Old 11-24-2009, 11:27   #1351 (permalink)
Member: 337837
Thanks Meter: 538
.:::::: Vodafone indie unlocked successfully with infinity :::::::.
COM9 [VCP0] selected
module v2.94
Device: Vodafone-Indie
Checking data, wait...
Action: "format ffs"
Do you want to make ffs/eeprom backup before format ?
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:8303:0009
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
Initialize Done
====> Set baud ...
230400
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.90933 CC8.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA1 08.BIN_D3155415].rpl
rom info detection finished
device-id: 90933CC8
rom info protocol ver: 04
ver. sw 1: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA1 08.BIN
ver. sw 2: X761_Z2_SF_BFFA108, 155415D3
address offset: 00000000
ffs offset/size: 00E00000/00200000
ffs address assigned: 00E00000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: Vodafone-Indie_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF _BFFA108__ffs...
file saved: C:\Program Files\InfinityBox\MModule\Vodafone-Indie_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF _BFFA108__ffs_20091124-151628.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-Indie_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF _BFFA108__system_log_90933CC8_D3155415_20091124-151648.B0X.bin
Finished, time used: 172 sec
Remove/Install battery now !
The Following User Says Thank You to sairat For This Useful Post:
Old 11-24-2009, 11:31   #1352 (permalink)
sajidali's Avatar
Member: 181886
Sonork: 100.1579817
Thanks Meter: 1,007
<<<<<<<A35 Unlock Done>>>>>>
Screen Short
The Following User Says Thank You to sajidali For This Useful Post:
Old 11-24-2009, 11:43   #1353 (permalink)
Member: 337837
Thanks Meter: 538
.::::: c558 chinese repaired white screen ok :::::.
module v2.98
Device: Autodetect 6205-6227 NOR
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:0503:0008
status: FF
Boot Done
Initialize ...
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
921600
Set baud Done
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
TCL-ID is absent
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.0CB504A5.[C558P_3_PCB01_GPRS_MT6225_S00.00_3.BIN_6EC8A126].rpl
New firmware detected (v.2.98, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
device-id: 0CB504A5
ver. sw 1: C558P_3_PCB01_GPRS_MT6225_S00.00_3.BIN
ver. sw 2: C558P_3.00.3, 26A1C86E
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
reading: C558P_3_PCB01_GPRS_MT6225_S00.00_3__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\C558P_3_PCB01_GPR S_MT6225_S00.00_3__ffs_20091124-153506.B0E.bin
Write ...
Write Done
Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\C 558P_3_PCB01_GPRS_MT6225_S00.00_3__system_log_0CB5 04A5_6EC8A126_20091124-153606.B0X.bin
Finished, time used: 178 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 11-24-2009, 11:55   #1354 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
n95 FORMATE ok
COM4 [VCP0] selected
module v2.82
Action: reset settings
Model: Autodetect 6205-6227 NOR
19200 autodetect
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:B65A:3CB7
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: MAUI.06A.W06.48.MP.V25
Version: MK6227_06A_HW
detecting structure #2...
0 done
44 byte(s) read
imei: 35954201173812
connection Ok
building list...
done
items to clear: 162
warning: wrong packet cs
items cleared: 162 of 162
items remains: 0
Finished, time used: 29 sec
The Following User Says Thank You to ehsas_ghum For This Useful Post:
Old 11-24-2009, 12:46   #1355 (permalink)
Member: 202611
Thanks Meter: 51
Thumbs up s621x unlocked fine 2day
COM5 [VCP0] selected
module v2.96
Device: Alcatel-S621X, S621A
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:C303:A00B
status: 01
Boot Done
flash: 01227E22422200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is present
startup code area #1 backup saved: D:\Program Files\InfinityBox\MModule\backup_security\id.55FAB 6DB.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_CBC62112].rpl
TCL-ID detection...
TCL-ID detection done
device-id: 55FAB6DB
rom info protocol ver: 05
ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN
ver. sw 2: MAUI.06B.W07.28.SP1.V34, 1221C6CB
ffs offset/size: 01020000/00FE0000
TCL-ID identification
version: 556
provider: S621X-2AVRGB1
customization: CD55CW40
customization: XD55CW40
TCL-ID identification done
ffs address assigned: 01020000
startup code area #1 check...
startup code area #1 fixed
sim-lock status: enabled
product id: JRD_COMMUNICATION_B82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
security area (sec info, part #2) calculation...
identification header detected
customization name adjusted
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
security area (sec info, part #1) calculation...
