Old 12-05-2008, 15:20   #1 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
subject: touchscreen calibration failed : New firmware detected (2.70)
==== log: [12/5/2008 6:00:56 PM] ====
COM6 [VCP0] selected
module v2.70
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:6054:2793
high speed boot Off
boot packet size: 0002
Release Power button now !
Boot Done
Initialize ...
flash: 04227E22212200:2CEA0000000000
flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.25A1DA4D.[QVGA_PCB01_GPRS_MT6226_S01.SC_7787_JBO_CSTAR_EN_AB RI_V1_3_26B_20071022.BIN_FA15095E].rpl
New firmware detected (2.70) :
- make "Read full flash" operation
- send "system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 25A1DA4D
identification#1 protocol ver: 04
ver. sw 1: QVGA_PCB01_GPRS_MT6226_S01.SC_7787_JBO_CSTAR_EN_AB RI_V1_3_26B_20071022.BIN
ver. sw 2: SC_7787_JBO_CSTAR_EN_ABRI_V1.3_26B_20071022, A1F6EA05
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_25A1DA4D_QVGA_PCB01_GPRS_MT6226_S01.SC_7 787_JBO_CSTAR_EN_ABRI_V1_3_26B_20071022.BIN_FA1509 5E_20081205-180217.B0X.bin
Finished, time used: 68 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
==== log: [12/5/2008 6:03:03 PM] ====
module v2.70
Action: touchscreen calibration
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6226
high speed boot Off
Connecting, wait...
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: SC_7787_JBO_CSTAR_EN_ABRI_V1.3_26B_20071022
Version: KP26_06B_HW
detecting structure #2...
0 done
44 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
detecting structure #5 (mode-4)...
1 2 3 4 5 6 7 8 9 11 12 13 14 15 16 17 18 19error:
detection failed (18 tries)
What to do:
Try another calibration method, if still no luck:
1. make full flash backup for emergency case
2. make "format ffs"
3. Power-On phone
4. Power-Off phone by "Power" button (do NOT remove battery)
5. Repeat "Calibration" operation again
6. if still no luck read full flash and send to support with subject: touchscreen calibration failed
error: can't read required data
error: operation failed !
Finished, time used: 10 sec
==== log: [12/5/2008 6:03:27 PM] ====
module v2.70
error: can't activate test mode
Finished, time used: 2 sec
==== log: [12/5/2008 6:03:46 PM] ====
module v2.70
19200 autodetect
CPU: MT6226
high speed boot Off
Connecting, wait...
Date: 2005.04.12
Version: 1.0
0 done
44 byte(s) read
connection Ok
detecting structure #5 (mode-3)...
done
158 byte(s) read
writing data...
verification...
error: verification failed
Finished, time used: 14 sec
==== log: [12/5/2008 6:04:13 PM] ====
module v2.70
19200 autodetect
CPU: MT6226
high speed boot Off
Connecting, wait...
Date: 2005.04.12
Version: 1.0
0 done
44 byte(s) read
connection Ok
detecting structure #5 (mode-2)...
1 2 3 4 5 6 7 8 9 10warning: wrong packet cs
11 done
146 byte(s) read
reading data #2...
reading data #3...
Finished, time used: 44 sec
==== log: [12/5/2008 6:05:06 PM] ====
module v2.70
19200 autodetect
CPU: MT6226
high speed boot Off
Connecting, wait...
Date: 2005.04.12
Version: 1.0
0 done
44 byte(s) read
connection Ok
detecting structure #5 (mode-1)...
0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19error:
detection failed (20 tries)
What to do:
3. Power-On phone
Finished, time used: 88 sec
==== log: [12/5/2008 6:07:05 PM] ====
module v2.70
Action: read NOR flash
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
high speed boot Off
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
device-id: 25A1DA4D
ffs chip: 00
reading: flash[QVGA_PCB01_GPRS_MT6226_S01.SC_7787_JBO_CSTAR_EN_AB RI_V1_3_26B_20071022.BIN]...
file saved: C:\Documents and Settings\Mano Billy\My Documents\flash[QVGA_PCB01_GPRS_MT6226_S01.SC_7787_JBO_CSTAR_EN_AB RI_V1_3_26B_20071022.BIN]_20081205-181521.B0M.bin
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_25A1DA4D_QVGA_PCB01_GPRS_MT6226_S01.SC_7 787_JBO_CSTAR_EN_ABRI_V1_3_26B_20071022.BIN_FA1509 5E_20081205-181548.B0X.bin
Finished, time used: 521 sec
here is the link
Faisal_Computer
Old 12-06-2008, 13:57   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what is full model name?
s3 touchscreen calibration failed... gsmsikar Infinity-Box 6 08-07-2009 07:59
Ztc N328 touchscreen calibration failed KK Mobile Infinity-Box 1 05-06-2009 20:20
Calibration Mode Falied New firmware detected. Shakeel_pattoki Infinity-Box 5 04-18-2009 00:28
<<< China A666 Touchscreen Calibration Failed >>> khadim100 Infinity-Box 2 04-05-2009 11:36
Touchscreen calibration failed in N99i lie_james Infinity-Box 1 01-23-2009 19:40
Page generated in 0.20045 seconds with 9 queries
