Old 06-29-2020, 14:10   #1 (permalink)
lionfinger2007's Avatar
Member: 576282
Thanks Meter: 145
Tecno Camon X Air (CX Air) Hangs on Tecno Logo After Reset, how to solve?
I have this tecno Camon X Air (CX Air) that the owner wanted to flash but the phone is working only that he complain of the phone been slow whenever the data is on!
I did SmartAv with "Clean UserData" option marked and also full reset and after that the phone is now hanging in Tecno logo.
The build of the phone is CXAir-H3713A-N-190614V169 but the file of the phone I have is CXAir-H3713A1-N-170411V92, please if I flashed it with it, will the phone be ok?
Identification log;
Card found : S/N : B25B7C49 , v0137
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 4500017045434148091201415BAFBF2A
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , AECAH
[eMMC] : FLASH_CID : 7001004548414345410112092ABFA45B
[eMMC] : FLASH_LEN : 0x0000000390000000
[eMMC] : FLASH_UCP : 14592 MiB [eMMC 16 GiB]
DEV RID : 0xCA0D485B9C5D1DD106AD8C1459781E76
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : TECNO
ProdName : H3713
ProdModel : TECNO CX Air
Device : TECNO-CX-Air
AndroidVer: 7.0
MTKxCPU : MT6737M
MTKxPRJ : CXAir-H3713A-N-190614V169
Done!
Elapsed: 00:00:09
Reconnect Power/Cable!
Reseting Log;
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:45
Old 06-30-2020, 12:08   #2 (permalink)
babarmughal's Avatar
Member: 2609063
Thanks Meter: 100
in setting use WIPE, or use phone recovery and delete data/cache reboot.
result ?
Old 06-30-2020, 12:46   #3 (permalink)
Member: 576282
Thanks Meter: 145
result ?
Do you mean in CM2 settings?
Because if you mean in phones settings, the phone is not coming on complete again, it only hangs on Tecno logo and I try to put it into recovery and from there I delete cache, but the problem was not solved, is still hanging on Tecno logo and also if I want to do full reset from recovery mode, it will not reset, rather the phone will just restart and still on Tecno logo still.
Please somebody help me out!
Old 06-30-2020, 21:31   #4 (permalink)
Member: 2955840
Thanks Meter: 67
The two build numbers are not the same CXAir-H3713A and CXAir-H3713A1 except you made mistake.
Old 06-30-2020, 23:44   #5 (permalink)
Member: 2251589
Thanks Meter: 33
Auto format with miracle it will solve,next time reset frp alone and hardreset with buttons.or use cm2t2 meta mode reset
Old 07-01-2020, 14:54   #6 (permalink)
Member: 576282
Thanks Meter: 145
I did that but the problem still there!
Do anybody have file of the exact build of that phone please (I mean this exact file "CXAir-H3713A-N-190614V169")?
Old 07-01-2020, 20:14   #7 (permalink)
Member: 2955840
Thanks Meter: 67
Search online you will see. Always use google
Old 07-03-2020, 13:29   #8 (permalink)
Member: 576282
Thanks Meter: 145
Please somebody that have CXAir-H3713A-N-190614V169 should help me out, I read the firmware of the phone and use cm2 to flash it back and now the phone is not coming on.
Below are the flashing logs;
Scatter Load Ok , BaseBand : MT6735 , Project : rlk6737m_65_n , Storage : EMMC
Files found : 11 , Set to Flash : 10
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : TECNO
Device Model : TECNO-CX-Air
Device CPU : MT6737M
Device IntName : H3713
Device Version : 7.0
Device Compile : 6/14/2019 2:14:06 AM
Device Project : CXAir-H3713A-N-190614V169
Device ExtInfo : TECNO CX Air
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6735 , Project : rlk6737m_65_n , Storage : EMMC
Setting : Flash Pre-Erase : Off ( Write Flash Only )
Setting : AFF verify : Disabled
Setting : HW verify : Disabled
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : 4212 mV
BL : BatteryLevel Ok
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_rlk6737m_65_n.bin
Preloader Sent , Init passed
PartCount : 0016
Use FLN Mode
Processing : Flash Write
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : TEE1
Image Flash Ok
Flash now : TEE2
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USERDATA
Image Flash Ok
Flash Write Done, time used : 00:15:21
Update RomInfo done
Done!
Elapsed: 00:15:45
======= Flash
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check eMMC compatibility
BL : BatteryLevel : 4210 mV
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001C80000-0x0000000004D80000
Erase : 0x0000000006B00000-0x0000000388480000
Flash Pre-Erase Done, time used : 00:00:03
PartCount : 0016
Update PMT by user request
Repartition Done!
Use FLN Mode
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : TEE1
Image Flash Ok
Flash now : TEE2
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Image Flash Ok
Flash Write Done, time used : 00:09:24
Processing : Verify
Verify Passed : LK
Verify Passed : BOOT
Verify Passed : RECOVERY
Verify Passed : LOGO
Verify Passed : SECRO
Verify Passed : TEE1
Verify Passed : TEE2
Verify Passed : SYSTEM
Verify Passed : CACHE
Verify Passed : USERDATA
Data Verify Done, time used : 00:00:58
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:10:47
======= Flash
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
PartCount : 0016
Use FLN Mode
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : TEE1
Image Flash Ok
Flash now : TEE2
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Image Flash Ok
Flash Write Done, time used : 00:08:37
Update RomInfo done
Done!
Elapsed: 00:08:58
Old 07-04-2020, 00:14   #9 (permalink)
Member: 2955840
Thanks Meter: 67
Cx air
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
PartCount : 0016
Use FLN Mode
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : TEE1
Image Flash Ok
Flash now : TEE2
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Image Flash Ok
Update RomInfo done
Done!
Elapsed: 00:15:45
======= Flash
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
PartCount : 0016
Repartition Done!
Use FLN Mode
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : TEE1
Image Flash Ok
Flash now : TEE2
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Image Flash Ok
Processing : Verify
Verify Passed : LK
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:10:47
======= Flash
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
PartCount : 0016
Use FLN Mode
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : TEE1
Image Flash Ok
Flash now : TEE2
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Image Flash Ok
Update RomInfo done
Done!
Elapsed: 00:08:58
Whenever you wanted to flash with cm2mtk,make sure you untick pre-erase and tick skip preloader.
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.22553 seconds with 7 queries
