12-19-2007, 00:58 | #1 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Leon
Member: 8804 Status: Offline Thanks Meter: 4 | to support :problem with dongle ? I just got infinity from one of your resellers and it registered fine , i can access support and everything, but the RX-TX lights are always on weather i have a cable connected or not.... even when i try to connect a cable to a phone that is working, i cannot get any info from it. although i am using the right cable. Is there a way to find out if this dongle has a hardware problem ? I have not contacted the reseller yet regarding this issue, should I send it back to them to check it out or is there a way to find out what is wrong and fix it myself, i looked at another dongle that is working and the lights are not on like mine. Thanks. |
12-19-2007, 01:43 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, check this thread first: http:///vbb/showthread.php?t=342807 You will see box photos and some info about settings. Also, regarding installation: As I can understand smart-card drivers installed and works fine (in other case you cant access support area). So the problam may be only with cables/unibox. Do you see new COM port device in DeviceManager when you connect box to PC ? Do you see any new USB device when you connect box to PC (like FTxxxx usb device) ? Possible problem reason: it may be that your unibox configured in other way than need. If so we can reporgram unibox, no need to return it to reseller, and everything will works fine. After you will answer to my previous 2 questions we will see what to do next. |
12-19-2007, 11:39 | #3 (permalink) |
Junior Member Join Date: Dec 2006
Member: 421376 Status: Offline Thanks Meter: 0 | i also have the similar problem. I tired to unlock Moto c115 with the box. Phone was first opened & track cutted acording to documantation. "Repair mode & Soft restore Cutted Track" were selected. The Phone was then Flashed with "c115_1.0.10 main_Arabic.18m". "write" was commanded. The following were the results: "com 1 selected" "repair mode" active "smart write" active "softrestore" active Action: flash Write: flex write: language pack Write: Eeprom Err: no data language pack..Failed Finished, Time....... When "sp unlock" was commanded it gave the following: "com 1 selected" "repair mode" active Action: unlock Device: Moto c115.. Checking data, wait...... Connecting..... Press & hold Power...>>> I hold the Power botton but there is no action. Infinity Team, Please help me to solve the Problem. |
12-19-2007, 18:46 | #5 (permalink) |
Member: 8804 Status: Offline Thanks Meter: 4 | Box is different the drivers are installed just fine, a new com port 5 is added when i plug the dongle in. The infinity box i have looks nothing like the ones in those pictures, i have a slim black colored box with the sim reader on the side, i am attaching a picture here for reference. I was able to get the program working via another com port, as long as the dongle is plugged in, the program runs and gives me options to use other com ports, so I did and was able to connect to a phone using the correct pinouts. so what should I do now. Thanks |
12-19-2007, 20:42 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! sometimes is needed to change Latency value in com port settings to get better connection with motorola phones. for sure cable for motorola must be modified (cut rubber around pins) picture how connector should look like is here: C:\Program Files\InfinityBox\pinout\Panasonic-G50_modified1.jpg also, if truck is cutted- you must set "repair mode" in settings Tab and if all is done but no connection- last thing to try is standalone rs232 cable |
12-20-2007, 08:55 | #7 (permalink) | |
Member: 8804 Status: Offline Thanks Meter: 4 | Quote:
Thank you. | |
12-20-2007, 09:23 | #8 (permalink) | |
Also you must check what is pinout of your unibox, probably cables that you have not suitable for your unibox pinout. As I can see you was registered in 2002 so I hope you have enough skills and you understand what I talk about. If you still have problems with cables/unibox you need to contact to your reseller and ask him to replace your cables or unibox. | |
TO SUPPORTER Problem with reading Card Serial Number | .:iTRi:. | Cyclonebox | 2 | 07-13-2009 00:07 |
unable to log in to support even with pink dongle | dumbmf | Twisterflasher | 1 | 07-02-2006 05:00 |
unable to log in to support even with pink dongle | dumbmf | Twisterflasher | 5 | 06-12-2006 12:21 |
can't login to support area with my name and password | maxking | ThunderStorm Box | 3 | 11-23-2005 18:03 |
How to support for Crazzy Dongle ? | gsavv723 | NEC | 1 | 05-03-2005 16:56 |
