Old 03-29-2011, 08:56   #10381 (permalink)
Member: 1066865
Thanks Meter: 593
gfive l300 no licesence to produce successfully repaired
module  v3.28
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: write flash
"smart write" active
write: Firmware
GOLDDRAGON25_GEMINI_PCB03_GPRS_MT6225_S00.L182_ALP_DSIM_ST32T3W0_F_SP_V01__fullflash_20110329-130046.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:3103:0003
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: 2088C4FFFF0043:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====>  Set baud ...
921600
Set baud Done
====>  Initialize bootcode ...
Initialize bootcode Done
====>  Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (04)
TCL-ID is absent
New firmware found (v.3.28, database date: 19.03.2011):
GOLDDRAGON25_GEMINI_PCB03_GPRS_MT6225_S00.L182_ALP_DSIM_ST32T3W0_F_SP_V01.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info ver: 04
sw version: GOLDDRAGON25_GEMINI_PCB03_GPRS_MT6225_S00.L182_ALP_DSIM_ST32T3W0_F_SP_V01.BIN
project-id: L182_ALP_DSIM_ST32T3W0_F_SP_V01, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
reading: GOLDDRAGON25_GEMINI_PCB03_GPRS_MT6225_S00.L182_ALP_DSIM_ST32T3W0_F_SP_V01__ffs...
file saved: C:\InfinityBox\ChineseMiracle\GOLDDRAGON25_GEMINI_PCB03_GPRS_MT6225_S00.L182_ALP_DSIM_ST32T3W0_F_SP_V01__ffs_20110329-130326.B0E.bin
Backup required data Done
====>  Patch required data ...
Patch required data Done
====>  Special operation ...
No licensed to produce fix...
No licensed to produce done
Special operation Done
====>  Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
done
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Write Done
====>  Finalization ...
Finalization Done
Finished, time used: 2 min 45 sec
Remove/Install battery now !
The Following 2 Users Say Thank You to sunny_luthras99 For This Useful Post:
Old 03-29-2011, 09:37   #10382 (permalink)
mobile+plus's Avatar
Member: 1532828
Thanks Meter: 77
Talking Device: ZTE-S100 unlocking done
COM156 [QCUSB_COM156_1] selected
module v1.48
Device: ZTE-S100
operation: SP-unlock mode #2
Phone should be Switched ON !
connecting...
ESN(hex) : 80C7EB9B
disabling minlock...
Done...
Phones should be restarting now...
Finished, time used: 3 sec
The Following 2 Users Say Thank You to mobile+plus For This Useful Post:
Old 03-29-2011, 09:49   #10383 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 2,080
6131 Dead USB Flashing Success!
card found: S/N 012345678
registered to: xerraco
Connect phone on selected interface...
Phone found!
Series 40 Device detected!
read info... - Ok
Phone disconected!
Core version : 1.18 , Rev : 3.0
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm115__06.60.mcusw
PPM : rm115__06.60.ppm_t
CNT : rm115__06.60.image_tw
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Getting product info...
Dead Mode is Selected
Waiting for USB device...
--- Press phone's power button or insert cable & charger! ---
Connection opened successfully
Waiting for communication response.
[BB5 FLASH]: Bootrom Ok!
RAP_PUB: 2360000992AE6C56E20D500E94343B1A7A8CCFD2
CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1
PatchRAWLoader: Patched OK
Processing RAWLOADER...
Processing UPDAPP...
Processing PASUBTOC...
TIME : Boot time : 00:00:00
Reopening the connection...
Waiting for response: 30
ADL Server confirm flashmode!
===Flashing [MCU]===
Erase : Processing rm115__06.60.mcusw
Found 9 areas to erase
Erasing area 0x00000000 - 0x000006BF, NOR, CMT
Result: 0000
Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT
Result: 0000
Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT
Result: 0000
Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT
Result: 0000
Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT
Result: 0000
Erasing area 0x00200000 - 0x002DFFFF, NOR, CMT
Result: 0000
Erasing area 0x002E0000 - 0x00EDFFFF, NOR, CMT
Result: 0000
Erasing area 0x00EE0000 - 0x00EF7FFF, NOR, CMT
Result: 0000
Erasing area 0x00EF8000 - 0x00EFFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:01:03
Write : Processing rm115__06.60.mcusw
Total 852 [852/0/0] blocks to write, writing...
