t280i is successfully unlocked Great Great Great work by INFINITY I unlocked T303 & T280i by infinity here is the LOG of T208i module v1.32 Device: Sony-Ericsson-T280i "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb Check hardware done Read data ... reading Sony-Ericsson-T280i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T280i_eeprom_calibration-1_20090221-120619.80E.bin Read data done Check data ... Check data done Write ... ........................ flash: 89890400040089:89890400000000 Write: simlock Write done Finished, time used: 228 sec Remove/Install battery now ! |
Great infinity team, always working!!! thanks for post your results!!! |
Even model which were not unlockable can be unlocked by infinity? like t303 |
==== log: [2/2/2009 2:26:21 PM] ==== COM14 [VCP0] selected module v1.30 Device: Sony-Ericsson-K330 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb Check hardware done Read data ... reading Sony-Ericsson-K330_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K330_eeprom_calibration-1_20090202-142846.80E.bin Read data done Check data ... Check data done Write ... ......................... flash: 89890400040089:89890400000000 Write: simlock Write done Finished, time used: 187 sec Remove/Install battery now ! ! |
==== log: [2/2/2009 2:37:38 PM] ==== COM14 [VCP0] selected module v1.30 Device: Sony-Ericsson-T303 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb software version: 1210-4091 software version: R2BB012 Check hardware done Read data ... reading Sony-Ericsson-T303_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T303_eeprom_calibration-1_20090202-143943.80E.bin Read data done Check data ... Check data done Write ... ............................ flash: 89890400040089:89890400000000 Write: simlock Write done Finished, time used: 180 sec Remove/Install battery now ! |
thanks you !!!!!!!!11 |
which cable u used ? |
pls dose it work with the new versions too pls let me no thanks |
which software u used ? |
which cable??? k750 ??? |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: http://www.infinity-box.com/download...shell_v126.jpg Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
Dear infinity team i get the following error while unlocking T280i COM8 [VCP0] selected module v1.34 Device: Sony-Ericsson-T280i "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 47 sec Remove/Install battery now ! soln please |
Hello, It looks like it's new CPU type that is not supported yet. |
