12-07-2011, 08:56 | #14956 (permalink) |
No Life Poster Join Date: Jan 2011 Location: in your Heart
Member: 1484062 Status: Offline Sonork: 1610135 Thanks Meter: 218 | COM52 [VCP0] selected module v1.38 Device: Sony-Ericsson-J110i "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb software version: 1030-000 software version: KIM-5- Check hardware done Read data ... reading Sony-Ericsson-J110i_eeprom_calibration-1... file saved: C:\Program Files\HModule\Sony-Ericsson-J110i_eeprom_calibration-1_20111207-124847.6AE.bin Read data done Check data ... error: not locked or unknown eeprom Check data done Write ... .........data prepared Ok flash: 89886200010001:89886200000000 Write: eeprom Write done Finished, time used: 26 sec Remove/Install battery now ! |
12-07-2011, 10:13 | #14957 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Reliance TAB ZTE V9c Unlock in 5Sec 1. Press Vol(-) button and connect USB cable 2. You will see "FTM" text at phone LCD 3. Click to "SP-Unlock button checking version... 9GB_RLNC_V9CV1.0.0B03 9GB_RLNC_V9CV1.0.0B03 ZTE V9C Ver 13 July 2011 selected... patching in progress.. done... Finished, time used: 5 sec |
The Following 5 Users Say Thank You to srinibas For This Useful Post: |
12-07-2011, 10:43 | #14958 (permalink) |
No Life Poster Join Date: Mar 2010 Location: djerba
Member: 1269161 Status: Offline Thanks Meter: 119 | succes unlock zte s213 COM6 [VCP0] selected module v4.12 Action: read unlock codes unlock method: read codes Model: ZTE-S213 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:4F03:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: FE-FR-OM9S-P109A14V1.0.0B05 Version: ZTENJ23D_09A_HW ==================== New firmware found (v.4.12, database date: 28.11.2011): FE-FR-OM9S-P109A14V1.0.0B05 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 86 byte(s) read imei: ************* connection Ok 192 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 180 byte(s) read reading data... 972 byte(s) read lock[1] code: + 864594220240 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 21 sec Remove/Install battery now ! |
12-07-2011, 11:31 | #14960 (permalink) |
No Life Poster Join Date: Mar 2006 Age: 41
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | Unlock Alcatel Ot-355 COM11 [VCP0] selected module v4.06 Device: Alcatel-355X, 355A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:BDFF:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: D:\Program Files\InfinityBox\MModule\backup_security\id.C8170 000.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_1FCF6C5F].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: C8170000 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 5F6CCF1F code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 46G provider: 355X-2CRGGB1 customization: CI46CN81 customization: XI46CN81 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XI46CN81 customization name adjusted flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35392304301233 flash: 01227E22202200:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22202200:2BEA0000000000 Finalization Done file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-355X,355A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__system_log_C8170000_1FCF6C5F_201 11207-152757.B0X.bin Finished, time used: 3 min 12 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
12-07-2011, 13:43 | #14962 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2008 Location: at work
Member: 770863 Status: Offline Sonork: 100.1597188 Thanks Meter: 123 | e51 dead mode flashing done successflly flash e51 with INFINTY BEST Here is log Core version : 1.30 Rev : 1.1 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm244_41034001_prd.c00 PPM : rm244_41034001_prd.v01 CNT : rm244_41034001.01U Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101031103 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 14F000115E368B52352D88A79006E363892B5B3C ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP ... Processing PASUBTOC ... Boot Done! TIME : Boot time : 00:00:29 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 Waiting for response: 26 Waiting for response: 25 Waiting for response: 24 Waiting for response: 23 Waiting for response: 22 Waiting for response: 21 Waiting for response: 20 Waiting for response: 19 Waiting for response: 18 ADL Server confirm flashmode! Get req info : empty ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm244_41034001_prd.c00 Found 2 areas to erase Erasing area 0x00040000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00A00000 - 0x068FFFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader Partitioning : Ok [5] TIME : Erase time : 00:00:01 Write : Processing rm244_41034001_prd.c00 Total 444 [444/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS*CORE] CMT : Writing Hash CERT [SOS+ROFS] TIME : Write time : 00:01:08 MCU Write done ===Flashing [PPM]=== Erase : Processing rm244_41034001_prd.v01 Found 1 areas to erase Erasing area 0x04A00000 - 0x068FFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm244_41034001_prd.v01 Total 169 [169/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFX] TIME : Write time : 00:00:28 PPM Write done ===Flashing [CNT]=== Erase : Processing rm244_41034001.01U Partition erase not allowed by loader TIME : Erase time : 00:00:00 Write : Processing rm244_41034001.01U Total 30 [30/0/0] blocks to write, writing... TIME : Write time : 00:00:05 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:01:42 Reboot phone now... Reading Phone Info.... Connected phone - Nokia E51 Software Info: V ICPR71_09w14.3 17-02-10 RM-244 (c) Nokia IMEI: 356903030493196 Ape Version: 410.34.001 Product code: 0552344 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done ;D Done! Elapsed: 00:02:47 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Elapsed: 00:00:10 |
