Old 12-02-2009, 12:14   #1411 (permalink)
Cheater -Don't Deal with him-
Member: 283204
Sonork: 100.1577140
Thanks Meter: 1,098
<<<<succsessfully repair chines phone ime with infinity box>>>>
Here is log:
Action: imei
Model: Autodetect 6205-6227 NOR
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
imei-1: 359444025641587
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono CPU
new imei-1: xxxxxxxxxxxxxxx
verification Ok
Finished, time used: 2 sec
Power off phone now !
Br:
Harkishan
The Following User Says Thank You to Harkishan singh For This Useful Post:
Old 12-02-2009, 13:51   #1412 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
CLUB16 PHONE LOCK OK
software version: 1.17
cable type: 2x5 (L10B)
platform: MT: MT62xx (autodetect)
searching adapter at COM6...
adapter found, version: 2000
pins: 10, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200 fixed
CPU: MT6225
result: Rx:2 Tx:8
time required: 9 sec
Power On !
COM6 [VCP0] selected
module v3.00
Action: read codes
unlock method: read codes
19200 autodetect
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:3003:0005
status: FF
Connecting at 19200, wait...
Release Power button now !
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: BB17N_BLE_CLUB_L8EN_303_080826_LG4684_GC0306_WI75_ CTF_BT_FM
Version: 25_GEMINI_HW
detecting structure #2...
5 11 done
67 byte(s) read
imei: 35701300142670
connection Ok
detecting structure #1...
1 5 8 9 10 12 13 14 done
178 byte(s) read
166 byte(s) read
Phone lock: On
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 8200
Finished, time used: 11 sec
Remove/Install battery now !
The Following User Says Thank You to ehsas_ghum For This Useful Post:
Old 12-02-2009, 13:52   #1413 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,363
Sim-2 also working fine-
Action: imei
Connecting, wait...
imei-2: 3566100101*****
imei write channel: imei #2 for dual sim/mono CPU
new imei-2: 3539230392*****
verification Ok
Finished, time used: 3 sec
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 12-02-2009, 14:44   #1414 (permalink)
Star75's Avatar
Member: 53198
Sonork: 100.1589499
Thanks Meter: 819
Samsung C140 unlock OK
Action: unlock
Device: C140
Phone must be powered-On
Connecting...
device found: C140AKGA3
phone connected, working...
software version: C140AKGA3
hardware revision: MP 0.800
hardware id: C140
imei: 3537120105651301
working...
operaton finished Ok
Finished, time used: 28 sec
The Following User Says Thank You to Star75 For This Useful Post:
Old 12-02-2009, 16:21   #1415 (permalink)
Member: 283204
Sonork: 100.1577140
Thanks Meter: 1,098
one more repair chines ime with infinity-box
Here is log:
Action: imei
Connecting, wait...
imei-1: 135790246811220
new imei-1: 353xxxxxxxxxxxxx
verification Ok
Finished, time used: 25 sec
Br:
Harkishan
Old 12-02-2009, 19:30   #1416 (permalink)
Gokuu2007's Avatar
Member: 712887
Sonork: gokuu2011
Thanks Meter: 349
repair imei c701a
==== log: [12/1/2009 12:40:51 PM] ====
COM4 [VCP0] selected
modulo  v2.96
Servicio: Alcatel-C701X, C701A
Checkeando datos, espere...
Habilitada la deteccion avanzada del chip
Action: "repair imei"
Nuevo imei: 011073080554979
====>  Boot ...
Mantenga Presionado el boton Power !
19200 fixed
Conectando, espere...
Iniciando [6226:8A03:8A02]...
CPU: MT6226
chip: 0031:2636:A000
status: 01
Tamaño del boot packet: 0400
Deje de presionar el boton power ahora !
Boot Done
====>  Iniciar ...
Flash 01227E22302200:2BEA0000000000
Flash Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb
numero de flash chip/regiones detectadas: 01/01
Iniciar Done
====>  Seleccionar velocidad ...
921600
Seleccionar velocidad Done
====>  Iniciar bootcode ...
Iniciar bootcode Done
====>  Comprobar la integridad del firmware ...
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: H:\InfinityBox\MModule\backup_security\id.1683BC69.[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP1_V24.BIN_5725BEE3].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 1683BC69
rom info protocol ver: 05
ver. sw 1: JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP1_V24.BIN
ver. sw 2: MAUI.06A.W06.52.SP1.V24, E3BE2557
address offset: 00000000
ffs offset/size: 01200000/00E00000
TCL-ID identification
Version: 197
provider: C701A-2ACECO1
Personalización CC19NG26
Personalización XC19NG26
TCL-ID identification done
ffs address assigned: 01200000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Estado sim-lock: disabled
product id: JRD_Communication_Inc_C7_Series
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
Comprobar la integridad del firmware Done
====>  Comprobar el contenido del firmware ...
