Old 11-23-2009, 10:45   #1336 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
COM3 [VCP0] selected
module v1.71
Device: Zong-A136
Checking data, wait...
Action: "repair imei"
new imei: 350000000000006
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20091123-014344.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20091123-014344.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20091123-014346.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_imei-area_20091123-014419.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20091123-014422.B1E.bin
backup critical area Done
Check memory ...
lock found
lock type #1 found
imei found #1
Check memory Done
Write ...
Erasing: imei-area
Writing: imei-area
Erasing: lock-area
Writing: lock-area
Erasing: eeprom-security
Writing: eeprom-security
Write Done
Finished, time used: 103 sec
Remove/Install battery now !
Finished
The Following User Says Thank You to cel_phon For This Useful Post:
Old 11-23-2009, 10:46   #1337 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
module v1.71
Device: Zong-A136
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
loading data...
data loaded
Check memory ...
lock found
lock type #1 found
imei found #1
Check memory Done
Write ...
Erasing: imei-area
Writing: imei-area
Erasing: lock-area
Writing: lock-area
Write Done
Finished
Old 11-23-2009, 11:31   #1338 (permalink)
limem2003's Avatar
Member: 108627
Thanks Meter: 307
COM3 [VCP1] selected
module v2.95
Device: Alcatel-708X, 708A
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:9003:A00F
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98006F00000003:09EA0000000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.039D1 A55.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_FC4F51B9].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 039D1A55
rom info protocol ver: 07
ver. sw 1: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN
ver. sw 2: MAUI.08A.W08.40.SP1.V32, B9514FFC
address offset: 00020000
ffs offset/size: 01800000/00800000
TCL-ID identification
version: 169
provider: 708X-2BRGFR1
customization: CN16CB27
customization: XN16CB27
TCL-ID identification done
ffs address assigned: 01800000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRDHUIZHOU_MT6225_OTMINI_SERIES
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, part #2) calculation...
error: security area (sec info, part #2) header is invalid
security area (sec info, part #1) calculation...
use default security area (sec info, part #1) pattern
max address is too big, should be recalculated: 00006F50
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
identification header detected
customization name adjusted
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
done
done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 00000000000000
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_039D1A55_FC4F51B9_20 091123-111400.B0X.bin
Finished, time used: 295 sec
The Following User Says Thank You to limem2003 For This Useful Post:
Old 11-23-2009, 11:35   #1339 (permalink)
diljan_07's Avatar
Member: 434968
Sonork: 100.1590883
Thanks Meter: 580
Alcatel-S319X unlock done
COM32 [VCP0] selected
module v2.94
Device: Alcatel-S319X, S319A
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:03C3:A00C
status: 01
Boot Done
flash: 98000300000001:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
Initialize Done
====> Set baud ...
921600
Set baud Done
rom info structure: 2nd [standard] generation
TCL-ID is present
TCL-ID detection...
rom info protocol ver: 05
ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN
ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000
address offset: 00000000
ffs offset/size: 00C00000/00400000
version: 16U
provider: S319X-2HWTCH1
customization: CH16ET30
customization: XH16ET30
ffs address assigned: 00C00000
product id: JRD_COMMUNICATION_U82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__00000000_20091123-153038.B0X.bin
Finished, time used: 193 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to diljan_07 For This Useful Post:
Old 11-23-2009, 11:57   #1340 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
LG-KP100
COM4 [VCP0] selected
module v1.66
Device: LG-KP100
Action: unlock
read unlock codes
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .01 ULC2GL KP100 VODAFONE DE 01 FL 49 V10a 262-02 AUG-21-2008
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20091122-150249.B1E.bin
loading data...
data loaded
imei: 35490303575193900
reading eeprom-security_35490303575193900...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35490303575193900_20091122-150250.B1E.bin
reading eeprom-complete_35490303575193900...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35490303575193900_20091122-150257.B1E.bin
Check memory ...
loading data...
data loaded
code: 00150722
Finished, time used: 21 sec
The Following User Says Thank You to ehsas_ghum For This Useful Post:
Old 11-23-2009, 11:58   #1341 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
6300
module v2.82
Device: Autodetect 6205-6227 NOR
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:C903:0005
status: FF
Boot Done
Initialize ...
