Old 03-29-2011, 02:43   #10366 (permalink)
rizkypratama999's Avatar
Member: 1210129
Thanks Meter: 68
3110C RESTART
card found: S/N XXXX:XXXX
registered to: rizky pratama
Connect phone on selected interface...
UFS S/N 73751 boot - Ok
Phone found!
Series 40 Device detected!
read info... - Ok
Core version : 1.17 , Rev : 2.3
Selected FlashSettings : Manual
Files Set for Flashing :
CNT : rm237__07.21.image_x
Check FlashFiles, Please, wait...
-> SWversion check skipped : Custom mode selected
Backup enabled, Will read Certificates now...
Backup CRT308
CRT308 Backup Created...
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT ASICID : 000000010000022600010006010C192101001101
CMT EM0 ID : 00000232
CMT EM1 ID : 00000353
CMT PUB ID : 1BB0011772977D561101EA9F557EF4EA7BEA0122
CMT MODE ID : 00
CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
CMT ROM ID : 191EC665DFAAF68F
CMT : Sending 2nd loader...
Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0
CMT Loader sent, Boot Ok
MCU Configuration
FLASHID : 89810089 , CMT , NOR
CMT Flash ID : 89810089 < INTEL => NU48F256
FLCNT : 00000000000000000000000000000000000000
FLASHID : 0000FFFF , CMT , MMC , EXT
CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok
Sending ALGO....
Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1
CMT Algo sent
CMT PAPUB : E691EA16A7593A9BB28832D7312A39F7ED668D0500
Transmission mode : Dual (Ddr, TX2)
Boot Done!
CMT : Read NPC certificate...
Cert size : 12288 byte(s)
IMEI : 359343025242323
CMT : Read CCC certificate...
Cert size : 8192 byte(s)
CMT : Read HWC certificate...
CMT : Read VARIANT certificate...
Cert size : 20480 byte(s)
Cert Read done!
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
WMDRM_PD Data saved...
RPL saved : c:\InfinityBox\BEST\Backup\Cert\359343025242323.rp l
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
Sending ALGO....
CMT Algo sent
Boot Done!
CNT : Converted to 128k page data exist
Erase : Processing rm237__07.21.image_x_128
Found 1 areas to erase, erase group
Asic : CMT , Sub : NOR
CMT , NOR , Area : 0x01520000 - 0x01FDFFFF
Using TimeOut : 7 min ( 430 sec )
Erasing, wait.....
CMT : Group erase Ok
TIME : Erase time : 00:01:27
Write : Processing rm237__07.21.image_x_128
Total writen 360 blocks
TIME : Write time : 00:00:40
Init Service mode... Wait...
Reading Phone Info....
Connected phone - Nokia 3110c
Software Info: V 07.21
05-11-08
RM-237
(c) Nokia.
IMEI: 359343025242323
Product code: 0514959
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Checking User Certificates...
Total - 0 certs
Uploading certificates...
Writen 21 certs!
AfterFlash operations done... Reconnect, wait...
Phone found!
read info... - Ok
Resetting selected items...
Check phone mode...
Phone already in Test mode, skip change...
Settings Full Factory Defaults...
Set OK!
Settings Software Upgrade Defaults...
Set OK!
Settings Service Centre Defaults...
Set OK!
Settings Production Tune Defaults...
Set OK!
Settings User Data Defaults...
Set OK!
Settings Leave Factory defaults...
Set OK!
Elapsed: 00:00:01
The Following 3 Users Say Thank You to rizkypratama999 For This Useful Post:
Old 03-29-2011, 04:57   #10367 (permalink)
joni_rajpura's Avatar
Member: 508072
Thanks Meter: 1,621
COM2 [VCP1] selected
module v1.49
Device: Huawei-C2285-C02B208SP01
operation: SP-unlock
Phone should be Switched ON !
connecting...
sending comand...
disabling minlock...
Phones should be restarting now...
Finished, time used: 27 sec
The Following User Says Thank You to joni_rajpura For This Useful Post:
Old 03-29-2011, 05:44   #10368 (permalink)
noor012345's Avatar
Member: 861464
Sonork: 100.1597346 noor
Thanks Meter: 172
Thumbs up successfull unlock vodafone 340
COM3 [VCP0] selected
module v3.62
Action: "sp-unlock"
unlock method: smart fast
Model: Vodafone-340
Checking data, wait...