Comprobar el contenido del firmware Done
====>  Backup de datos requeridos ...
Imei original: 01107300055497
Backup de datos requeridos Done
====>  Revisión de datos requeridos ...
original data found, method-A
Revisión de datos requeridos Done
====>  Operacion Especial ...
Operacion Especial Done
====>  Escribir ...
Escribir imei
sec info (fast) detection...
security area (sec info, part #2) calculation...
identification header detected
relocation table detected
name table detected
customization detected: CC19NG26
Escribir security area (sec info, part #2)
security area (sec info, part #2) calculation done
security area (sec info, part #1) calculation...
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
Listo
Escribir security area (sec info, part #1)
security area (sec info, part #1) calculation done
Escribir Done
====>  Finalizado ...
FFS formatting...
Finalizado Done
Archivo guardado: H:\InfinityBox\MModule\backup_security\Alcatel-C701X,C701A_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP1_V24__system_log_1683BC69_5725BEE3_20091201-124510.B0X.bin
Finalizado, tiempo usado: 253 sec
Quite/coloque la bateria ahora !
The Following User Says Thank You to Gokuu2007 For This Useful Post:
Old 12-03-2009, 07:49   #1417 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,363
One more invalid 2nd IMEI in chinese phone repaired-
Action: imei
Connecting, wait...
imei-2: 13579024681****
new imei-2: 35944402249****
verification Ok
Finished, time used: 5 sec
Old 12-03-2009, 12:01   #1418 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
COM3 [VCP0] selected
module v1.71
Device: Panasonic-X60,X66,X68,X77
Action: flash write
done: 10
Boot ...
e-gold: A0
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0010:221C
Connecting Done
Check hardware ...
flash chip supported
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\Panasonic-X60,X66,X68,X77_eeprom-static_20091203-025525.07E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\Panasonic-X60,X66,X68,X77_eeprom-security_20091203-025527.07E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\Panasonic-X60,X66,X68,X77_eeprom-complete_20091203-025531.07E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
Erasing: Firmware
Writing: Firmware
Erasing: Firmware
Writing: Firmware
Write Done
Finished, time used: 379 sec
The Following User Says Thank You to cel_phon For This Useful Post:
Old 12-03-2009, 18:50   #1419 (permalink)
Member: 25025
Thanks Meter: 6
Alcatel-KR01x, Crystal DONE !
COM1 [Serial0] selected
module v2.98
Device: Alcatel-KR01x, Crystal
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:6D03:A008
status: 01
boot packet size: 0400
Boot Done
====> Initialize ...
flash: 98006F00000003:08EA0000000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader (chip) is present: 00020000
TCL-ID is present
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.DDADA 6B4.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_CA401D03].rpl
TCL-ID detection...
device-id: DDADA6B4
ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN
ver. sw 2: MAUI.06B.W07.28.SP1.V38, 031D40CA
code offset: 00020000
ffs offset/size: 01000000/00FE0000
version: 352
provider: KR01X-2ATWGB1
customization: CJ35DL18
customization: XJ35DL18
ffs/eeprom address assigned: 01000000
product id: JRD_COMMUNICATION_B82X_PRODUCTS
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is invalid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
error: security area (sec info, part #2) header is invalid
done
Write: security area (sec info, part #1)
customization name adjusted
Write: security area (sec info, part #2)
done
done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 00000000000000
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-KR01x,Crystal_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI _06B_W07_28_SP1_V38__system_log_DDADA6B4_CA401D03_ 20091203-093929.B0X.bin
Finished, time used: 738 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to steveb For This Useful Post:
Old 12-04-2009, 03:54   #1420 (permalink)
vino_89's Avatar
Member: 935830
Thanks Meter: 157
Arrow C820A ALCATEL LOGO done by infinity w/pinout
open infinity software
select model c820A ALCATEL
select com port
go to FFS CLICK CONNECT
if the phone ditect
click process
logs
COM16 [VCP1] selected
module  v2.73
Action: reset settings
Model: Alcatel-C820A
19200 autodetect
Initializing [6219:8B03:8B02]...
