq : 16 bit, Single TransmissionReq : Accepted, 16 bit, Single Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent! TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual PAPUBKeys : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBD APE : Sending 2nd loader... Use : helen3_2nd.fg APE Loader sent, Boot Ok MCU configuration APE Flash ID : 00A100EC < SAMSUNG [SEC] => K5E1G12ACM [NAND] FLASHID : 00A100EC , APE , NAND FLCNT : 010100FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Sending ALGO.... Use : h3_xsr15_flash_alg.fg APE Algo sent! TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual PAPUBKeys : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBD Boot done! Partitioning.... Partitioning Ok... TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Erase : Processing N73_4.0839.42.0.1_western_C00_PRD_cc.fpsx Init Erase Mode Ok Found 4 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00080000 - 0x0073194D CMT , NOR , Area : 0x00000000 - 0x0005FFFF CMT , NOR , Area : 0x001E0000 - 0x001FFFFF CMT , NOR , Area : 0x00880000 - 0x00FEFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok Found 4 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x00000000 - 0x0007FFFF APE , NAND , Area : 0x00080000 - 0x000FFFFF APE , NAND , Area : 0x00100000 - 0x0025FFFF APE , NAND , Area : 0x003C0000 - 0x04E1FFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:46 PrReq : NOR, 00 PrReq : NAND, 010300000000000000000000000000 TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Write : Processing N73_4.0839.42.0.1_western_C00_PRD_cc.fpsx Init Write Mode Ok CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [ADL] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] APE: Writing Hash CERT [KEYS] APE: Writing Hash CERT [X-LOADER] APE: Writing Hash CERT [PRIMAPP] APE: Writing Hash CERT [SOS+LOADER] APE: Writing Hash CERT [SOS*UPDAPP] APE: Writing Hash CERT [SOS+UZIP] APE: Writing Hash CERT [PAPUBKEYS] APE: Writing Hash CERT [PASUBTOC] APE: Writing Hash CERT [ADL] APE: Writing Hash CERT [SOS+XZIP] APE: Writing Hash CERT [SOS*CORE] APE: Writing Hash CERT [SOS+ROFS] APE: Writing Hash CERT [SOS+ROFX] Total writen 1704 blocks TIME : Write time : 00:04:23 PrReq : NOR, 00 PrReq : NAND, 010300000000000000000000000000 Partitioning.... Partitioning Ok... TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Erase : Processing N73_rofx_4.0839.42.0.1_PRD.V05 Init Erase Mode Ok Found 1 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x03920000 - 0x04E1FFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:01 PrReq : NOR, 00 PrReq : NAND, 010300000000000000000000000000 TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Write : Processing N73_rofx_4.0839.42.0.1_PRD.V05 Init Write Mode Ok APE: Writing Hash CERT [SOS+ROFX] Total writen 2071 blocks TIME : Write time : 00:02:44 PrReq : NOR, 00 PrReq : NAND, 010300000000000000000000000000 TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Erase : Processing N73_userarea_4.0839.42.0.1.U01 Init Erase Mode Ok Found 1 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x04E20000 - 0x07C9FFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:01 PrReq : NOR, 00 PrReq : NAND, 010300000000000000000000000000 TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Write : Processing N73_userarea_4.0839.42.0.1.U01 Init Write Mode Ok Total writen 164 blocks TIME : Write time : 00:00:27 PrReq : NOR, 00 PrReq : NAND, 010300000000000000000000000000 Switch jaf to FBUS... FbusMode set Ok Phone connected IMEI : 353546024492410 Simlock status : Simlock is Ok Security status : Security is Ok Settings After Flash Defaults... FullFactorySet...OK! Flashing done Ready for operations... |
The Following 3 Users Say Thank You to Dzirt For This Useful Post: |
03-27-2011, 14:13 | #10326 (permalink) |
No Life Poster Join Date: May 2008 Location: NC, USA Age: 36
