01-26-2016, 10:20 | #1 (permalink) |
No Life Poster Join Date: Apr 2014 Location: B A N G L A D E S H
Member: 2171294 Status: Offline Sonork: 100.1659207(No More Use) Thanks Meter: 706 | symphony w71i MT6572 Preloader init Problem Read Info- Code: Start at : [25-01-16 / 20.08.54] Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447393010DED99185111B DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 DRAM Init Ok , 0x20000000 DA Sent. Configure setting now ... Code: User selected Preloader file : preloader_up06_w71i.bin Start at : [25-01-16 / 20.11.40] Operation : Init Preloader [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447393010DED99185111B DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 DRAM Init Ok , 0x20000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0000 , OEM : 0000 [eMMC] : FLASH_INF : [eMMC] : FLASH_CID : 00000000000000000000000000000000 [eMMC] : FLASH_EXT : 00000000/00000000 [eMMC] : FLASH_LEN : 0x0000000000000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SecCfg Passed , 1799 BL : BBID supported by BootLoader! Flash Info : FlashID [0] CID : 90014A2058494E5948 , Name : XINYH , Vendor : 90 , [HYNIX] FlashID [1] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] FlashID [2] CID : 110100303034473930 , Name : 004G90 , Vendor : 11 , [TOSHIBA] FlashID [3] CID : 7001004D4D43303447 , Name : MMC04G , Vendor : 70 , [KINGSTON] FlashID [4] CID : 110100303034473930 , Name : 004G90 , Vendor : 11 , [TOSHIBA] FlashID [5] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] STORAGE : BL NOT support this eMMC! Select Correct One! Done! Elapsed: 00.00.22 Reconnect Power/Cable! Code: User selected Preloader file : preloader_up06_w71i.bin Start at : [25-01-16 / 20.20.32] Operation : Init Preloader [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447393010DED99185111B DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 DRAM Init Ok , 0x20000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0000 , OEM : 0000 [eMMC] : FLASH_INF : [eMMC] : FLASH_CID : 00000000000000000000000000000000 [eMMC] : FLASH_EXT : 00000000/00000000 [eMMC] : FLASH_LEN : 0x0000000000000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SecCfg Passed , 1799 BL : BBID supported by BootLoader! Flash Info : FlashID [0] CID : 90014A2058494E5948 , Name : XINYH , Vendor : 90 , [HYNIX] FlashID [1] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] FlashID [2] CID : 110100303034473930 , Name : 004G90 , Vendor : 11 , [TOSHIBA] FlashID [3] CID : 7001004D4D43303447 , Name : MMC04G , Vendor : 70 , [KINGSTON] FlashID [4] CID : 110100303034473930 , Name : 004G90 , Vendor : 11 , [TOSHIBA] FlashID [5] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] STORAGE : BL NOT support this eMMC! Select Correct One! Done! Elapsed: 00.00.23 Reconnect Power/Cable! |
01-26-2016, 10:47 | #2 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | maybe preloader not matched Code: STORAGE : BL NOT support this eMMC! Select Correct One! Code: Brand : Symphony ProdName : SYMPHONY_W71i ProdModel : Symphony Xplorer W71i Device : SYMPHONY_W71i AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 |