CMT : Writing Hash CERT [NOLO]
CMT : Writing Hash CERT [KEYS]
CMT : Writing Hash CERT [PRIMAPP]
CMT : Writing Hash CERT [PASUBTOC]
CMT : Writing Hash CERT [PAPUBKEYS]
CMT : Writing Hash CERT [UPDAPP]
CMT : Writing Hash CERT [DSP0]
CMT : Writing Hash CERT [MCUSW]
CMT : Writing Hash CERT [PMM_CONF]
CMT : Writing Hash CERT [SBIF_CONF]
TIME : Write time : 00:01:11
MCU Write done
===Flashing [PPM]===
Erase : Processing rm115__06.60.ppm_t
Found 1 areas to erase
Erasing area 0x00F00000 - 0x0145FFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:00:22
Write : Processing rm115__06.60.ppm_t
Total 309 [309/0/0] blocks to write, writing...
TIME : Write time : 00:00:26
PPM Write done
===Flashing [CNT]===
Erase : Processing rm115__06.60.image_tw
Erasing area 0x01460000 - 0x01FDFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:00:57
Checking content info...
Resetting phone...
Checking CNT sector PN<>FL
PN CNT sector : 128 kb
ConvertImage: Processing rm115__06.60.image_tw
ConvertImage: Page Size is 64K, converting...
ConvertImage: File converted
Loader len: 254784, CHK: 0CD7
ADL -> Sending loader...
Reset connection...
Write : Processing rm115__06.60.image_tw_128
Total 408 [408/0/0] blocks to write, writing...
TIME : Write time : 00:00:33
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:04:34
Reboot phone now...
The Following 3 Users Say Thank You to xerraco For This Useful Post:
Old 03-29-2011, 11:04   #10384 (permalink)
JINDALGSM™'s Avatar
Member: 467045
Sonork: 100.1603919
Thanks Meter: 1,705
nokia 7210c flashing done
card found: S/N 0390:0118
registered to: jindalgsm4255
MCU : rm436__07.23.mcusw
PPM : rm436__07.23.ppm_c
CNT : rm436__07.23.image_c_de
Check files done...
RAP_PUB: 25B001072705595013824FBCF0503B883FDA0031
CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723
TIME : Boot time : 00:00:06
ADL -> [2nd] changing...
ADL : Check data
ADL : Data accepted
ADL : ASIC CMT select Ok
Erase : Processing rm436__07.23.mcusw
Found 6 areas to erase
Result: 0000
Result: 0000
Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT
Result: 0000
Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT
Result: 0000
Erasing area 0x00140000 - 0x0119FFFF, NOR, CMT
Result: 0000
Erasing area 0x011A0000 - 0x0133FFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:01:48
Write : Processing rm436__07.23.mcusw
Total 1170 [1170/0/0] blocks to write, writing...
TIME : Write time : 00:00:54
MCU Write done
Erase : Processing rm436__07.23.ppm_c
Erasing area 0x01340000 - 0x01BDFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:00:49
Write : Processing rm436__07.23.ppm_c
Total 448 [448/0/0] blocks to write, writing...
TIME : Write time : 00:00:21
PPM Write done
Erase : Processing rm436__07.23.image_c_de
Found 2 areas to erase
Erasing area 0x01BE0000 - 0x01F7FFFF, NOR, CMT
Result: 0000
Erasing area 0x01F80000 - 0x03FBFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:05:25
Check Image : Content size is 128k, use direct write mode
Write : Processing rm436__07.23.image_c_de
Total 1424 [1424/0/0] blocks to write, writing...
TIME : Write time : 00:01:07
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:10:28
Reboot phone now...
Reading Phone Info....
Connected phone - Nokia 7210 Supernova
Software Info: V 07.23 17-07-09 RM-436 (c) Nokia
IMEI: 359310021540968
PPM version : V 07.23 17-07-09 RM-436 (c) Nokia C
Product code: 0572571
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Settings After Flash Defaults...
