01-15-2021, 20:49 | #257 (permalink) |
Junior Member Join Date: Jul 2016
Member: 2603890 Status: Offline Thanks Meter: 0 | infinity best dongle please help can't get this to work I have tried with different versions on cm2mt2. Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! |
01-15-2021, 21:37 | #258 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Try to selecta another DA Also try to use CM2MT2 v2.xx Result ? | |
01-16-2021, 08:50 | #259 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Which brand/model is this? Br. Infinity-Box Team. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
01-19-2021, 21:02 | #260 (permalink) |
Freak Poster Join Date: Dec 2005 Location: Lagos Nigeria
Member: 215142 Status: Offline Thanks Meter: 3 | Infinity box dongle error Good day, how do I go about rectifying my smart card error in my infinity box . While I was updating my infinity box, the connecting cable to the box shook and showed this error below. === DongleManager [Infinity] v1.81 [1/19/2021 20:48:10] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0001679CFF021982 === Process started: 1/19/2021 20:48:11 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to https://www.infinity-box.com/support/?r=2 |
01-19-2021, 23:21 | #261 (permalink) | |
Update it once again now. Result ? | |
01-25-2021, 23:19 | #262 (permalink) |
Junior Member Join Date: Dec 2019 Location: مصر
Member: 2940652 Status: Offline Thanks Meter: 0 | === DongleManager [Infinity] v1.81 [26/01/2021 00:15:37] === Searching... Card-Reader: Generic EMV Smartcard Reader 1 HWID: 0000038B21344082 Box/Dongle found: Infinity-Box/Dongle [CM2] Serial No (S/N): FD5F038B Firmware version: 0146.02 "UK Edition" status: On Last launched Application: 0033 v.0146 => Activations: - 00: Infinity-Box/Dongle [CM2] v0146 => Options: - Infinity-Box/Dongle [CM2] |
01-25-2021, 23:21 | #263 (permalink) | |
Probably your dongle support period is expired. How to check - https://www.infinity-box.com/doc/?r=17 If support is expired please contact to your seller and renew support for 1 or 2 years - https://www.infinity-box.com/buy/ | |
02-28-2021, 19:27 | #267 (permalink) | |
Reset forgotten password here - https://www.infinity-box.com/support/?r=16 | |
04-24-2021, 13:30 | #268 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | always getting this error - How to get Username and Password - How to Sign In Sign In required to download MT6580_AllCall_AllCall_RIO_AllCall_RIO_7.0_alps-mp-n0.mp2-V1_vz6580.weg.i.n_P99.7z Continue but i already login |
04-24-2021, 13:59 | #269 (permalink) | |
Please try once again now, it should be Ok. | |