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:1A03:A005
status: 01
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: BM35A1.V2.22.M00.02.44
Version: FOXLINK25_08B_HW
81 byte(s) read
imei: 35592203595414
connection Ok
186 byte(s) read
reading data...
reading data #4...
building new data...
writing data...
174 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 38 sec
Remove/Install battery now !
The Following 2 Users Say Thank You to noor012345 For This Useful Post:
Old 03-29-2011, 07:10   #10369 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,741
registered to: saeedullah_khan
Phone found!
read info... - Ok
Core version : 1.18 , Rev : 3.0
CNT : rm411__07.23.image_mb_grey
Flashing phone now...
Check files done...
Backup CRT308 data...
SimLock Data saved...
SimLock Key saved...
RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\BEST_v1.18.5\Backup\Cert\356840021602262_SIM. rpl
Getting product info...
RAP_BOOT: 0803000302010000
RAP_PUBLIC: 09D0000112E658501B656D1B0AE0E2BFA6EEECF3
CMT_ROOTKEY: 9DDBFCFE6E73CED7D8C6268C8EB85723
RAP_PAPUBKEY: D93826B23E9B093BE4DD7304FBAA6778996AE60B
Checking CNT sector PN<>FL
PN CNT sector : 128 kb
ConvertImage: Processing rm411__07.23.image_mb_grey
ConvertImage: Page Size is 128K, no need convert
Loader len: 307008, CHK: C0CE
ADL -> Sending loader...
Update Server code succesfully sent to phone!
TIME : Boot time : 00:00:04
Reopening the connection...
Waiting for response: 30
Waiting for response: 29
ADL -> [2nd] changing...
ADL Server confirm flashmode!
ADL : ASIC CMT select Ok
===Flashing [CNT]===
Erase : Processing rm411__07.23.image_mb_grey
Found 2 areas to erase
Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT
Result: 0000
Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:05:06
Write : Processing rm411__07.23.image_mb_grey
Total 520 [520/0/0] blocks to write, writing...
TIME : Write time : 00:00:34
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:05:41
Reboot phone now...
Connected phone - Nokia 5220 XpressMusic
Software Info: V 07.23 17-07-09 RM-411 (c) Nokia
IMEI: 356840021602262
PPM version : V 07.23 17-07-09 RM-411 (c) Nokia MB
Product code: 0564105
Checking...
Read Info Done!
Settings After Flash Defaults...
FullFactorySet...OK!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Total - 0 certs
Writen 21 certs!
Done!
Elapsed: 00:06:31
Phone found!
read info... - Ok
The Following 3 Users Say Thank You to saeedullah_khan For This Useful Post:
Old 03-29-2011, 07:10   #10370 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,741
Phone found!
read info... - Ok
Reading User code...
User Code is: 4275637
Done!
Resetting User Code to default (12345)...
Clear data : Ok
Result: 12345
Done!
Backup Certificates now...
Check communication with phone....
ADL not support backup mode, rpl reading impossible
RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\BEST_v1.18.5\Backup\Cert\353101023907867_SIM. rpl
Elapsed: 00:00:00
Phone found!
read info... - Ok
Old 03-29-2011, 07:11   #10371 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,741
MCU : rm237__07.30.mcusw
PPM : rm237__07.30.ppm_c
CNT : rm237__07.30.image_ora_pl_games
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
--- Press phone's power button or insert cable & charger! ---
Connection opened successfully
Waiting for communication response.
[BB5 FLASH]: Bootrom Ok!
RAP_PUB: 1E8002118D727E5694B7359842CAF49340046789
CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1
PatchRAWLoader: Patched OK
Processing RAWLOADER...
Processing UPDAPP...
Processing PASUBTOC...
TIME : Boot time : 00:00:05
ADL : Check data
ADL : Data accepted
===Flashing [MCU]===
Erase : Processing rm237__07.30.mcusw
Found 9 areas to erase
Erasing area 0x00000000 - 0x000006BF, NOR, CMT
Result: 0000
Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT
Result: 0000
Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT
Result: 0000
Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT
Result: 0000
Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT
Result: 0000
Erasing area 0x00200000 - 0x0031FFFF, NOR, CMT
Result: 0000
Erasing area 0x00320000 - 0x0105FFFF, NOR, CMT
Result: 0000
Erasing area 0x01060000 - 0x01067FFF, NOR, CMT
Result: 0000
Erasing area 0x01068000 - 0x0107FFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:02:06
Write : Processing rm237__07.30.mcusw
Total 945 [945/0/0] blocks to write, writing...