FullFactorySet...OK!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Checking User Certificates...
Total - 0 certs
Uploading certificates...
Writen 21 certs!
AfterFlash operations done... Reconnect, wait...
Done!
Elapsed: 00:11:36
Phone found!
read info... - Ok
The Following 3 Users Say Thank You to JINDALGSM™ For This Useful Post:
Old 03-29-2011, 11:44   #10385 (permalink)
AL-KARAM MOBILE's Avatar
Member: 1329373
Thanks Meter: 87
COM3 [VCP0] selected
module v3.25
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:3703:000E
status: FF
Boot Done
flash: 98000300000001:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is absent
New firmware found (v.3.25, database date: 19.01.2011):
TINNO25_GEMINI_PCB01_GPRS_MT6225_S00.E400-PK_FM_V1_1.BIN
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
rom info ver: 04
sw version: TINNO25_GEMINI_PCB01_GPRS_MT6225_S00.E400-PK_FM_V1_1.BIN
project-id: E400-PK.FM.V1.1, 00000000
ffs offset/size [01]: 00E00000/001F0000
TCL-ID is absent
ffs/eeprom chip: 00
====> Write ...
Write Done
ffs formatting...
Finalization Done
Finished, time used: 46 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following 2 Users Say Thank You to AL-KARAM MOBILE For This Useful Post:
Old 03-29-2011, 11:59   #10386 (permalink)
JINDALGSM™'s Avatar
Member: 467045
Sonork: 100.1603919
Thanks Meter: 1,705
COM2 [VCP0] selected
module v1.48
Device: Samsung-SCH-S189
connecting...
Connecting, wait...
Phone detected, wait...
step-1 done
step-2 done
step-3 done
operation finished
Finished, time used: 17 sec
The Following 2 Users Say Thank You to JINDALGSM™ For This Useful Post:
Old 03-29-2011, 12:16   #10387 (permalink)
JINDALGSM™'s Avatar
Member: 467045
Sonork: 100.1603919
Thanks Meter: 1,705
nokia 5220c flashing done
MCU : rm411__07.23.mcusw
PPM : rm411__07.23.ppm_a
CNT : rm411__07.23.image_a_a_green
Check files done...
RAP_PUB: 18C0000AD9A30254C2A5C6ACBFFB851B33D59121
ADL : Check data
ADL : Data accepted
Erase : Processing rm411__07.23.mcusw
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT
Result: 0000
Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:02:31
Write : Processing rm411__07.23.mcusw
Total 1289 [1289/0/0] blocks to write, writing...
TIME : Write time : 00:01:02
MCU Write done
Erase : Processing rm411__07.23.ppm_a
Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:01:00
Write : Processing rm411__07.23.ppm_a
Total 435 [435/0/0] blocks to write, writing...
PPM Write done
Erase : Processing rm411__07.23.image_a_a_green
Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT
Result: 0000
Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:05:28
Write : Processing rm411__07.23.image_a_a_green
Total 688 [688/0/0] blocks to write, writing...
TIME : Write time : 00:00:38
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:11:02
Reboot phone now...
Connected phone - Nokia 5220 XpressMusic
Software Info: V 07.23 17-07-09 RM-411 (c) Nokia
IMEI: 353662011337466
PPM version : V 07.23 17-07-09 RM-411 (c) Nokia A
Product code: 0563611
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 0 certs
Writen 21 certs!
Done!
Elapsed: 00:11:48
Phone found!
read info... - Ok
Old 03-29-2011, 12:25   #10388 (permalink)
Member: 144708
Sonork: 100.1615125
Thanks Meter: 387
Selected FlashSettings : FullFlash
MCU : rm443__10.10.mcusw
PPM : rm443__10.10.ppm_mb
CNT : rm443__10.10.image_mb_matt_black
Check files done...
