Old 11-26-2009, 09:33   #1366 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
COM8 [VCP0] selected
module v2.98
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:2303:000F
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: L_2010_v1.7.9
Version: 2010-REV.B
detecting structure #2...
5 11 done
67 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
building list...
done
items to clear: 159
warning: wrong packet cs
items cleared: 159 of 159
items remains: 0
Finished, time used: 64 sec
Remove/Install battery now !
The Following User Says Thank You to cel_phon For This Useful Post:
Old 11-26-2009, 09:34   #1367 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
Action: imei
Phone should be Switched ON !
Connecting, wait...
imei-1: 135790246811220
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono CPU
new imei-1: 350000000000006
verification Ok
Finished, time used: 15 sec
Power off phone now !
Old 11-26-2009, 10:23   #1368 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
module v2.98
19200 autodetect
CPU: MT6225
high speed boot On
chip: 0001:A503:0001
status: FF
Date: 2006.06.14
Version: 1.0
Version: sygj.6300.1.2.3.2
Version: W25_GEMINI_HW
5 11 done
67 byte(s) read
imei: 35935601890419
connection Ok
building list...
done
items to clear: 166
items cleared: 166 of 166
building list...
done
items remains: 0
Finished, time used: 28 sec
Old 11-26-2009, 10:27   #1369 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
OM8 [VCP0] selected
module v2.98
Device: Autodetect 6205-6227 NOR
Action: "format ffs"
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
boot packet size: 0400
Boot Done
Initialize ...
flash: 98000300000000:18E59F00000000
flash: Toshiba AMD/Fujitsu std [def 0008x004000 007Fx020000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
921600
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
rom info protocol ver: 04
ver. sw 1: MT6225_GEMINI_PCB01_GPRS_MT6225_S00.SYGJ_6300_1_2_ 3_2.BIN
ver. sw 2: sygj.6300.1.2.3.2, 00000000
address offset: 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: MT6225_GEMINI_PCB01_GPRS_MT6225_S00.SYGJ_6300_1_2_ 3_2__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\MT6225_GEMINI_PCB 01_GPRS_MT6225_S00.SYGJ_6300_1_2_3_2__ffs_20091126-012704.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 130 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 11-26-2009, 10:29   #1370 (permalink)
StRaNgE PeRsOn's Avatar
Member: 391445
Sonork: 100.1583575
Thanks Meter: 392
COM3 [VCP0] selected
module  v2.79
Action: unlock
unlock method: smart fast
Model: ZTE-195
19200 autodetect
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:1ADC:000C
status: FF
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: AE-UAE-ET-P109A2FMV1.0.0B04
Version: 07AZTENJ23_07A_PMJ
44 byte(s) read
imei: 358xxxxxxxxxxx
connection Ok
157 byte(s) read
reading data...
reading data #2...
reading data #3...
reading data #4...
reading data #5...
building new data...
writing data...
145 byte(s) read
reading data...
writing data...
verifying...
verification Ok
done
Finished, time used: 20 sec
The Following User Says Thank You to StRaNgE PeRsOn For This Useful Post:
Old 11-26-2009, 10:34   #1371 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
Action: imei
Connecting, wait...
verification Ok
Finished, time used: 12 sec
Old 11-26-2009, 10:41   #1372 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
module v2.98
Action: write NOR flash
write: Firmware
MT6225_GEMINI_PCB01_GPRS_MT6225_S00.SYGJ_6300_1_2_ 3_2_16m_En_Ru_Fr_Es_Vn_Tr_Pt_Ar.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
921600
Set baud Done
TCL-ID is absent
ffs/eeprom chip: 00
file saved: C:\Program Files\InfinityBox\ChineseMiracle\MT6225_GEMINI_PCB 01_GPRS_MT6225_S00.SYGJ_6300_1_2_3_2__ffs_20091126-013236.B0E.bin
Write ...
sec info (fast) detection...
startup code area #1 check...
startup code area #1 fixed
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Write Done
Finalization ...
Finalization Done
Finished, time used: 624 sec
Old 11-26-2009, 11:46   #1373 (permalink)
BaNgErS's Avatar
Member: 553262
Thanks Meter: 297
Arrow Alcatel-KR01x, Crystal - DIRECT UNLOCK, NO CODES, NO LOGS, NO FLASHING, NO DEAD PHONE
While with others, need to buy logs, codes or even flash to unlock causing loosing all data or even dead phones
With Infinity Box DIRECT UNLOCK under 5mins
Here is Log
==== log: [11/25/2009 1:35:38 PM] ====
module v2.96
Device: Alcatel-KR01x, Crystal
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:8703:A00B
status: 01
Boot Done
====> Initialize ...
flash: 98006F00000003:08EA0000000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
====> Check firmware integrity ...
rom info structure: 2nd [enhanced] generation
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.99722 F6A.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_CA401D03].rpl
TCL-ID detection...