CMT : Writing Hash CERT [NOLO]
CMT : Writing Hash CERT [KEYS]
CMT : Writing Hash CERT [PRIMAPP]
CMT : Writing Hash CERT [PASUBTOC]
CMT : Writing Hash CERT [PAPUBKEYS]
CMT : PAPUBKEYS skip, already sent
CMT : Writing Hash CERT [UPDAPP]
CMT : Writing Hash CERT [DSP0]
CMT : Writing Hash CERT [MCUSW]
CMT : Writing Hash CERT [PMM_CONF]
CMT : Writing Hash CERT [SBIF_CONF]
TIME : Write time : 00:00:47
MCU Write done
===Flashing [PPM]===
Erase : Processing rm237__07.30.ppm_c
Erasing area 0x01080000 - 0x0151FFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:00:37
Write : Processing rm237__07.30.ppm_c
Total 240 [240/0/0] blocks to write, writing...
TIME : Write time : 00:00:12
PPM Write done
Erase : Processing rm237__07.30.image_ora_pl_games
Erasing area 0x01520000 - 0x01FDFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:01:54
Checking content info...
Resetting phone...
Converted content already exist, skip convert and using 128k
Loader len: 253888, CHK: 17DB
Reset connection...
ADL : Check data
ADL : Data accepted
Write : Processing rm237__07.30.image_ora_pl_games_128
Total 296 [296/0/0] blocks to write, writing...
TIME : Write time : 00:00:15
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:05:53
Reboot phone now...
Software Info: V 07.30 07-05-09 RM-237 (c) Nokia.
IMEI: 353203036848383
PPM version : V 07.30 07-05-09 RM-237 (c) Nokia. C
Product code: 0544318
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 0 certs
Writen 21 certs!
Done!
Elapsed: 00:06:42
Phone found!
read info... - Ok
Checking StartUp data ...
SDD Key status : SD Data is Ok
PA_SimLock Version :
PA_SL phone detected
Done!
Old 03-29-2011, 07:13   #10372 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,741
Phone found!
Series 60 Device detected!
read info... - Ok
MCU : RM-504_32.0.007_prd.core.C00
PPM : RM-504_32.0.007_prd.rofs2.V12
PPM2 : RM-504_32.0.007_C06_prd.rofs3.fpsx
CNT : RM-504_32.0.007_007_000_U001.uda.fpsx
Check files done...
-> SWversion check skipped : Manual mode selected
RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\BEST_v1.18.5\Backup\Cert\359368034641819_SIM. rpl
ADL req restart
Communication verify done... Preparing...
Gathering phone info...
Batery valtage : 3695 mV
-> Batery voltage less, than 3,8V (3695mV). Continue at user risk
Reboot....
Waiting for communication response...
ASIC ID: 000000010000022600010006400C192101051105
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 12A00008948E0052F31C8DBD6935074EB87BD398
ASIC MODE ID: 00
ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
ROM ID: 4B9B75103E691FF8
Processing PAPUBKEYS...
Boot Done!
ADL : Auth done...
Erase : Processing RM-504_32.0.007_prd.core.C00
Found 5 areas to erase
Erasing area 0x00040000 - 0x00082FFF, NAND, CMT
Result: 0000
Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT
Result: 0000
Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT
Result: 0000
Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT
Result: 0000
Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT
Result: 0000
Erase partition 0x0A
Partition erase Ok
Partitioning : Ok [5]
TIME : Erase time : 00:00:00
Write : Processing RM-504_32.0.007_prd.core.C00
Total 434 [434/0/0] blocks to write, writing...
CMT : Writing Hash CERT [ADA]
CMT : Writing Hash CERT [RAP3NAND]
CMT : Writing Hash CERT [SOS*UPDAPP]
CMT : Writing Hash CERT [SOS*ENO]
CMT : Writing Hash CERT [SOS*DSP0]
CMT : Writing Hash CERT [SOS*ISASW]
CMT : Writing Hash CERT [SOS+CORE]
CMT : Writing Hash CERT [SOS+ROFS1]
MCU Write done
Erase : Processing RM-504_32.0.007_prd.rofs2.V12
Erasing area 0x07260000 - 0x0935FFFF, NAND, CMT
Result: 0000
Write : Processing RM-504_32.0.007_prd.rofs2.V12
Total 84 [84/0/0] blocks to write, writing...