Member: 779665 Status: Offline Sonork: 100.1581784 Thanks Meter: 492 | 6700S Code: Connect phone on selected interface... Core version : 1.18 , Rev : 3.0 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm576_061.004_prd.core.fpsx PPM : rm576_061.004_05.01_Russian_prd.rofs2.fpsx CNT : rm576_061.004_URed006.000_prd.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102011104 EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 23200214B07903449E099334529AA564C540CA61 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.4.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.4.0 Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 353390043471083 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\353390043471083_CRT.rpl ===Flashing [MCU]=== Erase : Processing rm576_061.004_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm576_061.004_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 366 blocks TIME : Write time : 00:00:13 MCU Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [PPM]=== Erase : Processing rm576_061.004_05.01_Russian_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm576_061.004_05.01_Russian_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 154 blocks TIME : Write time : 00:00:06 PPM Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [CNT]=== Erase : Processing rm576_061.004_URed006.000_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm576_061.004_URed006.000_prd.uda.fpsx Total writen 16 blocks TIME : Write time : 00:00:01 CNT Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ADL: Close_Session Content: 000300000000030000000300000000 ADL: Reboot Flashing done! Total flash time : 00:00:23 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6700s Software Info: V ICPR82_10w34.2 15-10-10 RM-576 (c) Nokia IMEI: 353390043471083 Ape Version: 061.004 Product code: 0589292 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Set phone to Normal mode... AfterFlash operations done... Done! Elapsed: 00:01:38 Connect phone on selected interface... |
The Following 3 Users Say Thank You to nadirghazi For This Useful Post: |
03-27-2011, 15:07 | #10328 (permalink) |
Freak Poster Join Date: Dec 2009 Location: near the mosque
Member: 1187394 Status: Offline Thanks Meter: 14 | 6300 flach "lang" card found: S/N 1D1F:0118 registered to: barika05 Connect phone on selected interface... UFS S/N 84512 boot - Ok Connect phone on selected interface... Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 1B600206C4517056BF990F0551E74D65FBEC69D8 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 00410001 , CMT , NOR CMT Flash ID : 00410001 < SPANSION => 72NS256PD FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 7E6491E8D30494B45630BB3A8599F4E1C674C95500 Transmission mode : Dual (Ddr, TX2) Boot Done! Init Service mode... Wait... SimLock status : SimLock is Ok Security status : Security is Ok SDD Key status : SD Data is Ok PA_SimLock Version : PA_SL phone detected Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.18 , Rev : 3.0 Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm217__07.30.mcusw PPM : rm217__07.30.ppm_c CNT : rm217__07.30.image_c_tr Check FlashFiles, Please, wait... -> SWversion check skipped : Manual mode selected Backup enabled, Will read Certificates now... Backup CRT308 CRT308 Backup Created... CRT308 Backup Created... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 1B600206C4517056BF990F0551E74D65FBEC69D8 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 00410001 , CMT , NOR CMT Flash ID : 00410001 < SPANSION => 72NS256PD FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 7E6491E8D30494B45630BB3A8599F4E1C674C95500 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 12288 byte(s) IMEI : 353510028143999 CMT : Read CCC certificate... Cert size : 8192 byte(s) CMT : Read HWC certificate... Cert size : 12288 byte(s) CMT : Read VARIANT certificate... Cert size : 20480 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\353510028143999.rp l Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 1B600206C4517056BF990F0551E74D65FBEC69D8 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 00410001 , CMT , NOR CMT Flash ID : 00410001 < SPANSION => 72NS256PD FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 7E6491E8D30494B45630BB3A8599F4E1C674C95500 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm217__07.30.mcusw Found 9 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00020000 - 0x0007FFFF CMT , NOR , Area : 0x00080000 - 0x000DFFFF CMT , NOR , Area : 0x00100000 - 0x001FFFFF CMT , NOR , Area : 0x00200000 - 0x0031FFFF CMT , NOR , Area : 0x00320000 - 0x0105FFFF CMT , NOR , Area : 0x01060000 - 0x01067FFF CMT , NOR , Area : 0x01068000 - 0x0107FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:07 Transmission mode : Dual (Ddr, TX2) Write : Processing rm217__07.30.