RAP_PUB: 17500202D06F7F56872DF8519AA1687DC2EFC778
TIME : Boot time : 00:00:01
ADL : Check data
ADL : Data accepted
Erase : Processing rm443__10.10.mcusw
Found 8 areas to erase
Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT
Result: 0000
Erasing area 0x00040000 - 0x0005FFFF, NOR, CMT
Result: 0000
Erasing area 0x00060000 - 0x0007FFFF, NOR, CMT
Result: 0000
Erasing area 0x00080000 - 0x0015FFFF, NOR, CMT
Result: 0000
Erasing area 0x00160000 - 0x0023FFFF, NOR, CMT
Result: 0000
Erasing area 0x01740000 - 0x0191FFFF, NOR, CMT
Result: 0000
Erasing area 0x00240000 - 0x0173FFFF, NOR, CMT
Result: 0000
Erasing area 0x022E0000 - 0x0261FFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:02:44
Write : Processing rm443__10.10.mcusw
Total 1597 [1597/0/0] blocks to write, writing...
CMT : Writing Hash CERT [ISA+DYNSW]
TIME : Write time : 00:01:17
MCU Write done
Erase : Processing rm443__10.10.ppm_mb
Erasing area 0x01920000 - 0x022DFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:00:56
Write : Processing rm443__10.10.ppm_mb
Total 367 [367/0/0] blocks to write, writing...
TIME : Write time : 00:00:18
PPM Write done
Erase : Processing rm443__10.10.image_mb_matt_black
Erasing area 0x02620000 - 0x029BFFFF, NOR, CMT
Result: 0000
Erasing area 0x029C0000 - 0x03FBFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:03:51
Write : Processing rm443__10.10.image_mb_matt_black
Total 560 [560/0/0] blocks to write, writing...
TIME : Write time : 00:00:27
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:09:35
Reboot phone now...
-> Flashing Failed! Maybee HW error, or Downgrade try???!
Anyway - try reinsert battery and PowerUp phone manualy
Done!
Elapsed: 00:11:34
MCU : rm237__07.30.mcusw
PPM : rm237__07.30.ppm_c
CNT : rm237__07.30.image_c_tr_pink
Check files done...
-> Phone not found..
-> Error while flashing...
Check files done...
[BB5 FLASH]: GetFirstBlock Failed, Aborting
-> Error answer from BootRom
-> 1. Try make battery charge
-> 2. Try insert charger, without pressing poweron
-> 3. Try change USB port, if driver hang - restart PC
MCU : rm443__10.12.mcusw
PPM : rm443__10.12.ppm_f
CNT : rm443__10.12.image_b_steel
Check files done...
Check files done...
ADL : Check data
ADL : Data accepted
Erase : Processing rm443__10.12.mcusw
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
TIME : Erase time : 00:02:53
Write : Processing rm443__10.12.mcusw
TIME : Write time : 00:01:08
MCU Write done
Erase : Processing rm443__10.12.ppm_f
Result: 0000
Write : Processing rm443__10.12.ppm_f
Total 391 [391/0/0] blocks to write, writing...
TIME : Write time : 00:00:17
PPM Write done
Erase : Processing rm443__10.12.image_b_steel
Result: 0000
Result: 0000
TIME : Erase time : 00:03:47
Write : Processing rm443__10.12.image_b_steel
Total 648 [648/0/0] blocks to write, writing...
TIME : Write time : 00:00:28
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:09:34
Reboot phone now...
Connected phone - Nokia 6303 classic
Software Info: V 10.12 08-04-10 RM-443 (c) Nokia
IMEI: 353199037259119
PPM version : V 10.12 08-04-10 RM-443 (c) Nokia F
Product code: 0569439
Checking...
Read Info Done!
SwUpgradeSet...OK!..............6303 flashing Done with infinity best tool/////////
GSM007
The Following 2 Users Say Thank You to ***GSM007*** For This Useful Post:
Old 03-29-2011, 12:30   #10389 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,741
registered to: saeedullah_khan
MCU : C5F02102_rm495__07.97.mcusw
PPM : 4BB8AA07_rm495__07.97.ppm_mena_a1
CNT : E24393CE_rm495__07.97.image_mena_a1_red
Check files done...