CMT : Writing Hash CERT [SOS+ROFS2]
TIME : Write time : 00:00:07
PPM Write done
===Flashing [PPM2]===
Erase : Processing RM-504_32.0.007_C06_prd.rofs3.fpsx
Erasing area 0x09360000 - 0x09E5FFFF, NAND, CMT
Result: 0000
Write : Processing RM-504_32.0.007_C06_prd.rofs3.fpsx
Total 27 [27/0/0] blocks to write, writing...
CMT : Writing Hash CERT [SOS+ROFS3]
TIME : Write time : 00:00:02
PPM Write done
Erase : Processing RM-504_32.0.007_007_000_U001.uda.fpsx
Erasing area 0x09E60000 - 0x0F71FFFF, NAND, CMT
Result: 0000
Write : Processing RM-504_32.0.007_007_000_U001.uda.fpsx
Total 25 [25/0/0] blocks to write, writing...
CNT Write done
ADL : End flashing
ADL : Finalize...
Flashing done!
Total flash time : 00:00:46
Reboot phone now...
Connected phone - Nokia 5530 XpressMusic
Software Info: V ICPR72_10w25.3 11-10-10 RM-504 (c) Nokia
IMEI: 359368034641819
Ape Version: V 32.0.007
Product code: 0578172
Checking...
Read Info Done!
SwUpgradeSet...OK!
Done!
Elapsed: 00:01:12
Phone found!
read info... - Ok
Old 03-29-2011, 07:13   #10373 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,741
UFS S/N 82121 boot - Ok
Phone found!
read info... - Ok
PPM : rm689_003.00ic
Infineon flashing...
Booting phone now....
Sync Ok , A2
CPU ID : XGOLD , A200341100
Boot Ok , 01
PBL : SE0_091125 F11
Algo Ok , 01
SBL mode Ok
SBL : Default_RAM_Bootloader
EPP CFG [Bering]...
FLASH ID : 00EC000000542200
FLASH ID : Samsung, K8S6415E
Boot Done!
File : rm689_003.00ic
Image : hw_s01_rm689_003.00ic.fls
Cert block found, sending....
Cert sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x00210000 , Len : 0x001E8980
Erasing, wait ...
Erase done
Write , Start : 0x00210000 , Len : 0x001E8980
Flashing , wait ...
Region flash done
Check : CB69
Flashing done, rebooting...
-> Infineon info : Do FullFactory Sets after flashing
Flashing Done!
Afterflash settings...
SW ver : V 03.00
31-08-10
RM-689
(c) Nokia
IMEI : 354863047099364
PCode : 059B372
All done!
Phone found!
read info... - Ok
Old 03-29-2011, 07:15   #10374 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,741
Phone found!
read info... - Ok
Connected phone - Nokia 6233
Software ver : V 05.60 14-09-07 RM-145 (c) Nokia
IMEI : 356293015404966
Ape Ver :
APE Var :
APE ADSP:
DSP Ver : pb05wk46v50
APE Test:
PPM : V 05.60 14-09-07 RM123_145_- (c) Nokia C
CNT :
Product SN : 2AG901923
Product code : 0532188
Base Prd.code: 0528588
Module code : 0202772
Long Prod.SN :
Hardware info=======
HWID : 1016
Retu : 32
Tahvo : 53
Batery: 3976 mV
Camera:
CMT BT:
APE BT:
APE HW:
LCDVer: SEIKO
RF ic :
Lock info ===========
IMEI spNet : 3A 65 92 03 51 04 94 06
IMEI svNet : 33 65 92 03 51 04 94 06 F8
Conf key : 0000000000000000
Provider key : 2440700000000000
Provider : AT&T;U.S.A. (3650)
Counters : Key 0 [3] , Fbus 0 [10]
Blocks : 7
LOCK STATUS :
BLK : 1
Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS : All Open
User Code : 12345
MMC pwd : no any record found
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
User Code is: 12345
Done!
CNT : rm123_145_30005.60.image_g
Check files done...