The Following User Says Thank You to alhameed For This Useful Post: |
12-07-2011, 13:52 | #14963 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | ALCATEL-203X UNLOCKED module v4.12 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:7C67:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 37M provider: 203X-2BRGTE5 customization: CM37CC30 customization: XM37CC30 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM37CC30 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35247403767962 flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0111207-144933.B0X.bin Finished, time used: 2 min 0 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
12-07-2011, 15:56 | #14964 (permalink) |
Member: 1269161 Status: Offline Thanks Meter: 119 | succes unlock sfr115 COM3 [VCP0] selected module v4.12 Action: "user code" unlock method: smart fast Model: SFR-115 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:42AD:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: EFS-SFR-R9SM-P109A17V1.0.4B03 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: ****************** connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... user code set to: 0000 Finished, time used: 11 sec Remove/Install battery now ! |
12-08-2011, 08:43 | #14965 (permalink) |
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | ALCATEL-203X UNLOCKED module v4.12 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:48A9:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 37M provider: 203X-2BRGTE5 customization: CM37CC30 customization: XM37CC30 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM37CC30 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35247403524822 flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0111208-093641.B0X.bin Finished, time used: 1 min 58 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to KYEJUSA For This Useful Post: |
12-08-2011, 12:07 | #14966 (permalink) |
Member: 770863 Status: Offline Sonork: 100.1597188 Thanks Meter: 123 | Here is c3-01 flash jst in 36 seconds. Thx INFINTY BEST TEAM here logs Core version : 1.30 Rev : 1.1 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm640__06.00.mcusw PPM : rm640__06.00.ppm_a CNT : rm640__06.00.image_a_0599354_006 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 055001172ED90344BBFEA13A0E43863B77ACF6BA ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.34.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.34.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : 5AA09885C97BF3B0F6783A6337506F9394F346EF ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 357019048838766 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\357019048838766_CR T_2nd.rpl ===Flashing [MCU]=== Erase : Processing rm640__06.00.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm640__06.00.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 264 blocks TIME : Write time : 00:00:05 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing rm640__06.00.ppm_a Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm640__06.00.ppm_a Total writen 62 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing rm640__06.00.image_a_0599354_006 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm640__06.00.image_a_0599354_006 Total writen 287 blocks TIME : Write time : 00:00:06 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:00:15 Reboot phone now... Reading Phone Info.... Connected phone - Nokia C3-01 Software Info: V 06.00 28-03-11 RM-640 (c) Nokia IMEI: 357019048838766 PPM version : V 06.00 28-03-11 RM-640 (c) Nokia A Product code: 0599542 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 39 certs Data exist, skip certificate repair... AfterFlash operations done ;D Done! Elapsed: 00:00:36 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! |
The Following 2 Users Say Thank You to alhameed For This Useful Post: |
12-08-2011, 17:25 | #14967 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Moldova
Member: 614304 Status: Offline Thanks Meter: 150 | HUAWEI G6 SUCCESUFULLY UNLOCKED BY INFINITY ! COM8 [VCP0] selected module v4.10 Model: Huawei-G6 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: PTRC77B168SSC Version: VER.B 115 byte(s) read imei: 35391604036075 Finished, time used: 9 sec Remove/Install battery now ! Now click to "OK" button and press and HOLD phone "Power" button again ! interface: META_DLL_v6.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! Shutdown... done Finished, time used: 6 sec Remove/Install battery now ! |
