11-27-2009, 09:54 | #1381 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | module v3.00 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:A803:000E status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info protocol ver: 04 ver. sw 1: A25_B_268D_F_8_PCB01_GPRS_MT6225_S00.GEMINI_1_0.BI N ver. sw 2: A25_B_268D_F_8.GEMINI.1.0, 00000000 address offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: A25_B_268D_F_8_PCB01_GPRS_MT6225_S00.GEMINI_1_0__f fs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\A25_B_268D_F_8_PC B01_GPRS_MT6225_S00.GEMINI_1_0__ffs_20091127-125411.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:18E59F00000000 Finalization Done Finished, time used: 121 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to cel_phon For This Useful Post: |
11-27-2009, 09:57 | #1382 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | Action: touchscreen calibration mode: 4 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:A803:000E status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: A25_B_268D_F_8.GEMINI.1.0 Version: VIGORTECH25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-4)... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19error: detection failed (20 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't detect eeprom structure id error: operation failed ! Finished, time used: 12 sec Remove/Install battery now ! |
11-27-2009, 10:10 | #1383 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Mirpur-1, Dhaka,Bangladesh
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | zx760 and gb102 unlock done by infinity thanks still alive but I think some special update need (and it should be paid update ) ----------------- Alam Dream Touch |
11-27-2009, 12:40 | #1384 (permalink) |
Freak Poster Join Date: Apr 2008 Age: 41
Member: 752606 Status: Offline Sonork: 100.1587361 Thanks Meter: 110 | lg f2250 unlock with infinity box COM6 [VCP1] selected module v1.39 Device: LG-F2250 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: enhanced Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 flash: Intel 128MBit-B Strata B 16Mb id: 00005272 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 356560000072010 file saved: C:\Program Files\InfinityBox\LGA\eeprom_356560000072010_LG-F2250_20091127-163703.B1E.bin .. Check flash Done Check space ... current eeprom imei: 356560000072010 Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 34 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to adreesas For This Useful Post: |
11-27-2009, 18:08 | #1385 (permalink) |
Banned Join Date: Feb 2008
Member: 715429 Status: Offline Thanks Meter: 258 | Thanks <infinity <team .FULL SUPPORT FOR NEW ALCATEL 221 & 222 Checking data, wait... advanced flash detection enabled Action: rebuild security area Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7960:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V28.F1, 00000000 address offset: 00000000 ffs offset/size: 003A0000/00058000 TCL-ID identification version: 377 provider: V221A-2AAVDO1 customization: CM37NE31 customization: XM37NE31 TCL-ID identification done ffs address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... customization: XM37NG37 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... address range is too big, should be recalculated ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 01227E221A2201:2BEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0091117-171724.B0X.bin Finished, time used: 91 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! UNLOCK OK Send FLASHES TO SUPPORT IN THE AFTERNOON |
The Following User Says Thank You to residentdenuevo For This Useful Post: |
11-28-2009, 02:27 | #1386 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Dominica, West Indies Age: 64
Member: 88701 Status: Offline Thanks Meter: 381 | New Bird S230A Unlock Report + Pinout PCB Hi..... Unlock of Bird S230A with new MM Module success ! Unlock time no longer than 10 secs. LOG : COM23 [VCP0] selected module v2.96 Action: unlock unlock method: smart fast Model: Bird-S230 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:2AC0:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: V1.00.01_M090717DOM850-V38 Version: BIRD23P_GPRS07A_HW 44 byte(s) read imei: 0 connection Ok 157 byte(s) read reading data... reading data #2... building new data... writing data... 145 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 39 sec Remove/Install battery now ! Please remove the current picture pinout for S230 (its wrong PCB)...and add this correct one. Thanks ;smokin |
The Following 2 Users Say Thank You to Orange_Dominica For This Useful Post: |
11-28-2009, 12:41 | #1387 (permalink) |
Freak Poster Join Date: Sep 2003 Location: philippines Age: 47