RAP_BOOT: 0803000002010000
RAP_PUBLIC: 212002129157635085A1F52F258BEF2AEDBE4241
CMT_ROOTKEY: BAF3A9C3DBFA8454937DB77F2B8852B1
RAP_PAPUBKEY: 2F36DDC4990FD844712A61A80C033211BD9602E3
Loader len: 236992, CHK: 0254
TIME : Boot time : 00:00:03
Erase : Processing rm123_145_30005.60.image_g_128
Erasing area 0x016E0000 - 0x01E7FFFF, NOR, CMT
Result: 0000
Erasing area 0x01E80000 - 0x01FDFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:00:26
Write : Processing rm123_145_30005.60.image_g_128
Total 128 [128/0/0] blocks to write, writing...
TIME : Write time : 00:00:11
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:00:37
Reboot phone now...
Software Info: V 05.60 14-09-07 RM-145 (c) Nokia
IMEI: 356293015404966
PPM version : V 05.60 14-09-07 RM123_145_- (c) Nokia C
Product code: 0532188
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 0 certs
Writen 21 certs!
Done!
Elapsed: 00:00:58
Phone found!
read info... - Ok
Old 03-29-2011, 07:16   #10375 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,741
MCU : rm303__10.10.mcusw
PPM : rm303__10.10.ppm_m4
CNT : rm303__10.10.image_m4_red
Check files done...
RAP_PUB: 2AA0011270700254C99F84856788A241DF46FF7E
TIME : Boot time : 00:00:06
ADL : Check data
ADL : Data accepted
Erase : Processing rm303__10.10.mcusw
Found 6 areas to erase
Result: 0000
Result: 0000
Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT
Result: 0000
Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT
Result: 0000
Erasing area 0x00140000 - 0x010DFFFF, NOR, CMT
Result: 0000
Erasing area 0x010E0000 - 0x0121FFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:01:01
Write : Processing rm303__10.10.mcusw
Total 1107 [1107/0/0] blocks to write, writing...
TIME : Write time : 00:01:51
MCU Write done
Erase : Processing rm303__10.10.ppm_m4
Erasing area 0x01220000 - 0x0189FFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:00:15
Write : Processing rm303__10.10.ppm_m4
Total 314 [314/0/0] blocks to write, writing...
TIME : Write time : 00:00:33
PPM Write done
Erase : Processing rm303__10.10.image_m4_red
Erasing area 0x018A0000 - 0x01B1FFFF, NOR, CMT
Result: 0000
Erasing area 0x01B20000 - 0x03FBFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:02:00
Check Image : Content size is 128k, use direct write mode
Write : Processing rm303__10.10.image_m4_red
Total 512 [512/0/0] blocks to write, writing...
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:06:29
Reboot phone now...
Connected phone - Nokia 5310 XpressMusic
Software Info: V 10.10 23-03-09 RM-303 (c) Nokia
IMEI: 359562017262276
PPM version : V 10.10 23-03-09 RM-303 (c) Nokia M4
Product code: 0556708
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 0 certs
Writen 21 certs!
Done!
Elapsed: 00:07:06
Phone found!
read info... - Ok
RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\BEST_v1.18.5\Backup\Cert\359562017262276_SIM. rpl
Elapsed: 00:00:00
Phone found!
read info... - Ok
Old 03-29-2011, 07:18   #10376 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,741
Phone found!
read info... - Ok
User ACCEPTED FULL ERASE
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT ASICID : 000000010000022600010006030C192101033000
CMT EM0 ID : 00000296
CMT EM1 ID : 00000B22
CMT PUB ID : 167001161B807E5635FC204941E3B5E3EA4975CE
CMT MODE ID : 00
CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROM ID : 273F6D55DFAAF68F
MCU Configuration
FLASHID : 89820089 , CMT , NOR
CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512
Sending ALGO....
CMT Algo sent
CMT PAPUB : 917F11196FDB7378C18EF7260698CA4489DCA02700
Boot Done!
Full Erase started...
Erase Area 0x00000000-0x03FFFFFF
Using TimeOut : 10 min ( 600 sec )
Erasing, wait.....
Erase CMT Finished , [FF]
CMT : Erase Ok
Done
Phone disconected!
MCU : C5F02102_rm495__07.97.mcusw
PPM : 4BB8AA07_rm495__07.97.ppm_mena_a1
CNT : E24393CE_rm495__07.97.image_mena_a1_red
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Sending ALGO....
CMT Algo sent
PAPUBkeys blank (erased or HW failure)
Boot Done!
Cert size : 0 byte(s)
No any CRT data (MCU damaged/CERT erased), skip saving
Init Service Mode Failed!
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
Sending ALGO....
CMT Algo sent
Boot Done!