RAP_PUB: 0EE00113C3B67D56F95A744A8456FE0F077F7F2C
ADL : Check data
ADL : Data accepted
Erase : Processing C5F02102_rm495__07.97.mcusw
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
TIME : Erase time : 00:02:16
Write : Processing C5F02102_rm495__07.97.mcusw
Total 1178 [1178/0/0] blocks to write, writing...
MCU Write done
Erase : Processing 4BB8AA07_rm495__07.97.ppm_mena_a1
Result: 0000
TIME : Erase time : 00:00:55
Write : Processing 4BB8AA07_rm495__07.97.ppm_mena_a1
Total 388 [388/0/0] blocks to write, writing...
TIME : Write time : 00:00:20
PPM Write done
Erase : Processing E24393CE_rm495__07.97.image_mena_a1_red
Result: 0000
Result: 0000
TIME : Erase time : 00:05:17
Write : Processing E24393CE_rm495__07.97.image_mena_a1_red
Total 656 [656/0/0] blocks to write, writing...
TIME : Write time : 00:00:34
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:10:30
Reboot phone now...
Connected phone - Nokia 5130c-2
Software Info: V 07.97 13-09-10 RM-495 (c) Nokia
IMEI: 354179039347087
PPM version : V 07.97 13-09-10 RM-495 (c) Nokia MEN
Product code: 0579033
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 0 certs
Writen 21 certs!
Done!
Elapsed: 00:11:49
Phone found!
read info... - Ok
Backup Certificates now...
Backup CRT308 data...
CRT308 Backup Created...
Check communication with phone....
ADL not support backup mode, rpl reading impossible
SimLock Data saved...
SimLock Key saved...
WMDRM_PD Data saved...
RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\BEST_v1.18.5\Backup\Cert\354179039347087_SIM. rpl
Elapsed: 00:00:00
Phone found!
read info... - Ok
The Following 2 Users Say Thank You to saeedullah_khan For This Useful Post:
Old 03-29-2011, 12:56   #10390 (permalink)
danrachita's Avatar
Member: 428861
Sonork: 100.1619141
Thanks Meter: 1,629
K220i
Sony Ericsson K220i succesfully unlocked.
Thank you Infinity Team.
BR.
COM326 [VCP0] selected
module v1.38
Device: Sony-Ericsson-K220i
"advanced chip detection" active
Action: unlock
Boot ...
Press Power button now !
loading...
Boot done
Check connection ...
Check connection done
Set baud ...
406250
Set baud done
Check hardware ...
flash: 01227E22212200:92EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
software version: R1AD001
software version: CXC1251013
version flex: CDA102807/43
imei: 3524340222xxxx
Check hardware done
Read data ...
reading Sony-Ericsson-K220i_3524340222xxxx_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_3524340222xxxx_eeprom_calibration-1_20110329-145323.80E.bin
reading Sony-Ericsson-K220i_3524340222xxxx_eeprom_calibration-2...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_3524340222xxxx_eeprom_calibration-2_20110329-145328.80E.bin
Read data done
Check data ...
Check data done
Write ...
flash: 01227E22212200:46237300000000
Write: eeprom
Write: eeprom
locks cleared
Write done
Finished, time used: 33 sec
The Following 2 Users Say Thank You to danrachita For This Useful Post:
Old 03-29-2011, 13:29   #10391 (permalink)
silhouette's Avatar
Member: 52597
Thanks Meter: 275
Nokia N8 code calculated successfully
Server version: 0.191
There are 0 free slots on the server.
Looking for jobs...Done.
You have 2 current job(s):
-->job 0: imei: 355974045xxxxxx, status: idle(no 9 on queue)
-->job 1: imei: 353391044xxxxxx, status: idle(no 420 on queue)
Archived jobs:
35594404xxxxxxx: Code: #pw+047606473943574+7#
35376304xxxxxxx: Code: #pw+557444776717692+7#
35935103xxxxxxx: Code: #pw+342281947989494+7#
Using F-bus count...
Sending code 047606473943574 Level : 7 to SimLock Server...
Simlock Server Answer: Unlock code Accepted! :)
Done!
Phone disconected!
