tecno h6 flashed but not coming on, please what to do? This phone was not coming on and I flashed it, it flashed complete but still not coming on, what could be the problem? Below is flashing log; Card found: S/N B25B:0128 Chinese Miracle II [MTK module] v 1.24 Scatter Load Ok , BaseBand : MT6582 , Project : ratech82_cwet_rlk_kk , Storage : EMMC Files found : 12 , Set to Flash : 11 Ready to Flash! Operation : Flash [ v1.24 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100513758534142016B77E7E681BB DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BASX7 [eMMC] : FLASH_CID : 150100513758534142016B77E7E681BB [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : ratech82_cwet_rlk_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000000000-0x0000000000100000 Erase : 0x0000000001D00000-0x000000014B280000 Flash Pre-Erase Done, time used : 00:00:09 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_ratech82_cwet_rlk_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:05:42 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:06 Update RomInfo done Done! Elapsed: 00:06:17 Reconnect Power/Cable! |
Hello. By the log all seems as ok. Try flash also with SPFT to make sure in correct ( I still not test enough 6582 ) , and if same - erase phone and reflash. Make NVRAM backup before. |
Thanks, but please what is SPFT and how will I use that? |
SP Flash Tool. Use v5.14xx or newer. CM2 read files, which compatible with SPFT fully. |
Thanks, it worked with SP-Flash-Tool-v5.1528.00 and the phone is coming on now and working fine. Others, please you can get the setup here |
Unfortunately - just phisycally and financial sides can't allow me collect much different samples to test all. If you will face any branded model ( like alcatel and e.t.c. , which are WW and possible find it in Europe/Asia - then I can get it. |
What you mean by "which are WW "? |
Hello, WW stands here for World Wide. Br. |
