08-31-2022, 13:16 | #1 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Tacno KG5j Not Cannnect Code: Operation : Identify Device [ v2.35 ] Mode : FLASH Deep Info: On Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN : MediaTek PreLoader USB VCOM (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack... PRELOADER : ACK confirmed BROM : Init BROM BROM init passed CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT Mode: 0 State: 6 Core: 0 AGENT : Tecno : RAPHAEL_v2 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : MTK_AllInOne_DA_V2.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM : Reset Interface PTFN : MediaTek PreLoader USB VCOM (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack... PRELOADER : ACK confirmed BROM : Init BROM BROM init passed CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT Mode: 0 State: 6 Core: 0 AGENT : Tecno : RAPHAEL_v2 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : MTK_AllInOne_DA_V2.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM : 0x00007024 : DA SEND ERROR ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol >>> Remove battery and cable. Check cable/connection/drivers and repeat operation! Reconnect Power/Cable now Code: Operation : Identify Device [ v2.35 ] Mode : FLASH Deep Info: On Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN : MediaTek PreLoader USB VCOM (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack... PRELOADER : ACK confirmed BROM : Init BROM BROM init passed CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT Mode: 0 State: 6 Core: 0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM : Reset Interface PTFN : MediaTek PreLoader USB VCOM (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack... PRELOADER : ACK confirmed BROM : Init BROM BROM init passed CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT Mode: 0 State: 6 Core: 0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM : 0x00007024 : DA SEND ERROR ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol >>> Remove battery and cable. Check cable/connection/drivers and repeat operation! Reconnect Power/Cable now |
08-31-2022, 14:28 | #2 (permalink) |
Registered User Join Date: Aug 2016 Location: Multan Pakistan
Member: 2608490 Status: Offline Thanks Meter: 921 | Hello Please Go To Platform Apply Infinity FireFly & Repeat Operation. connect Phone in Brom mode with Both Vol Pressed. What is the result ? |
The Following User Says Thank You to GSM AR For This Useful Post: |
09-02-2022, 17:43 | #3 (permalink) |
Freak Poster Join Date: Jul 2014 Location: Tanzania
Member: 2231042 Status: Offline Thanks Meter: 65 | Hello; If your mobile phone software version is v5xx you need to use test point. If software is lower up to v4xx tick Local SLA and connect with vol- & Vol+ together. |
The Following User Says Thank You to MimiTena For This Useful Post: |
10-04-2022, 19:43 | #7 (permalink) |
No Life Poster Join Date: Sep 2010
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | https://forum.gsmhosting.com/vbb/f29...l#post14655640 the same problem |
10-04-2022, 19:44 | #8 (permalink) |
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | help https://forum.gsmhosting.com/vbb/f29...l#post14655640 the same problem i think not hardware problem broom blocked |
10-16-2022, 11:17 | #12 (permalink) |
Junior Member Join Date: Oct 2018
Member: 2872983 Status: Offline Thanks Meter: 5 | TECNO KG5J BROM ERROR FIX TESTPOINT IS THERE FREEE https://www.youtube.com/watch?v=na7SnO9LOy8 |
10-16-2022, 11:17 | #13 (permalink) |
10-16-2022, 11:20 | #14 (permalink) |
10-16-2022, 11:21 | #15 (permalink) |
The Following 2 Users Say Thank You to Charstone For This Useful Post: |