12-09-2011, 03:13 | #14968 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Darwin Northern Teretory Age: 40
Member: 136173 Status: Offline Sonork: 108426:ind Thanks Meter: 97 | E6 DEBRANDED AND TESTED OK , WITH ALL BACKUPS LOL, ITS BEST IS BEST TOOL card found: S/N 368**:0118 registered to: zipzap_kill Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 23F00106E5D80344997A26164A59AF9A7830E90D ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.34.0 Processing RAWLOADER... FLIC : 00680020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.34.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 327C6B67C95DA04A763DEFD4BA15C19FF16D9AE7 ADL: Reading certificates... Reading NPC certificate... IMEI : 354875044864954 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! ADL: Reading certificates done! ADL: Close_Session Content: 0003000000000D0000000D00000000 ADL: Reboot NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\3548750***64954.rp l All done, Disconnecting Elapsed: 00:00:31 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Operating mode is OK, no need change... Reading PM from field 0 to 400 Field [1] 31 Record(s) Record 0: 10 byte(s) readed - Ok Record 1: 94 byte(s) readed - Ok Record 2: 110 byte(s) readed - Ok Record 4: 10 byte(s) readed - Ok Record 6: 110 byte(s) readed - Ok Record 7: 450 byte(s) readed - Ok Record 8: 10 byte(s) readed - Ok Record 13: 110 byte(s) readed - Ok Record 15: 30 byte(s) readed - Ok Record 16: 30 byte(s) readed - Ok Record 17: 30 byte(s) readed - Ok Record 18: 30 byte(s) readed - Ok Record 19: 30 byte(s) readed - Ok Record 22: 24 byte(s) readed - Ok Record 26: 10 byte(s) readed - Ok Record 27: 36 byte(s) readed - Ok Record 28: 110 byte(s) readed - Ok Record 29: 10 byte(s) readed - Ok Record 30: 36 byte(s) readed - Ok Record 31: 24 byte(s) readed - Ok Record 32: 216 byte(s) readed - Ok Record 33: 36 byte(s) readed - Ok Record 35: 24 byte(s) readed - Ok Record 36: 24 byte(s) readed - Ok Record 38: 216 byte(s) readed - Ok Record 39: 36 byte(s) readed - Ok Record 40: 24 byte(s) readed - Ok Record 41: 216 byte(s) readed - Ok Record 43: 36 byte(s) readed - Ok Record 44: 216 byte(s) readed - Ok Record 45: 216 byte(s) readed - Ok Field [2] 1 Record(s) Record 0: 2808 byte(s) readed - Ok Field [4] 7 Record(s) Record 1: 200 byte(s) readed - Ok Record 3: 10 byte(s) readed - Ok Record 4: 8 byte(s) readed - Ok Record 5: 8 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 9: 5 byte(s) readed - Ok Record 28: 2 byte(s) readed - Ok Field [6] 1 Record(s) Record 0: 96 byte(s) readed - Ok Field [8] 7 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 16 byte(s) readed - Ok Record 2: 16 byte(s) readed - Ok Record 3: 128 byte(s) readed - Ok Record 4: 128 byte(s) readed - Ok Record 8: 8 byte(s) readed - Ok Record 10: 32 byte(s) readed - Ok Field [11] 5 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Record 2: 4 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 1059 byte(s) readed - Ok Field [12] 1 Record(s) Record 0: 8 byte(s) readed - Ok Field [26] 2 Record(s) Record 0: 16 byte(s) readed - Ok Record 1: 68 byte(s) readed - Ok Field [31] 1 Record(s) Record 4: 12 byte(s) readed - Ok Field [44] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [50] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [54] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [96] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 20 byte(s) readed - Ok Field [117] 3 Record(s) Record 5: 10 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 8: 42 byte(s) readed - Ok Field [120] 4 Record(s) Record 0: 88 byte(s) readed - Ok Record 1: 160 byte(s) readed - Ok Record 2: 130 byte(s) readed - Ok Record 3: 112 byte(s) readed - Ok Field [122] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [153] 6 Record(s) Record 0: 68 byte(s) readed - Ok Record 1: 68 byte(s) readed - Ok Record 2: 68 byte(s) readed - Ok Record 3: 68 byte(s) readed - Ok Record 4: 68 byte(s) readed - Ok Record 5: 68 byte(s) readed - Ok Field [193] 4 Record(s) Record 2: 8 byte(s) readed - Ok Record 3: 32 byte(s) readed - Ok Record 4: 32 byte(s) readed - Ok Record 9: 64 byte(s) readed - Ok Field [217] 1 Record(s) Record 0: 32 byte(s) readed - Ok Field [239] 1 Record(s) Record 6: 218 byte(s) readed - Ok Field [291] 1 Record(s) Record 0: 92 byte(s) readed - Ok Field [308] 7 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 8192 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 6: 1 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Field [309] 7 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Record 2: 12 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 12 byte(s) readed - Ok Record 7: 12 byte(s) readed - Ok Record 17: 12 byte(s) readed - Ok Field [313] 1 Record(s) Record 0: 800 byte(s) readed - Ok Field [322] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [327] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [329] 1 Record(s) Record 0: 8392 byte(s) readed - Ok Field [334] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [341] 3 Record(s) Record 0: 1 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 4518 byte(s) readed - Ok Field [354] 1 Record(s) Record 0: 13 byte(s) readed - Ok Field [356] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [360] 