flash: 01227E22202200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
115200
Set baud Done
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.1EC52065.[JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN_9E607E91].rpl
identification#1 detection finished
device-id: 1EC52065
identification#1 protocol ver: 04
ver. sw 1: JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN
ver. sw 2: MAUI.07A.W07.52.MP.V2, 6E819F61
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\J IA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V2 __system_log_1EC52065_9E607E91_20091123-131706.B0X.bin
Finished, time used: 46 sec
Old 11-23-2009, 12:01   #1342 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
kp100 repair restart ok
module v1.66
Device: LG-KP100
Action: reset
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .01 ULC2GL KP105 KP100 P16 00 ARB V10b ARB-XX DEC-27-2007
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20091122-162838.B1E.bin
loading data...
data loaded
imei: 35996001186194700
reading eeprom-security_35996001186194700...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35996001186194700_20091122-162840.B1E.bin
reading eeprom-complete_35996001186194700...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35996001186194700_20091122-162846.B1E.bin
Check memory ...
Check memory Done
Write ...
reset...
done
Write Done
Finished, time used: 27 sec
Old 11-23-2009, 12:20   #1343 (permalink)
NawabN Sahoo's Avatar
Member: 687312
Thanks Meter: 290
T303 Successfully Unlocked:
Device: Sony-Ericsson-T303
Done
==== log: [2009/11/23 03:10:48 È.Ù] ====
COM17 [VCP0] selected
module v1.34
"advanced chip detection" active
Action: unlock
Boot ...
Press Power button now !
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection ...
Check connection done
Set baud ...
203125
Set baud done
Check hardware ...
flash: 89890400040089:89890400000000
flash: Intel ST [def 0080x040000] 32Mb
software version: 1209-8242
software version: R2CA005
Check hardware done
Read data ...
reading Sony-Ericsson-T303_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T303_eeprom_calibration-1_20091123-151242.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 156 sec
WBR
The Following User Says Thank You to NawabN Sahoo For This Useful Post:
Old 11-23-2009, 12:49   #1344 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
COM23 [VCP0] selected
module  v2.90
Device: Thomson-TH102
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6205:8B00]...
CPU: MT6205
Boot Done
Initialize ...
flash: 01227E220A2201:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb
Initialize Done
Set baud ...
921600
Set baud Done
detect device rom info...
detection phase #2...
warning: rom info information not found, possible reasons:
.old firmware type w/o rom info data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device rom info finished
ffs address can not be detected, value from database assigned: 00380000/00080000
detect device sec info...
detect device sec info finished
reading: Thomson-TH102__ffs...
file saved: C:\Documents and Settings\Shakeel Software\Desktop\Thomson-TH102__ffs_20091123-164406.B0E.bin
Write ...
Write Done
Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 206 sec
Regards.
The Following User Says Thank You to Shakeel_pattoki For This Useful Post:
Old 11-23-2009, 12:51   #1345 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
module v1.37
Device: Motorola-C168
Action: flash write
"format ffs" active
write: Firmware
C168_Main_9-1490-000.69M.bin
write: Flex/Customization
C168_Flex_1490-013.69F.bin
write: Language Pack
C168_LP_1490-008_En_Fr_Arabic_Farsi_Urdu.69P.bin
skip: FFS/File system
write: Images
C168_Images_1490-004.69G.bin
write: Melody
C168_Melody_1490-004.69G.bin
skip: Eeprom
Boot ...
loading...
Boot done
Set baud ...
812500
Set baud done
Check hardware ...
flash: 89886400010001:89886400000000
flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb
software version: 1490-000
software version: TCT-9-
Check hardware done
Read data ...
reading Motorola-C168_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Motorola-C168_eeprom_calibration-1_20091123-034705.69E.bin
reading Motorola-C168_ffs...
file saved: C:\Program Files\InfinityBox\HModule\Motorola-C168_ffs_20091123-034744.69E.bin
Read data done
Check data ...