The Following 2 Users Say Thank You to silhouette For This Useful Post:
Old 03-29-2011, 13:46   #10392 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,270
N97 Mini USB flash Report Ok
MCU : RM-555_12.0.110_prd.core.C00
PPM : RM-555_12.0.110_prd.rofs2.V44
PPM2 : RM-555_12.0.110_C01_prd.rofs3.fpsx
CNT : RM555_12.0.110_uda_4_001.uda.fpsx
APE : rm555ENOA09w24v0.050.fpsx
Check files done...
->  Check SW version...
FlashFile version : 12.0.110
Phone version : v 12.0.110
->  Error on SW version check...
CRT308 Backup Created... :)
RPL saved : c:\InfinityBox\BEST\Backup\Cert\358315037107737_SIM.rpl
ADL req restart
Communication verify done... Preparing...
Gathering phone info...
Reboot....
Waiting for communication response...
ASIC ID:       000000010000022600010006400C192101031103
EM0 ID:        00000296
EM1 ID:        00000B22
PUBLIC ID:     1A4001114086005244ED4DD15974B95605999CEB
ASIC MODE ID:  00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID:        4B9B75103E691FF8
Processing PAPUBKEYS...
Boot Done! :)
TIME : Boot time : 00:00:03
Waiting for response: 29
ADL : Auth done...
Erase : Processing RM-555_12.0.110_prd.core.C00
Found 4 areas to erase
Erasing area 0x00040000 - 0x00082FFF, NAND, CMT
Result: 0000
Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT
Result: 0000
Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT
Result: 0000
Erasing area 0x00D60000 - 0x0D39FFFF, NAND, CMT
Result: 0000
Erase partition 0x0A
Partition erase Ok
Partitioning : Ok [5]
TIME : Erase time : 00:00:01
Write : Processing RM-555_12.0.110_prd.core.C00
Total 486 [486/0/0] blocks to write, writing...
CMT : Writing Hash CERT [ADA]
CMT : Writing Hash CERT [RAP3NAND]
CMT : Writing Hash CERT [SOS*UPDAPP]
CMT : Writing Hash CERT [SOS*DSP0]
CMT : Writing Hash CERT [SOS*ISASW]
CMT : Writing Hash CERT [SOS+CORE]
CMT : Writing Hash CERT [SOS+ROFS1]
MCU Write done
Erase : Processing RM-555_12.0.110_prd.rofs2.V44
Erasing area 0x094A0000 - 0x0C49FFFF, NAND, CMT
Result: 0000
TIME : Erase time : 00:00:00
Write : Processing RM-555_12.0.110_prd.rofs2.V44
Total 95 [95/0/0] blocks to write, writing...
CMT : Writing Hash CERT [SOS+ROFS2]
TIME : Write time : 00:00:07
PPM Write done
   ===Flashing [PPM2]===
Erase : Processing RM-555_12.0.110_C01_prd.rofs3.fpsx
Erasing area 0x0C4A0000 - 0x0D39FFFF, NAND, CMT
Result: 0000
Write : Processing RM-555_12.0.110_C01_prd.rofs3.fpsx
Total 7 [7/0/0] blocks to write, writing...
CMT : Writing Hash CERT [SOS+ROFS3]
TIME : Write time : 00:00:00
PPM Write done
Erase : Processing RM555_12.0.110_uda_4_001.uda.fpsx
Erasing area 0x0D3A0000 - 0x1EF7FFFF, NAND, CMT
Result: 0000
Write : Processing RM555_12.0.110_uda_4_001.uda.fpsx
Total 97 [97/0/0] blocks to write, writing...
TIME : Write time : 00:00:09
CNT Write done
   ===Flashing [APE]===
Erase : Processing rm555ENOA09w24v0.050.fpsx
Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT
Result: 0000
Write : Processing rm555ENOA09w24v0.050.fpsx
Total 17 [17/0/0] blocks to write, writing...
CMT : Writing Hash CERT [SOS*ENO]
APE Write done
ADL : End flashing
ADL : Finalize...
Flashing done!
Total flash time : 00:00:53
Reboot phone now...
