12-17-2010, 20:44 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Back after long time :-) Age: 40
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | Sucessfully revived and repaired imei of LG-GB210 Br. Vijendra Saini. |
The Following User Says Thank You to Vijendra Saini For This Useful Post: |
12-18-2010, 10:06 | #2 (permalink) |
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | Here is the report First i have select lg kp170 then i format the phone here is log COM4 [VCP0] selected module v1.39 Device: LG-KP170 (under test) Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:00EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005283 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 35 file saved: C:\Program Files\InfinityBox\LGA\eeprom_35_LG-KP170 (under test)_20101218-142713.B1E.bin ................................................. version: LG-KP210Obigo reading LG-KP210Obigo_eeprom-ffs_35... file saved: C:\Program Files\InfinityBox\LGA\LG-KP210Obigo_eeprom-ffs_35:_LG-KP170 (under test)_20101218-143217.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 373 sec Remove/Install battery now ! |
The Following 3 Users Say Thank You to Vijendra Saini For This Useful Post: |
12-18-2010, 10:33 | #3 (permalink) |
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | After that i flashed the phone with other tool because i not found the firmware of Infinity After that phone is on but imei is 00000000000000 NOW I SELECT THE MODEL GB125 THEN WRITE IMEI Here is the log Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Action: imei software version: GB210AT-00-V10e-404-XXX-MAY-07-2010+0 original imei: 00000000000000000 new imei: 35283803181511 imei verification Ok Done Finished Br. Vijendra Saini |
05-04-2011, 10:05 | #4 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 361529 Status: Offline Thanks Meter: 8 | cant flash with infinitybox promts error wrong file doe as it is described in forum but cant flash lg gb210 model selected kp170 as well gb125 but same error cant load tge flash file pls help how to retrive this or can i gt the suitable flash file for infinitybox to flsh this model |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
