02-06-2009, 09:32 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Heart of Islam Age: 41
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | Sunny Ericssun k770 strange problem its problem power on and blinking i do format the phone and its ok but its screen damage and want to calibration touch screen i do all mod(1-5) for touch screen but still phone ask to touch screen calibration. how sovled this problem ==== log: [2/6/2009 1:09:53 PM] ==== COM4 [VCP0] selected module v2.76 Action: touchscreen calibration mode: 2 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:7303:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: S_R_DICOTEC_C968_KBC_V1.12 Version: C968_V1.0 detecting structure #2... 0 done 44 byte(s) read imei: 35755600007439 connection Ok detecting structure #5 (mode-2)... done 160 byte(s) read writing data... verification... verification Ok Finished, time used: 9 sec Remove/Install battery now ! ==== log: [2/6/2009 1:11:12 PM] ==== COM4 [VCP0] selected module v2.76 Action: touchscreen calibration mode: 3 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:7303:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: S_R_DICOTEC_C968_KBC_V1.12 Version: C968_V1.0 detecting structure #2... 0 done 44 byte(s) read imei: 35755600007439 connection Ok detecting structure #5 (mode-3)... 1 2 3 4 6 7 8 9error: detection failed (8 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 13 sec Remove/Install battery now ! ==== log: [2/6/2009 1:11:47 PM] ==== COM4 [VCP0] selected module v2.76 Action: touchscreen calibration mode: 4 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:7303:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: S_R_DICOTEC_C968_KBC_V1.12 Version: C968_V1.0 detecting structure #2... 0 done 44 byte(s) read imei: 35755600007439 connection Ok detecting structure #5 (mode-4)... 0 1 2 3 4 5 6 7 8 9error: detection failed (10 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 15 sec Remove/Install battery now ! ==== log: [2/6/2009 1:12:26 PM] ==== COM4 [VCP0] selected module v2.76 Action: touchscreen calibration mode: 5 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:7303:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: S_R_DICOTEC_C968_KBC_V1.12 Version: C968_V1.0 detecting structure #2... 0 done 44 byte(s) read imei: 35755600007439 connection Ok detecting structure #5 (mode-5)... 0 1 2 3 4 5 6 7 8 9error: detection failed (10 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 7 sec Remove/Install battery now ! ==== log: [2/6/2009 1:15:57 PM] ==== COM4 [VCP0] selected module v2.76 Action: touchscreen calibration mode: 1 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:7303:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: S_R_DICOTEC_C968_KBC_V1.12 Version: C968_V1.0 detecting structure #2... 0 done 44 byte(s) read imei: 35755600007439 connection Ok detecting structure #5 (mode-1)... 0 1 2 3 5 6 7warning: wrong packet cs 8error: detection failed (8 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 10 sec Remove/Install battery now ! ==== log: [2/6/2009 1:16:58 PM] ==== COM4 [VCP0] selected module v2.76 Action: touchscreen calibration mode: 2 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:7303:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: S_R_DICOTEC_C968_KBC_V1.12 Version: C968_V1.0 detecting structure #2... 0 done 44 byte(s) read imei: 35755600007439 connection Ok detecting structure #5 (mode-2)... done 160 byte(s) read writing data... verification... verification Ok Finished, time used: 25 sec Remove/Install battery now ! ==== log opened: [2/6/2009 1:26:46 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.76 S/N: 5E76:0112 Wait... Device: Autodetect 6205-6227 NOR Done Guljee |
02-06-2009, 12:08 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please make "read full flash" and send it to [email protected] write subect "touchscreen calibration failed" in mail body write posted above Logs we wil process this file and next Chinese Miracle update will solve your problem. i think we will release it on monday-tuesday |
I8510 strang problem | naslejavan | QUALCOMM Models (3G) | 4 | 03-30-2010 09:32 |
n95 (rm-159) strang problem | Tayyab_raja777 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 14:45 |
K770 strange problem | bossa91 | Sony Ericsson Hardware Repair | 5 | 08-22-2009 14:42 |
k770 strange problem | jabed_net | Sony Ericsson Hardware Repair | 3 | 08-11-2009 09:53 |
Please Help Me about strange problem K770 CID 53 | brwa | Cruiser Suite | 15 | 12-01-2008 16:30 |
