Tecno kc8 spark 4 hang and restart ineed help overcome this problem. ihave tried all files on support but this phone has failed to power on normally. what should ido. original file was this MT6761__TECNO_MOBILE_LIMITED__TECNO_KC8__9__KC8-H6110LMN-P-200617V205__PPR1.180610.011__kc8_h6110 itried this on support KC8-H6110LMN-P-201207V232 but phone failed to power on normally. |
Card found : xxxxxx , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.28 Load IDBase v98353 Ok! Update configuration ... Update Ok! Load IDBase v98353 Ok! Operation : Identify [ v2.28 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM6) MODE : PRELOADER PORT PORT : 6 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : TECNO : SEC_MIXED | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 880103534C443332475507AE32241705 EMMC: VEN : FORESEE : OEM : 3 : ID : 534C44333247 EMMC: VEN : FORESEE : SLD32G EMMC: SNN : 128856612 ( 0x07AE3224) , MF : 1/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x73A000000 [ 28.91 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 263B8A0E2D6DDEEDA853E3AA5A060B7 DA : USB : HIGH-SPEED Boot done! USERDATA : EMPTY NVRAM : TK_MD_BASIC_MDBIN_PCB01_MT6761_S00.MOLY_LR12A_R3_M P_V71_11_P22 NVRAM : Damaged! Backup sensetive data [ 16 ] Backup path : Backup\MT6761__263B8A0E2D6DDEED0A853E3AA5A060B7\ [12] Read : NVRAM [37] Read : NVDATA [29] Read : PROINFO [13] Read : LK [36] Read : NVCFG [24] Read : PROTECT1 [25] Read : PROTECT2 [1] Read : PGPT [23] Read : PERSIST [0] Read : PRELOADER Backup done! STORAGE : Life Status : eMMC : NOT implemented in selected DA! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:28 Preloader [HW DEV] Info : EMI : DEV : MT6761 EMI : SRC : preloader_kc8_h6110.bin EMI : CNT : 000D EMI : [00] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 512.00 MB ] EMI : [01] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 150100464536324D42 : VEN : SAMSUNG | DEV : FE62MB : RAM : [ 1.00 GB ] EMI : [03] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [04] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [05] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [06] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [07] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [08] : DRAM : LP_DDR4 : ID : 88 : VEN : FORESEE | DEV : : RAM : [ 1.00 GB ] EMI : [09] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [0A] : DRAM : LP_DDR4 : ID : 70 : VEN : KINGSTON | DEV : : RAM : [ 1.00 GB ] EMI : [0B] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [0C] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] Operation : Write Flash [ v2.28 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :22 [FL] : Set : preloader_kc8_h6110.bin [FL] : Set : md1img-verified.img [FL] : Set : spmfw-verified.img [FL] : Set : scp-verified.img [FL] : Set : scp-verified.img [FL] : Set : sspm-verified.img [FL] : Set : sspm-verified.img [FL] : Set : lk-verified.img [FL] : Set : lk-verified.img [FL] : Set : boot.img [FL] : Set : logo-verified.bin [FL] : Set : dtbo-verified.img [FL] : Set : tee-verified.img [FL] : Set : tee-verified.img [FL] : Set : vendor.img [FL] : Set : system.img [FL] : Set : vbmeta.img [FL] : Set : cache.img [FL] : Set : recovery.img [FL] : Set : tkv.img [FL] : Set : tranfs.img [FL] : Set : userdata.img [FL] : Total size : 0xC739E290 [ 3.11 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM6) MODE : PRELOADER PORT PORT : 6 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : TECNO : SEC_MIXED | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 880103534C443332475507AE32241705 EMMC: VEN : FORESEE : OEM : 3 : ID : 534C44333247 EMMC: VEN : FORESEE : SLD32G EMMC: SNN : 128856612 ( 0x07AE3224) , MF : 1/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x73A000000 [ 28.91 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 263B8A0E2D6DDEEDA853E3AA5A060B7 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000009B00000 Erase : 0x000000000DB00000 : 0x00000000DAD00000 Erase : 0x00000000EC800000 : 0x0000000014D00000 Erase : 0x0000000101800000 : 0x0000000016280000 Erase : 0x0000000119A80000 : 0x00000000C4580000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : MD1IMG Write : SPMFW Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : LK Write : LK2 Write : BOOT Write : LOGO Write : DTBO FAIL : SEC : IMG TYPE MISMATCH Write : TEE1 Write : TEE2 Write : VENDOR Write : SYSTEM Write : VBMETA Write : CACHE Write : RECOVERY Write : TKV FAIL : SEC : IMG TYPE MISMATCH Write : TRANFS Write : USERDATA Ultra : OK! [ All failed parts successfully flashed ] SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:02:21 Reconnect Power/Cable! |
