t33i incoming call ring problem i have a problem in my mobile which model is t33i.when i listen music ringer and loud speaker work correct.when call come in my mobile no ring i listen in my mobile.no handsfree mode and no silent mode.i much worried.any one can help me?this is file name (GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.DSX809_ COSTDOWN_ENG_01.BIN) |
hello! start from formating FFS |
0k with safe mode COM5 [VCP1] selected module v3.04 Action: reset settings ("format ffs") Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8103:0006 status: FF Connecting at 19200, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs error: can not finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 2 min 16 sec Remove/Install battery now ! |
and with complete mode COM5 [VCP1] selected module v3.04 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8103:0006 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #04 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #05 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #06 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #07 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 08/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.05071681.[GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.DSX809_C OSTDOWN_ENG_01.BIN_50C76E33].rpl rom info detection finished ==================== New firmware detected (v.3.04, database date: unknown): GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.DSX809_C OSTDOWN_ENG_01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: 05071681 rom info ver: 05 sw version: GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.DSX809_C OSTDOWN_ENG_01.BIN project-id: DSX809_Costdown_Eng_01, 336EC750 code offset: 00000000 ffs offset/size [01]: 00770000/00090000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00770000 standard ffs/eeprom offset confirmed: 00770000 detecting ffs/eeprom size... ffs/eeprom size: 00090000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00770000-007FFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.DSX809_C OSTDOWN_ENG_01__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\GINWAVE25_08A_GEM INI_PCB01_GSM_MT6225_S00.DSX809_COSTDOWN_ENG_01__f fs_20100101-141141.B0E.bin flash: EC257E25062501:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25062501:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\G INWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.DSX809_CO STDOWN_ENG_01__system_log_05071681_50C76E33_201001 01-141157.B0X.bin Finished, time used: 2 min 21 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On |
hello! does format FFS solved your problem? |
hello! i can only advice to try some similar flash file from support |
i have same problem in fxd t33i, is any 1 have solution ? please share for us , good working flash files for this model share please |
i tryed all thing but the same safe mode complete mode repair security infinity team pls add firmware in support |
hello! we upload to support all files which we have. If there is no such file- we dont have it to take from. try to find same, but working phone on local market. read out backup and try to flash your faulty phone |