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
original imei: 35199002126590
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S621X,S621A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34__system_log_55FAB6DB_CBC62112_20 091124-144212.B0X.bin
Finished, time used: 248 sec
thanx to infinity team
The Following User Says Thank You to stivubicco For This Useful Post:
Old 11-24-2009, 15:22   #1356 (permalink)
alis's Avatar
Member: 206532
Sonork: 100.1622270
Thanks Meter: 876
zte gr231
module v2.95
Action: unlock
unlock method: smart fast
Model: ZTE-R231
19200 autodetect
Initializing [6235:8A04:8A01]...
CPU: MT6235
chip: 0000:0000:0003
status: FF
rom: 4D573031
Hardware: MT6235,E04
Date: 2000.00.00
Version: 1.0
Version: ORANGE_ENG_EN_P107A1V1.0.4B02
Version: 08BZTENJ35_OG_08B
80 byte(s) read
imei: 35424903004819
connection Ok
186 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
174 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 35 sec
The Following User Says Thank You to alis For This Useful Post:
Old 11-25-2009, 06:57   #1357 (permalink)
thushdt's Avatar
Member: 544160
Sonork: 100.1603100
Thanks Meter: 180
China N98 8gb repair done
module v2.93
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
chip: 0031:BA02:BB68
status: FF
high speed boot Off
boot packet size: 0002
Boot Done
Initialize ...
flash: EC257E25082501:2CEA0000000000
Initialize Done
Set baud ...
921600
Set baud Done
it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
detect device rom info...
detection phase #1...
detect device rom info finished
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.F7C77FA0.[N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32.B IN_BCAF2066].rpl
New firmware detected (v.2.93, database date: unknown):
device-id: F7C77FA0
ver. sw 1: N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32.B IN
ver. sw 2: MAUI.06B.W07.04.MP.V32, 99DF5043
ffs/eeprom chip: 00
detect device sec info...
detect device sec info finished
reading: N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\N95_PCB01_GPRS_MT 6226_S01.MAUI_06B_W07_04_MP_V32__ffs_20091125-105637.B0E.bin
Write ...
Write Done
Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__s ystem_log_F7C77FA0_BCAF2066_20091125-105654.B0X.bin
Finished, time used: 381 sec
The Following User Says Thank You to thushdt For This Useful Post:
Old 11-25-2009, 08:34   #1358 (permalink)
Member: 1002206
Thanks Meter: 5
ZTEX760 unlocking done
COM7 [VCP0] selected
module  v2.96
Action: unlock
Model: ZTE-X760
19200 autodetect
CPU: MT6225
chip: 0001:4503:0005
status: FF
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: X760_Z15UK_FS_BFFA106
Version: ZTEMT25_07A_HW_C
44 byte(s) read
imei: 35235302250379
connection Ok
157 byte(s) read
reading data...
reading data #2...
writing data...
145 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 10 sec
The Following User Says Thank You to 1st_choys For This Useful Post:
Old 11-25-2009, 09:44   #1359 (permalink)
Member: 436948
Thanks Meter: 4
COM3 [VCP0] selected
Device: E365
Device must be POWERED-ON !
Connecting, wait...
Device connected. Working...
current imei: *******************
software version: 0139.MOTOROLA_T66
flex version: FLEX.90.63.2007
simlock write Ok
Thanx Infinity
The Following User Says Thank You to aashiq14 For This Useful Post:
Old 11-25-2009, 12:34   #1360 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
ZTC
ZT168 CALIBRATION OK
READ LOG
==== log: [11/25/2009 1:59:12 PM] ====
module v3.00
Action: read NOR flash
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:4203:0004
status: FF
Boot Done
flash: 01227E22202200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
rom info structure: 2nd [standard] generation
TCL-ID is absent
New firmware detected (v.3.00, database date: 20.11.2009):
SUNPLUS25_06B_PCB01_GPRS_MT6225_S00.C5702C_V01_08_ IL_OV_070911_MSP.BIN
ver. sw 1: SUNPLUS25_06B_PCB01_GPRS_MT6225_S00.C5702C_V01_08_ IL_OV_070911_MSP.BIN
ver. sw 2: C5702C_V01.08_IL_OV_070911_MSP, 00000000
standard ffs/eeprom offset confirmed: 00E00000
ffs/eeprom chip: 00
reading: SUNPLUS25_06B_PCB01_GPRS_MT6225_S00.C5702C_V01_08_ IL_OV_070911_MSP__fullflash...