Check data done
Write ...
Area: Firmware
Write: Firmware
Area: Flex/Customization
flash: 89886400000000:89886400000000
Write: Flex/Customization
Area: Language Pack
Write: Language Pack
Area: Images
Write: Images
Area: Melody
Write: Melody
Erase: ffs
ffs format done
Write done
Finished, time used: 291 sec
Old 11-23-2009, 17:55   #1346 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,534
::::successfully unlock alcatel s621x with infinity::::
::::here is log files::::
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:E103:A007
status: 01
Boot Done
flash: 01227E22302200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is present
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.43709 A0F.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_CBC62112].rpl
TCL-ID detection...
device-id: 43709A0F
ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN
ver. sw 2: MAUI.06B.W07.28.SP1.V34, 1221C6CB
ffs offset/size: 01020000/00FE0000
version: 556
provider: S621X-2AVRGB1
customization: CD55CW40
customization: XD55CW40
ffs address assigned: 01020000
product id: JRD_COMMUNICATION_B82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
original imei: 35199*********
firmware patch sp-lock #1 is not required
firmware patch sp-lock #2 is not required
====> Write ...
startup code area #1 calculation...
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S621X,S621A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34__system_log_43709A0F_CBC62112_20 091123-093410.B0X.bin
Area: Firmware
Write: Firmware
sec info (fast) detection...
relocation table detected
name table detected
customization detected: CD55AM40
customization: CD55AM40
done
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S621X,S621A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34__system_log_43709A0F_CBC62112_20 091123-094753.B0X.bin
Finished, time used: 877 sec
The Following User Says Thank You to .::M Irfan::. For This Useful Post:
Old 11-23-2009, 18:10   #1347 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,534
:::successfully review dead T33i+ new with infinity just with formating:::
COM6 [VCP0] selected
module v3.00
Do you want to make ffs/eeprom backup before format ?
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:1C03:0008
status: FF
Boot Done
flash: 89881500010001:89881500000000
flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is absent
rom info protocol ver: 04
ver. sw 1: T1C2O9N_0427_ML_B06.BIN
ver. sw 2: T1C2O9N_0427_ML_B06, 00000000
checking area [00000000]: 00010000-00FFFFFF...
ffs/eeprom found near: 00E40000
Detected ffs/eeprom address is non-standard: 00E40000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00E40000
ffs/eeprom size: 001C0000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E40000-00FFFFFF
====> Write ...
Write Done
ffs formatting...
Finalization Done
Finished, time used: 57 sec
Old 11-24-2009, 05:59   #1348 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
module v2.75
Action: touchscreen calibration
mode: 2
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6225
high speed boot On
chip: 0001:A803:000E
Connecting, wait...
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: A25_B_268D_F_8.GEMINI.1.0
Version: VIGORTECH25_GEMINI_HW
detecting structure #2...
5 11 done
67 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
detecting structure #5 (mode-3)...
0 1 2 3 done
209 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 11 sec
Old 11-24-2009, 08:24   #1349 (permalink)
Temporary banned !!
Member: 206532
Sonork: 100.1622270
Thanks Meter: 876
COM5 [VCP0] selected
module v1.71
Device: Zong-A136
Action: unlock
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
230400
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20091124-122327.B1E.bin
loading data...
wrong database file: C:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg
error: can't load database v.11
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20091124-122327.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20091124-122331.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20091124-122338.B1E.bin
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 47 sec
The Following User Says Thank You to alis For This Useful Post:
Old 11-24-2009, 10:25   #1350 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
module  v2.91
Action: reset settings
19200 autodetect
CPU: MT6225
high speed boot On
chip: 0001:8503:0006
status: FF
Connecting at 19200, wait...
Date: 2006.06.14
Version: 1.0
Version: S90_TOSHIBA_MP_V003
Version: S90_V1.0_HW
 5 11 done
67 byte(s) read
connection Ok
building list...
done
items to clear: 158
warning: wrong packet cs
items cleared: 158 of 158
building list...
done
items remains: 0
Finished, time used: 61 sec
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.44982 seconds with 10 queries
