Old 05-17-2017, 09:35   #1 (permalink)
aqeelrovi's Avatar
Member: 1000101
Thanks Meter: 13
Red face huawei y5ii dead after try frp reset? with log . any soultion plz.need factory file
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 110100303038473730001954A2F973A5
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00:00:07
Reconnect Power/Cable!
Old 05-17-2017, 10:05   #2 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME( /-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00:00:07
No operation done to your phone,check your battery and SELECT "FRP PROTECTION"
Old 05-17-2017, 13:51   #3 (permalink)
aqeelrovi's Avatar
Member: 1000101
Thanks Meter: 13
Red face
[QUOTE=Kirumira;12503382]No operation done to your phone,check your battery and SELECT "FRP PROTECTION"[/Q battery fully charge but phone not power on . only take 7 amp on supply. bro you have factory file>?
Old 05-17-2017, 16:52   #4 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Try Google for Factory file.
Old 05-18-2017, 07:47   #5 (permalink)
aqeelrovi's Avatar
Member: 1000101
Thanks Meter: 13
many try but only find dload update file no factory
Old 05-18-2017, 08:20   #6 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
even no warning message.
still no update or at least bug fix since some month.
Old 05-18-2017, 08:36   #7 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
repair files
https://yadi.sk/d/gBnzuLGN3G7M6Y
and here another file:
https://yadi.sk/d/SOrS24ic3GC5eR
choose Download-Agent DA_SWSEC.bin from 807_sec_da folder.
thx goes to 4pda.ru
The Following 3 Users Say Thank You to BouRRi_GSM For This Useful Post:
Old 05-20-2017, 12:40   #8 (permalink)
aqeelrovi's Avatar
Member: 1000101
Thanks Meter: 13
Originally Posted by BouRRi_GSM View Post
repair files
thx goes to 4pda.ru
second file part2????
The Following User Says Thank You to aqeelrovi For This Useful Post:
Old 05-23-2017, 13:07   #9 (permalink)
aqeelrovi's Avatar
Member: 1000101
Thanks Meter: 13
Red face inferano suported huawei y5ii mt 6582?? factory file no write this?
repair files
thx goes to 4pda.ru
inferano suported huawei y5ii mt 6582?? factory file no write this? merpi also?
Old 05-24-2017, 06:05   #10 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
This is part 2
https://yadi.sk/d/JYhmrVgr3GCTV5
And use SP_Flash_Tool_exe_Windows_v5.1548.00.000-secure
Those file are from 4pda.ru
The Following User Says Thank You to BouRRi_GSM For This Useful Post:
Old 05-24-2017, 07:00   #11 (permalink)
Nasir Mobiles's Avatar
Member: 355782
Thanks Meter: 1,265
init preloader hope this will save you from full flashing and further issues.
Y5II (CUN-U29) Preloader
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:07
Old 05-24-2017, 11:03   #12 (permalink)
aqeelrovi's Avatar
Member: 1000101
Thanks Meter: 13
Red face huawei y5ii frp lock which device remove?
repair files
thx goes to 4pda.ru
y5ii problem solve thanks bro very much. now frp lock show which device suported merapi& inferano & cm2 ? i have two device?
Old 05-24-2017, 17:07   #13 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
Search youtube and unlock free with screenshot trick.
Page generated in 0.24159 seconds with 8 queries