file saved: C:\Documents and Settings\Administrator\My Documents\New Folder\SUNPLUS25_06B_PCB01_GPRS_MT6225_S00.C5702C_ V01_08_IL_OV_070911_MSP__fullflash_20091125-142930.B0M.bin
Finished, time used: 1822 sec
CALIBRATION LOG
module v3.00
Action: touchscreen calibration
How to calibrate touchscreen:
- for this operation you need to have full flash backup from phone
- if you have full flash backup already press "Yes", select full flash file and follow instructions given by software
- if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure
Do you have full flash backup ?
Loading file v.02...
SUNPLUS25_06B_PCB01_GPRS_MT6225_S00.C5702C_V01_08_ IL_OV_070911_MSP__fullflash_20091125-142930.B0M.bin loaded
ffs/eeprom record offset detected
ffs/eeprom record size detected
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: C5702C_V01.08_IL_OV_070911_MSP
Version: MTK_25_06B_0726V54
44 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
512 byte(s) read
160 byte(s) read
reading data #2...
512 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 27 sec
Old 11-26-2009, 01:33   #1361 (permalink)
motursa's Avatar
Member: 112034
Thanks Meter: 60
Thumbs up Verykool i250 Movistar EL SALVADOR + Pinfinder
The Following User Says Thank You to motursa For This Useful Post:
Old 11-26-2009, 06:14   #1362 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
COM8 [VCP0] selected
module v2.98
19200 autodetect
CPU: MT6226
high speed boot Off
chip: 0031:276A:876A
status: FF
Date: 2005.04.12
Version: 1.0
Version: V2.0628.0.0.1
Version: NokiaN73(11)
done
60 byte(s) read
connection Ok
building list...
done
items to clear: 167
items cleared: 160 of 167
building list...
done
items remains: 7
Finished, time used: 74 sec
The Following User Says Thank You to cel_phon For This Useful Post:
Old 11-26-2009, 07:59   #1363 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
NKTEL REPAIR
module v3.00
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:2A03:000C
status: FF
Boot Done
flash: 98000300000001:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is absent
NEOTEL25_GEMINI_PCB01_GPRS_MT6225_S00.GP2522_ADD_C DGB_EN_V1_1.BIN
ver. sw 1: NEOTEL25_GEMINI_PCB01_GPRS_MT6225_S00.GP2522_ADD_C DGB_EN_V1_1.BIN
ver. sw 2: GP2522_ADD_CDGB_EN_V1.1, 00000000
ffs/eeprom found near: 00E20000
Detected ffs/eeprom address is non-standard: 00E20000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
standard ffs/eeprom address confirmed by user: 00E00000
ffs/eeprom chip: 00
====> Write ...
Write Done
ffs formatting...
Finalization Done
Finished, time used: 60 sec
Old 11-26-2009, 08:37   #1364 (permalink)
GsmTower's Avatar
Member: 226755
Thanks Meter: 198
>> OT-280 Langage French 100% Unlocked <<
All unlocked with french SimFree !
- Check "Format FFS durinf write" in flash mode.
- Load Firmware "280X-2AALFR1-681_XH68WQ03_JRD23_07A_PCB01_GPRS_MT6223_S00[1].MAUI_07A_W07_36_SP1_V25_2009-02-12_En_Fr_Es_It_De_simfree.B0M.bin"
- Click "Write".
- Put sim card and press Power On until the phone start.
- PHONE UNLOCKED !
GSMTOWER
The Following User Says Thank You to GsmTower For This Useful Post:
Old 11-26-2009, 09:16   #1365 (permalink)
GsmTower's Avatar
Member: 226755
Thanks Meter: 198
>> OT-363 Langage French 100% Unlocked <<
OT-363 - All unlocked with french SimFree !
- Load Firmware "363X-2AALEU1-233_XI26AB30_JRD23_08A_PCB01_GPRS_MT6223P_S00[1].MAUI_08A_W08_36_SP1_V9_2009-08-03_En_Fr_Es_It_De_simfree.B0M.bin"
- Click "Write".
- PHONE UNLOCKED !
GSMTOWER
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.64430 seconds with 10 queries