TCL-ID detection done
device-id: 99722F6A
rom info protocol ver: 05
ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN
ver. sw 2: MAUI.06B.W07.28.SP1.V38, 031D40CA
address offset: 00020000
ffs offset/size: 01000000/00FE0000
TCL-ID identification
version: 352
provider: KR01X-2ATWGB1
customization: CJ35DL18
customization: XJ35DL18
TCL-ID identification done
ffs address assigned: 01000000
product id: JRD_COMMUNICATION_B82X_PRODUCTS
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is invalid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, part #2) calculation...
error: security area (sec info, part #2) header is invalid
security area (sec info, part #1) calculation...
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
identification header detected
customization name adjusted
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
done
done
====> Check firmware content ...
====> Backup required data ...
original imei: 00000000000000
====> Patch required data ...
====> Special operation ...
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-KR01x,Crystal_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI _06B_W07_28_SP1_V38__system_log_99722F6A_CA401D03_ 20091125-134022.B0X.bin
Finished, time used: 259 sec
The Following User Says Thank You to BaNgErS For This Useful Post:
Old 11-26-2009, 12:27   #1374 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
ZTE SFR UNLOCK OK
COM6 [VCP0] selected
module v1.66
Device: SFR-111
Action: unlock
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
sw version: SFR-P108A2FMV1.0.0B03 04.12.00 18.26.11 08.02.00 Aug 28 2008 SFR
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\SFR-111_eeprom-static_20091126-161602.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\SFR-111_eeprom-security_20091126-161603.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\SFR-111_eeprom-complete_20091126-161609.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\SFR-111_lock-area_20091126-161622.B1E.bin
backup critical area Done
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 51 sec
The Following User Says Thank You to ehsas_ghum For This Useful Post:
Old 11-26-2009, 12:29   #1375 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
t280i unlock done
module v1.37
Device: Sony-Ericsson-T280i
"advanced chip detection" active
Action: unlock
Boot ...
Press Power button now !
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection ...
Check connection done
Set baud ...
115200
Set baud done
Check hardware ...
flash: 89890400040089:89890400000000
flash: Intel ST [def 0080x040000] 32Mb
Check hardware done
Read data ...
reading Sony-Ericsson-T280i_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\T280 UNLOCK RICKY
Read data done
Check data ...
Check data done
Write ...
The Following User Says Thank You to venuno For This Useful Post:
Old 11-26-2009, 15:07   #1376 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
Thanks Meter: 1,451
ZTE-G X760 unlock
COM4 [VCP0] selected
module v2.95
Action: unlock
Model: ZTE-X760
19200 autodetect
CPU: MT6225
chip: 0001:7D03:000E
status: FF
Date: 2006.06.14
Version: 1.0
Version: X760_Z10UK_GD_BFFA112
Version: ZTEMT25_07A_HW_C
44 byte(s) read
imei: 35235302465151
connection Ok
157 byte(s) read
reading data...
reading data #2...
writing data...
145 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 11 sec
The Following User Says Thank You to guljee786 For This Useful Post:
Old 11-27-2009, 04:51   #1377 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
Thumbs up Vk vodafone successfully unlock
WHAT IS THE BEST IS HERE THANK YOU INFINITY TEAM
COM10 selected
Device must be POWERED-ON !
Connecting, wait...
software version: VK570ZUK_NH2.02R
hardware version: VK530_01.00
Phone connected. Working...
SIM lock: deactivated
EXT lock: deactivated
Vodafone lock: deactivated
N/A-1 lock: deactivated
N/A-2 lock: deactivated
N/A-3 lock: deactivated
Smartcom lock: deactivated
Power-Off phone now by Power button (don't remove battery)
Finished
SUCCESSFULLY UNLOCK
HAPPY UNLOCKING
WITH BEST REGARDS;
LILONG LEE
The Following User Says Thank You to lilong_lee For This Useful Post:
Old 11-27-2009, 07:28   #1378 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
COM3 [VCP1] selected
module v2.93
Model: LG-KG200
19200 autodetect
Initializing [6219:8B02:8B01]...
CPU: MT6219
chip: 0031:3F15:6A92
status: FF
detected CPU: MT6226MA
Hardware: MT6219B,E02
Date: 2005.04.12
Version: 1.0
Version: 7S7330SA00-001-R1D
Version: EP1
60 byte(s) read
imei: 35282701340074
connection Ok
building list...
done
items to clear: 217
items cleared: 217 of 217
building list...
done
items remains: 0
Finished, time used: 36 sec
Old 11-27-2009, 09:32   #1379 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
module v3.00
19200 autodetect
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:6B41:ADBC
status: FF
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: DM200.V009.1.6.WIN.XM.DL
Version: RDC_HW
done
60 byte(s) read
connection Ok
building list...
done
items to clear: 169
items cleared: 169 of 169
building list...
done
items remains: 0
Finished, time used: 31 sec
Old 11-27-2009, 09:53   #1380 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 574
module v1.37
Device: Sony-Ericsson-J132
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Set baud ...
812500
Set baud done
Check hardware ...
flash: 2088C0FFFFFFFF:2088C000000000
flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb
Check hardware done
Read data ...
reading Sony-Ericsson-J132_eeprom_calibration-1...
file saved: E:\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20091127-004737.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 62 sec
The Following User Says Thank You to zeerik For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.62833 seconds with 10 queries