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [PMM_CONF] CMT: Writing Hash CERT [SBIF_CONF] Total writen 943 blocks TIME : Write time : 00:01:38 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm217__07.30.ppm_c Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01080000 - 0x015FFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:19 Transmission mode : Dual (Ddr, TX2) Write : Processing rm217__07.30.ppm_c Total writen 289 blocks TIME : Write time : 00:00:30 CNT : Converted to 128k page data exist Transmission mode : Dual (Ddr, TX2) Erase : Processing rm217__07.30.image_c_tr_128 Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01600000 - 0x01FDFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:41 Transmission mode : Dual (Ddr, TX2) Write : Processing rm217__07.30.image_c_tr_128 Total writen 224 blocks TIME : Write time : 00:00:23 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 6300 Software Info: V 07.30 07-05-09 RM-217 (c) Nokia. IMEI: 353510028143999 Product code: 0515919 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 3 Users Say Thank You to barika05 For This Useful Post: |
03-27-2011, 15:25 | #10329 (permalink) |
No Life Poster Join Date: Apr 2010
Member: 1277468 Status: Offline Sonork: 100.1603661 Thanks Meter: 701 | Huawei G6603 unlock done........ huawei G6603 unlock done with infinity box.. COM4 [VCP1] selected module v3.73 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G6603 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E5.2EU01V01.03 Version: BYD35_09A_PMWY_HW 82 byte(s) read imei: 3535370408?????? connection Ok 189 byte(s) read reading data... reading data #2... building new data... writing data... 177 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 14 sec Remove/Install battery now ! thanks to infinity team br:. shabir97 |
The Following User Says Thank You to shabir97 For This Useful Post: |
03-28-2011, 06:07 | #10330 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,080 | 6500s USB Flashed[CODE]card found: S/N 012345678 registered to: xerraco Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 6500s-1 Software ver : V 10.30 23-04-09 RM-240 (c) Nokia IMEI : 357659016728935 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR71_09w03 APE Test: PPM : V 10.30 23-04-09 RM-240 (c) Nokia C CNT : Content: _pre_c V 10.30 23-04-09 RM-240 (c) Nokia Product SN : CTF491585 Product code : 0549752 Base Prd.code: 0543753 Module code : 0203327 Long Prod.SN : 0 Hardware info======= HWID : 1001 Retu : 15 Tahvo : 22 Batery: 3693 mV Camera: CMT BT: 2222-143 APE BT: APE HW: LCDVer: SEIKO RF ic : Lock info =========== IMEI : 357659016728935 IMEI spNet : 3A 75 56 09 61 27 98 03 IMEI svNet : 33 75 56 09 61 27 98 73 F8 Conf key : 8000000000000002 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created... User Code : not set MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Core version : 1.18 , Rev : 3.0 Selected FlashSettings : Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm240__10.30.mcusw PPM : rm240__10.30.ppm_c CNT : rm240__10.30_ISM_008.image_c_tr_brown Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Getting product info... RAP_BOOT: 0803000002010000 RAP_PUBLIC: 2320010CCC704950FF2C608220F5937CA21CA2CE CMT_ROOTKEY: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP_PAPUBKEY: A69838E8C5F20150E64E2E6E06DE6E50B26B593F Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm240__10.30_ISM_008.image_c_tr_brown ConvertImage: Page Size is 128K, no need convert Loader len: 294144, CHK: 6A87 ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 ADL Server confirm flashmode! ===Flashing [MCU]=== Erase : Processing rm240__10.30.mcusw Found 5 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x01480000 - 0x015FFFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0147FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:09 Write : Processing rm240__10.30.mcusw Total 1316 [1316/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:02:17 MCU Write done ===Flashing [PPM]=== Erase : Processing rm240__10.30.ppm_c Found 1 areas to erase Erasing area 0x01600000 - 0x01CBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:45 Write : Processing rm240__10.30.ppm_c Total 411 [411/0/0] blocks to write, writing... TIME : Write time : 00:00:47 PPM Write done ===Flashing [CNT]=== Erase : Processing rm240__10.30_ISM_008.image_c_tr_brown