Connected phone -   Nokia N97 mini
Software Info:     V ICPR72_09w44.18 28-05-10 RM-555 (c) Nokia
IMEI:  358315037107737
Ape Version: v 12.0.110
Product code:  0591336
Checking...
Read Info Done!
SwUpgradeSet...OK!
Product code update...
Set phone to Normal mode...
Done!
Elapsed: 00:01:36
The Following 2 Users Say Thank You to Mohsin-* For This Useful Post:
Old 03-29-2011, 14:04   #10393 (permalink)
Pratheesh T K's Avatar
Member: 866865
Sonork: 1645198
Thanks Meter: 182
Sucussfuly unlcked Vodafone 543(alcatel 543x)
COM6 [VCP0] selected
module v3.80
Device: Alcatel-543X
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:3C03:A00A
status: 01
Boot Done
flash: 98006F00000004:09EA0000000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
otp offset: 01FE0000
Initialize Done
====> Set baud ...
115200
Set baud Done
usb bootloader (chip) is present: 00020000
rom info structure: [protected] type (07), 1 record(s)
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.3D3B6719 .[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_814E5441].rpl
TCL-ID detection...
TCL-ID detection done
device-id: 3D3B6719
rom info ver: 07
sw version: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN
project-id: MAUI.08A.W08.40.SP1.V32.F3, 41544E81
code offset: 00020000
ffs offset/size [01]: 01800000/00800000
TCL-ID identification
version: 267
provider: 543X-2FVDGB1
customization: CN26FC01
customization: XN26FC01
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 01800000
startup code area #1 fixed
product id: JRDHUIZHOU_MT6225_OTMINI_SERIES
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, cust) calculation...
error: security area (sec info, cust) header is invalid
security area (sec info, hash) calculation...
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
warning: wrong cs at 0x00014000, retry...
read error recovered
warning: wrong cs at 0x00014C00, retry...
warning: wrong cs at 0x00015400, retry...
warning: wrong cs at 0x00015800, retry...
warning: wrong cs at 0x00017800, retry...
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
identification header detected
customization name adjusted
warning: wrong cs at 0x017EE400, retry...
warning: wrong cs at 0x017F4400, retry...
warning: wrong cs at 0x017F6000, retry...
warning: wrong cs at 0x017F9800, retry...
warning: wrong cs at 0x017FB800, retry...
warning: wrong cs at 0x017FFC00, retry...
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
done
done
original imei: 35982003592205
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: c:\InfinityBox\MModule\backup_security\Alcatel-543X_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_ 40_SP1_V32_F3__system_log_3D3B6719_814E5441_201103 29-182515.B0X.bin
Finished, time used: 8 min 22 sec
Am modify a USB CABLE(CA-101D)
AM FOUND 4 COLOUR CABLE IN THE USB CABLE
GREEN, WHITE, BLACK, AND RED
GREEN CONNECTED TO TX ON THE RJ47 CABLE
AND WHITE CONECTER TO RX
AND BLACK TO THE GROUND
AM HAPPY WITH INFINITY BOX
The Following 2 Users Say Thank You to Pratheesh T K For This Useful Post:
Old 03-29-2011, 14:05   #10394 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
N73 repair SD and security Ufs ok
UFS S/N 82508 boot - Ok
Phone found!
Series 60 Device detected!
read info...  - Ok
Checking StartUp data ...
SDD Key status : SDData Damaged!!!!! :(
PA_SimLock Version :
PA_SL phone detected
Done!
Read Uniq key data started...
Phone Imei: 357651012721527
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
APE part info :
APE ASICID   : 17100708
APE MODE ID : 00
APE PUB ID    : 5468BB63172D909D6D9A0015612A0CD262A99FEC
APE R_HASH  : 49A97E826B93BA20B7ED0B082475C005
APE ROM ID  : 1DFD66132C872FD4
CMT part info :
CMT ASICID   : 000000010000022600010006010C192101003000
CMT EM0 ID  : 00000295
CMT EM1 ID  : 00000B22
CMT PUB ID  : 1280010D653E6350799FCF5AC5C79E11DB926407
CMT MODE ID : 00
CMT R_HASH  : BAF3A9C3DBFA8454937DB77F2B8852B1
CMT ROM ID  : 273F6D55DFAAF68F
CMT : Sending 2nd loader...
