07-15-2017, 11:16 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Hatfield Harare Zimbabwe Age: 42
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | TECNO J8 cant write fac Firmware Help Read info: Code: Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333145FA1A0D428FB7DC4E Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:01:04 Reconnect Power/Cable! Code: Scatter Load Ok , BaseBand : MT6735 , Project : rlk6735_65u_1_l1 , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : TECNO Device Model : TECNO-J8 Device CPU : MT6735 Device IntName : TECNO-J8 Device Version : 5.1 Device Compile : 3/10/2016 4:24:42 PM Device Project : J8-H354-C1-L-HiOS-20160310 Device ExtInfo : TECNO-J8 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333145FA1A0D428FB7DC4E Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:36 Reconnect Power/Cable! Code: User selected Preloader file : preloader_rlk6735_65u_1_l1.bin Operation : Init Preloader [ v1.58 ] Supported HW by Preloader : FlashID [0] CID : 90014A484147326505 , Name : HAG2e , Vendor : 90 , [HYNIX] FlashID [1] CID : 150100513832334D42 , Name : Q823MB , Vendor : 15 , [SAMSUNG] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333145FA1A0D428FB7DC4E Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:24 Reconnect Power/Cable! |
07-15-2017, 13:28 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Then it can mean there is 2 revisions with different RAM memory ammount ( 512 - 1024 ) or device RAM not alive at all. There should be combo eMCP. |
10-23-2017, 22:37 | #7 (permalink) |
Freak Poster Join Date: Aug 2014 Location: Tanzania
Member: 2239923 Status: Offline Thanks Meter: 48 | I NEED THIS FIRMWARE OR PRE-LOADER ONLY [AP] : Initial info read Ok! Brand : TECNO ProdName : TECNO-J8 ProdModel : TECNO-J8 Device : TECNO-J8 AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : J8-H354-C1-L-HiOS-20160405 THANK IN ADVANCE |
01-31-2018, 13:03 | #8 (permalink) |
No Life Poster Join Date: Oct 2013 Location: Cote Ivoire ABJ,tvlle, LBJ.23 Age: 39
Member: 2041210 Status: Offline Thanks Meter: 541 | bro i have same problem hang logo after flash it is dead i have flash with more 5 frmw same one , i have try same flash file in BIN ( 16go ) alway dead , i have remove emmc to all ecrase and write again with medusa pro and past emmc try to flash all done but alway no power .... tell me if you has solved this problem ? pls wtite me inbox |
02-02-2018, 08:42 | #9 (permalink) | |
Member: 2239923 Status: Offline Thanks Meter: 48 | Quote:
J8-H354-C1-L-HiOS-20160506 J8-H354C1-L-160721V14 J8-H354C1-L-160907V32 | |