Member: 39561 Status: Offline Thanks Meter: 109 | OT-203X direct unlock only COM13 [VCP0] selected module v2.96 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:4793:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V28.F1, 00000000 address offset: 00000000 ffs offset/size: 003A0000/00058000 TCL-ID identification version: 37E provider: 203X-2BBBPG1 customization: CM37MQ34 customization: XM37MQ34 TCL-ID identification done ffs address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XM37MQ34 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0091128-194030.B0X.bin Finished, time used: 83 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Loading file v.05... 203X-2BRGTE5-37E_XM37CC30_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MA UI_08A_W08_36_SP1_V28_F1_2009-09-01_En_Fr_Es_It_Pt.B0M.bin loaded rom info protocol ver: 05 ver. sw 1: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V28.F1, 00000000 address offset: 00000000 ffs offset/size: 003A0000/00058000 detecting languages... Languages: En Fr Es It Hi Pt |
The Following 3 Users Say Thank You to reignsmart For This Useful Post: |
11-28-2009, 12:48 | #1388 (permalink) |
Member: 39561 Status: Offline Thanks Meter: 109 | and another 203x COM13 [VCP0] selected module v2.96 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6A44:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V28.F1, 00000000 address offset: 00000000 ffs offset/size: 003A0000/00058000 TCL-ID identification version: 37H provider: 203X-2FBBPG1 customization: CM37KB30 customization: XM37KB30 TCL-ID identification done ffs address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XM37KB30 customization name adjusted flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 2088BAFFFFFFFF:2088BA00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088BAFFFFFFFF:2088BA00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0091128-194750.B0X.bin Finished, time used: 86 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to reignsmart For This Useful Post: |
11-28-2009, 12:53 | #1389 (permalink) |
Member: 39561 Status: Offline Thanks Meter: 109 | ....and another alcatel 203x COM13 [VCP0] selected module v2.96 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5946:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V28.F1, 00000000 address offset: 00000000 ffs offset/size: 003A0000/00058000 TCL-ID identification version: 37E provider: 203X-2BBBPG1 customization: CM37MQ34 customization: XM37MQ34 TCL-ID identification done ffs address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XM37MQ34 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0091128-195541.B0X.bin Finished, time used: 80 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to reignsmart For This Useful Post: |
11-28-2009, 12:58 | #1390 (permalink) |
Member: 39561 Status: Offline Thanks Meter: 109 | another same unit, BTW all are bemobile locked. 5 more units to be unlocked. no need to flash, just click SP-unlock COM13 [VCP0] selected module v2.96 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5B73:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V28.F1, 00000000 address offset: 00000000 ffs offset/size: 003A0000/00058000 TCL-ID identification version: 37E provider: 203X-2BBBPG1 customization: CM37MQ34 customization: XM37MQ34 TCL-ID identification done ffs address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XM37MQ34 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0091128-200058.B0X.bin Finished, time used: 84 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
11-28-2009, 19:09 | #1392 (permalink) |
Registered User Join Date: Dec 2007
Member: 642071 Status: Offline Thanks Meter: 54 | Ot-660 t-mobile e100 flip unlocked succesfully Infinity Pinfinder box Cable: L10c Updated software MModule v2.96 COM7 [VCP0] selected module v2.96 Device: Alcatel-660 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:BF03:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000003:08EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.6B4FC B11.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_C368F055].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 6B4FCB11 rom info protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V38, 55F068C3 address offset: 00020000 ffs offset/size: 01000000/00FE0000 TCL-ID identification version: 331 provider: 660X-2DTBGB1 customization: CJ33DH04 customization: XJ33DH04 TCL-ID identification done ffs address assigned: 01000000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is invalid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:08EA0000000000 flash: 98006F00000003:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XJ33DH04 customization name adjusted flash: 98006F00000003:08EA0000000000 flash: 98006F00000003:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:08EA0000000000 flash: 98006F00000003:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XJ33DH04 customization name adjusted flash: 98006F00000003:08EA0000000000 flash: 98006F00000003:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:08EA0000000000 flash: 98006F00000003:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 flash: 98006F00000003:08EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000003:08EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-660_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_2 8_SP1_V38__system_log_6B4FCB11_C368F055_20091129-005746.B0X.bin Finished, time used: 319 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Thanks infinty |