CMT Loader sent, Boot Ok
rap= 1280010D653E6350799FCF5AC5C79E11DB926407
hash= BAF3A9C3DBFA8454937DB77F2B8852B1
key= 67204EA96F47ECFE2779B274B050F9A7413855A2
Init Service mode... Wait...
Key file updated...
Done!
Repair SD procedure started...
Key file exists, no need to read...
Operating mode is OK, no need change...
Writing Super Dongle Key...   Ok
Done!
SDD Key status : SD Data is Ok
Security status : Security Damaged!!!!! :(
Done!
Local SX4 procedure started...
Use custom key...
Step 1...
Step 2...
Step 3...
SX4 Auth - Ok
Done!
Uploading RF/Battery tune to phone...
Using : RM-133.pm
Field 1
   Record 0 write - Ok
   Record 2 write - Ok
   Record 4 write - Ok
   Record 6 write - Ok
   Record 8 write - Ok
   Record 13 write - Ok
   Record 16 write - Ok
   Record 18 write - Ok
   Record 20 write - Ok
   Record 22 write - Ok
   Record 23 write - Ok
   Record 24 write - Ok
   Record 25 write - Ok
   Record 26 write - Ok
   Record 28 write - Ok
   Record 29 write - Ok
   Record 31 write - Ok
   Record 33 write - Ok
   Record 34 write - Ok
   Record 44 write - Ok
Field 309
   Record 0 write - Ok
   Record 1 write - Ok
   Record 2 write - Ok
   Record 4 write - Ok
   Record 5 write - Ok
   Record 7 write - Ok
   Record 8 write - Ok
   Record 17 write - Ok
Check ST_SECURITY now...
Security status : ST_SECURITY => OK
Done!
Elapsed: 00:00:01
Old 03-29-2011, 14:07   #10395 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
3120c Unlock Ok
Phone found!
read info...  - Ok
Connected phone -    Nokia 3120 classic
Software ver : V 07.16 27-05-08 RM-364 (c) Nokia
IMEI    :      354849027815028
Ape Ver :
APE Var :
APE ADSP:
DSP Ver :      ICPR71_08w17
APE Test:
PPM     :      V 07.16
27-05-08
RM-364
(c) Nokia
C
CNT     :      Content: 3_uk
V 07.16
27-05-08
RM-364
(c) Nokia
Product SN   :     KKS274372
Product code :     0561596
Base Prd.code:     0553930
Module code  :     0203882
Long Prod.SN :     0
Hardware info=======
HWID  : 2002
Retu  : 15
Tahvo : 22
Batery: 4668 mV
Camera:
CMT BT: Error
APE BT:
APE HW: Error
LCDVer: Error
RF ic : Error
Lock info ===========
IMEI spNet :
IMEI svNet :
Conf key     : 8000000000000002
Provider key : 2342000000000000
Provider    : Hutchinson 3G (3);United Kingdom
Counters   : Key 0  [3] , Fbus 0  [10]
Blocks      : 2
LOCK STATUS :
BLK : 1
 Lock1:Close
BLK : 2
 Lock1:Close
LOCKS :  Closed
User Code : not set
MMC pwd  : no any record found
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
Unlock procedure started...
Phone Imei: 354849027815028
Checking locks...
Blocks      : 2
LOCK STATUS :
BLK : 1
 Lock1:Close
BLK : 2
 Lock1:Close
LOCKS :  Closed
PA_SL2 phone detected...
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT PUB ID  : 2490000297F67C563369FCB873D36E6EC7076EE4
CMT MODE ID : 00
rap= 2490000297F67C563369FCB873D36E6EC7076EE4
key= 3D3317BCEA49B3DCA07EBAD6C462A67EB74EF62F
Key file updated...
Sending code 226992983079871 Level : 7 to SimLock Server...
Done!
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.75900 seconds with 10 queries