2 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Field [369] 1 Record(s) Record 0: 40 byte(s) readed - Ok Field [382] 1 Record(s) Record 1: 4 byte(s) readed - Ok Field [388] 1 Record(s) Record 0: 4 byte(s) readed - Ok Field [395] 1 Record(s) Record 0: 16 byte(s) readed - Ok Saved as C:\InfinityBox\BEST\Backup\RM-609 Nokia E6-00_35487504****954_0_400.pm Done! Elapsed: 00:00:01 Operating mode is OK, no need change... Reading Product Profile sets... 0 - 127 1 - 0 4 - 0 7 - 1 9 - 0 34 - 0 35 - 0 56 - 0 61 - 0 65 - 0 66 - 0 69 - 1 70 - 0 71 - 1 78 - 0 79 - 1 100 - 1 130 - 5 131 - 7 135 - 0 138 - 0 139 - 1 145 - 0 146 - 0 147 - 0 156 - 0 157 - 1 158 - 1 164 - 0 165 - 0 166 - 0 168 - 0 177 - 0 183 - 0 192 - 0 202 - 3 205 - 0 206 - 0 211 - 0 212 - 0 214 - 0 217 - 0 219 - 0 220 - 0 228 - 0 SETS 1 Readed 45 element(s) Saved as C:\InfinityBox\BEST\RM-609 Nokia E6-00_35487504****954.pp Done! Elapsed: 00:00:00 Core version : 1.30 Rev : 1.1 Selected FlashSettings : Manual -> File : RM-609_025.007_U03.01_79.92.uda.fpsx not found! Check it! Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-609_025.007_79.92_prd.core.fpsx PPM : RM-609_025.007_34.01_APAC_2_QW_79.92_prd.rofs2.fpsx PPM2 : RM-609_025.007_C02.01_SEAP_79.92_prd.rofs3.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Batery valtage : 3783 mV -> Batery voltage less, than 3,8V (3783mV). Continue at user risk Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 23F00106E5D80344997A26164A59AF9A7830E90D ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.34.0 Processing RAWLOADER... FLIC : 00680020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.34.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : 327C6B67C95DA04A763DEFD4BA15C19FF16D9AE7 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 3548750*****4954 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\35487504****954_2n d.rpl ===Flashing [MCU]=== Erase : Processing RM-609_025.007_79.92_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:06 Write : Processing RM-609_025.007_79.92_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 509 blocks TIME : Write time : 00:00:18 MCU Write done ADL: Request programm status NAND status : 0000000D / 0000000D / 00000000 ===Flashing [PPM]=== Erase : Processing RM-609_025.007_34.01_APAC_2_QW_79.92_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-609_025.007_34.01_APAC_2_QW_79.92_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 127 blocks TIME : Write time : 00:00:04 PPM Write done ADL: Request programm status NAND status : 0000000D / 0000000D / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-609_025.007_C02.01_SEAP_79.92_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-609_025.007_C02.01_SEAP_79.92_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 2 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 0000000D / 0000000D / 00000000 ADL: Close_Session Content: 0003000000000D0000000D00000000 ADL: Reboot Flashing done! Total flash time : 00:00:31 Reboot phone now... Reading Phone Info.... Connected phone - Nokia E6-00 Software Info: V 92_11w37 14-09-11 RM-609 (c) Nokia IMEI: 35487504*****954 Ape Version: 025.007 Product code: 059J1V9 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! AfterFlash operations done ;D Done! Elapsed: 00:00:56 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
The Following 2 Users Say Thank You to zipzap_kill For This Useful Post: |
12-09-2011, 12:04 | #14969 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Bulgaria,Assenovgrad Age: 46
Member: 591325 Status: Offline Thanks Meter: 151 | COM6 [VCP0] selected module v3.26 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:FE14:5AE7 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: E558_ND2F8PA.01.1_26S01 Version: M500Z_05C_HW detecting structure #2... done 60 byte(s) read imei: 35456500283954 connection Ok building list... done items to clear: 213 warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs items cleared: 213 of 213 building list... done items remains: 0 Finished, time used: 41 sec Remove/Install battery now ! |
12-09-2011, 15:28 | #14970 (permalink) |
Member: 591325 Status: Offline Thanks Meter: 151 | vodafon 541 COM6 [VCP0] selected module v3.95 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:AC03:A000 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\PROGRA~1\INFINI~1\MModule\backup_security\id.18 032C89.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_BEC882F7].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 18032C89 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, F782C8BE code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 17C provider: 708X-2FVDES1 customization: CN17FE82 customization: XN17FE82 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17FE92 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17FE92 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35400703479553 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\PROGRA~1\INFINI~1\MModule\backup_security\Vodaf one-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_18032C89_BEC882F7_20111209-162728.B0X.bin Finished, time used: 6 min 9 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