The Following User Says Thank You to Dwight07 For This Useful Post: |
11-29-2009, 17:39 | #1394 (permalink) |
Major Poster Join Date: Dec 2007 Location: Colombia Barranquilla Atlántic
Member: 663355 Status: Offline Thanks Meter: 33 | unlock direct alcatel 383 COM3 [VCP0] selected modulo v2.96 Servicio: Alcatel-383A Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: rebuild security area ====> Boot ... Mantenga Presionado el boton Power ! 19200 fixed Conectando, espere... Iniciando [6223:8A05:8A00]... CPU: MT6223 chip: 0011:99FF:A00C status: 01 Tamaño del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done ====> Iniciar ... detecting chip #00 in region #00... Flash 98000300000001:2BEA0000000000 Flash Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb numero de flash chip/regiones detectadas: 01/01 Iniciar Done ====> Seleccionar velocidad ... 921600 Seleccionar velocidad Done ====> Iniciar bootcode ... Iniciar bootcode Done ====> Comprobar la integridad del firmware ... searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.E8 1640E2.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_20AF1775].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: E81640E2 rom info protocol ver: 05 ver. sw 1: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V9, 7517AF20 address offset: 00000000 ffs offset/size: 00C00000/00400000 TCL-ID identification Version: 365 provider: 383A-2BCECO3 Personalización CI36NE13 Personalización XI36NE13 TCL-ID identification done ffs address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished Estado sim-lock: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected Personalización XI36NE13 customization name adjusted Flash 98000300000001:2BEA0000000000 Flash 98000300000001:2BEA0000000000 Escribir security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... Listo Flash 98000300000001:2BEA0000000000 Flash 98000300000001:2BEA0000000000 Escribir security area (sec info, part #1) security area (sec info, part #1) calculation done Comprobar la integridad del firmware Done ====> Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done ====> Backup de datos requeridos ... Flash 98000300000001:2BEA0000000000 Backup de datos requeridos Done ====> Revisión de datos requeridos ... Revisión de datos requeridos Done ====> Operacion Especial ... Operacion Especial Done ====> Escribir ... Escribir Done ====> Finalizado ... FFS formatting... Flash 98000300000001:2BEA0000000000 Finalizado Done Archivo guardado: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-383A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V9__system_log_E81640E2_20AF1775_20091129-103116.B0X.bin Finalizado, tiempo usado: 183 sec Quite/coloque la bateria ahora ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to WENMODE29 For This Useful Post: |
11-29-2009, 18:57 | #1395 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 712887 Status: Offline Sonork: gokuu2011 Thanks Meter: 349 | repair imei s211 Code: ==== log opened: [11/29/2009 12:50:24 PM] ==== Application: H:\InfinityBox\HModule\HModule.exe Lenguaje seleccionado: Espanol [The_Dj] Cargando datos, Espere... [Infinity Box] v1.37 S/N: 36D4:0112 Espere... Servicio: Alcatel-S211 Listo ==== log: [11/29/2009 12:51:06 PM] ==== COM4 [VCP0] selected modulo v1.37 Servicio: Alcatel-S211 "Deteccion avanzada de chip" activado Action: imei repair Nuevo imei: 015219880021000 Checkeando datos, espere... Boot ... El Telefono deberia estar APAGADO ! Presiona boton POWER Ahora ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Seleccionar velocidad ... 115200 Seleccionar velocidad done Check hardware ... Flash 012A7E2A242A00:54000000000000 Flash AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... leyendo Alcatel-S211_eeprom_calibration-1... Archivo guardado: H:\InfinityBox\HModule\Alcatel-S211_eeprom_calibration-1_20091129-125216.80E.bin Read data done Check data ... Check data done Escribir ... ......... ..... Flash 012A7E2A242A00:54000000000000 Escribir imei area Escribir done Finalizado, tiempo usado: 89 sec Quite/coloque la bateria ahora ! |
The Following User Says Thank You to Gokuu2007 For This Useful Post: |