Erase : Processing C5F02102_rm495__07.97.mcusw
Found 6 areas to erase, erase group
CMT , NOR , Area : 0x00000000 - 0x000006BF
CMT , NOR , Area : 0x000006C0 - 0x0001FFFF
CMT , NOR , Area : 0x00040000 - 0x000BFFFF
CMT , NOR , Area : 0x000C0000 - 0x0013FFFF
CMT , NOR , Area : 0x00140000 - 0x0137FFFF
CMT , NOR , Area : 0x01380000 - 0x0151FFFF
Erasing, wait.....
TIME : Erase time : 00:00:05
Write : Processing C5F02102_rm495__07.97.mcusw
CMT: Writing Hash CERT [NOLO]
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [PASUBTOC]
CMT: Writing Hash CERT [PAPUBKEYS]
CMT: Writing Hash CERT [UPDAPP]
CMT: Writing Hash CERT [DSP0]
CMT: Writing Hash CERT [MCUSW]
Total writen 1169 blocks
TIME : Write time : 00:02:43
Erase : Processing 4BB8AA07_rm495__07.97.ppm_mena_a1
CMT , NOR , Area : 0x01520000 - 0x01DBFFFF
Erasing, wait.....
TIME : Erase time : 00:00:02
Write : Processing 4BB8AA07_rm495__07.97.ppm_mena_a1
Total writen 388 blocks
TIME : Write time : 00:00:51
ConvertImage: Processing E24393CE_rm495__07.97.image_mena_a1_red
Erase : Processing E24393CE_rm495__07.97.image_mena_a1_red
Found 2 areas to erase, erase group
CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF
CMT , NOR , Area : 0x02160000 - 0x03FBFFFF
Erasing, wait.....
TIME : Erase time : 00:00:08
Write : Processing E24393CE_rm495__07.97.image_mena_a1_red
Total writen 656 blocks
TIME : Write time : 00:01:30
Connected phone - Nokia 5130c-2
Software Info: V 07.97
13-09-10
RM-495
(c) Nokia
IMEI: 12345610654321?
Product code:
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 0 certs
Writen 21 certs!
Phone found!
read info... - Ok
SDD Key status : SDData Damaged!!!!!
Done!
Backup CRT308
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
Sending ALGO....
CMT Algo sent
Boot Done!
IMEI : 000000000000000
Cert size : 30600 byte(s)
Cert Read done!
RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\BEST_v1.18.5\Backup\Cert\000000000000000_SIM. rpl
Phone disconected!
Phone found!
read info... - Ok
Phone disconected!
Old 03-29-2011, 07:19   #10377 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,741
Phone found!
read info... - Ok
MCU : rm237__07.21.mcusw
PPM : rm237__07.21.ppm_mea4
CNT : rm237__07.21.image_mea4
Check files done...
Batery valtage : 3792 mV
-> Batery voltage less, than 3,8V (3792mV). Continue at user risk
RAP_BOOT: 0901010002010000
RAP_PUBLIC: 0E70011336F97E566219240192BCCF3A6130728B
RAP_PAPUBKEY: C0E691EA16A7593A9BB28832D7312A39F7ED668D
DownGr: Prepare phone for downgrade...
DownGr: Prepare Started.... Psec : 12704
-> Prepare status : Ok
DownGr: Phone ready!
Loader len: 253888, CHK: 129B
ADL : Check data
ADL : Data NOT accepted by phone, continue at user risk
Erase : Processing rm237__07.21.mcusw
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
TIME : Erase time : 00:02:17
Write : Processing rm237__07.21.mcusw
Total 944 [944/0/0] blocks to write, writing...
TIME : Write time : 00:01:01
MCU Write done
Erase : Processing rm237__07.21.ppm_mea4
Result: 0000
TIME : Erase time : 00:00:40
Write : Processing rm237__07.21.ppm_mea4
Total 178 [178/0/0] blocks to write, writing...
PPM Write done
Erase : Processing rm237__07.21.image_mea4_128
Result: 0000
TIME : Erase time : 00:01:58
Write : Processing rm237__07.21.image_mea4_128
Total 212 [212/0/0] blocks to write, writing...
TIME : Write time : 00:00:14
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:06:23
Reboot phone now...
Software Info: V 07.21 05-11-08 RM-237 (c) Nokia.
