11-15-2010, 21:17 | #1 (permalink) |
Major Poster Join Date: Oct 2010
Member: 1408084 Status: Offline Thanks Meter: 11 | to Support !! lanix x10 Flash read OK !!! here i have a Lanix X10 From Telcel mexico... I make everything... All unlock methods, Format Full FS, etc etc,,, and the phone still blocked... (Sin not VALID) .. I conect Ok with Pinfinder and Cable L10 Rx: 4 and Tx : 5 or viceverse... I read the full flash and the FS and send to you with this rapidshare LINK for support.. thanks advanced http://rapidshare.com/files/431027249/Lanix_X10.rar Here i put LOg Below too : ==== C:\Archivos de programa\InfinityBox\ChineseMiracle\ChineseMiracle .exe [11/11/2010 15:44:03] ==== web site: Infinity-Box - About support forum in English: Infinity-Box - GSM-Forum Lenguaje seleccionado: Espanol [The_Dj] Cargando datos, Espere... [Infinity Box] Chinese Miracle v3.21 ==== [11/11/2010 15:45:56] ==== COM8 [VCP0] selected modulo v3.21 Action: read unlock codes Metodo unlock: read codes Modelo: Autodetect 6205-6239 NOR Checkeando datos, espere... El Telefono deberia estar APAGADO ! Mantenga Presionado el boton Power ! 19200 autodetect Iniciando [6225:8A05:8A00]... CPU: MT6225 alta velocidad de boot On chip: 0001:CE03:0004 status: FF Connecting at 19200, wait... Peligro: wrong packet cs Peligro: wrong packet cs Peligro: wrong packet cs Peligro: wrong packet cs error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: La operaciَn fallَ ! Finalizado, tiempo usado: 19 sec Quite/coloque la bateria ahora ! ==== [11/11/2010 15:46:26] ==== COM8 [VCP0] selected modulo v3.21 Servicio: Autodetect 6205-6239 NOR Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: "sp-unlock" Metodo unlock: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Mantenga Presionado el boton Power ! 19200 fixed Conectando, espere... Iniciando [6225:8A05:8A00]... CPU: MT6225 alta velocidad de boot On chip: 0001:CE03:0004 status: FF Tamaٌo del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done ====> Iniciar ... detecting chip #00 in region #00... Flash 01227E223C2200:0AEA0000000000 Flash Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... Flash 01227E223C2200:0AEA0000000000 Flash Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 numero de flash chip/regiones detectadas: 02/01 Iniciar Done ====> Seleccionar velocidad ... 921600 Seleccionar velocidad Done ====> Iniciar bootcode ... Iniciar bootcode Done ====> Comprobar la integridad del firmware ... device parameters detection in progress... detecting chip #00 in region #00... Flash 01227E223C2200:0AEA0000000000 Flash Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... Flash 01227E223C2200:0AEA0000000000 Flash Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 it's time to stop: 0A0000EAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEA numero de flash chip/regiones detectadas: 01/01 Tamaٌo total de la region flasheada: 02000000 usb bootloader detect... usb bootloader (chip) is present: 00010000 searching rom info... search rom info finished rom info structure: 2nd [standard] type TCL-ID is absent rom info detection finished rom info ver: 05 sw version: X10_PCB01_GPRS_MT6225_S00.PR_R1_0_V030_TELCEL.BIN project-id: X10.PR.R1.0.V030_TELCEL, 00000000 code offset: 00010000 ffs offset/size [01]: 01C00000/003F0000 rom info structure: 2nd [standard] type TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01C00000 standard ffs/eeprom offset confirmed: 01C00000 detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01C00000-01FFFFFF firmware area: 00000000-01BFFFFF detectando startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent detecting ffs/eeprom structure pass 1... ....................................... ffs/eeprom: detect std location pass #1... .................................................. .................................................. ............ ffs/eeprom: detect ext location pass #1... .................................................. ............ ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Comprobar la integridad del firmware Done ====> Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done ====> Backup de datos requeridos ... leyendo X10_PCB01_GPRS_MT6225_S00.PR_R1_0_V030_TELCEL__ffs ... Archivo guardado: C:\Archivos de programa\InfinityBox\ChineseMiracle\X10_PCB01_GPRS _MT6225_S00.PR_R1_0_V030_TELCEL__ffs_20101111-155131.B0E.bin Flash 01227E223C2200:0AEA0000000000 Backup de datos requeridos Done ====> Revisiَn de datos requeridos ... detection procedure, wait... detection procedure completed Revisiَn de datos requeridos Done ====> Operacion Especial ... Operacion Especial Done ====> Escribir ... Flash 01227E223C2200:0AEA0000000000 Escribir ffs Escribir Done ====> Finalizado ... Finalizado Done Finalizado, tiempo usado: 6 min 26 sec Quite/coloque la bateria ahora ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [11/11/2010 15:56:07] ==== COM8 [VCP0] selected modulo v3.21 Servicio: Autodetect 6205-6239 NOR Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Mantenga Presionado el boton Power ! 