Found 2 areas to erase Erasing area 0x01FC0000 - 0x03F9FFFF, NOR, CMT Result: 0000 Erasing area 0x01CC0000 - 0x01FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:04:22 Write : Processing rm240__10.30_ISM_008.image_c_tr_brown Total 736 [736/0/0] blocks to write, writing... TIME : Write time : 00:01:18 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:11:40 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6500s-1 Software Info: V 10.30 23-04-09 RM-240 (c) Nokia IMEI: 357659016728935 PPM version : V 10.30 23-04-09 RM-240 (c) Nokia C Product code: 0549752 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:12:20 Connect phone on selected interface... |
The Following 3 Users Say Thank You to xerraco For This Useful Post: |
03-28-2011, 06:13 | #10331 (permalink) |
Member: 890926 Status: Offline Thanks Meter: 2,080 | 5220 USB Flashed Code: card found: S/N 12345678 registered to: xerraco Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.18 , Rev : 3.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm411__07.23.mcusw PPM : rm411__07.23.ppm_t CNT : rm411__07.23.image_t_blue Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Getting product info... RAP_BOOT: 0803000302010000 RAP_PUBLIC: 1600020D71AA025474E00EA44E398517D1DF7E5D CMT_ROOTKEY: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP_PAPUBKEY: D93826B23E9B093BE4DD7304FBAA6778996AE60B Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm411__07.23.image_t_blue ConvertImage: Page Size is 128K, no need convert Loader len: 307008, CHK: C0CE ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm411__07.23.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:15 Write : Processing rm411__07.23.mcusw Total 1289 [1289/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:13 MCU Write done ===Flashing [PPM]=== Erase : Processing rm411__07.23.ppm_t Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:57 Write : Processing rm411__07.23.ppm_t Total 480 [480/0/0] blocks to write, writing... TIME : Write time : 00:00:29 PPM Write done ===Flashing [CNT]=== Erase : Processing rm411__07.23.image_t_blue Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:01 Write : Processing rm411__07.23.image_t_blue Total 656 [656/0/0] blocks to write, writing... TIME : Write time : 00:00:39 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:10:37 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5220 XpressMusic Software Info: V 07.23 17-07-09 RM-411 (c) Nokia IMEI: 353662011737962 PPM version : V 07.23 17-07-09 RM-411 (c) Nokia T Product code: 0563611 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Resetting LifeTimer Error check LifeTimer Data, break :( Reset It manually, please Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:11:26 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
03-28-2011, 06:35 | #10332 (permalink) |
Member: 890926 Status: Offline Thanks Meter: 2,080 | card found: S/N 12345678 registered to: xerraco Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.18 , Rev : 3.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm237__07.30.mcusw PPM : rm237__07.30.ppm_c CNT : rm237__07.30.image_c_tr Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Getting product info... RAP_BOOT: 0901010002010000 RAP_PUBLIC: 25F001039D587E569B044CAA5E525A5EB686518F CMT_ROOTKEY: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP_PAPUBKEY: C0E691EA16A7593A9BB28832D7312A39F7ED668D Checking CNT sector PN<>FL PN CNT sector : 128 kb Converted content already exist, skip convert and using 128k Loader len: 253888, CHK: 17DB ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm237__07.30.mcusw Found 9 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT Result: 0000 Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT Result: 0000 Erasing area 0x00200000 - 0x0031FFFF, NOR, CMT Result: 0000 Erasing area 0x00320000 - 0x0105FFFF, NOR, CMT Result: 0000 Erasing area 0x01060000 - 0x01067FFF, NOR, CMT Result: 0000 Erasing area 0x01068000 - 0x0107FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:08 Write : Processing rm237__07.30.mcusw Total 945 [945/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [PAPUBKEYS] CMT : PAPUBKEYS skip, already sent CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [PMM_CONF] CMT : Writing Hash CERT [SBIF_CONF] TIME : Write time : 00:00:56 MCU Write done ===Flashing [PPM]=== Erase : Processing rm237__07.30.ppm_c Found 1 areas to erase Erasing area 0x01080000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:38 Write : Processing rm237__07.30.ppm_c Total 240 [240/0/0] blocks to write, writing... TIME : Write time : 00:00:13 PPM Write done ===Flashing [CNT]=== Erase : Processing rm237__07.30.image_c_tr_128 Found 1 areas to erase Erasing area 0x01520000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:52 Write : Processing rm237__07.30.image_c_tr_128 Total 240 [240/0/0] blocks to write, writing... TIME : Write time : 00:00:14 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:06:03 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 3110c Software Info: V 07.30 07-05-09 RM-237 (c) Nokia. IMEI: 353183035436127 PPM version : V 07.30 07-05-09 RM-237 (c) Nokia. C Product code: 0554141 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:06:28 3110 USB Flashed! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
03-28-2011, 06:36 | #10333 (permalink) |
Member: 890926 Status: Offline Thanks Meter: 2,080 | 5130C Read MMC Pass. card found: S/N 12345678 registered to: xerraco Connect phone on selected interface... UFS S/N 123453 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 5130c-2 Software ver : V 07.91 29-10-09 RM-495 (c) Nokia IMEI : 351508048616368 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR72_09w33 APE Test: PPM : V 07.91 29-10-09 RM-495 (c) Nokia T CNT : Content: t_ph_red V 07.91 29-10-09 RM-495 (c) Nokia Product SN : IDV779619 Product code : 0579013 Base Prd.code: 0578151 Module code : 0204024 Long Prod.SN : 0 Hardware info======= HWID : 2002 Retu : 16 Tahvo : 22 Batery: 4692 mV Camera: CMT BT: Error APE BT: Error APE HW: Error LCDVer: Error RF ic : 06540601 Lock info =========== IMEI : 351508048616368 IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User Code : 42885 MMC pwd : Backup saved UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Reading MMC password... MMC pass Record found, saving... 1 MMC pwd records are found! Extracting... ------------------------------- We have next Pass: angelo ------------------------------- Done! Phone disconected! Connect phone on selected interface... |
03-28-2011, 07:42 | #10334 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Mumbai--Great INDIA
Member: 665441 Status: Offline Sonork: 100.1670531 Thanks Meter: 603 | COM26 [QCUSB_COM26_1] selected module v1.48 Device: ZTE-S100 operation: SP-unlock mode #2 Phone should be Switched ON ! connecting... ESN(hex) : 80DD08EA disabling minlock... Done... Phones should be restarting now... Finished, time used: 4 sec |
The Following User Says Thank You to hanif007 For This Useful Post: |
03-28-2011, 08:21 | #10335 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 213172 Status: Offline Sonork: 1582799 Thanks Meter: 265 | COM6 [VCP0] selected module v3.75 Device: Alcatel-543X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:3403:A002 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.46679 001.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_9096F062].rpl ==================== New firmware found (v.3.75, database date: 12.02.2011): JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 46679001 rom info ver: 07 sw version: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN project-id: MAUI.08A.W08.40.SP1.V32.F3, 62F09690 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 268 provider: 543X-2DVDGB2 customization: CN26CA04 customization: XN26CA04 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... version is not found in database: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 00006F50->00006C50 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26CA04 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN use default security area (sec info, hash) pattern ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26CA04 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN use default security area (sec info, hash) pattern ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35982003734185 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-543X_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_ 40_SP1_V32_F3__system_log_46679001_9096F062_201103 28-110102.B0X.bin Finished, time used: 5 min 9 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to abdulwajid147 For This Useful Post: |