IMEI: 356029035287704
PPM version : V 07.21 05-11-08 RM-237 (c) Nokia. MEA
Product code: 0544343
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 0 certs
Writen 21 certs!
Done!
Elapsed: 00:07:11
Phone found!
read info... - Ok
Old 03-29-2011, 07:21   #10378 (permalink)
Member: 508072
Thanks Meter: 1,621
COM2 [VCP2] selected
module v3.80
Device: Spice-S404N
Action: "sp-unlock"
unlock method: standard fast
Unlock procedure can be faster if you skip ffs/eeprom area backup procedure.
Do you want to disable ffs/eeprom backup ?
ffs/eeprom backup disabled
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6205:8B00]...
CPU: MT6205
boot packet size: 0400
Boot Done
====> Initialize ...
flash: EC22A000000000:18E59F00000000
flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb
otp offset: 003F0000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
ffs/eeprom address can not be detected, value from database assigned: 00300000/00100000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
lock area found
Patch required data Done
====> Special operation ...
detecting parameters to apply patch area 1...
error: area 1 can not apply patch
detecting parameters to apply patch area 2...
error: area 2 can not apply patch
detecting parameters to apply patch area 3...
error: area 3 can not apply patch
detecting parameters to apply patch area 4...
required data found
Write: area 4 (pass 1)
area 4 patch applied Ok
Special operation Done
====> Write ...
Write: lock-area-1
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 37 sec
The Following 2 Users Say Thank You to joni_rajpura For This Useful Post:
Old 03-29-2011, 07:39   #10379 (permalink)
Member: 1108057
Sonork: harvinder
Thanks Meter: 131
COM2 [VCP0] selected
module v1.49
Device: Huawei-C5330-Version-108
operation: Repair "Contact Service"
connecting...
Contact Service Remover...
Finished, time used: 10 sec
The Following 2 Users Say Thank You to harvinder43 For This Useful Post:
Old 03-29-2011, 08:46   #10380 (permalink)
Member: 1066865
Thanks Meter: 593
nokia 5220 rm-411 flashed successfully using j.a.f
Opening Connection...
Device Location: 00000041
Connect Ok!
Initializing Connection...
JAF Firmware: 01.B1
JAF S/N DiTENZSF boot - Ok
Ready for operations...
MCU : rm411__07.23.mcusw
PPM : rm411__07.23.ppm_mr
CNT : rm411__07.23.image_mr_in_red
Checking BUS...
Switch jaf to FlashMode...
FlashMode set Ok
Booting phone...
BOOT 1ST   : C0
CMT part info :
CMT EM0 ID  : 00000295
CMT PUB ID  : 219000166B505750B429D8CB357B2FAAD43E1B81
CMT MODE ID : 00
MCU configuration
TransmissionReq : 16 bit, Single
TransmissionReq : Accepted, 16 bit, Single
Sending ALGO....
Use : RAP3Gv3_algo.fg
CMT Algo sent!
TransmissionReq : 32 bit, Dual
TransmissionReq : Accepted, 32 bit, Dual
Boot done!
Erase : Processing rm411__07.23.mcusw
Init Erase Mode Ok
Erasing, wait.....
TIME : Erase time : 00:00:46
PrReq : NOR, 00
Write : Processing rm411__07.23.mcusw
Init Write Mode Ok
Total writen 1280 blocks
TIME : Write time : 00:02:35
PrReq : NOR, 00
Erase : Processing rm411__07.23.ppm_mr
Init Erase Mode Ok
Erasing, wait.....
TIME : Erase time : 00:00:31
PrReq : NOR, 00
Write : Processing rm411__07.23.ppm_mr
Init Write Mode Ok
Total writen 461 blocks
TIME : Write time : 00:00:54
PrReq : NOR, 00
ConvertImage: Processing rm411__07.23.image_mr_in_red
Erase : Processing rm411__07.23.image_mr_in_red
Init Erase Mode Ok
Erasing, wait.....
TIME : Erase time : 00:03:22
PrReq : NOR, 00
Write : Processing rm411__07.23.image_mr_in_red
Init Write Mode Ok
Total writen 632 blocks
TIME : Write time : 00:01:14
PrReq : NOR, 00
Switch jaf to FBUS...
FbusMode set Ok
Phone connected
IMEI : 353662017872342
Simlock status : Simlock is Ok
Flashing done
The Following 3 Users Say Thank You to sunny_luthras99 For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.77895 seconds with 10 queries
