05-13-2009, 12:49 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Madrid, ES. Age: 41
Member: 51153 Status: Offline Sonork: 100.113241 Thanks Meter: 3,682 | LG-KG300 i cant Format module v2.74 Device: LG-KG300 Checking data, wait... Action: NAND reset read mode: 01 Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6227:8A02:8A01]... CPU: MT6227 chip: 0031:7407:07A1 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 08 loader: 3.0840.00.00 NAND: Toshiba TC58DVM92A1FT 512+16 32 pages, 66Mb NAND id: 9876A5C0 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 external ram: 00800000 finalize connection... done ram test... pass 1... pass 2... pass 3... pass 4... done NOR: 0098:004900000000 [01000000] NAND: 0098:007600A500C0 [04200000] Initialize Done Set baud ... 115200 Set baud Done Identification ... detect device identification#1... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished error: can't detect ffs/eeprom address Identification Fail Finished, time used: 51 sec Remove/Install battery now ! |
05-13-2009, 13:41 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | ok if u facing LG LOGO problem then slect chines miricle slect 62xx based cpu slect 6228 nand flash then format FULL FLASH CHIP 10000% TESTED SOLUTION |
05-13-2009, 14:35 | #3 (permalink) |
Member: 51153 Status: Offline Sonork: 100.113241 Thanks Meter: 3,682 | now is dead COM14 [VCP0] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: erase flash chip eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6227:8A02:8A01]... CPU: MT6227 high speed boot On chip: 0031:7407:07A1 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7312SA00-001.BIN ver. sw 2: 7S7312SA00-001, 00000000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: 98004900000001:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7312SA00-001.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7312SA00-001.BIN]_20090513-062932.B0E.bin flash: 98004900000001:29EA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98004900000001:29EA0000000000 Erase: chip 1 of 1 Finalization Done Finished, time used: 449 sec Remove/Install battery now ! |
05-14-2009, 13:22 | #6 (permalink) |
No Life Poster Join Date: Oct 2005 Location: P A K I S T A N Age: 16
Member: 190344 Status: Offline Thanks Meter: 280 | i can only see ur eeprom saved. reading: eeprom[ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7312SA00-001.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7312SA00-001.BIN]_20090513-062932.B0E.bin just write it back. if set not powering on after flash, down load the requird files from support and flash it agian. |
05-15-2009, 13:01 | #8 (permalink) |
Member: 51153 Status: Offline Sonork: 100.113241 Thanks Meter: 3,682 | i flash with files from support area now is power on but when i make Format FFS complete mode again the phone is dead COM14 [VCP0] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6227:8A02:8A01]... CPU: MT6227 high speed boot On chip: 0031:7407:07A1 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000001:29EA0000000000 error: no any expected answer : wrong answer after chip cfi request flash: 98004900000001:29EA0000000000 flash: Toshiba TV00578002DABD T 8Mb detecting chip #02 in region #00... flash: 98004900000001:ECF0CF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 03/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7312SA00-001-R1C.BIN ver. sw 2: 7S7312SA00-001-R1C, 00000000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: 98004900000001:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7312SA00-001-R1C.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7312SA00-001-R1C.BIN]_20090515-045720.B0E.bin flash: 98004900000001:29EA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98004900000001:29EA0000000000 Finalization Done Finished, time used: 253 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
05-19-2009, 07:18 | #10 (permalink) | |
Member: 950201 Status: Offline Thanks Meter: 1,928 | Quote:
if u dont have flash backup then open the log and read about the flash file name (which u areased) it will be ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7312SA00-001.BIN go in infinity support and search this file through search bar | |
05-19-2009, 10:55 | #11 (permalink) |
Member: 51153 Status: Offline Sonork: 100.113241 Thanks Meter: 3,682 | FIXED with u best solution! thank you. COM14 [VCP0] selected module v2.73 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6227:8A02:8A01]... CPU: MT6227 high speed boot On chip: 0031:7407:07A1 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6227,E02 Date: 2005.04.12 Version: 1.0 Version: 7S7312SA00-001-R1C Version: EP1 detecting structure #2... done 60 byte(s) read imei: 35283401017682 connection Ok building list... done items to clear: 209 warning: wrong packet cs warning: wrong packet cs items cleared: 209 of 209 building list... done items remains: 0 Finished, time used: 39 sec Remove/Install battery now ! |
lg kg300 format ffs Fail | gsm-world | Infinity-Box | 15 | 03-13-2011 02:14 |
Lg Kg300 Format with Pinfinity | alfox | Infinity-Box | 4 | 07-08-2009 08:26 |
Lg Kg300 Dead after format | adnanskyland | SpiderMan | 3 | 12-25-2008 06:30 |
lg kg300 restarting solved with format also pinfinding with pinfinder | joni_rajpura | Infinity-Box | 3 | 12-09-2008 14:01 |
plz add lg kg300 unlock and format ffs option in next update | rajabrotherscom | Infinity-Box | 1 | 05-08-2007 12:19 |
