Old 10-03-2017, 12:23   #136 (permalink)
Member: 1043909
Thanks Meter: 56,552
Originally Posted by lktweneboah View Post
please support & download area is working . boss check
it works. do you have any problem ?
Old 10-03-2017, 12:43   #137 (permalink)
Member: 1115532
Thanks Meter: 4
boss i mean support & download area is not working check it
Old 10-03-2017, 12:47   #138 (permalink)
Member: 1043909
it works. do you have any problem with support & download area ?
Old 10-03-2017, 12:48   #139 (permalink)
Member: 1115532
Thanks Meter: 4
if i click on support & download area it open this
- Click to menu "Support & Downloads" and once again to "Support & Downloads"
- Click to link with Support Area that you want to access
NOTE: Different Support Area links will be available depends on your active Services
Infinity-Box Shell is not required any more for Support Area login !
How to access Support Area:
1. Login to your IOS Account
Old 10-03-2017, 12:54   #140 (permalink)
Member: 1043909
Just follow the instruction and login to support area.
result ?
Old 10-12-2017, 11:40   #141 (permalink)
Member: 1521049
Thanks Meter: 3
Originally Posted by princesaddam View Post
After login iam Getting account is not active iam having Support
Activation 1: Infinity-Box/Dongle; ; Firmware Version: 0135; Registered: 2015-06-05; Expired: 2018-10-21; Support: Active
Still this error
Click on Continue. You will be taken to support area.
Old 10-13-2017, 07:02   #142 (permalink)
Member: 148515
Thanks Meter: 17,748
Try once again now.
result ?
Old 10-24-2017, 11:36   #143 (permalink)
Member: 2684593
Sonork: 100.650600
Infinity best code
Hi
need help
nokia 225
Unlock procedure started...
Using F-bus count...
Sending code 051050060249442 Level : 7 to SimLock Server...
Simlock Server Answer: Error
Done!
tried code manually
code error
Thanks!
Old 10-24-2017, 21:47   #144 (permalink)
Member: 1043909
Originally Posted by corvo mega View Post
Hi
need help
nokia 225
Done!
tried code manually
code error
Thanks!
answered in other thread already
Old 10-28-2017, 05:51   #145 (permalink)
Member: 2675958
even me same problem
Old 10-28-2017, 10:53   #146 (permalink)
Member: 1043909
Hello,
What is the problem ?
please explain
Old 12-12-2017, 10:30   #147 (permalink)
Member: 1115532
Thanks Meter: 4
i boss can infinity box unlock alcatel ot-1016g spd
Old 12-12-2017, 11:01   #148 (permalink)
Member: 1115532
Thanks Meter: 4
alcatel spd phones is not supported yet infinity box
Old 12-14-2017, 01:09   #149 (permalink)
Member: 1043909
Do you have any problem with support area access ?
Old 12-20-2017, 07:16   #150 (permalink)
Member: 1807959
Thanks Meter: 17
Card found : 8CAD13A1 , v0136
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14
Operation : Identify [ v1.14 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 425 [MSM8917]
ID_BLOCK_S : E81BC01B
ID_BLOCK_I : 000560E1
ID_BLOCK_L : 04D3F81B8609C68410D890629EBD3142
ID_BLOCK_L : F4B933C63EC4F3543D8A4E1FA85C512B
Use CM2 Internal Loader
Error : Prepare target failed! Unsupported SecureType!
Send log and report.log to support! Include device info also!
Reconnect Power/Cable!
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.21820 seconds with 8 queries