19200 fixed Conectando, espere... Iniciando [6225:8A05:8A00]... CPU: MT6225 alta velocidad de boot On chip: 0001:CE03:0004 status: FF Tamaٌo del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done ====> Iniciar ... detecting chip #00 in region #00... Flash 01227E223C2200:0AEA0000000000 Flash Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... Flash 01227E223C2200:0AEA0000000000 Flash Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 numero de flash chip/regiones detectadas: 02/01 Iniciar Done ====> Seleccionar velocidad ... 921600 Seleccionar velocidad Done ====> Iniciar bootcode ... Iniciar bootcode Done ====> Comprobar la integridad del firmware ... device parameters detection in progress... detecting chip #00 in region #00... Flash 01227E223C2200:0AEA0000000000 Flash Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... Flash 01227E223C2200:0AEA0000000000 Flash Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 it's time to stop: 0A0000EAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEA numero de flash chip/regiones detectadas: 01/01 Tamaٌo total de la region flasheada: 02000000 usb bootloader detect... usb bootloader (chip) is present: 00010000 searching rom info... search rom info finished rom info structure: 2nd [standard] type TCL-ID is absent rom info detection finished rom info ver: 05 sw version: X10_PCB01_GPRS_MT6225_S00.PR_R1_0_V030_TELCEL.BIN project-id: X10.PR.R1.0.V030_TELCEL, 00000000 code offset: 00010000 ffs offset/size [01]: 01C00000/003F0000 rom info structure: 2nd [standard] type TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01C00000 standard ffs/eeprom offset confirmed: 01C00000 detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01C00000-01FFFFFF firmware area: 00000000-01BFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Comprobar la integridad del firmware Done ====> Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done ====> Backup de datos requeridos ... leyendo X10_PCB01_GPRS_MT6225_S00.PR_R1_0_V030_TELCEL__ffs ... Archivo guardado: C:\Archivos de programa\InfinityBox\ChineseMiracle\X10_PCB01_GPRS _MT6225_S00.PR_R1_0_V030_TELCEL__ffs_20101111-155915.B0E.bin Flash 01227E223C2200:0AEA0000000000 Backup de datos requeridos Done ====> Revisiَn de datos requeridos ... Revisiَn de datos requeridos Done ====> Operacion Especial ... Operacion Especial Done ====> Escribir ... Escribir Done ====> Finalizado ... FFS formatting... Flash 01227E223C2200:0AEA0000000000 Finalizado Done Finalizado, tiempo usado: 5 min 57 sec Quite/coloque la bateria ahora ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ==== [11/11/2010 16:03:17] ==== COM8 [VCP0] selected modulo v3.21 Servicio: Autodetect 6205-6239 NOR Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: "sp-unlock" Metodo unlock: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Mantenga Presionado el boton Power ! 19200 fixed Conectando, espere... Iniciando [6225:8A05:8A00]... CPU: MT6225 alta velocidad de boot On chip: 0001:CE03:0004 status: FF Tamaٌo del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done ====> Iniciar ... detecting chip #00 in region #00... Flash 01227E223C2200:0AEA0000000000 Flash Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... Flash 01227E223C2200:0AEA0000000000 Flash Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 numero de flash chip/regiones detectadas: 02/01 Iniciar Done ====> Seleccionar velocidad ... 921600 Seleccionar velocidad Done ====> Iniciar bootcode ... Iniciar bootcode Done ====> Comprobar la integridad del firmware ... device parameters detection in progress... detecting chip #00 in region #00... Flash 01227E223C2200:0AEA0000000000 Flash Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... Flash 01227E223C2200:0AEA0000000000 Flash Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 it's time to stop: 0A0000EAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEA numero de flash chip/regiones detectadas: 01/01 Tamaٌo total de la region flasheada: 02000000 usb bootloader detect... usb bootloader (chip) is present: 00010000 searching rom info... search rom info finished rom info structure: 2nd [standard] type TCL-ID is absent rom info detection finished rom info ver: 05 sw version: X10_PCB01_GPRS_MT6225_S00.PR_R1_0_V030_TELCEL.BIN project-id: X10.PR.R1.0.V030_TELCEL, 00000000 code offset: 00010000 ffs offset/size [01]: 01C00000/003F0000 rom info structure: 2nd [standard] type TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01C00000 standard ffs/eeprom offset confirmed: 01C00000 detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01C00000-01FFFFFF firmware area: 00000000-01BFFFFF detectando startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent detecting ffs/eeprom structure pass 1... ....................................... ffs/eeprom: detect std location pass #1... .................................................. .................................................. ............ ffs/eeprom: detect ext location pass #1... .................................................. ............ ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Comprobar la integridad del firmware Done ====> Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done ====> Backup de datos requeridos ... leyendo X10_PCB01_GPRS_MT6225_S00.PR_R1_0_V030_TELCEL__ffs ... Archivo guardado: C:\Archivos de programa\InfinityBox\ChineseMiracle\X10_PCB01_GPRS _MT6225_S00.PR_R1_0_V030_TELCEL__ffs_20101111-160813.B0E.bin Flash 01227E223C2200:0AEA0000000000 Backup de datos requeridos Done ====> Revisiَn de datos requeridos ... detection procedure, wait... detection procedure completed Revisiَn de datos requeridos Done ====> Operacion Especial ... Operacion Especial Done ====> Escribir ... Flash 01227E223C2200:0AEA0000000000 Escribir ffs Escribir Done ====> Finalizado ... Finalizado Done Finalizado, tiempo usado: 8 min 29 sec Quite/coloque la bateria ahora ! ==== [11/11/2010 16:12:58] ==== COM8 [VCP0] selected modulo v3.21 Servicio: Autodetect 6205-6239 NOR Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: read flash ====> Boot ... Mantenga Presionado el boton Power ! 19200 fixed Conectando, espere... Iniciando [6225:8A05:8A00]... CPU: MT6225 alta velocidad de boot On chip: 0001:CE03:0004 status: FF Tamaٌo del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done ====> Iniciar ... detecting chip #00 in region #00... Flash 01227E223C2200:0AEA0000000000 Flash Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... Flash 01227E223C2200:0AEA0000000000 Flash Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 numero de flash chip/regiones detectadas: 02/01 Iniciar Done ====> Seleccionar velocidad ... 921600 Seleccionar velocidad Done ====> Iniciar bootcode ... Iniciar bootcode Done ====> Comprobar la integridad del firmware ... device parameters detection in progress... detecting chip #00 in region #00... Flash 01227E223C2200:0AEA0000000000 Flash Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... Flash 01227E223C2200:0AEA0000000000 Flash Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 it's time to stop: 0A0000EAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEA numero de flash chip/regiones detectadas: 01/01 Tamaٌo total de la region flasheada: 02000000 usb bootloader detect... usb bootloader (chip) is present: 00010000 searching rom info... search rom info finished rom info structure: 2nd [standard] type TCL-ID is absent rom info detection finished rom info ver: 05 sw version: X10_PCB01_GPRS_MT6225_S00.PR_R1_0_V030_TELCEL.BIN project-id: X10.PR.R1.0.V030_TELCEL, 00000000 code offset: 00010000 ffs offset/size [01]: 01C00000/003F0000 rom info structure: 2nd [standard] type TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01C00000 standard ffs/eeprom offset confirmed: 01C00000 detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01C00000-01FFFFFF firmware area: 00000000-01BFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Comprobar la integridad del firmware Done ====> Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done ====> Backup de datos requeridos ... leyendo X10_PCB01_GPRS_MT6225_S00.PR_R1_0_V030_TELCEL__ful lflash... Archivo guardado: C:\Archivos de programa\InfinityBox\ChineseMiracle\X10_PCB01_GPRS _MT6225_S00.PR_R1_0_V030_TELCEL__fullflash_2010111 1-163501.B0M.bin Finalizado, tiempo usado: 37 min 5 sec Quite/coloque la bateria ahora ! |
The Following 3 Users Say Thank You to movilserver For This Useful Post: |
02-03-2011, 00:31 | #4 (permalink) | |
Cable: L10C 4: box Rx/phone Tx/PinFinder Rx (RJ45 pin-3) 5: box Tx/phone Rx/PinFinder Tx (RJ45 pin-2) | |
02-04-2011, 02:44 | #5 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1335946 Status: Offline Thanks Meter: 0 | Tell InfinitySupport, do I use adaptor PADO22/L10C/E107? And do I use the GF-AM624 Infinity Combo main Cable? Do I use the batery or pinzer black and red? Sorry, but I'm new with my Infinity Box. |
10-04-2011, 01:38 | #6 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Lima - Peru
Member: 1168095 Status: Offline Sonork: 100.1602891 Thanks Meter: 13 | [QUOTE=InfinitySupport;6908415]Cable name: Lanix-X10 X10_PCB01_GPRS_MT6225_S00.PR_R1_0_V030_TELCEL__ful lflash_20110930-114812.B0M.rar - 4shared.com - online file sharing and storage - download please send me the beta software I have the team Please standby .. thanks infinity team Lanix box full flash attachment - x10 telcel Sonork contact me nickname: tonygsm thanks |
11-29-2011, 18:45 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Lanix-LX10 unlock solution released: Infinity-Box Technical Support • View topic - Lanix-LX10 unlock solution released |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
