Old 01-06-2009, 05:47   #1 (permalink)
aslam870's Avatar
Member: 383033
Sonork: 100.1580642
Thanks Meter: 441
Smile Sucessfully Unlocked KYOCERA E2500 with Infinity
Just today I unlocked OK an very fast a Kyocera E2500 with Infinity. I make my own cable an all run very well.
COM5 [VCP0] selected
modulo v2.58
Servicio: Kyocera-E2500
Checkeando datos, espere...
Habilitada la deteccion avanzada del chip
Accion: leer/checkear informacion detallada
Boot ...
Mantenga Presionado el boton Power !
19200 fixed
Conectando, espere...
Iniciando [6219:8B02:8B01]...
CPU: MT6219
detected CPU: MT6226MA
chip: 0031:50C1:65FA
Tamaño del boot packet: 0400
Deje de presionar el boton power ahora !
Boot Done
Iniciar ...
Flash 01227E22202200:2AEA0000000000
Flash Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
numero de flash chip/regiones detectadas: 01/01
Iniciar Done
Seleccionar velocidad ...
115200
Seleccionar velocidad Done
Iniciar bootcode ...
Iniciar bootcode Done
Comprobar la integridad del firmware ...
detect device identification#1...
fase de deteccion #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.A1 F8D3BE.[K1000_PCB01_GPRS_MT6226M_S01.K1000_VE_DT_Q_01_20.B IN_70548236].rpl
identification#1 detection finished
device-id: A1F8D3BE
identification#1 protocol ver: 04
ver. sw 1: K1000_PCB01_GPRS_MT6226M_S01.K1000_VE_DT_Q_01_20.B IN
ver. sw 2: K1000.VE.DT.Q.01.20, C97DAB8F
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
Estado sim-lock: unknown
Comprobar la integridad del firmware Done
Comprobar el contenido del firmware ...
Comprobar el contenido del firmware Done
Backup de datos requeridos ...
Archivo guardado: C:\Archivos de programa\InfinityBox\MModule\backup_security\syste m_log_A1F8D3BE_K1000_PCB01_GPRS_MT6226M_S01.K1000_ VE_DT_Q_01_20.BIN_70548236_20090105-130438.B0X.bin
Finalizado, tiempo usado: 21 sec
Quite/coloque la bateria ahora !
modulo v2.58
Action: unlock
Metodo unlock: smart fast
Modelo: Kyocera-E2500
El Telefono deberia estar APAGADO !
19200 autodetect
CPU: MT6219
Telefono detectado, espere...
Hardware: MT6226M,E02
Dato: 2005.04.12
Version: 1.0
Version: K1000.VE.DT.Q.01.20
Version: TELI26_06BJAVA_HW
44 byte(s) read
imei: 01124800301881
coneccion Ok
156 byte(s) read
Leyendo datos...
construcción de nuevos datos..
escribiendo datos...
145 byte(s) read
Leyendo datos...
verifying...
verificacion Ok
Listo
Finalizado, tiempo usado: 13 sec
Very well, Infinity Team by your support..........
The Following 2 Users Say Thank You to aslam870 For This Useful Post:
Old 01-06-2009, 10:34   #2 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works and what is
possible problems (so we will be able to fix it) and successfully done work.
Old 01-07-2009, 08:23   #3 (permalink)
aslam870's Avatar
Member: 383033
Sonork: 100.1580642
Thanks Meter: 441
Smile
This, my friend, is the best way to help you. We need to share this kind of information and then you can improve all the soft bugs. I considered this like an obbligation. Thank you by your support and your work.
Old 01-22-2009, 05:24   #4 (permalink)
Member: 220595
Thanks Meter: 355
I have a question...
I have been looking for kyocera on the shell brands list and could not find it there
I have all latest updates on every module, and I cant find this model, what module do you use for unlocking this phone ?
and what is the cablepinout ?
Old 01-22-2009, 14:25   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
Old 02-02-2009, 08:30   #6 (permalink)
aslam870's Avatar
Member: 383033
Sonork: 100.1580642
Thanks Meter: 441
Smile
This model was added very recently, December 25. I used a handfree modified cable and works 100% by me. A fiend of mine was my first victim because he has a Kyocera locked since a few months ago and donate his phone to the science because it was nothing to lose. JAJAJAJA
And Infinity like always give us a solution. And very fast. Until today I unlocked some pieces of this model perfectly.
THANKS INFINITY TEAM
The Following User Says Thank You to aslam870 For This Useful Post:
cable to unlock kyocera E2500 fclavel Infinity-Box 2 03-15-2009 05:58
how unlock kyocera e2500 welfreng Infinity-Box 7 12-29-2008 17:15
Sucessfully unlock Bird-D736 with Infinity Masud-GSM Infinity-Box 2 10-22-2008 16:07
<<<__6280 Sucessfully Unlocked Without Downgrade With Mt-box Pro Lite__>>> keaelite MT-BOX 4 10-16-2007 09:03
sucessfully unlocked E1 roker with got Javajohn GOT Motorola 0 01-26-2007 18:42
Page generated in 0.27274 seconds with 9 queries