CPU: MT6219
chip: 0031:2D2B:A000
status: 01
detected CPU: MT6226MA
Hardware: MT6226M,E03
Date: 2005.04.12
Version: 1.0
Version: MAUI.06A.W06.28.MP.V45
Version: JRD26_06A_HW
43 byte(s) read
connection Ok
building list...
done
items total: 260
items to clear: 260
warning: wrong packet cs
items cleared: 246 of 260
building list...
done
items remains: 2
Finished, time used: 102 sec
br:
bolochie
The Following User Says Thank You to vino_89 For This Useful Post:
Old 12-04-2009, 06:52   #1421 (permalink)
adreesas's Avatar
Member: 752606
Sonork: 100.1587361
Thanks Meter: 110
alcatle ot 600x ynlock done with infinity
COM6 [VCP1] selected
module v2.98
Device: Alcatel-600
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:8D03:A000
status: 01
Boot Done
flash: 98000300000001:08EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is present
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.C0589 C1E.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_C4B7397C].rpl
TCL-ID detection...
device-id: C0589C1E
ver. sw 2: MAUI.06B.W07.28.SP1.V38, 7C39B7C4
ffs offset/size: 00C00000/00400000
version: 266
provider: 600X-2AVRGB1
customization: CJ26CW10
customization: XJ26CW10
ffs/eeprom address assigned: 00C00000
area1 is valid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
done
done
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-600_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_2 8_SP1_V38__system_log_C0589C1E_C4B7397C_20091204-104924.B0X.bin
Finished, time used: 298 sec
USMAN COMUNICATIONS CHAKSWARI
The Following User Says Thank You to adreesas For This Useful Post:
Old 12-04-2009, 07:28   #1422 (permalink)
adreesas's Avatar
Member: 752606
Sonork: 100.1587361
Thanks Meter: 110
lg gb102 unlock done with infinity box
module v1.71
Device: LG-GB102
Action: unlock
direct unlock method #2 (Airtel etc.)
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 007F:22F6
Connecting Done
Check hardware ...
sw version: .01 ULC2GL 2008-03-17 1.0 TMO_UK GB102 01 FL 44 V10a 234-30 M
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-static_20091204-112229.B1E.bin
loading data...
data loaded
imei: 35761602060279500
reading eeprom-security_35761602060279500...
file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-security_35761602060279500_20091204-112230.B1E.bin
reading eeprom-complete_35761602060279500...
file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-complete_35761602060279500_20091204-112236.B1E.bin
Check memory ...
Check memory Done
Write ...
Erasing: eeprom-security
Writing: eeprom-security
probably you need to restore original imei after unlock process
Write Done
Finished, time used: 27 sec
The Following 2 Users Say Thank You to adreesas For This Useful Post:
Old 12-04-2009, 09:39   #1423 (permalink)
mali_comm's Avatar
Member: 1145301
Thanks Meter: 116
LG GB102 unlock successfull
COM16 [VCP0] selected
module v1.68
Device: LG-GB102
Action: unlock
read unlock codes
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
230400
Set Baud Done
Connecting ...
flash: 007F:22F6
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-static_20091202-204114.B1E.bin
loading data...
data loaded
imei: 3576---------------
reading eeprom-security_35761602152357800...
file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-security_35-----_20091202-204114.B1E.bin
reading eeprom-complete_35761602152357800...
file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-complete_357--------_20091202-204118.B1E.bin
Check memory ...
loading data...
data loaded
code: 40737758
The Following User Says Thank You to mali_comm For This Useful Post:
Old 12-04-2009, 09:40   #1424 (permalink)
mali_comm's Avatar
Member: 1145301
Thanks Meter: 116
LG GB102 unlock succeessfull
module v1.68
Device: LG-GB102
Action: unlock
read unlock codes
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
230400
Set Baud Done
Connecting ...
flash: 007F:22F6
Connecting Done
Check hardware ...
Check hardware Done
loading data...
data loaded
Check memory ...
loading data...
data loaded
code: 40737758
Old 12-04-2009, 11:04   #1425 (permalink)
vineet thapar's Avatar
Member: 233618
Thanks Meter: 29
Lg gb102 unlocked successfully
hi unlocked lg gb102 with infinity box.
COM1 [VCP0] selected
module v1.71
Device: LG-GB102
Action: unlock
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .01 ULC2GL O2 GB102GO 04 FL 49 V10b 262-07 MAR-25-2009 +3 j
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-static_20091204-152949.B1E.bin
loading data...
data loaded
imei: 3539990xxxxxxxxxx
reading eeprom-security_3539990xxxxxxxxxx...
file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-security_3539990xxxxxxxxxx_20091204-152950.B1E.bin
reading eeprom-complete_3539990xxxxxxxxx...
file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-complete_3539990xxxxxxxxxx_20091204-152956.B1E.bin
Check memory ...
Check memory Done
Write ...
Write Done
Finished, time used: 21 sec
The Following User Says Thank You to vineet thapar For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.66534 seconds with 10 queries
